  4. RGBW-Widget
    5.2k
RGBW-Widget
vis
15 Beiträge 4 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • kmxakK Offline
    kmxakK Offline
    kmxak
    schrieb am zuletzt editiert von kmxak
    was hälst du von so etwas? das ist ein Schieberegler. Kannst dir ja mal importen
    [{"tpl":"tplJquiSliderVertical","data":{"oid":"fhem.0.Kueche2.hue","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-slider mdui-transparent-acc","min":"0","max":"300","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"496px","top":"80px","height":"280px"},"widgetSet":"jqui"}]
    code edit
    Gruß Alex
    • P Offline
      PatrickFro
      Leider finde ich bei dem Widget keinen Datenpunkt. Wie kann ich das Widget denn trotzdem nutzen?
      • P Offline
        PatrickFro
        ... und es bezieht sich nur auf den Farbwechsel. Gibt es denn nichts, was Dimmen, Farbwechsel und Warmweiß in einem Widget unterstützt?
        • kmxakK Offline
          kmxakK Offline
          kmxak
          Unter Allgemein - Object ID dort wählst den Datenpunkt.
          Es kann sein das es bei dir nicht geht da du die CSS Klassen nicht hast. Das hatte ich nicht bedacht und sieht ohne nicht so toll aus.
          Für Dimmer und WW habe ich auch einfach diesen Slider genommen.
          Wieso sollte das alles in einem Widget gehen?
          Gruß Alex
          • P Offline
            PatrickFro
            Ich mag es aufgeräumt und hab gerne so wenig Widgets wie möglich 😉
            Manchmal setze ich mir etwas in den Kopf und suche dann nur nach der Lösung. Ich schätze aber, dass ich hier auch eher auf Deine Lösung übergehen werde..
            • kmxakK Offline
              kmxakK Offline
              kmxak
              das war übrigens das falsche widget.. ich wusste es der editor hatte sich schon so komisch verhalten aber hatte trotzdem chrome verwendet.
              Hier mal das richtige:
              Gruß Alex
              • kmxakK kmxak
                HomoranH Offline
                HomoranH Offline
                @kmxak sagte in RGBW-Widget:
                Und wie soll es technisch gehen?
                Rgbw led liefern ein aus rgb zusammengesetztes licht + je nach modell ein warm- oder kaltweißes Licht.
                Um jetzt aus dem Licht der Warmweißen Led ein "kaltweißes" zu erzeugen muss jetzt noch farbe (mindestens blau) hinzugemischt werden, während bei kaltweißen led rot zugemischt werden muss um warmweiß zu erhalten.
                Im Gegensatz zu LED die nur die Farbtemperatur ändern geht dies nicht mit rgbw Lampen.
                • P Offline
                  PatrickFro
                  Vielen Dank kmxak, ich bin durch Deine Antworten deutlich weitergekommen. Ich denke, ich werde wirklich mit Slidern und Farbpickern arbeiten. Kann ich beim Anschalten des Lichtes dieses kombiniert als Popup angezeigt bekommen? Leider habe ich nicht mehr so viel Platz und würde den Weg bevorzugen.
                  @Homoran: Völlig egal ich will es nur schön haben ;-) Spaß beiseite, von der Technik habe ich nicht so viel Hintergrundwissen. Es leuchtet, ich bin glücklich.
                  • kmxakK Offline
                    kmxakK Offline
                    kmxak
                    da du Anfänger bist kommt die Erfahrung mit der Zeit. Lass dir eins gesagt seit. Dein Vis wirst eh noch oft umbauen 😁
                    Also Popup ginge es. Wie man sowas erstellt findest du auch hier im Forum über die Suche. Ansonsten kannst du aber auch mit der Sichtbarkeit spielen.
                    Findest im Widget sehr weit oben. Dort z.B einfach den ein aus state von der LED und damit den Slider anzeigen lassen oder verstecken.
                    Gibt dort viele Wege.
                    Gruß Alex
                    • P Offline
                      PatrickFro
                      Eine Frage habe ich noch. Wenn ich 2 Lampen gleichzeitig Dimmen oder die Farbe äbdern möchte, wie mache ich das? Muss ich dafür wirklich Blockly nutzen? Bei Imperihome gibt es sowas sehr einfach im Dashboard, daher hoffe ich, an Blockly noch vorbeizukommen...
                      Danke!
                      • kmxakK Offline
                        kmxakK Offline
                        kmxak
                        Also ich kenne Imperihome nicht aber ich würde mir dazu neue Datenpunkte anlegen und dann die Lampen gruppieren per Blockly oder JS.
                        Anders wüsste ich es jetzt nicht.
                        Gruß Alex
