  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.5k Aufrufe 30 Beobachtet
  • M maniac
    Neues Update.
    Grundsätzlich läuft der Adapter wieder. Allerdings startet der Adapter alle 5min neu, bzw. stürzt ab und startet dann wieder.
    Siehe Log. Das passiert alle 5min.
    Version hab ich jetzt die 3.0.6 laufen.
    Eine Idee?
    shelly.0	2019-07-19 14:06:14.446	info	Listening for Shelly packets in the network
    shelly.0	2019-07-19 14:06:14.446	info	Stating Shelly adapter in CoAP modus.
    shelly.0	2019-07-19 14:06:14.215	info	starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.0
    shelly.0	2019-07-19 14:05:43.801	info	Closing Adapter
    shelly.0	2019-07-19 14:05:43.801	error	Error: No reply in 247s at Timeout._onTimeout (/opt/iobroker/node_modules/coap/lib/retry_send.js:74:16) at ontimeout (timers.js:498:11) at tryOnTimeout (timers.js:323:5) at Timer.listO
    shelly.0	2019-07-19 14:05:43.801	error	uncaught exception: No reply in 247s
    shelly.0	2019-07-19 14:05:43.369	debug	Set state SHSW-1#1D9450#1.uptime, Value: "222T01:09:19" for 192.168.223.142 (shelly1 / shelly1-1D9450 / SHSW-1#1D9450#1)
    shelly.0	2019-07-19 14:05:43.319	debug	CoAP data ignored: {"3332":"SHSW-1#1D90CC#1","3412":38400,"3420":512,"Uri-Path":"cit/s"} / {"G":[[0,112,1]]}
    shelly.0	2019-07-19 14:05:43.011	debug	Set state SHSW-1#1D90CC#1.uptime, Value: "02:27:25" for 192.168.223.143 (shelly1 / shelly1-1D90CC / SHSW-1#1D90CC#1)
    shelly.0	2019-07-19 14:05:42.777	debug	Set state SHSW-1#500637#1.uptime, Value: "222T22:52:24" for 192.168.223.141 (shelly1 / shelly1-500637 / SHSW-1#500637#1)
    shelly.0	2019-07-19 14:05:42.431	debug	CoAP data ignored: {"3332":"SHSW-1#1D9450#1","3412":38400,"3420":32005,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
    shelly.0	2019-07-19 14:05:42.425	debug	CoAP data ignored: {"3332":"SHSW-1#50014E#1","3412":38400,"3420":7936,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
    shelly.0	2019-07-19 14:05:41.462	debug	CoAP data ignored: {"3332":"SHSW-1#500637#1","3412":38400,"3420":45829,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
    shelly.0	2019-07-19 14:05:41.270	debug	CoAP data ignored: {"3332":"SHSW-25#693077#1","3412":38400,"3420":49152,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000],[0,121,0.000000]]}
    shelly.0	2019-07-19 14:05:41.233	debug	Set state SHSW-1#50014E#1.uptime, Value: "8T20:19:31" for 192.168.223.140 (shelly1 / shelly1-50014E / SHSW-1#50014E#1)
    shelly.0	2019-07-19 14:05:40.715	debug	Set state SHSW-25#693077#1.uptime, Value: "1T04:47:34" for 192.168.223.144 (shellyswitch25 / shellyswitch25-693077 / SHSW-25
    StuebiS Offline
    StuebiS Offline
    Stuebi
    schrieb am zuletzt editiert von Stuebi
    #587
    @maniac , ich habe in die Version 3.0.7 einen Timeout für die http Requests mit eingebaut. Ich hoffe, dass behebt den Fehler.
    Es gibt auch ein Issue zu dem Thema:
    https://github.com/schmupu/ioBroker.shelly/issues/71
    ioBroker auf Synology DS216+II im Docker Container
    • StuebiS Stuebi
      DreamForce
      #588
      @Stuebi ich habe jetzt für ein paar Tage auch das Problem gehabt, dass der Adapter alle 4 Minuten abstürzt und neu startet: uncaught exception: No reply in 247s at Timeout... usw.
