  4. IOBroker hat sich beendet
iobrokerabsturz
59 Beiträge 8 Kommentatoren 6.3k Aufrufe 6 Beobachtet
  • D derrapf
    @Homoran
    Ui, da sind ja jetzt ganz viele. Sorry. Als ich damals auf der Seite war gab es nur eines.
    Ich habe das hier "ioBroker_Image_Rock64_20180419_stretch.img". Hilft Dir das?
    Ich habe jetzt mal den js-controller auf der Commandline gestartet
    Da kommen viele Fehler.
    root@ioBroker-Rock64:/opt/iobroker# node node_modules/iobroker.js-controller/controlle                                                             r.js --logs
    2019-02-25 19:55:43.332  - info: host.ioBroker-Rock64 iobroker.js-controller version 1                                                             .4.2 js-controller starting
    2019-02-25 19:55:43.342  - info: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox,                                                              2014 hobbyquaker
    2019-02-25 19:55:43.343  - info: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node:                                                              v8.15.0
    2019-02-25 19:55:43.350  - info: host.ioBroker-Rock64 ip addresses: 192.168.111.176 fd                                                             13:235b:7090:0:4f6a:8f2e:213a:f7b7 2003:f4:4bc4:8200:b97a:5558:33ac:531c fd13:235b:709                                                             0::cda fd13:235b:7090:0:7897:fff:fefc:11b5 fe80::7897:fff:fefc:11b5
    2019-02-25 19:55:44.492  - info: host.ioBroker-Rock64  inMem-objects listening on port                                                              9001
    2019-02-25 19:55:44.666  - info: host.ioBroker-Rock64 States connected to redis: 127.0                                                             .0.1:6379
    2019-02-25 19:55:44.671  - info: host.ioBroker-Rock64 InMemoryDB connected
    2019-02-25 19:55:44.767  - info: host.ioBroker-Rock64 57 instances found
    host.ioBroker-Rock64 check instance "system.adapter.admin.0" for host "ioBroker-Rock64                                                             "
    host.ioBroker-Rock64 check instance "system.adapter.web.0" for host "ioBroker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis.0" for host "ioBroker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.history.0" for host "ioBroker-Rock                                                             64"
    host.ioBroker-Rock64 check instance "system.adapter.javascript.0" for host "ioBroker-R                                                             ock64"
    host.ioBroker-Rock64 check instance "system.adapter.socketio.0" for host "ioBroker-Roc                                                             k64"
    host.ioBroker-Rock64 check instance "system.adapter.mobile.0" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.vis-bars.0" for host "ioBroker-Roc                                                             k64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-metro.0" for host "ioBroker-Ro                                                             ck64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-rgraph.0" for host "ioBroker-R                                                             ock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-plumb.0" for host "ioBroker-Ro                                                             ck64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-players.0" for host "ioBroker-                                                             Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-map.0" for host "ioBroker-Rock                                                             64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-keyboard.0" for host "ioBroker                                                             -Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-lcars.0" for host "ioBroker-Ro                                                             ck64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-justgage.0" for host "ioBroker                                                             -Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-hqwidgets.0" for host "ioBroke                                                             r-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-jqui-mfd.0" for host "ioBroker                                                             -Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-fancyswitch.0" for host "ioBro                                                             ker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-colorpicker.0" for host "ioBro                                                             ker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-canvas-gauges.0" for host "ioB                                                             roker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-google-fonts.0" for host "ioBr                                                             oker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-history.0" for host "ioBroker-                                                             Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.ical.0" for host "ioBroker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.text2command.0" for host "ioBroker                                                             -Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.sayit.0" for host "ioBroker-Rock64                                                             "
    host.ioBroker-Rock64 check instance "system.adapter.owntracks.0" for host "ioBroker-Ro                                                             ck64"
