  4. HmIP-Wired Nutzer
HmIP-Wired Nutzer
hmip-wired
33 Beiträge 4 Kommentatoren 4.2k Aufrufe 2 Beobachtet
  • foxriver76F Offline
    foxriver76F Offline
    foxriver76
    Lösche mal bitte deine Wired Devices in den hm-rpc Objekten, schalte den hm-rpc Adapter auf Debug und poste den Log.
    Videotutorials & mehr
    A 2 Antworten Letzte Antwort
    • foxriver76F foxriver76
      AHg
      @foxriver76 hier der Log
      2019-03-12 04:27:58.767 - info: hm-rpc.2 Disconnected
      2019-03-12 04:27:58.804 - info: hm-rpc.2 terminating
      2019-03-12 04:27:58.851 - info: host.raspberrypi instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
      2019-03-12 04:28:08.848 - info: host.raspberrypi object change system.adapter.hm-rpc.2
      2019-03-12 04:30:31.699 - info: host.raspberrypi object change system.adapter.hm-rpc.2
      2019-03-12 04:30:31.715 - info: host.raspberrypi "system.adapter.hm-rpc.2" enabled
      2019-03-12 04:30:31.788 - info: host.raspberrypi instance system.adapter.hm-rpc.2 started with pid 12249
      2019-03-12 04:30:33.155 - debug: hm-rpc.2 objectDB connected
      2019-03-12 04:30:33.265 - debug: hm-rpc.2 statesDB connected
      2019-03-12 04:30:33.416 - warn: hm-rpc.2 setObject updated (type=state) property native missing!
      2019-03-12 04:30:33.418 - warn: hm-rpc.2 setObject updated (type=state) property common.role missing!
      2019-03-12 04:30:33.479 - info: hm-rpc.2 starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
      2019-03-12 04:30:33.769 - info: hm-rpc.2 xmlrpc server is trying to listen on 127.0.0.1:2010
      2019-03-12 04:30:33.770 - info: hm-rpc.2 xmlrpc client is trying to connect to 192.168.2.62:2010/ with ["http://192.168.2.1:2010","hm-rpc.2"]
      2019-03-12 04:30:33.774 - debug: hm-rpc.2 Connect...
      2019-03-12 04:30:33.775 - debug: hm-rpc.2 xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.1:2010","hm-rpc.2"]
      2019-03-12 04:30:33.791 - debug: hm-rpc.2 start connecting interval
      2019-03-12 04:30:33.836 - info: hm-rpc.2 Connected
      2019-03-12 04:30:33.838 - debug: hm-rpc.2 clear connecting interval
      2019-03-12 04:30:33.839 - debug: hm-rpc.2 start ping interval
      2019-03-12 04:30:39.119 - debug: hm-rpc.2 system.adapter.admin.0: logging true
      2019-03-12 04:32:03.841 - debug: hm-rpc.2 [KEEPALIVE] Check if connection is alive
      2019-03-12 04:32:03.843 - debug: hm-rpc.2 Send PING...
      2019-03-12 04:32:03.877 - debug: hm-rpc.2 PING ok
        AHg
        @foxriver76 hier nochmal aktuell
        hm-rpc.2 2019-03-12 07:59:57.643 debug PING ok
        hm-rpc.2 2019-03-12 07:59:57.616 debug Send PING...
        hm-rpc.2 2019-03-12 07:59:57.615 debug [KEEPALIVE] Check if connection is alive
        hm-rpc.2 2019-03-12 06:58:27.604 debug start ping interval
        hm-rpc.2 2019-03-12 06:58:27.603 debug clear connecting interval
        hm-rpc.2 2019-03-12 06:58:27.601 info Connected
        hm-rpc.2 2019-03-12 06:58:27.555 debug start connecting interval
        hm-rpc.2 2019-03-12 06:58:27.539 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.1:2010","hm-rpc.2"]
        hm-rpc.2 2019-03-12 06:58:27.538 debug Connect...
        hm-rpc.2 2019-03-12 06:58:27.534 info xmlrpc client is trying to connect to 192.168.2.62:2010/ with ["http://192.168.2.1:2010","hm-rpc.2"]
        hm-rpc.2 2019-03-12 06:58:27.534 info xmlrpc server is trying to listen on 127.0.0.1:2010
        hm-rpc.2 2019-03-12 06:58:27.229 info starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
        hm-rpc.2 2019-03-12 06:58:27.175 warn setObject updated (type=state) property common.role missing!
        hm-rpc.2 2019-03-12 06:58:27.174 warn setObject updated (type=state) property native missing!
        hm-rpc.2 2019-03-12 06:58:27.044 debug statesDB connected
        hm-rpc.2 2019-03-12 06:58:26.787 debug objectDB connected
        host.raspberrypi 2019-03-12 06:58:25.393 info instance system.adapter.hm-rpc.2 started with pid 19770
        host.raspberrypi 2019-03-12 06:58:22.916 info instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
        hm-rpc.2 2019-03-12 06:58:22.863 info terminating
        hm-rpc.2 2019-03-12 06:58:22.831 info Disconnected
        hm-rpc.2 2019-03-12 06:58:22.802 info xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.1:2010",""]
        host.raspberrypi 2019-03-12 06:58:22.794 info stopInstance timeout "1000 system.adapter.hm-rpc.2 killing pid 19654
        hm-rpc.2 2019-03-12 06:58:21.853 debug system.adapter.admin.0: logging true
        hm-rpc.2 2019-03-12 06:58:21.807 debug [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.raspberrypi","callback":{"message":null,"id":6,"ack":false,"time":1552373901789},"_id":72583157}
        host.raspberrypi 2019-03-12 06:58:21.785 info stopInstance system.adapter.hm-rpc.2
        host.raspberrypi 2019-03-12 06:58:21.763 info object change system.adapter.hm-rpc.2
        hm-rpc.2 2019-03-12 06:57:22.542 debug system.adapter.admin.0: logging false
        hm-rpc.2 2019-03-12 06:57:09.057 debug PING ok
        hm-rpc.2 2019-03-12 06:57:09.023 debug Send PING...
        hm-rpc.2 2019-03-12 06:57:09.020 debug [KEEPALIVE] Check if connection is alive
        • A AHg
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          @AHg Wenn du die Devices vor dem Neustart gelöscht hast, legt er sie doch dann beim erneuten Start an oder?
          Dann sollte auf debug eigentlich etwas in die Richtung geloggt werden:
          19-03-12 10:37:46.162 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.1 created
          2019-03-12 10:37:46.171 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0 created
          2019-03-12 10:37:46.183 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840 created
          2019-03-12 10:37:46.186 - debug: hm-rpc.0 getValueParamsets HM-Sec-SCo.MAINTENANCE.3
          2019-03-12 10:37:46.187 - debug: hm-rpc.0 paramset cache hit
          2019-03-12 10:37:46.214 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.AES_KEY extended
          2019-03-12 10:37:46.216 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.CONFIG_PENDING extended
          2019-03-12 10:37:46.219 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.DEVICE_IN_BOOTLOADER extended
          2019-03-12 10:37:46.221 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.LOWBAT extended
          2019-03-12 10:37:46.223 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.RSSI_DEVICE extended
          2019-03-12 10:37:46.255 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.RSSI_PEER extended
          2019-03-12 10:37:46.258 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.STICKY_UNREACH extended
          2019-03-12 10:37:46.260 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.UNREACH extended
          2019-03-12 10:37:46.261 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.0.UPDATE_PENDING extended
          2019-03-12 10:37:46.263 - debug: hm-rpc.0 getValueParamsets HM-Sec-SCo.SHUTTER_CONTACT.3
          2019-03-12 10:37:46.264 - debug: hm-rpc.0 paramset cache hit
          2019-03-12 10:37:46.275 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.1.ERROR extended
          2019-03-12 10:37:46.279 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.1.INSTALL_TEST extended
          2019-03-12 10:37:46.289 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.1.LOWBAT extended
          2019-03-12 10:37:46.291 - debug: hm-rpc.0 object hm-rpc.0.OEQ1197840.1.STATE extended
            AHg
            @foxriver76 leider legt er sie jetzt nicht mehr an
              foxriver76F Offline
              foxriver76
              Auch sollte bei HMIP relativ am Anfang eine Meldung new Devices geloggt werden. Welche Adapterversionen nutzt du eigentlich? Hast du in der HMIP Instanz auch nicht-wired Geräte, die korrekt übertragen werden? Bzw. besitzt du auch nicht wired Geräte und diese werden auch nicht übertragen?
                AHg
                schrieb am zuletzt editiert von AHg
                @foxriver76 nach dem Anhalten und erneuten Starten von hm-rega sind wieder alle HMIPW-Module da.
                Ich nutze die Version 1.9.8. Ich nutze nur wired Geräte in der HMIP-Instanz.
                Log:
                hm-rpc.2 2019-03-12 12:45:31.793 debug start ping interval
                hm-rpc.2 2019-03-12 12:45:31.792 debug clear connecting interval
                hm-rpc.2 2019-03-12 12:45:31.770 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                hm-rpc.2 2019-03-12 12:45:01.767 debug start connecting interval
                hm-rpc.2 2019-03-12 12:45:01.767 debug clear ping interval
                hm-rpc.2 2019-03-12 12:45:01.766 debug Connect...
                hm-rpc.2 2019-03-12 12:45:01.766 debug [KEEPALIVE] Connection timed out, initializing new connection
                hm-rpc.2 2019-03-12 12:45:01.765 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.0 2019-03-12 12:43:50.935 info new CUxD devices/channels after filter: 0
                hm-rpc.0 2019-03-12 12:43:50.917 info xmlrpc -> listDevices 0
                hm-rpc.2 2019-03-12 12:43:31.786 debug PING ok
                hm-rpc.2 2019-03-12 12:43:31.763 debug Send PING...
                hm-rpc.2 2019-03-12 12:43:31.762 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.2 2019-03-12 12:43:03.276 debug system.adapter.admin.0: logging true
                hm-rpc.2 2019-03-12 11:42:01.757 debug start ping interval
                hm-rpc.2 2019-03-12 11:42:01.756 debug clear connecting interval
                hm-rpc.2 2019-03-12 11:42:01.733 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                hm-rpc.2 2019-03-12 11:41:31.732 debug start connecting interval
                hm-rpc.2 2019-03-12 11:41:31.732 debug clear ping interval
                hm-rpc.2 2019-03-12 11:41:31.732 debug Connect...
                hm-rpc.2 2019-03-12 11:41:31.731 debug [KEEPALIVE] Connection timed out, initializing new connection
                hm-rpc.2 2019-03-12 11:41:31.730 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.0 2019-03-12 11:40:20.846 info new CUxD devices/channels after filter: 0
                hm-rpc.0 2019-03-12 11:40:20.821 info xmlrpc -> listDevices 0
                hm-rpc.2 2019-03-12 11:40:01.748 debug PING ok
                hm-rpc.2 2019-03-12 11:40:01.726 debug Send PING...
                hm-rpc.2 2019-03-12 11:40:01.725 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.2 2019-03-12 11:38:31.724 debug start ping interval
                hm-rpc.2 2019-03-12 11:38:31.723 debug clear connecting interval
                hm-rpc.2 2019-03-12 11:38:31.700 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                hm-rpc.2 2019-03-12 11:38:02.705 debug system.adapter.admin.0: logging false
                hm-rpc.2 2019-03-12 11:38:01.699 debug start connecting interval
                hm-rpc.2 2019-03-12 11:38:01.698 debug clear ping interval
                hm-rpc.2 2019-03-12 11:38:01.698 debug Connect...
