  4. Maxcul einrichtung
    5.9k
Maxcul einrichtung
14 Beiträge 4 Kommentatoren 2.4k Aufrufe
    DUDU
    • apollon77A Offline
      Du kannst mal den Loglevel auf Debug setzen (Instanzen -> Expertenmodus -> Loglevel auf debug setzen bei der Instanz.
      Danach mal versuchen zu pairen und Log senden
        DUDU
        maxcul.0 2018-03-17 23:12:27.291 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:27.289 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:27.287 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:12:22.290 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:22.288 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:22.286 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:12:17.287 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:17.285 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:17.281 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:12:12.284 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:12.279 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:12.277 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:12:07.277 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:07.275 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:07.273 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:12:02.271 debug delayed next send by 0ms (Queue length left = 0)
        maxcul.0 2018-03-17 23:12:02.269 debug serial port buffer have been drained
        maxcul.0 2018-03-17 23:12:02.268 debug Send Packet to CUL: X, awaiting drain event
        maxcul.0 2018-03-17 23:11:57.267 debug delayed next send by 0ms (Queue length left = 0)
        • dabbeljuhD Offline
          dabbeljuhD Offline
          dabbeljuh
          Guten Morgen,
          ich hatte anfangs auch so meine Probleme damit, den CUL zum Laufen zu bringen. Aus den Gründen hab ich bisher auch immer noch die Version 0.3.0 installiert und auf Updates verzichtet. Damit funktioniert bei mir soweit alles. Vielleicht versuchst du es mal mit dieser Version.
          Soweit ich es noch im Hinterkopf habe, könnte es auch an der installierten CUL Library liegen. Eventuell kannst du auch dort ansetzen.
          Beste Grüße
          dabbeljuh
          NUC, Z-Stick Gen5, maxCUL 433, JeeLink/LaCrosse, Zigbee-Stick; Z-Wave Tür-/Fenster u. Steckdosen, max! Tür-/Fenster u. Wandschalter, TX29DTH-IT, HUE, Osram, TP-Link, Xiaomi, IP-Cams, Echo Dot, Sonos, Home mini, Xiaomi Kontakte u. Sensoren
            Also wenn er einen nanocul hat dann geht mit der 0.3 nahezu nix, weil der ne sezielle Behandung braucht - die ist in 0.5 drin.
            Das interessante am obigen Log ist das gar nichts kommt - hast Du versucht die Geräte anzulernen?
              DUDU
              ja habe versucht die Geräte anzulernen, 30 Sekunden rum und der log zeigt nix.
              Könnte es vielleicht doch an der installation des NanoCUL und der Library liegen?
                Wenn er am Anfang (siehst Du auch im Log) korrekt verbindet zum nanocul verbindet sollte er auch empfangen …
                Kannst Du versuchen direkt die Heizkörperdinger anzulernen und zu steuern?
                  DUDU
                  Hm wüste nicht wie ich direkt anlernen kann?
                  Kann ich mit den daten von max cube etwas anfangen?
                    skraw.iobroker
                    hab den Thread grade mal kurz gelesen. Wir sollten ganz vorne anfangen. Kannst Du mal ein Log posten das direkt beim Reload der maxcul Instanz beginnt. Erst Loglevel auf debug stellen, dann per "Kreispfeil" den Reload ausloesen und das Log ab dann posten, so die ersten 20-30 Zeilen.
                      DUDU
                      hallo skraw.iobroker danke für deine hilfe
                      habe den pi neu gestartet und hir der log
                      maxcul.0 2018-03-19 20:43:57.498 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:57.496 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:52.493 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:52.492 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:52.489 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:47.494 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:47.488 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:47.486 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:42.490 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:42.486 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:42.485 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:37.481 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:37.480 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:37.478 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:32.481 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:32.479 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:32.476 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:28.502 debug Za drained
                      maxcul.0 2018-03-19 20:43:28.499 debug Za written
                      maxcul.0 2018-03-19 20:43:28.497 debug Zr drained
                      maxcul.0 2018-03-19 20:43:28.495 debug Zr written
                      maxcul.0 2018-03-19 20:43:28.493 debug X20 drained
                      maxcul.0 2018-03-19 20:43:28.490 debug X20 written
                      maxcul.0 2018-03-19 20:43:28.488 debug enable MAX! Mode of the CUL868
                      maxcul.0 2018-03-19 20:43:27.477 debug delayed next send by 0ms (Queue length left = 0)
                      maxcul.0 2018-03-19 20:43:27.474 debug serial port buffer have been drained
                      maxcul.0 2018-03-19 20:43:27.470 debug Send Packet to CUL: X, awaiting drain event
                      maxcul.0 2018-03-19 20:43:24.501 info CUL FW Version: V 1.67 nanoCUL433
                      maxcul.0 2018-03-19 20:43:24.497 debug incoming raw data from CUL: V 1.67 nanoCUL433
                      maxcul.0 2018-03-19 20:43:24.483 debug Requested CUL Version…
                      maxcul.0 2018-03-19 20:43:24.475 debug check CUL Firmware version
                      maxcul.0 2018-03-19 20:43:22.468 info serialPort /dev/ttyUSB0 is open!
                      maxcul.0 2018-03-19 20:43:22.447 info using serial device /dev/ttyUSB0@38400
                      maxcul.0 2018-03-19 20:43:21.994 info starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.13.1
                      maxcul.0 2018-03-19 20:43:21.884 debug statesDB connected
                      maxcul.0 2018-03-19 20:43:21.812 debug objectDB connected
                      maxcul.0 2018-03-19 20:43:17.831 info terminating
                      maxcul.0 2018-03-19 20:42:57.917 info CUL FW Version: V 1.67 nanoCUL433
                      maxcul.0 2018-03-19 20:42:55.885 info serialPort /dev/ttyUSB0 is open!
                      maxcul.0 2018-03-19 20:42:55.862 info using serial device /dev/ttyUSB0@38400
                      maxcul.0 2018-03-19 20:42:55.411 info starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.13.1
                      maxcul.0 2018-03-19 20:42:51.297 info terminating
                        skraw.iobroker
                        Ja Moment, das ist ja ein 433 CUL. Bist Du sicher dass Deine Thermostate auf 433 senden? Die MAX die ich kenne machen 868 …?
                          DUDU
                          433 CUL :o habe ein 868 gekauft 😢
                          na dann kann das ja auch nicht funzen :oops: :oops:
                          danke skraw.iobroker
