Modbus Adapter killt sich selbst?
1.4.2 (auf beiden Hosts).
Node gerade die Woche auf 6.x aktualisiert (beide Hosts)
Hier noch etwas zusätzlicher Input:
host.iobroker 2018-05-18 00:36:24.720 error instance system.adapter.modbus.0 terminated with code 0 (OK) Caught 2018-05-18 00:36:24.720 error by controller[4]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-05-18 00:36:24.720 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-05-18 00:36:24.719 error by controller[4]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-05-18 00:36:24.719 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-05-18 00:36:24.718 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-05-18 00:36:24.718 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-05-18 00:36:24.717 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-05-18 00:36:24.717 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-05-18 00:36:24.717 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-05-18 00:36:24.717 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-05-18 00:36:24.716 error by controller[4]: 2018-05-18 00:36:24.624 - error: modbus.0 TypeError: adapter.stop is not a function Caught 2018-05-18 00:36:24.716 error by controller[4]: 2018-05-18 00:36:24.623 - error: modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-05-18 00:36:24.716 error by controller[4]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-05-18 00:36:24.716 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-05-18 00:36:24.716 error by controller[4]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-05-18 00:36:24.715 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-05-18 00:36:24.715 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-05-18 00:36:24.715 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-05-18 00:36:24.715 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-05-18 00:36:24.715 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-05-18 00:36:24.714 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-05-18 00:36:24.714 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-05-18 00:36:24.714 error by controller[4]: TypeError: adapter.stop is not a function Caught 2018-05-18 00:36:24.713 error by controller[4]: 2018-05-18 00:36:24.619 - modbus.0 Reconnect did not help, restart adapter Caught 2018-05-18 00:36:24.712 error by controller[3]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-05-18 00:36:24.712 error by controller[3]: at tryOnTimeout (timers.js:250:5) Caught 2018-05-18 00:36:24.712 error by controller[3]: at ontimeout (timers.js:386:11) Caught 2018-05-18 00:36:24.711 error by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-05-18 00:36:24.711 error by controller[3]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-05-18 00:36:24.711 error by controller[3]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-05-18 00:36:24.711 error by controller[3]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-05-18 00:36:24.711 error by controller[3]: 2018-05-18 00:36:24.612 - modbus.0 TypeError: adapter.stop is not a function Caught 2018-05-18 00:36:24.710 error by controller[2]: 2018-05-18 00:36:24.611 - modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-05-18 00:36:24.710 error by controller[1]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-05-18 00:36:24.710 error by controller[1]: at tryOnTimeout (timers.js:250:5) Caught 2018-05-18 00:36:24.709 error by controller[1]: at ontimeout (timers.js:386:11) Caught 2018-05-18 00:36:24.709 error by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-05-18 00:36:24.709 error by controller[1]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-05-18 00:36:24.709 error by controller[1]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-05-18 00:36:24.708 error by controller[1]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-05-18 00:36:24.706 error by controller[1]: TypeError: adapter.stop is not a function Caught 2018-05-18 00:36:24.696 error by controller[0]: 2018-05-18 00:36:24.602 - modbus.0 Reconnect did not help, restart adapter
Installier nochmal neu vom Github und danach aber manuell die Instanz neu starten. Jetzt?
Aber ja - wenn der Adapter die Verbindung verliert und nicht wieder herstellen kann in mehreren Versuchen dann startet er sich selbst neu weil das eine Lösung ist die sich bewiesen hat. Warum das geht und nicht verbindung an sich neu ist noch unbekannt
So, im Moment sieht es so aus als würde es funktionieren.
Die Installation zieht sich offenbar irgendwas "hinterher" (siehe 2018-05-18 22:25:39.198). Hier mal das Installprotokoll (habe modbus.2 zum Upgrade genommen und danach .1 und .0 neu gestartet).