                hm-rpc.2 2019-03-12 11:38:01.697 debug [KEEPALIVE] Connection timed out, initializing new connection
                hm-rpc.2 2019-03-12 11:38:01.696 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.2 2019-03-12 11:37:17.835 debug system.adapter.admin.0: logging true
                hm-rpc.2 2019-03-12 11:37:06.525 debug system.adapter.admin.0: logging false
                hm-rpc.0 2019-03-12 11:36:50.748 info new CUxD devices/channels after filter: 0
                hm-rpc.0 2019-03-12 11:36:50.725 info xmlrpc -> listDevices 0
                hm-rpc.2 2019-03-12 11:36:31.722 debug PING ok
                hm-rpc.2 2019-03-12 11:36:31.690 debug Send PING...
                hm-rpc.2 2019-03-12 11:36:31.688 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.2 2019-03-12 11:35:27.251 debug system.adapter.admin.0: logging true
                hm-rega.0 2019-03-12 11:35:02.320 info got state values
                hm-rega.0 2019-03-12 11:35:01.800 info request state values
                hm-rega.0 2019-03-12 11:35:01.798 info deleted 0 variables
                hm-rega.0 2019-03-12 11:35:01.798 info added/updated 19 variables
                hm-rega.0 2019-03-12 11:35:01.740 info got 19 variables
                hm-rpc.2 2019-03-12 11:35:01.686 debug start ping interval
                hm-rpc.2 2019-03-12 11:35:01.685 debug clear connecting interval
                hm-rega.0 2019-03-12 11:35:01.632 info deleted 2 programs
                hm-rpc.2 2019-03-12 11:35:01.683 info Connected
                hm-rega.0 2019-03-12 11:35:01.630 info added/updated 8 programs
                hm-rpc.2 2019-03-12 11:35:01.621 debug start connecting interval
                hm-rpc.2 2019-03-12 11:35:01.600 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                hm-rpc.2 2019-03-12 11:35:01.598 debug Connect...
                hm-rpc.2 2019-03-12 11:35:01.594 info xmlrpc client is trying to connect to 192.168.2.62:2010/ with ["http://192.168.2.95:2010","hm-rpc.2"]
                hm-rpc.2 2019-03-12 11:35:01.593 info xmlrpc server is trying to listen on 127.0.0.1:2010
                hm-rega.0 2019-03-12 11:35:01.590 info got 9 programs
                hm-rega.0 2019-03-12 11:35:01.540 info renamed hm-rpc.2.001F58A9A71489 to "HmIP-RCV-50 001F58A9A71489"
                hm-rega.0 2019-03-12 11:35:01.520 info renamed hm-rpc.2.001F58A9A71489.0 to "HmIP-RCV-50 001F58A9A71489:0"
                hm-rega.0 2019-03-12 11:35:01.514 info renamed hm-rpc.2.001F58A9A71489.1 to "HmIP-RCV-50 001F58A9A71489:1"
                hm-rega.0 2019-03-12 11:35:01.504 info renamed hm-rpc.2.001F58A9A71489.2 to "HmIP-RCV-50 001F58A9A71489:2"
                hm-rega.0 2019-03-12 11:35:01.476 info renamed hm-rpc.2.001F58A9A71489.3 to "HmIP-RCV-50 001F58A9A71489:3"
                hm-rega.0 2019-03-12 11:35:01.465 info renamed hm-rpc.2.001F58A9A71489.4 to "HmIP-RCV-50 001F58A9A71489:4"
                hm-rega.0 2019-03-12 11:35:01.458 info renamed hm-rpc.2.001F58A9A71489.5 to "HmIP-RCV-50 001F58A9A71489:5"
                hm-rega.0 2019-03-12 11:35:01.348 info renamed hm-rpc.2.001F58A9A71489.6 to "HmIP-RCV-50 001F58A9A71489:6"
                hm-rega.0 2019-03-12 11:35:01.339 info renamed hm-rpc.2.001F58A9A71489.7 to "HmIP-RCV-50 001F58A9A71489:7"
                hm-rega.0 2019-03-12 11:35:01.331 info renamed hm-rpc.2.001F58A9A71489.8 to "HmIP-RCV-50 001F58A9A71489:8"
                hm-rega.0 2019-03-12 11:35:01.323 info renamed hm-rpc.2.001F58A9A71489.9 to "HmIP-RCV-50 001F58A9A71489:9"
                hm-rega.0 2019-03-12 11:35:01.315 info renamed hm-rpc.2.001F58A9A71489.10 to "HmIP-RCV-50 001F58A9A71489:10"
                hm-rega.0 2019-03-12 11:35:01.308 info renamed hm-rpc.2.001F58A9A71489.11 to "HmIP-RCV-50 001F58A9A71489:11"
                hm-rega.0 2019-03-12 11:35:01.299 info renamed hm-rpc.2.001F58A9A71489.12 to "HmIP-RCV-50 001F58A9A71489:12"
                hm-rpc.2 2019-03-12 11:35:01.281 info starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
                hm-rega.0 2019-03-12 11:35:01.276 info renamed hm-rpc.2.001F58A9A71489.13 to "HmIP-RCV-50 001F58A9A71489:13"
                hm-rega.0 2019-03-12 11:35:01.269 info renamed hm-rpc.2.001F58A9A71489.14 to "HmIP-RCV-50 001F58A9A71489:14"
                hm-rega.0 2019-03-12 11:35:01.262 info renamed hm-rpc.2.001F58A9A71489.15 to "HmIP-RCV-50 001F58A9A71489:15"
                hm-rega.0 2019-03-12 11:35:01.254 info renamed hm-rpc.2.001F58A9A71489.16 to "HmIP-RCV-50 001F58A9A71489:16"
                hm-rega.0 2019-03-12 11:35:01.246 info renamed hm-rpc.2.001F58A9A71489.17 to "HmIP-RCV-50 001F58A9A71489:17"
                hm-rega.0 2019-03-12 11:35:01.239 info renamed hm-rpc.2.001F58A9A71489.18 to "HmIP-RCV-50 001F58A9A71489:18"
                hm-rega.0 2019-03-12 11:35:01.231 info renamed hm-rpc.2.001F58A9A71489.19 to "HmIP-RCV-50 001F58A9A71489:19"
                hm-rega.0 2019-03-12 11:35:01.224 info renamed hm-rpc.2.001F58A9A71489.20 to "HmIP-RCV-50 001F58A9A71489:20"
                hm-rega.0 2019-03-12 11:35:01.212 info renamed hm-rpc.2.001F58A9A71489.21 to "HmIP-RCV-50 001F58A9A71489:21"
                hm-rega.0 2019-03-12 11:35:01.203 info renamed hm-rpc.2.001F58A9A71489.22 to "HmIP-RCV-50 001F58A9A71489:22"
                hm-rega.0 2019-03-12 11:35:01.188 info renamed hm-rpc.2.001F58A9A71489.23 to "HmIP-RCV-50 001F58A9A71489:23"
                hm-rega.0 2019-03-12 11:35:01.178 info renamed hm-rpc.2.001F58A9A71489.24 to "HmIP-RCV-50 001F58A9A71489:24"
                hm-rega.0 2019-03-12 11:35:01.168 info renamed hm-rpc.2.001F58A9A71489.25 to "HmIP-RCV-50 001F58A9A71489:25"
                hm-rega.0 2019-03-12 11:35:01.160 info renamed hm-rpc.2.001F58A9A71489.26 to "HmIP-RCV-50 001F58A9A71489:26"
                hm-rega.0 2019-03-12 11:35:01.152 info renamed hm-rpc.2.001F58A9A71489.27 to "HmIP-RCV-50 001F58A9A71489:27"
                hm-rega.0 2019-03-12 11:35:01.143 info renamed hm-rpc.2.001F58A9A71489.28 to "HmIP-RCV-50 001F58A9A71489:28"
                hm-rpc.2 2019-03-12 11:35:01.140 debug statesDB connected
                hm-rega.0 2019-03-12 11:35:01.136 info renamed hm-rpc.2.001F58A9A71489.29 to "HmIP-RCV-50 001F58A9A71489:29"
                hm-rega.0 2019-03-12 11:35:01.128 info renamed hm-rpc.2.001F58A9A71489.30 to "HmIP-RCV-50 001F58A9A71489:30"
                hm-rega.0 2019-03-12 11:35:01.120 info renamed hm-rpc.2.001F58A9A71489.31 to "HmIP-RCV-50 001F58A9A71489:31"
                hm-rega.0 2019-03-12 11:35:01.111 info renamed hm-rpc.2.001F58A9A71489.32 to "HmIP-RCV-50 001F58A9A71489:32"
                hm-rega.0 2019-03-12 11:35:01.103 info renamed hm-rpc.2.001F58A9A71489.33 to "HmIP-RCV-50 001F58A9A71489:33"
                hm-rega.0 2019-03-12 11:35:01.096 info renamed hm-rpc.2.001F58A9A71489.34 to "HmIP-RCV-50 001F58A9A71489:34"
                hm-rega.0 2019-03-12 11:35:01.088 info renamed hm-rpc.2.001F58A9A71489.35 to "HmIP-RCV-50 001F58A9A71489:35"
                hm-rega.0 2019-03-12 11:35:01.076 info renamed hm-rpc.2.001F58A9A71489.36 to "HmIP-RCV-50 001F58A9A71489:36"
                hm-rpc.2 2019-03-12 11:35:01.000 debug objectDB connected
                hm-rega.0 2019-03-12 11:35:01.067 info renamed hm-rpc.2.001F58A9A71489.37 to "HmIP-RCV-50 001F58A9A71489:37"
                hm-rega.0 2019-03-12 11:35:01.060 info renamed hm-rpc.2.001F58A9A71489.38 to "HmIP-RCV-50 001F58A9A71489:38"
                hm-rega.0 2019-03-12 11:35:01.053 info renamed hm-rpc.2.001F58A9A71489.39 to "HmIP-RCV-50 001F58A9A71489:39"
                hm-rega.0 2019-03-12 11:35:01.045 info renamed hm-rpc.2.001F58A9A71489.40 to "HmIP-RCV-50 001F58A9A71489:40"
                hm-rega.0 2019-03-12 11:35:01.036 info renamed hm-rpc.2.001F58A9A71489.41 to "HmIP-RCV-50 001F58A9A71489:41"
                hm-rega.0 2019-03-12 11:35:01.029 info renamed hm-rpc.2.001F58A9A71489.42 to "HmIP-RCV-50 001F58A9A71489:42"
                hm-rega.0 2019-03-12 11:35:01.019 info renamed hm-rpc.2.001F58A9A71489.43 to "HmIP-RCV-50 001F58A9A71489:43"
                hm-rega.0 2019-03-12 11:35:01.008 info renamed hm-rpc.2.001F58A9A71489.44 to "HmIP-RCV-50 001F58A9A71489:44"
                hm-rega.0 2019-03-12 11:35:01.000 info renamed hm-rpc.2.001F58A9A71489.45 to "HmIP-RCV-50 001F58A9A71489:45"
                hm-rega.0 2019-03-12 11:35:00.992 info renamed hm-rpc.2.001F58A9A71489.46 to "HmIP-RCV-50 001F58A9A71489:46"
                hm-rega.0 2019-03-12 11:35:00.984 info renamed hm-rpc.2.001F58A9A71489.47 to "HmIP-RCV-50 001F58A9A71489:47"
                hm-rega.0 2019-03-12 11:35:00.977 info renamed hm-rpc.2.001F58A9A71489.48 to "HmIP-RCV-50 001F58A9A71489:48"
                hm-rega.0 2019-03-12 11:35:00.969 info renamed hm-rpc.2.001F58A9A71489.49 to "HmIP-RCV-50 001F58A9A71489:49"
                hm-rega.0 2019-03-12 11:35:00.962 info renamed hm-rpc.2.001F58A9A71489.50 to "HmIP-RCV-50 001F58A9A71489:50"
                hm-rega.0 2019-03-12 11:35:00.954 info renamed hm-rpc.2.001718A9A77F9D to "HmIPW-Eingänge 1-32:7F9D"
                hm-rega.0 2019-03-12 11:35:00.945 info renamed hm-rpc.2.001718A9A77F9D.0 to "HmIPW-Eingänge 1-32:7F9D:0"
                hm-rega.0 2019-03-12 11:35:00.937 info renamed hm-rpc.2.001718A9A77F9D.1 to "HmIPW-DRI32 001718A9A77F9D:1"
