  4. [Gelöst] Blockly - Rollo Steuerung Abhängigkeit Tür
    5.8k
28 Beiträge 3 Kommentatoren 3.5k Aufrufe
    Belei
    Habe den Code nachgebaut.
    Ich hatte zum Zeitpunk Sonnenuntergang den TFK geöffnet und es kam eine Pushover!
    Dann habe ich den TFK geschlossen aber das Rollo bleibt oben?
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="44gpXyTQ_x[N#VzCnLgb" x="-337" y="-187"><mutation items="1"></mutation>
        <value name="OID0"><shadow type="field_oid" id="Poy6_h96Od5zcQnsna1Q"><field name="oid">fhem.0.TuerWintergarten.state</field></shadow></value>
        <statement name="STATEMENT"><block type="controls_if" id="~SDsCLI;Ecv,J4DYR][2"><value name="IF0"><block type="logic_operation" id="xeQ8y5~YP3iw[{iD~Xh?" inline="false"><field name="OP">AND</field>
                <value name="A"><block type="logic_compare" id="UVWr,|+un*umA`A@ha/e"><field name="OP">EQ</field>
                    <value name="A"><block type="variables_get" id="QDf1rH9*AvsV(PqbdA|d"><field name="VAR">Wert</field></block></value>
                    <value name="B"><block type="text" id="6T;_]0cB,lx#zfvCq:XS"><field name="TEXT">closed</field></block></value></block></value>
                <value name="B"><block type="time_compare_ex" id="lq}5.T/dgY(|gI-Jt73!" inline="false"><mutation end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">not between</field>
                    <value name="START_TIME"><shadow type="text" id="XX`gW4T692bu)A~)lBzt"><field name="TEXT">12:00</field></shadow>
                      <block type="time_astro" id="5tHBay*bx1N5%yaX%NS#"><field name="TYPE">sunrise</field>
                        <field name="OFFSET">0</field></block></value>
                    <value name="END_TIME"><shadow type="text" id="NlAm,A)HGHgJ6/pTHHCM"><field name="TEXT">18:00</field></shadow>
                      <block type="time_astro" id="T*_snCzodss?}RO}9K.|"><field name="TYPE">sunset</field>
                        <field name="OFFSET">0</field></block></value></block></value></block></value>
            <statement name="DO0"><block type="control" id="qD9oBw7dS/o@Uxyc~wvN"><mutation delay_input="true"></mutation>
                <field name="OID">rflink.0.channels.BrelMotor_2.BLIND_33</field>
                <field name="DELAY_MS">10</field>
                <value name="VALUE"><block type="logic_boolean" id="O1fn9hkCEI9S!jXy:2H{"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement>
        <next><block type="schedule" id="cZ5_:~7y)EO~[u:oSpPF"><field name="SCHEDULE">0 8 * * *</field>
            <statement name="STATEMENT"><block type="control" id="J??JUNQrd~`AydANF6~:"><mutation delay_input="false"></mutation>
                <value name="VALUE"><block type="logic_boolean" id="(D5.2~Lt9hzhRUZ2a-*!"><field name="BOOL">TRUE</field></block></value></block></statement>
            <next><block type="astro" id="LA7JOH!g~G24~51gsUCx"><field name="TYPE">sunset</field>
                <statement name="STATEMENT"><block type="comment" id="jW:/2v8@CivU%=pTS;HL"><field name="COMMENT">Tür</field>
                    <next><block type="controls_if" id="1K|.!Jb]|TaM~WOs~7fD"><mutation else="1"></mutation>
                        <value name="IF0"><block type="logic_compare" id="Yr`%2BVA+)E`+xbM=[6l"><field name="OP">EQ</field>
                            <value name="A"><block type="get_value" id="A;v/Eh#/d@[B@nsyCu89"><field name="ATTR">val</field>
                                <field name="OID">fhem.0.TuerWintergarten.state</field></block></value>
                            <value name="B"><block type="text" id="q7N]*%zDKsDJTlA:C9j/"><field name="TEXT">closed</field></block></value></block></value>
                        <statement name="DO0"><block type="comment" id="cUM:S{Einto7-^LMzwGd"><field name="COMMENT">Rollo</field>
                            <next><block type="control" id="%*E8RwVufT3V:u`~*o_!"><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="logic_boolean" id="Z~8]z~~nLyw?LTq-{VVA"><field name="BOOL">FALSE</field></block></value></block></next></block></statement>
                        <statement name="ELSE"><block type="pushover" id="AK0T#ShP]?X@A;^uHhd?"><field name="INSTANCE">.0</field>
                            <field name="PRIORITY">0</field>
                            <value name="MESSAGE"><shadow type="text" id="2e+lsSk:^Z1,Aqwi)@p`"><field name="TEXT">Rollo 3 konnte nicht geschlossen werden, da die Wintrgarten Tür noch geöffnet ist.</field></shadow></value></block></statement></block></next></block></statement></block></next></block></next></block>
      <block type="comment" id="V*g}ZJ^:Ga3j_MdCbcyx" x="-262" y="213"><field name="COMMENT">Morgens Rollo hoch</field></block></xml>
    • paul53P Offline
      @Belei:
      Dann habe ich den TFK geschlossen aber das Rollo bleibt oben? `
      Wird dann tatsächlich der Wert "closed" geliefert. Das solltest Du mal Loggen (vor dem falls im Tür-Trigger):
      debug output Wert
        Belei
        Ich "meine" das da gestern mal False stand…
        Aber definitiv eben mehrmals auf zu gemacht, wird immer auf open/closed geändert.