2018-05-18 22:19:54.077 - info: iobroker url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus 2018-05-18 22:19:55.008 - info: iobroker install https://github.com/ioBroker/ioBroker.modbus/tarball/master 2018-05-18 22:19:56.217 - info: iobroker npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --save --prefix "/opt/iobroker" (System call) 2018-05-18 22:21:43.793 - info: iobroker npm 2018-05-18 22:21:43.805 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/dashdash/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/engine.io-client/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/engine.io-parser/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/has-binary/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socket.io-client/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/sshpk/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar-pack/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar.gz/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utile/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/node_modules/sshpk/package.json' npm ERR! Linux 3.16.0-4-amd64 npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.modbus/tarball/master" "--production" "--save" "--prefix" "/opt/iobroker" npm ERR! node v6.14.2 npm ERR! npm v3.10.10 2018-05-18 22:21:43.812 - info: iobroker npm ERR! path /opt/iobroker/node_modules/.staging/minimist-af8b260cnpm ERR! code ENOENT npm ERR! errno -2 npm ERR! syscall rename npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/minimist-af8b260c' -> '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist' 2018-05-18 22:21:43.830 - info: iobroker npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/minimist-af8b260c' -> '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist'npm ERR! enoent This is most likely not a problem with npm itself npm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent 2018-05-18 22:21:44.244 - info: iobroker 2018-05-18 22:21:44.245 - info: iobroker npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log npm ERR! code 1 2018-05-18 22:21:44.365 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json' 2018-05-18 22:21:44.399 - info: iobroker exit 0 2018-05-18 22:21:45.102 - info: host.iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json" 2018-05-18 22:25:36.671 - info: host.iobroker object change system.adapter.modbus.2 2018-05-18 22:25:36.680 - info: host.iobroker stopInstance system.adapter.modbus.2 2018-05-18 22:25:36.682 - info: host.iobroker stopInstance system.adapter.modbus.2 killing pid 29357 2018-05-18 22:25:36.726 - info: modbus.2 terminating 2018-05-18 22:25:36.792 - info: host.iobroker instance system.adapter.modbus.2 terminated with code 0 (OK) 2018-05-18 22:25:39.198 - warn: host.iobroker startInstance cannot find adapter "modbus". Try to install it... 1 attempt 2018-05-18 22:25:39.199 - info: iobroker install modbus 2018-05-18 22:25:42.274 - info: iobroker NPM version: 3.10.10 2018-05-18 22:25:43.197 - info: iobroker npm install iobroker.modbus --production --save --prefix "/opt/iobroker" (System call) 2018-05-18 22:26:26.436 - info: host.iobroker object change system.adapter.modbus.1 2018-05-18 22:26:26.439 - info: host.iobroker stopInstance system.adapter.modbus.1 2018-05-18 22:26:26.439 - info: host.iobroker stopInstance system.adapter.modbus.1 killing pid 29341 2018-05-18 22:26:26.487 - info: modbus.1 terminating 2018-05-18 22:26:26.556 - info: host.iobroker instance system.adapter.modbus.1 terminated with code 0 (OK) 2018-05-18 22:26:27.494 - info: host.iobroker object change system.adapter.modbus.0 2018-05-18 22:26:27.494 - info: host.iobroker stopInstance system.adapter.modbus.0 2018-05-18 22:26:27.495 - info: host.iobroker stopInstance system.adapter.modbus.0 killing pid 29385 2018-05-18 22:26:27.532 - info: modbus.0 terminating 2018-05-18 22:26:27.586 - info: host.iobroker instance system.adapter.modbus.0 terminated with code 0 (OK) 2018-05-18 22:27:07.707 - info: iobroker node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.3.1/usb_bindings-v1.3.1-node-v48-linux-x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.14.2 (node-v48 ABI, glibc) (falling back to source compile with node-gyp) 2018-05-18 22:27:17.309 - info: iobroker ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden #include ^ compilation terminated. 2018-05-18 22:27:17.622 - info: iobroker make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1 2018-05-18 22:27:17.632 - info: iobroker gyp 2018-05-18 22:27:17.637 - info: iobroker ERR! build error 2018-05-18 22:27:17.642 - info: iobroker gyp 2018-05-18 22:27:17.643 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:106:13) gyp ERR! stack at ChildProcess.emit (events.js:191:7) 2018-05-18 22:27:17.644 - info: iobroker gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp 2018-05-18 22:27:17.646 - info: iobroker ERR! System Linux 3.16.0-4-amd64gyp 2018-05-18 22:27:17.651 - info: iobroker ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/usb gyp ERR! node -v v6.14.2 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok 2018-05-18 22:27:17.663 - info: iobroker node-pre-gyp ERR! build error 2018-05-18 22:27:17.665 - info: iobroker