  4. Letsencrypt will nicht laufen
httpslets encryptraspberry pi
11 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • 9 Offline
    9 Offline
    9_Mad-Max_5
    Ich versuche gerade auf meinem Pi3 wo iobroker läuft ein letsencrypt zertifikat zu bekommen.
    Während es ohne Let´s Encrypt noch https läuft stürtzt beim einschalten der admin adapter jedesmal ab.
    Leider verstehe ich nicht wieso.
    Vl kennt ja jemand das Problem schon.
    2019-04-02 19:47:38.233 - error: Caught by controller[0]: { Error: listen EADDRINUSE :::80
    2019-04-02 19:47:38.234 - error: Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at listenInCluster (net.js:1401:12)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at Server.listen (net.js:1485:7)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:75:21)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:446:32)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:477:7)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at getData (/opt/iobroker/node_modules/iobroker.admin/main.js:388:39)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.admin/main.js:414:35)
    2019-04-02 19:47:38.235 - error: Caught by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-04-02 19:47:38.236 - error: Caught by controller[0]: errno: 'EADDRINUSE',
    2019-04-02 19:47:38.237 - error: Caught by controller[0]: code: 'EADDRINUSE',
    2019-04-02 19:47:38.237 - error: Caught by controller[0]: syscall: 'listen',
    2019-04-02 19:47:38.237 - error: Caught by controller[0]: address: '::',
    2019-04-02 19:47:38.237 - error: Caught by controller[0]: port: 80 }
    2019-04-02 19:47:38.237 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
    2019-04-02 19:47:38.237 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2019-04-02 19:47:39.262 - info: host.raspberrypi object change system.adapter.admin.0
    • 9 Offline
      9 Offline
      9_Mad-Max_5
      Ok sehr dumm von mir wenn der port 80 von Appache schon belegt es kann es natürich nicht klapen.
      • 9 Offline
        9 Offline
        9_Mad-Max_5
        MHm ner error
        019-04-02 20:08:23.594	error	Cannot get certificates: Error: connect ETIMEDOUT 62.158.202.35:80
        • 9 Offline
          9 Offline
          9_Mad-Max_5
          Still not working
          admin.0	2019-04-02 21:48:16.093	error	Cannot get certificates: Error: socket hang up
          • 9 9_Mad-Max_5
            Still not working
            astrakid
            @9_Mad-Max_5 da kommt keine Antwort von le
            Welche Daten verwendest du? Kommst du von aussen über Port 80 auf deinen rpi3?
            • 9 Offline
              9 Offline
              9_Mad-Max_5
              So hat ne weile gedauert bis alles wieder lief. Ja der Port 80 ist von außen verfügbar habe ihn durch gereicht genauso wie 443.
              Solange ich die Schlüssel auf default lasse klappt alles. Aber wenn ich Let´s encrypt einschalte passiert ewig nichts, bestimmt eine 3/4 h habe ich es schon laden lassen. Vorgestern bevor ich erneut den Pi bereinigt hatte von alten Projekten hat es auch einmal funktioniert und er hat alles im Ordner abgelegt. Aber das scheint er nicht mehr zu mögen.
              • 9 Offline
                9 Offline
                9_Mad-Max_5
                Mhm leider will dieser teil vom admin adapter einfach nicht so wie ich will.
                • 9 9_Mad-Max_5
                  astrakid
                  @9_Mad-Max_5 kannst du das lets encrypt.scriptal manuell anschmeissen? Gibt bestimmt einen Fehler. Ggf Mal im Log schauen.
                  • 9 Offline
                    9 Offline
                    9_Mad-Max_5
                    Habe es jetzt aufgegeben und einfach letsecrypt direkt instaliert und die zertifikate in iobroker angezogen. Das hat fast auf anhieb geklappt und ich hatte jetzt keine lust mehr.
                    • 9 9_Mad-Max_5
                      darkiop
                      @9_Mad-Max_5 Kannst du kurz beschreiben was du da genau gemacht hast?
                      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                      9 1 Antwort Letzte Antwort
                      • D darkiop
                        9 Offline
                        9 Offline
                        9_Mad-Max_5
                        @darkiop Hallo,
                        Ich habe mich an dieses Tutorial gehalten:
                        https://tutorials-raspberrypi.de/raspberry-pi-ssl-zertifikat-kostenlos-mit-lets-encrypt-erstellen/
                        Allerdings musste ich hier und da noch etwas anpassen je nachdem was noch auf dem PI läuft:
                        sudo apt-get install git
                        cd ~
                        git clone https://github.com/letsencrypt/letsencrypt
                        cd letsencrypt
                        Das hier musste bei mir noch rein da der certbot fehlt:
                        sudo apt-get install python-certbot-apache
                        ./letsencrypt-auto -d ERSTE_DOMAIN -d ZWEITE_DOMAIN --redirect -m DEINE_MAIL
                        Hier kam es bei mir allerdings zu einem solchen Fehler:
                        pip prints the following errors: ===================================================== Collecting ConfigArgParse==0.14.0 (from -r /tmp/tmp.iW05XqH4O0/letsencrypt-auto-requirements.txt (line 7))
                        Grund dafür ist wohl ein bug bei pip der er vor einem Tag oder so aufkam bei einer neueren rasbian version.
                        Leider habe ich mir den Link nicht gespeichert. Es musste einfach in der pip conf alles gelöscht werden damit er den certbot nicht mehr überprüft und danach klappt alles
                        sudo crontab -e
                        und das hier in crontab eintragen damit das Zertifikat immer wieder erneurt wird.
                        0 1 2 * * /home/pi/letsencrypt/letsencrypt-auto -d ERSTE_DOMAIN -d ZWEITE_DOMAIN --redirect -m DEINE_MAIL --agree-tos --renew-by-default
                        Nachdem nun endlich alles geklappt hatte und immerhin mal die Zertifikate da waren einfach auf den Schraubenschlüssel in iobroker drücken.
                        Dann auf den Tab Zertifikate tippen.
                        Und dort die Dateien mit dem absoluten Pfad eintragen:
                        /etc/letsencrypt/live/ERSTE_DOMAIN/
                        Öffentliches Zertifikat: cert.pem
                        Privates Zertifikat: privkey.cem
                        Verkettetes Zertifikat: fullchain.pem
                        Diese müssen dann im Admin-Adapter noch ausgewählt werden und HTTPS aktiviert.
                        Autentifizierung bitte auch an machen ansonsten öffnet man das Tor zur Hölle 😂
                        Den Letsencrypt tab fassen wir nicht im admin adapter an bzw deaktivieren da alles.
                        Zumindest klappt es bei mir so.
