Node.js: Cannot find module
seit gestern ist mein iobroker (inkl. vis) nur sporadisch erreichbar.
Im Log wiederholt sich folgender Fehler ständig:
host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
Hat jemand ne Idee, warum das so spontan kommen kann und wie ich das beheben könnte?
Dominic
Kam das wirklich spontan, oder nach einem update?
UND:
@Communicate:host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module) `
da müsste auch noch stehen welches modul
493_history_mit_24h.jpg -
es kam spontan und danach habe ich dann per iobroker upgrade alles aktualisiert.
So sieht das Log aus:
raspberrypi 2015-09-28 20:47:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:47:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:47:04 info host.raspberrypi instance system.adapter.admin.1 started with pid 9292
raspberrypi 2015-09-28 20:46:34 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:46:34 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:46:29 info host.raspberrypi instance system.adapter.admin.1 started with pid 9291
raspberrypi 2015-09-28 20:45:59 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:45:59 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:45:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9290
raspberrypi 2015-09-28 20:45:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:45:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:45:19 info host.raspberrypi instance system.adapter.admin.1 started with pid 9289
raspberrypi 2015-09-28 20:44:49 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:44:49 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:44:39 info host.raspberrypi instance system.adapter.admin.1 started with pid 9288
raspberrypi 2015-09-28 20:44:09 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:44:09 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:44:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:44:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:44:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9287
raspberrypi 2015-09-28 20:43:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:43:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:43:26 info host.raspberrypi instance system.adapter.admin.1 started with pid 9286
raspberrypi 2015-09-28 20:42:56 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:42:56 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:42:46 info host.raspberrypi instance system.adapter.admin.1 started with pid 9285
raspberrypi 2015-09-28 20:42:16 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:42:16 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:42:06 info host.raspberrypi instance system.adapter.admin.1 started with pid 9284
raspberrypi 2015-09-28 20:41:36 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:41:36 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:41:28 info host.raspberrypi instance system.adapter.admin.1 started with pid 9283
raspberrypi 2015-09-28 20:40:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:40:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:40:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9282
raspberrypi 2015-09-28 20:40:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:40:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:40:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
raspberrypi 2015-09-28 20:40:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
raspberrypi 2015-09-28 20:39:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:39:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:39:44 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:39:44 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:39:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9280
raspberrypi 2015-09-28 20:39:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:39:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:38:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9279
raspberrypi 2015-09-28 20:38:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:38:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:38:21 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
raspberrypi 2015-09-28 20:38:20 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
raspberrypi 2015-09-28 20:37:50 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:37:50 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:37:38 info host.raspberrypi instance system.adapter.admin.1 started with pid 9277
raspberrypi 2015-09-28 20:37:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:37:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:37:02 info host.raspberrypi instance system.adapter.admin.1 started with pid 9276
raspberrypi 2015-09-28 20:36:32 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:36:32 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:36:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9275
raspberrypi 2015-09-28 20:35:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:35:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:35:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:35:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:35:50 info host.raspberrypi instance system.adapter.admin.1 started with pid 9274
raspberrypi 2015-09-28 20:35:20 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:35:20 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:35:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9273
raspberrypi 2015-09-28 20:34:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:34:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:34:33 info host.raspberrypi instance system.adapter.admin.1 started with pid 9272
raspberrypi 2015-09-28 20:34:03 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:34:03 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:33:57 info host.raspberrypi instance system.adapter.admin.1 started with pid 9271
raspberrypi 2015-09-28 20:33:27 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:33:27 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:33:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9270
raspberrypi 2015-09-28 20:32:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:32:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:32:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9269
raspberrypi 2015-09-28 20:32:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:32:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:31:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9268
raspberrypi 2015-09-28 20:31:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:31:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:31:16 info host.raspberrypi instance system.adapter.admin.1 started with pid 9267
raspberrypi 2015-09-28 20:30:46 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:30:46 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:30:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9266
raspberrypi 2015-09-28 20:30:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:30:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:29:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9265
raspberrypi 2015-09-28 20:29:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:29:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:29:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
raspberrypi 2015-09-28 20:29:13 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