      Ich verwendete die Version 3.0.5 und habe ein Update auf 3.0.7 gemacht weil ich gehofft habe, dass die Fehlerursache dadurch behoben wird. Leider wird das eigentliche Problem nicht behoben - lediglich die "uncaught exception" wird nun behandelt, und zwar insofern, dass der Adapter sich 4 Minuten nach Start selbst beendet, aber nicht mehr von alleine neustartet. Auf diese Weise ist der Shelly-Adapter unter dieser Fehlersituation unbrauchbar geworden, da ich als Anwender ihn von nun an alle 4 Minuten händisch starten muss.
      Ergo habe ich wieder auf 3.0.5 downgegradet - jetzt stürzt er zwar nach wie vor alle 4 Minuten ab, startet aber wenigstens von alleine neu.
      Nachdem ich schon sehr viel im iobroker und im Adapter erfolglos probiert hatte, habe ich nun in letzter Instanz aus reiner Hilflosigkeit den heimischen Switch stromlos gemacht und 30 Sek. später wieder gestartet (ein D-Link 8-Port Gigabit PoE-Switch). Und siehe da: auf einmal sind alle Shellys im Netzwerk wieder funktionstüchtig und auch iobroker kann sie wieder steuern. Der Adapter stürzt nun auch nicht mehr ab.
      Was meinen Switch angeht vermute ich einen Überlauf der Routing- oder ARP-Tabelle oder einen simplen Software-Absturz. Per TCP/IP und http-Protokoll waren alle Shellys die ganze Zeit (z. B. über den Webbrowser) steuerbar, aber anscheinend gingen von einigen Shellys keine Multicast UDP-Pakete mehr über den Äther sodass Coap versagte.
      Was den Shelly-Adapter angeht muss aber etwas an der Fehlertoleranz geschehen. Wenn ein Shelly plötzlich im Netzwerk nicht mehr erreichbar ist, sollte nicht gleich der ganze Adapter den Dienst quittieren.
      Nachdem der Switch jetzt rebootet ist und alle Shellys wieder laufen, wird die nachträgliche Fehlersuche natürlich schwieriger, trotzdem biete ich mich gern für's Debugging an :)
      Schöne Grüße
      Thomas
      StuebiS 1 Antwort Letzte Antwort
      • D DreamForce
        Schöne Grüße
        Thomas
        StuebiS Offline
        StuebiS Offline
        Stuebi
        #589
        @DreamForce , danke für die genaue Analyse. Zu dem Thema gibt es ein Issue (https://github.com/schmupu/ioBroker.shelly/issues/71). Leider bin ich bei der Lösung des Fehlers auf andere Libs angewiesen. Daher muss ich warten, bis dort der Fehler behoben wird.
        In der 3.0.7 der Shelly Adapter startet der Shelly nicht neu. Das kann ich aber in Version 3.0.8 wieder einbauen.
        D M 2 Antworten Letzte Antwort
        • StuebiS Stuebi
          DreamForce
          #590
          @Stuebi weiß Du denn, woher der Timeout genau kommt? Also welcher Request könnte ins Leere laufen? Mit dieser Information könnte ich vielleicht besser nachvollziehen, warum hier im Netz einige Shellys versagten und ggf. kann ich die Situation ja dann sogar nochmal nachstellen.
          • D DreamForce
            StuebiS Offline
            StuebiS Offline
            Stuebi
            #591
            @DreamForce , schaue Dir einmal den Issue https://github.com/schmupu/ioBroker.shelly/issues/71 an. Dort hat @foxriver76 netterweise das Logfile zur Verfügung gestellt. Es kommt aus der CoAP Lib (https://github.com/mcollina/node-coap).
            • Sascha TiedemannS Offline
              Sascha Tiedemann
              #592
              Ich habe gestern Abend auf die 3.0.5 geupdatet und alle shelly1 auf die Firmware 1.5 gebracht. Seit dem geht nichts mehr. Kein einziger shelly lässt sich noch schalten.
              Auf dem WebIF der shelly s lassen Sie sich schalten. In der shelly App auch. Im WebIF habe ich auch schon testweise sie Coap Funktion aktiviert. Hilft aber leider auch nicht.
              Warum geht es in der neuen Version nicht mehr über iobroker?
