  4. JavaScript
  5. Daten aus einer Website mit Javascript
    6.0k
138 Beiträge 16 Kommentatoren 34.0k Aufrufe 5 Beobachtet
  • I Offline
    I Offline
    ioregistryexplorer
    leider bekomme ich es nicht hin. Kann mir hier jemand helfen? Installation habe ich exakt nach der Vorgabe gemacht, IP-Adresse wurde eingetragen etc.
    LOG zeigt:
    javascript.0 2018-11-30 16:31:07.483 warn at process._tickCallback (internal/process/next_tick.js:180:9)
    javascript.0 2018-11-30 16:31:07.483 warn at _combinedTickCallback (internal/process/next_tick.js:138:11)
    javascript.0 2018-11-30 16:31:07.483 warn at endReadableNT (_stream_readable.js:1064:12)
    javascript.0 2018-11-30 16:31:07.482 warn at IncomingMessage.emit (events.js:208:7)
    javascript.0 2018-11-30 16:31:07.482 warn at emitNone (events.js:111:20)
    javascript.0 2018-11-30 16:31:07.482 warn at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:447:13)
    javascript.0 2018-11-30 16:31:07.481 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:610:14)
    javascript.0 2018-11-30 16:31:07.481 warn at exports.XMLHttpRequest.dispatchEvent (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:591:25)
    javascript.0 2018-11-30 16:31:07.480 warn at exports.XMLHttpRequest.Interval.xhr.onreadystatechange (script.js.Datenholen:74:33)
    javascript.0 2018-11-30 16:31:07.478 warn State "Messwerte.0.SC18.Allgemein.D_C_4_1" not found
    javascript.0 2018-11-30 16:31:07.477 warn at process._tickCallback (internal/process/next_tick.js:180:9)
    javascript.0 2018-11-30 16:31:07.477 warn at _combinedTickCallback (internal/process/next_tick.js:138:11)
    javascript.0 2018-11-30 16:31:07.477 warn at endReadableNT (_stream_readable.js:1064:12)
    javascript.0 2018-11-30 16:31:07.476 warn at IncomingMessage.emit (events.js:208:7)
    javascript.0 2018-11-30 16:31:07.476 warn at emitNone (events.js:111:20)
    javascript.0 2018-11-30 16:31:07.476 warn at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:447:13)
    javascript.0 2018-11-30 16:31:07.475 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:610:14)
    javascript.0 2018-11-30 16:31:07.475 warn at exports.XMLHttpRequest.dispatchEvent (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:591:25)
    javascript.0 2018-11-30 16:31:07.474 warn at exports.XMLHttpRequest.Interval.xhr.onreadystatechange (script.js.Datenholen:72:33)
    javascript.0 2018-11-30 16:31:07.472 warn Wrong type of Messwerte.0.SC18.Allgemein.D_C_5_2: "string". Please fix, while deprecated and will not work in next versions.
    javascript.0 2018-11-30 16:31:05.055 info script.js.Datenholen: Request 2 ausgeführt
    javascript.0 2018-11-30 16:31:02.050 info script.js.Datenholen: Request 1 ausgeführt
    javascript.0 2018-11-30 16:30:59.045 info script.js.Datenholen: Request 5 ausgeführt
    javascript.0 2018-11-30 16:30:56.041 info script.js.Datenholen: Request 4 ausgeführt
    javascript.0 2018-11-30 16:30:53.039 info script.js.Datenholen: Request 3 ausgeführt</anonymous></anonymous>
      Breiti1234
      laufen beide Scripte bei dir?
      Stop mal das Statemaschine Script…
        Tom63
        Hallo Fangemeinde vom IO-Broker,
        ich bin seit 5 Tagen auch endlich glücklicher Besitzer eines Raspberry und habe mich dank des guten Image sofort für den IO-Broker als Smarthome Projekt entschieden. Neben dem PI-Hole läuft derzeit aktiv nur der IO-Broker.
        Ich habe auch eine SC18 Enthärtung, die ja per App viel zu sagen hat, aber eben sehr kryptisch.
        Zunächst ein Dank an diesen Beitrag, ich habe es in kurzer Zeit ohne besondere Vorkenntnisse zum Laufen bekommen. :D
        Durch meine derzeit aktuelle Version vom IO-Broker (3.5.10) sind die hier hinterlegten Bilder auch schon wieder veraltet,
        z.B. Javascribt Ablageverzeichnis.
        Ich habe die Scribts derzeit ins Root-Verzeichnis gespeichert, da ich das Verzeichnis Global oder Common als falsch erachtet habe.
        Weiterhin habe ich es so verstanden, dass im Scribt 1 eigentlich nur einmalig die Datenfelder wie im Bild 3 dargestellt angelegt werden.
        Somit muss dieses Scribt nur einmal ausgeführt werden. Richtig ?
        Mit dem Logger werden jetzt die Daten permanent befüllt, die aus der SC18 entnommern werden.
        Somit liest er fortlaufend die aktuellen Anlagedaten in den Parser.
        Wichtig zu erwähnen für alle Anfänger (wie mich) -im Scribt 2 in der Zeile 15 ist die IP-Adresse der eigenen Anlage fest einzutragen
        ( Keine Constante im Kopf des Scribt festgelegt).
        Meine Anlage wird ab sofort ausgelesen und ich bin echt begeistert, wie schnell ich meine ersten Lösungen im IO-Broker dank Euch fertig habe.!
