  4. Neu aufgesetzter Broker zickt rum
iobroker zuverlässigkeit
20 Beiträge 4 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    Ohne logfiles und eine genaue Beschreibung deiner Vorgehensweise wird es schwer zu helfen.
    excalibur270
    schrieb am zuletzt editiert von excalibur270
    @wendy2702 Auszug bis der Broker abgeschmiert ist ```
    $ ./iobroker upgrade javascript
    Update javascript from @3.6.4 to @4.1.12
    NPM version: 6.4.1
    npm install iobroker.javascript@4.1.12 --production --save --prefix "/opt/iobroker" (System call)
    Could not install NodeJS typings. This is not critical.
    Reason: npm ERR! Unexpected token &
    npm ERR! path /root/.npm/_logs
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR! stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'scandir',
    npm ERR! path: '/root/.npm/_logs' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    errno: -13,
    code: 'EACCES',
    syscall: 'scandir',
    npm
    WARN
    JSON.parse Failed to parse jsonnpm WARN JSON.parse Unexpected token J in JSON at position 1 while parsing near '{J� "_froo�8$"bli@0.4...'
    npm WARN JSON.parse Failed to parse json
    npm WARN JSON.parse Unexpected token * in JSON at position 1 while parsing near '{* "_fsom": "slid�P0...'
    npm WARN JSON.parse Unexpected token  in JSON at position 1 while parsing near '{ *_grom"z "coffee-...'
    npm WARN JSON.parse Unexpected token s in JSON at position 0 while parsing near 'sJ "_nrom�>`"is
    sym...'
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.javascript"
    npm
    WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor
    • wendy2702W Online
      wendy2702W Online
      Sieht nach einem rechte Problem aus.
      Kannst du mal unmittelbar nach erstellen des Sticks den Fixer laufen lassen.
      • E Offline
        excalibur270
        Ich dachte das muss bei den neuen nicht gemacht werden. Bei den vorigen Stand nicht mehr verwenden. Fix in Vorbereitung. Dann werde ich das ganze nochmal machen. Zumindest läuft ja der rettungsstick halbwegs.
        • E excalibur270
          @excalibur270
          Von was für einem Stick redest du die ganze Zeit?
          Das Image ist für eine SD Karte
          E 1 Antwort Letzte Antwort
            @excalibur270
            excalibur270
            @Homoran kann man nicht einfach auf einen USB stick packen?
            • E excalibur270
              @excalibur270
              nein!
                @excalibur270
                nein!
                excalibur270
                @Homoran komisch. Das jetzige läuft im Prinzip wunderbar vom USB stick.
                • E excalibur270
                  @excalibur270
                  Wurde aber nicht dafür produziert und nie getestet.
                  Ich weiß auch nicht ob der Bootvorgang dafür konfiguriert ist.
                  • E excalibur270
                    @excalibur270
                    Habe mich eben nochmals schlau gemacht.
                    Angeblich geht es mit den letzten Raspbian Images tatsächlich dieses direkt mit etcher auf einen USB-Stick zu schreiben und von da zu booten
                    Nichtsdestoweniger ist dieses Vorgehen mit einem ioBroker Image nicht getestet, zumal die Installation des ioBroker auf einer SD Karte stattgefunden hatte.
                      @excalibur270
                      excalibur270
                      @Homoran Danke für deine Mühe. Ich habe gerade eine frische sd geordert und werde es dann übermorgen alles neu auf sd aufsetzen. Für den Notfall habe ich dann ja noch den stick auf dem es jetzt läuft.
                      • E Offline
                        excalibur270
                        schrieb am zuletzt editiert von Stabilostick
                        So. Neue SD Karte läuft. Allerdings:
                        iot.0	2019-04-02 06:26:53.675	error	[object Object]
                        iot.0	2019-04-02 06:26:53.673	error	Cannot fetch keys: "Internal server error"
                        iot.0	2019-04-02 06:26:50.530	error	Cannot read URL key: Not exists
                        Und es werden nicht alle Funktionen in der Aufzählung übernommen und somit sind die smart Geräte annähernd leer im iot Adapter.
                        [02.04.19 09:17 - stabilostick - Codeblock Format gefixed]
                        • apollon77A Offline
                          Wenn alles tut die Meldung bitte einfach ignorieren. Die kommt von der Google Home Integration, die noch kommt
                          • apollon77A apollon77
                            excalibur270
                            @apollon77 ne. Es geht ja nicht wirklich was. Von wegen cloud Verbindung. Der Adapter bleibt gelb.
                              iot oder cloud?
                              Zugangsdaten stimmen? Zertifikate ausgetauscht? Schalt mal Debug ein ... kommt da ggf mehr?
                                iot oder cloud?
                                excalibur270
                                @apollon77 iot. zugangsdaten sind korrekt. Zertifikate sind erneuert. Debug wirft die bekannten Fehler sus plus dann die Erstellung der ganzen Objekte.
                                Edit. Nun ist er grün. Deinstalliert und einmal von vorne. Jetzt geht er.
                                Danke trotzdem.