        Habe auch gerade den Kontakt nochmal gelöscht und neu gesynct.
          Belei
          20:05:14.919	[info]	javascript.0 Stop script script.js.common.Rollo_Wz_Tür_Schiebetür
          20:05:15.106	[info]	javascript.0 Start javascript script.js.common.Rollo_Wz_Tür_Schiebetür
          20:05:15.107	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: subscribe: {"pattern":{"id":"fhem.0.TuerWintergarten.state","change":"ne"},"name":"script.js.common.Rollo_Wz_Tür_Schiebetür"}
          20:05:15.107	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: schedule(cron=0 8 * * *)
          20:05:15.107	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: setTimeout(ms=21284897)
          20:05:15.107	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: registered 1 subscription and 2 schedules
          • paul53P Offline
            Den Debug-Block hast Du eingebaut und die Tür anschließend geschlossen ?
              Belei
              ähm jetzt ja. Aber wo soll jetzt was angezeigt werden? bzw muss ich noch im Blockly auf debug und Hilfe klicken?
              Edit:
              Oder meiste oben im ersten Block, der wäre doch eigentlich gerade aktiv?
              • paul53P Offline
                Ein Loggen eines konstanten Strings "Wert" bei Sonnenuntergang liefert keine Information. Bitte so:
                Dann siehst Du im Log unterhalb des Blockly-Fensters ob beim Schließen der Tür false oder closed übergeben wird.
                • paul53P Offline
                  Wie sieht der Datenpunkt (Wert) der Tür im Reiter Objekte aus ? Vielleicht so ?
                  closed anstelle Aus ?
                    Belei
                    mhhh UNDEFined
                    21:33:12.285	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: setTimeout(ms=16007727)
                    21:33:12.285	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: registered 1 subscription and 2 schedules
                    21:34:22.893	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: undefined
                    21:34:33.391	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: undefined
                    • paul53P Offline
                      siehe nächsten Beitrag.
                      • paul53P Offline
                        Ich habe ein Vermutung: Ist Wert eine Variable ? Dann ist undefined erklärbar.
                        Wert muss eine Eigenschaft des Triggerdatenpunktes sein (Trigger-Blöcke).
                        Hier Dein Export mit Korrektur:
                                    <value name="A"><block type="on_source" id="q3KMWhUK-EOqYkTW,;]t"><field name="ATTR">state.val</field></block></value>
                                    <value name="END_TIME"><shadow type="text" id="-L8;|(Q?gQ^IBvs[c#QL"><field name="TEXT">18:00</field></shadow>
                          Belei
                          Ich habe jetzt noch nicht neu importiert sonder tatsächlich die VARIABLE Wert geändert in Trigger/objectID-Wert.
                          Und Debug ausgemacht, das Rollo ging runter. Steht zwar trotzdem was mit undefined aber es ging.
                          22:23:52.148	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: undefined
                          22:23:52.149	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: getAstroDate(pattern=sunrise, date=Sat Sep 29 2018 22:23:52 GMT+0200 (CEST)) => Sat Sep 29 2018 07:20:05 GMT+0200 (CEST)
                          22:23:52.149	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: getAstroDate(pattern=sunset, date=Sat Sep 29 2018 22:23:52 GMT+0200 (CEST)) => Sat Sep 29 2018 19:06:07 GMT+0200 (CEST)
                          22:23:52.149	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: setStateDelayed(id=rflink.0.channels.BrelMotor_2.BLIND_33, state=false, isAck=false, delay=10000, clearRunning=false)
                          22:24:02.149	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: setForeignState(id=rflink.0.channels.BrelMotor_2.BLIND_33, state={"val":false,"ack":false})
                          • paul53P Offline
                            @Belei:
                            Ich habe jetzt noch nicht neu importiert sonder tatsächlich die VARIABLE Wert geändert in Trigger/objectID-Wert. `
                            Mehr habe ich auch nicht geändert. Kann also so bleiben.
                              Belei
                              Super, wieder was gelernt!
                              Danke für die Hilfe.
                              Ein komischen Rollo Script hab ich noch :roll:
                              Aber jetzt bin ich zu müde :mrgreen:
                                Belei
                                Ich habe jetzt den TFK von FHEM abgelernt und an die CCU angemeldet, Wert laut Debug immer noch undefined.
                                Habe auch mal einen andere TFK genommen, dieser meldet das gleiche.??