raspberrypi 2015-09-28 20:28:43 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:28:43 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:28:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9263
raspberrypi 2015-09-28 20:28:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:28:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:28:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9262
raspberrypi 2015-09-28 20:27:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:27:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:27:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9261
raspberrypi 2015-09-28 20:26:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:26:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:26:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9260
raspberrypi 2015-09-28 20:26:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:26:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:26:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9259
raspberrypi 2015-09-28 20:25:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:25:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
raspberrypi 2015-09-28 20:25:38 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
raspberrypi 2015-09-28 20:25:38 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:25:26 info instance system.adapter.admin.1 started with pid 9258
host-raspberrypi 2015-09-28 20:24:56 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:24:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:24:49 info instance system.adapter.admin.1 started with pid 9257
host-raspberrypi 2015-09-28 20:24:19 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:24:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:24:07 info instance system.adapter.admin.1 started with pid 9256
host-raspberrypi 2015-09-28 20:23:37 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:23:37 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:23:33 info instance system.adapter.admin.1 started with pid 9255
host-raspberrypi 2015-09-28 20:23:03 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:23:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:22:59 info instance system.adapter.admin.1 started with pid 9254
host-raspberrypi 2015-09-28 20:22:29 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:22:29 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:22:25 info instance system.adapter.admin.1 started with pid 9253
host-raspberrypi 2015-09-28 20:21:55 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:21:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:21:49 info instance system.adapter.admin.1 started with pid 9252
host-raspberrypi 2015-09-28 20:21:19 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:21:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:21:14 info instance system.adapter.admin.1 started with pid 9251
host-raspberrypi 2015-09-28 20:20:44 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:20:44 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:20:38 info instance system.adapter.admin.1 started with pid 9250
host-raspberrypi 2015-09-28 20:20:08 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:20:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:20:01 info instance system.adapter.admin.1 started with pid 9249
host-raspberrypi 2015-09-28 20:19:31 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:19:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:19:27 info instance system.adapter.admin.1 started with pid 9248
host-raspberrypi 2015-09-28 20:18:57 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:18:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:18:53 info instance system.adapter.admin.1 started with pid 9247
host-raspberrypi 2015-09-28 20:18:23 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:18:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:18:19 info instance system.adapter.admin.1 started with pid 9246
host-raspberrypi 2015-09-28 20:17:49 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:17:49 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:17:40 info instance system.adapter.admin.1 started with pid 9245
host-raspberrypi 2015-09-28 20:17:10 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:17:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:17:06 info instance system.adapter.admin.1 started with pid 9244
host-raspberrypi 2015-09-28 20:16:36 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:16:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:16:32 info instance system.adapter.admin.1 started with pid 9233
host-raspberrypi 2015-09-28 20:16:02 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:16:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:15:57 info instance system.adapter.admin.1 started with pid 9232
host-raspberrypi 2015-09-28 20:15:27 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:15:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:15:22 info instance system.adapter.admin.1 started with pid 9231
host-raspberrypi 2015-09-28 20:14:52 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:14:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:14:48 info instance system.adapter.admin.1 started with pid 9230
host-raspberrypi 2015-09-28 20:14:18 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:14:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:14:08 info instance system.adapter.admin.1 started with pid 9229
host-raspberrypi 2015-09-28 20:13:38 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:13:38 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:13:33 info instance system.adapter.admin.1 started with pid 9228
host-raspberrypi 2015-09-28 20:13:03 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:13:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:12:59 info instance system.adapter.admin.1 started with pid 9227
host-raspberrypi 2015-09-28 20:12:28 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:12:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:12:25 info instance system.adapter.admin.1 started with pid 9226
host-raspberrypi 2015-09-28 20:11:54 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:11:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:11:50 info instance system.adapter.admin.1 started with pid 9225
host-raspberrypi 2015-09-28 20:11:20 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:11:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:11:10 info instance system.adapter.admin.1 started with pid 9224
host-raspberrypi 2015-09-28 20:10:40 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:10:40 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:10:36 info instance system.adapter.admin.1 started with pid 9223
host-raspberrypi 2015-09-28 20:10:06 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:10:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:10:01 info instance system.adapter.admin.1 started with pid 9222
host-raspberrypi 2015-09-28 20:09:31 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:09:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:09:26 info instance system.adapter.admin.1 started with pid 9221
host-raspberrypi 2015-09-28 20:08:56 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:08:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:08:51 info instance system.adapter.admin.1 started with pid 9220
