  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 319.6k Aufrufe 54 Beobachtet
  • smileS smile
    @smile sagte in [Adapter] Neuer radar2-Adapter:
    @frankjoke Achso okay, sorry.
    Habe iobroker auf einem Intel i5 mit Windows 10Pro, 16GB RAM. Node 8.15.1, npm 6.9.0
    Hier einmal der LOG wenn ich den Radar Adapter starte:
    host.DJ-Server 2019-05-14 20:02:39.796 info Restart adapter system.adapter.radar2.0 because enabled
    host.DJ-Server 2019-05-14 20:02:39.796 error instance system.adapter.radar2.0 terminated with code 0 (OK)
    Caught 2019-05-14 20:02:39.796 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
    Caught 2019-05-14 20:02:39.796 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
    Caught 2019-05-14 20:02:39.795 error by controller[0]: Error: No compatible USB Bluetooth 4.0 device found!
    radar2.0 2019-05-14 20:02:39.763 info Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0 2019-05-14 20:02:39.762 error at process._tickCallback (internal/process/next_tick.js:181:9)
    radar2.0 2019-05-14 20:02:39.762 error at _combinedTickCallback (internal/process/next_tick.js:132:7)
    radar2.0 2019-05-14 20:02:39.762 error at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
    radar2.0 2019-05-14 20:02:39.762 error at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
    radar2.0 2019-05-14 20:02:39.762 error at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
    radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
    radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
    radar2.0 2019-05-14 20:02:39.762 error Error: No compatible USB Bluetooth 4.0 device found!
    radar2.0 2019-05-14 20:02:39.762 error uncaught exception: No compatible USB Bluetooth 4.0 device found!
    radar2.0 2019-05-14 20:02:39.759 warn Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then (C:\ioBroker\node_modules\iobroker.radar2\radar
    radar2.0 2019-05-14 20:02:39.757 info radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0 2019-05-14 20:02:39.757 info arp-scan will use the following interfaces: [ 'Ethernet', 'USB Netzwerk Dongle' ]
    radar2.0 2019-05-14 20:02:39.757 info use known IP list: [ '1.1.1.1', '172.16.2.47' ]
    radar2.0 2019-05-14 20:02:39.756 info use known BT list: [ '3c:dc:bc:24:05:21', '00:00:46:00:00:01' ]
    radar2.0 2019-05-14 20:02:39.756 info radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0 2019-05-14 20:02:39.756 info found 'node-bluetooth'
    radar2.0 2019-05-14 20:02:39.715 info found '@abandonware/noble'
    radar2.0 2019-05-14 20:02:39.296 info Connected with '0.0.0.0' for DHCP Scan
    radar2.0 2019-05-14 20:02:39.193 info radar2 initialization started...
    radar2.0 2019-05-14 20:02:39.160 info starting. Version 1.0.7 in C:/ioBroker/node_modules/iobroker.radar2, node: v8.15.1
    Danke für Deine Unterstützung.
    Hi frankjoke, darf ich nochmal nachfragen ob dir der Log weitergeholfen hat?
    Oder gibt es noch irgendetwas anderes was ich probieren kann um die Bluetooth Anwesenheit auf Windows zu realisieren?
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #637
    @smile
    Noble braucht spezielle BT-Treiber glaub ich für Windows und auch spezielle build-tools. Schau mal auf https://github.com/noble/noble#readme
    Ich kann nur auf https://github.com/jasongin/noble-uwp verweisen, das hab ich selbst gerade gefunden und noch nicht ausprobiert.
    Wenn das unter Windows funktioniert kann ich mal testen ob ich beide noble einbauen kann und je nach OS das eine oder andere verwende, wird aber dauern bis ich das testen kann, muss mir eine Windows vm bauen wo ich iobroker drauf gib und dann alles wie in obigen links beschrieben mal installiere...
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    smileS 1 Antwort Letzte Antwort
    • MathiasJM MathiasJ
      was vllt interessant wäre, ist jeder version einen anderen Namen zu geben.
      Jetzt kann ich nicht mehr zurück von der 1.2.0 auf die 1.2.0
      bei der letzten Version ging Radar mit hciscan, hier nur noch mit Noble.
      frankjokeF Offline
      frankjokeF Offline
      frankjoke
      #638
      @MathiasJ
      Wie meinst du das, du hast jetzt nur 2 flags getrennt! Wie schaut dein log aus wenn du auf hciscan schaltest ?
      Frank,
      MathiasJM 1 Antwort Letzte Antwort
      • frankjokeF frankjoke
        @MathiasJ
        MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        schrieb am zuletzt editiert von MathiasJ
        #639
        @frankjoke
        so, jetzt bin ih schlauer.
        BLE scan wird gar nicht durchgeführt.
        Die BT-Adresse des Handies wird gefunden, die G-Tags nicht.