    host.ioBroker-Rock64 check instance "system.adapter.js-controller.0" for host "ioBroke                                                             r-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.fritzbox.0" for host "ioBroker-Roc                                                             k64"
    host.ioBroker-Rock64 check instance "system.adapter.dwd.0" for host "ioBroker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.telegram.0" for host "ioBroker-Roc                                                             k64"
    host.ioBroker-Rock64 check instance "system.adapter.tvspielfilm.0" for host "ioBroker-                                                             Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.simple-api.0" for host "ioBroker-R                                                             ock64"
    host.ioBroker-Rock64 check instance "system.adapter.vis-timeandweather.0" for host "io                                                             Broker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.mqtt-client.0" for host "ioBroker-                                                             Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.hm-rpc.0" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.hm-rpc.1" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.samsung.0" for host "ioBroker-Rock                                                             64"
    host.ioBroker-Rock64 check instance "system.adapter.hm-rega.0" for host "ioBroker-Rock                                                             64"
    host.ioBroker-Rock64 check instance "system.adapter.cloud.0" for host "ioBroker-Rock64                                                             "
    host.ioBroker-Rock64 check instance "system.adapter.alexa2.0" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.iot.0" for host "ioBroker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.scenes.0" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.hm-rpc.2" for host "ioBroker-Rock6                                                             4"
    host.ioBroker-Rock64 check instance "system.adapter.amazon-dash.0" for host "ioBroker-                                                             Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.weatherunderground.0" for host "io                                                             Broker-Rock64"
    host.ioBroker-Rock64 check instance "system.adapter.shelly.0" for host "ioBroker-Rock6                                                             4"
    2019-02-25 19:55:44.841  - info: host.ioBroker-Rock64 starting 26 instances
    2019-02-25 19:55:44.903  - info: host.ioBroker-Rock64 instance system.adapter.admin.0                                                              started with pid 25475
    2019-02-25 19:55:49.553  - info: host.ioBroker-Rock64 instance system.adapter.web.0 started with pid 25481
    (node:25465) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
    2019-02-25 19:55:51.231  - error: host.ioBroker-Rock64 instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:55:51.232  - info: host.ioBroker-Rock64 Restart adapter system.adapter.admin.0 because enabled
    2019-02-25 19:55:53.226  - error: host.ioBroker-Rock64 instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:55:53.227  - info: host.ioBroker-Rock64 Restart adapter system.adapter.web.0 because enabled
    2019-02-25 19:55:57.015  - info: host.ioBroker-Rock64 instance system.adapter.history.0 started with pid 25508
    2019-02-25 19:56:02.547  - info: host.ioBroker-Rock64 instance system.adapter.javascript.0 started with pid 25529
    Cannot parse "/user/vis-views.json
    Send diag info: {"uuid":"aec67a1a-f2cf-7abe-98d8-845cd7e36d52","language":"de","country":"","hosts":[{"version":"1.4.2","platform":"Javascript/Node.js","type":"linux"}],"node":"v8.15.0","arch":"arm64","adapters":{"admin":{"version":"3.5.10","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.9.6","platform":"Javascript/Node.js"},"hm-rega":{"version":"2.3.0","platform":"Javascript/Node.js"},"web":{"version":"2.4.1","platform":"Javascript/Node.js"},"vis":{"version":"1.1.8","platform":"Javascript/Node.js"},"history":{"version":"1.8.5","platform":"Javascript/Node.js"},"flot":{"version":"1.9.2","platform":"javascript/Node.js"},"javascript":{"version":"3.6.4","platform":"Javascript/Node.js"},"socketio":{"version":"2.1.1","platform":"Javascript/Node.js"},"mobile":{"version":"0.4.11","platform":"javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-rgraph":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.1","platform":"Javascript/Node.js"},"vis-players":{"version":"0.1.5","platform":"Javascript/Node.js"},"vis-map":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-lcars":{"version":"1.0.4","platform":"Javascript/Node.js"},"vis-justgage":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-colorpicker":{"version":"1.1.1","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"0.1.5","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-history":{"version":"0.2.7","platform":"Javascript/Node.js"},"icons-addictive-flavour-png":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-icons8":{"version":"0.0.1","platform":"javascript/Node.js"},"icons-material-png":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-material-svg":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-mfd-png":{"version":"1.0.2","platform":"javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"icons-open-icon-library-png":{"version":"0.1.3","platform":"javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"ical":{"version":"1.7.0","platform":"Javascript/Node.js"},"text2command":{"version":"1.2.4","platform":"Javascript/Node.js"},"sayit":{"version":"1.7.0","platform":"Javascript/Node.js"},"owntracks":{"version":"0.5.0","platform":"Javascript/Node.js"},"js-controller":{"version":"1.4.2","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"dwd":{"version":"2.4.3","platform":"javascript/Node.js"},"telegram":{"version":"1.3.6","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"simple-api":{"version":"2.0.