host-raspberrypi 2015-09-28 20:08:21 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:08:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:08:09 info instance system.adapter.admin.1 started with pid 9219
host-raspberrypi 2015-09-28 20:07:39 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:07:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:07:34 info instance system.adapter.admin.1 started with pid 9218
host-raspberrypi 2015-09-28 20:07:04 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:07:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:07:00 info instance system.adapter.admin.1 started with pid 9217
host-raspberrypi 2015-09-28 20:06:30 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:06:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:06:25 info instance system.adapter.admin.1 started with pid 9216
host-raspberrypi 2015-09-28 20:05:55 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:05:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:05:51 info instance system.adapter.admin.1 started with pid 9215
host-raspberrypi 2015-09-28 20:05:20 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:05:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:05:11 info instance system.adapter.admin.1 started with pid 9214
host-raspberrypi 2015-09-28 20:04:41 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:04:41 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:04:36 info instance system.adapter.admin.1 started with pid 9213
host-raspberrypi 2015-09-28 20:04:06 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:04:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:04:02 info instance system.adapter.admin.1 started with pid 9212
host-raspberrypi 2015-09-28 20:03:32 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:03:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:03:28 info instance system.adapter.admin.1 started with pid 9211
host-raspberrypi 2015-09-28 20:02:58 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:02:58 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:02:51 info instance system.adapter.admin.1 started with pid 9209
host-raspberrypi 2015-09-28 20:02:21 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:02:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:02:17 info instance system.adapter.admin.1 started with pid 9208
host-raspberrypi 2015-09-28 20:01:46 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:01:46 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:01:38 info instance system.adapter.admin.1 started with pid 9207
host-raspberrypi 2015-09-28 20:01:08 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:01:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:01:03 info instance system.adapter.admin.1 started with pid 9206
host-raspberrypi 2015-09-28 20:00:33 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 20:00:33 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 20:00:29 info instance system.adapter.admin.1 started with pid 9205
host-raspberrypi 2015-09-28 19:59:59 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:59:59 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:59:54 info instance system.adapter.admin.1 started with pid 9204
host-raspberrypi 2015-09-28 19:59:23 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:59:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:59:18 info instance system.adapter.admin.1 started with pid 9203
host-raspberrypi 2015-09-28 19:58:48 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:58:48 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:58:40 info instance system.adapter.admin.1 started with pid 9202
host-raspberrypi 2015-09-28 19:58:10 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:58:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:58:05 info instance system.adapter.admin.1 started with pid 9201
host-raspberrypi 2015-09-28 19:57:35 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:57:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:57:31 info instance system.adapter.admin.1 started with pid 9200
host-raspberrypi 2015-09-28 19:57:01 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:57:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:56:57 info instance system.adapter.admin.1 started with pid 9199
host-raspberrypi 2015-09-28 19:56:27 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:56:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:56:23 info instance system.adapter.admin.1 started with pid 9198
host-raspberrypi 2015-09-28 19:55:53 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:55:53 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:55:48 info instance system.adapter.admin.1 started with pid 9197
host-raspberrypi 2015-09-28 19:55:18 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:55:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:55:06 info instance system.adapter.admin.1 started with pid 9196
host-raspberrypi 2015-09-28 19:54:36 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:54:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:54:32 info instance system.adapter.admin.1 started with pid 9195
host-raspberrypi 2015-09-28 19:54:02 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:54:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:53:58 info instance system.adapter.admin.1 started with pid 9194
host-raspberrypi 2015-09-28 19:53:28 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:53:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:53:24 info instance system.adapter.admin.1 started with pid 9193
host-raspberrypi 2015-09-28 19:52:54 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:52:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:52:48 info instance system.adapter.admin.1 started with pid 9192
host-raspberrypi 2015-09-28 19:52:18 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:52:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:52:09 info instance system.adapter.admin.1 started with pid 9191
host-raspberrypi 2015-09-28 19:51:39 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:51:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:51:34 info instance system.adapter.admin.1 started with pid 9190
host-raspberrypi 2015-09-28 19:51:04 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:51:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:50:58 info instance system.adapter.admin.1 started with pid 9189
host-raspberrypi 2015-09-28 19:50:28 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:50:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:50:24 info instance system.adapter.admin.1 started with pid 9188
host-raspberrypi 2015-09-28 19:49:54 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:49:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:49:49 info instance system.adapter.admin.1 started with pid 9187
host-raspberrypi 2015-09-28 19:49:19 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:49:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:49:13 info instance system.adapter.admin.1 started with pid 9186
host-raspberrypi 2015-09-28 19:48:43 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:48:43 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:48:37 info instance system.adapter.admin.1 started with pid 9185
host-raspberrypi 2015-09-28 19:48:07 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:48:07 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:48:02 info instance system.adapter.admin.1 started with pid 9184
