  4. Blockly Script welches Objekte zusammenfasst
    5.8k
blocklyventilationclimatemonitoring
13 Beiträge 3 Kommentatoren 1.8k Aufrufe 1 Beobachtet
  • Nito33N Nito33
    Kannst du mir den Code davon Posten? Das wäre nett
    @Noé1237 sagte:
    Code davon Posten?
    Sämtliche Datenpunkt-IDs müssen noch zugewiesen werden.
      <block type="comment" id="S?vFH9^Mp`YRqvS#vY36" x="-87" y="63">
        <field name="COMMENT">Klima An</field>
        <next>
          <block type="on_ext" id="5kg%Js.Crgf{GR|na0zn">
            <mutation items="1"></mutation>
            <value name="OID0">
              <shadow type="field_oid" id=":GHh}|:b:%DC*);59#zZ">
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="comment" id="L`_l}vO:-vw@wp|7[Bd*">
                <field name="COMMENT">Klima Schalter</field>
                <next>
                  <block type="update" id=".ZxB^)67P4TD1@PVj%t1">
                    <mutation delay_input="false"></mutation>
                    <value name="VALUE">
                      <block type="logic_boolean" id=".=F%U}Y[0m*U7].|8uXQ">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="comment" id="[CwRZ*Zq[4#V|t0Tzb21">
                <field name="COMMENT">Klima Aus</field>
                <next>
                  <block type="on_ext" id="q;4x2o;3I=O2rar;Ds2%">
                    <value name="OID0">
                      <shadow type="field_oid" id="!nKs)f%,WA61Nb1A4Od^">
                      </shadow>
                    </value>
                      <block type="comment" id="v%qAJtQESRq4b+TNBlRu">
                        <next>
                          <block type="update" id="@)k2q}9``*f5HXaoaWR_">
                              <block type="logic_boolean" id="FV;kV6h4j%G7m6Y18W36">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                      <block type="comment" id="%4u;@y!;-,uS=iNN*xsr">
                        <next>
                          <block type="on_ext" id="Zw=sb)`V%`y`_CS~3PD%">
                            <value name="OID0">
                              <shadow type="field_oid" id="o;|BS;UeH#Yk^.O*hki/">
                              </shadow>
                            </value>
                              <block type="controls_if" id="5:7`K^JS=wv|J1b-Hx[5">
                                <value name="IF0">
                                  <block type="logic_compare" id="iDYd^L{8_zX}po4r^u)R">
                                    <field name="OP">NEQ</field>
                                    <value name="A">
                                      <block type="on_source" id=";DwNKF2bS*VVR~bijsJ!">
                                        <field name="ATTR">state.from</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="Ft}eH=_DcgQf82NCeT0l">
                                        <field name="TEXT">system.adapter.javascript.0</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO0">
                                  <block type="controls_if" id="A5j7#|NJ5B-0t$:g?@,]">
                                    <value name="IF0">
                                      <block type="on_source" id="aACZD:]:?F$EI?%El~o%">
                                      </block>
                                    </value>
                                      <block type="comment" id="OX36-k-SEW]XrGtm?cpQ">
                                        <field name="COMMENT">Klima an</field>
                                        <next>
                                          <block type="control" id="F`WuVuL!f1$xG;J6)UXT">
                                              <block type="logic_boolean" id="9F/Uw2TXj(f12}yZjL`)">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <statement name="ELSE">
                                      <block type="comment" id="ceT|InAU#s`7$EQOIJ24">
                                        <field name="COMMENT">Klima aus</field>
                                        <next>
                                          <block type="control" id="(?Wk[b3r|m,vJHR!RFTJ">
                                              <block type="logic_boolean" id="N5!qf^T+X(+hNgsSvZ,C">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    • Nito33N Offline
      Nito33N Offline
      Nito33
      Wo genau muss aber was jetzt rein? Brauche ja nur den An und Aus Datenpunkt oder?
      • Nito33N Nito33
        @Noé1237 sagte:
        Das steht in dem Kommentar über dem Block.
        @Noé1237 sagte in [Anfängerfrage] Blockly Script welches Objekte zusammenfasst:
        ... und den Datenpunkt für den Schalter (Vis). Den musst Du wahrscheinlich erst erstellen (Typ: Logikwert), empfohlen im Reiter "Objekte" unter javascript.0.
        • Nito33N Offline
          Nito33N Offline
          Nito33
          So sieht es bei mir jetzt aus. Ich habe unter dem Ordner Javascript ein Datenpunkt angelegt und den dann immer bei Klima Schalter eingefügt. Wenn ich dann das häkchen bei dem Datenpunkt verändere passiert leider nichts...
          • Nito33N Nito33
            @Noé1237 sagte:
            Wie schaltest Du manuell über ioBroker die AC an bzw aus ? Welche Werte stehen normalerweise in den Datenpunkten "Klima An" und "Klima Aus" (ist oben leider nicht zu sehen) ?
            • Nito33N Offline
              Nito33N Offline
              Nito33
              Hatte natürlich das USB Kabel vom Broadlink nicht angeschlossen 😬 😫
              Funktionieren tut es jetzt immernoch nicht richtig. Eben ging es nur ab und zu aber jetzt scheint es zu Funktionieren.
              Ich steuere jetzt über den Datenpunkt neues_Objekt
              Habe jetzt diesen Switch ausprobiert und den Datenpunkt als Object eingetragen, wenn ich den Switch jetzt nutzen möchte passiert überhaupt nichts...weder an noch aus 😑
              • Nito33N Nito33
                @Noé1237 Keine Datenpunkte unter javascript.0.scriptEnabled anlegen ! Bitte direkt unter javascript.0, so wie es in Vis zu sehen ist !
                Bei den beiden Button vermisse ich die Zeitstempel.
                • Nito33N Offline
                  Nito33N Offline
                  Nito33
                  Habe es jetzt hinbekommen :) Hatte wohl einfach den falschen Datenpunkt für den Button ausgewählt 😦
                  Was meinst du mit den Zeitstempeln? Und hast du eine idee wie ich den Switch in der Vis beschriften kann? Finde leider kein Widget in dem ich einfach einen Text schreiben kann. Soll einfach vor oder auf dem Switch stehen, dass er für die Klima ist 🤔
                  • Nito33N Nito33
                    @Noé1237 sagte:
                    Mit Vis kenne ich mich nicht aus.
                    • Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      Als String
                      Da die Frage eh kommt, größe ,fett , kursiv oder Farbe usw. änderst du hier :