        LOG HERUNTERLADENLog-Größe: 0.00 MB
          close	Zeit
        Meldung
        radar2.0	2019-05-26 08:35:09.018	info	debug: ChangeState ack:true of Mathias-Handy._lastHere = 2019-05-26@08:35:08
        radar2.0	2019-05-26 08:35:08.997	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.944 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:35:08.965	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.920 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:35:05.204	info	debug: started #29 hcitool -i hci0 lescan --duplicates
        radar2.0	2019-05-26 08:35:05.166	info	debug: started #28 hciconfig hci0 up
        radar2.0	2019-05-26 08:35:05.050	info	debug: radar2 found uIP's: []
        radar2.0	2019-05-26 08:35:05.048	info	debug: started #27 hciconfig hci0 down
        radar2.0	2019-05-26 08:34:56.180	info	debug: ChangeState ack:true of _uIPs = [ '192.168.1.1','192.168.1.10','192.168.1.100','192.168.1.101','192.168.1.102','192.168.1.11','192.168.1.12','192.168.1.13','192.168.1.14','192.168.1.199','192.1
        radar2.0	2019-05-26 08:34:56.171	info	debug: radar2 found uBT's: [ '94:87:e0:a2:16:1e' ]
        radar2.0	2019-05-26 08:34:56.170	info	debug: and not here (Familie, Mathias, Mieter)
        radar2.0	2019-05-26 08:34:56.170	info	debug: and who here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:56.170	info	debug: radar2 found here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:48.995	info	debug: ChangeState ack:true of Mathias-Handy._lastHere = 2019-05-26@08:34:48
        radar2.0	2019-05-26 08:34:48.982	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.965 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:34:48.949	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.955 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:34:45.162	info	debug: started #26 hcitool -i hci0 lescan --duplicates
        radar2.0	2019-05-26 08:34:45.127	info	debug: started #25 hciconfig hci0 up
        radar2.0	2019-05-26 08:34:45.006	info	debug: radar2 found uIP's: []
        radar2.0	2019-05-26 08:34:45.005	info	debug: started #24 hciconfig hci0 down
        radar2.0	2019-05-26 08:34:35.755	info	debug: ChangeState ack:true of _uIPs = [ '192.168.1.1','192.168.1.10','192.168.1.100','192.168.1.101','192.168.1.102','192.168.1.11','192.168.1.12','192.168.1.13','192.168.1.14','192.168.1.2','192.168
        radar2.0	2019-05-26 08:34:35.747	info	debug: radar2 found uBT's: [ '94:87:e0:a2:16:1e' ]
        radar2.0	2019-05-26 08:34:35.747	info	debug: and not here (Familie, Mathias, Mieter)
        radar2.0	2019-05-26 08:34:35.747	info	debug: and who here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:35.746	info	debug: radar2 found here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:28.900	info	debug: ChangeState ack:true of Mathias-Handy._lastHere = 2019-05-26@08:34:28
        radar2.0	2019-05-26 08:34:28.890	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.951 seconds and returned 24 hosts.
        radar2.0	2019-05-26 08:34:28.877	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.942 seconds and returned 24 hosts.
        radar2.0	2019-05-26 08:34:25.098	info	debug: started #23 hcitool -i hci0 lescan --duplicates
        radar2.0	2019-05-26 08:34:25.057	info	debug: started #22 hciconfig hci0 up
        radar2.0	2019-05-26 08:34:24.939	info	debug: radar2 found uIP's: []
        radar2.0	2019-05-26 08:34:24.938	info	debug: started #21 hciconfig hci0 down
        radar2.0	2019-05-26 08:34:16.511	info	debug: radar2 found uBT's: [ '94:87:e0:a2:16:1e' ]
        radar2.0	2019-05-26 08:34:16.511	info	debug: and not here (Familie, Mathias, Mieter)
        radar2.0	2019-05-26 08:34:16.511	info	debug: and who here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:16.510	info	debug: radar2 found here (Mathias-Handy)
        radar2.0	2019-05-26 08:34:08.903	info	debug: ChangeState ack:true of Mathias-Handy._lastHere = 2019-05-26@08:34:08
        radar2.0	2019-05-26 08:34:08.877	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.964 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:34:08.840	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.942 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:34:05.047	info	debug: started #20 hcitool -i hci0 lescan --duplicates
        radar2.0	2019-05-26 08:34:05.011	info	debug: started #19 hciconfig hci0 up
        radar2.0	2019-05-26 08:34:04.896	info	debug: radar2 found uIP's: []
        radar2.0	2019-05-26 08:34:04.895	info	debug: started #18 hciconfig hci0 down
        radar2.0	2019-05-26 08:33:56.065	info	debug: ChangeState ack:true of _uIPs = [ '192.168.1.1','192.168.1.10','192.168.1.100','192.168.1.101','192.168.1.102','192.168.1.11','192.168.1.12','192.168.1.13','192.168.1.14','192.168.1.199','192.1
        radar2.0	2019-05-26 08:33:56.055	info	debug: radar2 found uBT's: [ '94:87:e0:a2:16:1e' ]
        radar2.0	2019-05-26 08:33:56.055	info	debug: and not here (Familie, Mathias, Mieter)
        radar2.0	2019-05-26 08:33:56.055	info	debug: and who here (Mathias-Handy)
        radar2.0	2019-05-26 08:33:56.054	info	debug: radar2 found here (Mathias-Handy)
        radar2.0	2019-05-26 08:33:48.799	info	debug: ChangeState ack:true of Mathias-Handy._lastHere = 2019-05-26@08:33:48
        radar2.0	2019-05-26 08:33:48.780	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.938 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:33:48.767	info	debug: arp-scan -lgq --retry=4 --timeout=400 --interface=eth0 executed for 3.945 seconds and returned 26 hosts.