node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding' (1)node-pre-gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/iobroker.radar/node_modules/node-pre-gyp/lib/util/compile.js:83:29) node-pre-gyp ERR! 2018-05-18 22:27:17.669 - info: iobroker stack at emitTwo (events.js:106:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7) node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16) node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5) node-pre-gyp ERR! System Linux 3.16.0-4-amd64 node-pre-gyp ERR! 2018-05-18 22:27:17.671 - info: iobroker command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.radar/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/usb 2018-05-18 22:27:17.673 - info: iobroker node-pre-gyp ERR! node -v v6.14.2 2018-05-18 22:27:17.674 - info: iobroker node-pre-gyp ERR! node-pre-gyp -v v0.6.39node-pre-gyp ERR! not ok 2018-05-18 22:27:38.574 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/dashdash/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/engine.io-client/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/engine.io-parser/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/has-binary/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prompt/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socket.io-client/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/sshpk/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar-pack/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar.gz/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/usb/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utile/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/node_modules/sshpk/package.json' npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/iobroker.radar/node_modules/usb): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: `node-pre-gyp install --fallback-to-build` npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 2018-05-18 22:27:38.750 - info: iobroker host.iobroker object system.adapter.modbus created 2018-05-18 22:27:38.880 - info: iobroker got /opt/iobroker/node_modules/iobroker.modbus/admin 2018-05-18 22:27:38.909 - info: iobroker upload [11] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/words.js words.js application/javascript 2018-05-18 22:27:39.002 - info: iobroker upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png 2018-05-18 22:27:39.065 - info: iobroker upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript 2018-05-18 22:27:39.130 - info: iobroker upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript 2018-05-18 22:27:39.200 - info: iobroker upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript 2018-05-18 22:27:39.261 - info: iobroker upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript 2018-05-18 22:27:39.329 - info: iobroker upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css 2018-05-18 22:27:39.389 - info: iobroker upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css 2018-05-18 22:27:39.448 - info: iobroker upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css 2018-05-18 22:27:39.516 - info: iobroker upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css 2018-05-18 22:27:39.591 - info: iobroker upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html 2018-05-18 22:27:39.665 - info: iobroker upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png 2018-05-18 22:27:39.779 - info: iobroker exit 0 2018-05-18 22:27:39.809 - info: host.iobroker instance system.adapter.modbus.2 started with pid 5129 2018-05-18 22:27:41.052 - info: modbus.2 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.2 2018-05-18 22:27:41.442 - info: sql.0 enabled logging of modbus.2.inputRegisters.100_100_CP-Status 2018-05-18 22:27:41.508 - info: sql.0 enabled logging of modbus.2.inputRegisters.120_120_W_L1-N 2018-05-18 22:27:41.526 - info: sql.0 enabled logging of modbus.2.inputRegisters.128_128_total_kwh 2018-05-18 22:27:41.845 - info: modbus.2 Connected to slave evcc 2018-05-18 22:27:47.333 - info: robonect.0 Polling done (Status) 2018-05-18 22:28:38.723 - info: nut.0 Start NUT update 2018-05-18 22:28:38.748 - info: nut.0 All Nut values set 2018-05-18 22:28:47.348 - info: robonect.0 Polling done (Status) 2018-05-18 22:29:38.729 - info: nut.0 Start NUT update 2018-05-18 22:29:38.769 - info: nut.0 All Nut values set 2018-05-18 22:29:47.357 - info: robonect.0 Polling done (Status) 2018-05-18 22:29:55.734 - info: host.iobroker object change system.adapter.modbus.1 2018-05-18 22:29:55.774 - info: host.iobroker instance system.adapter.modbus.1 started with pid 5742 2018-05-18 22:29:57.116 - info: modbus.1 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.2 2018-05-18 22:29:57.398 - info: sql.0 enabled logging of modbus.1.inputRegisters.30001_VAC_L1-N 2018-05-18 22:29:57.437 - info: sql.0 enabled logging of modbus.1.inputRegisters.30003_VAC_L2-N 2018-05-18 22:29:57.447 - info: sql.0 enabled logging of modbus.1.inputRegisters.30005_VAC_L3-N 2018-05-18 22:29:57.662 - info: sql.0 enabled logging of modbus.1.inputRegisters.30053_WAC_Gesamt 2018-05-18 22:29:57.688 - info: sql.0 enabled logging of modbus.1.inputRegisters.30073_Zaehlerstand 2018-05-18 22:29:58.036 - info: modbus.1 Connected to slave 192.168.1.109 2018-05-18 22:30:00.038 - info: host.iobroker instance system.adapter.dwd.0 started with pid 5752 2018-05-18 22:30:00.063 - info: host.iobroker instance system.adapter.ical.0 started with pid 5758 2018-05-18 22:30:00.095 - info: host.iobroker instance system.adapter.ical.1 started with pid 5764 2018-05-18 22:30:19.333 - info: host.iobroker object change system.adapter.modbus.0 2018-05-18 22:30:19.355 - info: host.iobroker instance system.adapter.modbus.0 started with pid 5782 2018-05-18 22:30:20.637 - info: modbus.