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"cloud":{"version":"2.6.2","platform":"Javascript/Node.js"},"mqtt-client":{"version":"1.1.1","platform":"Javascript/Node.js"},"rickshaw":{"version":"1.0.0","platform":"javascript/Node.js"},"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"alexa2":{"version":"1.1.3","platform":"Javascript/Node.js"},"iot":{"version":"0.2.2","platform":"Javascript/Node.js"},"scenes":{"version":"1.1.0","platform":"Javascript/Node.js"},"amazon-dash":{"version":"0.3.1","platform":"Javascript/Node.js"},"weatherunderground":{"version":"2.0.4","platform":"Javascript/Node.js"},"shelly":{"version":"2.0.8","platform":"Javascript/Node.js"},"plexconnect":{"version":"0.0.7","platform":"Javascript/Node.js"}},"model":"unknown","cpus":4,"mem":4196204544,"ostype":"Linux","city":"","vis":249}
    2019-02-25 19:56:04.180  - error: host.ioBroker-Rock64 instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:04.181  - info: host.ioBroker-Rock64 Restart adapter system.adapter.history.0 because enabled
    2019-02-25 19:56:04.893  - info: host.ioBroker-Rock64 instance system.adapter.socketio.0 started with pid 25539
    2019-02-25 19:56:05.870  - info: host.ioBroker-Rock64 instance system.adapter.vis.0 terminated while should be started once
    2019-02-25 19:56:07.395  - error: host.ioBroker-Rock64 instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:07.397  - info: host.ioBroker-Rock64 Restart adapter system.adapter.socketio.0 because enabled
    2019-02-25 19:56:07.523  - error: host.ioBroker-Rock64 instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:07.523  - info: host.ioBroker-Rock64 Restart adapter system.adapter.javascript.0 because enabled
    2019-02-25 19:56:08.890  - info: host.ioBroker-Rock64 instance scheduled system.adapter.ical.0 0,30 * * * *
    2019-02-25 19:56:08.924  - info: host.ioBroker-Rock64 instance system.adapter.ical.0 started with pid 25553
    2019-02-25 19:56:12.886  - info: host.ioBroker-Rock64 instance system.adapter.text2command.0 started with pid 25563
    2019-02-25 19:56:14.378  - error: host.ioBroker-Rock64 instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:14.379  - info: host.ioBroker-Rock64 Restart adapter system.adapter.text2command.0 because enabled
    2019-02-25 19:56:16.885  - info: host.ioBroker-Rock64 instance system.adapter.sayit.0 started with pid 25573
    2019-02-25 19:56:18.485  - error: host.ioBroker-Rock64 instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:18.486  - info: host.ioBroker-Rock64 Restart adapter system.adapter.sayit.0 because enabled
    2019-02-25 19:56:20.851  - error: host.ioBroker-Rock64 startInstance js-controller.0: cannot find start file!
    2019-02-25 19:56:21.265  - info: host.ioBroker-Rock64 instance system.adapter.admin.0 started with pid 25587
    2019-02-25 19:56:23.265  - info: host.ioBroker-Rock64 instance system.adapter.web.0 started with pid 25593
    2019-02-25 19:56:24.888  - info: host.ioBroker-Rock64 instance system.adapter.fritzbox.0 started with pid 25603
    2019-02-25 19:56:25.005  - error: host.ioBroker-Rock64 instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:25.006  - info: host.ioBroker-Rock64 Restart adapter system.adapter.admin.0 because enabled
    2019-02-25 19:56:25.845  - error: host.ioBroker-Rock64 instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:25.846  - info: host.ioBroker-Rock64 Restart adapter system.adapter.web.0 because enabled
    2019-02-25 19:56:26.451  - info: host.ioBroker-Rock64 instance system.adapter.ical.0 terminated with code 0 (OK)
    TypeError: Cannot read property 'debug' of undefined
        at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/main.js:130:17)
        at emitOne (events.js:116:13)
        at Adapter.emit (events.js:211:7)
        at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5033:18)
        at Object.onceWrapper (events.js:315:30)
        at process.emit (events.js:211:7)
        at process.exit (internal/process.js:146:15)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:780:25
        at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:236:17)
    2019-02-25 19:56:28.857  - info: host.ioBroker-Rock64 instance scheduled system.adapter.dwd.0 3 * * * *
    2019-02-25 19:56:28.905  - info: host.ioBroker-Rock64 instance system.adapter.dwd.0 started with pid 25617
    2019-02-25 19:56:32.476  - info: host.ioBroker-Rock64 instance system.adapter.dwd.0 terminated with code 0 (OK)
    2019-02-25 19:56:32.880  - info: host.ioBroker-Rock64 instance system.adapter.telegram.0 started with pid 25627
    2019-02-25 19:56:34.218  - info: host.ioBroker-Rock64 instance system.adapter.history.0 started with pid 25633
    2019-02-25 19:56:35.925  - error: host.ioBroker-Rock64 instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:35.926  - info: host.ioBroker-Rock64 Restart adapter system.adapter.history.0 because enabled
    Mon, 25 Feb 2019 18:56:36 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    In the future, you will have to enable it yourself.
    See Link Removed. at module.js:653:30
    2019-02-25 19:56:36.860  - info: host.ioBroker-Rock64 instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
    2019-02-25 19:56:36.895  - info: host.ioBroker-Rock64 instance system.adapter.tvspielfilm.0 started with pid 25643
    2019-02-25 19:56:37.115  - error: Caught by controller[0]: Mon, 25 Feb 2019 18:56:36 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    2019-02-25 19:56:37.116  - error: Caught by controller[0]: In the future, you will have to enable it yourself.
