  4. […gelöst] HILFE Admin ist nicht mehr erreichbar ???
    6.0k
102 Beiträge 6 Kommentatoren 19.3k Aufrufe
  • P Offline
    PapaChriLo
    #66
    @wendy2702:
    Komisch das es nicht richtig funktioniert.
    Dann folgendes Versuchen:
    Im Docker
    • Anlegen des Verzeichnisses (wenn noch nicht vorhanden) /opt/iobroker/backups
    • Kopieren des Backups````
      2017_12_27-14_23_40_backupiobroker.tar
    - iobroker stoppen
    Dann im Docker
    cd /opt/iobroker
    sudo iobroker restore 0
    Die komplette Ausgabe bitte loggen und dann in Code Tags Posten. `
    root@iobroker:/opt/iobroker/backups# cd /opt/iobroker
    root@iobroker:/opt/iobroker# iobroker restore 0
    host.iobroker Using backup file 2017_12_27-14_23_40_backupiobroker.tar.gz
    iobroker controller daemon is not running
    host.iobroker OK.
    host.iobroker Clear all objects and states...
    clean 35 objects...
    clean 21 states...
    host.iobroker done.
    host.iobroker Processed 0/1683 states
    host.iobroker Processed 200/1683 states
    host.iobroker Processed 400/1683 states
    host.iobroker Processed 600/1683 states
    host.iobroker Processed 800/1683 states
    host.iobroker Processed 1000/1683 states
    host.iobroker Processed 1200/1683 states
    host.iobroker Processed 1400/1683 states
    host.iobroker Processed 1600/1683 states
    1683 states restored.
    host.iobroker Processed 0/2292 objects
    host.iobroker Processed 200/2292 objects
    host.iobroker Cannot restore hm-rpc.0.*NEQ0011304.1: Invalid ID: hm-rpc.0.*NEQ0011304.1
    host.iobroker Cannot restore hm-rpc.0.*NEQ0011304.0: Invalid ID: hm-rpc.0.*NEQ0011304.0
    host.iobroker Cannot restore hm-rpc.0.*NEQ0011304: Invalid ID: hm-rpc.0.*NEQ0011304
    host.iobroker Processed 400/2292 objects
    host.iobroker Processed 600/2292 objects
    host.iobroker Processed 800/2292 objects
    host.iobroker Processed 1000/2292 objects
    host.iobroker Cannot restore hm-rpc.0.*NEQ0011304.1.INSTALL_TEST: Invalid ID: hm-rpc.0.*NEQ0011304.1.INSTALL_TEST
    host.iobroker Cannot restore hm-rpc.0.*NEQ0011304.1.STATE: Invalid ID: hm-rpc.0.*NEQ0011304.1.STATE
    host.iobroker Processed 1200/2292 objects
    host.iobroker Processed 1400/2292 objects
    host.iobroker Processed 1600/2292 objects
    host.iobroker Processed 1800/2292 objects
    host.iobroker Processed 2000/2292 objects
    host.iobroker Processed 2200/2292 objects
    2292 objects restored.
    host.iobroker Upload user file "vis.0/AuCh-Home/Buecherregal.png
    host.iobroker Upload user file "vis.0/AuCh-Home/LampeBR_Aus.png
    host.iobroker Upload user file "vis.0/AuCh-Home/LampeBR_Ein.png
    host.iobroker Upload user file "vis.0/AuCh-Home/VZLampeAus.png
    host.iobroker Upload user file "vis.0/AuCh-Home/VZLampeEin.png
    host.iobroker Upload user file "vis.0/AuCh-Home/Vorzimmer.png
    host.iobroker Upload user file "vis.0/AuCh-Home/vis-views.json
    host.iobroker Upload user file "vis.0/ChrisTablet/vis-views.json
    host.iobroker Upload user file "vis.0//Heizung_OFF.png
    host.iobroker Upload user file "vis.0//Heizung_ON.png
    host.iobroker Upload user file "vis.0//LampeEsstisch0.png
    host.iobroker Upload user file "vis.0//LampeEsstisch1.png
    host.iobroker Upload user file "vis.0//Ledbeleuchtung0.png
    host.iobroker Upload user file "vis.0//Ledbeleuchtung1.png
    host.iobroker Upload user file "vis.0//Lueftung1.png
    host.iobroker Upload user file "vis.0//Lueftung2.png
    host.iobroker Upload user file "vis.0//Wohnzimmer01.png
    host.iobroker Upload user file "vis.0//Wohnzimmer1.png
    host.iobroker Upload user file "vis.0/main/vis-views.json
    host.iobroker Upload user file "vis.0//rauchmelder1.png
    got /opt/iobroker/node_modules/iobroker.admin/admin
    upload [3] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    System successfully restored!
    LG
    Christian
    • wendy2702W Online
      wendy2702W Online
      #67
      Das sieht doch gut aus:
      Was sagt der Admin?
      • P Offline
        PapaChriLo
        #68
        Hallo!
        Sorry das ich mich heute erst wieder melde, aber ich war gestern nach wieder unzähligen Stunden vorm PC ohne Ergebnis einfach geschafft.
        Stand ist jetzt folgender:
        Der Admin lässt sich starten (der neue ADMIN)
        So wie es aussieht, sind auch meine Adapter wieder da.
        Zumindestans werden sie im Reiter Instanzen wieder angezeigt.
        Die VIS lässt sich aber nicht satrten
        Weder mit http://ipadresse:8082/vis/edit.html?AuCh-Home#Klima2
        Aber auch nicht direkt mit http://ipadresse:8082
        Es komm nur rechts oben im Browser No connection
        LG
        Christian
        • wendy2702W Online
          wendy2702W Online
          #69
          @PapaChriLo:
          Weder mit http://ipadresse:8082/vis/edit.html?AuCh-Home#Klima2 `
          Du hast aber hier die IP deines Dockers eingetragen und bestimmt nur für den Post gelöscht, oder?
          Und du siehst unter Instanzen eine "VIS.0" Instanz die auch aktiviert ist?
          • P Offline
            PapaChriLo
            #70
            @wendy2702:
            @PapaChriLo:
            Und du siehst unter Instanzen eine "VIS.0" Instanz die auch aktiviert ist? `
            Ja klar hab ich da die richtige ipadresse meines NAS eingetragen.
            Ja die VIS.0 ist da und aktiv
            Da das jetzt aber alles anders aussieht muss ich mich erst mal orientieren.
            Bei der VIS.0 steht rechts unter der Spalte Ereignisse ⇥0 / ↦8
            was bedeutet das. 0 ist nicht gut nehme ich mal an.
            Kann das jetzt nichts mit dem Versionssprung zu tun haben
            LG
            Christian
            • P Offline
              PapaChriLo
              #71
              Noch was.
              Meine Skripte sind auch wieder da.
