Драйвер ioBroker Visualisation (vis)
Попробуй обновить vis:
cd /opt/iorboker npm install https://github.com/ioBroker/ioBroker.vis/tarball/masterВ прошлой версии встроил поддержку touch. Видать некоторые события приходят и по click и по touchstart `
Все равно срабатывает два раза -
metro toggle? -
metro toggle? `
Этот точно[{"tpl":"tplMetroTileToggle","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true","bg_class_false":"bg-gray","bg_class_true":"bg-teal","icon_class_false":"icon-custom","icon_class_true":"icon-custom","icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"","brand_bg_class_true":"","visibility-oid":"","oid":"javascript.0.TV","label_false":"ТВ","label_true":"ТВ","icon_false":"/vis/img/Icons2/gktelik.gif","icon_true":"/vis/img/Icons2/gktelik.gif"},"style":{"left":"40px","top":"70px","width":"116px","height":"110px"},"widgetSet":"metro"}]И эти
[{"tpl":"tplJquiButtonState","data":{"oid":"mqtt.0.myhome.RS232.LGTV_RemoteKey","visibility-cond":"==","visibility-val":1,"buttontext":" 9 ","padding":"5","value":"19"},"style":{"left":"500px","top":"135px"},"widgetSet":"jqui"}] -
После обюновления на страничке не показывается виджет
[{"tpl":"tplBarNavigator","data":{"visibility-cond":"==","visibility-val":1,"bCount":"5", "bTheme":"sidebar-dark","bPosition":"floatVertical","bSpace":"5","bRadius":"5","bOffset":"0", "bTextAlign":"center","bImageAlign":"right","bLayout":"auto", "bShowEffect":"show","bShowEffectMs":"100","bHideEffect":"show","bHideEffectMs":"91", "buttonsOption1":"Home","views":["Home","Index","Media","Scenes","test","Scenes_new"], "buttonsOption2":"Media", "buttonsOption3":"Scenes","buttonsText1":"Home","buttonsText2":"Media","buttonsText3":"Scenes", "buttonsOption4":"test","buttonsText4":"KODI","buttonsOption5":"Index","buttonsText5":"Temp"}, "style":{"left":"855px","top":"470px","width":"133px","height":"222px","z-index":"3"},"widgetSet":"bars"}]В редактировании он есть.
Добавлено:
Разобрался, отдельным драйвером вынесен теперь :)
ДОлжно быть исправлено. `
Метро все равно срабатывает два раза -
Блин.. Можешь найти подходящий минимальный параметер.
Для этого надо:
- изменить noFileCache в /opt/iorboker/iobroker-data/iobroker.json на true
{ "network": { "IPv4": true, "IPv6": true, "bindAddress": null, "useSystemNpm": true }, "objects": { "type": "file", "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].", "host": "127.0.0.1", "port": 9001, "user": "", "pass": "", "noFileCache": true },-
перестартовать iobroker
поменять в файле:
/opt/iorboker/iobroker-data/files/vis/js/vis.js
Строка 1780:
detectBounce: function (el) { // Protect against two events var now = (new Date()).getTime(); var lastClick = $(el).data('lc'); if (lastClick && now - lastClick < 150) return true; $(el).data('lc', now); return false; }Надо подобрать такой параметр (который 150), что бы начало работать. Поставь 1000 (1 секунда), что бы проверить вообще работоспособность.
После каждого изменения надо менять файл /opt/iorboker/iobroker-data/files/vis/cache.manifest (неважно что. например dev build увеличить) и обновлять броузер.
Затем до тех пор уменьшать 1000 пока работает. И сказать мне число.
P.S. vis-metro должен быть 0.1.5
Для этого надо:
поменять в файле:
Строка 1780:
P.S. vis-metro должен быть 0.1.5 `
На что влияет этот параметр? Смысл тача отлавливать длинное нажатие (Тогда оно составляет около 1 секунды)?Я бы оставил вместо 150 - 1000, этого хватает до длинного нажатия и срабатывает при нормальном нажатии без проблем, если меньше ставить то за время, установленное в if'е нужно получается успеть нажать и убрать палец с экрана, при 600 например срабатывает если прям быстро нажать и убрать палец…. Вообщем 1000 само оптимально, если я правильно понял принцип.
В диалоговом окне с телефона ничего не отображается (в модальном тоже не показывает). При нажатии на виджете открывается пустое диалоговое окно но успевает сработать кнопка из этого диалога, хотя она не отображается.
