  4. Maxcul einrichtung
    5.9k
Maxcul einrichtung
14 Beiträge 4 Kommentatoren 2.4k Aufrufe
  • apollon77A Offline
    Welche Version des Adapters nutzt Du?
      DUDU
        Du kannst mal den Loglevel auf Debug setzen (Instanzen -> Expertenmodus -> Loglevel auf debug setzen bei der Instanz.
        Danach mal versuchen zu pairen und Log senden
          DUDU
          maxcul.0 2018-03-17 23:12:27.291 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:27.289 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:27.287 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:12:22.290 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:22.288 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:22.286 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:12:17.287 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:17.285 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:17.281 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:12:12.284 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:12.279 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:12.277 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:12:07.277 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:07.275 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:07.273 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:12:02.271 debug delayed next send by 0ms (Queue length left = 0)
          maxcul.0 2018-03-17 23:12:02.269 debug serial port buffer have been drained
          maxcul.0 2018-03-17 23:12:02.268 debug Send Packet to CUL: X, awaiting drain event
          maxcul.0 2018-03-17 23:11:57.267 debug delayed next send by 0ms (Queue length left = 0)
          • dabbeljuhD Offline
            dabbeljuhD Offline
            dabbeljuh
            Guten Morgen,
            ich hatte anfangs auch so meine Probleme damit, den CUL zum Laufen zu bringen. Aus den Gründen hab ich bisher auch immer noch die Version 0.3.0 installiert und auf Updates verzichtet. Damit funktioniert bei mir soweit alles. Vielleicht versuchst du es mal mit dieser Version.
            Soweit ich es noch im Hinterkopf habe, könnte es auch an der installierten CUL Library liegen. Eventuell kannst du auch dort ansetzen.
            Beste Grüße
            dabbeljuh
            NUC, Z-Stick Gen5, maxCUL 433, JeeLink/LaCrosse, Zigbee-Stick; Z-Wave Tür-/Fenster u. Steckdosen, max! Tür-/Fenster u. Wandschalter, TX29DTH-IT, HUE, Osram, TP-Link, Xiaomi, IP-Cams, Echo Dot, Sonos, Home mini, Xiaomi Kontakte u. Sensoren
              Also wenn er einen nanocul hat dann geht mit der 0.3 nahezu nix, weil der ne sezielle Behandung braucht - die ist in 0.5 drin.
              Das interessante am obigen Log ist das gar nichts kommt - hast Du versucht die Geräte anzulernen?
                DUDU
                ja habe versucht die Geräte anzulernen, 30 Sekunden rum und der log zeigt nix.
                Könnte es vielleicht doch an der installation des NanoCUL und der Library liegen?
                  Wenn er am Anfang (siehst Du auch im Log) korrekt verbindet zum nanocul verbindet sollte er auch empfangen …
                  Kannst Du versuchen direkt die Heizkörperdinger anzulernen und zu steuern?
                    DUDU
                    Hm wüste nicht wie ich direkt anlernen kann?
                    Kann ich mit den daten von max cube etwas anfangen?
                      skraw.iobroker
                      hab den Thread grade mal kurz gelesen. Wir sollten ganz vorne anfangen. Kannst Du mal ein Log posten das direkt beim Reload der maxcul Instanz beginnt. Erst Loglevel auf debug stellen, dann per "Kreispfeil" den Reload ausloesen und das Log ab dann posten, so die ersten 20-30 Zeilen.
                        DUDU
                        hallo skraw.iobroker danke für deine hilfe
                        habe den pi neu gestartet und hir der log
                        maxcul.0 2018-03-19 20:43:57.498 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:57.496 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:52.493 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:52.492 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:52.489 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:47.494 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:47.488 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:47.486 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:42.490 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:42.486 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:42.485 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:37.481 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:37.480 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:37.478 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:32.481 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:32.479 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:32.476 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:28.502 debug Za drained
                        maxcul.0 2018-03-19 20:43:28.499 debug Za written
                        maxcul.0 2018-03-19 20:43:28.497 debug Zr drained
                        maxcul.0 2018-03-19 20:43:28.495 debug Zr written
                        maxcul.0 2018-03-19 20:43:28.493 debug X20 drained
                        maxcul.0 2018-03-19 20:43:28.490 debug X20 written
                        maxcul.0 2018-03-19 20:43:28.488 debug enable MAX! Mode of the CUL868
                        maxcul.0 2018-03-19 20:43:27.477 debug delayed next send by 0ms (Queue length left = 0)
                        maxcul.0 2018-03-19 20:43:27.474 debug serial port buffer have been drained
                        maxcul.0 2018-03-19 20:43:27.470 debug Send Packet to CUL: X, awaiting drain event
                        maxcul.0 2018-03-19 20:43:24.501 info CUL FW Version: V 1.67 nanoCUL433
                        maxcul.0 2018-03-19 20:43:24.497 debug incoming raw data from CUL: V 1.67 nanoCUL433
                        maxcul.0 2018-03-19 20:43:24.483 debug Requested CUL Version…
                        maxcul.0 2018-03-19 20:43:24.475 debug check CUL Firmware version
                        maxcul.0 2018-03-19 20:43:22.468 info serialPort /dev/ttyUSB0 is open!
                        maxcul.0 2018-03-19 20:43:22.447 info using serial device /dev/ttyUSB0@38400
                        maxcul.0 2018-03-19 20:43:21.994 info starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.13.1
                        maxcul.0 2018-03-19 20:43:21.884 debug statesDB connected
                        maxcul.0 2018-03-19 20:43:21.812 debug objectDB connected
                        maxcul.0 2018-03-19 20:43:17.831 info terminating
                        maxcul.0 2018-03-19 20:42:57.917 info CUL FW Version: V 1.67 nanoCUL433
                        maxcul.0 2018-03-19 20:42:55.885 info serialPort /dev/ttyUSB0 is open!
                        maxcul.0 2018-03-19 20:42:55.862 info using serial device /dev/ttyUSB0@38400
                        maxcul.0 2018-03-19 20:42:55.411 info starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.13.1
                        maxcul.0 2018-03-19 20:42:51.297 info terminating
                          skraw.iobroker
                          Ja Moment, das ist ja ein 433 CUL. Bist Du sicher dass Deine Thermostate auf 433 senden? Die MAX die ich kenne machen 868 …?
                            DUDU
                            433 CUL :o habe ein 868 gekauft 😢
                            na dann kann das ja auch nicht funzen :oops: :oops:
                            danke skraw.iobroker