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.2 2018-05-18 22:30:20.889 - info: sql.0 disabled logging of modbus.0.holdingRegisters.40080_VAC_L1-N 2018-05-18 22:30:20.928 - info: sql.0 disabled logging of modbus.0.holdingRegisters.40081_VAC_L2-N 2018-05-18 22:30:20.941 - info: sql.0 disabled logging of modbus.0.holdingRegisters.40082_VAC_L3-N 2018-05-18 22:30:20.971 - info: sql.0 enabled logging of modbus.0.holdingRegisters.40085_ACPF 2018-05-18 22:30:21.345 - info: modbus.0 Connected to slave 192.168.1.27 2018-05-18 22:30:26.556 - warn: modbus.0 Poll error count: 1 code: "App Timeout"
Und wie schaut es aus?
Nicht wirklich gut… gerade ist der Adapter mal wieder hops gegangen, hat sich neu gestartet und alles lief perfekt..
Er erzählt halt auch die ganze Zeit was von App Timeout, aber wenn ich mit einem anderen Programm auf den Bus schaue, ist die Gegenstelle da und alles ist schick, egal was ich anfrage, die Kiste antwortet sofort..
modbus.0 2018-06-13 23:32:48.311 info Connected to slave 192.168.1.27 sql.0 2018-06-13 23:32:47.962 info enabled logging of modbus.0.holdingRegisters.40085_ACPF sql.0 2018-06-13 23:32:47.938 info enabled logging of modbus.0.holdingRegisters.40084_CurrentPower-AC sql.0 2018-06-13 23:32:47.918 info disabled logging of modbus.0.holdingRegisters.40082_VAC_L3-N sql.0 2018-06-13 23:32:47.899 info disabled logging of modbus.0.holdingRegisters.40081_VAC_L2-N sql.0 2018-06-13 23:32:47.848 info disabled logging of modbus.0.holdingRegisters.40080_VAC_L1-N modbus.0 2018-06-13 23:32:47.559 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.2 host.iobroker 2018-06-13 23:32:46.149 info instance system.adapter.modbus.0 started with pid 18586 host.iobroker 2018-06-13 23:32:16.117 info Restart adapter system.adapter.modbus.0 because enabled host.iobroker 2018-06-13 23:32:16.116 error instance system.adapter.modbus.0 terminated with code 0 (OK) Caught 2018-06-13 23:32:16.115 error by controller[6]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-06-13 23:32:16.115 error by controller[6]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-06-13 23:32:16.115 error by controller[6]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-06-13 23:32:16.114 error by controller[6]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.114 error by controller[6]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.113 error by controller[6]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.113 error by controller[6]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.112 error by controller[6]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.112 error by controller[6]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.111 error by controller[6]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.111 error by controller[6]: 2018-06-13 23:32:16.029 - modbus.0 TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.110 error by controller[5]: 2018-06-13 23:32:16.028 - error: modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-06-13 23:32:16.110 error by controller[5]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-06-13 23:32:16.110 error by controller[5]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-06-13 23:32:16.109 error by controller[5]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-06-13 23:32:16.109 error by controller[5]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.108 error by controller[5]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.108 error by controller[5]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.108 error by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.107 error by controller[5]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.107 error by controller[5]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.106 error by controller[5]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.106 error by controller[5]: TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.105 error by controller[5]: 2018-06-13 23:32:16.024 - modbus.0 Reconnect did not help, restart adapter Caught 2018-06-13 23:32:16.105 error by controller[4]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-06-13 23:32:16.104 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-06-13 23:32:16.104 error by controller[4]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-06-13 23:32:16.103 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.103 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.102 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.102 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.102 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.101 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.101 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.100 error by controller[4]: 2018-06-13 23:32:16.021 - error: modbus.0 TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.100 