        Besten Dank - nun nur noch die Visualisierung und die 2. VIS ist nach dem tankerkönig online.
        Zusätzlich bin ich beim Überlegen die Messwerte z.B. für Verbrauch als Metadaten auch in den SQL-Server zu schreiben und dort zu archivieren.
        Wie schreiben uns weiter !
        Technik kann auch Funktionieren ohne Cloud ;)
        • F Offline
          f0rd42
          Kurze Frage zum Wasserverbrauch.
          Ist der nicht eigentlich pauschal falsch dadurch dass es ja immer einen Verschnitt gibt der nicht gemessen wird?
          Eigentlich müsste man also z.b 10 Liter Zapfen und dann sehen was die Anlage anzeigt und daraus einen Multiplikator berechnen oder habe ich hier einen Denkfehler?
          • F Offline
            f0rd42
            noch etwas (unabhängig von der Frage nach dem Wasserverbrauch oben):
            Ich bekomme beim Request 2 immer folgende Fehlermeldung:
            javascript.0	2019-01-12 19:07:56.092	info	script.js.Gruenbeck_Logger: Request 5 ausgeführt
            javascript.0	2019-01-12 19:07:53.088	info	script.js.Gruenbeck_Logger: Request 4 ausgeführt
            javascript.0	2019-01-12 19:07:50.087	info	script.js.Gruenbeck_Logger: Request 3 ausgeführt
            javascript.0	2019-01-12 19:07:49.617	warn	at process._tickCallback (internal/process/next_tick.js:181:9)
            javascript.0	2019-01-12 19:07:49.617	warn	at _combinedTickCallback (internal/process/next_tick.js:139:11)
            javascript.0	2019-01-12 19:07:49.617	warn	at endReadableNT (_stream_readable.js:1064:12)
            javascript.0	2019-01-12 19:07:49.617	warn	at IncomingMessage.emit (events.js:208:7)
            javascript.0	2019-01-12 19:07:49.617	warn	at emitNone (events.js:111:20)
            javascript.0	2019-01-12 19:07:49.616	warn	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:447:13)
            javascript.0	2019-01-12 19:07:49.616	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:610:14)
            javascript.0	2019-01-12 19:07:49.616	warn	at exports.XMLHttpRequest.dispatchEvent (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:591:25)
            javascript.0	2019-01-12 19:07:49.616	warn	at exports.XMLHttpRequest.Interval.xhr.onreadystatechange (script.js.Gruenbeck_Logger:74:33)
            javascript.0	2019-01-12 19:07:49.616	warn	State "Messwerte.0.SC18.Allgemein.D_C_4_1" not found
            javascript.0	2019-01-12 19:07:49.615	warn	at process._tickCallback (internal/process/next_tick.js:181:9)
            javascript.0	2019-01-12 19:07:49.615	warn	at _combinedTickCallback (internal/process/next_tick.js:139:11)
            javascript.0	2019-01-12 19:07:49.615	warn	at endReadableNT (_stream_readable.js:1064:12)
            javascript.0	2019-01-12 19:07:49.615	warn	at IncomingMessage.emit (events.js:208:7)
            javascript.0	2019-01-12 19:07:49.615	warn	at emitNone (events.js:111:20)
            javascript.0	2019-01-12 19:07:49.614	warn	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:447:13)
            javascript.0	2019-01-12 19:07:49.614	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:610:14)
            javascript.0	2019-01-12 19:07:49.614	warn	at exports.XMLHttpRequest.dispatchEvent (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:591:25)
            javascript.0	2019-01-12 19:07:49.614	warn	at exports.XMLHttpRequest.Interval.xhr.onreadystatechange (script.js.Gruenbeck_Logger:72:33)
            javascript.0	2019-01-12 19:07:49.613	warn	Wrong type of Messwerte.0.SC18.Allgemein.D_C_5_2: "string". Please fix, while deprecated and will not work in next versions.
            javascript.0	2019-01-12 19:07:47.083	info	script.js.Gruenbeck_Logger: Request 2 ausgeführt
            javascript.0	2019-01-12 19:07:44.082	info	script.js.Gruenbeck_Logger: Request 1 ausgeführt</anonymous></anonymous>
            und ab und zu (relativ oft) bekomme ich noch bei den unterschiedlichsten Requests:
            javascript.0	2019-01-12 19:07:32.076	error	at Timer.listOnTimeout (timers.js:290:5)
            javascript.0	2019-01-12 19:07:32.075	error	at tryOnTimeout (timers.js:323:5)
            javascript.0	2019-01-12 19:07:32.075	error	at ontimeout (timers.js:511:34)
            javascript.0	2019-01-12 19:07:32.075	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1762:34)
            javascript.0	2019-01-12 19:07:32.075	error	at Object.Interval (script.js.Gruenbeck_Logger:16:5)
            javascript.0	2019-01-12 19:07:32.075	error	at exports.XMLHttpRequest.setRequestHeader (/opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:201:13)
            javascript.0	2019-01-12 19:07:32.075	error	Error in callback: Error: INVALID_STATE_ERR: send flag is true
            javascript.0	2019-01-12 19:07:29.074	info	script.js.Gruenbeck_Logger: Request 3 ausgeführt
            javascript.0	2019-01-12 19:07:26.071	info	script.js.Gruenbeck_Logger: Request 3 ausgeführt
            was muss / sollte ich hier noch anpassen?