host-raspberrypi 2015-09-28 19:47:32 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:47:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:47:27 info instance system.adapter.admin.1 started with pid 9183
host-raspberrypi 2015-09-28 19:46:57 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:46:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:46:52 info instance system.adapter.admin.1 started with pid 9182
host-raspberrypi 2015-09-28 19:46:22 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:46:22 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:46:17 info instance system.adapter.admin.1 started with pid 9181
host-raspberrypi 2015-09-28 19:45:47 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:45:47 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:45:40 info instance system.adapter.admin.1 started with pid 9180
host-raspberrypi 2015-09-28 19:45:10 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:45:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:45:05 info instance system.adapter.admin.1 started with pid 9179
host-raspberrypi 2015-09-28 19:44:35 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:44:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:44:31 info instance system.adapter.admin.1 started with pid 9178
host-raspberrypi 2015-09-28 19:44:01 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:44:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:43:57 info instance system.adapter.admin.1 started with pid 9177
host-raspberrypi 2015-09-28 19:43:27 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:43:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:43:22 info instance system.adapter.admin.1 started with pid 9176
host-raspberrypi 2015-09-28 19:42:52 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:42:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:42:47 info instance system.adapter.admin.1 started with pid 9175
host-raspberrypi 2015-09-28 19:42:17 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:42:17 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:42:09 info instance system.adapter.admin.1 started with pid 9174
host-raspberrypi 2015-09-28 19:41:39 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:41:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:41:32 info instance system.adapter.admin.1 started with pid 9173
host-raspberrypi 2015-09-28 19:41:02 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:41:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:40:58 info instance system.adapter.admin.1 started with pid 9172
host-raspberrypi 2015-09-28 19:40:28 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:40:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:40:24 info instance system.adapter.admin.1 started with pid 9171
host-raspberrypi 2015-09-28 19:39:54 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:39:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:39:49 info instance system.adapter.admin.1 started with pid 9170
host-raspberrypi 2015-09-28 19:39:19 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:39:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:39:09 info instance system.adapter.admin.1 started with pid 9169
host-raspberrypi 2015-09-28 19:38:39 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:38:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:38:35 info instance system.adapter.admin.1 started with pid 9168
host-raspberrypi 2015-09-28 19:38:05 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:38:05 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:38:00 info instance system.adapter.admin.1 started with pid 9167
host-raspberrypi 2015-09-28 19:37:30 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:37:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:37:24 info instance system.adapter.admin.1 started with pid 9166
host-raspberrypi 2015-09-28 19:36:54 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:36:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:36:43 info instance system.adapter.admin.1 started with pid 9165
host-raspberrypi 2015-09-28 19:36:12 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:36:12 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:36:06 info instance system.adapter.admin.1 started with pid 9164
host-raspberrypi 2015-09-28 19:35:36 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:35:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:35:32 info instance system.adapter.admin.1 started with pid 9163
host-raspberrypi 2015-09-28 19:35:02 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:35:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:34:58 info instance system.adapter.admin.1 started with pid 9162
host-raspberrypi 2015-09-28 19:34:28 info Restart adapter system.adapter.admin.1 because enabled
host-raspberrypi 2015-09-28 19:34:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
host-raspberrypi 2015-09-28 19:34:23 info instance system.adapter.admin.1 started with pid 9161
host-raspberrypi 2015-09-28 19:33:53 info Restart adapter system.adapter.admin.1 because enabled -
so, log einträge sind weg. Ich hatte auf einmal eine zweite admin instanz.
Was auch immer ich gemacht habe, dass die auf einmal da war…
kommando zurück. jetzt kann ich gar nicht mehr auf iobroker zugreifen:
Diese Webseite ist nicht verfügbar.
ERR_CONNECTION_REFUSED
auch ein reboot hat nichts gebracht :-(
jetzt siehts so aus, als hätte ich gar keine admin instanz mehr.
Und owohl die VIS instanz ja da ist, kann ich vis auch nicht mehr aufrufen :-(
ps -A | grep io
17 ? 00:00:00 bioset
20 ? 00:00:00 rpciod
23 ? 00:00:00 nfsiod
35 ? 00:00:00 DWC Notificatio
2043 ? 00:00:11 io.js-controlle
2325 ? 00:00:09 io.web.0
2375 ? 00:00:08 io.hm-rega.0
2376 ? 00:00:07 io.hm-rpc.0
2378 ? 00:00:06 io.vis.0
reboot hatte ich schon durch.
admin neu isntallieren probiere ich gerade
das klappt leider auch nicht mehr:
dules/utf-8-validate
node-gyp rebuild
! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
CXX(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
COPY Release/validation.node
make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
node-gyp rebuild
! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
COPY Release/bufferutil.node
make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
! > utf-8-validate@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
node-gyp rebuild
! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
node-gyp rebuild
! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /opt/iobroker/npm-debug.log
npm ERR! not ok code 0und hier die npm-debug.log:root@raspberrypi:/opt/iobroker# tail /opt/iobroker/npm-debug.log
6592 error npm-@googlegroups.com6593 error System Linux 3.18.11+
6594 error command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin"
6595 error cwd /opt/iobroker
6596 error node -v v0.10.22
6597 error npm -v 1.3.14
6598 error path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/lib/permuteDomain.js
6599 error code ENOENT
6600 error errno 34
6601 verbose exit [ 34, true ]/npm-@googlegroups.com -
Da fehlt ihm eine Datei.
Versuch es mal mit:
cd /opt/iobroker npm cache clean npm install iobroker.admin --productionWenn das nicht klappt, hat mir bei einem solchen Problem mit einem anderen Adapter der Tip von versteckt geholfen, alles im Verzeichnis /tmp zu installieren und dann rüberzukopieren
…oder plattmachen
scheint erstmal geklappt zu haben. aber merkwürdig ists trotzdem…