    2019-02-25 19:56:37.117  - error: Caught by controller[0]: See Link Removed. at module.js:653:30
    2019-02-25 19:56:37.118  - error: host.ioBroker-Rock64 instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:37.120  - info: host.ioBroker-Rock64 Restart adapter system.adapter.telegram.0 because enabled
    2019-02-25 19:56:37.432  - info: host.ioBroker-Rock64 instance system.adapter.socketio.0 started with pid 25653
    2019-02-25 19:56:37.564  - info: host.ioBroker-Rock64 instance system.adapter.javascript.0 started with pid 25659
    2019-02-25 19:56:38.163  - info: host.ioBroker-Rock64 instance system.adapter.telegram.0 started with pid 25665
    2019-02-25 19:56:39.910  - error: host.ioBroker-Rock64 instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:39.912  - info: host.ioBroker-Rock64 Restart adapter system.adapter.socketio.0 because enabled
    2019-02-25 19:56:40.894  - info: host.ioBroker-Rock64 instance system.adapter.simple-api.0 started with pid 25679
    Mon, 25 Feb 2019 18:56:42 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    2019-02-25 19:56:42.625  - error: host.ioBroker-Rock64 instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:42.626  - info: host.ioBroker-Rock64 Restart adapter system.adapter.javascript.0 because enabled
    2019-02-25 19:56:43.013  - error: host.ioBroker-Rock64 instance system.adapter.simple-api.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:43.014  - info: host.ioBroker-Rock64 Restart adapter system.adapter.simple-api.0 because enabled
    2019-02-25 19:56:44.412  - info: host.ioBroker-Rock64 instance system.adapter.text2command.0 started with pid 25697
    2019-02-25 19:56:44.887  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 started with pid 25703
    2019-02-25 19:56:46.073  - error: host.ioBroker-Rock64 instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:46.074  - info: host.ioBroker-Rock64 Restart adapter system.adapter.text2command.0 because enabled
    2019-02-25 19:56:46.651  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:46.652  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.0 because enabled
    2019-02-25 19:56:48.518  - info: host.ioBroker-Rock64 instance system.adapter.sayit.0 started with pid 25717
    2019-02-25 19:56:48.884  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 started with pid 25723
    2019-02-25 19:56:50.138  - error: host.ioBroker-Rock64 instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:50.139  - info: host.ioBroker-Rock64 Restart adapter system.adapter.sayit.0 because enabled
    2019-02-25 19:56:50.573  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:50.574  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.1 because enabled
    2019-02-25 19:56:52.884  - info: host.ioBroker-Rock64 instance system.adapter.samsung.0 started with pid 25737
    2019-02-25 19:56:54.545  - error: host.ioBroker-Rock64 instance system.adapter.samsung.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:54.546  - info: host.ioBroker-Rock64 Restart adapter system.adapter.samsung.0 because enabled
    2019-02-25 19:56:55.039  - info: host.ioBroker-Rock64 instance system.adapter.admin.0 started with pid 25747
    2019-02-25 19:56:55.882  - info: host.ioBroker-Rock64 instance system.adapter.web.0 started with pid 25753
    2019-02-25 19:56:56.902  - info: host.ioBroker-Rock64 instance system.adapter.hm-rega.0 started with pid 25759
    2019-02-25 19:56:58.354  - error: host.ioBroker-Rock64 instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:58.355  - info: host.ioBroker-Rock64 Restart adapter system.adapter.web.0 because enabled
    2019-02-25 19:56:58.567  - error: host.ioBroker-Rock64 instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:58.568  - info: host.ioBroker-Rock64 Restart adapter system.adapter.admin.0 because enabled
    2019-02-25 19:56:59.858  - error: host.ioBroker-Rock64 instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:56:59.859  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rega.0 because enabled
    2019-02-25 19:57:00.875  - info: host.ioBroker-Rock64 instance system.adapter.cloud.0 started with pid 25777
    2019-02-25 19:57:03.241  - error: host.ioBroker-Rock64 instance system.adapter.cloud.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:03.242  - info: host.ioBroker-Rock64 Restart adapter system.adapter.cloud.0 because enabled
    2019-02-25 19:57:04.873  - info: host.ioBroker-Rock64 instance system.adapter.alexa2.0 started with pid 25787
    2019-02-25 19:57:05.952  - info: host.ioBroker-Rock64 instance system.adapter.history.0 started with pid 25793
    2019-02-25 19:57:06.720  - error: host.ioBroker-Rock64 instance system.adapter.alexa2.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:06.721  - info: host.ioBroker-Rock64 Restart adapter system.adapter.alexa2.0 because enabled
    2019-02-25 19:57:07.486  - error: host.ioBroker-Rock64 instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:07.487  - info: host.ioBroker-Rock64 Restart adapter system.adapter.history.0 because enabled
    2019-02-25 19:57:08.873  - info: host.ioBroker-Rock64 instance system.adapter.iot.0 started with pid 25807
    2019-02-25 19:57:09.937  - info: host.ioBroker-Rock64 instance system.adapter.socketio.0 started with pid 25813