            Das Script liesst ja auch die "Uhrzeit" aus, aber die ist ja mal füllig von der rolle. Ich habe aber auch in der SC18 nirgends eine Möglichkeit gefunden einen Uhrzeit einzustellen.. Ist das bei Euch auch so?
              Tom63
              Hallo SC18 Nutzer,
              hier mal ein praktischer Ansatz. Ich habe eine SC18 von Grünbeck seit einem jahr im Einsatz.
              Dank des hier im Forum sehr gut beschriebenen Js-Scribt liest der IO-Broker jetzt permanent meinen aktuellen Status aus.
              Mit ein wenig Mathematik lässt sich sogar die Verbrauchsanzeige in Liter/Minute darstellen.
              Mein aktuelles Vis sieht so aus:
              Die Felder aus den Messdaten im VIS-Editor einbinden ist simpel.
              Es gibt aber einen Multiplikator in den erweiterten Einstellungen.
              Damit kannst du dann die Restkapazität der Anlage in Liter zumindest annähernd anzeigen lassen.
              Das Scribt ist auch so schnell, dass innerhalb von wenigen Sekunden der aktuelle Verbrauch gleich unten auf der VIS-Seite angezeigt wird.
              Z.B. bei der WC-Spülung sieht man sehr schön den Durchfluss oder wenn die Waschmaschine läuft.
              Ich habe auch den letzten Time-Stempel dafür extra eingebaut.
              Bitte stellt Eure Anlage zumindest auf Regenarationszeitpunkt Fest ein.
              Nur so kann auch die Uhrzeit in der Anlage per App gestellt werden. (warum holt die sich das nicht vom Router ? :roll:
              Wen es variable bleibt, wird es amlaufenden Tag gemacht.
              Diese Brühe sorgt dann für die Ablagerungen auf den Armaturen, die sich sehr hartnäckig gegen Reiniger wehren können !!!
              Deshalb unbedingt die Regeneration auf Fest einstellen.
              • H Offline
                hiasii12
                ich habe das Script nochmals überarbeitet.
                Alles was zum einstellen ist ist jetzt in den ersten Zeilen zu finden.
                Es hat jetzt eine Verbindungsüberwachung integriert und die Aktualisierungszeit ist auch einstellbar.
                Es sollten diejenigen die Fehlermeldungen bekommen die Aktualisierungsrate verringern.
                Post auf Seite 1 wurde aktualisiert.
                Ist es möglich das diejenigen die so schöne Widgets erstellt haben diese für alle zur Verfügung stellen?
                • F Offline
                  f0rd42
                  @hiasii12:
                  Ist es möglich das diejenigen die so schöne Widgets erstellt haben diese für alle zur Verfügung stellen? `
                  Hi
                  nun sind bei mir auch die Fehler scheinbar weg. Danke!
                  Eine Frage noch:
                  Die Werte D_Y_4_xx haben einen "Namen" von "Prozentsatz Regeneration 1vor aktueller". Abgesehen von dem Fehlenden Leerzeichen zwischen der Zahl und dem Wort "vor" bekomme ich hier als Werte allerdings Stunden / Minuten angezeigt ??!?!?!?!
                    ArnoD
                    @f0rd42:
                    Hi
                    Eine Frage noch:
                    Die Werte D_Y_4_xx haben einen "Namen" von "Prozentsatz Regeneration 1vor aktueller". Abgesehen von dem Fehlenden Leerzeichen zwischen der Zahl und dem Wort "vor" bekomme ich hier als Werte allerdings Stunden / Minuten angezeigt ??!?!?!?! `
                    Ja, da ist noch ein Fehler enthalten.
                    D_Y_4_xx ist die Zeit von Regeneration zu Regeneration und D_A_3_2_xx sollte die Prozentangabe der Regeneration sein.
                    Du kanns entweder den Text ändern oder das Script anpassen.
                      ArnoD
                      Erst mal danke an alle für das Script und die Anleitung.
                      Habe auch als Laie, was Java Script angeht, alles soweit hinbekommen.
                      Weiss jemand wie man eine manuelle Regeneration über IO Brocker auslösen kann ?
                        ArnoD
                        Für alle die was kopieren wollen habe mein View Gruenbeck eingefügt :D
                        10332_21_gruenbeck.txt
                          ArnoD
                          Ich hatte heute etwas Zeit um mich mit dem Thema zu beschäftigen. :D
                          Ich habe die Enthärtungsanlage softliQ:SC18 und bei mir erhalte ich
                          bei folgenden Abfragen keine vernüftige Rückmeldungen:
                          D_C_5_2 Datum (kein Wert)
                          D_C_5_3 Sommer/Winterzeit (kein Wert)
                          D_Y_13 wird bei mir Wert 0 angezeigt was nach der Austauscher gestört bedeutet, obwohl keine Störung vorliegt.
                          D_A_3_2_1-14 wird bei allen Werten nur der Prozentsatz der letzten Regeneration angezeigt und nicht der letzten 14 Regenerationen
                          D-A-3_1 sollte nach der Schnittstellenbeschreibung ein String sein (TT.MM.JJJ HH:MM) ist aber die Zeit der letzten Regeneration in h
                          Meine Frage ist, ob das bei allen so ist, oder jemand mit der SC18 da was Sinnvolles angezeigt bekommt ?
