  4. Dash Button Adapter lässt sich nicht installieren
    6.4k
23 Beiträge 6 Kommentatoren 4.0k Aufrufe
    martin
    /opt/iobroker$ sudo apt install git
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    Paketlisten werden gelesen...
    Abhängigkeitsbaum wird aufgebaut....
    Statusinformationen werden eingelesen....
    git ist schon die neueste Version (1:2.11.0-3+deb9u3).
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 264 nicht aktualisiert.
    /opt/iobroker$
    $ ./iobroker url "https://github.com/PArns/ioBroker.amazon-dash/tarball/master" amazon-dash
    install https://github.com/PArns/ioBroker.amazon-dash/tarball/master
    npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" (System call)
    npm WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security pam_appl.h="">
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.11.3
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
     #include <dns_sd.h>
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! not ok
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    gyp
     ERR! build error
    gyp
     ERR!
     System
     Linux 4.9.59-v7+gyp
    ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp ERR! not ok
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
    ERR! pcap@2.0.0 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm
     ERR! npm ERR! Failed at the pcap@2.0.0 install script.
    npm ERR!     /root/.npm/_logs/2018-08-04T18_32_34_614Z-debug.log
    ERROR: Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/amazon-dash/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/amazon-dash/io-package.json'
    process exited with code 0</pcap></dns_sd.h></security>
    • apollon77A Offline
      Das muss mit —unsafe-perm installiert werden in dem Fall.
      Bitte manuell per npm installieren und nicht per Admin und den genannten Parameter mit angeben. Und issue bei js-controller anlegen das der Adapter das braucht. Dann kommt er auf die Liste.
      Gesendet vom Handy …
        martin
        Und wie genau mache ich das? Kenne mich da leider nicht so gut aus.
          npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" --unsafe-perm
            js-controller 1.5.0 macht das dann später automatisch.
              martin
              Klappt leider immer noch nicht.
              > iobroker.amazon-dash@0.2.9 preinstall /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
              The following additional packages will be installed:
                libpcap0.8 libpcap0.8-dev
              Die folgenden NEUEN Pakete werden installiert:
                libpcap-dev libpcap0.8 libpcap0.8-dev
              0 aktualisiert, 3 neu installiert, 0 zu entfernen und 264 nicht aktualisiert.
              Es müssen 369 kB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 916 kB Plattenplatz zusätzlich benutzt.
              Holen:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libpcap0.8 armhf 1.8.1-3 [123 kB]
              Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian stretch/main armhf libpcap0.8-dev armhf 1.8.1-3 [220 kB]
              Holen:3 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian stretch/main armhf libpcap-dev all 1.8.1-3 [25,4 kB]
              debconf: kann Oberfläche nicht initialisieren: Dialog
              debconf: (Die Dialog-Oberfläche funktioniert nicht auf einem Dumb-Terminal, einem Emacs-Shellbuffer oder ohne ein steuerndes Terminal.)
              debconf: greife zurück auf die Oberfläche: Readline
              debconf: kann Oberfläche nicht initialisieren: Readline
              debconf: (Diese Oberfläche bedarf eines steuernden Terminals.)
              debconf: greife zurück auf die Oberfläche: Teletype
              dpkg-preconfigure: kann Stdin nicht wieder öffnen:
              Es wurden 369 kB in 0 s geholt (385 kB/s).
              Vormals nicht ausgewähltes Paket libpcap0.8:armhf wird gewählt.
              (Lese Datenbank ...
              (Lese Datenbank ... 5% (Lese Datenbank ... 10%
              (Lese Datenbank ... 15% (Lese Datenbank ... 20% (Lese Datenbank ... 25% (Lese Datenbank ... 30% (Lese Datenbank ... 35% (Lese Datenbank ... 40% (Lese Datenbank ... 45% (Lese Datenbank ... 50% (Lese Datenbank ... 55%
              (Lese Datenbank ... 60%
              (Lese Datenbank ... 65%
              (Lese Datenbank ... 70%
              (Lese Datenbank ... 75%
              (Lese Datenbank ... 80%
              (Lese Datenbank ... 85%
              (Lese Datenbank ... 90%
              (Lese Datenbank ... 95%
              (Lese Datenbank ... 100% (Lese Datenbank ...