              Und das LOG läuft wie verrückt aber das ist vieles ROT.
              hier mal ein Auszug davon
              web.0	2018-04-17 09:37:57.308	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:55.286	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:54.254	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:53.200	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:51.959	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:50.771	info	Connected system.user.admin from ::ffff:192.168.113.159
              host.iobroker	2018-04-17 09:37:50.394	info	Restart adapter system.adapter.hm-rpc.0 because enabled
              host.iobroker	2018-04-17 09:37:50.394	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
              host.iobroker	2018-04-17 09:37:50.394	error	Caught by controller[0]: port: 2001 }
              host.iobroker	2018-04-17 09:37:50.394	error	Caught by controller[0]: address: '192.168.113.31',
              host.iobroker	2018-04-17 09:37:50.393	error	Caught by controller[0]: syscall: 'listen',
              host.iobroker	2018-04-17 09:37:50.393	error	Caught by controller[0]: errno: 'EADDRNOTAVAIL',
              host.iobroker	2018-04-17 09:37:50.393	error	Caught by controller[0]: code: 'EADDRNOTAVAIL',
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at net.js:1423:9
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at listen (net.js:1313:10)
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at Server._listen2 (net.js:1264:19)
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
              host.iobroker	2018-04-17 09:37:50.392	error	Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
              host.iobroker	2018-04-17 09:37:50.391	error	Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.113.31:2001
              hm-rpc.0	2018-04-17 09:37:50.369	info	Disconnected
              hm-rpc.0	2018-04-17 09:37:50.352	info	Connected
              hm-rpc.0	2018-04-17 09:37:50.316	info	binrpc -> 192.168.113.30:2001 init ["xmlrpc_bin://192.168.113.31:2001",""]
              hm-rpc.0	2018-04-17 09:37:50.316	error	Error: listen EADDRNOTAVAIL 192.168.113.31:2001 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at Server._listen2 (net.js:1264:19)
              hm-rpc.0	2018-04-17 09:37:50.316	error	uncaught exception: listen EADDRNOTAVAIL 192.168.113.31:2001
              hm-rpc.0	2018-04-17 09:37:50.316	info	binrpc client is trying to connect to 192.168.113.30:2001 with ["xmlrpc_bin://192.168.113.31:2001","hm-rpc.0"]
              hm-rpc.0	2018-04-17 09:37:50.314	info	binrpc server is trying to listen on 192.168.113.31:2001
              hm-rpc.0	2018-04-17 09:37:50.175	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
              web.0	2018-04-17 09:37:49.745	info	Connected system.user.admin from ::ffff:192.168.113.159
              host.iobroker	2018-04-17 09:37:49.392	info	instance system.adapter.hm-rpc.0 started with pid 3593
              web.0	2018-04-17 09:37:48.721	info	Connected system.user.admin from ::ffff:192.168.113.159
              web.0	2018-04-17 09:37:46.691	info	Connected system.user.admin from ::ffff:192.168.113.159
              host.iobroker	2018-04-17 09:37:45.783	info	Restart adapter system.adapter.hm-rpc.1 because enabled
              LG
              Christian
              • wendy2702W Online
                wendy2702W Online
                #72
                Bei mir steht da gar nichts:
                Bekommst du Vis Editor denn auf wenn du diesen Button (Markierung im Bild) drückst?
                Stoppe mal deine RPC Instanz(en).
                Was sagt das log dann?
                Ist das deine CCU IP = 192.168.113.31 ?
                • P Offline
                  PapaChriLo
                  #73
                  Wenn ich die rpc Instanzen stoppe steht das LOG
                  Die IP 192.168.113.31 ist die von meinem NAS
                  192.168.133.30 ist die CCU2 Homematic
                  host.iobroker	2018-04-17 10:04:32.442	info	Restart adapter system.adapter.radar.0 because enabled
                  host.iobroker	2018-04-17 10:04:32.442	error	instance system.adapter.radar.0 terminated with code null ()
                  host.iobroker	2018-04-17 10:04:32.442	warn	instance system.adapter.radar.0 terminated due to SIGABRT
                  host.iobroker	2018-04-17 10:04:32.441	error	Caught by controller[0]: 0: ../deps/uv/src/unix/poll.c:120: uv_poll_start: Assertion `!(((handle)->flags & (UV_CLOSING | UV_CLOSED)) != 0)' failed.
                  radar.0	2018-04-17 10:04:30.739	info	Init item Christian_Tablet with { name: 'Christian_Tablet', ip: '192.168.113.50', macs: '34:8A:7B:F6:28:66', bluetooth: '34:8A:7B:F6:28:65', id: 'Christian_Tablet', hasMAC: [ '34:8A:7B:F6:2
                  radar.0	2018-04-17 10:04:30.736	warn	MAC addresses '34:8A:7B:F6:28:66' will not be scanned because no arp-scan is available!
                  radar.0	2018-04-17 10:04:30.684	info	Init item Andrea_Handy with { name: 'Andrea_Handy', ip: '192.168.113.154', macs: '5C:CA:1A:E7:9F:8C', bluetooth: '', id: 'Andrea_Handy', hasMAC: [ '5C:CA:1A:E7:9F:8C' ], hasBT: false, p
                  radar.0	2018-04-17 10:04:30.678	warn	MAC addresses '5C:CA:1A:E7:9F:8C' will not be scanned because no arp-scan is available!
                  radar.0	2018-04-17 10:04:30.625	info	BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview\'
                  radar.0	2018-04-17 10:04:30.624	info	radar set to scan every 30 sec and printers every 500 scans.
                  radar.0	2018-04-17 10:04:30.564	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v6.14.1
                  host.iobroker	2018-04-17 10:04:29.679	info	instance system.adapter.radar.0 started with pid 2303
                  harmony.0	2018-04-17 10:04:25.032	info	synced hub config
                  host.iobroker	2018-04-17 10:04:24.584	info	Do not restart adapter system.adapter.hm-rpc.1 because disabled or deleted
                  host.iobroker	2018-04-17 10:04:24.583	error	instance system.adapter.hm-rpc.1 terminated with code 3 (Adapter disabled or invalid config)
                  hm-rpc.1	2018-04-17 10:04:24.546	error	adapter disabled
                  harmony.0	2018-04-17 10:04:24.090	info	connected to Harmony Hub WZ
                  harmony.0	2018-04-17 10:04:20.348	info	connecting to Harmony Hub WZ
                  harmony.0	2018-04-17 10:04:20.326	info	discovered Harmony Hub WZ
                  host.iobroker	2018-04-17 10:04:15.856	info	"system.adapter.hm-rpc.1" disabled
                  host.iobroker	2018-04-17 10:04:15.856	info	object change system.adapter.hm-rpc.1
                  rpi2.0	2018-04-17 10:04:15.784	error	No Value found for soc_temp
                  rpi2.0	2018-04-17 10:04:15.784	error	/1024
                  rpi2.0	2018-04-17 10:04:15.784	error	/dev/md2 933062924 608123996 324938928 66% /
                  rpi2.0	2018-04-17 10:04:15.784	error	Cannot evaluate: Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
                  rpi2.0	2018-04-17 10:04:15.783	error	/1024
                  rpi2.0	2018-04-17 10:04:15.783	error	/dev/md2 933062924 608123996 324938928 66% /
                  rpi2.0	2018-04-17 10:04:15.783	error	Cannot evaluate: Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
                  rpi2.0	2018-04-17 10:04:15.780	error	No Value found for memory_available
                  rpi2.0	2018-04-17 10:04:15.779	error	No Value found for mem_gpu
                  rpi2.0	2018-04-17 10:04:15.779	error	No Value found for mem_arm
                  rpi2.0	2018-04-17 10:04:15.779	error	No Value found for cpu_voltage
                  host.iobroker	2018-04-17 10:04:14.615	info	"system.adapter.hm-rpc.0" disabled
                  host.iobroker	2018-04-17 10:04:14.615	info	object change system.adapter.hm-rpc.0
                  harmony.0	2018-04-17 10:04:05.083	warn	could not connect to Harmony Hub WZ: Error: Timed out after 5000 ms
                  host.iobroker	2018-04-17 10:03:59.998	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                  LG
                  Christian
                  • wendy2702W Online
                    wendy2702W Online
                    #74
                    Kannst du mal iobroker stoppen und dann
                    ps -ef|grep io
                    ````machen und gucken ob dann noch irgendetwas von iobroker läuft?
                    • P Offline
                      PapaChriLo
                      #75
                      Hier noch wie das aussieht wenn ich die VIS starten will.