error by controller[4]: 2018-06-13 23:32:16.020 - error: modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-06-13 23:32:16.099 error by controller[4]: at process._tickCallback (internal/process/next_tick.js:104:9) Caught 2018-06-13 23:32:16.099 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:77:11) Caught 2018-06-13 23:32:16.098 error by controller[4]: at listOnTimeoutNT (timers.js:276:26) Caught 2018-06-13 23:32:16.098 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.098 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.095 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.094 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.094 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.094 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.093 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.093 error by controller[4]: TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.093 error by controller[4]: 2018-06-13 23:32:16.017 - error: modbus.0 Reconnect did not help, restart adapter Caught 2018-06-13 23:32:16.092 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.092 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.091 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.091 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.091 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.090 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.090 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.089 error by controller[4]: 2018-06-13 23:32:16.014 - error: modbus.0 TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.089 error by controller[4]: 2018-06-13 23:32:16.012 - error: modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-06-13 23:32:16.089 error by controller[4]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.088 error by controller[4]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.088 error by controller[4]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.087 error by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.087 error by controller[4]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.087 error by controller[4]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.086 error by controller[4]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.086 error by controller[4]: TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.085 error by controller[4]: 2018-06-13 23:32:16.009 - modbus.0 Reconnect did not help, restart adapter Caught 2018-06-13 23:32:16.085 error by controller[3]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.085 error by controller[3]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.084 error by controller[3]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.084 error by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.084 error by controller[3]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.083 error by controller[3]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.083 error by controller[3]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.083 error by controller[3]: 2018-06-13 23:32:15.991 - modbus.0 TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.082 error by controller[2]: 2018-06-13 23:32:15.990 - modbus.0 uncaught exception: adapter.stop is not a function Caught 2018-06-13 23:32:16.082 error by controller[1]: at Timer.listOnTimeout (timers.js:214:5) Caught 2018-06-13 23:32:16.081 error by controller[1]: at tryOnTimeout (timers.js:250:5) Caught 2018-06-13 23:32:16.081 error by controller[1]: at ontimeout (timers.js:386:11) Caught 2018-06-13 23:32:16.081 error by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) Caught 2018-06-13 23:32:16.080 error by controller[1]: at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) Caught 2018-06-13 23:32:16.080 error by controller[1]: at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) Caught 2018-06-13 23:32:16.079 error by controller[1]: at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 Caught 2018-06-13 23:32:16.079 error by controller[1]: TypeError: adapter.stop is not a function Caught 2018-06-13 23:32:16.077 error by controller[0]: 2018-06-13 23:32:15.981 - modbus.0 Reconnect did not help, restart adapter modbus.0 2018-06-13 23:32:16.029 error at process._tickCallback (internal/process/next_tick.js:104:9) modbus.0 2018-06-13 23:32:16.029 error at _combinedTickCallback (internal/process/next_tick.js:77:11) modbus.0 2018-06-13 23:32:16.029 error at listOnTimeoutNT (timers.js:276:26) modbus.0 2018-06-13 23:32:16.029 error at Timer.listOnTimeout (timers.js:214:5) modbus.0 2018-06-13 23:32:16.029 error at tryOnTimeout (timers.js:250:5) modbus.0 2018-06-13 23:32:16.029 error at ontimeout (timers.js:386:11) modbus.0 2018-06-13 23:32:16.029 error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) modbus.0 2018-06-13 23:32:16.029 error at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) modbus.0 2018-06-13 23:32:16.029 error at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) modbus.0 2018-06-13 23:32:16.029 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 modbus.0 2018-06-13 23:32:16.029 error TypeError: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.026 error uncaught exception: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.024 