<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] Telegram Adapter Probleme]]></title><description><![CDATA[<p dir="auto">Moin,</p>
<p dir="auto">ich kann den Telegram Adapter nicht installieren.</p>
<p dir="auto">Im Log steht folgendes:</p>
<p dir="auto">host.ioBroker-RasPi 2018-12-14 09:08:17.812 warn warning: Cannot read "<a href="http://download.iobroker.net/sources-dist.json" rel="nofollow ugc">http://download.iobroker.net/sources-dist.json</a>"</p>
<p dir="auto">host.ioBroker-RasPi 2018-12-14 09:08:07.479 info Update repository "default" under "<a href="http://download.iobroker.net/sources-dist.json" rel="nofollow ugc">http://download.iobroker.net/sources-dist.json</a>"</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.274 info exit 0</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.210 info npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-12-14T08_08_07_188Z-debug.log</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.208 info</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.183 info ERR! Unexpected string</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.182 info</p>
<p dir="auto">iobroker 2018-12-14 09:08:07.181 info npm</p>
<p dir="auto">iobroker 2018-12-14 09:07:58.040 info npm install <a href="https://github.com/ioBroker/ioBroker.telegram/tarball/master" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.te … all/master</a> --production --save --prefix "/opt/iobroker" (System call)</p>
<p dir="auto">Jemand eine Idee ?</p>
]]></description><link>https://forum.iobroker.net/topic/17550/gelöst-telegram-adapter-probleme</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 10:48:57 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/17550.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Dec 2018 08:11:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Sat, 15 Dec 2018 08:41:01 GMT]]></title><description><![CDATA[<p dir="auto"><s><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a>:</s></p>
<blockquote>
<p dir="auto">Bei dir tippe ich darauf das deine Adresse Karte langsam den Geist aufgibt. Da hat es eine Datei zerschossen.</p>
<p dir="auto">Am besten auf neue Karte wechseln und Backup einspielen.</p>
<p dir="auto">Gesendet vom Handy … `<br />
Danke</p>
</blockquote>
<p dir="auto">Das werde ich probieren. Kann ich da einfach ein backitup backup aus der Dropbox mit win32 aufspielen?</p>
<p dir="auto">In Putty kommt das.</p>
<blockquote>
<p dir="auto">! dpkg-query: Fehler: Parsen der Datei »/var/lib/dpkg/status«, nahe Zeile 56:<br />
! nach Feldname »Statuc▒« muss ein Doppelpunkt folgen Ist das was den fehler verursacht?</p>
</blockquote>
<p dir="auto">Edit:SD war kaputt</p>
]]></description><link>https://forum.iobroker.net/post/199418</link><guid isPermaLink="true">https://forum.iobroker.net/post/199418</guid><dc:creator><![CDATA[excalibur270]]></dc:creator><pubDate>Sat, 15 Dec 2018 08:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 21:03:09 GMT]]></title><description><![CDATA[<p dir="auto">Bei dir tippe ich darauf das deine Adresse Karte langsam den Geist aufgibt. Da hat es eine Datei zerschossen.</p>
<p dir="auto">Gesendet vom Handy …</p>
]]></description><link>https://forum.iobroker.net/post/199356</link><guid isPermaLink="true">https://forum.iobroker.net/post/199356</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 21:03:09 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 19:35:58 GMT]]></title><description><![CDATA[<p dir="auto">Moin moin. Ich klinke mich mal ein. Bin auch gerade erst am Anfang. Seit heute mittag explodiert mein log.````<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.558	info	Restart adapter system.adapter.telegram.0 because enabled<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	instance system.adapter.telegram.0 terminated with code 0 (OK)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at Module.load (module.js:566:32)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at Module._compile (module.js:653:30)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.557	error	Caught by controller[0]: at Object. &lt;anonymous&gt;(/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:746:1)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at require (internal/module.js:11:18)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at Module.require (module.js:597:17)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at Module.load (module.js:566:32)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.556	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: at Module._compile (module.js:617:28)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: at createScript (vm.js:80:10)<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.555	error	Caught by controller[0]: " if (sender === this._hnhtialValue) return this._cancel();<br />
host.ioBroker-RasPi	2018-12-14 20:24:08.554	error	Caught by controller[0]: /opt/iobroker/node_modules/bluebird/js/release/reduce.js:66<br />
telegram.0	2018-12-14 20:24:08.480	info	starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.14.0<br />
host.ioBroker-RasPi	2018-12-14 20:24:06.734	info	instance system.adapter.telegram.0 started with pid 22782<br />
host.ioBroker-RasPi	2018-12-14 20:24:05.722	info	Restart adapter system.adapter.telegram.0 because enabled&lt;/anonymous&gt;</p>
<pre><code>Das wiederholt sich dann alle paar Sekunden.
