  4. [iot-Aktion] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb"
    6.0k
48 Beiträge 15 Kommentatoren 10.2k Aufrufe
  • nukleuzN Offline
    nukleuzN Offline
    nukleuz
    Habe heute auf Multihost umgestellt danach blieb der iot-Adapter gelb.
    Neue Keys angefordert und die Zugangsdaten (Passwort) neu eingegeben, obwohl vorhanden.
    Jetzt läuft wieder alles.
    Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
    • ElzersharkE Offline
      ElzersharkE Offline
      Elzershark
      iot.0	2019-01-22 13:03:56.521	info	Connection changed: disconnect
      iot.0	2019-01-22 13:03:56.520	error	premature close
      iot.0	2019-01-22 13:03:26.512	debug	reconnect
      iot.0	2019-01-22 13:03:21.503	info	Connection changed: disconnect
      iot.0	2019-01-22 13:03:21.501	error	premature close
      iot.0	2019-01-22 13:03:21.491	debug	offline
      iot.0	2019-01-22 12:03:07.031	debug	system.adapter.admin.0: logging true
      iot.0	2019-01-22 12:02:57.504	debug	sendTo "enums" to system.adapter.admin.0 from system.adapter.iot.0
      iot.0	2019-01-22 12:02:57.503	debug	Created ALEXA device: test ["turnOn","turnOff"]
      iot.0	2019-01-22 12:02:57.473	info	Request enums
      iot.0	2019-01-22 12:02:56.863	debug	sendTo "browse" to system.adapter.admin.0 from system.adapter.iot.0
      iot.0	2019-01-22 12:02:56.860	debug	Created ALEXA device: test ["turnOn","turnOff"]
      iot.0	2019-01-22 12:02:56.800	info	Request devices
      iot.0	2019-01-22 12:02:54.863	debug	system.adapter.admin.0: logging false
      iot.0	2019-01-22 12:02:52.190	warn	Invalid URL key. Status update is disabled: {"error":{"error":"No license found or license is no more valid"}}
      iot.0	2019-01-22 12:02:52.188	error	Cannot report device state: null
      iot.0	2019-01-22 12:02:51.326	debug	URL key is {"key":"1efcc810-1e3a-11e9-806c-237f48ccfdf7"}
      iot.0	2019-01-22 12:02:51.293	debug	Created ALEXA device: test ["turnOn","turnOff"]
      iot.0	2019-01-22 12:02:51.135	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.0	2019-01-22 12:02:51.106	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.iot, node: v8.15.0
      iot.0	2019-01-22 12:02:50.928	debug	statesDB connected
      iot.0	2019-01-22 12:02:50.863	debug	objectDB connected
      host.raspberrypi	2019-01-22 12:02:48.971	info	instance system.adapter.iot.0 started with pid 3558
      host.raspberrypi	2019-01-22 12:02:46.505	info	instance system.adapter.iot.0 terminated with code 0 (OK)
      host.raspberrypi	2019-01-22 12:02:46.446	info	stopInstance system.adapter.iot.0 killing pid 3349
      host.raspberrypi	2019-01-22 12:02:46.445	info	stopInstance system.adapter.iot.0
      Bleibt Gelb…
      mit license...
      iot.0	2019-01-22 13:12:30.309	info	Connection changed: disconnect
      iot.0	2019-01-22 13:12:30.308	error	premature close
      iot.0	2019-01-22 13:12:00.296	debug	reconnect
      iot.0	2019-01-22 13:11:55.294	info	Connection changed: disconnect
      iot.0	2019-01-22 13:11:55.292	error	premature close
      iot.0	2019-01-22 13:11:55.282	debug	offline
      iot.0	2019-01-22 13:11:25.276	debug	URL key is {"key":"1efcc810-1e3a-11e9-806c-237f48ccfdf7"}
      iot.0	2019-01-22 12:11:23.240	debug	Subscribe done
      iot.0	2019-01-22 12:11:23.239	debug	Subscribe 0 states for google home
      iot.0	2019-01-22 12:11:23.238	debug	CHECK URL reported: "{\"result\":\"OK\"}"
      iot.0	2019-01-22 12:11:22.855	debug	Created ALEXA device: test ["turnOn","turnOff"]
      iot.0	2019-01-22 12:11:22.772	debug	Fetching keys...
      iot.0	2019-01-22 12:11:22.684	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.0	2019-01-22 12:11:22.656	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.iot, node: v8.15.0
      iot.0	2019-01-22 12:11:22.491	debug	statesDB connected
      iot.0	2019-01-22 12:11:22.358	debug	objectDB connected
      host.raspberrypi	2019-01-22 12:11:20.587	info	instance system.adapter.iot.0 started with pid 3749
      https://www.youtube.com/c/Elzershark
      https://t.me/joinchat/BD87n3xMU0QzYmUy
      https://www.facebook.com/elzershark
      • marcusklM Offline
        marcusklM Offline
        marcuskl
        Bei mir kommt täglich diese Meldung~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201901 ... 36f469.jpg">https://uploads.tapatalk-cdn.com/20190124/3f2df4d08dac3f1488bb1d2ecd36f469.jpg</link_text>" />
        Gesendet von meinem SM-G950F mit Tapatalk~~
        Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
        Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
        • apollon77A Offline
          Der Fehler kommt aus der Google Home Library. Wie hast du das denn hinbekommen?
          • marcusklM Offline
            marcusklM Offline
            marcuskl
            @apollon77:
            Der Fehler kommt aus der Google Home Library. Wie hast du das denn hinbekommen? ` Ich habe den Adapter nicht mal
              iot hat schon eine Basisunterstützung für Google Home drin und daher kommt der Fehler.
              Komisch. ignorier es mal
                ElzersharkE Offline
                Elzershark
                Wer diesen Fehler auch hat , muss/sollte bei seinem Linux System ipv6 ausschalten. Amazon verhindert/verzögert das verbinden zur Cloud URL und die iot-Cloud bleibt gelb.
                unter anderem steht im log auch "timeout". und die Cloud versucht sich zig mal zu verbinden
                @Elzershark:
                Bleibt Gelb…
                mit license...
                  @marcuskl:
                  Bei mir kommt täglich diese Meldung![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201901 ... 36f469.jpg">https://uploads.tapatalk-cdn.com/20190124/3f2df4d08dac3f1488bb1d2ecd36f469.jpg</link_text>" /> ` AM Ende aktuell zu ignorieren. Wird mit einer kommenden iot Version gefixt
                  • MessiahsM Offline
                    MessiahsM Offline
                    Messiahs
                    @apollon77:
                    Nur zur Info.. Meldung kommt bei mir auch. Grundsätzlich lassen sich die Geräte aber über Alexa steuern.
                    Habe aber zusätzlich:
                    iot.0	2019-01-25 23:17:32.308	info	Connection changed: connect
                    iot.0	2019-01-25 23:17:30.455	warn	Invalid URL key. Status update is disabled: {"error":{"error":"No license found or license is no more valid"}}
                    iot.0	2019-01-25 23:17:30.454	error	Cannot report device state: null
                    eine Option in ioBroker.pro um iot zu abonieren, habe ich nicht… es wird nur Fernverwaltung angeboten...
                      Bitte die Meldung aktuell einfach ignorieren. Die kommt aus dem Google-Home Modul und sollte an sich nicht da sein, aber hat auf Alexa keinen Effekt :-)