        radar2.0	2019-05-26 08:33:44.990	info	debug: started #17 hcitool -i hci0 lescan --duplicates
        radar2.0	2019-05-26 08:33:44.953	info	debug: started #16 hciconfig hci0 up
        radar2.0	2019-05-26 08:33:44.838	info	debug: radar2 found uIP's: []
        radar2.0	2019-05-26 08:33:44.836	info	debug: started #15 hciconfig hci0 down
        das Handy wird per arp-scan getrickert.
        laut Log könnte ich es aber auch via Bluetooth einbinden.
        ich vermute, BT geht, BLE nicht.
        Gruß,
        Mathias
        IObroker auf dem NUC als VM.
          @ChristianF
          Hast wirklich die Liste der Befehle hier im Install Spoiler ausgeführt?
          Der Rechner hat keine Rechte für das Bind auf DHCP, auch arp-scan braucht Rechte.
          Und noch was, hast eventuell 'ne alte Instanz laufen? mach mal sudo pkill -f io.radar2.0
          ChristianF
          #640
          @frankjoke
          Ich hatte die Befehle ausgeführt die auf der Git Seite standen. Habe nun nochmal alle von hier oben aus dem Spoiler nachgezogen, ändert aber nichts. Ein DHCP/DNS Server (in meinem Falle PiHole) und Radar auf einem Rechner scheinen sich nicht zu vertragen (beanspruchen halt beide Port 67) . Schade, damit muss ich dann zurück zum BLE Adapter :(
          Das Fehlerlog sieht übrigens immernoch genauso aus:
          host.raspi	2019-05-26 19:07:18.667	info	Restart adapter system.adapter.radar2.1 because enabled
          host.raspi	2019-05-26 19:07:18.667	error	instance system.adapter.radar2.1 terminated with code 0 (OK)
          host.raspi	2019-05-26 19:07:18.667	error	Caught by controller[0]: port: 67 }
          host.raspi	2019-05-26 19:07:18.667	error	Caught by controller[0]: address: '0.0.0.0',
          host.raspi	2019-05-26 19:07:18.667	error	Caught by controller[0]: syscall: 'bind',
          host.raspi	2019-05-26 19:07:18.667	error	Caught by controller[0]: code: 'EADDRINUSE',
          host.raspi	2019-05-26 19:07:18.667	error	Caught by controller[0]: errno: 'EADDRINUSE',
          host.raspi	2019-05-26 19:07:18.666	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
          host.raspi	2019-05-26 19:07:18.666	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:142:11)
          host.raspi	2019-05-26 19:07:18.666	error	Caught by controller[0]: at _handle.lookup (dgram.js:266:18)
          host.raspi	2019-05-26 19:07:18.666	error	Caught by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:67
          host.raspi	2019-05-26 19:07:15.999	info	instance system.adapter.radar2.1 started with pid 10994
          host.raspi	2019-05-26 19:07:15.986	info	"system.adapter.radar2.1" enabled
          Gibt es vielleicht irgendeinen Weg, wie man dem Adapter sagen kann, dass er ARP, DHCP usw. weglassen soll, sondern sich nur auf BT konzentrieren soll?
          frankjokeF 1 Antwort Letzte Antwort
          • C ChristianF
            @frankjoke
            frankjokeF Offline
            frankjokeF Offline
            frankjoke
            #641
            @ChristianF
            Ja, PiHole ist ein Problem das wir noch nicht lösen konnten, Bin noch am überlegen ob ich die DNS-Funktion abschaltbar mache damit der Rest verwendet werden kann...
            Frank,
            C 1 Antwort Letzte Antwort
              @smile
              smileS Offline
              smileS Offline
              smile
              #642
              @frankjoke Okay, danke für den Hinweis. Ich bin ein kleines bisschen IT bewandert, aber so intensiv leider nicht.
              Es wäre mega klasse wenn der Adapter unter Win10 funktional wäre.
              Wenn ich auf irgendeine Weise dazu mit Testbetrieb bei mir beitragen kann, dann helfe ich gern.