Kann da evtl jemand helfen?</code></pre>
]]></description><link>https://forum.iobroker.net/post/199335</link><guid isPermaLink="true">https://forum.iobroker.net/post/199335</guid><dc:creator><![CDATA[excalibur270]]></dc:creator><pubDate>Fri, 14 Dec 2018 19:35:58 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 17:43:37 GMT]]></title><description><![CDATA[<p dir="auto">Ja aber ich habe das Problem gefunden.</p>
<p dir="auto">Ich hatte den Speicher nicht erweitert. Er hatte also nur die zwei GB vom Image [emoji1]</p>
<p dir="auto">Sorry, vermutlich Anfängerfehler ;)</p>
<p dir="auto">Danke für deine Hilfe [emoji106]</p>
]]></description><link>https://forum.iobroker.net/post/199285</link><guid isPermaLink="true">https://forum.iobroker.net/post/199285</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 17:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 17:40:59 GMT]]></title><description><![CDATA[<p dir="auto">Auch mit sudo?</p>
]]></description><link>https://forum.iobroker.net/post/199281</link><guid isPermaLink="true">https://forum.iobroker.net/post/199281</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 17:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 15:58:55 GMT]]></title><description><![CDATA[<p dir="auto">Ja das updaten vom npm funktioniert nicht.</p>
<p dir="auto">Habe es mit npm install - g npm@latest versucht</p>
<p dir="auto">Gesendet von meinem BKL-L04 mit Tapatalk</p>
]]></description><link>https://forum.iobroker.net/post/199243</link><guid isPermaLink="true">https://forum.iobroker.net/post/199243</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 15:58:55 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 15:52:11 GMT]]></title><description><![CDATA[<p dir="auto">npm ist aber immer noch 5.8.0!</p>
]]></description><link>https://forum.iobroker.net/post/199240</link><guid isPermaLink="true">https://forum.iobroker.net/post/199240</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 15:52:11 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 15:40:30 GMT]]></title><description><![CDATA[<p dir="auto">Klappt leider auch nicht ..</p>
<blockquote>
<p dir="auto">! 0 info it worked if it ends with ok<br />
! 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'npm@latest', '-g' ]<br />
! 2 info using npm@5.8.0<br />
! 3 info using node@v8.11.1<br />
! 4 verbose npm-session 1547d5dc14b6eaa0<br />
! 5 silly install loadCurrentTree<br />
! 6 silly install readGlobalPackageData<br />
! 7 verbose stack /usr/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/lib/pubsuffix.js:96<br />
! 7 verbose stack {"ac":true,"<a href="http://com.ac" rel="nofollow ugc">com.ac</a>":true,"<a href="http://edu.ac" rel="nofollow ugc">edu.ac</a>":true,"<a href="http://gov.ac" rel="nofollow ugc">gov.ac</a>":true,"<a href="http://net.ac" rel="nofollow ugc">net.ac</a>":true,"<a href="http://mil.ac" rel="nofollow ugc">mil.ac</a>":true,"<a href="http://org.ac" rel="nofollow ugc">org.ac</a>":true,"ad":true,"<a href="http://nom.ad" rel="nofollow ugc">nom.ad</a>":true,"ae":true,"<a href="http://co.ae" rel="nofollow ugc">co.ae</a>":true,"<a href="http://net.ae" rel="nofollow ugc">net.ae</a>":true,"<a href="http://org.ae" rel="nofollow ugc">org.ae</a>":true,"<a href="http://sch.ae" rel="nofollow ugc">sch.ae</a>":true,"<a href="http://ac.ae" rel="nofollow ugc">ac.ae</a>":true,"<a href="http://gov.ae" rel="nofollow ugc">gov.ae</a>":true,"<a href="http://mil.ae" rel="nofollow ugc">mil.ae</a>":true,"aero":true,"<a href="http://accident-investigation.aero" rel="nofollow ugc">accident-investigation.aero</a>":true,"<a href="http://accident-prevention.aero" rel="nofollow