                          • H Offline
                            hiasii12
                            => Anfrage liefert keinen Wert => Wert ist aber eigentlich auch uninteressant => wurde entfernt
                            => Da hast du eigentlich recht. Ist bei meiner Anlage auch so. Nicht gestört oder in Regeneration und 0 :shock:
                            D_A_3_2_1-14
                            => Auch hier hast du recht. Ist bei meiner Anlage auch so. :shock:
                            D_A_3_1
                            Ich habe das Script nochmals überarbeitet.
                            siehe Seite 1
                            6543_gruenbeck_webserver_dokumentation.pdf
                            • F Offline
                              f0rd42
                              Ich muss nochmals meine Frage zum Wasserverbrauch aufgreifen.
                              Da die meisten mit einem Verschnitt arbeiten (wer will schon eine Härte von 0), muss der Wasserverbrauch doch berechnet werden, da ein Teil des Wassers ja an der Anlage vorbei geht, oder sehe ich das hier komplett falsch?
                                ArnoD
                                Die Anzeige des momentanen Verbrauchs bezieht sich auf das 0°dH Wasser welches durch die Anlage selber geht . Um den realen Durchfluss zuhaben, müsstest du den prozentualen Verschnitt über das Verschneide Ventil mit dazu rechnen.
                                  ArnoD
                                  Vielleicht noch ein paar hinweiße zur Erklärung der Kapazitätszahl (Anlagenkapazität), die ich im Haustechnik Dialog Forum, gefunden habe.
                                  Die Kapazitätszahl errechnet sich durch den Durchschnittsverbrauch 0 °dH Wasser der drei letzten Tage, ohne Verschnittwasser
                                  mal je nach Modus Eco 1,3 und Power 1,8 mal Grundhärte.
                                  Berechnung der automatischen Einstellung der Anlagenkapazität
                                  = Wasser Durchschnittverbrauch x (1,3 Eco, oder 1,8 Power) x Grundhärte
                                  Kleines Beispiel:
                                  Verbrauch vor 1 Tag 323 l, vor 2 Tagen 292 l, vor 3 Tagen 282 l, Einstellung Power Modus, Grundwasserhärte 21 °dH
                                  323+292+282 = 897 l /3 = 299 l Wasser Durchnittsverbrauch
                                  299 l x 1,8 (Power Modus) = 538,2 l x 21 °dH = 11,30 qm x °dH
                                  Hier noch ein paar Berechnungen, die interessant sind:
                                  1. Berechnung Restkapazität (max)
                                  = Anlagenkapazität / Grundhärte
                                  1. Berechnung max. Verschnittwassermenge (Grundhärtewasser und SC18-Wasser)
                                  = Anlagenkapazität / (Grundhärte - Schnitthärte)
                                    ArnoD
                                    hiasii12 kannst du das Script noch etwas optimieren ?? :D ;)
                                    In der Schnittstellenbeschreibung steht "Um die Schnittstelle zuverlässig betreiben zu können, sollte der Abstand zweier Anfragen eine Zeit
                                    von 15 Sekunden zueinander nicht unterschreiten."
                                    Das konnte ich bereits auch feststellen, da ich bei weniger als 15 sek. keine Einstellungen mehr mit der Grünbeck APP verändern konnte.
                                    Ich würde gerne alle Werte in ein Paket packen und alle 15 sek. abfragen, nicht wie jetzt über drei Abfragen verteilt.
                                    Die Werte für Wasserverbrauch D_Y_2_xx und Zeit letzte Regeneration D_Y_4_xx würden einmal am Tag ausreichen, da sich ja nichts ändert.
                                    (z.B. immer um 1:00 Uhr in der Nacht)
                                    Würde es ja selber machen, aber bei der Aufgabe, Werte nur einmal am Tag abfragen, scheitere ich mit meinen Scriptkenntnissen. :?
                                    So sieht mein View jetzt aus :D
                                    Ach ja, wenn jetzt noch jemand weiss wie mann eine manuelle Regeneration über Vis auslösen kann, währe ich happy :mrgreen:
                                      Marc_P
                                      vielleicht kann mir jemand helfen. Ich habe das Problem, dass das Logger-Script nicht läuft.
                                      Die Datenpunkte wurden durch das erste Script erstellt.
                                      Wenn ich das Logger-Script starte kommt die Fehlermeldung:
                                      javascript.0	2019-02-11 16:40:47.957	error	Error in callback: Error: INVALID_STATE_ERR: send flag is true
                                      und
                                      error	javascript.0 at Object.Interval (script.js.gruenbeck_logger:28:9)
                                      Hat er ein Problem mit der function Interval?