              Ich habe mir noch einen separaten Bluetooth Dongle besorgt, falls das hilfreich ist.
              io.broker @ debian @ virtualbox @ Windows 10 Pro / Node 18.17.1, npm 9.6.7 / CCU3 / IR.Trans Server / Daslight 4 / Mobotix IP Cams / Qnap NAS / Sonos /
              Mein Rolladen - Blockly: https://forum.iobroker.net/topic/6442/das-ultimative-markisen-rolladen-blockly-script
                @ChristianF
                ChristianF
                #643
                @frankjoke das wäre extrem klasse. Viel mehr als eine zusätzliche If Schleife mit zugehöriger Checkbox auf der Config Seite dürfte das eigentlich nicht sein, oder? Das würde mindestens den Pihole Usern entgegen kommen :)
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  #644
                  Ich habe IObroker bei pi hole außen vor gelassen. Das heißt, ich habe bei jedem Gerät als DNS die IP von pi hole eingegeben.
                  Bei der Raspberrymatic und IObroker eben nicht.
                  Funktioniert einwandfrei.
                  @frankjoke
                  Hast Du schon etwas mit meinem Log anfangen können?
                  Gruß,
                  Mathias
                  • C Offline
                    ChrisXY
                    #645
                    Also nach 2x Iobroker Kaputt nach dem ich Radar2 testen wote ( Alles hat nurnoch gehangen trotz Deinstall .. )
                    Habe ich mich ein 3. mal getraut da iobroker nun tabie läuft seit Tagen )
                    Install Log:
                    $ ./iobroker add radar2  --host iobroker
                    NPM version: 6.4.1
                    npm install iobroker.radar2@1.0.3 --production --save --prefix "/opt/iobroker" (System call)
                    npm
                     notice created a lockfile as package-lock.json. You should commit this file.
                    prebuild-install
                     info begin Prebuild-install version 5.3.0
                    prebuild-install
                    info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/97a8e8-usb-v1.6.0-node-v57-linux-x64.tar.gz
                    prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v57-linux-x64.tar.gz
                    prebuild-install
                     http 200 https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v57-linux-x64.tar.gz
                    prebuild-install info downloading to @ /home/iobroker/.npm/_prebuilds/97a8e8-usb-v1.6.0-node-v57-linux-x64.tar.gz.10076-1f8b97d431049.tmp
                    prebuild-install info renaming to @ /home/iobroker/.npm/_prebuilds/97a8e8-usb-v1.6.0-node-v57-linux-x64.tar.gzprebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/97a8e8-usb-v1.6.0-node-v57-linux-x64.tar.gz
                    prebuild-install info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node
                    prebuild-install info unpack required /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node successfully
                    prebuild-install
                     info install Successfully installed prebuilt binary!
                    node-pre-gyp
                     WARN Using request for node-pre-gyp https download
                    node-pre-gyp
                     WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v57-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:252:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                    In file included from ../src/BluetoothHciSocket.cpp:8:0:
                    ../../../nan/nan.h:1045:46: note: declared here
                       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:283:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                    ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden     #include <bluetooth/bluetooth.h>
                    compilation terminated.
                    make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
                    gyp
                     ERR! build error
                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                    gyp ERR! stack     at emitTwo (events.js:126:13)
                    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                    gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
                    gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
                    gyp ERR! node -v v8.16.0gyp ERR! node-gyp -v v3.8.0
                    gyp ERR! not ok
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                    host.iobroker install adapter radar2
                    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.radar2"
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    prebuild-install
                    prebuild-install
                    prebuild-install info found cached prebuild prebuild-install
                    prebuild-install
                     info unpack resolved to /opt/iobroker/node_modules/iobroker.radar2/node_modules/usb/build/Release/usb_bindings.node
                    prebuild-install info unpack required /opt/iobroker/node_modules/iobroker.radar2/node_modules/usb/build/Release/usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
                    node-pre-gyp
                    WARN
                    node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v57-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                    gyp
                     ERR! build error
                    ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at emitTwo (events.js:126:13)
                    gyp ERR!
                     "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetooth
                    gyp ERR! not ok
                    npm
                    npm
                     WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
                    npm WARN optional
                    got /opt/iobroker/node_modules/iobroker.radar2/admin
                    upload [13] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
                    upload [12] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
                    upload [11] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
                    upload [10] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
                    upload [9] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    host.iobroker object system.adapter.radar2 created
                    host.iobroker create instance radar2
                    host.iobroker object system.adapter.radar2.0.outputCount created
                    host.iobroker object system.adapter.radar2.0.inputCount created
                    host.iobroker object system.adapter.radar2.0.uptime created
                    host.iobroker object system.adapter.radar2.0.memRss created
                    host.iobroker object system.adapter.radar2.0.memHeapTotal created
                    host.iobroker object system.adapter.radar2.0.memHeapUsed created
                    host.iobroker object system.adapter.radar2.0.cputime created
                    host.iobroker object system.adapter.radar2.0.cpu created
                    host.iobroker object system.adapter.radar2.0.connected created
                    host.iobroker object system.adapter.radar2.0.alive created
                    host.iobroker object system.adapter.radar2.0 created
                    process exited with code 0
                    Und im log fehler und Adapter bleibt rot:
                    host.iobroker	2019-05-31 08:27:50.887	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.iobroker	2019-05-31 08:27:50.887	error	instance system.adapter.radar2.0 terminated with code null ()
                    host.iobroker	2019-05-31 08:27:50.887	warn	instance system.adapter.radar2.0 terminated due to SIGABRT
                    host.iobroker	2019-05-31 08:27:50.886	error	Caught by controller[0]: .0: ../deps/uv/src/unix/poll.c:123: uv_poll_start: Assertion `!(((handle)->flags & (UV_HANDLE_CLOSING | UV_HANDLE_CLOSED)) != 0)' failed.
