  4. [gelöst] Telegram Adapter Probleme
15 Beiträge 3 Kommentatoren 1.5k Aufrufe
  • F Offline
    fromfuture
    Moin,
    ich kann den Telegram Adapter nicht installieren.
    Im Log steht folgendes:
    host.ioBroker-RasPi 2018-12-14 09:08:17.812 warn warning: Cannot read "http://download.iobroker.net/sources-dist.json"
    host.ioBroker-RasPi 2018-12-14 09:08:07.479 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    iobroker 2018-12-14 09:08:07.274 info exit 0
    iobroker 2018-12-14 09:08:07.210 info npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-12-14T08_08_07_188Z-debug.log
    iobroker 2018-12-14 09:08:07.208 info
    iobroker 2018-12-14 09:08:07.183 info ERR! Unexpected string
    iobroker 2018-12-14 09:08:07.182 info
    iobroker 2018-12-14 09:08:07.181 info npm
    iobroker 2018-12-14 09:07:58.040 info npm install https://github.com/ioBroker/ioBroker.te … all/master --production --save --prefix "/opt/iobroker" (System call)
    Jemand eine Idee ?
    • apollon77A Offline
      Sieht nach einem Problem mit NPM aus. Was steht denn in dem angegeben Logfile?
      • F Offline
        fromfuture
        Hier der Log
        ! 0 info it worked if it ends with ok
        ! 1 verbose cli [ '/usr/bin/node',
        ! 1 verbose cli '/usr/bin/npm',
        ! 1 verbose cli 'install',
        ! 1 verbose cli 'https://github.com/ioBroker/ioBroker.te … all/master',
        ! 1 verbose cli '--production',
        ! 1 verbose cli '--save',
        ! 1 verbose cli '--prefix',
        ! 1 verbose cli '/opt/iobroker' ]
        ! 2 info using npm@5.8.0
        ! 3 info using node@v8.11.1
        ! 4 verbose npm-session b7b7d55106c8552d
        ! 5 silly install loadCurrentTree
        ! 6 silly install readLocalPackageData
        ! 7 verbose stack /usr/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/lib/pubsuffix.js:96
        ! 7 verbose stack {"ac":true,"com.ac":true,"edu.ac":true,"gov.ac":true,"net.ac":true,"mil.ac":true,"org.ac":true,"ad":true,"nom.ad":true,"ae":true,"co.ae":true,"net.ae":true,"org.ae":true,"sch.ae":true,"ac.ae":true,"gov.ae":true,"mil.ae":true,"aero":true,"accident-investigation.aero":true,"accident-prevention.aero":true,"aerobatic.aero":true,"aeroclub.aero":true,"aerodrome.aero":true,"agents.aero":true,"aircraft.aero":true,"airline.aero":true,"airport.aero":true,"air-surveillance.aero":true,"airtraffic.aero":true,"air-traffic-control.aero":true,"ambulance.aero":true,"amusement.aero":true,"association.aero":true,"author.aero":true,"ballooning.aero":true,"broker.aero":true,"caa.aero":true,"cargo.aero":true,"catering.aero":true,"certification.aero":true,"championship.aero":true,"charter.aero":true,"civilaviation.aero":true,"club.aero":true,"conference.aero":true,"consultant.aero":true,"consulting.aero":true,"control.aero":true,"council.
        ! 7 verbose stack
        ! 7 verbose stack SyntaxError: Unexpected string
        ! 7 verbose stack at createScript (vm.js:80:10)
        ! 7 verbose stack at Object.runInThisContext (vm.js:139:10)
        ! 7 verbose stack at Module._compile (module.js:616:28)
        ! 7 verbose stack at Object.Module._extensions..js (module.js:663:10)
        ! 7 verbose stack at Module.load (module.js:565:32)
        ! 7 verbose stack at tryModuleLoad (module.js:505:12)
        ! 7 verbose stack at Function.Module._load (module.js:497:3)
        ! 7 verbose stack at Module.require (module.js:596:17)
        ! 7 verbose stack at require (internal/module.js:11:18)
        ! 7 verbose stack at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/lib/cookie.js:34:17)
        ! 7 verbose stack at Module._compile (module.js:652:30)
        ! 8 verbose cwd /opt
        ! 9 verbose Linux 4.14.30-v7+
        ! 10 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.te ... all/master" "--production" "--save" "--prefix" "/opt/iobroker"
        ! 11 verbose node v8.11.1
        ! 12 verbose npm v5.8.0
        ! 13 error Unexpected string
        ! 14 verbose exit [ 1, true ]</anonymous>
          Versuch mal dein npm zu aktualisieren auf 6.4.x oder so
          • F Offline
            fromfuture
            Läuft alles gerade so schön oder ist es unproblematisch das Update zu machen?