                                      Hier noch mein komplettes Script:
                                      // Logger
                                          // Wichtige Daten hier anpassen
                                          // V1.0: Erstellung
                                          // V1.1: Header mit Konstanten hinzu;
                                          // Verbindungsüberwachung hinzu;
                                          // V1.2: Datum auslesen entfernt
                                          // Sommer/Winterzeit auslesen entfernt
                                          // Hier IP Adresse der Anlage eintragen
                                          var constIP = "192.168.10.31"
                                          // Hier Namen der State Variable eintragen wenn Verbindung über Ping Adapter geprüft werden soll
                                          // Wenn kein Ping Adapter verwendet werden soll dan True eintragen
                                          var statePingAdapter = 'ping.0.iobroker.192_168_10_31'
                                          // Hier Abfragezyklus in Sekunden eintragen
                                          var constTick = 5
                                          var XMLHttpRequest = require("xmlhttprequest").XMLHttpRequest;
                                          var parser = require('xmldom').DOMParser;
                                          var xhr = new XMLHttpRequest();
                                          var requestNumber = 1 ;
                                          xhr.onload = function () { };
                                          xhr.onerror = function () { };
                                          var varInterval = setInterval(Interval, constTick * 1000 );
                                          function Interval() {
                                          var connection = getState(statePingAdapter)
                                          // console.log(connection.val);
                                          if (connection.val)
                                          xhr.open("POST","http://" + constIP + "/mux_http");
                                          xhr.setRequestHeader("Content-type", "application/json");
                                          xhr.responseType = "document";
                                          switch(requestNumber) {
                                          case 1:
                                          //console.log('Request ' + requestNumber + ' ausgeführt');
                                          xhr.send("id=8871&show=D_Y_2_1|D_Y_2_2|D_Y_2_3|D_Y_2_4|D_Y_2_5|D_Y_2_6|D_Y_2_7|D_Y_2_8|D_Y_2_9|D_Y_2_10|D_Y_2_11|D_Y_2_12|D_Y_2_13|D_Y_2_14~");
                                          xhr.onreadystatechange = function()
                                          if (xhr.readyState==4)
                                          if (xhr.status == 200)
                                          if (xhr.responseText)
                                          var str = xhr.responseText;
                                       const regex = /<data>`([^\<]+)<\/code><d_y_2_1>([^\<]+)<\/D_Y_2_1><d_y_2_2>([^\<]+)<\/D_Y_2_2><d_y_2_3>([^\<]+)<\/D_Y_2_3><d_y_2_4>([^\<]+)<\/D_Y_2_4><d_y_2_5>([^\<]+)<\/D_Y_2_5><d_y_2_6>([^\<]+)<\/D_Y_2_6><d_y_2_7>([^\<]+)<\/D_Y_2_7><d_y_2_8>([^\<]+)<\/D_Y_2_8><d_y_2_9>([^\<]+)<\/D_Y_2_9><d_y_2_10>([^\<]+)<\/D_Y_2_10><d_y_2_11>([^\<]+)<\/D_Y_2_11><d_y_2_12>([^\<]+)<\/D_Y_2_12><d_y_2_13>([^\<]+)<\/D_Y_2_13><d_y_2_14>([^\<]+)<\/D_Y_2_14><\/data>/;
                                                      const subst = regex.exec(str);
                                                          if (subst)
                                                              for ( i = 1; i < 15; i++ ) {
        i1 = i + 1;
        if (i < 10)
        setState("Messwerte.0.SC18.Wasserverbrauch.D_Y_2_0" + i , parseInt(subst[i1]) );
        else
        setState("Messwerte.0.SC18.Wasserverbrauch.D_Y_2_" + i , parseInt(subst[i1]) );
                                                          requestNumber = 2;
                                      break;
                                      case 2:
                                      xhr.send("id=8871&show=D_C_4_1|D_C_4_2|D_C_4_3|D_C_5_1|D_C_7_1~");
                                                      const regex = /<data>`([^\<]+)<\/code><d_c_4_1>([^\<]+)<\/D_C_4_1><d_c_4_2>([^\<]+)<\/D_C_4_2><d_c_4_3>([^\<]+)<\/D_C_4_3><d_c_5_1>([^\<]+)<\/D_C_5_1><d_c_7_1>([^\<]+)<\/D_C_7_1><\/data>/;
                                                          if (subst)
        setState("Messwerte.0.SC18.Allgemein.D_C_4_1" , parseInt(subst[2]) );
        setState("Messwerte.0.SC18.Allgemein.D_C_4_2" , subst[3] );
        setState("Messwerte.0.SC18.Allgemein.D_C_4_3" , subst[4] );
        setState("Messwerte.0.SC18.Allgemein.D_C_5_1" , parseInt(subst[5]) );
        setState("Messwerte.0.SC18.Allgemein.D_C_7_1" , parseInt(subst[6]) );
                                                          requestNumber = 3;
                                      break;