[{"tpl":"tplMetroTileDialogNumber","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true","bg_class":"ribbed-darkIndigo", "icon_class":"icon-meter-fast","badge_bg_class":"", "brand_bg_class":"ribbed-darkCyan","dialog_draggable":"true", "dialog_icon_class":"icon-meter-fast","contains_view":"Vodonagrevatel", "dialog_width":"350", "dialog_height":"300","number_oid":"mqtt.0.myhome.NRF.Vodonagrevatel.Temp_water", "dialog_title":"","icon_width":"0","icon_top":"0","label":""}, "style":{"left":"36px","top":"287px","width":"47px","height":"28px"},"widgetSet":"metro"}] -
Хотел попробовать виджет добавить, а он не появляется в списке. Один раз появился и исчез, и файлик с виджетом похоже заменяется. Как добавить свой виджет?
[{"tpl":"tplMetroTileDialogNumber","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true","bg_class":"ribbed-darkIndigo", "icon_class":"icon-meter-fast","badge_bg_class":"","brand_bg_class":"ribbed-darkCyan", "dialog_draggable":"true", "dialog_icon_class":"icon-meter-fast","contains_view":"Vodonagrevatel", "dialog_width":"350", "dialog_height":"300","number_oid":"mqtt.0.myhome.NRF.Vodonagrevatel.Temp_water", "dialog_title":"","icon_width":"0","icon_top":"0","label":""}, "style":{"left":"36px","top":"287px","width":"47px","height":"28px"},"widgetSet":"metro"}] ```` `Что то не могу воспроизвести ошибку. Можешь весь vis проект дать? (/opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json)
Хотел попробовать виджет добавить, а он не появляется в списке. Один раз появился и исчез, и файлик с виджетом похоже заменяется. Как добавить свой виджет? `
Так и делал, кроме замены index.html, после изменения cache.manifest и обновлении страницы написано что обнаружено обновление, но внесенные изменения в виджете (C:\iobroker\iobroker-data\files\vis\widgets\basic.html) не появляются, даже если удалить виджет из файла он все равно отображается в списке виджетов на странице редактирования. И еще, у меня виз 0.6.13 а на странице редактирования показывает версию 0.6.11.
Уже пробовал и firefox, все тоже самое.
Уже пробовал и firefox, все тоже самое. `
ndex.html содержит все виджеты. Он строится каждый раз при запуске iobrokerПо этому его нужно заменить.
По этому его нужно заменить. `
Не строится он каждый раз. Сейчас попробовал снова, у файлов стоит дата вчерашняя. -
Хм. рестартанул именно ВИЗ, файлы обновились, но и файл с виджетом заменился, все изменения исчезли из файладобавлено:
Добавил новый виджет в edit, изменил манифест и виджет появился в списке
Bluefox будут исправления? файл не пересоздается каждый раз.
Как в виджете задаваемы параметр присвоить переменной? пример кода:
value1 отрабатывает, а вот digit1 немогу победить.
[{"tpl":"tplMetroTileDialogNumber","data":{"visibility-cond":"==", "visibility-val":1,"hover":"true","transform":"true","bg_class":"ribbed-darkIndigo", "icon_class":"icon-meter-fast","badge_bg_class":"", "brand_bg_class":"ribbed-darkCyan","dialog_draggable":"true", "dialog_icon_class":"icon-meter-fast","contains_view":"Vodonagrevatel","dialog_width":"350", "dialog_height":"300", "number_oid":"mqtt.0.myhome.NRF.Vodonagrevatel.Temp_water", "dialog_title":"","icon_width":"0","icon_top":"0","label":""}, "style":{"left":"36px","top":"287px","width":"47px","height":"28px"},"widgetSet":"metro"}] ```` `Что то не могу воспроизвести ошибку. Можешь весь vis проект дать? (/opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json) `
Так и не победил, пробовал менять и размеры окна и удалял виджеты в нем,. на компе показывает на телефоне пустое окно хотя на кнопки реагирует. Причем добавил аналогичный виджет он отрабатывает норм. Кстати высота окна (всплывающего) на телефоне не меняется, выставляю высоту окна больше, на компе оно становится больше а на телефоне остается неизменной, может где css пересекается?PS в личку кидал проект.
OK Спасибо. Поставлю 700 `
При скроле страницы на телефоне нажимаются кнопки, я думаю мало 700 либо вообще зачем нужна обработка тача? -