error Reconnect did not help, restart adapter modbus.0 2018-06-13 23:32:16.022 warn Poll error count: 16 code: "App Timeout" modbus.0 2018-06-13 23:32:16.021 error at process._tickCallback (internal/process/next_tick.js:104:9) modbus.0 2018-06-13 23:32:16.021 error at _combinedTickCallback (internal/process/next_tick.js:77:11) modbus.0 2018-06-13 23:32:16.021 error at listOnTimeoutNT (timers.js:276:26) modbus.0 2018-06-13 23:32:16.021 error at Timer.listOnTimeout (timers.js:214:5) modbus.0 2018-06-13 23:32:16.021 error at tryOnTimeout (timers.js:250:5) modbus.0 2018-06-13 23:32:16.021 error at ontimeout (timers.js:386:11) modbus.0 2018-06-13 23:32:16.021 error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) modbus.0 2018-06-13 23:32:16.021 error at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) modbus.0 2018-06-13 23:32:16.021 error at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) modbus.0 2018-06-13 23:32:16.021 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 modbus.0 2018-06-13 23:32:16.021 error TypeError: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.019 error uncaught exception: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.017 error Reconnect did not help, restart adapter modbus.0 2018-06-13 23:32:16.016 warn Poll error count: 15 code: "App Timeout" modbus.0 2018-06-13 23:32:16.013 error at Timer.listOnTimeout (timers.js:214:5) modbus.0 2018-06-13 23:32:16.013 error at tryOnTimeout (timers.js:250:5) modbus.0 2018-06-13 23:32:16.013 error at ontimeout (timers.js:386:11) modbus.0 2018-06-13 23:32:16.013 error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) modbus.0 2018-06-13 23:32:16.013 error at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) modbus.0 2018-06-13 23:32:16.013 error at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) modbus.0 2018-06-13 23:32:16.013 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 modbus.0 2018-06-13 23:32:16.013 error TypeError: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.012 error uncaught exception: adapter.stop is not a function modbus.0 2018-06-13 23:32:16.009 error Reconnect did not help, restart adapter modbus.0 2018-06-13 23:32:16.008 warn Poll error count: 14 code: "App Timeout" modbus.0 2018-06-13 23:32:15.991 error at Timer.listOnTimeout (timers.js:214:5) modbus.0 2018-06-13 23:32:15.991 error at tryOnTimeout (timers.js:250:5) modbus.0 2018-06-13 23:32:15.991 error at ontimeout (timers.js:386:11) modbus.0 2018-06-13 23:32:15.991 error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.modbus/main.js:2235:18) modbus.0 2018-06-13 23:32:15.991 error at Object.pollResult (/opt/iobroker/node_modules/iobroker.modbus/main.js:2201:17) modbus.0 2018-06-13 23:32:15.991 error at stop (/opt/iobroker/node_modules/iobroker.modbus/main.js:88:19) modbus.0 2018-06-13 23:32:15.991 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:2202:29 modbus.0 2018-06-13 23:32:15.991 error TypeError: adapter.stop is not a function modbus.0 2018-06-13 23:32:15.990 error uncaught exception: adapter.stop is not a function modbus.0 2018-06-13 23:32:15.981 error Reconnect did not help, restart adapter modbus.0 2018-06-13 23:32:15.979 warn Poll error count: 13 code: "App Timeout" modbus.0 2018-06-13 23:32:15.898 warn Poll error count: 12 code: "App Timeout" modbus.0 2018-06-13 23:32:15.861 warn Poll error count: 11 code: "App Timeout" modbus.0 2018-06-13 23:32:15.855 warn Poll error count: 10 code: "App Timeout" modbus.0 2018-06-13 23:32:15.793 warn Poll error count: 9 code: "App Timeout" modbus.0 2018-06-13 23:32:15.762 warn Poll error count: 8 code: "App Timeout" modbus.0 2018-06-13 23:32:15.748 warn Poll error count: 7 code: "App Timeout" modbus.0 2018-06-13 23:32:15.630 warn Poll error count: 6 code: "App Timeout" modbus.0 2018-06-13 23:32:15.627 warn Poll error count: 5 code: "App Timeout" modbus.0 2018-06-13 23:32:11.135 warn Poll error count: 4 code: "App Timeout" modbus.0 2018-06-13 23:32:11.134 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:11.132 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:11.130 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:11.099 warn On error: {} modbus.0 2018-06-13 23:32:11.078 info Disconnected from slave 192.168.1.27 modbus.0 2018-06-13 23:32:11.075 warn Poll error count: 6 code: "App Timeout" modbus.0 2018-06-13 23:32:11.070 warn Poll error count: 5 code: "App Timeout" modbus.0 2018-06-13 23:32:11.070 warn Poll error count: 4 code: "App Timeout" modbus.0 2018-06-13 23:32:11.056 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:11.055 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:11.051 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:11.003 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:11.002 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:10.994 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.946 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.942 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:10.940 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.924 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.897 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:10.892 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.875 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.824 