                                      case 3:
                                      xhr.send("id=8871&show=D_Y_4_1|D_Y_4_2|D_Y_4_3|D_Y_4_4|D_Y_4_5|D_Y_4_6|D_Y_4_7|D_Y_4_8|D_Y_4_9|D_Y_4_10|D_Y_4_11|D_Y_4_12|D_Y_4_13|D_Y_4_14~");
                                                      const regex = /<data>`([^\<]+)<\/code><d_y_4_1>([^\<]+)<\/D_Y_4_1><d_y_4_2>([^\<]+)<\/D_Y_4_2><d_y_4_3>([^\<]+)<\/D_Y_4_3><d_y_4_4>([^\<]+)<\/D_Y_4_4><d_y_4_5>([^\<]+)<\/D_Y_4_5><d_y_4_6>([^\<]+)<\/D_Y_4_6><d_y_4_7>([^\<]+)<\/D_Y_4_7><d_y_4_8>([^\<]+)<\/D_Y_4_8><d_y_4_9>([^\<]+)<\/D_Y_4_9><d_y_4_10>([^\<]+)<\/D_Y_4_10><d_y_4_11>([^\<]+)<\/D_Y_4_11><d_y_4_12>([^\<]+)<\/D_Y_4_12><d_y_4_13>([^\<]+)<\/D_Y_4_13><d_y_4_14>([^\<]+)<\/D_Y_4_14><\/data>/;
                                                          if (subst)
        i1 = i + 1;
        if (i < 10)
        setState("Messwerte.0.SC18.Regenerationen.D_Y_4_0" + i , subst[i1] );
        else
        setState("Messwerte.0.SC18.Regenerationen.D_Y_4_" + i , subst[i1] );
                                                          requestNumber = 4;
                                      break;
                                      case 4:
                                      xhr.send("id=8871&show=D_Y_5|D_Y_7|D_Y_8_11|D_Y_10_1|D_Y_13|D_Y_14|D_B_1|D_C_5_1~");
                                                      const regex = /<data>`([^\<]+)<\/code><d_y_5>([^\<]+)<\/D_Y_5><d_y_7>([^\<]+)<\/D_Y_7><d_y_8_11>([^\<]+)<\/D_Y_8_11><d_y_10_1>([^\<]+)<\/D_Y_10_1><d_y_13>([^\<]+)<\/D_Y_13><d_y_14>([^\<]+)<\/D_Y_14><d_b_1>([^\<]+)<\/D_B_1><d_c_5_1>([^\<]+)<\/D_C_5_1><\/data>/;
                                                          if (subst)
        setState("Messwerte.0.SC18.Allgemein.D_Y_5" , parseInt(subst[2]) );
        setState("Messwerte.0.SC18.Allgemein.D_Y_7" , subst[3] );
        setState("Messwerte.0.SC18.Allgemein.D_Y_8_11" , parseInt(subst[4]) );
        setState("Messwerte.0.SC18.Allgemein.D_Y_10_1" , parseInt(subst[5]) );
        setState("Messwerte.0.SC18.Allgemein.D_Y_13" , parseInt(subst[6]) );
        setState("Messwerte.0.SC18.Allgemein.D_Y_14" , subst[7] );
        setState("Messwerte.0.SC18.Allgemein.D_B_1" , parseInt(subst[8]) );
        setState("Messwerte.0.SC18.Allgemein.D_C_5_1" , parseInt(subst[9]) );
                                                          requestNumber = 5;
                                      break;
                                      case 5:
                                      xhr.send("id=8871&show=D_A_1_1|D_A_1_2|D_A_1_3|D_A_2_1|D_A_3_1|D_A_3_2~");
                                                      const regex = /<data>`([^\<]+)<\/code><d_a_1_1>([^\<]+)<\/D_A_1_1><d_a_1_2>([^\<]+)<\/D_A_1_2><d_a_1_3>([^\<]+)<\/D_A_1_3><d_a_2_1>([^\<]+)<\/D_A_2_1><d_a_3_1>([^\<]+)<\/D_A_3_1><d_a_3_2>([^\<]+)<\/D_A_3_2><\/data>/;
                                                          if (subst)
        setState("Messwerte.0.SC18.Aktualwerte.D_A_1_1" , parseFloat(subst[2]) );
        setState("Messwerte.0.SC18.Aktualwerte.D_A_1_2" , parseFloat(subst[3]) );
        setState("Messwerte.0.SC18.Aktualwerte.D_A_1_3" , parseFloat(subst[4]) );
        setState("Messwerte.0.SC18.Aktualwerte.D_A_2_1" , parseInt(subst[5]) );
        setState("Messwerte.0.SC18.Aktualwerte.D_A_3_1" , subst[6] );
        setState("Messwerte.0.SC18.Aktualwerte.D_A_3_2" , parseInt(subst[7]) );
                                                          requestNumber = 1;
                                      Auch ist mir die folgende Zeile im Original-Script nicht ganz klar:
                                      var statePingAdapter = 'ping.0.matthias-SS15HT.192_168_0_132'/192 168 0 132/
                                      gehört das /192 168 0 132/ mit dazu oder ist das ein Kommentar?
                                      Wenn ich das mit reinschreibe, gibt es ein compile error.
                                      Marc
                                        Marc_P
                                        So, der Fehler ist, warum auch immer, verschwunden?!
                                        Allerdings werden keine Daten in die Objekte geschrieben.
                                        Ich habe mit console.Log das Script im Betrieb mal überprüft:
                                        • console.Log(xhr.responseText) enthält die Daten, die mit xhr.send angefragt wurden
                                        • console.Log(subst) hat aber den Inhalt null. Es scheint so, dass das regex nicht richtig funktioniert oder sehe ich das falsch?
                                        Wenn ich es auf der Seite regex101.com wie folgt teste, gibt es keine Übereinstimmung:
                                        REGULAR EXPRESSION
                                        TEST STRING
                                        <data><code>ok</code><D_C_4_1>1</D_C_4_1><D_C_4_2>13:10</D_C_4_2><D_C_4_3>02:00</D_C_4_3><D_C_5_1>0</D_C_5_1><D_C_7_1>365</D_C_7_1></data>
                                        Könnte hier jemand sein Logger-Script einstellen, was bei ihm funktioniert?