                hm-rega.0 2019-03-12 11:35:00.928 info renamed hm-rpc.2.001718A9A77F9D.2 to "HmIPW-DRI32 001718A9A77F9D:2"
                hm-rega.0 2019-03-12 11:35:00.921 info renamed hm-rpc.2.001718A9A77F9D.3 to "HmIPW-DRI32 001718A9A77F9D:3"
                hm-rega.0 2019-03-12 11:35:00.907 info renamed hm-rpc.2.001718A9A77F9D.4 to "HmIPW-DRI32 001718A9A77F9D:4"
                hm-rega.0 2019-03-12 11:35:00.896 info renamed hm-rpc.2.001718A9A77F9D.5 to "HmIPW-DRI32 001718A9A77F9D:5"
                hm-rega.0 2019-03-12 11:35:00.888 info renamed hm-rpc.2.001718A9A77F9D.6 to "HmIPW-DRI32 001718A9A77F9D:6"
                hm-rega.0 2019-03-12 11:35:00.873 info renamed hm-rpc.2.001718A9A77F9D.7 to "HmIPW-DRI32 001718A9A77F9D:7"
                hm-rega.0 2019-03-12 11:35:00.866 info renamed hm-rpc.2.001718A9A77F9D.8 to "HmIPW-DRI32 001718A9A77F9D:8"
                hm-rega.0 2019-03-12 11:35:00.857 info renamed hm-rpc.2.001718A9A77F9D.9 to "HmIPW-DRI32 001718A9A77F9D:9"
                hm-rega.0 2019-03-12 11:35:00.850 info renamed hm-rpc.2.001718A9A77F9D.10 to "HmIPW-DRI32 001718A9A77F9D:10"
                hm-rega.0 2019-03-12 11:35:00.826 info renamed hm-rpc.2.001718A9A77F9D.11 to "HmIPW-DRI32 001718A9A77F9D:11"
                hm-rega.0 2019-03-12 11:35:00.818 info renamed hm-rpc.2.001718A9A77F9D.12 to "HmIPW-DRI32 001718A9A77F9D:12"
                hm-rega.0 2019-03-12 11:35:00.810 info renamed hm-rpc.2.001718A9A77F9D.13 to "HmIPW-DRI32 001718A9A77F9D:13"
                hm-rega.0 2019-03-12 11:35:00.801 info renamed hm-rpc.2.001718A9A77F9D.14 to "HmIPW-DRI32 001718A9A77F9D:14"
                hm-rega.0 2019-03-12 11:35:00.793 info renamed hm-rpc.2.001718A9A77F9D.15 to "HmIPW-DRI32 001718A9A77F9D:15"
                hm-rega.0 2019-03-12 11:35:00.786 info renamed hm-rpc.2.001718A9A77F9D.16 to "HmIPW-DRI32 001718A9A77F9D:16"
                hm-rega.0 2019-03-12 11:35:00.779 info renamed hm-rpc.2.001718A9A77F9D.17 to "HmIPW-DRI32 001718A9A77F9D:17"
                hm-rega.0 2019-03-12 11:35:00.771 info renamed hm-rpc.2.001718A9A77F9D.18 to "HmIPW-DRI32 001718A9A77F9D:18"
                hm-rega.0 2019-03-12 11:35:00.763 info renamed hm-rpc.2.001718A9A77F9D.19 to "HmIPW-DRI32 001718A9A77F9D:19"
                hm-rega.0 2019-03-12 11:35:00.756 info renamed hm-rpc.2.001718A9A77F9D.20 to "HmIPW-DRI32 001718A9A77F9D:20"
                hm-rega.0 2019-03-12 11:35:00.748 info renamed hm-rpc.2.001718A9A77F9D.21 to "HmIPW-DRI32 001718A9A77F9D:21"
                hm-rega.0 2019-03-12 11:35:00.740 info renamed hm-rpc.2.001718A9A77F9D.22 to "HmIPW-DRI32 001718A9A77F9D:22"
                hm-rega.0 2019-03-12 11:35:00.730 info renamed hm-rpc.2.001718A9A77F9D.23 to "HmIPW-DRI32 001718A9A77F9D:23"
                hm-rega.0 2019-03-12 11:35:00.711 info renamed hm-rpc.2.001718A9A77F9D.24 to "HmIPW-DRI32 001718A9A77F9D:24"
                hm-rega.0 2019-03-12 11:35:00.704 info renamed hm-rpc.2.001718A9A77F9D.25 to "HmIPW-DRI32 001718A9A77F9D:25"
                hm-rega.0 2019-03-12 11:35:00.697 info renamed hm-rpc.2.001718A9A77F9D.26 to "HmIPW-DRI32 001718A9A77F9D:26"
                hm-rega.0 2019-03-12 11:35:00.689 info renamed hm-rpc.2.001718A9A77F9D.27 to "HmIPW-DRI32 001718A9A77F9D:27"
                hm-rega.0 2019-03-12 11:35:00.677 info renamed hm-rpc.2.001718A9A77F9D.28 to "HmIPW-DRI32 001718A9A77F9D:28"
                hm-rega.0 2019-03-12 11:35:00.663 info renamed hm-rpc.2.001718A9A77F9D.29 to "HmIPW-DRI32 001718A9A77F9D:29"
                hm-rega.0 2019-03-12 11:35:00.655 info renamed hm-rpc.2.001718A9A77F9D.30 to "HmIPW-DRI32 001718A9A77F9D:30"
                hm-rega.0 2019-03-12 11:35:00.647 info renamed hm-rpc.2.001718A9A77F9D.31 to "HmIPW-DRI32 001718A9A77F9D:31"
                hm-rega.0 2019-03-12 11:35:00.639 info renamed hm-rpc.2.001718A9A77F9D.32 to "HmIPW-DRI32 001718A9A77F9D:32"
                hm-rega.0 2019-03-12 11:35:00.631 info renamed hm-rpc.2.001718A9A77F9D.33 to "HmIPW-DRI32 001718A9A77F9D:33"
                hm-rega.0 2019-03-12 11:35:00.622 info renamed hm-rpc.2.001658A99FD33B to "HmIPW-Rollladen 1-4:D33B"
                hm-rega.0 2019-03-12 11:35:00.605 info renamed hm-rpc.2.001658A99FD33B.0 to "HmIPW-Rollladen 1-4:D33B:0"
                hm-rega.0 2019-03-12 11:35:00.586 info renamed hm-rpc.2.001658A99FD33B.1 to "HmIPW-DRBL4 001658A99FD33B:1"
                hm-rega.0 2019-03-12 11:35:00.577 info renamed hm-rpc.2.001658A99FD33B.2 to "HmIPW-DRBL4 001658A99FD33B:2"
                hm-rega.0 2019-03-12 11:35:00.569 info renamed hm-rpc.2.001658A99FD33B.3 to "HmIPW-DRBL4 001658A99FD33B:3"
                hm-rega.0 2019-03-12 11:35:00.560 info renamed hm-rpc.2.001658A99FD33B.4 to "HmIPW-DRBL4 001658A99FD33B:4"
                hm-rega.0 2019-03-12 11:35:00.549 info renamed hm-rpc.2.001658A99FD33B.5 to "HmIPW-DRBL4 001658A99FD33B:5"
                hm-rega.0 2019-03-12 11:35:00.541 info renamed hm-rpc.2.001658A99FD33B.6 to "HmIPW-DRBL4 001658A99FD33B:6"
                hm-rega.0 2019-03-12 11:35:00.508 info renamed hm-rpc.2.001658A99FD33B.7 to "HmIPW-DRBL4 001658A99FD33B:7"
                hm-rega.0 2019-03-12 11:35:00.494 info renamed hm-rpc.2.001658A99FD33B.8 to "HmIPW-DRBL4 001658A99FD33B:8"
                hm-rega.0 2019-03-12 11:35:00.486 info renamed hm-rpc.2.001658A99FD33B.9 to "HmIPW-DRBL4 001658A99FD33B:9"
                hm-rega.0 2019-03-12 11:35:00.478 info renamed hm-rpc.2.001658A99FD33B.10 to "HmIPW-DRBL4 001658A99FD33B:10"
                hm-rega.0 2019-03-12 11:35:00.469 info renamed hm-rpc.2.001658A99FD33B.11 to "HmIPW-DRBL4 001658A99FD33B:11"
                hm-rega.0 2019-03-12 11:35:00.461 info renamed hm-rpc.2.001658A99FD33B.12 to "HmIPW-DRBL4 001658A99FD33B:12"
                hm-rega.0 2019-03-12 11:35:00.453 info renamed hm-rpc.2.001658A99FD33B.13 to "HmIPW-DRBL4 001658A99FD33B:13"
                hm-rega.0 2019-03-12 11:35:00.445 info renamed hm-rpc.2.001658A99FD33B.14 to "HmIPW-DRBL4 001658A99FD33B:14"
                hm-rega.0 2019-03-12 11:35:00.436 info renamed hm-rpc.2.001658A99FD33B.15 to "HmIPW-DRBL4 001658A99FD33B:15"
                hm-rega.0 2019-03-12 11:35:00.426 info renamed hm-rpc.2.001658A99FD33B.16 to "HmIPW-DRBL4 001658A99FD33B:16"
                hm-rega.0 2019-03-12 11:35:00.417 info renamed hm-rpc.2.001658A99FD33B.17 to "HmIPW-DRBL4 001658A99FD33B:17"
                hm-rega.0 2019-03-12 11:35:00.407 info renamed hm-rpc.2.001658A99FD432 to "HmIPW-Rollladen 13-16:D432"
                hm-rega.0 2019-03-12 11:35:00.398 info renamed hm-rpc.2.001658A99FD432.0 to "HmIPW-Rollladen 13-16:D432:0"
                hm-rega.0 2019-03-12 11:35:00.118 info renamed hm-rpc.2.001658A99FD432.1 to "HmIPW-DRBL4 001658A99FD432:1"
                hm-rega.0 2019-03-12 11:35:00.102 info renamed hm-rpc.2.001658A99FD432.2 to "HmIPW-DRBL4 001658A99FD432:2"
                hm-rega.0 2019-03-12 11:35:00.093 info renamed hm-rpc.2.001658A99FD432.3 to "HmIPW-DRBL4 001658A99FD432:3"
                hm-rega.0 2019-03-12 11:35:00.078 info renamed hm-rpc.2.001658A99FD432.4 to "HmIPW-DRBL4 001658A99FD432:4"
                hm-rega.0 2019-03-12 11:35:00.070 info renamed hm-rpc.2.001658A99FD432.5 to "HmIPW-DRBL4 001658A99FD432:5"
                hm-rega.0 2019-03-12 11:35:00.057 info renamed hm-rpc.2.001658A99FD432.6 to "HmIPW-DRBL4 001658A99FD432:6"
                hm-rega.0 2019-03-12 11:35:00.049 info renamed hm-rpc.2.001658A99FD432.7 to "HmIPW-DRBL4 001658A99FD432:7"
                hm-rega.0 2019-03-12 11:35:00.038 info renamed hm-rpc.2.001658A99FD432.8 to "HmIPW-DRBL4 001658A99FD432:8"
                hm-rega.0 2019-03-12 11:35:00.030 info renamed hm-rpc.2.001658A99FD432.9 to "HmIPW-DRBL4 001658A99FD432:9"
                hm-rega.0 2019-03-12 11:35:00.021 info renamed hm-rpc.2.001658A99FD432.10 to "HmIPW-DRBL4 001658A99FD432:10"
                hm-rega.0 2019-03-12 11:35:00.013 info renamed hm-rpc.2.001658A99FD432.11 to "HmIPW-DRBL4 001658A99FD432:11"
                hm-rega.0 2019-03-12 11:35:00.004 info renamed hm-rpc.2.001658A99FD432.12 to "HmIPW-DRBL4 001658A99FD432:12"
                hm-rega.0 2019-03-12 11:34:59.996 info renamed hm-rpc.2.001658A99FD432.13 to "HmIPW-DRBL4 001658A99FD432:13"
                hm-rega.0 2019-03-12 11:34:59.984 info renamed hm-rpc.2.001658A99FD432.14 to "HmIPW-DRBL4 001658A99FD432:14"
                hm-rega.0 2019-03-12 11:34:59.976 info renamed hm-rpc.2.001658A99FD432.15 to "HmIPW-DRBL4 001658A99FD432:15"
                hm-rega.0 2019-03-12 11:34:59.967 info renamed hm-rpc.2.001658A99FD432.16 to "HmIPW-DRBL4 001658A99FD432:16"
                hm-rega.0 2019-03-12 11:34:59.958 info renamed hm-rpc.2.001658A99FD432.17 to "HmIPW-DRBL4 001658A99FD432:17"
                hm-rega.0 2019-03-12 11:34:59.950 info renamed hm-rpc.2.001658A99FD422 to "HmIPW-Rollladen 17-20:D422"
                hm-rega.0 2019-03-12 11:34:59.942 info renamed hm-rpc.2.001658A99FD422.0 to "HmIPW-Rollladen 17-20:D422:0"
                hm-rega.0 2019-03-12 11:34:59.927 info renamed hm-rpc.2.001658A99FD422.1 to "HmIPW-DRBL4 001658A99FD422:1"
                hm-rega.0 2019-03-12 11:34:59.913 info renamed hm-rpc.2.001658A99FD422.2 to "HmIPW-DRBL4 001658A99FD422:2"
                hm-rega.0 2019-03-12 11:34:59.899 info renamed hm-rpc.2.001658A99FD422.3 to "HmIPW-DRBL4 001658A99FD422:3"