                    radar2.0	2019-05-31 08:27:48.995	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                    host.iobroker	2019-05-31 08:27:48.323	info	instance system.adapter.radar2.0 started with pid 12970
                    host.iobroker	2019-05-31 08:27:18.187	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.iobroker	2019-05-31 08:27:18.187	error	instance system.adapter.radar2.0 terminated with code null ()
                    host.iobroker	2019-05-31 08:27:18.187	warn	instance system.adapter.radar2.0 terminated due to SIGABRT
                    host.iobroker	2019-05-31 08:27:18.187	error	Caught by controller[0]: .0: ../deps/uv/src/unix/poll.c:123: uv_poll_start: Assertion `!(((handle)->flags & (UV_HANDLE_CLOSING | UV_HANDLE_CLOSED)) != 0)' failed.
                    radar2.0	2019-05-31 08:27:16.320	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                    host.iobroker	2019-05-31 08:27:15.611	info	instance system.adapter.radar2.0 started with pid 12738
                    host.iobroker	2019-05-31 08:26:45.595	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.iobroker	2019-05-31 08:26:45.595	error	instance system.adapter.radar2.0 terminated with code null ()
                    host.iobroker	2019-05-31 08:26:45.595	warn	instance system.adapter.radar2.0 terminated due to SIGSEGV
                    radar2.0	2019-05-31 08:26:43.663	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                    host.iobroker	2019-05-31 08:26:42.935	info	instance system.adapter.radar2.0 started with pid 12509
                    host.iobroker	2019-05-31 08:26:12.926	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.iobroker	2019-05-31 08:26:12.926	error	instance system.adapter.radar2.0 terminated with code null ()
                    host.iobroker	2019-05-31 08:26:12.926	warn	instance system.adapter.radar2.0 terminated due to SIGSEGV
                    • C ChrisXY
                      Install Log:
                      NPM version: 6.4.1
                      npm
                      prebuild-install
                      prebuild-install
                      prebuild-install
                      prebuild-install
                      node-pre-gyp
                      node-pre-gyp
                      gyp
                       ERR! build error
                      gyp ERR! not ok
                      prebuild-install
                      prebuild-install
                      prebuild-install
                      node-pre-gyp
                      WARN
                      gyp
                       ERR! build error
                      gyp ERR!
                      gyp ERR! not ok
                      npm
                      npm
                      npm WARN optional
                      frankjokeF Offline
                      frankjokeF Offline
                      frankjoke
                      #646
                      @ChrisXY ,
                      Ich sehe 2 Dinge in den ersten Zeilen des logs:
                      1. Du installierst nicht die letzte Version von git (V1.2.0), es wird 1.0.3 installiert! Bitte installiere über admin, clicke dort auf das git-Äffchen und gib dort unter 'Von github' radar2 ein und installieren. Aber:
                      2. Vorher das script ausführen welches beim readme unter install (oder hier am ersten post) gelistet ist. Habe im log gesehen dass z.B. bluetooth.h nicht gefunden wird und das deutet darauf hin dass einige bluetooth-treiber nicht installiert wurden!
                      Das kann natürlich auch daher kommen dass du nicht unter linux sondern unter WSL/Windows arbeitest, aber deine Kommandozeile schaut nach linux aus.
                      Bitte checken!
                      Frank,
                        @ChrisXY ,
                        Bitte checken!
                        ChrisXY
                        #647
                        @frankjoke ups okay. Ich nutze docker und habe bei BT. Kann man das nicht deaktivieren?
                        • stephan1827S Offline
                          stephan1827
                          schrieb am zuletzt editiert von stephan1827
                          #648
                          ich versuche radar2 in einem Docker Container auf einer Synology zu installieren. Ich bekomme nach dem Start die folgenden Log Einträge
                          2019-06-01 07:23:06.506 - info: host.e329125469a2 instance system.adapter.radar2.0 started with pid 17801
                          2019-06-01 07:23:06.978 - info: radar2.0 starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                          2019-06-01 07:23:07.030 - info: radar2.0 radar2 initialization started...