ugc">accident-prevention.aero</a>":true,"<a href="http://aerobatic.aero" rel="nofollow ugc">aerobatic.aero</a>":true,"<a href="http://aeroclub.aero" rel="nofollow ugc">aeroclub.aero</a>":true,"<a href="http://aerodrome.aero" rel="nofollow ugc">aerodrome.aero</a>":true,"<a href="http://agents.aero" rel="nofollow ugc">agents.aero</a>":true,"<a href="http://aircraft.aero" rel="nofollow ugc">aircraft.aero</a>":true,"<a href="http://airline.aero" rel="nofollow ugc">airline.aero</a>":true,"<a href="http://airport.aero" rel="nofollow ugc">airport.aero</a>":true,"<a href="http://air-surveillance.aero" rel="nofollow ugc">air-surveillance.aero</a>":true,"<a href="http://airtraffic.aero" rel="nofollow ugc">airtraffic.aero</a>":true,"<a href="http://air-traffic-control.aero" rel="nofollow ugc">air-traffic-control.aero</a>":true,"<a href="http://ambulance.aero" rel="nofollow ugc">ambulance.aero</a>":true,"<a href="http://amusement.aero" rel="nofollow ugc">amusement.aero</a>":true,"<a href="http://association.aero" rel="nofollow ugc">association.aero</a>":true,"<a href="http://author.aero" rel="nofollow ugc">author.aero</a>":true,"<a href="http://ballooning.aero" rel="nofollow ugc">ballooning.aero</a>":true,"<a href="http://broker.aero" rel="nofollow ugc">broker.aero</a>":true,"<a href="http://caa.aero" rel="nofollow ugc">caa.aero</a>":true,"<a href="http://cargo.aero" rel="nofollow ugc">cargo.aero</a>":true,"<a href="http://catering.aero" rel="nofollow ugc">catering.aero</a>":true,"<a href="http://certification.aero" rel="nofollow ugc">certification.aero</a>":true,"<a href="http://championship.aero" rel="nofollow ugc">championship.aero</a>":true,"<a href="http://charter.aero" rel="nofollow ugc">charter.aero</a>":true,"<a href="http://civilaviation.aero" rel="nofollow ugc">civilaviation.aero</a>":true,"<a href="http://club.aero" rel="nofollow ugc">club.aero</a>":true,"<a href="http://conference.aero" rel="nofollow ugc">conference.aero</a>":true,"<a href="http://consultant.aero" rel="nofollow ugc">consultant.aero</a>":true,"<a href="http://consulting.aero" rel="nofollow ugc">consulting.aero</a>":true,"<a href="http://control.aero" rel="nofollow ugc">control.aero</a>":true,"council.<br />
! 7 verbose stack<br />
! 7 verbose stack SyntaxError: Unexpected string<br />
! 7 verbose stack at createScript (vm.js:80:10)<br />
! 7 verbose stack at Object.runInThisContext (vm.js:139:10)<br />
! 7 verbose stack at Module._compile (module.js:616:28)<br />
! 7 verbose stack at Object.Module._extensions..js (module.js:663:10)<br />
! 7 verbose stack at Module.load (module.js:565:32)<br />
! 7 verbose stack at tryModuleLoad (module.js:505:12)<br />
! 7 verbose stack at Function.Module._load (module.js:497:3)<br />
! 7 verbose stack at Module.require (module.js:596:17)<br />
! 7 verbose stack at require (internal/module.js:11:18)<br />
! 7 verbose stack at Object. &lt;anonymous&gt;(/usr/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/lib/cookie.js:34:17)<br />
! 7 verbose stack at Module._compile (module.js:652:30)<br />
! 8 verbose cwd /opt/iobroker<br />
! 9 verbose Linux 4.14.30-v7+<br />
! 10 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "npm@latest" "-g"<br />
! 11 verbose node v8.11.1<br />
! 12 verbose npm v5.8.0<br />
! 13 error Unexpected string<br />
! 14 verbose exit [ 1, true ]&lt;/anonymous&gt;</p>
</blockquote>
<p dir="auto">Versucht per Putty mit root</p>
]]></description><link>https://forum.iobroker.net/post/199233</link><guid isPermaLink="true">https://forum.iobroker.net/post/199233</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 15:40:30 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 14:32:51 GMT]]></title><description><![CDATA[<p dir="auto">No risk no fun [emoji16]</p>