                      LG
                      Christian
                      • P Offline
                        PapaChriLo
                        #76
                        @wendy2702:
                        ps -ef|grep io
                        ````machen und gucken ob dann noch irgendetwas von iobroker läuft? `
                        LG
                        Christian
                        • wendy2702W Online
                          wendy2702W Online
                          #77
                          Das sieht gut aus.
                          Ich würde iobroker starten und dann mal ein
                          iobroker upload all
                          machen.
                          Kannst du dann das komplette Start log hier Posten?
                          • P Offline
                            PapaChriLo
                            #78
                            @wendy2702:
                            Das sieht gut aus.
                            iobroker upload all
                            machen.
                            Kannst du dann das komplette Start log hier Posten? `
                            root@iobroker:/opt/iobroker# iobroker upload all
                            got /opt/iobroker/node_modules/iobroker.mobile/admin
                            upload [1] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/mobile.png mobile.png image/png
                            upload [0] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/index.html index.html text/html
                            Update "system.adapter.mobile.0"
                            got /opt/iobroker/node_modules/iobroker.mobile/www
                            upload [50] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.min.css lib/css/grey/jquery.mobile.min
                            .css text/css
                            upload [40] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/windowOpened.png img/windowOpened.png image/png
                            upload [30] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/rgb-red.png img/rgb-red.png image/png
                            upload [20] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/bulbOff.pdn img/bulbOff.pdn application/octet-stream
                            upload [19] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind90.png img/blind90.png image/png
                            upload [18] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind80.png img/blind80.png image/png
                            upload [17] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind70.png img/blind70.png image/png
                            upload [16] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind60.png img/blind60.png image/png
                            upload [15] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind50.png img/blind50.png image/png
                            upload [14] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind40.png img/blind40.png image/png
                            upload [13] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind30.png img/blind30.png image/png
                            upload [12] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind20.png img/blind20.png image/png
                            upload [11] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind100.png img/blind100.png image/png
                            upload [10] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind10.png img/blind10.png image/png
                            upload [9] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind0.png img/blind0.png image/png
                            upload [8] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/battery.png img/battery.png image/png
                            upload [7] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/alarmOn.png img/alarmOn.png image/png
                            upload [6] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/alarmOff.png img/alarmOff.png image/png
                            upload [5] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/mobile.css css/mobile.css text/css
                            upload [4] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Regular.ttf css/OpenSans-Regular.ttf font/ttf
                            upload [3] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-LICENSE.txt css/OpenSans-LICENSE.txt text/plain
                            upload [2] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Italic.ttf css/OpenSans-Italic.ttf font/ttf
                            upload [1] mobile /opt/iobroker/node_modules/iobroker.mobile/www/css/OpenSans-Bold.ttf css/OpenSans-Bold.ttf font/ttf
                            upload [0] mobile /opt/iobroker/node_modules/iobroker.mobile/www/cache.manifest cache.manifest text/cache-manifest
                            got /opt/iobroker/node_modules/iobroker.email/admin
                            upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
                            upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
                            upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
                            upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
                            upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
                            Update "system.adapter.email.0"
                            Cannot find io-package.json in null
                            Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                            got /opt/iobroker/node_modules/iobroker.harmony/admin
                            upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
                            upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
                            got /opt/iobroker/node_modules/iobroker.rpi2/admin
                            upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                            upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
                            Update "system.adapter.rpi2.0"
                            got /opt/iobroker/node_modules/iobroker.cloud/admin
                            upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                            upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                            upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
                            upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                            upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                            upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                            upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                            Update "system.adapter.cloud.0"
                            got /opt/iobroker/node_modules/iobroker.miele/admin
                            upload [2] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/xmiele.png xmiele.png image/png
                            upload [1] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/miele.png miele.png image/png
                            upload [0] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/index.html index.html text/html
                            got /opt/iobroker/node_modules/iobroker.radar/admin
                            upload [1] radar.admin /opt/iobroker/node_modules/iobroker.radar/admin/radar.png radar.png image/png
                            upload [0] radar.admin /opt/iobroker/node_modules/iobroker.radar/admin/index.html index.html text/html
                            got /opt/iobroker/node_modules/iobroker.ping/admin
                            upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                            upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                            upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
                            got /opt/iobroker/node_modules/iobroker.influxdb/admin
                            upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
                            upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
                            upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
                            upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index.html index.html text/html
                            upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
                            upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom.html custom.html text/html
                            Update "system.adapter.influxdb.0"
                            Adapter "system.adapter.influxdb.0" restarted.
                            got /opt/iobroker/node_modules/iobroker.history/admin
                            upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                            upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                            upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                            upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                            upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                            upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                            Update "system.adapter.history.0"
                            got /opt/iobroker/node_modules/iobroker.flot/admin
                            upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                            Update "system.adapter.flot.0"
                            got /opt/iobroker/node_modules/iobroker.flot/www
                            upload [30] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.hiddengraphs.js lib/js/jquery.flot.hiddengraphs.js application/javascript
                            upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/preview-opacity.png lib/css/images/preview-opacity.png image/png
                            upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map.png lib/css/images/map.png image/png
                            upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-pointer.png lib/css/images/map-pointer.png image/png
                            upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-opacity.png lib/css/images/map-opacity.png image/png
                            upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar.png lib/css/images/bar.png image/png
                            upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-pointer.png lib/css/images/bar-pointer.png image/png
                            upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-opacity.png lib/css/images/bar-opacity.png image/png
                            upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-alpha.png lib/css/images/bar-alpha.png image/png
                            upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/map.png lib/css/images/128/map.png image/png
                            upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar.png lib/css/images/128/bar.png image/png
                            upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar-alpha.png lib/css/images/128/bar-alpha.png image/png
                            upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/js/words.js js/words.js application/javascript
                            upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/js/settings.js js/settings.js application/javascript
                            upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
                            upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/js/data.js js/data.js application/javascript
                            upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/js/chart.js js/chart.js application/javascript
                            upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
                            upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/img/resetZoom.png img/resetZoom.png image/png
                            upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
                            upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/img/edit.svg img/edit.svg image/svg+xml
                            upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
                            got /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/admin
                            upload [1] icons-open-icon-library-png.admin /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/admin/index.html index.html text/html
                            upload [0] icons-open-icon-library-png.admin /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/admin/icons-open-icon-library-png.png icons-open-icon-l
                            ibrary-png.png image/png
                            Update "system.adapter.icons-open-icon-library-png.0"
                            got /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www
                            upload [5800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/weather-severe-alert.png status/weather-severe-
                            alert.png image/png
                            upload [5750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/ups-low-charging.png status/ups-low-charging.pn
                            g image/png
                            upload [5700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/network-wireless-disconnected.png status/networ
                            k-wireless-disconnected.png image/png
                            upload [5650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/mail-replied-2.png status/mail-replied-2.png im
                            age/png
                            upload [5600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/disc-35.png status/disc-35.png image/png
                            upload [5550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/battery-charging-100.png status/battery-chargin
                            g-100.png image/png
                            upload [5500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/status/audio-volume-high.png status/audio-volume-high.