            Nicht das es mir alles zerschießt.
            Bin noch frisch dabei [emoji16]
            Gesendet von meinem BKL-L04 mit Tapatalk
              Sagen wir es so: Der Fehler kommt von npm meiner Meinung nach, wie ich das lese.
              Du kannst jetzt suchen ob der Fehler bei npm bekannt ist und ggf gefixt wurde.
              npm 5->6 sollte, meiner meinung nach, kein Problem darstellen, wobei ich nichts verspreche ;-) Alle Aussagen "nach bestem Wissen und Gewissen"
              • F Offline
                fromfuture
                No risk no fun [emoji16]
                Kenne ich von meiner Android Bastelei.
                Ich melde mich.
                • F Offline
                  fromfuture
                  Klappt leider auch nicht ..
                  ! 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'npm@latest', '-g' ]
                  ! 4 verbose npm-session 1547d5dc14b6eaa0
                  ! 6 silly install readGlobalPackageData
                  ! 7 verbose stack
                  ! 8 verbose cwd /opt/iobroker
                  ! 10 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "npm@latest" "-g"
                  Versucht per Putty mit root
                    npm ist aber immer noch 5.8.0!
                    • F Offline
                      fromfuture
                      Ja das updaten vom npm funktioniert nicht.
                      Habe es mit npm install - g npm@latest versucht
                        Auch mit sudo?
                        Gesendet vom Handy …
                        • F Offline
                          fromfuture
                          Ja aber ich habe das Problem gefunden.
                          Ich hatte den Speicher nicht erweitert. Er hatte also nur die zwei GB vom Image [emoji1]
                          Sorry, vermutlich Anfängerfehler ;)
                          Danke für deine Hilfe [emoji106]
                          • E Offline
                            excalibur270
                            Moin moin. Ich klinke mich mal ein. Bin auch gerade erst am Anfang. Seit heute mittag explodiert mein log.````
                            host.ioBroker-RasPi 2018-12-14 20:24:08.558 info Restart adapter system.adapter.telegram.0 because enabled
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error instance system.adapter.telegram.0 terminated with code 0 (OK)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at Module.load (module.js:566:32)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at Module._compile (module.js:653:30)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.557 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:746:1)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at require (internal/module.js:11:18)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at Module.require (module.js:597:17)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at Module.load (module.js:566:32)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.556 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: at Module._compile (module.js:617:28)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: at createScript (vm.js:80:10)
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: SyntaxError: Invalid or unexpected token
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                            host.ioBroker-RasPi 2018-12-14 20:24:08.555 error Caught by controller[0]: " if (sender === this._hnhtialValue) return this._cancel();
                            host.ioBroker-RasPi 2018-12-14 20:24:08.554 error Caught by controller[0]: /opt/iobroker/node_modules/bluebird/js/release/reduce.js:66
                            telegram.0 2018-12-14 20:24:08.480 info starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.14.0
                            host.ioBroker-RasPi 2018-12-14 20:24:06.734 info instance system.adapter.telegram.0 started with pid 22782
                            host.ioBroker-RasPi 2018-12-14 20:24:05.722 info Restart adapter system.adapter.telegram.0 because enabled</anonymous>
                            Das wiederholt sich dann alle paar Sekunden.
                            Kann da evtl jemand helfen?
                              Bei dir tippe ich darauf das deine Adresse Karte langsam den Geist aufgibt. Da hat es eine Datei zerschossen.
                              Am besten auf neue Karte wechseln und Backup einspielen.
                              • E Offline
                                excalibur270
                                @apollon77:
                                Gesendet vom Handy … `
                                Das werde ich probieren. Kann ich da einfach ein backitup backup aus der Dropbox mit win32 aufspielen?
                                In Putty kommt das.
                                ! dpkg-query: Fehler: Parsen der Datei »/var/lib/dpkg/status«, nahe Zeile 56:
                                ! nach Feldname »Statuc▒« muss ein Doppelpunkt folgen Ist das was den fehler verursacht?
                                Edit:SD war kaputt