    2019-02-25 19:57:11.972  - error: host.ioBroker-Rock64 instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:11.973  - info: host.ioBroker-Rock64 Restart adapter system.adapter.socketio.0 because enabled
    2019-02-25 19:57:12.264  - error: host.ioBroker-Rock64 instance system.adapter.iot.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:12.265  - info: host.ioBroker-Rock64 Restart adapter system.adapter.iot.0 because enabled
    2019-02-25 19:57:12.647  - info: host.ioBroker-Rock64 instance system.adapter.javascript.0 started with pid 25827
    2019-02-25 19:57:12.874  - info: host.ioBroker-Rock64 instance system.adapter.scenes.0 started with pid 25833
    2019-02-25 19:57:13.042  - info: host.ioBroker-Rock64 instance system.adapter.simple-api.0 started with pid 25839
    2019-02-25 19:57:14.840  - error: host.ioBroker-Rock64 instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:14.841  - info: host.ioBroker-Rock64 Restart adapter system.adapter.scenes.0 because enabled
    2019-02-25 19:57:14.913  - error: host.ioBroker-Rock64 instance system.adapter.simple-api.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:14.914  - info: host.ioBroker-Rock64 Restart adapter system.adapter.simple-api.0 because enabled
    2019-02-25 19:57:16.099  - info: host.ioBroker-Rock64 instance system.adapter.text2command.0 started with pid 25853
    2019-02-25 19:57:16.678  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 started with pid 25859
    2019-02-25 19:57:16.851  - error: host.ioBroker-Rock64 instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:16.853  - info: host.ioBroker-Rock64 Restart adapter system.adapter.javascript.0 because enabled
    2019-02-25 19:57:16.879  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.2 started with pid 25869
    2019-02-25 19:57:17.926  - error: host.ioBroker-Rock64 instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:17.928  - info: host.ioBroker-Rock64 Restart adapter system.adapter.text2command.0 because enabled
    2019-02-25 19:57:18.584  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:18.585  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.0 because enabled
    2019-02-25 19:57:18.738  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.2 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:18.739  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.2 because enabled
    2019-02-25 19:57:20.161  - info: host.ioBroker-Rock64 instance system.adapter.sayit.0 started with pid 25887
    2019-02-25 19:57:20.598  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 started with pid 25893
    2019-02-25 19:57:20.864  - info: host.ioBroker-Rock64 instance scheduled system.adapter.weatherunderground.0 12 * * * *
    2019-02-25 19:57:21.772  - error: host.ioBroker-Rock64 instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:21.773  - info: host.ioBroker-Rock64 Restart adapter system.adapter.sayit.0 because enabled
    2019-02-25 19:57:22.301  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:22.302  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.1 because enabled
    2019-02-25 19:57:24.568  - info: host.ioBroker-Rock64 instance system.adapter.samsung.0 started with pid 25907
    2019-02-25 19:57:24.874  - info: host.ioBroker-Rock64 instance system.adapter.shelly.0 started with pid 25913
    2019-02-25 19:57:26.261  - error: host.ioBroker-Rock64 instance system.adapter.samsung.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:26.262  - info: host.ioBroker-Rock64 Restart adapter system.adapter.samsung.0 because enabled
    2019-02-25 19:57:26.848  - error: host.ioBroker-Rock64 instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:26.849  - info: host.ioBroker-Rock64 Restart adapter system.adapter.shelly.0 because enabled
    2019-02-25 19:57:28.377  - info: host.ioBroker-Rock64 instance system.adapter.web.0 started with pid 25931
    2019-02-25 19:57:28.592  - info: host.ioBroker-Rock64 instance system.adapter.admin.0 started with pid 25937
    2019-02-25 19:57:29.886  - info: host.ioBroker-Rock64 instance system.adapter.hm-rega.0 started with pid 25943
    2019-02-25 19:57:30.776  - error: host.ioBroker-Rock64 instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:30.777  - info: host.ioBroker-Rock64 Restart adapter system.adapter.web.0 because enabled
    2019-02-25 19:57:32.099  - error: host.ioBroker-Rock64 instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:32.103  - info: host.ioBroker-Rock64 Restart adapter system.adapter.admin.0 because enabled
    2019-02-25 19:57:32.480  - error: host.ioBroker-Rock64 instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:32.481  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rega.0 because enabled
    2019-02-25 19:57:33.264  - info: host.ioBroker-Rock64 instance system.adapter.cloud.0 started with pid 25961
    2019-02-25 19:57:35.456  - error: host.ioBroker-Rock64 instance system.adapter.cloud.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:35.457  - info: host.ioBroker-Rock64 Restart adapter system.adapter.cloud.0 because enabled
    2019-02-25 19:57:36.746  - info: host.ioBroker-Rock64 instance system.adapter.alexa2.0 started with pid 25971