              120689 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../libpcap0.8_1.8.1-3_armhf.deb ...
              Entpacken von libpcap0.8:armhf (1.8.1-3) ...
              Vormals nicht ausgewähltes Paket libpcap0.8-dev wird gewählt.
              Vorbereitung zum Entpacken von .../libpcap0.8-dev_1.8.1-3_armhf.deb ...
              Entpacken von libpcap0.8-dev (1.8.1-3) ...
              Vormals nicht ausgewähltes Paket libpcap-dev wird gewählt.
              Vorbereitung zum Entpacken von .../libpcap-dev_1.8.1-3_all.deb ...
              Entpacken von libpcap-dev (1.8.1-3) ...
              Trigger für libc-bin (2.24-11+deb9u1) werden verarbeitet ...
              Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
              libpcap0.8:armhf (1.8.1-3) wird eingerichtet ...
              libpcap0.8-dev (1.8.1-3) wird eingerichtet ...
              libpcap-dev (1.8.1-3) wird eingerichtet ...
              > socketwatcher@0.3.0 install /opt/iobroker/node_modules/socketwatcher
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/socketwatcher/build“ wird betreten
                CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
                SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
                COPY Release/socketwatcher.node
              make: Verzeichnis „/opt/iobroker/node_modules/socketwatcher/build“ wird verlassen
              > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
              #include <security pam_appl.h="">^
              authenticate_pam.target.mk:93: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
              make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
              gyp ERR! build error
              gyp
              ERR!
              gyp ERR! not ok
              > mdns@2.4.0 install /opt/iobroker/node_modules/mdns
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird betreten
                CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
              #include <dns_sd.h>^
              dns_sd_bindings.target.mk:150: die Regel für Ziel „Release/obj.target/dns_sd_bindings/src/dns_sd.o“ scheiterte
              make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
              gyp
              ERR! build error
              gyp
              gyp ERR!
              gyp
              gyp
              gyp
              gyp
              gyp
              v3.6.0
              gyp ERR!
              not ok
              > pcap@2.0.0 install /opt/iobroker/node_modules/pcap
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
                CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                CXX(target) Release/obj.target/pcap_binding/pcap_session.o
                SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
                COPY Release/pcap_binding.node
              make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
              iobroker@1.0.0 /opt/iobroker
              └─┬ iobroker.amazon-dash@0.2.9
                └─┬ pcap@2.0.0
                  └── socketwatcher@0.3.0  (git+https://github.com/bytzdev/node-socketwatcher.git#d252d3f8c45f565a0a48ebd155d4f9e4666798d9)
              npm
              WARN
              optional
              npm
              WARN
              optional
              npm
              WARN
              optional
              npm
              WARN
              connection lost .................................
              /opt/iobroker$</dns_sd.h></security>
                Installatiion ist aber erfolgreich durch. Die Fehler kommen von optionalen Paketen.
                Probier mal
                  martin
                  Inzwischen ist der Dash-Button-Adapter auch da. Nach der Installation war er noch nicht da.
                  Vielen Dank für eure Hilfe.
                  Ich werde es die nächsten Tage mal testen.
                  Eine Frage noch zum Dash-Button. Soll man mit dem 1 Bestellung bei Amazon tätigen um den Kaufpreis gutgeschrieben zu kriegen oder gleich im iobroker integrieren?
                  • ChaotC Offline
                    ChaotC Offline
                    Chaot
                    Ich habe mehrere Fehlermeldungen bei der Installation, aber am Ende kommt immer die Meldung Adapter installiert mit Code 0 - also sollte das erfolgreich gewesen sein.
                    Der Adapter startet, wird ganz kurz grün und dann rot.
                    Log:
                    host.haus	2018-08-11 23:33:58.158	info	Restart adapter system.adapter.amazon-dash.0 because enabled
                    host.haus	2018-08-11 23:33:58.158	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                    Caught	2018-08-11 23:33:58.158	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                    Caught	2018-08-11 23:33:58.158	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Adapter.emit (events.js:208:7)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at emitNone (events.js:106:13)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                    Caught	2018-08-11 23:33:58.157	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                    Caught	2018-08-11 23:33:58.156	error	by controller[0]: Error: socket: Operation not permitted
                    amazon-dash.0	2018-08-11 23:33:58.137	info	terminating
                    amazon-dash.0	2018-08-11 23:33:58.124	info	cleaned everything up...
