  4. Upnp Adapter verursacht Fehler im log
    6.0k
6 Beiträge 3 Kommentatoren 506 Aufrufe
    sveni_lee
    ich habe heute meine Fritzbox 7490 in Betrieb genommen und seit dem bekomme ich permanent FEhler durch den upnp-Adapter angezeigt.
    host.Gotham-City	2018-05-27 14:39:45.310	error	instance system.adapter.upnp.0 terminated with code 0 (OK)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:146:10
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:268:10)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:451:14)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    host.Gotham-City	2018-05-27 14:39:45.310	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.Gotham-City	2018-05-27 14:39:45.309	error	Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    host.Gotham-City	2018-05-27 14:39:45.309	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    host.Gotham-City	2018-05-27 14:39:45.309	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    host.Gotham-City	2018-05-27 14:39:45.302	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
    so wie es scheint stimmt irgendwas mit socket nicht…
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @sveni_lee:
      so wie es scheint stimmt irgendwas mit socket nicht… ` Leider stimmt alles. Es gibt ein Limit für die maximale Anzahal an Aufrufen zur gleichen Zeit.
      Der upnp Adapter verursacht sehr viele Aufrufe und deshalb kann es vorkommen das die Meldung "RangeError: Maximum call stack size exceeded" auftaucht.
      Bisher ist es mir nicht gelungen eine Lösung zu finden die Dauerhauft funktioniert. Es hängt auch davon ab wieviele upnp Geräte im Netzwerk vorhanden sind. Je mehr um so Wahrscheinlicher ist es dass das Limit erreicht wird.
      Bei mir ist es so das ich 2 Hosts im gleichen Netzwerk betreibe, aber nur bei einem das Problem auftritt, wobei auch nur hin und wieder.
      Aus interesse: Welche version des Adapters hast du installiert?
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
        sveni_lee
        Okay, verstehe.
        Habe ich die Möglichkeit das ein oder andere Gerät aus upnp auszuschließen?
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @sveni_lee:
          Habe ich die Möglichkeit das ein oder andere Gerät aus upnp auszuschließen? ` Nicht direkt. In der Adapterkonfiguration kannst du die Automatische Erkennung und Abonements deaktivieren.
          Probier mal ob das hilft. Das Problem tritt meisstens bei der Erkennung der Geräte auf.
            sveni_lee
            Danke, das scheint geholfen zu haben…
            • apollon77A Offline
              @JeyCee
              Warum arbeitest du die Geräte nicht sequenziell ab? Oder halt per JavaScript asynchrone Abarbeitung aber begrenzt.
              So wie „callback schleifen“ alles nacheinander abarbeiten kannst du so was bauen was nur 10 parallel arbeiten lässt.