                                        Ich habe es von hier kopiert, aber durch den Seitenumzug ist ja, wie man ganz oben sieht, alles zerschossen und ich bin mir nicht sicher ob mein Script soweit i.O. ist bzw. ob ich es richtig kopiert habe.☹
                                        Marc
                                          Marc_P
                                          schrieb am zuletzt editiert von Marc_P
                                          So, Problem gefunden.
                                          Durch die Forenumstellung sind die 2 Skripte oben unbrauchbar.
                                          Hier die 2, die bei mir jetzt einwandfrei laufen:
                                          statemachine
                                          // StateMaschine
                                              var i
                                              // Wasserverbrauch
                                              var path = 'Messwerte.0.SC18.Wasserverbrauch.';
                                              if (i<10)var id = path + 'D_Y_2_0' + i;
                                              else var id = path + 'D_Y_2_' + i ;
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Wasserverbrauch vor ' + i + ' Tagen' ;
                                              obj.common.type = 'number';
                                              obj.common.role = 'number';
                                              obj.common.desc = 'Wasserverbrauch vor ' + i + ' Tagen';
                                              obj.common.read = true;
                                              obj.common.write = true;
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = 'Liter';
                                          setObject(id, obj, function(err) {
                                              if(err) log('Cannot write object: ' + err);
                                              else setState(id, obj.common.def);
                                              // Regenerationen
                                              var path = 'Messwerte.0.SC18.Regenerationen.';
                                          if (i<10)var id = path + 'D_Y_4_0' + i;
                                          else var id = path + 'D_Y_4_' + i ;
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Zeitpunkt Regenereation ' + i + ' vor aktueller';
                                              obj.common.type = 'string';
                                              obj.common.role = 'string';
                                              obj.common.desc = 'Zeitpunkt Regenereation ' + i + ' vor aktueller';
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = '';
                                          // Allgemeine Felder
                                          var path = 'Messwerte.0.SC18.Allgemein.';
                                          var id = path + 'D_C_4_2';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Uhrzeit' ;
                                          obj.common.desc = 'Uhrzeit';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          obj.common.unit = 'Uhr';
                                          var id = path + 'D_C_5_1';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Ansprechverhalten' ;
                                          obj.common.desc = 'Ansprechverhalten';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                                var id = path + 'D_C_4_1';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Regenerationszeitpunkt' ;
                                          obj.common.desc = 'Regenerationszeitpunkt 0= Auto 1= Fest';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_C_4_3';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Startzeit Regeneration' ;
                                          obj.common.desc = 'Startzeit Regeneration';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_C_7_1';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Soll Service Intervalldauer' ;
                                          obj.common.desc = 'Soll Service Intervalldauer';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          obj.common.unit = 'Tage';
                                          var id = path + 'D_A_2_2';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Tage bis zur nächsten Wartung' ;
                                          obj.common.desc = 'Tage bis zur nächsten Wartung';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_Y_5';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Aktueller Regenerationsschritt 0= keine Regeneration 1= Soletank füllen 2= Besalzen 3= Verdrängen 4= Rückspülen 5= Erstfiltrat' ;
                                          obj.common.desc = 'Aktueller Regenerationsschritt 0= keine Regeneration 1= Soletank füllen 2= Besalzen 3= Verdrängen 4= Rückspülen 5= Erstfiltrat';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_Y_7';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Inbetriebnahme-Datum' ;
                                          obj.common.desc = 'Inbetriebnahme-Datum';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_Y_8_11';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Ergebnis letzter E-Mail Versand 0=keine Mail versandt 1=Mail erfolgreich versandt 2=Benutzerdaten fehlerhaft 3= kein Internetzugang/Server nicht bereit' ;
                                          obj.common.desc = 'Ergebnis letzter E-Mail Versand 0=keine Mail versandt 1=Mail erfolgreich versandt 2=Benutzerdaten fehlerhaft 3= kein Internetzugang/Server nicht bereit';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_Y_10_1';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Aktuelle Restkapazität Austauscher' ;
                                          obj.common.desc = 'Aktuelle Restkapazität Austauscher';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          obj.common.unit = '%';
                                          var id = path + 'D_Y_13';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = '0= Austauscher gestört/in Regeneration 1= Austauscher in Betrieb' ;
                                          obj.common.desc = '0= Austauscher gestört/in Regeneration 1= Austauscher in Betrieb';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          var id = path + 'D_Y_14';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Voraussichtliche nächste Regeneration' ;
                                          obj.common.desc = 'Voraussichtliche nächste Regeneration';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          //region D_B_1 Regeneration
                                          var id = path + 'D_B_1';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Regeneration aktiv' ;
