  4. Gelöst: WARN in Script
    5.8k
javascript
19 Beiträge 3 Kommentatoren 826 Aufrufe 1 Beobachtet
  • M michihorn
    @paul53 Ja alles da
    @michihorn
    Versuche es mal so:
    createState('Rolladen.WZ_Links');
    createState('Rolladen.WZ_Rechts');
    createState('Rolladen.EZ');
    createState('Rolladen.Küche');
    createState('Rolladen.WC');
    createState('Rolladen.Move_WZ_Links');
    createState('Rolladen.Move_WZ_Rechts');
    createState('Rolladen.Move_EZ');
    createState('Rolladen.Move_Küche');
    createState('Rolladen.Move_WC');
    var Statuswert;
    var Status;
    var Nr;
    var Kanal;
    function Rolladen(rollo, zeit) {
          setState('javascript.0.Rolladen.' + rollo, Statuswert, true);
          setState('javascript.0.Rolladen.Move_' + rollo, Status, true);
          setState('javascript.0.Rolladen.Zeitsteuerung.' + zeit + '.Nr', Nr, true);
          log(Kanal + ' ' + rollo + ' ' + Status + ' ' + Statuswert);
    on(id: 'hm-rpc.1.CUX4000002.6.RCVS', function(dp) {
          var RL = dp.state.val;
          Kanal = parseInt(RL.substr(8, 2), 16);
          Status = RL.substr(10, 2);
          Nr = parseInt(Status, 16);
          if (Status == "00") Statuswert = "No Information";
          else if (Status == "01") Statuswert = "OBEN";
          else if (Status == "02") Statuswert = "UNTEN";
          else if (Status == "03") Statuswert = "Intermediate position stop";
          else if (Status == "04") Statuswert = "Tilt/ventilation position stop";
          else if (Status == "05") Statuswert = "Blocking";
          else if (Status == "06") Statuswert = "Overheated";
          else if (Status == "07") Statuswert = "Timeout";
          else if (Status == "08") Statuswert = "Start to move up";
          else if (Status == "09") Statuswert = "Start to move down";
          else if (Status == "0A") Statuswert = "Fährt AUF";
          else if (Status == "0B") Statuswert = "Fährt AB";
          else if (Status == "0D") Statuswert = "Stopped in undefined position";
          else if (Status == "0E") Statuswert = "Top position stop which is tilt position";
          else if (Status == "0F") Statuswert = "Bottom position stop which is intermediate position";
          else if (Status == "10") Statuswert = "Switching devices switched off";
          else if (Status == "11") Statuswert = "Switching devices switched on";
          if (Kanal & 1) Rolladen('WZ_Links', 'EINS');
          if (Kanal & 2) Rolladen('WZ_Rechts', 'ZWEI');
          if (Kanal & 4) Rolladen('EZ', 'DREI');
          if (Kanal & 8) Rolladen('Küche', 'VIER');
          if (Kanal & 16) Rolladen('WC', 'FÜNF');
      @michihorn
      Weshalb erzeugst Du die Datenpunkte alle 2 Minuten neu ? Einmal genügt doch !
      Du deklarierst die Variablen Statuswert und Nr innerhalb der Schedule-Callback-Funktion. Damit sind die Variablen in dieser Funktion lokal, also unnütz deklariert, weil sie in dieser Funktion nicht verwendet werden.
      Lösche besser Zeilen 1 und 14 !
              var Kanal = RL.substr(8, 2);
      Kanal ist also ein String ! Weiter unten vergleichst Du Kanal mit Zahlen.
      Hat es einen Grund, warum Du ausgerechnet mit den Zahlen 01, 02, 04, 08 und 10 vergleichst ?
      M Online
      M Online
      michihorn
      @paul53 Ich checke alle 2 Minuten den Status den mir der Elero-Stick anbietet. Könnte ja sein das ein Rollo per Handfernbedienung betätigt wird. Der Kanal ist das entsprechende Rollo, eigentlich eine Zahl, ich habe mehrere Versuche gemacht diese Warnmeldung raus zu bekommen, daher ist es wohl noch einmal eine Zahl und da wieder ein String.
        @michihorn
        M Online
        M Online
        michihorn
        @paul53 sagte in WARN in Script:
        Das gibt die Elero Doku so vor:
        Easy Control Transmitter Stick.pdf
        • M michihorn
          @michihorn sagte:
          Das machst Du im 2-Minuten-Schedule nicht, sondern es wird nur createState() (Datenpunkte erzeugen) ausgeführt.