                hm-rega.0 2019-03-12 11:34:59.890 info renamed hm-rpc.2.001658A99FD422.4 to "HmIPW-DRBL4 001658A99FD422:4"
                hm-rega.0 2019-03-12 11:34:59.883 info renamed hm-rpc.2.001658A99FD422.5 to "HmIPW-DRBL4 001658A99FD422:5"
                hm-rega.0 2019-03-12 11:34:59.876 info renamed hm-rpc.2.001658A99FD422.6 to "HmIPW-DRBL4 001658A99FD422:6"
                hm-rega.0 2019-03-12 11:34:59.867 info renamed hm-rpc.2.001658A99FD422.7 to "HmIPW-DRBL4 001658A99FD422:7"
                hm-rega.0 2019-03-12 11:34:59.843 info renamed hm-rpc.2.001658A99FD422.8 to "HmIPW-DRBL4 001658A99FD422:8"
                hm-rega.0 2019-03-12 11:34:59.828 info renamed hm-rpc.2.001658A99FD422.9 to "HmIPW-DRBL4 001658A99FD422:9"
                hm-rega.0 2019-03-12 11:34:59.820 info renamed hm-rpc.2.001658A99FD422.10 to "HmIPW-DRBL4 001658A99FD422:10"
                hm-rega.0 2019-03-12 11:34:59.810 info renamed hm-rpc.2.001658A99FD422.11 to "HmIPW-DRBL4 001658A99FD422:11"
                hm-rega.0 2019-03-12 11:34:59.796 info renamed hm-rpc.2.001658A99FD422.12 to "HmIPW-DRBL4 001658A99FD422:12"
                hm-rega.0 2019-03-12 11:34:59.790 info renamed hm-rpc.2.001658A99FD422.13 to "HmIPW-DRBL4 001658A99FD422:13"
                hm-rega.0 2019-03-12 11:34:59.781 info renamed hm-rpc.2.001658A99FD422.14 to "HmIPW-DRBL4 001658A99FD422:14"
                hm-rega.0 2019-03-12 11:34:59.772 info renamed hm-rpc.2.001658A99FD422.15 to "HmIPW-DRBL4 001658A99FD422:15"
                hm-rega.0 2019-03-12 11:34:59.762 info renamed hm-rpc.2.001658A99FD422.16 to "HmIPW-DRBL4 001658A99FD422:16"
                hm-rega.0 2019-03-12 11:34:59.754 info renamed hm-rpc.2.001658A99FD422.17 to "HmIPW-DRBL4 001658A99FD422:17"
                hm-rega.0 2019-03-12 11:34:59.745 info renamed hm-rpc.2.001658A99FD461 to "HmIPW-Rollladen 5-8:D461"
                hm-rega.0 2019-03-12 11:34:59.737 info renamed hm-rpc.2.001658A99FD461.0 to "HmIPW-Rollladen 5-8:D461:0"
                hm-rega.0 2019-03-12 11:34:59.728 info renamed hm-rpc.2.001658A99FD461.1 to "HmIPW-DRBL4 001658A99FD461:1"
                hm-rega.0 2019-03-12 11:34:59.720 info renamed hm-rpc.2.001658A99FD461.2 to "HmIPW-DRBL4 001658A99FD461:2"
                hm-rega.0 2019-03-12 11:34:59.709 info renamed hm-rpc.2.001658A99FD461.3 to "HmIPW-DRBL4 001658A99FD461:3"
                hm-rega.0 2019-03-12 11:34:59.700 info renamed hm-rpc.2.001658A99FD461.4 to "HmIPW-DRBL4 001658A99FD461:4"
                hm-rega.0 2019-03-12 11:34:59.690 info renamed hm-rpc.2.001658A99FD461.5 to "HmIPW-DRBL4 001658A99FD461:5"
                hm-rega.0 2019-03-12 11:34:59.682 info renamed hm-rpc.2.001658A99FD461.6 to "HmIPW-DRBL4 001658A99FD461:6"
                hm-rega.0 2019-03-12 11:34:59.674 info renamed hm-rpc.2.001658A99FD461.7 to "HmIPW-DRBL4 001658A99FD461:7"
                hm-rega.0 2019-03-12 11:34:59.667 info renamed hm-rpc.2.001658A99FD461.8 to "HmIPW-DRBL4 001658A99FD461:8"
                hm-rega.0 2019-03-12 11:34:59.659 info renamed hm-rpc.2.001658A99FD461.9 to "HmIPW-DRBL4 001658A99FD461:9"
                hm-rega.0 2019-03-12 11:34:59.652 info renamed hm-rpc.2.001658A99FD461.10 to "HmIPW-DRBL4 001658A99FD461:10"
                hm-rega.0 2019-03-12 11:34:59.643 info renamed hm-rpc.2.001658A99FD461.11 to "HmIPW-DRBL4 001658A99FD461:11"
                hm-rega.0 2019-03-12 11:34:59.635 info renamed hm-rpc.2.001658A99FD461.12 to "HmIPW-DRBL4 001658A99FD461:12"
                hm-rega.0 2019-03-12 11:34:59.627 info renamed hm-rpc.2.001658A99FD461.13 to "HmIPW-DRBL4 001658A99FD461:13"
                hm-rega.0 2019-03-12 11:34:59.620 info renamed hm-rpc.2.001658A99FD461.14 to "HmIPW-DRBL4 001658A99FD461:14"
                hm-rega.0 2019-03-12 11:34:59.612 info renamed hm-rpc.2.001658A99FD461.15 to "HmIPW-DRBL4 001658A99FD461:15"
                hm-rega.0 2019-03-12 11:34:59.604 info renamed hm-rpc.2.001658A99FD461.16 to "HmIPW-DRBL4 001658A99FD461:16"
                hm-rega.0 2019-03-12 11:34:59.593 info renamed hm-rpc.2.001658A99FD461.17 to "HmIPW-DRBL4 001658A99FD461:17"
                hm-rega.0 2019-03-12 11:34:59.584 info renamed hm-rpc.2.001658A99FD436 to "HmIPW-Rollladen 9-12:D436"
                hm-rega.0 2019-03-12 11:34:59.564 info renamed hm-rpc.2.001658A99FD436.0 to "HmIPW-Rollladen 9-12:D436:0"
                hm-rega.0 2019-03-12 11:34:59.557 info renamed hm-rpc.2.001658A99FD436.1 to "HmIPW-DRBL4 001658A99FD436:1"
                hm-rega.0 2019-03-12 11:34:59.549 info renamed hm-rpc.2.001658A99FD436.2 to "HmIPW-DRBL4 001658A99FD436:2"
                hm-rega.0 2019-03-12 11:34:59.542 info renamed hm-rpc.2.001658A99FD436.3 to "HmIPW-DRBL4 001658A99FD436:3"
                hm-rega.0 2019-03-12 11:34:59.534 info renamed hm-rpc.2.001658A99FD436.4 to "HmIPW-DRBL4 001658A99FD436:4"
                hm-rega.0 2019-03-12 11:34:59.525 info renamed hm-rpc.2.001658A99FD436.5 to "HmIPW-DRBL4 001658A99FD436:5"
                hm-rega.0 2019-03-12 11:34:59.516 info renamed hm-rpc.2.001658A99FD436.6 to "HmIPW-DRBL4 001658A99FD436:6"
                hm-rega.0 2019-03-12 11:34:59.508 info renamed hm-rpc.2.001658A99FD436.7 to "HmIPW-DRBL4 001658A99FD436:7"
                hm-rega.0 2019-03-12 11:34:59.487 info renamed hm-rpc.2.001658A99FD436.8 to "HmIPW-DRBL4 001658A99FD436:8"
                hm-rega.0 2019-03-12 11:34:59.475 info renamed hm-rpc.2.001658A99FD436.9 to "HmIPW-DRBL4 001658A99FD436:9"
                hm-rega.0 2019-03-12 11:34:59.466 info renamed hm-rpc.2.001658A99FD436.10 to "HmIPW-DRBL4 001658A99FD436:10"
                hm-rega.0 2019-03-12 11:34:59.457 info renamed hm-rpc.2.001658A99FD436.11 to "HmIPW-DRBL4 001658A99FD436:11"
                hm-rega.0 2019-03-12 11:34:59.444 info renamed hm-rpc.2.001658A99FD436.12 to "HmIPW-DRBL4 001658A99FD436:12"
                hm-rega.0 2019-03-12 11:34:59.435 info renamed hm-rpc.2.001658A99FD436.13 to "HmIPW-DRBL4 001658A99FD436:13"
                hm-rega.0 2019-03-12 11:34:59.427 info renamed hm-rpc.2.001658A99FD436.14 to "HmIPW-DRBL4 001658A99FD436:14"
                hm-rega.0 2019-03-12 11:34:59.419 info renamed hm-rpc.2.001658A99FD436.15 to "HmIPW-DRBL4 001658A99FD436:15"
                hm-rega.0 2019-03-12 11:34:59.410 info renamed hm-rpc.2.001658A99FD436.16 to "HmIPW-DRBL4 001658A99FD436:16"
                hm-rega.0 2019-03-12 11:34:59.392 info renamed hm-rpc.2.001658A99FD436.17 to "HmIPW-DRBL4 001658A99FD436:17"
                host.raspberrypi 2019-03-12 11:34:59.291 info instance system.adapter.hm-rpc.2 started with pid 1706
                host.raspberrypi 2019-03-12 11:34:59.260 info object change system.adapter.hm-rpc.2
                hm-rega.0 2019-03-12 11:34:58.685 info added/updated rooms to enum.rooms
                hm-rega.0 2019-03-12 11:34:58.633 info added/updated functions to enum.functions
                hm-rega.0 2019-03-12 11:34:58.574 info added/updated 0 favorites to enum.favorites
                hm-rega.0 2019-03-12 11:34:58.529 info time difference local-ccu 1s
                hm-rega.0 2019-03-12 11:34:58.418 info ReGaHSS 192.168.2.62 up
                hm-rega.0 2019-03-12 11:34:58.311 info subscribe .BidCoS-RF.50.PRESS_SHORT
                hm-rega.0 2019-03-12 11:34:58.280 info starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.14.1
                host.raspberrypi 2019-03-12 11:34:55.200 info instance system.adapter.hm-rega.0 started with pid 1654
                host.raspberrypi 2019-03-12 11:34:55.119 info object change system.adapter.hm-rega.0
                host.raspberrypi 2019-03-12 11:34:48.980 info instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
                hm-rpc.2 2019-03-12 11:34:48.944 info terminating
                hm-rpc.2 2019-03-12 11:34:48.926 info Disconnected
                hm-rpc.2 2019-03-12 11:34:48.903 info xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010",""]
                host.raspberrypi 2019-03-12 11:34:48.896 info stopInstance timeout "1000 system.adapter.hm-rpc.2 killing pid 31903
                host.raspberrypi 2019-03-12 11:34:47.892 info stopInstance system.adapter.hm-rpc.2
                host.raspberrypi 2019-03-12 11:34:47.892 info "system.adapter.hm-rpc.2" disabled
                hm-rpc.2 2019-03-12 11:34:47.898 debug [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.raspberrypi","callback":{"message":null,"id":14,"ack":false,"time":1552390487893},"_id":72583309}
                host.raspberrypi 2019-03-12 11:34:47.890 info object change system.adapter.hm-rpc.2
                host.raspberrypi 2019-03-12 11:34:46.244 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                host.raspberrypi 2019-03-12 11:34:46.136 info stopInstance system.adapter.hm-rega.0 killing pid 1065
                host.raspberrypi 2019-03-12 11:34:46.135 info stopInstance system.adapter.hm-rega.0
                host.raspberrypi 2019-03-12 11:34:46.128 info "system.adapter.hm-rega.0" disabled
                host.raspberrypi 2019-03-12 11:34:46.111 info object change system.adapter.hm-rega.0
                hm-rpc.2 2019-03-12 11:34:26.516 debug start connecting interval
                hm-rpc.2 2019-03-12 11:34:26.515 debug clear ping interval
                hm-rpc.2 2019-03-12 11:34:26.514 debug Connect...
