  4. Ikea tradfri lässt sich nicht installieren
    6.0k
5 Beiträge 3 Kommentatoren 770 Aufrufe
    mctom
    leider bekommen ich den tradfri Adapter nicht installiert.
    Hier die Daten aus der Console:
    root@ioBrokerBETRIEB:~# cd /opt/iobroker
    root@ioBrokerBETRIEB:/opt/iobroker# sudo npm install iobroker.tradfri --production --unsafe-perm
    npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
    ! > node-aead-crypto@1.0.5 install /opt/iobroker/node_modules/node-aead-crypto
    node lib/install.js
    ! running default installation script
    module.js:478
    throw err;
    ! Error: Cannot find module 'npmlog'
    at Function.Module._resolveFilename (module.js:476:15)
    at Function.Module._load (module.js:424:25)
    at Module.require (module.js:504:17)
    at require (internal/module.js:20:19)
    at /opt/iobroker/node_modules/.bin/npm:18:11
    at Object. <anonymous>(/opt/iobroker/node_modules/.bin/npm:75:3)
    at Module._compile (module.js:577:32)
    at Object.Module._extensions..js (module.js:586:10)
    at Module.load (module.js:494:32)
    at tryModuleLoad (module.js:453:12)
    child_process.js:516
    throw err;
    ! Error: Command failed: npm run install:default
    at checkExecSyncError (child_process.js:473:13)
    at execSync (child_process.js:513:13)
    at Object. <anonymous>(/opt/iobroker/node_modules/node-aead-crypto/lib/install.js:22:1)
    at Function.Module._load (module.js:445:3)
    at Module.runMain (module.js:611:10)
    at run (bootstrap_node.js:387:7)
    iobroker.core@1.0.0 /opt/iobroker
    └── (empty)
    ! npm ERR! Linux 4.9.0-6-amd64
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.tradfri" "--production" "--unsafe-perm"
    npm ERR! node v6.14.1
    npm ERR! npm v3.10.10
    npm ERR! code ELIFECYCLE
    ! npm ERR! node-aead-crypto@1.0.5 install: node lib/install.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the node-aead-crypto@1.0.5 install script 'node lib/install.js'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the node-aead-crypto package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node lib/install.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs node-aead-crypto
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls node-aead-crypto
    npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:
    npm ERR! /opt/iobroker/npm-debug.log
    npm ERR! code 1</anonymous></anonymous>
    Hat jemand eine Idee was ich hier machen kann ?
    Meine Suche im Forum hat leider noch kein passendes Ergebnis gebracht.
    Systeminfos:
    Debian
    Host: 1.3.0
    Node: 6.14.1
    npm: 3.10.10
    MIchael
    • BuZZyB Offline
      BuZZyB Offline
      BuZZy
      Wieso installierst du nicht über das Webinterface?
      Wenn es damit auch nicht geht:
      Mach ein update von npm auf Version 4.
       sudo npm install -g npm@4
      VORHER BACKUP VOM SYSTEM MACHEN!
        mctom
        so konnte mich der Sache endlich mal wieder annehmen.
        Update von NPM durchgeführt.
        Bekomme weiterhin eine Fehlermeldung:
        $ ./iobroker add tradfri
        NPM version: 4.6.1
        npm install iobroker.tradfri --production --save --prefix "/opt/iobroker" (System call)
        module.js:478 throw err;
        ! npm ERR! code ELIFECYCLEnpm ERR! errno 1
        npm ERR! node-dtls-client@0.5.4 install: node install/postinstall.js
        npm ERR!
        npm ERR! Failed at the node-dtls-client@0.5.4 install script.
        ! npm
        ERR!
        A complete log of this run can be found in:
        npm
        ERR! /root/.npm/_logs/2018-05-29T19_02_41_520Z-debug.log
        host.ioBrokerBETRIEB create instance tradfri
        ERROR: host.ioBrokerBETRIEB error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
        ERROR: process exited with code 20</anonymous>
        Hat noch jemand eine Idee ?
        • AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          Ist dein JS-Controller aktuell?
          "/opt/iobroker/node_modules/.bin/npm" sollte in neueren Versionen nicht mehr existieren. Du hast zwar global eine neue npm-Version, intern wird aber anscheinend die ehemals mitgelieferte 2.x-Version verwendet.
          Lösche bitte mal diese Dateien/Ordner:
          /opt/iobroker/node_modules/npm
          und probiere es dann neu.
            mctom
            DANKE.
            Das war's. Ich habe den Controller aktualisiert, dann ging es noch nicht. Nachdem ich die Datei /opt/iobroker/node_modules/.bin/npm gelöscht hatte klappte es nun.
            Vielen Dank.