              • Sascha TiedemannS Sascha Tiedemann
                StuebiS Offline
                StuebiS Offline
                Stuebi
                #593
                @Sascha-Tiedemann , um dir diese Frage zu beantworten, müsste ich wissen von welcher Shelly Version du kommst, ob du MQTT oder CoAP nutzt und ich benötige das Logfile mit den Fehlern, falls es welche gibt.
                  Sascha Tiedemann
                  schrieb am zuletzt editiert von Sascha Tiedemann
                  #594
                  ich meine, dass ich von Version 1.05 komme.
                  Wo kann ich das jetzt noch sehen?
                  Ich nutze CoAP und http im shelly Adapter
                  Ich habe iobroker mal neu gestartet. Das ist der Log zum Suchbegriff "shelly"
                  host.WIN2016	2019-07-23 22:20:21.421	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:20:21.421	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  host.WIN2016	2019-07-23 22:20:20.641	info	instance system.adapter.shelly.0 started with pid 2298
                  host.WIN2016	2019-07-23 22:19:50.615	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:19:50.614	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  host.WIN2016	2019-07-23 22:19:49.893	info	instance system.adapter.shelly.0 started with pid 1816
                  host.WIN2016	2019-07-23 22:19:19.870	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:19:19.870	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  host.WIN2016	2019-07-23 22:19:19.170	info	instance system.adapter.shelly.0 started with pid 1289
                  host.WIN2016	2019-07-23 22:18:49.142	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:18:49.141	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  host.WIN2016	2019-07-23 22:18:48.429	info	instance system.adapter.shelly.0 started with pid 802
                  host.WIN2016	2019-07-23 22:18:18.402	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:18:18.402	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  host.WIN2016	2019-07-23 22:18:17.669	info	instance system.adapter.shelly.0 started with pid 255
                  host.WIN2016	2019-07-23 22:17:47.656	info	Restart adapter system.adapter.shelly.0 because enabled
                  host.WIN2016	2019-07-23 22:17:46.032	info	instance system.adapter.shelly.0 started with pid 32362
                  history.0	2019-07-23 22:17:45.139	info	enabled logging of shelly.0.SHSW-PM#E640C7#1.Power (Count=7), Alias=false
                  history.0	2019-07-23 22:17:45.085	info	enabled logging of shelly.0.SHSW-PM#E640C7#1.Power (Count=7), Alias=false
                  shelly.0	2019-07-23 22:17:43.281	info	Listening for Shelly packets in the network
                  shelly.0	2019-07-23 22:17:43.280	info	Stating Shelly adapter in CoAP modus.
                  shelly.0	2019-07-23 22:17:43.279	info	Stating Shelly adapter in CoAP modus.
                  shelly.0	2019-07-23 22:17:43.266	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.1
                  shelly.0	2019-07-23 22:17:43.257	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.1
                  shelly.0	2019-07-23 22:17:43.246	warn	Reconnection to DB.
                  shelly.0	2019-07-23 22:17:43.245	warn	Reconnection to DB.
                  Adapter	2019-07-23 22:17:40.481	info	shelly still running
                  Adapter	2019-07-23 22:17:39.482	info	shelly still running
                  shelly.0	2019-07-23 22:14:06.343	info	Listening for Shelly packets in the network
                  shelly.0	2019-07-23 22:14:06.284	info	Stating Shelly adapter in CoAP modus.
                  shelly.0	2019-07-23 22:14:06.276	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.1
                  host.WIN2016	2019-07-23 22:14:05.485	info	instance system.adapter.shelly.0 started with pid 30260
                  host.WIN2016	2019-07-23 22:14:02.962	info	instance system.adapter.shelly.0 terminated with code 0 (OK)
                  shelly.0	2019-07-23 22:14:02.948	info	Closing Adapter
                  shelly.0	2019-07-23 22:14:02.946	info	Closing Adapter
                  host.WIN2016	2019-07-23 22:14:02.945	info	stopInstance system.adapter.shelly.0 killing pid 30131
                  host.WIN2016	2019-07-23 22:14:02.945	info	object change system.adapter.shelly.0
                  shelly.0	2019-07-23 22:13:44.915	info	Listening for Shelly packets in the network
                  shelly.0	2019-07-23 22:13:44.840	info	Stating Shelly adapter in CoAP modus.