                                          obj.common.desc = 'Regeneration aktiv';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          // Aktualwerte
                                          var path = 'Messwerte.0.SC18.Aktualwerte.';
                                              //region D_A_1_1
                                              var id = path + 'D_A_1_1';
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Aktueller Durchfluss' ;
                                              obj.common.desc = 'Aktueller Durchfluss';
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = 'm³/h';
                                          //endregion D_A_1_1
                                              //region D_A_1_2
                                              var id = path + 'D_A_1_2';
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Restkapazität' ;
                                              obj.common.desc = 'Restkapazität';
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = 'm³*°dH';
                                          //endregion
                                          //region D_A_1_3
                                          var id = path + 'D_A_1_3';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Kapazitätszahl' ;
                                          obj.common.desc = 'Kapazitätszahl';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                              //endregion
                                              //region D_A_2_1
                                              var id = path + 'D_A_2_1';
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Restzeit/-menge Reg.Schritt' ;
                                              obj.common.desc = 'Restzeit/-menge Reg.Schritt';
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = 'l oder min';
                                              //endregion
                                              //region D_A_3_1
                                              var id = path + 'D_A_3_1';
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.common = {};
                                              obj.common.name = 'Letzte Regeneration' ;
                                              obj.common.desc = 'Letzte Regeneration vor x h';
                                              obj.common.def = 0;
                                              obj.common.min = 0;
                                              obj.common.unit = 'h';
                                          //endregion
                                              //region D_A_3_2
                                          var id = path + 'D_A_3_2';
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = {};
                                          obj.common.name = 'Letzte Regeneration Über' ;
                                          obj.common.desc = 'Letzte Regeneration Über';
                                          obj.common.def = 0;
                                          obj.common.min = 0;
                                          //endregion
                                          logger
                                          	// Logger
                                              // V1.0: Erstellung
                                              var constTick = 15
                                              var connection = getState(statePingAdapter);
                                              if (connection.val)
                                          case 1:
                                          console.log('Grünbeck: Request ' + requestNumber + ' ausgeführt');
                                          				const regex = /<data><code>([^\<]+)<\/code><D_Y_2_1>([^\<]+)<\/D_Y_2_1><D_Y_2_2>([^\<]+)<\/D_Y_2_2><D_Y_2_3>([^\<]+)<\/D_Y_2_3><D_Y_2_4>([^\<]+)<\/D_Y_2_4><D_Y_2_5>([^\<]+)<\/D_Y_2_5><D_Y_2_6>([^\<]+)<\/D_Y_2_6><D_Y_2_7>([^\<]+)<\/D_Y_2_7><D_Y_2_8>([^\<]+)<\/D_Y_2_8><D_Y_2_9>([^\<]+)<\/D_Y_2_9><D_Y_2_10>([^\<]+)<\/D_Y_2_10><D_Y_2_11>([^\<]+)<\/D_Y_2_11><D_Y_2_12>([^\<]+)<\/D_Y_2_12><D_Y_2_13>([^\<]+)<\/D_Y_2_13><D_Y_2_14>([^\<]+)<\/D_Y_2_14><\/data>/;
                                                              if (subst)
        i1 = i + 1;
        if (i < 10)
        else
                                                              requestNumber = 2;
                                          break;
                                          case 2:
                                                          const regex = /<data><code>([^\<]+)<\/code><D_C_4_1>([^\<]+)<\/D_C_4_1><D_C_4_2>([^\<]+)<\/D_C_4_2><D_C_4_3>([^\<]+)<\/D_C_4_3><D_C_5_1>([^\<]+)<\/D_C_5_1><D_C_7_1>([^\<]+)<\/D_C_7_1><\/data>/;
                                                              if (subst)
                                                              requestNumber = 3;
                                          break;
                                          case 3:
                                                          const regex = /<data><code>([^\<]+)<\/code><D_Y_4_1>([^\<]+)<\/D_Y_4_1><D_Y_4_2>([^\<]+)<\/D_Y_4_2><D_Y_4_3>([^\<]+)<\/D_Y_4_3><D_Y_4_4>([^\<]+)<\/D_Y_4_4><D_Y_4_5>([^\<]+)<\/D_Y_4_5><D_Y_4_6>([^\<]+)<\/D_Y_4_6><D_Y_4_7>([^\<]+)<\/D_Y_4_7><D_Y_4_8>([^\<]+)<\/D_Y_4_8><D_Y_4_9>([^\<]+)<\/D_Y_4_9><D_Y_4_10>([^\<]+)<\/D_Y_4_10><D_Y_4_11>([^\<]+)<\/D_Y_4_11><D_Y_4_12>([^\<]+)<\/D_Y_4_12><D_Y_4_13>([^\<]+)<\/D_Y_4_13><D_Y_4_14>([^\<]+)<\/D_Y_4_14><\/data>/;
                                                              if (subst)
        i1 = i + 1;
        if (i < 10)
        else
                                                              requestNumber = 4;
                                          break;
                                          case 4:
                                                          const regex = /<data><code>([^\<]+)<\/code><D_Y_5>([^\<]+)<\/D_Y_5><D_Y_7>([^\<]+)<\/D_Y_7><D_Y_8_11>([^\<]+)<\/D_Y_8_11><D_Y_10_1>([^\<]+)<\/D_Y_10_1><D_Y_13>([^\<]+)<\/D_Y_13><D_Y_14>([^\<]+)<\/D_Y_14><D_B_1>([^\<]+)<\/D_B_1><D_C_5_1>([^\<]+)<\/D_C_5_1><\/data>/;
                                                              if (subst)
                                                              requestNumber = 5;
                                          break;
                                          case 5:
                                                          const regex = /<data><code>([^\<]+)<\/code><D_A_1_1>([^\<]+)<\/D_A_1_1><D_A_1_2>([^\<]+)<\/D_A_1_2><D_A_1_3>([^\<]+)<\/D_A_1_3><D_A_2_1>([^\<]+)<\/D_A_2_1><D_A_3_1>([^\<]+)<\/D_A_3_1><D_A_3_2>([^\<]+)<\/D_A_3_2><\/data>/;
                                                              if (subst)
                                                              requestNumber = 1;
                                          Marc