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.751 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.729 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:10.724 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.708 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:10.590 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:06.005 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:05.998 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:05.997 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.977 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.966 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.884 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:05.881 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.853 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:05.852 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.803 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.737 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.696 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:05.689 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:05.558 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.940 warn Poll error count: 4 code: "App Timeout" modbus.0 2018-06-13 23:32:00.934 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:00.932 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:00.931 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.829 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:00.824 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.795 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:32:00.794 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:32:00.792 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.704 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.670 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:32:00.523 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:55.911 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:55.773 warn Poll error count: 4 code: "App Timeout" modbus.0 2018-06-13 23:31:55.765 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:31:55.756 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:55.743 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:55.653 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:55.649 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:55.635 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:55.500 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.751 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.731 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.728 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.616 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:50.607 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.585 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:50.468 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:45.713 warn Poll error count: 3 code: "App Timeout" modbus.0 2018-06-13 23:31:45.707 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:45.582 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:45.562 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:45.444 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:40.548 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:40.527 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:40.409 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:35.523 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:35.511 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:35.381 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:30.491 warn Poll error count: 2 code: "App Timeout" modbus.0 2018-06-13 23:31:30.352 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:25.319 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:20.298 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:15.272 warn Poll error count: 1 code: "App Timeout" modbus.0 2018-06-13 23:31:03.480 info Connected to slave 192.168.1.27
Ok, hm … jetzt sind wir inzwischen an dem Punkt das bluefox eine 2.0.2 auf Github hat. Weiter auf der 1.1.1 zu untersuchen wird schwierig ...
2.0.2 ist nur auf Github und ich habe es selbst noch nicht versucht. testing ist grün.
Mag jemand experimentieren?
Habe drei Instanzen von Version 1.1.1 laufen ohne Probleme.
Hast du mal versucht die Instanzen und Adapter komplett zu löschen und neu zu installieren?
Hast du nur Node oder auch NPM upgrade gemacht?
Wie hast du den Node upgrade gemacht? Gibt es davon noch ein log?
Ja, ich habe die Adapter komplett weggetreten und neu installiert. Vorher habe ich Node, NPM und alles was es sonst noch gibt aktualisiert (apt-get update && apt-get upgrade). Ein Log habe ich davon nicht mehr, sorry.
Welches Linux? Jessie, Stretch?
Dann upgrade ohne „-get“ und nur „apt“ verwenden.
Was kommt denn bei
npm -v node -v nodejs -v
Vllt ist es Zeit dann mal die 2.0.x zu testen: viewtopic.php?f=36&t=14929
Hier die gefragten Versionen:
root@iobroker:~# cat /proc/version Linux version 3.16.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.51-3 (2017-12-13) root@iobroker:~# npm -v 3.10.10 root@iobroker:~# node -v v6.14.2 root@iobroker:~# nodejs -v v6.14.2
Hm,
mit den Versionen läuft es bei mir mit 1.1.1 ohne Probleme.
