  3. Cloud Dienste
  4. IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!
643 Beiträge 91 Kommentatoren 194.5k Aufrufe 57 Beobachtet
  • ThomasLPZT Offline
    ThomasLPZT Offline
    ThomasLPZ
    Gestern am frühen Abend problemlos installiert, jetzt neu gestartet. Die Cookie-Daten haben sich definitiv verändert. Adapter auf grün.
    Super Arbeit - ganz herzlichen Dank!
    Viele Grüße
    ThomasLPZ
    • apollon77A Offline
      @Espace0401:
      Ich habe momentan das Log voller Warnmeldungen vom Adapter.
      ! alexa2.0 2018-12-04 23:12:18.421 warn Device-type:AKPGW064GI9HE (FLASH_BRIEFING,CHANGE_NAME,SUPPORTS_SOFTWARE_VERSION,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,ARTHUR_TARGET,MICROPHONE,PERSISTENT_CONNECTION,VOLUME_SETTING,ACTIVE_AFTER_FRO) alexa2.0 2018-12-04 23:12:18.421 warn Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted alexa2.0 2018-12-04 23:07:09.966 warn Device-type:AKPGW064GI9HE (ARTHUR_TARGET,CHANGE_NAME,VOLUME_SETTING,MICROPHONE,SUPPORTS_SOFTWARE_VERSION,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,ACTIVE_AFTER_FRO,PERSISTENT_CONNECTION,FLASH_BRIEFING) alexa2.0 2018-12-04 23:07:09.965 warn Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted alexa2.0 2018-12-04 23:02:01.226 warn Device-type:AKPGW064GI9HE (FLASH_BRIEFING,VOLUME_SETTING,ACTIVE_AFTER_FRO,SUPPORTS_SOFTWARE_VERSION,CHANGE_NAME,MICROPHONE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,ARTHUR_TARGET,PERSISTENT_CONNECTION) alexa2.0 2018-12-04 23:02:01.225 warn Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted ! `
      Was ist Das für ein Device? Was kanndas? Bitte GitHub issue anlegen
      • O Offline
        O Offline
        oetti
        @oetti:
        Auch von mir erst einmal vielen Dank für den Adapter, und die Arbeit, welche darin steckt. Danke!
        Ich habe den Adapter ebenfalls mal aktualisiert, Instanz neugestartet, Cookie abgeholt - alles grün.
        Den Cookie habe ich mal kopiert, um ihn nach 24h vergleichen zu können 8-)
        oetti `
        Funktioniert. Adapter neugestartet, neuer Cookie - alles grün 8-)
        oetti
        ioBroker 4.0.10 (master) (CentOS 7 auf ESXi 6.7) | ioBroker 4.0.10 (Slave #1) VM | ioBroker 4.0.10 (Slave #2) (RPI 3)
        • J Offline
          jans_ios
          Moin!
          Ich habe meinen Adapter ebenfalls erfolgreich auf die 2.0.0 Alpha upgedated und neu gestartet - es wurde sich nach Proxy-Authentifikation sauber ein neues Cookie gezogen. Ich warte jetzt mal morgen ab und starte neu.
          Danke auf jeden Fall an alle Beteiligten für die Entwicklungsarbeit !! Ich kann mich hier "nur" als Tester einbringen…
          Ich habe direkt noch eine Frage: Ich habe 3 Sonos One im Einsatz und kann diese auch wunderbar ansprechen per Adapter. Die Gruppen wiederum (z.B. Partyraum mit 2 Sonos One als Stereo-Paar + 1 Sub) weisen die Datenpunkte gar nicht auf.
          Eine in Alexa zusätzlich definierte Gruppe "Oben", in der wiederum die Räume "Partyraum" (s.o.) und "Küche oben" (1 Sonos One) enthalten sind, taucht im Adapter gar nicht auf.
          Wie kann ich jetzt bspw. auf allen Sonos-Lautsprechern zeitsynchron den selben Text ausgeben lassen?
          Gruß, Jan
            Zu Gruppen: sie werden nur beim adapterstart geladen. Also Neustarten dann sollte die neue Gruppe auftauchen.
            Wenn Datenpunkte bei Gruppen fehlen bitte prüfen ob per Alexa App Sprachausgabe und so geht. Und wenn ja dann bitte log schauen bzw mir den deviceType und die capabilities als GitHub issue melden. Und ggf log senden.
            Synchrone Sprachausgaben sind nicht möglich aktuell.
            Gesendet vom Handy …
            • Espace0401E Offline
              Espace0401E Offline
              Espace0401
              @apollon77:
              @Espace0401:
              Was ist Das für ein Device? Was kanndas? Bitte GitHub issue anlegen `
              Ich habe das Problem gefunden. Es ist ein Amazon firetvstick 4K.Diesen habe ich hier seit heute im Einsatz, bestellt war er schon länger und somit bereits in der Objekt Liste.
              Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
              • J Offline
                jans_ios
                Hallo Apollon,
                die Alexa-App kann nicht mal "nur" auf einem Sonos-Gerät eine Sprachausgabe erzeugen, sie behauptet, kein Audiogerät zu finden (s. auch meine Kommentare unter https://github.com/Apollon77/ioBroker.alexa2/issues/140). Der Adapter wiederum kann auf den einzelnen Geräten prima Ausgaben erzeugen, aber eben nicht auf den Gruppen wie z.B. "Partyraum", dem bei mir 2 Sonos One und 1 Sub zugeordnet sind.
                Ich habe Dir wie erbeten eine Issue (https://github.com/Apollon77/ioBroker.alexa2/issues/163) eröffnet.
                Gruß, Jan
                  Hm … wenn es einzeln tut könnte es auch über die gruppen tun weil der Adapter nur über die Gruppenmitglieder iteriert und einzelne speak Kommandos sendet. Also könnte man vllt doch die Kommandos einschalten.
                  Gesendet vom Handy ...
                    Marty56
                    Ich habe 6 Amazon Echos und eine Gruppe "Haus" mit 4 Echos.
                    Wenn ich text2speech mit 'Commands.speak" auf die Haus Gruppe mache, bekomme kommt der Text nur auf 2 Lautsprechern.
                    Das scheint auch noch etwas zufällig zu sein.
                    Dasselbe passiert, wenn ich ein Lied mit dem Kommando 'Music-Provider.Amazon-Music' auf die Haus Gruppe abspielen möchte.
                    Ich glaube, bin mir aber nicht ganz sicher, dass das mit der früheren Version schon mal funktioniert hat.
                    HW:NUC (16 GB Ram)
                    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                      @Marty56:
                      Ich glaube, bin mir aber nicht ganz sicher, dass das mit der früheren Version schon mal funktioniert hat. `
                      Version 2.0 hat daran nichts geändert debug log bitte per PN
                        Marty56
                        Jetzt habe ich ein paar Mal versucht und es hat funktioniert.
                        Vielleicht war es was anderes. Sorry für den falschen Alarm.
                        HW:NUC (16 GB Ram)
                          Arnulf
                          wie komme ich denn an die Alpha? Ich sehe auf github nur 1.1.3
                          Und ein paar Hinweise, dass irgendwo an einer 2.0.0 gearbeitet wird.
                          Ich wollte nämlich schauen, ob in der neuen Version bereits an der Stimmerkennung von Alexa gearbeitet wird
                          (Habe gerade so etwas auf golem gelesen)
                          • ? Offline
                            vielen Dank für die tolle Arbeit, Version 1.1.3 lief bei mir selbst mit 2 Instanzen ( zwei verschiedene Amazonaccounts) einwandfrei.
                            Version 2.0 auch mit 2 Instanzen.
                            Node 8.14, NPM 6.4.1, js-controller 1.5.3, linux mint 18.3.
                              Marty56
                              Bei mir war Stromausfall und der Router hat neugebootet.
                              Alles ging wieder, nur Alexa 2 blieb dauerhaft auf gelb.
                              HW:NUC (16 GB Ram)
                              • ? Offline
                                @Marty56:
                                Alles ging wieder, nur Alexa 2 blieb dauerhaft auf gelb. `
                                Das hatte ich auch, als ich meine Fritzbox umgesetzt hatte und die Verbindung zum Internet mal für ne Stunde ausgefallen war, hab n Issue dazu auf Github angelegt. Der cloud adapter und iot adapter schnackelt das, der Alexa adapter geht anscheinend irgendwann auf Störung und versucht nicht mehr, die Verbindung herzustellen.
                                Wenn die Verbindung mal kurz ausfällt, ist das kein problem, aber wenn sie mal für eine halbe Stunde oder mehr weg ist, dann schon..
                                  Jupp, steht noch auf der langen todo liste
                                  • C Offline
                                    Christian.B
                                    Freunde,
                                    ich bekomme den Echo Dot 3 nicht im Iobroker eingebunden.
                                    Ich habe die Adapterversion 2.0.0 installiert, unter login sind die Daten korrekt eingetragen.
                                    Die Adapterampel steht auf gelb da "verbunden mit Alexa 2 " auf "falsch" steht. Verbunden mit Host und Lebenszeichen stehen auf wahr.
                                    Mit der Adapterversion 1.1.3 gab es dieselben Probleme.
                                    Wo muss ich ansetzen um das Problem zu lösen?
                                    Viele Grüße
                                    Christian
                                    viele Grüße
                                    Christian
                                    • I Offline
                                      I Offline
                                      itzibitzistriezi
                                      Was sagt Log ?