    2019-02-25 19:57:37.512  - info: host.ioBroker-Rock64 instance system.adapter.history.0 started with pid 25977
    2019-02-25 19:57:38.516  - error: host.ioBroker-Rock64 instance system.adapter.alexa2.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:38.517  - info: host.ioBroker-Rock64 Restart adapter system.adapter.alexa2.0 because enabled
    2019-02-25 19:57:39.076  - error: host.ioBroker-Rock64 instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:39.077  - info: host.ioBroker-Rock64 Restart adapter system.adapter.history.0 because enabled
    2019-02-25 19:57:40.789  - info: host.ioBroker-Rock64 instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    2019-02-25 19:57:42.008  - info: host.ioBroker-Rock64 instance system.adapter.socketio.0 started with pid 25991
    2019-02-25 19:57:42.289  - info: host.ioBroker-Rock64 instance system.adapter.iot.0 started with pid 25997
    2019-02-25 19:57:44.134  - error: host.ioBroker-Rock64 instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:44.135  - info: host.ioBroker-Rock64 Restart adapter system.adapter.socketio.0 because enabled
    2019-02-25 19:57:44.869  - info: host.ioBroker-Rock64 instance system.adapter.scenes.0 started with pid 26007
    2019-02-25 19:57:44.939  - info: host.ioBroker-Rock64 instance system.adapter.simple-api.0 started with pid 26013
    2019-02-25 19:57:45.272  - error: host.ioBroker-Rock64 instance system.adapter.iot.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:45.274  - info: host.ioBroker-Rock64 Restart adapter system.adapter.iot.0 because enabled
    2019-02-25 19:57:46.560  - error: host.ioBroker-Rock64 instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:46.561  - info: host.ioBroker-Rock64 Restart adapter system.adapter.scenes.0 because enabled
    2019-02-25 19:57:46.601  - error: host.ioBroker-Rock64 instance system.adapter.simple-api.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:46.602  - info: host.ioBroker-Rock64 Restart adapter system.adapter.simple-api.0 because enabled
    2019-02-25 19:57:46.874  - info: host.ioBroker-Rock64 instance system.adapter.javascript.0 started with pid 26031
    2019-02-25 19:57:47.951  - info: host.ioBroker-Rock64 instance system.adapter.text2command.0 started with pid 26037
    2019-02-25 19:57:48.613  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 started with pid 26043
    2019-02-25 19:57:48.768  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.2 started with pid 26049
    2019-02-25 19:57:49.860  - error: host.ioBroker-Rock64 instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:49.862  - info: host.ioBroker-Rock64 Restart adapter system.adapter.text2command.0 because enabled
    2019-02-25 19:57:50.670  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:50.671  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.0 because enabled
    2019-02-25 19:57:50.831  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.2 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:50.832  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.2 because enabled
    2019-02-25 19:57:51.166  - error: host.ioBroker-Rock64 instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:51.166  - info: host.ioBroker-Rock64 Restart adapter system.adapter.javascript.0 because enabled
    2019-02-25 19:57:51.795  - info: host.ioBroker-Rock64 instance system.adapter.sayit.0 started with pid 26071
    2019-02-25 19:57:52.326  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 started with pid 26077
    2019-02-25 19:57:53.366  - error: host.ioBroker-Rock64 instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:53.367  - info: host.ioBroker-Rock64 Restart adapter system.adapter.sayit.0 because enabled
    2019-02-25 19:57:53.975  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    2019-02-25 19:57:53.976  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.1 because enabled
    2019-02-25 19:57:56.296  - info: host.ioBroker-Rock64 instance system.adapter.samsung.0 started with pid 26091
    Und dann geht es ewig so weiter.
    Dass das VIS Json nicht parsebar ist muss ich noch getrennt untersuchen. VIS läuf eigentlich.
    Gruss Ralf
    @derrapf sagte in IOBroker hat sich beendet:
    Naja, zumindest für die Frage wie zu stoppen/nach dem Status zu fragen ist.
    Da geht es immer noch mit (sudo) iobroker status
    kann aber da noch gewesen sein, dass das im Veruzeichnis /opt/iobroker ausgeführt werden muss
    ABER:
    Das ist ein so genannter "nightly build". Da sind eventuell Features drin, die noch nicht unbedingt stable sein müssen.
    • D derrapf
      @Homoran
      Gruss Ralf
      derrapf
      @derrapf
      Wo kommen denn diese "created this issue" unter "Gruss Ralf" her? Die hab ich nicht getippt...
      StabilostickS 1 Antwort Letzte Antwort
        derrapf
        schrieb am zuletzt editiert von derrapf
        Das Image hat jetzt wochenlang super funktioniert.
        Also an Deinem Image kann es nicht gelegen haben.
        Was ich gemacht habe war:
        Ich habe ein paar Scripte zum loggen von offenen Fenstern, Licht und zum Sammeln der IObroker Logs für VIS hinzugefügt. Speziell das Sammeln der IOBroker Logs für VIS hat den javascript Adapter auf 100% CPU gebracht. Deshalb hab ich das wieder disabled.