                hm-rpc.2 2019-03-12 11:34:26.513 debug [KEEPALIVE] Connection timed out, initializing new connection
                hm-rpc.2 2019-03-12 11:34:26.512 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.0 2019-03-12 11:33:20.682 info new CUxD devices/channels after filter: 0
                hm-rpc.0 2019-03-12 11:33:20.658 info xmlrpc -> listDevices 0
                hm-rpc.2 2019-03-12 11:32:56.512 debug PING ok
                hm-rpc.2 2019-03-12 11:32:56.496 debug Send PING...
                hm-rpc.2 2019-03-12 11:32:56.495 debug [KEEPALIVE] Check if connection is alive
                hm-rpc.2 2019-03-12 11:31:26.480 debug start ping interval
                hm-rpc.2 2019-03-12 11:31:26.476 debug clear connecting interval
                  AHg
                  @foxriver76 nun nochmal die Geräte gelöscht und neu gestartet
                  hm-rpc.2 2019-03-12 12:52:21.842 debug start ping interval
                  hm-rpc.2 2019-03-12 12:52:21.841 debug clear connecting interval
                  hm-rpc.2 2019-03-12 12:52:21.820 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                  hm-rpc.2 2019-03-12 12:51:51.816 debug start connecting interval
                  hm-rpc.2 2019-03-12 12:51:51.816 debug clear ping interval
                  hm-rpc.2 2019-03-12 12:51:51.816 debug Connect...
                  hm-rpc.2 2019-03-12 12:51:51.816 debug [KEEPALIVE] Connection timed out, initializing new connection
                  hm-rpc.2 2019-03-12 12:51:51.814 debug [KEEPALIVE] Check if connection is alive
                  hm-rpc.0 2019-03-12 12:50:51.123 info new CUxD devices/channels after filter: 0
                  hm-rpc.0 2019-03-12 12:50:51.100 info xmlrpc -> listDevices 0
                  hm-rpc.2 2019-03-12 12:50:21.834 debug PING ok
                  hm-rpc.2 2019-03-12 12:50:21.811 debug Send PING...
                  hm-rpc.2 2019-03-12 12:50:21.810 debug [KEEPALIVE] Check if connection is alive
                  hm-rpc.2 2019-03-12 12:49:43.997 debug system.adapter.admin.0: logging true
                  hm-rpc.2 2019-03-12 11:49:38.959 debug system.adapter.admin.0: logging false
                  hm-rega.0 2019-03-12 11:48:59.664 info got state values
                  hm-rega.0 2019-03-12 11:48:59.168 info request state values
                  hm-rega.0 2019-03-12 11:48:59.166 info deleted 0 variables
                  hm-rega.0 2019-03-12 11:48:59.166 info added/updated 19 variables
                  hm-rega.0 2019-03-12 11:48:59.105 info got 19 variables
                  hm-rega.0 2019-03-12 11:48:59.020 info deleted 0 programs
                  hm-rega.0 2019-03-12 11:48:59.018 info added/updated 8 programs
                  hm-rega.0 2019-03-12 11:48:58.988 info got 8 programs
                  hm-rega.0 2019-03-12 11:48:58.967 info renamed hm-rpc.2.001F58A9A71489 to "HmIP-RCV-50 001F58A9A71489"
                  hm-rega.0 2019-03-12 11:48:58.960 info renamed hm-rpc.2.001F58A9A71489.0 to "HmIP-RCV-50 001F58A9A71489:0"
                  hm-rega.0 2019-03-12 11:48:58.953 info renamed hm-rpc.2.001F58A9A71489.1 to "HmIP-RCV-50 001F58A9A71489:1"
                  hm-rega.0 2019-03-12 11:48:58.945 info renamed hm-rpc.2.001F58A9A71489.2 to "HmIP-RCV-50 001F58A9A71489:2"
                  hm-rega.0 2019-03-12 11:48:58.938 info renamed hm-rpc.2.001F58A9A71489.3 to "HmIP-RCV-50 001F58A9A71489:3"
                  hm-rega.0 2019-03-12 11:48:58.921 info renamed hm-rpc.2.001F58A9A71489.4 to "HmIP-RCV-50 001F58A9A71489:4"
                  hm-rega.0 2019-03-12 11:48:58.914 info renamed hm-rpc.2.001F58A9A71489.5 to "HmIP-RCV-50 001F58A9A71489:5"
                  hm-rega.0 2019-03-12 11:48:58.907 info renamed hm-rpc.2.001F58A9A71489.6 to "HmIP-RCV-50 001F58A9A71489:6"
                  hm-rega.0 2019-03-12 11:48:58.900 info renamed hm-rpc.2.001F58A9A71489.7 to "HmIP-RCV-50 001F58A9A71489:7"
                  hm-rega.0 2019-03-12 11:48:58.893 info renamed hm-rpc.2.001F58A9A71489.8 to "HmIP-RCV-50 001F58A9A71489:8"
                  hm-rega.0 2019-03-12 11:48:58.887 info renamed hm-rpc.2.001F58A9A71489.9 to "HmIP-RCV-50 001F58A9A71489:9"
                  hm-rega.0 2019-03-12 11:48:58.880 info renamed hm-rpc.2.001F58A9A71489.10 to "HmIP-RCV-50 001F58A9A71489:10"
                  hm-rega.0 2019-03-12 11:48:58.873 info renamed hm-rpc.2.001F58A9A71489.11 to "HmIP-RCV-50 001F58A9A71489:11"
                  hm-rega.0 2019-03-12 11:48:58.864 info renamed hm-rpc.2.001F58A9A71489.12 to "HmIP-RCV-50 001F58A9A71489:12"
                  hm-rega.0 2019-03-12 11:48:58.855 info renamed hm-rpc.2.001F58A9A71489.13 to "HmIP-RCV-50 001F58A9A71489:13"
                  hm-rega.0 2019-03-12 11:48:58.846 info renamed hm-rpc.2.001F58A9A71489.14 to "HmIP-RCV-50 001F58A9A71489:14"
                  hm-rega.0 2019-03-12 11:48:58.831 info renamed hm-rpc.2.001F58A9A71489.15 to "HmIP-RCV-50 001F58A9A71489:15"
                  hm-rega.0 2019-03-12 11:48:58.825 info renamed hm-rpc.2.001F58A9A71489.16 to "HmIP-RCV-50 001F58A9A71489:16"
                  hm-rega.0 2019-03-12 11:48:58.813 info renamed hm-rpc.2.001F58A9A71489.17 to "HmIP-RCV-50 001F58A9A71489:17"
                  hm-rega.0 2019-03-12 11:48:58.807 info renamed hm-rpc.2.001F58A9A71489.18 to "HmIP-RCV-50 001F58A9A71489:18"
                  hm-rega.0 2019-03-12 11:48:58.799 info renamed hm-rpc.2.001F58A9A71489.19 to "HmIP-RCV-50 001F58A9A71489:19"
                  hm-rega.0 2019-03-12 11:48:58.792 info renamed hm-rpc.2.001F58A9A71489.20 to "HmIP-RCV-50 001F58A9A71489:20"
                  hm-rega.0 2019-03-12 11:48:58.785 info renamed hm-rpc.2.001F58A9A71489.21 to "HmIP-RCV-50 001F58A9A71489:21"
                  hm-rega.0 2019-03-12 11:48:58.778 info renamed hm-rpc.2.001F58A9A71489.22 to "HmIP-RCV-50 001F58A9A71489:22"
                  hm-rega.0 2019-03-12 11:48:58.771 info renamed hm-rpc.2.001F58A9A71489.23 to "HmIP-RCV-50 001F58A9A71489:23"
                  hm-rega.0 2019-03-12 11:48:58.764 info renamed hm-rpc.2.001F58A9A71489.24 to "HmIP-RCV-50 001F58A9A71489:24"
                  hm-rega.0 2019-03-12 11:48:58.756 info renamed hm-rpc.2.001F58A9A71489.25 to "HmIP-RCV-50 001F58A9A71489:25"
                  hm-rega.0 2019-03-12 11:48:58.747 info renamed hm-rpc.2.001F58A9A71489.26 to "HmIP-RCV-50 001F58A9A71489:26"
                  hm-rega.0 2019-03-12 11:48:58.740 info renamed hm-rpc.2.001F58A9A71489.27 to "HmIP-RCV-50 001F58A9A71489:27"
                  hm-rega.0 2019-03-12 11:48:58.733 info renamed hm-rpc.2.001F58A9A71489.28 to "HmIP-RCV-50 001F58A9A71489:28"
                  hm-rega.0 2019-03-12 11:48:58.726 info renamed hm-rpc.2.001F58A9A71489.29 to "HmIP-RCV-50 001F58A9A71489:29"
                  hm-rega.0 2019-03-12 11:48:58.712 info renamed hm-rpc.2.001F58A9A71489.30 to "HmIP-RCV-50 001F58A9A71489:30"
                  hm-rega.0 2019-03-12 11:48:58.666 info renamed hm-rpc.2.001F58A9A71489.31 to "HmIP-RCV-50 001F58A9A71489:31"
                  hm-rega.0 2019-03-12 11:48:58.652 info renamed hm-rpc.2.001F58A9A71489.32 to "HmIP-RCV-50 001F58A9A71489:32"
                  hm-rega.0 2019-03-12 11:48:58.646 info renamed hm-rpc.2.001F58A9A71489.33 to "HmIP-RCV-50 001F58A9A71489:33"
                  hm-rega.0 2019-03-12 11:48:58.641 info renamed hm-rpc.2.001F58A9A71489.34 to "HmIP-RCV-50 001F58A9A71489:34"
                  hm-rega.0 2019-03-12 11:48:58.633 info renamed hm-rpc.2.001F58A9A71489.35 to "HmIP-RCV-50 001F58A9A71489:35"
                  hm-rega.0 2019-03-12 11:48:58.613 info renamed hm-rpc.2.001F58A9A71489.36 to "HmIP-RCV-50 001F58A9A71489:36"
                  hm-rega.0 2019-03-12 11:48:58.606 info renamed hm-rpc.2.001F58A9A71489.37 to "HmIP-RCV-50 001F58A9A71489:37"
                  hm-rega.0 2019-03-12 11:48:58.600 info renamed hm-rpc.2.001F58A9A71489.38 to "HmIP-RCV-50 001F58A9A71489:38"
                  hm-rega.0 2019-03-12 11:48:58.594 info renamed hm-rpc.2.001F58A9A71489.39 to "HmIP-RCV-50 001F58A9A71489:39"
                  hm-rega.0 2019-03-12 11:48:58.586 info renamed hm-rpc.2.001F58A9A71489.40 to "HmIP-RCV-50 001F58A9A71489:40"
                  hm-rega.0 2019-03-12 11:48:58.579 info renamed hm-rpc.2.001F58A9A71489.41 to "HmIP-RCV-50 001F58A9A71489:41"
                  hm-rega.0 2019-03-12 11:48:58.572 info renamed hm-rpc.2.001F58A9A71489.42 to "HmIP-RCV-50 001F58A9A71489:42"