<p dir="auto">Kenne ich von meiner Android Bastelei.</p>
<p dir="auto">Ich melde mich.</p>
]]></description><link>https://forum.iobroker.net/post/199205</link><guid isPermaLink="true">https://forum.iobroker.net/post/199205</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 14:32:51 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 12:49:46 GMT]]></title><description><![CDATA[<p dir="auto">Sagen wir es so: Der Fehler kommt von npm meiner Meinung nach, wie ich das lese.</p>
<p dir="auto">Du kannst jetzt suchen ob der Fehler bei npm bekannt ist und ggf gefixt wurde.</p>
<p dir="auto">npm 5-&gt;6 sollte, meiner meinung nach, kein Problem darstellen, wobei ich nichts verspreche ;-) Alle Aussagen "nach bestem Wissen und Gewissen"</p>
]]></description><link>https://forum.iobroker.net/post/199176</link><guid isPermaLink="true">https://forum.iobroker.net/post/199176</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 12:49:46 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 12:16:49 GMT]]></title><description><![CDATA[<p dir="auto">Läuft alles gerade so schön oder ist es unproblematisch das Update zu machen?</p>
<p dir="auto">Nicht das es mir alles zerschießt.</p>
<p dir="auto">Bin noch frisch dabei [emoji16]</p>
]]></description><link>https://forum.iobroker.net/post/199164</link><guid isPermaLink="true">https://forum.iobroker.net/post/199164</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 12:16:49 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 11:31:42 GMT]]></title><description><![CDATA[<p dir="auto">Versuch mal dein npm zu aktualisieren auf 6.4.x oder so</p>
]]></description><link>https://forum.iobroker.net/post/199150</link><guid isPermaLink="true">https://forum.iobroker.net/post/199150</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 11:31:42 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 10:18:42 GMT]]></title><description><![CDATA[<p dir="auto">Hier der Log</p>
<blockquote>
! 1 verbose cli [ '/usr/bin/node',<br />
! 1 verbose cli '/usr/bin/npm',<br />
! 1 verbose cli 'install',<br />
! 1 verbose cli '<a href="https://github.com/ioBroker/ioBroker.telegram/tarball/master" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.te … all/master</a>',<br />
! 1 verbose cli '--production',<br />
! 1 verbose cli '--save',<br />
! 1 verbose cli '--prefix',<br />
! 1 verbose cli '/opt/iobroker' ]<br />
! 4 verbose npm-session b7b7d55106c8552d<br />
! 6 silly install readLocalPackageData<br />
! 8 verbose cwd /opt<br />
! 10 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "<a href="https://github.com/ioBroker/ioBroker.telegram/tarball/master" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.te ... all/master</a>" "--production" "--save" "--prefix" "/opt/iobroker"<br />
</blockquote>
]]></description><link>https://forum.iobroker.net/post/199118</link><guid isPermaLink="true">https://forum.iobroker.net/post/199118</guid><dc:creator><![CDATA[fromfuture]]></dc:creator><pubDate>Fri, 14 Dec 2018 10:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Telegram Adapter Probleme on Fri, 14 Dec 2018 09:55:37 GMT]]></title><description><![CDATA[<p dir="auto">Sieht nach einem Problem mit NPM aus. Was steht denn in dem angegeben Logfile?</p>
]]></description><link>https://forum.iobroker.net/post/199108</link><guid isPermaLink="true">https://forum.iobroker.net/post/199108</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 14 Dec 2018 09:55:37 GMT</pubDate></item></channel></rss>