        Ich schmeiss die jetzt alle wieder weg,
        Ansonsten habe ich hm-rega und alexa.2 upgedatet. Der Absturz vom js-controller ist aber schon vor dem alexa.2 Update passiert.
        Beide Adapter haben Probleme beim Update gemacht. Man musste in beiden Adaptern die Dateien in den .../node_modules/.bin Verzeichnissen wegmoven, dann updaten und dann wieder zurückspielen. Ansonsten gab es jedes Mal Fehler vom npn, dass er auf die Dateien nicht zugreifen kann. Neue wurden aber auch nicht installiert. Also hab ich die Alten wieder zurück gemoved.
        Gruss Ralf
        • D derrapf
          @derrapf
          StabilostickS Offline
          Stabilostick
          schrieb am zuletzt editiert von Stabilostick
          @derrapf
          Das ist ein Forum-Feature, wo Infos aus einem Beitrag, die nach GitHub-Referenzen aussehen, entsprechende Infoblöcke unter dem Beitrag auslösen.
          Da braucht es ggf. noch Finetuning.
          • StabilostickS Stabilostick
            @derrapf
            derrapf
            @Stabilostick sagte in IOBroker hat sich beendet:
            @derrapf
            Ah Ok, Ich dachte schon ich seh Gespenster.
            • StabilostickS Offline
              Stabilostick
              Das steht in Deinem Logauszug:
              See https://github.com/yagop/node-telegram-bot-api/issues/319. at module.js:653:30
              Ist doch ganz praktisch, oder?
                derrapf
                Hi
                Jetzt sind die "Created issues" weg. Hast du was gemacht?
                Ich hab mal den Link aufgerufen aber nur relativ viel Bahnhof verstanden. Vor allem was das für "Versprechen" sind die da in use sind. Muss mich das issue interessieren? Kann das mit dem Absturz des js-controllers zu tun haben?
                Gruss Ralf
                  derrapf
                  Hier hab ich noch was gefunden. Weiss aber nicht ob das ein relevanter Fehler ist:
                  iot.0	2019-02-25 20:33:57.703	warn	Invalid URL key. Status update is disabled: {"error":"Unsupported version"}
                  iot.0	2019-02-25 20:33:57.701	error	Cannot report device state: null
                  Gruss Ralf
                  • D derrapf
                    Hi
                    Gruss Ralf
                    Stabilostick
                    @derrapf
                    Jay-Cee hat den Link in Deinem Log entfernt. Dann verschwinden auch die Boxen. An meinem Beispiel oben siehst Du, auf was die GitHub-Box triggert. Aber jetzt zurück zu Deinem eigentlichen Thema... 🤗
                      @derrapf
                      derrapf
                      @Stabilostick
                      Danke.
                      Also ich habe jetzt mal die Java-Scripts stillgelegt. Und zwar alle die ich aus dem Netz rauskopiert und eingefügt hatte. Das war einmal eines zum Aufbereiten der IOBroker Logs damit man die in VIS anzeigen kann, und eines das die Anzahl der offenen Fenster zählt bzw. auflistet.
                      Seit ich das gemacht habe (also vor knapp einer Woche) lief der IOBroker stabil.
                      Heute hab ich allerdings ein anderes Problem gehabt. Weiss aber nicht ob es da Zusammenhänge gibt: Alle Geräte in der Alexa App waren offline. Auch neu Suchen hat nicht funktioniert. Alles wegwerfen und neu suchen auch nicht. Musste komplett den Skill neu installieren. Sehr seltsam.
                      Ich hoffe jetzt mal, dass es wirklich nur rein an den Scripten lag. Jetzt schalte ich die mal nacheinander wieder ein. Mal sehen ob er dann wieder instabil wird.
                      Gruss Ralf
                        derrapf
                        Inzwischen hat sich der js-controller schon wieder beendet, ohne dass ich eines der Scripten wieder aktiviert hätte. Schade. Daran lag es wohl nicht.
                        Gibt es irgend eine Möglichkeit das Problem einzugrenzen? Ich sehe im Log nichts auffälliges. Und auch im Syslog nichts.
                        (also damit meine ich, dass ich als Linux Laie nichts sehe..)
                        Ich kann die Logs hier einstellen, aber ich müsste wissen welche für Euch interessant sind...
                        Gruss Ralf
                        • apollon77A Offline
                          Erster Anlaufpunkt ist immer das ioBroker Log. Wenn das nichts enthält und sich der ioBroker "einfach so" beednet ist /var/log/syslog der nächste Anlaufpunkt. Dort vor allem nach "oom" ausschau halten - wenn wenn das drin ist war der RAM voll
                          • apollon77A apollon77
                            derrapf
                            @apollon77 sagte in IOBroker hat sich beendet:
                            Nee "oom" kommt nirgends vor. Ich hab mal die beiden Logs gezippt.
                            iobroker logs.zip
                              Ich denke der schuldige Teil ist der hier:
                              Mar  4 02:15:14 localhost systemd[2008]: Stopped target Default.