                  hm-rega.0 2019-03-12 11:48:58.565 info renamed hm-rpc.2.001F58A9A71489.43 to "HmIP-RCV-50 001F58A9A71489:43"
                  hm-rega.0 2019-03-12 11:48:58.557 info renamed hm-rpc.2.001F58A9A71489.44 to "HmIP-RCV-50 001F58A9A71489:44"
                  hm-rega.0 2019-03-12 11:48:58.550 info renamed hm-rpc.2.001F58A9A71489.45 to "HmIP-RCV-50 001F58A9A71489:45"
                  hm-rega.0 2019-03-12 11:48:58.543 info renamed hm-rpc.2.001F58A9A71489.46 to "HmIP-RCV-50 001F58A9A71489:46"
                  hm-rega.0 2019-03-12 11:48:58.538 info renamed hm-rpc.2.001F58A9A71489.47 to "HmIP-RCV-50 001F58A9A71489:47"
                  hm-rega.0 2019-03-12 11:48:58.530 info renamed hm-rpc.2.001F58A9A71489.48 to "HmIP-RCV-50 001F58A9A71489:48"
                  hm-rega.0 2019-03-12 11:48:58.522 info renamed hm-rpc.2.001F58A9A71489.49 to "HmIP-RCV-50 001F58A9A71489:49"
                  hm-rega.0 2019-03-12 11:48:58.514 info renamed hm-rpc.2.001F58A9A71489.50 to "HmIP-RCV-50 001F58A9A71489:50"
                  hm-rega.0 2019-03-12 11:48:58.507 info renamed hm-rpc.2.001718A9A77F9D to "HmIPW-Eingänge 1-32:7F9D"
                  hm-rega.0 2019-03-12 11:48:58.500 info renamed hm-rpc.2.001718A9A77F9D.0 to "HmIPW-Eingänge 1-32:7F9D:0"
                  hm-rega.0 2019-03-12 11:48:58.493 info renamed hm-rpc.2.001718A9A77F9D.1 to "HmIPW-DRI32 001718A9A77F9D:1"
                  hm-rega.0 2019-03-12 11:48:58.485 info renamed hm-rpc.2.001718A9A77F9D.2 to "HmIPW-DRI32 001718A9A77F9D:2"
                  hm-rega.0 2019-03-12 11:48:58.478 info renamed hm-rpc.2.001718A9A77F9D.3 to "HmIPW-DRI32 001718A9A77F9D:3"
                  hm-rega.0 2019-03-12 11:48:58.463 info renamed hm-rpc.2.001718A9A77F9D.4 to "HmIPW-DRI32 001718A9A77F9D:4"
                  hm-rega.0 2019-03-12 11:48:58.451 info renamed hm-rpc.2.001718A9A77F9D.5 to "HmIPW-DRI32 001718A9A77F9D:5"
                  hm-rega.0 2019-03-12 11:48:58.444 info renamed hm-rpc.2.001718A9A77F9D.6 to "HmIPW-DRI32 001718A9A77F9D:6"
                  hm-rega.0 2019-03-12 11:48:58.434 info renamed hm-rpc.2.001718A9A77F9D.7 to "HmIPW-DRI32 001718A9A77F9D:7"
                  hm-rega.0 2019-03-12 11:48:58.427 info renamed hm-rpc.2.001718A9A77F9D.8 to "HmIPW-DRI32 001718A9A77F9D:8"
                  hm-rega.0 2019-03-12 11:48:58.420 info renamed hm-rpc.2.001718A9A77F9D.9 to "HmIPW-DRI32 001718A9A77F9D:9"
                  hm-rega.0 2019-03-12 11:48:58.413 info renamed hm-rpc.2.001718A9A77F9D.10 to "HmIPW-DRI32 001718A9A77F9D:10"
                  hm-rega.0 2019-03-12 11:48:58.407 info renamed hm-rpc.2.001718A9A77F9D.11 to "HmIPW-DRI32 001718A9A77F9D:11"
                  hm-rega.0 2019-03-12 11:48:58.400 info renamed hm-rpc.2.001718A9A77F9D.12 to "HmIPW-DRI32 001718A9A77F9D:12"
                  hm-rega.0 2019-03-12 11:48:58.393 info renamed hm-rpc.2.001718A9A77F9D.13 to "HmIPW-DRI32 001718A9A77F9D:13"
                  hm-rega.0 2019-03-12 11:48:58.373 info renamed hm-rpc.2.001718A9A77F9D.14 to "HmIPW-DRI32 001718A9A77F9D:14"
                  hm-rega.0 2019-03-12 11:48:58.366 info renamed hm-rpc.2.001718A9A77F9D.15 to "HmIPW-DRI32 001718A9A77F9D:15"
                  hm-rega.0 2019-03-12 11:48:58.359 info renamed hm-rpc.2.001718A9A77F9D.16 to "HmIPW-DRI32 001718A9A77F9D:16"
                  hm-rega.0 2019-03-12 11:48:58.352 info renamed hm-rpc.2.001718A9A77F9D.17 to "HmIPW-DRI32 001718A9A77F9D:17"
                  hm-rega.0 2019-03-12 11:48:58.345 info renamed hm-rpc.2.001718A9A77F9D.18 to "HmIPW-DRI32 001718A9A77F9D:18"
                  hm-rega.0 2019-03-12 11:48:58.338 info renamed hm-rpc.2.001718A9A77F9D.19 to "HmIPW-DRI32 001718A9A77F9D:19"
                  hm-rega.0 2019-03-12 11:48:58.330 info renamed hm-rpc.2.001718A9A77F9D.20 to "HmIPW-DRI32 001718A9A77F9D:20"
                  hm-rega.0 2019-03-12 11:48:58.323 info renamed hm-rpc.2.001718A9A77F9D.21 to "HmIPW-DRI32 001718A9A77F9D:21"
                  hm-rega.0 2019-03-12 11:48:58.316 info renamed hm-rpc.2.001718A9A77F9D.22 to "HmIPW-DRI32 001718A9A77F9D:22"
                  hm-rega.0 2019-03-12 11:48:58.309 info renamed hm-rpc.2.001718A9A77F9D.23 to "HmIPW-DRI32 001718A9A77F9D:23"
                  hm-rega.0 2019-03-12 11:48:58.302 info renamed hm-rpc.2.001718A9A77F9D.24 to "HmIPW-DRI32 001718A9A77F9D:24"
                  hm-rega.0 2019-03-12 11:48:58.295 info renamed hm-rpc.2.001718A9A77F9D.25 to "HmIPW-DRI32 001718A9A77F9D:25"
                  hm-rega.0 2019-03-12 11:48:58.288 info renamed hm-rpc.2.001718A9A77F9D.26 to "HmIPW-DRI32 001718A9A77F9D:26"
                  hm-rega.0 2019-03-12 11:48:58.281 info renamed hm-rpc.2.001718A9A77F9D.27 to "HmIPW-DRI32 001718A9A77F9D:27"
                  hm-rega.0 2019-03-12 11:48:58.274 info renamed hm-rpc.2.001718A9A77F9D.28 to "HmIPW-DRI32 001718A9A77F9D:28"
                  hm-rega.0 2019-03-12 11:48:58.267 info renamed hm-rpc.2.001718A9A77F9D.29 to "HmIPW-DRI32 001718A9A77F9D:29"
                  hm-rega.0 2019-03-12 11:48:58.260 info renamed hm-rpc.2.001718A9A77F9D.30 to "HmIPW-DRI32 001718A9A77F9D:30"
                  hm-rega.0 2019-03-12 11:48:58.254 info renamed hm-rpc.2.001718A9A77F9D.31 to "HmIPW-DRI32 001718A9A77F9D:31"
                  hm-rega.0 2019-03-12 11:48:58.243 info renamed hm-rpc.2.001718A9A77F9D.32 to "HmIPW-DRI32 001718A9A77F9D:32"
                  hm-rega.0 2019-03-12 11:48:58.225 info renamed hm-rpc.2.001718A9A77F9D.33 to "HmIPW-DRI32 001718A9A77F9D:33"
                  hm-rega.0 2019-03-12 11:48:58.214 info renamed hm-rpc.2.001658A99FD33B to "HmIPW-Rollladen 1-4:D33B"
                  hm-rega.0 2019-03-12 11:48:58.202 info renamed hm-rpc.2.001658A99FD33B.0 to "HmIPW-Rollladen 1-4:D33B:0"
                  hm-rega.0 2019-03-12 11:48:58.196 info renamed hm-rpc.2.001658A99FD33B.1 to "HmIPW-DRBL4 001658A99FD33B:1"
                  hm-rega.0 2019-03-12 11:48:58.189 info renamed hm-rpc.2.001658A99FD33B.2 to "HmIPW-DRBL4 001658A99FD33B:2"
                  hm-rega.0 2019-03-12 11:48:58.181 info renamed hm-rpc.2.001658A99FD33B.3 to "HmIPW-DRBL4 001658A99FD33B:3"
                  hm-rega.0 2019-03-12 11:48:58.173 info renamed hm-rpc.2.001658A99FD33B.4 to "HmIPW-DRBL4 001658A99FD33B:4"
                  hm-rega.0 2019-03-12 11:48:58.146 info renamed hm-rpc.2.001658A99FD33B.5 to "HmIPW-DRBL4 001658A99FD33B:5"
                  hm-rega.0 2019-03-12 11:48:58.130 info renamed hm-rpc.2.001658A99FD33B.6 to "HmIPW-DRBL4 001658A99FD33B:6"
                  hm-rega.0 2019-03-12 11:48:58.123 info renamed hm-rpc.2.001658A99FD33B.7 to "HmIPW-DRBL4 001658A99FD33B:7"
                  hm-rega.0 2019-03-12 11:48:58.115 info renamed hm-rpc.2.001658A99FD33B.8 to "HmIPW-DRBL4 001658A99FD33B:8"
                  hm-rega.0 2019-03-12 11:48:58.108 info renamed hm-rpc.2.001658A99FD33B.9 to "HmIPW-DRBL4 001658A99FD33B:9"
                  hm-rega.0 2019-03-12 11:48:58.101 info renamed hm-rpc.2.001658A99FD33B.10 to "HmIPW-DRBL4 001658A99FD33B:10"
                  hm-rega.0 2019-03-12 11:48:58.093 info renamed hm-rpc.2.001658A99FD33B.11 to "HmIPW-DRBL4 001658A99FD33B:11"
                  hm-rega.0 2019-03-12 11:48:58.084 info renamed hm-rpc.2.001658A99FD33B.12 to "HmIPW-DRBL4 001658A99FD33B:12"
                  hm-rega.0 2019-03-12 11:48:58.076 info renamed hm-rpc.2.001658A99FD33B.13 to "HmIPW-DRBL4 001658A99FD33B:13"
                  hm-rega.0 2019-03-12 11:48:58.069 info renamed hm-rpc.2.001658A99FD33B.14 to "HmIPW-DRBL4 001658A99FD33B:14"
                  hm-rega.0 2019-03-12 11:48:58.061 info renamed hm-rpc.2.001658A99FD33B.15 to "HmIPW-DRBL4 001658A99FD33B:15"
                  hm-rega.0 2019-03-12 11:48:58.053 info renamed hm-rpc.2.001658A99FD33B.16 to "HmIPW-DRBL4 001658A99FD33B:16"
                  hm-rega.0 2019-03-12 11:48:58.044 info renamed hm-rpc.2.001658A99FD33B.17 to "HmIPW-DRBL4 001658A99FD33B:17"
                  hm-rega.0 2019-03-12 11:48:58.037 info renamed hm-rpc.2.001658A99FD432 to "HmIPW-Rollladen 13-16:D432"
                  hm-rega.0 2019-03-12 11:48:58.018 info renamed hm-rpc.2.001658A99FD432.0 to "HmIPW-Rollladen 13-16:D432:0"
                  hm-rega.0 2019-03-12 11:48:57.999 info renamed hm-rpc.2.001658A99FD432.1 to "HmIPW-DRBL4 001658A99FD432:1"
                  hm-rega.0 2019-03-12 11:48:57.986 info renamed hm-rpc.2.001658A99FD432.2 to "HmIPW-DRBL4 001658A99FD432:2"
