  4. [Gelöst] iobroker bzw. RPI hängt
    6.0k
15 Beiträge 6 Kommentatoren 5.1k Aufrufe
    MichaelG
    P.S.
    Um 1:17 fängt das Log damit AN.
    host.raspi3 2018-04-19 01:17:13.070 info hostname: raspi3, node: v6.14.1
    host.raspi3 2018-04-19 01:17:13.069 info Copyright © 2014-2017 bluefox, 2014 hobbyquaker
    host.raspi3 2018-04-19 01:17:13.055 info iobroker.js-controller version 1.2.3 js-controller starting
    Startet der neu?
    • apollon77A Offline
      Was sagt denn /var/log/syslog ?! Steht da was mit "OOM Killer" ?! Wenn ja dann ist es was Speichermäßiges
      • wendy2702W Offline
        wendy2702W Offline
        Auch immer ein nettes Problem ist die Stromversorgung des PI.
          MichaelG
          ups, der Tipp war gut. Das steht zwar nicht drin aber andere böse Sachen.
          Im Minutentakt:
          pr 19 01:24:18 raspi3 kernel: [238363.314465] Unable to handle kernel paging request at virtual address 000a41fd
          Apr 19 01:24:18 raspi3 kernel: [238363.318023] pgd = a60f8000
          Apr 19 01:24:18 raspi3 kernel: [238363.321453] [000a41fd] *pgd=26158835, *pte=00000000, *ppte=00000000
          Apr 19 01:24:18 raspi3 kernel: [238363.324905] Internal error: Oops: 17 [#27] SMP ARM
          Apr 19 01:24:18 raspi3 kernel: [238363.328245] Modules linked in: cmac bnep hci_uart bluetooth ecdh_generic brcmfmac brcmutil cfg80211 rfkill snd_bcm2835(C) snd_pcm snd_timer snd uio_pdrv_genirq uio fixed ip$
          Apr 19 01:24:18 raspi3 kernel: [238363.338319] CPU: 3 PID: 13595 Comm: cat Tainted: G      D  C      4.14.30-v7+ #1102
          Apr 19 01:24:18 raspi3 kernel: [238363.344797] Hardware name: BCM2835
          Apr 19 01:24:18 raspi3 kernel: [238363.347933] task: b8a0ad00 task.stack: a6056000
          Apr 19 01:24:18 raspi3 kernel: [238363.351016] PC is at __d_lookup+0x58/0x170
          Apr 19 01:24:18 raspi3 kernel: [238363.354002] LR is at lookup_fast+0x188/0x2c0
          Apr 19 01:24:18 raspi3 kernel: [238363.356883] pc : [<802a5274>]    lr : [<80295cc8>]    psr: 20000013
          Apr 19 01:24:18 raspi3 kernel: [238363.359763] sp : a6057d30  ip : a6057d58  fp : a6057d54
          Apr 19 01:24:18 raspi3 kernel: [238363.362566] r10: a6057d9c  r9 : b966c010  r8 : ffffffff
          Apr 19 01:24:18 raspi3 kernel: [238363.365277] r7 : a6057eb0  r6 : b803a088  r5 : 864a2c0a  r4 : 000a41ed
          Apr 19 01:24:18 raspi3 kernel: [238363.367990] r3 : 00010c94  r2 : ffffffff  r1 : a6057eb0  r0 : b803a088
          Apr 19 01:24:18 raspi3 kernel: [238363.370626] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
          Apr 19 01:24:18 raspi3 kernel: [238363.373284] Control: 10c5383d  Table: 260f806a  DAC: 00000055
          Apr 19 01:24:18 raspi3 kernel: [238363.375929] Process cat (pid: 13595, stack limit = 0xa6056210)
          Apr 19 01:24:18 raspi3 kernel: [238363.378538] Stack: (0xa6057d30 to 0xa6058000)
          Apr 19 01:24:18 raspi3 kernel: [238363.381084] 7d20:                                     a6057ea8 00000000 a6057da0 b803a088
          Apr 19 01:24:18 raspi3 kernel: [238363.386123] 7d40: a6057d98 b966c010 a6057d94 a6057d58 80295cc8 802a5228 b809f628 803054d8
          Apr 19 01:24:18 raspi3 kernel: [238363.464335] 7fa0: 80108080 80287e38 00000000 00000000 7e9ece8c 00020000 00000000 00000000
          Apr 19 01:24:18 raspi3 kernel: [238363.467353] 7fc0: 00000000 00000000 00015360 00000005 00000001 00020000 ffffffff 00000000
          Apr 19 01:24:18 raspi3 kernel: [238363.470373] 7fe0: 76e6acc0 7e9ecae0 000112c4 76e6ad04 60000010 7e9ece8c 00000000 00000000
          Apr 19 01:24:18 raspi3 kernel: [238363.473398] [<802a5274>] (__d_lookup) from [<80295cc8>] (lookup_fast+0x188/0x2c0)
