  4. Iobroker im Rock64 per Browser nicht zu erreichen.
    1.0k
    6.1k
39 Beiträge 5 Kommentatoren 3.8k Aufrufe
  • chucky666C Online
    chucky666C Online
    chucky666
    `2018-07-20 13:41:52.046  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 2a02:908:1e42:6660:38:a0ff:fe82:2dc0 fe80::38:a0ff:fe82:2dc0
    2018-07-20 13:41:52.115  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-07-20 13:41:52.169  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-07-20 13:41:52.202  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-07-20 13:41:52.251  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    2018-07-20 17:22:55.501  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-07-20 17:22:55.512  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-07-20 17:25:41.310  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.2 js-controller starting
    2018-07-20 17:25:41.329  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-07-20 17:25:41.331  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.3
    2018-07-20 17:25:41.334  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.73 2a02:908:1e42:6660:38:a0ff:fe82:2dc0 fe80::38:a0ff:fe82:2dc0
    2018-07-20 17:25:41.499  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-07-20 17:25:41.548  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-07-20 17:25:41.580  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-07-20 17:25:41.626  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    2018-07-20 17:29:01.436  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-07-20 17:29:01.447  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-07-20 17:29:07.877  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.2 js-controller starting
    2018-07-20 17:29:07.895  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-07-20 17:29:07.898  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.3
    2018-07-20 17:29:07.900  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.73 2a02:908:1e42:6660:38:a0ff:fe82:2dc0 fe80::38:a0ff:fe82:2dc0
    2018-07-20 17:29:08.060  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-07-20 17:29:08.111  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-07-20 17:29:08.144  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-07-20 17:29:08.191  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    2018-07-20 17:39:27.479  - [31merror[39m: vis.0 setObject id missing!!
    2018-07-20 17:39:27.531  - [33mwarn[39m: vis.0 setObject control.instance (type=state) property common.role missing!
    2018-07-20 17:39:27.544  - [33mwarn[39m: vis.0 setObject control.command (type=state) property common.role missing!
    2018-07-20 17:39:27.557  - [33mwarn[39m: vis.0 setObject control.data (type=state) property common.role missing!
    2018-07-20 17:39:27.574  - [32minfo[39m: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.3
    2018-07-20 17:39:27.691  - [32minfo[39m: vis.0 Changes in index.html detected => update cache.manifest
    2018-07-20 17:39:27.704  - [31merror[39m: vis.0 No license found for vis. Please get one on https://iobroker.net !
    2018-07-20 17:50:36.358  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-07-20 17:50:36.368  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-07-20 17:51:04.239  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.2 js-controller starting
    2018-07-20 17:51:04.258  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-07-20 17:51:04.260  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.3
    2018-07-20 17:51:04.262  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.73 2a02:908:1e42:6660:38:a0ff:fe82:2dc0 fe80::38:a0ff:fe82:2dc0
    2018-07-20 17:51:04.427  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-07-20 17:51:04.476  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-07-20 17:51:04.509  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-07-20 17:51:04.557  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    /code]
    [code]root@ioBroker-Rock64:/opt/iobroker# iobroker start admin.0
    Adapter "admin.0" does not exist.
    root@ioBroker-Rock64:/opt/iobroker# /code]`[/code]
    • paul53P Offline
      Es läuft nur der js-controller und keine Adapter. Dann solltest Du nach http://www.iobroker.net/docu/?page_id=3928&lang=de#Ein_Adapter_oder_js-controller_neu_installieren admin installieren.
        Ich würde vorher gerne noch etwas klären.
        Kann ja eigentlich nicht sein, dass alle Adapter weg sind - die waren ja da, oder?
        1.) hast du ein halbwegs aktuelles update?
        • oder ist das ganz frisch?
        2.) Hast du die Installation auf SD, Nand oder SSD/HDD?
        3.) Hast du irgendetwas (z.B. über armbian-config) konfiguriert gehabt?
        rainer
        • chucky666C Online
          chucky666C Online
          chucky666
          Installiert ist das System seit Februar, seit gestern war alles aktuell. Ich wollte heute morgen einen komplett Neustart machen , und danach war Iobroker nicht mehr da .
          System läuft auf eine ssd am usb 3 Port
          Gesendet von iPad mit Tapatalk Pro
          • paul53P Offline
            @Homoran:
            Kann ja eigentlich nicht sein, dass alle Adapter weg sind - die waren ja da, oder? `
            Es sollte sich feststellen lassen, welche Adapter installiert sind (waren)
            ls -l /opt/iobroker/node_modules/iob*
            Hoffentlich ist nicht die objects.json zerschossen ?
            ls -l /opt/iobroker/iobroker-data/obj*
            Gibt es ein Backup ?
            • chucky666C Online
              chucky666C Online
              chucky666
              <code>root@ioBroker-Rock64:/opt/iobroker# ls -l /opt/iobroker/iobroker-data/obj*
              -rw-r--r-- 1 root root 17561 Jul 20 17:51 /opt/iobroker/iobroker-data/objects.json
              -rw-r--r-- 1 root root 17761 Jul 20 17:51 /opt/iobroker/iobroker-data/objects.json.bak/code]
              ist das so richtig?
              adapter zeigt er an</code>
              • paul53P Offline
                Die objects.json ist verdächtig klein. Gibt es ein Backup ?
                @chucky666:
                adapter zeigt er an `
                Auch iobroker.admin ?
                • paul53P Offline
                  @chucky666:
                  seit gestern war alles aktuell. `
                  Dann müsste es automatische Backups von gestern im Verzeichnis /opt/iobroker/iobroker-data/backup-objects geben. Was ergibt ?
                  ls -l /opt/iobroker/iobroker-data/backup-objects
                  • chucky666C Online
                    chucky666C Online
                    chucky666
                    ja sind ein paar backups zu sehen
                    den admin zeigt er auch an
                    • paul53P Offline
                      Dann sind sicherlich einige (ältere) Backup-Dateien erheblich größer als 17 kB ? Daraus sollte sich eine funktionierende objects.json erzeugen lassen.
                      • chucky666C Online
                        chucky666C Online
                        chucky666
                        Die sind teils von gestern , viele größer als 17
                        • paul53P Offline
                          Dann unzippe eine der "großen" Dateien von gestern und kopiere sie (hh-mm steht für die tatsächliche Uhrzeit). Vorher ioBroker stoppen !
                          cd /opt/iobroker/iobroker-data/backup-objects
                          gunzip 2018-07-19_hh-mm_objects.json.gz
                          iobroker stop
                          cp 2018-07-19_hh-mm_objects.json /opt/iobroker/iobroker-data/objects.json
                          iobroker start
                          Viel Glück !
                          • chucky666C Online
                            chucky666C Online
                            chucky666
                            Danke teste ich gleich mal
                            • chucky666C Online
                              chucky666C Online
                              chucky666
                              Ich habe mit einem alten Backup das System wieder ans laufen bekommen .
                              Das Problem scheint beim Rock zu liegen , immer wenn das System Neustartet oder Stromlos war. Ist das System nicht mehr erreichbar . Leider finde ich das Problem nicht
                                Das kann ein andere ursahe haben.
                                Evtl. Ist der Autostart disabled.
                                Gruß Rainer
                                • chucky666C Online
                                  chucky666C Online
                                  chucky666
                                  Ok und wie schalte ich den an ?
                                    update-rc.d iobroker.sh defaults
                                    reboot
                                    • paul53P Offline
                                      @Homoran: Das wird nicht reichen, denn im Image fehlt anscheinend die Datei iobroker.sh. https://forum.iobroker.net/viewtopic.php?f=34&t=7019&start=300#p153021