                            png image/png
                            upload [5450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/tango-style/folder-forbidden.png places/tango-s
                            tyle/folder-forbidden.png image/png
                            upload [5400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/nuvola-style/user-trash-full.png places/nuvola-
                            style/user-trash-full.png image/png
                            upload [5350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/nuvola-style/file-locked.png places/nuvola-styl
                            e/file-locked.png image/png
                            upload [5300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/intrigue-style/folder-games.png places/intrigue
                            -style/folder-games.png image/png
                            upload [5250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/crystal_clear-style/folder-print.png places/cry
                            stal_clear-style/folder-print.png image/png
                            upload [5200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/places/crystal-style/folder-lin.png places/crystal-sty
                            le/folder-lin.png image/png
                            upload [5150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/others/people-girl-anime_with_silver_hair.png others/p
                            eople-girl-anime_with_silver_hair.png image/png
                            upload [5100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/others/circle_grey.png others/circle_grey.png image/pn
                            g
                            upload [5050] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/others/animals-dolphin.png others/animals-dolphin.png
                            image/png
                            upload [5000] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/xfce4-style/text-x-gettext-translation.png m
                            imetypes/xfce4-style/text-x-gettext-translation.png image/png
                            upload [4950] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/xfce4-style/audio-x-mod.png mimetypes/xfce4-
                            style/audio-x-mod.png image/png
                            upload [4900] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/xfce4-style/application-x-compressed-tar.png
                             mimetypes/xfce4-style/application-x-compressed-tar.png image/png
                            upload [4850] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/text-x-authors.png mimetypes/text-x-authors.
                            png image/png
                            upload [4800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/tango-style/image-x-xcursor.png mimetypes/ta
                            ngo-style/image-x-xcursor.png image/png
                            upload [4750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/tango-style/application-x-plasma.png mimetyp
                            es/tango-style/application-x-plasma.png image/png
                            upload [4700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/tango-style/application-vnd.sun.xml.writer.t
                            emplate.png mimetypes/tango-style/application-vnd.sun.xml.writer.template.png image/png
                            upload [4650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/uri-mmst.png mimetypes/oxygen-s
                            tyle/uri-mmst.png image/png
                            upload [4600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/text-x-c++hdr.png mimetypes/oxy
                            gen-style/text-x-c++hdr.png image/png
                            upload [4550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/audio-x-flac.png mimetypes/oxyg
                            en-style/audio-x-flac.png image/png
                            upload [4500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/application-x-object.png mimety
                            pes/oxygen-style/application-x-object.png image/png
                            upload [4450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/application-x-cd-image.png mime
                            types/oxygen-style/application-x-cd-image.png image/png
                            upload [4400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/oxygen-style/application-octet-stream.png mi
                            metypes/oxygen-style/application-octet-stream.png image/png
                            upload [4350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/nuvola-style/encrypted.png mimetypes/nuvola-
                            style/encrypted.png image/png
                            upload [4300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/nuvola-style/application-vnd.oasis.opendocum
                            ent.presentation-template.png mimetypes/nuvola-style/application-vnd.oasis.opendocument.presentation-template.png image/png
                            upload [4250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/gnome-style/text-x-opml+xml.png mimetypes/gn
                            ome-style/text-x-opml+xml.png image/png
                            upload [4200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/gnome-style/electrem_adf.png mimetypes/gnome
                            -style/electrem_adf.png image/png
                            upload [4150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/gnome-style/application-x-font-pcf-2.png mim
                            etypes/gnome-style/application-x-font-pcf-2.png image/png
                            upload [4100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/crystal-style/text-x-texinfo.png mimetypes/c
                            rystal-style/text-x-texinfo.png image/png
                            upload [4050] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/crystal-style/koffice.png mimetypes/crystal-
                            upload [4000] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/crystal-style/application-x-lisp-2.png mimet
                            ypes/crystal-style/application-x-lisp-2.png image/png
                            upload [3950] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/mimetypes/application-x-executable.png mimetypes/appli
                            cation-x-executable.png image/png
                            upload [3900] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/emotes/face-devilish-2.png emotes/face-devilish-2.png
                            image/png
                            upload [3850] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/emblems/emblem-important.png emblems/emblem-important.
                            png image/png
                            upload [3800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/printer-3.png devices/printer-3.png image/png
                            upload [3750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/multimedia-player-mp3player-2.png devices/mult
                            imedia-player-mp3player-2.png image/png
                            upload [3700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/media-optical-cd-r.png devices/media-optical-c
                            d-r.png image/png
                            upload [3650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/media-flash-memory_stick.png devices/media-fla
                            sh-memory_stick.png image/png
                            upload [3600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/drive-removable-media-4.png devices/drive-remo
                            vable-media-4.png image/png
                            upload [3550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/devices/camera-photo-8.png devices/camera-photo-8.png
                            image/png
                            upload [3500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/categories/preferences-desktop-peripherals-2.png categ
                            ories/preferences-desktop-peripherals-2.png image/png
                            upload [3450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/categories/applications-engineering.png categories/app
                            lications-engineering.png image/png
                            upload [3400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/xiterm+thai.png apps/xiterm+thai.png image/png
                            upload [3350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/wordperfect.png apps/wordperfect.png image/png
                            upload [3300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/virtualdub.png apps/virtualdub.png image/png
                            upload [3250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/utilities-announcements.png apps/utilities-announ
                            cements.png image/png
                            upload [3200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/texworks.png apps/texworks.png image/png
                            upload [3150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/system-hibernate.png apps/system-hibernate.png im
                            age/png
                            upload [3100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/soundconverter.png apps/soundconverter.png image/
                            png
                            upload [3050] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/scribes.png apps/scribes.png image/png
                            upload [3000] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/randr-2.png apps/randr-2.png image/png
                            upload [2950] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/preferences-system-time.png apps/preferences-syst
                            em-time.png image/png
                            upload [2900] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/preferences-desktop-mouse-2.png apps/preferences-
                            desktop-mouse-2.png image/png
                            upload [2850] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/ppracer.png apps/ppracer.png image/png
                            upload [2800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/padre.png apps/padre.png image/png
                            upload [2750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/nepomuk.png apps/nepomuk.png image/png
                            upload [2700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/monsterz_graphics.png apps/monsterz_graphics.png
                            image/png
                            upload [2650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/lprof.png apps/lprof.png image/png
                            upload [2600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kwin4-3.png apps/kwin4-3.png image/png
                            upload [2550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/ktip-3.png apps/ktip-3.png image/png
                            upload [2500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/ksirtet.png apps/ksirtet.png image/png
                            upload [2450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kphotoalbum.png apps/kphotoalbum.png image/png
                            upload [2400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/konquest.png apps/konquest.png image/png
                            upload [2350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kmplot.png apps/kmplot.png image/png
                            upload [2300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/klettres-2.png apps/klettres-2.png image/png
                            upload [2250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kgamma.png apps/kgamma.png image/png
                            upload [2200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kdmconfig-3.png apps/kdmconfig-3.png image/png
                            upload [2150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kcmprocessor-2.png apps/kcmprocessor-2.png image/
                            png
                            upload [2100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kblackbox-3.png apps/kblackbox-3.png image/png
                            upload [2050] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/kaffeine.png apps/kaffeine.png image/png
                            upload [2000] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/internet-mail.png apps/internet-mail.png image/pn
                            g
                            upload [1950] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/gtranslator.png apps/gtranslator.png image/png
                            upload [1900] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/goobox.png apps/goobox.png image/png
                            upload [1850] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/gnome-screenshot.png apps/gnome-screenshot.png im
                            age/png
                            upload [1800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/gnome-apps.png apps/gnome-apps.png image/png
                            upload [1750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/geogebra.png apps/geogebra.png image/png
                            upload [1700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/games-chinese_chess.png apps/games-chinese_chess.