                  shelly.0	2019-07-23 22:13:44.831	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.1
                  host.WIN2016	2019-07-23 22:13:44.045	info	instance system.adapter.shelly.0 started with pid 30131
                  host.WIN2016	2019-07-23 22:13:41.523	info	instance system.adapter.shelly.0 terminated with code 0 (OK)
                  shelly.0	2019-07-23 22:13:41.514	info	Closing Adapter
                  shelly.0	2019-07-23 22:13:41.511	info	Closing Adapter
                  host.WIN2016	2019-07-23 22:13:41.510	info	stopInstance system.adapter.shelly.0 killing pid 17887
                  host.WIN2016	2019-07-23 22:13:41.509	info	object change system.adapter.shelly.0
                  host.WIN2016	2019-07-23 22:17:47.656	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                  StuebiS Sascha TiedemannS 2 Antworten Letzte Antwort
                  • StuebiS Stuebi
                    maniac
                    #595
                    @Stuebi sagte in [Aufruf] Test Shelly Adapter:
                    Bei mir auch noch immer das gleiche und ähnlich wie bei @dreamforce habe ich alle Shellys stromlos gemacht, danach lief es wieder.
                    Wenn man nun aber weis woran es liegt, kann man ja reagieren.
                    Da die Shellys ja noch über das Webinterface reagieren, dachte ich mir das man die dann neu startet per http-Request?
                    Geht das irgendwie?
                    Gruß Frank…
                      StuebiS Offline
                      StuebiS Offline
                      Stuebi
                      #596
                      @Sascha-Tiedemann , sieht so aus, als ob der Shelly Adapter 2 Mal läuft.
                      Beende einmal ioBroker und starte es neu. Wenn dann der Shely später immer noch nicht geht, bitte nochmals Logfile schicken.
                        Sascha Tiedemann
                        #597
                        Ich habe den shelly Adapter nochmal komplett gelöscht und neu installiert. Bei der Installation kommt folgendes:
                        $ ./iobroker add shelly  --host WIN2016
                        NPM version: 6.4.1
                        npm install iobroker.shelly --production --save --prefix "/opt/iobroker" (System call)
                        npm WARN
                         enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/es6-set/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/event-emitter/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/npmlog/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/es6-map/package.json'
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        host.WIN2016 install adapter shelly
                        got /opt/iobroker/node_modules/iobroker.shelly/admin
                        upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                        upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                        upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                        host.WIN2016 object system.adapter.shelly created
                        host.WIN2016 create instance shelly
                        host.WIN2016 object shelly.0.info.connection created
                        host.WIN2016 object shelly.0.info created
                        host.WIN2016 object system.adapter.shelly.0.outputCount created
                        host.WIN2016 object system.adapter.shelly.0.inputCount created
                        host.WIN2016 object system.adapter.shelly.0.uptime created
                        host.WIN2016 object system.adapter.shelly.0.memRss created
                        host.WIN2016 object system.adapter.shelly.0.memHeapTotal created
                        host.WIN2016 object system.adapter.shelly.0.memHeapUsed created
                        host.WIN2016 object system.adapter.shelly.0.connected created
                        host.WIN2016 object system.adapter.shelly.0.alive created
                          NPM version: 6.4.1
                          npm WARN
                          StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #598
                          @Sascha-Tiedemann , sind erst einmal nur warnings. Erst einmal nicht beachten. Wichtig ist, dass der Shelly Adapter nicht mehrfach läuft.
                            Sascha Tiedemann
                            #599
                            Ich habe iobroker gestopt und wieder neu gestartet.
                            Jetzt kommt kein Fehler mehr im Log, dass es doppelt läuft.
                            Einen Restart von iobroker habe ich bestimmt schon 5 Mal gemacht. Ohne Erfolg.
                            Der Adapter (jetzt Version 3.0.7) scheint nun fehlerfrei zu laufen.
                            Durch das löschen des Adapters sind nun aber keine Objekte zu shelly da.
                            Er findet bisher nichts von allein. Muss ich da noch was machen?
                              StuebiS Offline
                              StuebiS Offline
                              Stuebi
                              #600
                              @Sascha-Tiedemann , hast du in der Shelly Adapter Konfiguration unter Instanzen CoAP stehen? Dann musst nichts tun. Die Shellys werden automatisch erkannt.