                          2019-06-01 07:23:07.249 - warn: host.e329125469a2 instance system.adapter.radar2.0 terminated due to SIGSEGV
                          2019-06-01 07:23:07.250 - error: host.e329125469a2 instance system.adapter.radar2.0 terminated with code null ()
                          2019-06-01 07:23:07.250 - info: host.e329125469a2 Restart adapter system.adapter.radar2.0 because enabled
                          Normalerweise sollte das behoben werden wenn ich die folgenden Zeilen ausführe
                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                          Wenn ich das mache startet jedoch iobroker nicht mehr. Ich habe eine völlig neue Instanz von dem iobroker 3.0.0 Container erstellt und auch da habe ich das Problem.
                          Die Zeile
                          node /opt/iobroker/node_modules/iobroker.radar2/radar2.js --force --logs --nolazy --debug
                          ergibt
                          info: got following adapter: { name: 'radar2' }
                          use known BT list: [ '01:12:23:34:45:56' ]
                          use known IP list: [ '1.1.1.1' ]
                          Remove name end for host names: .fritz.box
                          arp-scan will use the following interfaces: [ 'eth0' ]
                          Speicherzugriffsfehler
                          Hat jemand eine Idee woran das noch liegen könnte?
                          Stephan
                          • C Offline
                            ChristianF
                            #649
                            Speicherzugriffsfehler klingt stark nach einem Hardware Problem. Leider schreibst du nicht, was es für ein Host ist. Sollte es ein Einplatinensystem a la Raspberry oder Derivat sein, würde ich stark auf eine defekte Speicherkarte oder ein Netzteil Problem tippen.
                            stephan1827S 1 Antwort Letzte Antwort
                            • C ChristianF
                              stephan1827
                              #650
                              @ChristianF Das Ganze läuft in einem Docker Container. Ich denke einen Hardwarefehler können wir ausschliessen. Das gesamte System läuft ohne Problem und es laufen mehrere Docker Container ohne jede Probleme. Ich habe jetzt mal die aktuelle GitHub Version 1.2.0 installiert. Beim erstellen des Adapter kommen diverse Fehlermeldungen. Ich denke das Problem lieget irgendwo in der node-pre-gyp installation. Habe versucht es von Hand zu installieren aber bisher ohne Glück.
                              $ ./iobroker add radar2  --host test
                              host.test install adapter radar2
                              npm
                              ../src/raw.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE raw::CreateChecksum(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:82:44: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                Local<Object> buffer = info[1]->ToObject ();
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
                                               from ../src/raw.h:21,
                                               from ../src/raw.cc:6:
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
                               Local<Object> Value::ToObject() const {
                              ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::GetOption(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:388:44: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                Local<Object> buffer = info[2]->ToObject ();
                              ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Pause(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:509:40: warning: ‘v8::Local<v8::Boolean> v8::Value::ToBoolean() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                bool pause_recv = info[0]->ToBoolean ()->Value ();
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10034:16: note: declared here
                               Local<Boolean> Value::ToBoolean() const {
                              ../src/raw.cc:515:40: warning: ‘v8::Local<v8::Boolean> v8::Value::ToBoolean() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]  bool pause_send = info[1]->ToBoolean ()->Value ();
                              ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Recv(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:557:31: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 buffer = info[0]->ToObject ();
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,                 from ../src/raw.h:21,
                              ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:650:30: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::SetOption(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:727:45: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              node-pre-gyp
                              node-pre-gyp
                              WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v64-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@10.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                              ../src/node_usb.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetDebugLevel(Nan::NAN_METHOD_ARGS_TYPE)’:../src/node_usb.cc:99:73: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                if (info.Length() != 1 || !info[0]->IsUint32() || info[0]->Uint32Value() > 4) {
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from ../src/node_usb.h:12,
                                               from ../src/node_usb.cc:1:
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
                                 V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                 declarator __attribute__((deprecated(message)))
                              ../src/node_usb.cc:103:53: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                libusb_set_debug(usb_context, info[0]->Uint32Value());
                              ../src/node_usb.cc: In function ‘void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)’:../src/node_usb.cc:151:58: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
                              In file included from ../src/helpers.h:3:0,
                                               from ../src/node_usb.h:21,
                              ../../nan/nan.h:1001:46: note: declared here
                              ../src/node_usb.cc: In function ‘v8::Local<v8::Value> libusbException(int)’:../src/node_usb.cc:301:14: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                e->ToObject()->Set(Nan::New<String>("errno").ToLocalChecked(), Nan::New<Integer>(errorno));
                              In file included from ../src/node_usb.h:12:0,                 from ../src/node_usb.cc:1:
                              ../src/device.cc: In static member function ‘static void Req::default_after(uv_work_t*)’:../src/device.cc:237:64: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                  Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
                                               from ../src/device.cc:1:
                              ../../nan/nan.h:959:46: note: declared here
                              ../src/transfer.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Transfer_Submit(Nan::NAN_METHOD_ARGS_TYPE)’:../src/transfer.cc:58:47: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                Local<Object> buffer_obj = info[0]->ToObject();
                              In file included from ../src/node_usb.h:12:0,                 from ../src/transfer.cc:1:
                              ../src/transfer.cc: In function ‘void handleCompletion(Transfer*)’:../src/transfer.cc:126:72: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                 Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
                              In file included from ../src/helpers.h:3:0,                 from ../src/node_usb.h:21,
                              node-pre-gyp
                              node-pre-gyp
                               WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@10.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                              ../../../nan/nan.h:980:46: note: declared here