                            png image/png
                            upload [1650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/foss.png apps/foss.png image/png
                            upload [1600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/emacs.png apps/emacs.png image/png
                            upload [1550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/distributions-opengeu.png apps/distributions-open
                            geu.png image/png
                            upload [1500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/diffuse.png apps/diffuse.png image/png
                            upload [1450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/darwine.png apps/darwine.png image/png
                            upload [1400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/chromium-2.png apps/chromium-2.png image/png
                            upload [1350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/bluetooth.png apps/bluetooth.png image/png
                            upload [1300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/atomic.png apps/atomic.png image/png
                            upload [1250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/amarok.png apps/amarok.png image/png
                            upload [1200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/apps/RemoteDesk.app.png apps/RemoteDesk.app.png image/
                            png
                            upload [1150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/window-new.png actions/window-new.png image/pn
                            g
                            upload [1100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/view-refresh-8.png actions/view-refresh-8.png
                            image/png
                            upload [1050] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/view-list-icon.png actions/view-list-icon.png
                            image/png
                            upload [1000] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/user-group-new.png actions/user-group-new.png
                            image/png
                            upload [950] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/tab-new-6.png actions/tab-new-6.png image/png
                            upload [900] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/show-menu.png actions/show-menu.png image/png
                            upload [850] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/office-chart-polar.png actions/office-chart-pol
                            ar.png image/png
                            upload [800] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/media-skip-backward-2.png actions/media-skip-ba
                            ckward-2.png image/png
                            upload [750] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/media-optical-info.png actions/media-optical-in
                            fo.png image/png
                            upload [700] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/mail-new-2.png actions/mail-new-2.png image/png
                            upload [650] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/list-remove-4.png actions/list-remove-4.png ima
                            ge/png
                            upload [600] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/insert-pause.png actions/insert-pause.png image
                            /png
                            upload [550] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/go-top-3.png actions/go-top-3.png image/png
                            upload [500] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/go-home-3.png actions/go-home-3.png image/png
                            upload [450] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/format-text-strikethrough-3.png actions/format-
                            text-strikethrough-3.png image/png
                            upload [400] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/format-indent-more-4.png actions/format-indent-
                            more-4.png image/png
                            upload [350] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/edit-select-all-2.png actions/edit-select-all-2
                            .png image/png
                            upload [300] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/edit-delete-2.png actions/edit-delete-2.png ima
                            ge/png
                            upload [250] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/draw-halfcircle2.png actions/draw-halfcircle2.p
                            ng image/png
                            upload [200] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/document-print-frame-3.png actions/document-pri
                            nt-frame-3.png image/png
                            upload [150] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/dialog-ok.png actions/dialog-ok.png image/png
                            upload [100] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/configure-toolbars.png actions/configure-toolba
                            rs.png image/png
                            upload [90] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/color-picker-grey.png actions/color-picker-grey.
                            png image/png
                            upload [80] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/call-stop.png actions/call-stop.png image/png
                            upload [70] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/bookmark-new-list.png actions/bookmark-new-list.
                            png image/png
                            upload [60] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/bookmark-folder.png actions/bookmark-folder.png
                            image/png
                            upload [50] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/arrow-up-3.png actions/arrow-up-3.png image/png
                            upload [40] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/arrow-left-double-3.png actions/arrow-left-doubl
                            e-3.png image/png
                            upload [30] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/archive-remove.png actions/archive-remove.png im
                            age/png
                            upload [20] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/appointment-new-2.png actions/appointment-new-2.
                            png image/png
                            upload [19] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/application-exit.png actions/application-exit.pn
                            g image/png
                            upload [18] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/application-exit-5.png actions/application-exit-
                            5.png image/png
                            upload [17] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/application-exit-4.png actions/application-exit-
                            4.png image/png
                            upload [16] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/application-exit-3.png actions/application-exit-
                            3.png image/png
                            upload [15] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/application-exit-2.png actions/application-exit-
                            2.png image/png
                            upload [14] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-vertical-top-2.png actions/align-vertical-
                            top-2.png image/png
                            upload [13] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-vertical-center-2.png actions/align-vertic
                            al-center-2.png image/png
                            upload [12] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-vertical-bottom-2.png actions/align-vertic
                            al-bottom-2.png image/png
                            upload [11] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-top-out.png actions/align-horiz
                            ontal-top-out.png image/png
                            upload [10] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-right-out.png actions/align-hor
                            izontal-right-out.png image/png
                            upload [9] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-right-2.png actions/align-horizo
                            ntal-right-2.png image/png
                            upload [8] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-left.png actions/align-horizonta
                            l-left.png image/png
                            upload [7] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-left-out.png actions/align-horiz
                            ontal-left-out.png image/png
                            upload [6] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-center-2.png actions/align-horiz
                            ontal-center-2.png image/png
                            upload [5] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/align-horizontal-bottom-out.png actions/align-hor
                            izontal-bottom-out.png image/png
                            upload [4] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/address-book-new.png actions/address-book-new.png
                             image/png
                             upload [3] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/address-book-new-4.png actions/address-book-new-4
                            .png image/png
                            upload [2] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/address-book-new-3.png actions/address-book-new-3
                            .png image/png
                            upload [1] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/address-book-new-2.png actions/address-book-new-2
                            .png image/png
                            upload [0] icons-open-icon-library-png /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/www/actions/add-to-desktop.png actions/add-to-desktop.png ima
                            ge/png
                            got /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin
                            upload [1] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/index.html index.html text/html
                            upload [0] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/icons-mfd-png.png icons-mfd-png.png image/png
                            Update "system.adapter.icons-mfd-png.0"
                            got /opt/iobroker/node_modules/iobroker.icons-mfd-png/www
                            upload [850] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_rain_meter.png weather_rain_meter.png image/png
                            upload [800] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/vent_stop.png vent_stop.png image/png
                            upload [750] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/status_presence_simulation.png status_presence_simulation.png image/png
                            upload [700] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_sleeping_twin_0_1.png scene_sleeping_twin_0_1.png image/png
                            upload [650] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_dressing_room_alternat.png scene_dressing_room_alternat.png image/png
                            upload [600] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/sani_irrigation_pop_up_off.png sani_irrigation_pop_up_off.png image/png
                            upload [550] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/message_presence_geo_inactive.png message_presence_geo_inactive.png image/png
                            upload [500] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/measure_globe_long.png measure_globe_long.png image/png
                            upload [450] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/light_mirror.png light_mirror.png image/png
                            upload [400] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/it_ups_battery_empty.png it_ups_battery_empty.png image/png
                            upload [350] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_window_2w_tilt_lr.png fts_window_2w_tilt_lr.png image/png
                            upload [300] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_shutter_up.png fts_shutter_up.png image/png
                            upload [250] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_blade_z_90.png fts_blade_z_90.png image/png
                            upload [200] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_awning.png fts_awning.png image/png
                            upload [150] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_centr_arrow_up_left.png control_centr_arrow_up_left.png image/png
                            upload [100] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_modern_s_2og_int_og1.png control_building_modern_s_2og_int_og1.png
                             image/png
                            upload [90] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_modern02_okg_int_eg.png control_building_modern02_okg_int_eg.png im
                            age/png
                            upload [80] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_int_dg.png control_building_int_dg.png image/png
                            upload [70] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_flat_filled.png control_building_flat_filled.png image/png
                            upload [60] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_edg_eg.png control_building_edg_eg.png image/png
                            upload [50] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_2_s_int_all.png control_building_2_s_int_all.png image/png
                            upload [40] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_arrow_rightward.png control_arrow_rightward.png image/png
                            upload [30] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_3dot_vert_s.png control_3dot_vert_s.png image/png
                            upload [20] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_volume_mid.png audio_volume_mid.png image/png
                            upload [19] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_volume_low.png audio_volume_low.png image/png
                            upload [18] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_volume_high.png audio_volume_high.png image/png
                            upload [17] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_stop.png audio_stop.png image/png
                            upload [16] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_sound.png audio_sound.png image/png
                            upload [15] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_shuffle.png audio_shuffle.png image/png
                            upload [14] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_rew.png audio_rew.png image/png
                            upload [13] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_repeat.png audio_repeat.png image/png
                            upload [12] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_rec.png audio_rec.png image/png
                            upload [11] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_playlist.png audio_playlist.png image/png
                            upload [10] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_play.png audio_play.png image/png
                            upload [9] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_pause.png audio_pause.png image/png
                            upload [8] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_mic_mute.png audio_mic_mute.png image/png
                            upload [7] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_mic.png audio_mic.png image/png
                            upload [6] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_loudness.png audio_loudness.png image/png
                            upload [5] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_headphone.png audio_headphone.png image/png
                            upload [4] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_ff.png audio_ff.png image/png
                            upload [3] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_fade.png audio_fade.png image/png
                            upload [2] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_eq.png audio_eq.png image/png
                            upload [1] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_eject.png audio_eject.png image/png
                            upload [0] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_audio.png audio_audio.png image/png
                            got /opt/iobroker/node_modules/iobroker.vis-players/admin
                            upload [0] vis-players.admin /opt/iobroker/node_modules/iobroker.vis-players/admin/players.png players.png image/png
                            Update "system.adapter.vis-players.0"
                            Adapter "system.adapter.vis.0" restarted.