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Adapter.emit (events.js:208:7)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at emitNone (events.js:106:13)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                    amazon-dash.0	2018-08-11 23:33:58.123	error	Error: socket: Operation not permitted
                    amazon-dash.0	2018-08-11 23:33:58.123	error	uncaught exception: socket: Operation not permitted
                    amazon-dash.0	2018-08-11 23:33:58.116	info	starting pcap session on default interface
                    amazon-dash.0	2018-08-11 23:33:58.111	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.3
                    amazon-dash.0	2018-08-11 23:33:58.083	info	States connected to redis: 127.0.0.1:6379</anonymous></anonymous></anonymous></anonymous>
                      Unter welchem User läuft denn drin ioBroker?
                      Operation not permitted weißt an sich auf User/rechte Themen hin.
                      • ChaotC Offline
                        ChaotC Offline
                        Chaot
                        Der läuft als Admin.
                        Kann ich die Rechte ändern? Wie funktioniert das?
                          Admin? Du meinst root?
                          • ChaotC Offline
                            ChaotC Offline
                            Chaot
                            Ok, jetzt wird es vermutlich kompliziert
                            Der im Adapter eingesetzte Nutzer nennt sich Admin.
                            Allerdings scheint der keine Root-Rechte zu haben wenn ich m ir die Fehlermeldungen bei der Adapterinstallation so anschaue. "…missing permission..."
                            Wie bekomme ich den Adapter bzw. ioBroker dazu das er rootRechte hat?
                            Braucht er die zwingend?
                            Ach, und warum hat der Adapter vorher funktioniert?
                            • ChaotC Offline
                              ChaotC Offline
                              Chaot
                              :roll: :roll: :roll:
                              Ich vergesse das immer wieder :roll: :roll: :roll: :roll:
                              Update des JS Controler und der Dash läuft. :idea:
                              • ChaotC Offline
                                ChaotC Offline
                                Chaot
                                Nach dem letzten Update des JS-Controlers auf 1.5.3
                                funktionieren die blöden Dash Button wieder mal nicht:
                                host.haus	2018-09-15 22:37:51.275	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:25)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:830:13)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:54)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5290:18)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter.emit (events.js:208:7)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at emitNone (events.js:106:13)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
                                Caught	2018-09-15 22:37:51.275	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                                Caught	2018-09-15 22:37:51.274	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                                Caught	2018-09-15 22:37:51.274	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
                                Caught	2018-09-15 22:37:51.274	error	by controller[0]: Error: socket: Operation not permitted
                                host.haus	2018-09-15 22:37:50.499	info	instance system.adapter.amazon-dash.0 started with pid 2380</anonymous>
                                • U Offline
                                  U Offline
                                  ulistermclane
                                  Hallo Leute,
                                  ich kämpfe auch mit dem dash button adapter. Hier der output bei der Installation auf der Kommandozeile:
                                  uli@KNX-Kiste:/opt/iobroker$ sudo npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" --unsafe-perms
                                  [sudo] Passwort für uli:
                                  npm ERR! code 128
                                  npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
                                  npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-260a6434': Keine Berechtigung
                                  npm ERR!
                                  npm ERR!     /root/.npm/_logs/2018-11-19T15_51_20_244Z-debug.log
                                  uli@KNX-Kiste:
                                  Das debug.log ist auch nicht aufschlussreicher. Installation über die GUI liefert gleiches Ergebnis. libpcap-dev ist installiert, git ist installiert.
                                  npm -v: 6.4.1
                                  node -v: 8.12.0
                                  Bin dankbar für jeden Hinweis.
                                  Adapter: knx, owfs, mqtt, modbus, kodi, iCal, landroid, TR064, Luftdaten, Unifi, amazon-dash, js2fs
                                  HW: Fujitsu Futro S900, 4GB RAM, 32GB SSD, Selbstbau KNX Adapter mit Siemens BCU
                                  OS: Debian Stretch
                                    läuft als root?
                                    • U Offline
                                      U Offline
                                      ulistermclane
                                      ja, läuft auf root (sudo iobroker start)
                                      OS: Debian Stretch