          • M Online
            M Online
            michihorn
            schrieb am zuletzt editiert von michihorn
            Stimmt die Schedule sollte direkt vor dem eigentlichen Script sein.
              @michihorn sagte:
              M Online
              M Online
              michihorn
              @paul53 DerDatenpunkt "hm-rpc.1.CUX4000002.6.RCVS" wird von den Elero-Stick geschrieben, dort steht der Status des jeweiligen Rollo drin.
              • M michihorn
                @michihorn sagte:
                Der Datenpunkt dient als Trigger, dann solltest Du kein Schedule verwenden.
                • M Online
                  M Online
                  michihorn
                  Stimmt den habe ich gerade schon raus geworfen reagiert ja auf "ne"
                  • M Online
                    M Online
                    michihorn
                    Das Script sieht nun wie folgt aus:
                    var Statuswert;
                    var Status;
                    var Nr;
                    var Kanal;
                    on({id:'hm-rpc.1.CUX4000002.6.RCVS', change: "ne"},
                        function(Rolladen) {
                            var RL = getState("hm-rpc.1.CUX4000002.6.RCVS").val;
                            if (Kanal == "01") {
                                setState('javascript.0.Rolladen.WZ_Links', Statuswert);
                                setState('javascript.0.Rolladen.Move_WZ_Links', Status);
                                var Nr = Status.substr(1, 1);
                                setState('javascript.0.Rolladen.Zeitsteuerung.EINS.Nr',Nr);
                                            log(Kanal + " WZ Links " + Status + " " + Statuswert);
                            } else {
                                if (Kanal == "02") {
                                    setState('javascript.0.Rolladen.WZ_Rechts', Statuswert);
                                    setState('javascript.0.Rolladen.Move_WZ_Rechts', Status);
                                    setState('javascript.0.Rolladen.Zeitsteuerung.ZWEI.Nr',Nr);
                                    log(Kanal + " WZ Rechts " + Status + " " + Statuswert);
                                } else {
                                    if (Kanal == "04") {
                                        setState('javascript.0.Rolladen.EZ', Statuswert);
                                        setState('javascript.0.Rolladen.Move_EZ', Status);
                                        setState('javascript.0.Rolladen.Zeitsteuerung.DREI.Nr',Nr);
                                        log(Kanal + " EZ " + Status + " " + Statuswert);
                                    } else {
                                        if (Kanal == "08") {
                                            setState('javascript.0.Rolladen.Küche', Statuswert);
                                            setState('javascript.0.Rolladen.Move_Küche', Status);
                                            setState('javascript.0.Rolladen.Zeitsteuerung.VIER.Nr',Nr);
                                            log(Kanal + " Küche " + Status + " " + Statuswert);
                                        } else {
                                            if (Kanal == "10") {
                                                setState('javascript.0.Rolladen.WC', Statuswert);
                                                setState('javascript.0.Rolladen.Move_WC', Status);
                                                setState('javascript.0.Rolladen.Zeitsteuerung.FÜNF.Nr',Nr);
                                                log(Kanal + " WC " + Status + " " + Statuswert);
                    Die Warnmeldungen kommen bei Zeile 17, 21, 25, 29
                    Anbei das LOG-File
                    log.txt
                    • M michihorn
                      var Statuswert;
                      var Status;
                      var Nr;
                      var Kanal;
                              } else {
                                  } else {
                                      } else {
                                          } else {
                      Anbei das LOG-File
                      log.txt
                      @michihorn sagte:
                      Nein, Warnungen kommen bei den setState('javascript.0.Rolladen.Zeitsteuerung.ZWEI.Nr',Nr) bis FÜNF. Sind die Datenpunkte vom Typ "Zeichenkette"(string) ? Das sollten sie sein.
                      17, 21, 25, 29 sind die Zeichenpositionen in der Zeile.
                      • M Online
                        M Online
                        michihorn
                        Doch schon:
                        • M Online
                          M Online
                          michihorn
                          Jetzt klappt es:
                          Hab CreateState so ausgedrückt: "createState("javascript.0.Rolladen.Zeitsteuerung.FÜNF.Nr");"
                          Fehler war so: "createState("javascript.0.Rolladen.Zeitsteuerung.FÜNF.Nr",{read: true,write: true,desc: "Berechneter Wert,",type: "string",min:'0', max:'12',def:1});"
                          Danke Paul53
                          • M michihorn
                            Jetzt klappt es:
                            Danke Paul53
                            @michihorn
                            Ja, min: und max: machen bei Strings keinen Sinn.