Ich hätte nochmal eine Aktualisierung der Fehlermeldungen anzubieten. Installiert ist die Version 2.0.3.
Ich habe den Adapter manuell neugestartet, da ich ein Objekt schreibbar gemacht hatte.
modbus.2 2018-06-24 19:54:30.920 info Connected to slave evcc sql.0 2018-06-24 19:54:30.463 info enabled logging of modbus.2.inputRegisters.128_128_total_kwh sql.0 2018-06-24 19:54:30.445 info enabled logging of modbus.2.inputRegisters.120_120_W_L1-N sql.0 2018-06-24 19:54:30.336 info enabled logging of modbus.2.inputRegisters.100_100_CP-Status modbus.2 2018-06-24 19:54:30.105 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.3 host.iobroker 2018-06-24 19:54:28.742 info instance system.adapter.modbus.2 started with pid 15607 host.iobroker 2018-06-24 19:54:26.348 info instance system.adapter.modbus.2 terminated with code 0 (OK) Caught 2018-06-24 19:54:26.347 error by controller[0]: at processImmediate [as _immediateCallback] (timers.js:617:5) Caught 2018-06-24 19:54:26.347 error by controller[0]: at tryOnImmediate (timers.js:645:5) Caught 2018-06-24 19:54:26.347 error by controller[0]: at runCallback (timers.js:672:20) Caught 2018-06-24 19:54:26.347 error by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:180:21) Caught 2018-06-24 19:54:26.346 error by controller[0]: at pollFloatBlock (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:142:20) Caught 2018-06-24 19:54:26.345 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:195:21) Caught 2018-06-24 19:54:26.345 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:310:33) Caught 2018-06-24 19:54:26.345 error by controller[0]: at pollFloatsBlocks (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:191:13) Caught 2018-06-24 19:54:26.345 error by controller[0]: at pollFloatBlock (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:152:21) Caught 2018-06-24 19:54:26.344 error by controller[0]: 2018-06-24 19:54:26.275 - error: modbus.2 TypeError: Cannot read property 'readHoldingRegisters' of null Caught 2018-06-24 19:54:26.344 error by controller[0]: 2018-06-24 19:54:26.272 - modbus.2 uncaught exception: Cannot read property 'readHoldingRegisters' of null Caught 2018-06-24 19:54:26.344 error by controller[0]: at processImmediate [as _immediateCallback] (timers.js:617:5) Caught 2018-06-24 19:54:26.344 error by controller[0]: at tryOnImmediate (timers.js:645:5) Caught 2018-06-24 19:54:26.342 error by controller[0]: at runCallback (timers.js:672:20) Caught 2018-06-24 19:54:26.342 error by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:180:21) Caught 2018-06-24 19:54:26.342 error by controller[0]: at pollFloatBlock (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:142:20) Caught 2018-06-24 19:54:26.342 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:195:21) Caught 2018-06-24 19:54:26.342 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:310:33) Caught 2018-06-24 19:54:26.341 error by controller[0]: at pollFloatsBlocks (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:191:13) Caught 2018-06-24 19:54:26.341 error by controller[0]: at pollFloatBlock (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:152:21) Caught 2018-06-24 19:54:26.340 error by controller[0]: TypeError: Cannot read property 'readHoldingRegisters' of null host.iobroker 2018-06-24 19:54:26.208 info stopInstance system.adapter.modbus.2 killing pid 1493 host.iobroker 2018-06-24 19:54:26.207 info stopInstance system.adapter.modbus.2 host.iobroker 2018-06-24 19:54:26.206 info object change system.adapter.modbus.2
Vielleicht hat ja jemand eine Idee.
Viele Grüße
Christian
Bitte GitHub issue
Gesendet vom Handy …
Erledigt: https://github.com/ioBroker/ioBroker.modbus/issues/15
PS: die Code-Formatierung bei Github ist k*cke