                              Mar  4 02:15:14 localhost systemd[2008]: Stopped target Basic System.
                              Mar  4 02:15:14 localhost systemd[2008]: Stopped target Paths.
                              Mar  4 02:15:14 localhost systemd[2008]: Stopped target Timers.
                              Mar  4 02:15:14 localhost systemd[2008]: Stopped target Sockets.
                              Mar  4 02:15:14 localhost systemd[2008]: Closed GnuPG cryptographic agent (ssh-agent emulation).
                              Mar  4 02:15:14 localhost systemd[2008]: Closed GnuPG cryptographic agent and passphrase cache.
                              Mar  4 02:15:14 localhost systemd[2008]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
                              Mar  4 02:15:14 localhost systemd[2008]: Closed GnuPG cryptographic agent (access for web browsers).
                              Mar  4 02:15:14 localhost systemd[2008]: Closed GnuPG network certificate management daemon.
                              Mar  4 02:15:14 localhost systemd[2008]: Reached target Shutdown.
                              Mar  4 02:15:14 localhost systemd[2008]: Starting Exit the Session...
                              Mar  4 02:15:14 localhost systemd[2008]: Received SIGRTMIN+24 from PID 26362 (kill).
                              Mar  4 02:15:14 localhost systemd[1]: Stopped User Manager for UID 0.
                              Mar  4 02:15:14 localhost systemd[1]: Removed slice User Slice of root.
                              Kann es ein das Du ioBroker mal per root manuell per Shell gestartet hast? Aso da wurde der user root quasi final ausgeloggt ... und das hat wohl den ioBroker gekillt.
                              Was auch immer es war
                                derrapf
                                Ich verstehe nicht ganz was du genau meinst.
                                Ja, ich logge mich bisher immer mit root auf dem Rock64 ein. Einen anderen User gibt es da nicht.
                                Und Iobroker habe ich immer als root manuell gestartet, weil der automatische Start bis gestern nicht ging.
                                Was war da jetzt genau falsch dran?
                                Gruss Ralf
                                  ich sage nicht das da etwas "falsch" ist, fakt ist das 2:15 Uhr wo dein problem war genau im syslog zu sehen war das alle root-Prozesse gekillt wurden ... und das ist scheinbar Dein Problem irgendwie. So tief bin ich jetzt auch nicht fit in Linux und kann daher auch nur versuchen logs zu deuten.
                                  Jetzt mit Autostart sollte es ggf besser sein. Also beobachte es mal weiter.
                                    derrapf
                                    @apollon77
                                    Hi Apollon77
                                    Hmm... Ich bin zwar oft lang wach, aber explizit root prozesse habe ich nicht gekillt. IObroker fahre ich immer gesittet runter. Und zu dem Zeitpunkt als er ausgstiegen ist hab ich ziemlich sicher nachts nicht rumgedoktert.
                                    .. Halt. Idee:
                                    Ich habe einen Cron-Job laufen der nachts ein Backup macht. Augeblick, ich gucke....
                                    Kann es sein, dass ein Script zum Backuppen der SD-Karte hier vielleicht Ärger macht? Das wird um 2:15 Montags gestartet. Und der 4.März war ja ein Montag!
                                    Das sieht (noch aus Raspberry Zeiten) so aus:
                                    cd /opt/iobroker
                                    sudo iobroker stop
                                    sudo dd if=/dev/mmcblk0 of=/mnt/nas/backup/rock64_backup$NOW.img
                                    sudo iobroker start
                                      Ich bin mir nicht sicher ob dd ohne "unmound" des Dateisystems gehen kann ... wenn das so wäre dann ist es für mich auch erklärt :-)
                                        derrapf
                                        @apollon77
                                        Hi
                                        Ich kann aber das Dateisystem ja nicht unmounten. Schon gar nicht /mnt/nas weil das ist das Synology NAS auf das das Backup geht.
                                        Funktionieren tut irgendwas, denn da liegen lauter 32GB grosse *.img Dateien rum.
                                        Und ich fahre doch den IOBroker vorher runter und danach wieder hoch. Da dürfte doch nichts passieren, oder?
                                        Gruss Ralf
                                          Mapio90
                                          Hallo , ich habe dass problem dass ich seit dem stromausfall nicht mehr auf die weboberfläche komme und sich somit der iobroker verabschiedet hat?
                                          iobroker läuft auf einem Raspberry 3b+
                                          node -v = v10.15.3
                                          npm -v = 6.4.1
                                          wenn ich den befehl eingebe iobroker status , kommt folgendes:
                                          root@ioBroker-RasPi:/home/pi# iobroker status
                                          internal/modules/cjs/loader.js:584
                                          throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:582:15)
                                          at Function.Module._load (internal/modules/cjs/loader.js:508:25)
                                          at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
                                          at startup (internal/bootstrap/node.js:283:19)
                                          at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