                            got /opt/iobroker/node_modules/iobroker.vis-history/admin
                            upload [0] vis-history.admin /opt/iobroker/node_modules/iobroker.vis-history/admin/vis-history.png vis-history.png image/png
                            Update "system.adapter.vis-history.0"
                            got /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin
                            upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                            Update "system.adapter.vis-jqui-mfd.0"
                            got /opt/iobroker/node_modules/iobroker.vis-keyboard/admin
                            upload [1] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/keyboard.png keyboard.png image/png
                            upload [0] vis-keyboard.admin /opt/iobroker/node_modules/iobroker.vis-keyboard/admin/index.html index.html text/html
                            Update "system.adapter.vis-keyboard.0"
                            got /opt/iobroker/node_modules/iobroker.vis-bars/admin
                            upload [1] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/index.html index.html text/html
                            upload [0] vis-bars.admin /opt/iobroker/node_modules/iobroker.vis-bars/admin/bars.png bars.png image/png
                            Update "system.adapter.vis-bars.0"
                            got /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin
                            upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                            upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                            Update "system.adapter.vis-hqwidgets.0"
                            got /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin
                            upload [1] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/index.html index.html text/html
                            upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
                            Update "system.adapter.vis-colorpicker.0"
                            got /opt/iobroker/node_modules/iobroker.ical/admin
                            upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                            upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                            upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
                            upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                            Update "system.adapter.ical.0"
                            Update "system.adapter.ical.1"
                            got /opt/iobroker/node_modules/iobroker.icons-ultimate-png/admin
                            upload [1] icons-ultimate-png.admin /opt/iobroker/node_modules/iobroker.icons-ultimate-png/admin/index.html index.html text/html
                            upload [0] icons-ultimate-png.admin /opt/iobroker/node_modules/iobroker.icons-ultimate-png/admin/icons-ultimate-png.png icons-ultimate-png.png image/png
                            Update "system.adapter.icons-ultimate-png.0"
                            got /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www
                            upload [1000] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/index.html index.html text/html
                            upload [950] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/954.png 954.png image/png
                            upload [900] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/909.png 909.png image/png
                            upload [850] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/864.png 864.png image/png
                            upload [800] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/819.png 819.png image/png
                            upload [750] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/774.png 774.png image/png
                            upload [700] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/729.png 729.png image/png
                            upload [650] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/684.png 684.png image/png
                            upload [600] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/639.png 639.png image/png
                            upload [550] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/594.png 594.png image/png
                            upload [500] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/549.png 549.png image/png
                            upload [450] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/503.png 503.png image/png
                            upload [400] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/459.png 459.png image/png
                            upload [350] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/413.png 413.png image/png
                            upload [300] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/369.png 369.png image/png
                            upload [250] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/323.png 323.png image/png
                            upload [200] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/279.png 279.png image/png
                            upload [150] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/233.png 233.png image/png
                            upload [100] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/189.png 189.png image/png
                            upload [90] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/18.png 18.png image/png
                            upload [80] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/170.png 170.png image/png
                            upload [70] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/161.png 161.png image/png
                            upload [60] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/152.png 152.png image/png
                            upload [50] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/143.png 143.png image/png
                            upload [40] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/134.png 134.png image/png
                            upload [30] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/125.png 125.png image/png
                            upload [20] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/116.png 116.png image/png
                            upload [19] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/115.png 115.png image/png
                            upload [18] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/114.png 114.png image/png
                            upload [17] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/113.png 113.png image/png
                            upload [16] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/112.png 112.png image/png
                            upload [15] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/111.png 111.png image/png
                            upload [14] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/110.png 110.png image/png
                            upload [13] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/11.png 11.png image/png
                            upload [12] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/109.png 109.png image/png
                            upload [11] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/108.png 108.png image/png
                            upload [10] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/107.png 107.png image/png
                            upload [9] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/106.png 106.png image/png
                            upload [8] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/105.png 105.png image/png
                            upload [7] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/104.png 104.png image/png
                            upload [6] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/103.png 103.png image/png
                            upload [5] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/102.png 102.png image/png
                            upload [4] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/101.png 101.png image/png
                            upload [3] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/1000.png 1000.png image/png
                            upload [2] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/100.png 100.png image/png
                            upload [1] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/10.png 10.png image/png
                            upload [0] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/1.png 1.png image/png
                            got /opt/iobroker/node_modules/iobroker.vis-canvas-gauges/admin
                            upload [0] vis-canvas-gauges.admin /opt/iobroker/node_modules/iobroker.vis-canvas-gauges/admin/vis-canvas-gauges.png vis-canvas-gauges.png image/png
                            Update "system.adapter.vis-canvas-gauges.0"
                            got /opt/iobroker/node_modules/iobroker.vis-justgage/admin
                            upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
                            upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
                            Update "system.adapter.vis-metro.0"
                            got /opt/iobroker/node_modules/iobroker.vis-rgraph/admin
                            upload [1] vis-rgraph.admin /opt/iobroker/node_modules/iobroker.vis-rgraph/admin/rgraph.png rgraph.png image/png
                            upload [0] vis-rgraph.admin /opt/iobroker/node_modules/iobroker.vis-rgraph/admin/index.html index.html text/html
                            Update "system.adapter.vis-rgraph.0"
                            got /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin
                            upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                            upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                            Update "system.adapter.vis-timeandweather.0"
                            got /opt/iobroker/node_modules/iobroker.vis/admin
                            upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                            upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                            upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                            Update "system.adapter.vis.0"
                            LG
                            Christian
                            • P Offline
                              PapaChriLo
                              #79
                              @wendy2702:
                              Das sieht gut aus.
                              iobroker upload all
                              machen.