                              ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:396:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     devId = arg0->IntegerValue();
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                               from /home/iobroker/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                                               from ../src/BluetoothHciSocket.cpp:7:
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
                                 V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
                              ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:418:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/linux/DeviceINQ.cc: In static member function ‘static void DeviceINQ::EIO_AfterSdpSearch(uv_work_t*)’:../src/linux/DeviceINQ.cc:139:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                   baton->cb->Call(1, argv);
                              In file included from ../src/linux/DeviceINQ.cc:14:0:
                              ../node_modules/nan/nan.h:1674:3: note: declared here
                                 Call(int argc, v8::Local<v8::Value> argv[]) const {
                              ../src/linux/DeviceINQ.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE DeviceINQ::InquireSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/DeviceINQ.cc:251:26: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                     found->Call(2, argv);
                              ../src/linux/DeviceINQ.cc:255:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]     callback->Call(0, argv);
                              ../src/linux/DeviceINQ.cc: In member function ‘virtual void InquireWorker::HandleOKCallback()’:../src/linux/DeviceINQ.cc:284:26: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                              ../src/linux/DeviceINQ.cc:288:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]     callback->Call(0, argv);
                              ../src/linux/DeviceINQ.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE DeviceINQ::SdpSearch(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/DeviceINQ.cc:317:38: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                   String::Utf8Value address(info[0]);
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from ../src/linux/DeviceINQ.cc:12:
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                                                 explicit Utf8Value(Local<v8::Value> obj));
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterConnect(uv_work_t*)’:../src/linux/BTSerialPortBinding.cc:83:32: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                       baton->cb->Call(0, NULL);
                              In file included from ../src/linux/BTSerialPortBinding.cc:14:0:
                              ../src/linux/BTSerialPortBinding.cc:89:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]         baton->ecb->Call(1, argv);
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_Write(uv_work_t*)’:../src/linux/BTSerialPortBinding.cc:115:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                   if (data->result != data->bufferLength) {
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterWrite(uv_work_t*)’:../src/linux/BTSerialPortBinding.cc:135:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                   data->callback->Call(2, argv);
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterRead(uv_work_t*)’:../src/linux/BTSerialPortBinding.cc:207:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                   baton->cb->Call(2, argv);
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/BTSerialPortBinding.cc:253:38: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from ../src/linux/BTSerialPortBinding.cc:12:
                              ../src/linux/BTSerialPortBinding.cc:255:41: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                   int channelID = info[1]->Int32Value();
                              /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                 V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              ../src/linux/BTSerialPortBinding.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::Read(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/BTSerialPortBinding.cc:383:25: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                       nc->Call(2, argv);
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterListen(uv_work_t*)’:../src/linux/BTSerialPortBindingServer.cc:176:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                              In file included from ../src/linux/BTSerialPortBindingServer.cc:14:0:../node_modules/nan/nan.h:1674:3: note: declared here
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::TryListenAgain()’:../src/linux/BTSerialPortBindingServer.cc:199:31: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterWrite(uv_work_t*)’:../src/linux/BTSerialPortBindingServer.cc:239:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterRead(uv_work_t*)’:../src/linux/BTSerialPortBindingServer.cc:311:36: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                              ../src/linux/BTSerialPortBindingServer.cc:326:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]     baton->cb->Call(2, argv);
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/BTSerialPortBindingServer.cc:408:70: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                       string propertyName = std::string(*String::Utf8Value(property));
                              In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from ../src/linux/BTSerialPortBindingServer.cc:12:
                              ../src/linux/BTSerialPortBindingServer.cc:410:75: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         options[propertyName] = std::string(*String::Utf8Value(optionValue));
                              ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::Read(Nan::NAN_METHOD_ARGS_TYPE)’:../src/linux/BTSerialPortBindingServer.cc:618:25: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                       nc->Call(2, argv);
                              ../src/linux/BTSerialPortBindingServer.cc: In member function ‘virtual void BTSerialPortBindingServer::ClientWorker::HandleOKCallback()’:../src/linux/BTSerialPortBindingServer.cc:672:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                   callback->Call(1, argv);
                              host.test object system.adapter.radar2 created
                              host.test create instance radar2
                              host.test object radar2.0.info.connection created
                              host.test object radar2.0.info created
                              host.test object system.adapter.radar2.0.outputCount created
                              host.test object system.adapter.radar2.0.inputCount created
                              host.test object system.adapter.radar2.0.uptime created
                              host.test object system.adapter.radar2.0.memRss created
                              host.test object system.adapter.radar2.0.memHeapTotal created
                              host.test object system.adapter.radar2.0.memHeapUsed created
                              host.test object system.adapter.radar2.0.cputime created
                              host.test object system.adapter.radar2.0.cpu created
                              host.test object system.adapter.radar2.0.connected created
                              host.test object system.adapter.radar2.0.alive created
                              host.test object system.adapter.radar2.0 created
                              • C Offline
                                ChrisXY
                                #651
                                nochmal kurze frage von oben. Kann man das BT nicht Deaktivieren ? Da ich das eh nicht nutze will ich das script jetzt auch nur ungern ausühren. Leider läuft der Adapter sonst wohl nicht :(
                                • C ChrisXY
                                  ChristianF
                                  #652
                                  @ChrisXY Bisher sind keine Module einzeln aktivier- oder deaktivierbar. Ich hätte es auch gern einzeln deaktivierbar , da ich nur die BT Thematik nutze und das DNS Geraffel bei mir mit PiHole kollidiert.
