  4. Ist dies möglich?!
    5.7k
    1.5k
Ist dies möglich?!
19 Beiträge 4 Kommentatoren 806 Aufrufe
  • fischi87F Offline
    fischi87F Offline
    fischi87
    Hallo Gemeinde,
    ich habe zurzeit sehr viele fragen bezüglich vis da ich zurzeit an meiner persönlich vis arbeite :D
    ich habe dieses widget um einen kreis einzublenden:
    [{"tpl":"tplFrame","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"","title_top":"-10","title_left":"15","header_height":"0","header_color":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_font":"","title_back":"","class":"main_ring","filterkey":"Main"},"style":{"left":"794","top":"50","border-width":"2px","border-radius":"300px","border-style":"solid","border-color":"#ffffff","width":"200px","height":"200px","box-shadow":"0px 0px 10px 1px #ffffff"},"widgetSet":"basic"}]
    nun möchte ich, die status scripts, Fenster, lichter etc. in die kreise einfügen d.h. ich hätte gerne ein symbol in der Mitte, was jetzt nicht das ding ist. was ich aber zusätzlich möchte und jetzt meine frage, ich möchte die border farbe ändern sobald ein script z.b. servicmeldung 1 ist also sozusagen aktiv von mir aus rot und inaktiv halt grün. ich hoffe ich konnte mich verständlich ausdrücken.
    danke euch
    Mit freundlichen Grüßen Axel
      Brati
      ein Screenshot wäre besser, hab keine Lust das erst im vis edit zu importieren. Was du vorhast, kannst du auf 2 Wegen lösen:
      1. Du legst 2 mal das gleiche Widget übereinander (grüner/ toter) Rahmen und zeigst in Abhängigkeit deines Status an (siehe Sichtbarkeit).
      2. du fügst unter Border Color ein:
      {v:javascript.0.Status.xxx.xxx; (v>0) ? "red" : ""}
      Brati
      • fischi87F Offline
        fischi87F Offline
        fischi87
        ` > 2. du fügst unter Border Color ein:
        Brati `
        Guten Morgen brati,
        Wo füg ich dies ein? Direkt bei dem Widget In den css Einstellungen oder im Reiter script?
        Danke für deine Antwort, werde es mir merken mit dem Screenshot <emoji seq="1f609">😉</emoji>
        Grüße Axel
          Brati
          In der Config des Script auf der rechten Seite CSS Ränder (border…) oder wo auch immer du das brauchst. Klappt auch bei Background usw...
          Brati
          • fischi87F Offline
            fischi87F Offline
            fischi87
            sorry aber ich kann dir nicht ganz folgen, wenn ich den Befehl von dir bei border ein schreibe passiert garnichts?! anscheinend versteh ich dies noch nicht so richtig
            grüße
              Brati
              Wie schreibst du ihn denn rein? Den State musst du natürlich auf deinen Bedarf anpassen. Im Beispiel wird der Rahmen rot, wenn der ausgewählte State größer "0" ist.
              • fischi87F Offline
                fischi87F Offline
                fischi87
                ja klar passe ich den state natürlich an aber genau in der gleichen spalte wie du hab ich dies drin stehen aber da passiert nix. wenn ich das im Reiter css rein schreibe, kommt auch ein error an der Seite (rotes kreuz) "unknown property v"
                • R Offline
                  RappiRN
                  In den <u>Reiter</u> CSS gehört das nicht rein!
                  Zeig doch mal bitte deinen Datenpunkt, von dem die Farbe abhängen soll, welche Werte kann der annehmen?
                  Und dann zeig mal bitte auch, wo genau im Widget du den Eintrag probiert hast!
                  Bratis Beispiel hat aber nicht die Randfarbe sondern die Hintergrundfarbe und den Schatten verändert!
                  Enrico
                  • fischi87F Offline
                    fischi87F Offline
                    fischi87
                    @RappiRN:
                    Enrico `
                    hab es sowohl in background als auch bei box-shadow versucht oder auch bei color
                    okay ich füg mal paar Bilder ein:
                    • R Offline
                      RappiRN
                      Und dann bitte noch den genauen Text, den du eingetragen hast!
                      Enrico
                      • fischi87F Offline
                        fischi87F Offline
                        fischi87
                        @RappiRN:
                        Enrico `
                        {v:javascript.0.Status.Lichter.Anzahl_ein; (v>0) ? "red" : ""}
                        ich habe zusätzlich noch einen Daten Punkt wie die siehst in diesem script was auf true gesetzt wird wenn min ein licht an ist, vielleicht kann man auch diesen verwenden?
                        • R Offline
                          RappiRN
                          Ich werde mir das heute Abend nochmal genauer ansehen, wenn nicht irgendjemand schneller ist. True/false kannst du auch abfragen.
                          Enrico
                            Und wenn sich der Rahmen ändern soll bitte bei Border und nichtnbei Background eintragen.
                            Das Forum freut sich über eine Spende. Benutzt dazu den Spendenbutton im Header. Danke!
                            • fischi87F Offline
                              fischi87F Offline
                              fischi87
                              @Homoran:
                              3 `
                              Ich hab border auf „none“ also ich hab nur den shadow drin. Dieser geändert werden soll.
                              • fischi87F Offline
                                fischi87F Offline
                                fischi87
                                @RappiRN:
                                Enrico `
                                Das wäre nett, danke dir
                                • R Offline
                                  RappiRN
                                  @fischi87:
                                  Ich hab border auf „none“ also ich hab nur den shadow drin. Dieser geändert werden soll. `
                                  Willst du die Schattenfarbe ändern? Da müssen mehr Werte eingetragen werden als nur die Farbe z.B. 5px 5px 5px! Das wäre dann ein rechtschmaler Schatten. Ich glaube, die Farbe kann dazu auch noch angegeben werden, muss aber nicht, nur die Farbe geht glaub ich nicht!
                                  Hiermal ein Beispiel mit einem Datenpunkt als Farbe:
                                  {a:hm-rega.0.1404; a ==="true" ? "#2EFE2E" : "#ffff00"}
                                  Dieses Objekt hat entweder true oder false und schaltet zwischen einem Gelb und einem Grünton um.
                                  Enrico
                                  • fischi87F Offline
                                    fischi87F Offline
                                    fischi87
                                    @RappiRN:
                                    @fischi87:
                                    Enrico `
                                    läuft, jetzt kann ich das anpassen danke dir wie sau!!!!
                                    wofür steht das "a" bzw das "v"?
                                    • R Offline
                                      RappiRN
                                      @fischi87:
                                      wofür steht das "a" bzw das "v"? `
                                      Das ist "nur" eine Variable innerhalb dieser Angabe, es kann wohl jeder Buchstabe genommen werden, irgendwie kann man auch ein bisschen rechnen, also direkt auf zwei Objekte reagieren, da gibts aber noch mehr Abhängigkeiten, die ich leider nicht kenne.
                                      Enrico
                                      • fischi87F Offline
                                        fischi87F Offline
                                        fischi87
                                        @RappiRN:
                                        @fischi87:
                                        Enrico `
                                        okay alles klar, danke dir trotzdem!!!
                                        kann man sowas irgendwo nachlesen, gibt es da eine doku oder woher weiß man solche Sachen?
                                        32.7k
                                        82.6k