                                ` > 19:34:14.663 [info] javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: undefined
                                19:34:17.657 [info] javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: undefined `
                                • paul53P Offline
                                  Auch an den Debug-Block hast Du die Triggerdatenpunkt-Eigenschaft Wert übergeben und nicht die Variable Wert ?
                                    Belei
                                    :roll: auch das hab ich jetzt.. Immerhin meldet er jetzt true/false aber will nicht das Rollo schliessen.
                                    Ist vieleicht das "false" als Textfeld falsch?
                                    20:33:14.662	[info]	javascript.0 Stop script script.js.common.Rollo_Wz_Tür_Schiebetür
                                    20:33:14.855	[info]	javascript.0 Start javascript script.js.common.Rollo_Wz_Tür_Schiebetür
                                    20:33:14.856	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: subscribe: {"pattern":{"id":"hm-rpc.0.MEQ0898715.1.STATE","change":"ne"},"name":"script.js.common.Rollo_Wz_Tür_Schiebetür"}
                                    20:33:14.856	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: schedule(cron=0 8 * * *)
                                    20:33:14.857	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: setTimeout(ms=19605158)
                                    20:33:14.857	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: registered 1 subscription and 2 schedules
                                    20:35:32.200	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: true
                                    20:35:47.419	[info]	javascript.0 script.js.common.Rollo_Wz_Tür_Schiebetür: false
                                    • paul53P Offline
                                      @Belei:
                                      Ist vieleicht das "false" als Textfeld falsch? `
                                      Sicherlich ja. Ersetze es durch unwahr (Logik-Block).
                                        Belei
                                        Funktioniert leider auch nicht. Irgentwo ist noch der Wurm.
                                        Rollo geht nicht runter wenn Tür geschlossen wird und es nicht zwischen SA und SU ist.
                                         <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="44gpXyTQ_x[N#VzCnLgb" x="-287" y="-162"><mutation items="1"></mutation>
                                            <value name="OID0"><shadow type="field_oid" id="Poy6_h96Od5zcQnsna1Q"><field name="oid">hm-rpc.0.MEQ0268789.1.STATE</field></shadow></value>
                                            <statement name="STATEMENT"><block type="debug" id="02O}u#.kF1i#+D)-p8Y3"><field name="Severity">log</field>
                                                <value name="TEXT"><shadow type="text" id="Dcb^z+{z)/J3kk+jWa45"><field name="TEXT">Wert</field></shadow>
                                                  <block type="on_source" id="Qg{t]:wD(%71iwz`[EQx"><field name="ATTR">state.val</field></block></value>
                                                <next><block type="controls_if" id="~SDsCLI;Ecv,J4DYR][2"><value name="IF0"><block type="logic_operation" id="xeQ8y5~YP3iw[{iD~Xh?" inline="false"><field name="OP">AND</field>
                                                            <value name="A"><block type="on_source" id="!sPbhy4pUV!%2Z7L:MvZ"><field name="ATTR">state.val</field></block></value>
                                                            <value name="B"><block type="logic_boolean" id="ID+E#Hs+E~V7fl5Y9T(D"><field name="BOOL">FALSE</field></block></value></block></value>
                                                              <block type="time_astro" id="5tHBay*bx1N5%yaX%NS#"><field name="TYPE">sunrise</field></block></value>
                                                            <value name="END_TIME"><shadow type="text" id="=HFC7vG,z[/4:A6aDI)R"><field name="TEXT">18:00</field></shadow>
                                                              <block type="time_astro" id="T*_snCzodss?}RO}9K.|"><field name="TYPE">sunset</field></block></value></block></value></block></value>
                                                        <next><block type="control" id="qD9oBw7dS/o@Uxyc~wvN"><mutation delay_input="false"></mutation>
                                                            <value name="VALUE"><block type="logic_boolean" id="O1fn9hkCEI9S!jXy:2H{"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></next></block></statement>
                                            <next><block type="comment" id="V*g}ZJ^:Ga3j_MdCbcyx"><field name="COMMENT">Morgens Rollo hoch</field>
                                                        <field name="OFFSET">1</field>
        <field name="OID">hm-rpc.0.MEQ0268789.1.STATE</field></block></value>
        <value name="B"><block type="logic_boolean" id="p9s=W+^CO#K[eu/d%7^?"><field name="BOOL">FALSE</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="%*E8RwVufT3V:u`~*o_!"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="logic_boolean" id="Z~8]z~~nLyw?LTq-{VVA"><field name="BOOL">FALSE</field></block></value></block></statement>
        <value name="MESSAGE"><shadow type="text" id="2e+lsSk:^Z1,Aqwi)@p`"><field name="TEXT">Rollo 3 konnte nicht geschlossen werden, da die Wintrgarten Tür noch geöffnet ist.</field></shadow></value></block></statement></block></next></block></statement></block></next></block></next></block></next></block></xml>
                                        • paul53P Offline
                                          Kann keinen Fehler entdecken, es sollte so funktionieren.