                              got /opt/iobroker/node_modules/iobroker.vis/www
                              upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/js/moreskins.js widgets/timeandweather/js/moreskins.js application/javascript
                              upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/4-1.png widgets/timeandweather/img/clock/4-1.png image/png
                              upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/doc.html widgets/timeandweather/doc.html text/html
                              upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/rgraph/js/RGraph.common.effects.js widgets/rgraph/js/RGraph.common.effects.js application/javas
                              cript
                              upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/players/css/sonoshandbookpro-regular-webfont.woff widgets/players/css/sonoshandbookpro-regular-
                              webfont.woff font/woff
                              upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/keyboard/js/keyboard.js widgets/keyboard/js/keyboard.js application/javascript
                              upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/light_light_dim_50.png widgets/jqui-mfd/img/light_light_dim_50.png image/png
                              upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_markise_75.svg widgets/jqui-mfd/img/fts_markise_75.svg image/svg+xml
                              upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/lockUnlocked.png widgets/hqwidgets/img/lockUnlocked.png image/png
                              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic.html widgets/basic.html text/html
                              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars.html widgets/bars.html text/html
                              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                              got /opt/iobroker/node_modules/iobroker.web/admin
                              upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                              upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                              upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                              Update "system.adapter.web.0"
                              got /opt/iobroker/node_modules/iobroker.web/www
                              upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-icons_666666_256x240.png lib/css/themes/jquery-ui/vader/images
                              /ui-icons_666666_256x240.png image/png
                              upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_d19405_256x240.png lib/css/themes/jquery-ui/sunny/images
                              /ui-icons_d19405_256x240.png image/png
                              upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_f9bd01_256x240.png lib/css/themes/jquery-ui/redmond/im
                              ages/ui-icons_f9bd01_256x240.png image/png
                              upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/theme.css lib/css/themes/jquery-ui/hot-sneaks/theme.css text/css
                              upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/theme.css lib/css/themes/jquery-ui/eggplant/theme.css text/css
                              upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-icons_4b8e0b_256x240.png lib/css/themes/jquery-ui/dark-hiv
                              e/images/ui-icons_4b8e0b_256x240.png image/png
                              upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_flat_30_cccccc_40x100.png lib/css/themes/jquery-ui/dark-
                              hive/images/ui-bg_flat_30_cccccc_40x100.png image/png
                              upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/cu
                              stom-light/images/ui-bg_glass_95_fef1ec_1x400.png image/png
                              upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/custom-
                              dark/images/ui-icons_a83300_256x240.png image/png
                              upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/jquery-ui.css lib/css/themes/jquery-ui/cupertino/jquery-ui.css text/c
                              ss
                              upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_glass_80_d7ebf9_1x400.png lib/css/themes/jquery-ui/cuper
                              tino/images/ui-bg_glass_80_d7ebf9_1x400.png image/png
                              upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-icons_004276_256x240.png lib/css/themes/jquery-ui/blitzer/ima
                              ges/ui-icons_004276_256x240.png image/png
                              upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/theme.css lib/css/themes/jquery-ui/black-tie/theme.css text/css
                              upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_inset-hard_45_cd0a0a_1x100.png lib/css/themes/jquery-ui/
                              black-tie/images/ui-bg_inset-hard_45_cd0a0a_1x100.png image/png
                              upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_highlight-soft_50_aaaaaa_1x100.png lib/css/themes/jquery
                              -ui/black-tie/images/ui-bg_highlight-soft_50_aaaaaa_1x100.png image/png
                              upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_highlight-hard_40_aaaaaa_1x100.png lib/css/themes/jquery
                              -ui/black-tie/images/ui-bg_highlight-hard_40_aaaaaa_1x100.png image/png
                              upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_highlight-hard_100_f9f9f9_1x100.png lib/css/themes/jquer
                              y-ui/black-tie/images/ui-bg_highlight-hard_100_f9f9f9_1x100.png image/png
                              upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black
                              -tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                              upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black
                              -tie/images/ui-bg_glass_40_111111_1x400.png image/png
                              upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black
                              -tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                              upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery
                              -ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                              upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                              upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                              upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                              upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                              upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                              upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                              upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                              upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                              upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                              upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                              upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                              upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                              upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/gear.png admin/img/gear.png image/png
                              got /opt/iobroker/node_modules/iobroker.hm-rega/admin
                              upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                              upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                              upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                              upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                              Update "system.adapter.hm-rega.0"
                              got /opt/iobroker/node_modules/iobroker.hm-rpc/admin
                              upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/95_group_hm-cc-vg-1_thumb.png icons/95_group_hm-cc-vg-1_thumb.png image/png
                              upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/48_hm-sen-ep_thumb.png icons/48_hm-sen-ep_thumb.png image/png
                              upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/36_hmw-sys-ps7-dr_thumb.png icons/36_hmw-sys-ps7-dr_thumb.png image/png
                              upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/27_hmw-lc-bl1-dr_thumb.png icons/27_hmw-lc-bl1-dr_thumb.png image/png
                              upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/17_hm-sec-rhs_thumb.png icons/17_hm-sec-rhs_thumb.png image/png
                              upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/150_hm-lc-dw-wm_thumb.png icons/150_hm-lc-dw-wm_thumb.png image/png
                              upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                              upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                              upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                              upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                              upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                              upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                              upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                              upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                              upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                              upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                              upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                              upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                              upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                              upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                              upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                              upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                              upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                              upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                              upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                              upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                              upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                              upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                              upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                              upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                              Update "system.adapter.hm-rpc.0"
                              Update "system.adapter.hm-rpc.1"
                              got /opt/iobroker/node_modules/iobroker.javascript/admin
                              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/query-builder/query-builder.default.min.css query-builder/query-builder.default.mi
                              n.css text/css
                              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/jquery.cron.css jquery.cron.css text/css
                              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/es.js google-blockly/own/msg/es.js application/javascript
                              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_system.js google-blockly/own/blocks_system.js applicatio
                              n/javascript
                              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/fr.js google-blockly/msg/js/fr.js application/javascript
                              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur applicatio
                              n/octet-stream
                              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js app
                              lication/javascript
                              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application
                              /javascript
                              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js applicati
                              on/javascript
                              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
                              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron2text.js cron2text.js application/javascript
                              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron/jquery-cron.js cron/jquery-cron.js application/javascript
                              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron/jquery-cron.css cron/jquery-cron.css text/css
                              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/coffeescript.png coffeescript.png image/png
                              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/blockly.png blockly.png image/png
                              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                              Update "system.adapter.javascript.0"
                              Cannot find io-package.json in null
                              Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                              got /opt/iobroker/node_modules/iobroker.discovery/admin
                              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                              Update "system.adapter.discovery.0"
                              got /opt/iobroker/node_modules/iobroker.admin/admin
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              Update "system.adapter.admin.0"
                              root@iobroker:/opt/iobroker#
                              LG
                              Christian
                              • P Offline
                                PapaChriLo
                                #80
                                Ist leider nicht auf einmal gegengen waren zu viele Zeichen
                                LG
                                Christian
                                • wendy2702W Online
                                  wendy2702W Online
                                  #81
                                  Das sieht erstmal OK aus.
                                  Wie ist der Status im Admin? Was ist grün, was rot oder gelb?
                                  Geht der Editor oder VIS jetzt?
                                  Welchen Browser nutzt du?
                                  Mal den Cache gelöscht und ein Forced Reload (CTRL+F5) gemacht?
                                  • P Offline
                                    PapaChriLo
                                    #82
                                    @wendy2702:
                                    Mal den Cache gelöscht und ein Forced Reload (CTRL+F5) gemacht? `
                                    Status ADMIN: Alles auf Grün
                                    ausser der influxdb.0 der ist auf Gelb
                                    der hm-rpc.0 und der hm-rpc.1 ist auf ROT
                                    Die IP Adresse ist aber richtig eingetragen das hab ich schon kontrolliert
                                    Status VIS: so wie es aussieht startet jetzt auch die VIS allerdings dauert das ewig ca. 5 Minuten
                                    Browser: Firefox
                                    Cach löschen usw.: Hab ich gemacht hat aber nichts gebracht.
                                    Status auf meinem Bildschirm im VZ ist das die VIS jetzt zwar angezeigt wird aber es funktioniert nichts.
                                    Ich kann nichts schalten
                                    Die History der Temperatur der letzten sieben Tage wird nicht angezeigt usw.