                  hm-rega.0 2019-03-12 11:48:57.978 info renamed hm-rpc.2.001658A99FD432.3 to "HmIPW-DRBL4 001658A99FD432:3"
                  hm-rega.0 2019-03-12 11:48:57.968 info renamed hm-rpc.2.001658A99FD432.4 to "HmIPW-DRBL4 001658A99FD432:4"
                  hm-rega.0 2019-03-12 11:48:57.962 info renamed hm-rpc.2.001658A99FD432.5 to "HmIPW-DRBL4 001658A99FD432:5"
                  hm-rega.0 2019-03-12 11:48:57.954 info renamed hm-rpc.2.001658A99FD432.6 to "HmIPW-DRBL4 001658A99FD432:6"
                  hm-rega.0 2019-03-12 11:48:57.946 info renamed hm-rpc.2.001658A99FD432.7 to "HmIPW-DRBL4 001658A99FD432:7"
                  hm-rega.0 2019-03-12 11:48:57.939 info renamed hm-rpc.2.001658A99FD432.8 to "HmIPW-DRBL4 001658A99FD432:8"
                  hm-rega.0 2019-03-12 11:48:57.932 info renamed hm-rpc.2.001658A99FD432.9 to "HmIPW-DRBL4 001658A99FD432:9"
                  hm-rega.0 2019-03-12 11:48:57.924 info renamed hm-rpc.2.001658A99FD432.10 to "HmIPW-DRBL4 001658A99FD432:10"
                  hm-rega.0 2019-03-12 11:48:57.917 info renamed hm-rpc.2.001658A99FD432.11 to "HmIPW-DRBL4 001658A99FD432:11"
                  hm-rega.0 2019-03-12 11:48:57.910 info renamed hm-rpc.2.001658A99FD432.12 to "HmIPW-DRBL4 001658A99FD432:12"
                  hm-rega.0 2019-03-12 11:48:57.903 info renamed hm-rpc.2.001658A99FD432.13 to "HmIPW-DRBL4 001658A99FD432:13"
                  hm-rega.0 2019-03-12 11:48:57.895 info renamed hm-rpc.2.001658A99FD432.14 to "HmIPW-DRBL4 001658A99FD432:14"
                  hm-rega.0 2019-03-12 11:48:57.887 info renamed hm-rpc.2.001658A99FD432.15 to "HmIPW-DRBL4 001658A99FD432:15"
                  hm-rega.0 2019-03-12 11:48:57.879 info renamed hm-rpc.2.001658A99FD432.16 to "HmIPW-DRBL4 001658A99FD432:16"
                  hm-rega.0 2019-03-12 11:48:57.870 info renamed hm-rpc.2.001658A99FD432.17 to "HmIPW-DRBL4 001658A99FD432:17"
                  hm-rega.0 2019-03-12 11:48:57.863 info renamed hm-rpc.2.001658A99FD422 to "HmIPW-Rollladen 17-20:D422"
                  hm-rega.0 2019-03-12 11:48:57.850 info renamed hm-rpc.2.001658A99FD422.0 to "HmIPW-Rollladen 17-20:D422:0"
                  hm-rega.0 2019-03-12 11:48:57.842 info renamed hm-rpc.2.001658A99FD422.1 to "HmIPW-DRBL4 001658A99FD422:1"
                  hm-rega.0 2019-03-12 11:48:57.834 info renamed hm-rpc.2.001658A99FD422.2 to "HmIPW-DRBL4 001658A99FD422:2"
                  hm-rega.0 2019-03-12 11:48:57.828 info renamed hm-rpc.2.001658A99FD422.3 to "HmIPW-DRBL4 001658A99FD422:3"
                  hm-rega.0 2019-03-12 11:48:57.821 info renamed hm-rpc.2.001658A99FD422.4 to "HmIPW-DRBL4 001658A99FD422:4"
                  hm-rega.0 2019-03-12 11:48:57.815 info renamed hm-rpc.2.001658A99FD422.5 to "HmIPW-DRBL4 001658A99FD422:5"
                  hm-rega.0 2019-03-12 11:48:57.807 info renamed hm-rpc.2.001658A99FD422.6 to "HmIPW-DRBL4 001658A99FD422:6"
                  hm-rega.0 2019-03-12 11:48:57.799 info renamed hm-rpc.2.001658A99FD422.7 to "HmIPW-DRBL4 001658A99FD422:7"
                  hm-rega.0 2019-03-12 11:48:57.792 info renamed hm-rpc.2.001658A99FD422.8 to "HmIPW-DRBL4 001658A99FD422:8"
                  hm-rega.0 2019-03-12 11:48:57.783 info renamed hm-rpc.2.001658A99FD422.9 to "HmIPW-DRBL4 001658A99FD422:9"
                  hm-rega.0 2019-03-12 11:48:57.775 info renamed hm-rpc.2.001658A99FD422.10 to "HmIPW-DRBL4 001658A99FD422:10"
                  hm-rega.0 2019-03-12 11:48:57.763 info renamed hm-rpc.2.001658A99FD422.11 to "HmIPW-DRBL4 001658A99FD422:11"
                  hm-rega.0 2019-03-12 11:48:57.753 info renamed hm-rpc.2.001658A99FD422.12 to "HmIPW-DRBL4 001658A99FD422:12"
                  hm-rega.0 2019-03-12 11:48:57.729 info renamed hm-rpc.2.001658A99FD422.13 to "HmIPW-DRBL4 001658A99FD422:13"
                  hm-rega.0 2019-03-12 11:48:57.717 info renamed hm-rpc.2.001658A99FD422.14 to "HmIPW-DRBL4 001658A99FD422:14"
                  hm-rega.0 2019-03-12 11:48:57.704 info renamed hm-rpc.2.001658A99FD422.15 to "HmIPW-DRBL4 001658A99FD422:15"
                  hm-rega.0 2019-03-12 11:48:57.694 info renamed hm-rpc.2.001658A99FD422.16 to "HmIPW-DRBL4 001658A99FD422:16"
                  hm-rega.0 2019-03-12 11:48:57.686 info renamed hm-rpc.2.001658A99FD422.17 to "HmIPW-DRBL4 001658A99FD422:17"
                  hm-rega.0 2019-03-12 11:48:57.676 info renamed hm-rpc.2.001658A99FD461 to "HmIPW-Rollladen 5-8:D461"
                  hm-rega.0 2019-03-12 11:48:57.667 info renamed hm-rpc.2.001658A99FD461.0 to "HmIPW-Rollladen 5-8:D461:0"
                  hm-rega.0 2019-03-12 11:48:57.658 info renamed hm-rpc.2.001658A99FD461.1 to "HmIPW-DRBL4 001658A99FD461:1"
                  hm-rega.0 2019-03-12 11:48:57.646 info renamed hm-rpc.2.001658A99FD461.2 to "HmIPW-DRBL4 001658A99FD461:2"
                  hm-rega.0 2019-03-12 11:48:57.631 info renamed hm-rpc.2.001658A99FD461.3 to "HmIPW-DRBL4 001658A99FD461:3"
                  hm-rega.0 2019-03-12 11:48:57.622 info renamed hm-rpc.2.001658A99FD461.4 to "HmIPW-DRBL4 001658A99FD461:4"
                  hm-rega.0 2019-03-12 11:48:57.612 info renamed hm-rpc.2.001658A99FD461.5 to "HmIPW-DRBL4 001658A99FD461:5"
                  hm-rega.0 2019-03-12 11:48:57.605 info renamed hm-rpc.2.001658A99FD461.6 to "HmIPW-DRBL4 001658A99FD461:6"
                  hm-rega.0 2019-03-12 11:48:57.598 info renamed hm-rpc.2.001658A99FD461.7 to "HmIPW-DRBL4 001658A99FD461:7"
                  hm-rega.0 2019-03-12 11:48:57.590 info renamed hm-rpc.2.001658A99FD461.8 to "HmIPW-DRBL4 001658A99FD461:8"
                  hm-rega.0 2019-03-12 11:48:57.582 info renamed hm-rpc.2.001658A99FD461.9 to "HmIPW-DRBL4 001658A99FD461:9"
                  hm-rega.0 2019-03-12 11:48:57.575 info renamed hm-rpc.2.001658A99FD461.10 to "HmIPW-DRBL4 001658A99FD461:10"
                  hm-rega.0 2019-03-12 11:48:57.567 info renamed hm-rpc.2.001658A99FD461.11 to "HmIPW-DRBL4 001658A99FD461:11"
                  hm-rega.0 2019-03-12 11:48:57.560 info renamed hm-rpc.2.001658A99FD461.12 to "HmIPW-DRBL4 001658A99FD461:12"
                  hm-rega.0 2019-03-12 11:48:57.551 info renamed hm-rpc.2.001658A99FD461.13 to "HmIPW-DRBL4 001658A99FD461:13"
                  hm-rega.0 2019-03-12 11:48:57.544 info renamed hm-rpc.2.001658A99FD461.14 to "HmIPW-DRBL4 001658A99FD461:14"
                  hm-rega.0 2019-03-12 11:48:57.536 info renamed hm-rpc.2.001658A99FD461.15 to "HmIPW-DRBL4 001658A99FD461:15"
                  hm-rega.0 2019-03-12 11:48:57.529 info renamed hm-rpc.2.001658A99FD461.16 to "HmIPW-DRBL4 001658A99FD461:16"
                  hm-rega.0 2019-03-12 11:48:57.510 info renamed hm-rpc.2.001658A99FD461.17 to "HmIPW-DRBL4 001658A99FD461:17"
                  hm-rega.0 2019-03-12 11:48:57.493 info renamed hm-rpc.2.001658A99FD436 to "HmIPW-Rollladen 9-12:D436"
                  hm-rega.0 2019-03-12 11:48:57.482 info renamed hm-rpc.2.001658A99FD436.0 to "HmIPW-Rollladen 9-12:D436:0"
                  hm-rega.0 2019-03-12 11:48:57.473 info renamed hm-rpc.2.001658A99FD436.1 to "HmIPW-DRBL4 001658A99FD436:1"
                  hm-rega.0 2019-03-12 11:48:57.464 info renamed hm-rpc.2.001658A99FD436.2 to "HmIPW-DRBL4 001658A99FD436:2"
                  hm-rega.0 2019-03-12 11:48:57.454 info renamed hm-rpc.2.001658A99FD436.3 to "HmIPW-DRBL4 001658A99FD436:3"
                  hm-rega.0 2019-03-12 11:48:57.445 info renamed hm-rpc.2.001658A99FD436.4 to "HmIPW-DRBL4 001658A99FD436:4"
                  hm-rega.0 2019-03-12 11:48:57.433 info renamed hm-rpc.2.001658A99FD436.5 to "HmIPW-DRBL4 001658A99FD436:5"
                  hm-rega.0 2019-03-12 11:48:57.424 info renamed hm-rpc.2.001658A99FD436.6 to "HmIPW-DRBL4 001658A99FD436:6"
                  hm-rega.0 2019-03-12 11:48:57.415 info renamed hm-rpc.2.001658A99FD436.7 to "HmIPW-DRBL4 001658A99FD436:7"
                  hm-rega.0 2019-03-12 11:48:57.405 info renamed hm-rpc.2.001658A99FD436.8 to "HmIPW-DRBL4 001658A99FD436:8"
                  hm-rega.0 2019-03-12 11:48:57.396 info renamed hm-rpc.2.001658A99FD436.9 to "HmIPW-DRBL4 001658A99FD436:9"
                  hm-rega.0 2019-03-12 11:48:57.376 info renamed hm-rpc.2.001658A99FD436.10 to "HmIPW-DRBL4 001658A99FD436:10"
                  hm-rega.0 2019-03-12 11:48:57.362 info renamed hm-rpc.2.001658A99FD436.11 to "HmIPW-DRBL4 001658A99FD436:11"