                              Wenn das nicht der Fall ist, hast Du irgendetwas an Deinem Netzwerk verändert wie z.B. neuer Switch, Router, IP Adressen, ...
                                Sascha Tiedemann
                                #601
                                Genau. Es ist die Standard-Konfig mit CoAP und http.
                                Ich kann alle Shellys über deren IP erreichen (WebIF).
                                Alles sind nach wie vor im Netzwerkbereich 192.168.0.xxx, wie auch der iobroker Server
                                Es werden keine shellys gefunden.
                                Alles shellys haben die neuste Firmware 20190711-084053/v1.5.0-hotfix4@3b4f7414
                                Der Discovery Adapter findet alle shellys. Hilft aber für den shelly Adapter nicht weiter.
                                  StuebiS Offline
                                  StuebiS Offline
                                  Stuebi
                                  #602
                                  @Sascha-Tiedemann , auch wenn Deine Shellys über http erreichbar sind, heißt es nicht, dass diese auch über CoAP erreichbar sind. CoAP nutzt Multicast. Wenn die Shellys nicht gefunden werden, liegt es z.B. an unterschiedliche Subnetze, an Deinem Netzwerkinterface von ioBroker Server, Switches, Router, ....
                                  Um zu sehen ob CoAP funktioniert, kannst Du z.B. einmal den Shelly Adapter stoppen (darf nicht laufen!!!!) und dann folgendes ausführen:
                                  cd /opt/iobroker/node_modules/iobroker.shelly
                                  node coaptest.js
                                  Nun sollten Deine Shellys zu sehen sein. Wenn nicht, dann suche einmal den Fehler im Netzwerk bei Dir. Kannst auch einmal versuchen ein Hardware Reset bei einem Shelly durchzuführen.
                                  Wenn Du den Shelly Adapter wieder startest, darf node coaptest.js nicht mehr laufen.
                                    Sascha Tiedemann
                                    #603
                                    da kommt nur:
                                    undefined
                                    UDP Server listening on 0.0.0.0:5683
                                      da kommt nur:
                                      undefined
                                      StuebiS Offline
                                      StuebiS Offline
                                      Stuebi
                                      #604
                                      @Sascha-Tiedemann , es werden keine CoAP Pakete (Multicast) Pakete in Deinem Netzwerk von den Shellys an Deinen ioBroker Server weitergeleitet. Da musst Du jetzt den Fehler bei Dir suchen.
                                      Hat nichts mit ioBroker zu tun.
                                      Als erstes würde ich testweise bei einem Shelly einen Hardware Reset durchführen.
                                        Sascha Tiedemann
                                        #605
                                        GEFUNDEN!
                                        Da ich iobroker auf einem Windows Server betreibe war der UDP Port 5683 durch die Windows Firewall gesperrt.
                                        Gibt man den frei funktioniert auch alles😕
                                        Das muss aber neu sein. Bisher war diese Freigabe nicht nötig.
                                        Habe das Ganze schon fast ein Jahr so laufen.
                                        Mein Problem hätte ich alleine nie gelöst!!!
                                        Vielen Dank für eure Hilfe!
                                        • StuebiS Offline
                                          StuebiS Offline
                                          Stuebi
                                          #606
                                          es gibt eine neue Version des Shelly Adapter (3.0.8). Unterstützt wird nun auch der Shelly EM. Ich hoffe jemand von Euch hat diesen im Einsatz und kann ordentlich testen. Besonders der Wert Power Factor (PF) interessiert mich. Dieser wird nicht vom Shelly geliefert, sondern muss berechnet werden. Ich hoffe ich habe das richtig umgesetzt :-)
                                          Hier die Neuerungen in der Version 3.0.8
                                          • Add device Shelly EM
                                          • Add state energy for Shelly Plug S, Shelly PM and Shelly 2.5 in CoAP mode
                                          • Add state temperature for Shelly Plug S, Shelly PM and Shelly 2.5 in CoAP mode
                                          • Add state overtemperature for Shelly Plug S, Shelly PM and Shelly 2.5 in CoAP and MQTT mode
                                          • Bugfixing
                                          Die Version steht auf GitHub ab sofort zur Verfügung, als Update bei den Adaptern wahrscheinlich morgen.
                                          Stübi