                                    Ich kann zwar zwischen den einzelnen Views hin und her wechseln das geht jetzt aber wie gesagt
                                    ich kann absolut nichts schalten.
                                    So wie es aussieht fehlt irgendwie die Verbindung zur Homematic.
                                    host.iobroker	2018-04-17 11:45:23.677	info	Restart adapter system.adapter.hm-rpc.1 because enabled
                                    host.iobroker	2018-04-17 11:45:23.676	error	instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: port: 2010 }
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: address: '192.168.113.31',
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: syscall: 'listen',
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: errno: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: code: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at net.js:1423:9
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at listen (net.js:1313:10)
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at Server._listen2 (net.js:1264:19)
                                    host.iobroker	2018-04-17 11:45:23.676	error	Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
                                    host.iobroker	2018-04-17 11:45:23.675	error	Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
                                    host.iobroker	2018-04-17 11:45:23.675	error	Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:45:23.653	info	Disconnected
                                    hm-rpc.1	2018-04-17 11:45:23.607	info	Connected
                                    hm-rpc.1	2018-04-17 11:45:23.550	info	xmlrpc -> 192.168.113.30:2010 init ["http://192.168.113.31:2010",""]
                                    hm-rpc.1	2018-04-17 11:45:23.550	error	Error: listen EADDRNOTAVAIL 192.168.113.31:2010 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at Server._listen2 (net.js:1264:19)
                                    hm-rpc.1	2018-04-17 11:45:23.550	error	uncaught exception: listen EADDRNOTAVAIL 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:45:23.549	info	xmlrpc client is trying to connect to 192.168.113.30:2010 with ["http://192.168.113.31:2010","hm-rpc.1"]
                                    hm-rpc.1	2018-04-17 11:45:23.548	info	xmlrpc server is trying to listen on 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:45:23.445	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
                                    host.iobroker	2018-04-17 11:45:23.307	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                                    host.iobroker	2018-04-17 11:45:23.307	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: port: 2001 }
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: address: '192.168.113.31',
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: syscall: 'listen',
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: errno: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: code: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:45:23.307	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at net.js:1423:9
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at listen (net.js:1313:10)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at Server._listen2 (net.js:1264:19)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
                                    host.iobroker	2018-04-17 11:45:23.306	error	Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.113.31:2001
                                    hm-rpc.0	2018-04-17 11:45:23.286	info	Disconnected
                                    hm-rpc.0	2018-04-17 11:45:23.278	info	Connected
                                    hm-rpc.0	2018-04-17 11:45:23.225	info	binrpc -> 192.168.113.30:2001 init ["xmlrpc_bin://192.168.113.31:2001",""]
                                    hm-rpc.0	2018-04-17 11:45:23.225	error	Error: listen EADDRNOTAVAIL 192.168.113.31:2001 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at Server._listen2 (net.js:1264:19)
                                    hm-rpc.0	2018-04-17 11:45:23.225	error	uncaught exception: listen EADDRNOTAVAIL 192.168.113.31:2001
                                    hm-rpc.0	2018-04-17 11:45:23.225	info	binrpc client is trying to connect to 192.168.113.30:2001 with ["xmlrpc_bin://192.168.113.31:2001","hm-rpc.0"]
                                    hm-rpc.0	2018-04-17 11:45:23.224	info	binrpc server is trying to listen on 192.168.113.31:2001
                                    hm-rpc.0	2018-04-17 11:45:23.077	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
                                    host.iobroker	2018-04-17 11:45:22.632	info	instance system.adapter.hm-rpc.1 started with pid 11397
                                    host.iobroker	2018-04-17 11:45:22.291	info	instance system.adapter.hm-rpc.0 started with pid 11391
                                    rpi2.0	2018-04-17 11:45:20.156	error	No Value found for soc_temp
                                    rpi2.0	2018-04-17 11:45:20.156	error	Cannot evaluate: Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf /dev/md2 933062924 608113720 324949204 66% / /1024
                                    rpi2.0	2018-04-17 11:45:20.155	error	Cannot evaluate: Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf /dev/md2 933062924 608113720 324949204 66% / /1024
                                    rpi2.0	2018-04-17 11:45:20.155	error	No Value found for memory_available
                                    rpi2.0	2018-04-17 11:45:20.155	error	No Value found for mem_gpu
                                    rpi2.0	2018-04-17 11:45:20.155	error	No Value found for mem_arm
                                    rpi2.0	2018-04-17 11:45:20.154	error	No Value found for cpu_voltage
                                    host.iobroker	2018-04-17 11:44:52.625	info	Restart adapter system.adapter.hm-rpc.1 because enabled
                                    host.iobroker	2018-04-17 11:44:52.625	error	instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
                                    host.iobroker	2018-04-17 11:44:52.625	error	Caught by controller[0]: port: 2010 }
                                    host.iobroker	2018-04-17 11:44:52.625	error	Caught by controller[0]: address: '192.168.113.31',
                                    host.iobroker	2018-04-17 11:44:52.625	error	Caught by controller[0]: syscall: 'listen',
                                    host.iobroker	2018-04-17 11:44:52.625	error	Caught by controller[0]: errno: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: code: 'EADDRNOTAVAIL',
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at net.js:1423:9
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at listen (net.js:1313:10)
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at Server._listen2 (net.js:1264:19)
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
                                    host.iobroker	2018-04-17 11:44:52.624	error	Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
                                    host.iobroker	2018-04-17 11:44:52.623	error	Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:44:52.605	info	Disconnected
                                    hm-rpc.1	2018-04-17 11:44:52.569	info	Connected
                                    hm-rpc.1	2018-04-17 11:44:52.509	info	xmlrpc -> 192.168.113.30:2010 init ["http://192.168.113.31:2010",""]
                                    hm-rpc.1	2018-04-17 11:44:52.509	error	Error: listen EADDRNOTAVAIL 192.168.113.31:2010 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at Server._listen2 (net.js:1264:19)
                                    hm-rpc.1	2018-04-17 11:44:52.509	error	uncaught exception: listen EADDRNOTAVAIL 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:44:52.509	info	xmlrpc client is trying to connect to 192.168.113.30:2010 with ["http://192.168.113.31:2010","hm-rpc.1"]
                                    hm-rpc.1	2018-04-17 11:44:52.507	info	xmlrpc server is trying to listen on 192.168.113.31:2010
                                    hm-rpc.1	2018-04-17 11:44:52.400	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.1
                                    host.iobroker	2018-04-17 11:44:52.284	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                                    LG
                                    Christian
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #83
                                      Kannst du deine CCU aus dem Docker per ping erreichen?
                                      ping 192.168.133.30
                                      Wie sehen die RPC Adapter Einstellungen aus?
                                      Bei mir sieht es so aus:
                                      192.168.178.8 ist meine CCU
                                      192.168.178.18 mein iobroker
                                      Mach doch mal den haken bei der Markierung rein.
                                      Edit: Du musst glaube ich noch die Callback Adresse kontrollieren und auf die von deinem NAS Einstellen.
                                      • P Offline
                                        PapaChriLo
                                        #84
                                        @wendy2702:
                                        ping 192.168.133.30
                                        Edit: Du musst glaube ich noch die Callback Adresse kontrollieren und auf die von deinem NAS Einstellen. `
                                        OK schaut gut aus.
                                        zumindestens sind die rpc-Adapter nach dem eintragen der Callbackadresse jetzt grün.
                                        So wie es aussieht hab ich jetzt noch das Problem mit dem influxdb
                                        der ist weiter auf Gelb und mein flot zeigt nichts an
                                        LG
                                        Christian
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #85
                                          Ok. Den nutze ich leider nicht und kann dir dazu nichts sagen.
                                          Funktioniert das schalten über Vis denn wieder ?