                  hm-rega.0 2019-03-12 11:48:57.353 info renamed hm-rpc.2.001658A99FD436.12 to "HmIPW-DRBL4 001658A99FD436:12"
                  hm-rega.0 2019-03-12 11:48:57.343 info renamed hm-rpc.2.001658A99FD436.13 to "HmIPW-DRBL4 001658A99FD436:13"
                  hm-rega.0 2019-03-12 11:48:57.333 info renamed hm-rpc.2.001658A99FD436.14 to "HmIPW-DRBL4 001658A99FD436:14"
                  hm-rega.0 2019-03-12 11:48:57.324 info renamed hm-rpc.2.001658A99FD436.15 to "HmIPW-DRBL4 001658A99FD436:15"
                  hm-rega.0 2019-03-12 11:48:57.312 info renamed hm-rpc.2.001658A99FD436.16 to "HmIPW-DRBL4 001658A99FD436:16"
                  hm-rega.0 2019-03-12 11:48:57.301 info renamed hm-rpc.2.001658A99FD436.17 to "HmIPW-DRBL4 001658A99FD436:17"
                  hm-rega.0 2019-03-12 11:48:56.717 info added/updated rooms to enum.rooms
                  hm-rega.0 2019-03-12 11:48:56.632 info added/updated functions to enum.functions
                  hm-rega.0 2019-03-12 11:48:56.567 info added/updated 0 favorites to enum.favorites
                  hm-rega.0 2019-03-12 11:48:56.526 info time difference local-ccu 1s
                  hm-rega.0 2019-03-12 11:48:56.438 info ReGaHSS 192.168.2.62 up
                  hm-rega.0 2019-03-12 11:48:56.341 info subscribe .BidCoS-RF.50.PRESS_SHORT
                  hm-rega.0 2019-03-12 11:48:56.305 info starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.14.1
                  host.raspberrypi 2019-03-12 11:48:53.788 info instance system.adapter.hm-rega.0 started with pid 2394
                  host.raspberrypi 2019-03-12 11:48:53.736 info object change system.adapter.hm-rega.0
                  hm-rpc.2 2019-03-12 11:48:51.796 debug start ping interval
                  hm-rpc.2 2019-03-12 11:48:51.795 debug clear connecting interval
                  hm-rpc.2 2019-03-12 11:48:51.793 info Connected
                  hm-rpc.2 2019-03-12 11:48:51.735 debug start connecting interval
                  hm-rpc.2 2019-03-12 11:48:51.719 debug xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010","hm-rpc.2"]
                  hm-rpc.2 2019-03-12 11:48:51.717 debug Connect...
                  hm-rpc.2 2019-03-12 11:48:51.714 info xmlrpc client is trying to connect to 192.168.2.62:2010/ with ["http://192.168.2.95:2010","hm-rpc.2"]
                  hm-rpc.2 2019-03-12 11:48:51.713 info xmlrpc server is trying to listen on 127.0.0.1:2010
                  hm-rpc.2 2019-03-12 11:48:51.381 info starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
                  hm-rpc.2 2019-03-12 11:48:51.333 warn setObject updated (type=state) property common.role missing!
                  hm-rpc.2 2019-03-12 11:48:51.332 warn setObject updated (type=state) property native missing!
                  hm-rpc.2 2019-03-12 11:48:51.209 debug statesDB connected
                  hm-rpc.2 2019-03-12 11:48:51.097 debug objectDB connected
                  host.raspberrypi 2019-03-12 11:48:49.707 info instance system.adapter.hm-rpc.2 started with pid 2384
                  host.raspberrypi 2019-03-12 11:48:49.611 info "system.adapter.hm-rpc.2" enabled
                  host.raspberrypi 2019-03-12 11:48:49.608 info object change system.adapter.hm-rpc.2
                  host.raspberrypi 2019-03-12 11:48:43.185 info object change system.adapter.hm-rpc.2
                  host.raspberrypi 2019-03-12 11:47:47.884 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                  hm-rega.0 2019-03-12 11:47:47.827 info terminating
                  host.raspberrypi 2019-03-12 11:47:47.780 info stopInstance system.adapter.hm-rega.0 killing pid 1654
                  host.raspberrypi 2019-03-12 11:47:47.779 info stopInstance system.adapter.hm-rega.0
                  host.raspberrypi 2019-03-12 11:47:47.778 info object change system.adapter.hm-rega.0
                  host.raspberrypi 2019-03-12 11:47:45.496 info instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
                  hm-rpc.2 2019-03-12 11:47:45.425 info terminating
                  hm-rpc.2 2019-03-12 11:47:45.410 info Disconnected
                  hm-rpc.2 2019-03-12 11:47:45.376 info xmlrpc -> 192.168.2.62:2010/ init ["http://192.168.2.95:2010",""]
                  host.raspberrypi 2019-03-12 11:47:45.368 info stopInstance timeout "1000 system.adapter.hm-rpc.2 killing pid 1706
                  host.raspberrypi 2019-03-12 11:47:44.360 info stopInstance system.adapter.hm-rpc.2
                  hm-rpc.2 2019-03-12 11:47:44.367 debug [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.raspberrypi","callback":{"message":null,"id":15,"ack":false,"time":1552391264362},"_id":72583318}
                  host.raspberrypi 2019-03-12 11:47:44.349 info object change system.adapter.hm-rpc.2
                  hm-rpc.0 2019-03-12 11:47:21.039 info new CUxD devices/channels after filter: 0
                  hm-rpc.0 2019-03-12 11:47:20.989 info xmlrpc -> listDevices 0
                  • A AHg
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @AHg ist ja auch ständig ein Connection timeout. Zeig mal bitte die Config, hast du was in der Callbackadresse stehen?
                      AHg
                      @foxriver76 hier mal die Konfiguration vom hm-rpc
                      • A AHg
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        schrieb am zuletzt editiert von foxriver76
                        @AHg Stell mal bitte die Adapteradresse auf dein explizites Interface (z. B. eth0 wenn existent), wenn ich da localhost (127.0.0.1) anwähle laufe ich auch in den Timeout und es werden keine Geräte synchronisiert.
                          AHg
                          @foxriver76 Hey, super! 👍 sieht gut aus. Kleiner Fehler, große Wirkung.
                          Ob alles funktioniert, kann ich erst heute Abend versuchen, wenn ich wieder daheim bin.
                          Vielen Dank für Deine super Hilfe
                          • A AHg
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            @AHg Gerne, dann weiß ich jetzt, dass wir für Wired Geräte nichts anpassen müssen. 👍
                            Falls dir doch noch was auffällt, schreibe hier einfach nochmal.
                            Videotutorials & mehr
                            • N Offline
                              N Offline
                              Nussknacker
                              da schließe ich mich mal an. Bzgl. der Namensübertragungen und der Geräte Werte habe ich bei den Aktoren keine Probleme bei den Homematic IP Wired Geräten.
                              Was bei mir aber nicht funktioniert ist die Verwendung der Taster an den Eingangsmodulen. Hier erkennt der RPC Adapter nicht, ob ich den Taster gerdrückt habe und damit auch nicht ob er kurz oder lang gedrückt wurde.
                              Hat noch jemand das Problem und eine Lösung für mich?
                              Ich habe bis jetzt ein Dummyprogramm in der Webui angelegt und die Taster als Trigger eingetragen. Dann wurde manche Tasterbetätigungen erkannt, andere nicht. Es funktioniert nur der Umweg, dass ich mittels des Tasters eine Systemvariable in der Webui trigger und im ioBroker auf Änderungen der Systemvariable reagiere. Ziemlich umständlich.
                              Über ein Feedback würde ich mich freuen!
                              Danke!
                              Martin
                              • N Nussknacker
                                Danke!
                                Martin
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @Nussknacker Ändert sich der Timestamp des Datenpunktes, wenn du den Taster drückst? Manche aktualisieren nur und lösen keine Änderung des States aus.
                                • N Offline
                                  N Offline
                                  Nussknacker
                                  Ich guck heute Abend mal.
                                  • N Offline
                                    N Offline
                                    Nussknacker
                                    In ioBroker ändert sich nichts. Habe auch mal den History Adapter bemüht, der zeichnet nichts auf. Und in der WebUi steht auch kein Zeitstempel in der Gerätesteuerung.