                                      Iobroker seit über 10 Jahren :)
                                      • C Offline
                                        Christian.B
                                        Ich habe zwei Dot 3 im Netzwerk.
                                        Die IP Adressen sind 192.168.178.69 und 192.168.178.71.
                                        Leider finde ich unter Log nichts, was mit diesen IDs etwas zu tun hat.
                                        ! alexa2.1 2018-12-12 20:37:32.468 debug system.adapter.admin.0: logging true
                                        ! alexa2.1 2018-12-12 20:37:32.466 debug redis pmessage io..logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1544643452465,"q":0,"from":"system.adapter.admin.0","lc":1544643452465}
                                        ! alexa2.1 2018-12-12 20:33:52.844 debug system.adapter.admin.0: logging false
                                        ! alexa2.1 2018-12-12 20:33:52.838 debug redis pmessage io.
                                        .logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1544643232829,"q":0,"from":"system.adapter.admin.0","lc":1544643232829}
                                        ! iobroker 2018-12-12 20:20:31.160 info exit 0
                                        ! iobroker 2018-12-12 20:20:31.134 info Adapter "alexa2" updated
                                        ! iobroker 2018-12-12 20:20:31.069 info upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                        ! iobroker 2018-12-12 20:20:30.979 info upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
                                        ! iobroker 2018-12-12 20:20:30.911 info upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
                                        ! iobroker 2018-12-12 20:20:30.829 info upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
                                        ! iobroker 2018-12-12 20:20:30.750 info upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                        ! iobroker 2018-12-12 20:20:30.668 info upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                        ! iobroker 2018-12-12 20:20:30.583 info upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                        ! iobroker 2018-12-12 20:20:30.502 info upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                        ! iobroker 2018-12-12 20:20:30.422 info upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                        ! iobroker 2018-12-12 20:20:30.351 info upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                        ! iobroker 2018-12-12 20:20:30.279 info upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                        ! iobroker 2018-12-12 20:20:30.210 info upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                        ! iobroker 2018-12-12 20:20:30.112 info upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                        ! iobroker 2018-12-12 20:20:30.041 info upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                        ! iobroker 2018-12-12 20:20:29.963 info upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
                                        ! iobroker 2018-12-12 20:20:29.873 info upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                        ! iobroker 2018-12-12 20:20:29.777 info upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                        ! iobroker 2018-12-12 20:20:29.744 info got /opt/iobroker/node_modules/iobroker.alexa2/admin
                                        ! iobroker 2018-12-12 20:20:29.506 info notice created a lockfile as package-lock.json. You should commit this file.
                                        ! iobroker 2018-12-12 20:20:29.501 info npm
                                        ! iobroker 2018-12-12 20:19:47.787 info graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                        ! iobroker 2018-12-12 20:19:47.785 info deprecated
                                        ! iobroker 2018-12-12 20:19:47.784 info WARN
                                        ! iobroker 2018-12-12 20:19:47.783 info
                                        ! iobroker 2018-12-12 20:19:47.782 info npm
                                        ! iobroker 2018-12-12 20:19:47.685 info minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                        ! iobroker 2018-12-12 20:19:47.684 info deprecated
                                        ! iobroker 2018-12-12 20:19:47.683 info WARN
                                        ! iobroker 2018-12-12 20:19:47.681 info
                                        ! iobroker 2018-12-12 20:19:47.680 info npm
                                        ! iobroker 2018-12-12 20:19:46.026 info minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                        ! iobroker 2018-12-12 20:19:46.024 info deprecated
                                        ! iobroker 2018-12-12 20:19:46.023 info WARN
                                        ! iobroker 2018-12-12 20:19:46.022 info
                                        ! iobroker 2018-12-12 20:19:46.021 info npm
                                        ! iobroker 2018-12-12 20:19:43.984 info graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                        ! iobroker 2018-12-12 20:19:43.983 info deprecated
                                        ! iobroker 2018-12-12 20:19:43.982 info WARN
                                        ! iobroker 2018-12-12 20:19:43.981 info
                                        ! iobroker 2018-12-12 20:19:43.980 info npm
                                        ! iobroker 2018-12-12 20:19:39.920 info gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                        ! iobroker 2018-12-12 20:19:39.919 info deprecated
                                        viele Grüße
                                        Christian
                                        • J Offline
                                          janzev95
                                          Ich habe seit kurzer Zeit einen Echo Dot 3. Generation und habe das als Anlass genommen, mal ein bisschen mit ioBroker rumzuspielen. Bei mir wird der Alexa2 v2 (aus Github installiert) Adapter grün und der Echo Dot (3. Generation) ist auch unter den Objekten drin.
                                          Installiert ist ioBroker in einer VM mit Ubuntu 18.04.1 64 Bit. Die ioBroker Installation ist von Montag und der Adapter ist erst heute installiert worden; ich habe also ein ganz frisches, aktuelles System.