          Apr 19 01:24:18 raspi3 kernel: [238363.476413] [<80295cc8>] (lookup_fast) from [<80298014>] (walk_component+0x3c/0x2d4)
          Apr 19 01:24:18 raspi3 kernel: [238363.479446] [<80298014>] (walk_component) from [<80298540>] (link_path_walk+0x294/0x4a4)
          Apr 19 01:24:18 raspi3 kernel: [238363.482485] [<80298540>] (link_path_walk) from [<80298cf0>] (path_openat+0x88/0xff8)
          Apr 19 01:24:18 raspi3 kernel: [238363.485527] [<80298cf0>] (path_openat) from [<8029af10>] (do_filp_open+0x70/0xd4)
          Apr 19 01:24:18 raspi3 kernel: [238363.488573] [<8029af10>] (do_filp_open) from [<80287d7c>] (do_sys_open+0x120/0x1d0)
          Apr 19 01:24:18 raspi3 kernel: [238363.491616] [<80287d7c>] (do_sys_open) from [<80287e58>] (SyS_open+0x2c/0x30)
          Apr 19 01:24:18 raspi3 kernel: [238363.493181] [<80287e58>] (SyS_open) from [<80108080>] (ret_fast_syscall+0x0/0x28)
          Apr 19 01:24:18 raspi3 kernel: [238363.496200] Code: ea000013 e5944000 e3540000 0a000010 (e5942010)
          Apr 19 01:24:18 raspi3 kernel: [238363.497767] ---[ end trace 0b0183ce4ec469e2 ]---
          Könnt ihr was damit anfangen? Sieht irgendwie nach Stackoverflow aus. Nur warum????
          Mit iobroker hat es vermutlich nichts zu tun - oder?
          geändert: Code in Code-Tags; Homoran(Admin)
            MichaelG
            danke und sorry : Forums-Neuling
              MichaelG
              Habe mir extra ein "Starterset" besorgt, mit 2.5A Netzteil. Hoffe also, dass das Netzteil i.o.ist.
              Habe mal einen Flot-Chart erstellt mit Temperatur, Free Memory und CPU-Load-5
              Mal sehen, was der vor einem Absturz zeigt.
                wendy2702W Offline
                Für den PI3+ gab es Probleme mit dem Kernel.
                Vielleicht mal ein Kernel update probieren.
                sudo apt update && sudo apt upgrade
                sudo rpi-update
                • ChaotC Offline
                  ChaotC Offline
                  Chaot
                  Nur mal so aus Interesse weil ich ein ähnliches Problem habe/hatte:
                  Wenn du deinen WLan Router abschaltest und neu startest bleibt der Raspi dann hängen?
                  Bei mir hat sich das ganz klar mit einem Ausfall des WLan reproduzieren lassen und ich hatte ein identisches Fehlerbild. Nur das der Raspi in der "Standzeit" kein LOG geschrieben hat.
                    MichaelG
                    danke für die Infos.
                    Den Kernel-Update probiere ich aus. Ebenso das Wlan, obwohl der Raspi über LAN angeschlossen ist hat er natürlich auch einen WLAN-Verbindung, die zwar nicht genutzt wird, aber …
                    Bitte um Geduld, mache ich morgen oder am WE.
                    Bei Interesse könnt ihr Euch gerne mal unter http://www.grafs.de meine Smart-Home-Lösung ansehen. Bei all den vielen netten Hilfen hier möchte ich mich gerne revanchieren. (ist noch nicht ganz up to date)
                    Wer wissen will, wie man unter 10€ einen WLAN-fähigen und über mqtt steuerbaren Schaltaktor baut oder wie man <u>zuverlässig</u> die Bodenfeuchte im Garten misst (das ist nicht so einfach) kann sich gerne bei mir melden. Ist zwar nix für das iobroker Forum, aber unter der oben genannten Webseite kann man Kontakt aufnehmen.
                    Danke an alle
                    Michael
                      Also ja ein "kerlen Oops" ist nicht gut … Kernel Update ist die erste Wahl. Sonst kann es auch an anderen Dingen liegen ... RAM/Prozessorfehler und sowas ...
                        MichaelG
                        Danke an alle - habe den Kernel-Update durchgeführt (und WLAN abgeschaltet). Seit dem keine Abstürze mehr.
                        Klasse Tipp - tolles Forum