                                  • stephan1827S stephan1827
                                    npm
                                    node-pre-gyp
                                    node-pre-gyp
                                    node-pre-gyp
                                    node-pre-gyp
                                             nc->Call(2, argv);
                                             nc->Call(2, argv);
                                    frankjokeF Offline
                                    frankjokeF Offline
                                    frankjoke
                                    #653
                                    @stephan1827
                                    Das Problem ist der container, leider verbiegen container einige Systemaufrufe und nicht alles was im System erlaubt ist ist im container erlaubt.
                                    Ich habe ein Notebook bestellt das mein neues Entwicklungssystem werden wird, werd ich hoffentlich morgen geliefert bekommen und dann zu Pfingsten installiert haben (damit ich mir nicht das meiner Frau ausborgen muss wo ich keine speziellen tools installieren darf) und dann den Adapter umzuschreiben umBT, DHCP und andere Teile getrennt ausschalten zu können und auch zwischen noble für Windows und für Linux umzuschalten.
                                    Habe vor 2 Jahren aufgegeben mit Container (auf raspi's) zu arbeiten, kanns aber dann mal auf einer Testmaschine versuchen, auf Produktionssysteme kommt mir kein Docker auf 'nem Raspi, ist nur unnötiger overhead.
                                    Frank,
                                    C stephan1827S 2 Antworten Letzte Antwort
                                      @stephan1827
                                      ChristianF
                                      #654
                                      @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
                                      (...) dann den Adapter umzuschreiben umBT, DHCP und andere Teile getrennt ausschalten zu können und auch zwischen noble für Windows und für Linux umzuschalten.
                                      Weltbeste Nachricht!! Vielen vielen Dank bereits im Voraus!
                                      Das sehe ich genauso. Ich habe die ganzen Containergeschichten sein gelassen weil es laufend Ärger gab. Seitdem verwende ich auf meinem QNAP Nas in der Virtualisation Station kleine virtuelle Maschinen (sind übrigens VMware kompatibel!) mit einem Minimal-Debian für die einzelnen Anwendungen, und es läuft sehr gut. Vor allem haben Änderungen am Host keinen Einfluss auf die VMs.
                                        @stephan1827
                                        stephan1827
                                        #655
                                        @frankjoke Ich habe das mittlerweile am Laufen aber leider kann ich nicht genau sagen was das Problem war 😕 Ich habe einen Testcontainer erstellt wo eine neue ioBroker installation lief. Ich habe dort bei der Installation von radar2 schon Fehlermeldungen gesehen obwohl am Ende gesagt wurde das die Installation erfolgreich war. Die Meldungen deuteten auf Probleme mit node und nodejs hin. Ich habe die beiden auf den aktuellen Stand gebracht und noch einige anderen Sachen verdreht und plötzlich lief es. Ich habe dann die Daten von meinem Hauptcontainer importiert und es so ans laufen gebracht.
                                        Ich habe aber ein anderes Problem gefunden. Man kann in den Einstellungen festlegen nach wie vielen Minuten ein Teilnehmer als abwesend eingestuft wird. Ich würde also denken das wenn ein Teilnehmer erkannt wurde dauert es mindestens so lange bis er also abwesend erkannt wird. Ich habe jedoch ein iPhone das deutlich schneller als die 15 Minuten wieder auf false gesetzt wird. Siehe Screenshots unten
                                        • bmueller77B Offline
                                          bmueller77B Offline
                                          bmueller77
                                          schrieb am zuletzt editiert von bmueller77
                                          #656
                                          Hi, muss ich, um den Tintenstand meines HP-Laserjets abzurufen, noch irgendwas einstellen, außer der IP? Bisher finde ich unter Objekten keine Informationen zum Drucker... abgesehen von der Verfügbarkeit.
