  4. Aktion bei Öffnen der Tür
    6.0k
23 Beiträge 4 Kommentatoren 3.2k Aufrufe
  • MatzebhvM Offline
    MatzebhvM Offline
    Matzebhv
    Moin, stell mal einen Export von deinem Blockly hier ein.
    Matze
    • G Offline
      Gerni
      @Matzebhv:
      Matze ` Moin Matze,
      Kurz per Smartphone, hoffe das geht so.
      Stefan
      name="OID">mihome.0.devices.magnet_158d0001d821d1.state
      <field name="CONDITION">true</field>
      <statement name="STATEMENT"><block type="controls_if" id="r4;C-s:gJHryisv4KGb"><value name="IF0"><block type="logic_compare" id="UDQ/e84{v6!/G]9t7QB"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="U2EWT0XNsJOW]@]Yk=~f"><field name="ATTR">val</field>
      <field name="OID">hm-rpc.0.NEQ1554160.1.LEVEL</field></block></value>
      <value name="B"><block type="math_number" id="p?TJR~lG*ACFgAtTx8Q6"><field name="NUM">25</field></block></value></block></value>
      <statement name="DO0"><block type="control" id="|~G:]+8EHMW;8*1-^?~j"><mutation delay_input="false"></mutation>
      <field name="OID">hm-rpc.0.NEQ1502825.1.STATE</field>
      <value name="VALUE"><block type="logic_boolean" id="qsYjuh[gII/kw%kZfqH]"><field name="BOOL">TRUE</field></block></value>
      <next><block type="control" id="SV6|mmgVvsHrftVuT6}%"><mutation delay_input="false"></mutation>
      <field name="OID">deconz.0.deCONZ-GW.Gartenlampe 1.on</field>
      <value name="VALUE"><block type="logic_boolean" id="O5*RQyaef-63V-6:vO}w"><field name="BOOL">TRUE</field></block></value>
      <next><block type="control" id="sp-Am7zz%V.HpKKWy^i@"><mutation delay_input="false"></mutation>
      <field name="OID">deconz.0.deCONZ-GW.Gartenlampe 2.on</field>
      <value name="VALUE"><block type="logic_boolean" id=".Y%:Pk;+ksY3wnPi}_O@"><field name="BOOL">TRUE</field></block></value></block></next></block></next></block></statement>
      <next><block type="timeouts_cleartimeout" id="^<EMAIL email=" 9knde@5r7dmo.pb3zwr"="">9kndE@5R7DmO.Pb3ZWr">
      <next><block type="timeouts_settimeout" id="1m)Q_r6s:]S6[6JqKIcH"><field name="NAME">timeout</field>
      <field name="DELAY">3</field>
      <field name="UNIT">min</field>
      <statement name="STATEMENT"><block type="controls_if" id="q}VKP`-H5aXwG#1=6+qW"><value name="IF0"><block type="logic_compare" id="a/Ep-G.tm?WS;as%~Qg7"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="#8~y]1qOkiU/kT2-dbbY"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="8`oY:2LS{#!H|zj0)Q+b"><field name="NUM">25</field></block></value></block></value>
      <statement name="DO0"><block type="control" id="ftP!r*}f{K0X.R)Uax?:"><mutation delay_input="false"></mutation>
      <value name="VALUE"><block type="logic_boolean" id="Z7hs,k@|2R:*~^FsIB~#"><field name="BOOL">FALSE</field></block></value>
      <next><block type="control" id="cIKwJ?N*55Y%,|u}i5M0"><mutation delay_input="true"></mutation>
      <field name="DELAY_MS">10</field>
      <value name="VALUE"><block type="logic_boolean" id="1–}A40(#RWjEV,0F5q["><field name="BOOL">FALSE</field></block></value>
      <next><block type="control" id="0]8k?Pv3;K-fMv.V=d;+"><mutation delay_input="true"></mutation>
      <value name="VALUE"><block type="logic_boolean" id="0*=dU@/:Jh%34EkY5^j7"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></statement></block></next></block></next></block></statement>
      Gesendet von meinem MI 5s mit Tapatalk
      Jede Menge verschiedenes Zeug
      • wendy2702W Offline
        wendy2702W Offline
        Das Blockly Bitte in Spoiler und Code Tags Posten/ändern.
        • G Offline
          Gerni
          @wendy2702:
          Gesendet von iPhone mit Tapatalk Pro ` Ehm. Was soll ich? Bin aktuell nur mit dem Smartphone unterwegs. Kann man da so nichts mit anfangen?
            wendy2702W Offline
            Doch… ist nur gerade am Smartphone für alle anderen bisschen blöd zu lesen.
            Bei Tapatalk gibt es am iPhone (bei Android auch!?) links neben dem Textfeld ein „+“
            Da mal drücken ...
            • G Offline
              Gerni
              Dann versuche ich es mal am Notebook. Meint ihr so? Diese Funktionen sehe ich in der App nicht, aber das ist hier jetzt nicht das Thema.
              <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on" id="X;Cp_fbl5.{}9+*MBtnW" x="-162" y="-12"><field name="OID">mihome.0.devices.magnet_158d0001d821d1.state</field>
              <statement name="STATEMENT"><block type="controls_if" id="r4;C-s:gJHryisv4KGb`"><value name="IF0"><block type="logic_compare" id="UDQ/e84{v6!/G`]9t7QB"><field name="OP">LT</field>
                  <next><block type="timeouts_cleartimeout" id="^9kndE@5R7DmO.Pb3ZWr"><field name="NAME">timeout</field>
                                      <value name="VALUE"><block type="logic_boolean" id="1--}A40(#RWjEV,0F5q["><field name="BOOL">FALSE</field></block></value>
                                          <value name="VALUE"><block type="logic_boolean" id="0*=dU@/:Jh%34EkY5^j7"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></statement></block></statement></block></next></block></next></block></statement></block></xml>
                wendy2702W Offline
                Ja!
                Das meinte ich. Kein Problem, ist nur einfacher zu lesen und scrollen!
                Danke!
                • paul53P Offline
                  Mit einer Skriptvariablen licht_war_aus müsste es funktionieren.
                  • G Offline
                    Gerni
                    @paul53:
                    Blockly_Licht_war_aus.JPG `
                    Das war es!! Vielen Dank!
                    Ich denke ich muss noch ein bisschen mit den "Variablen" spielen und testen denn so ganz habe ich die Abfragen nicht verstanden.
                    Man setzt eine Variable auf Nicht Wert des Lichtaktors usw… bisschen komisch. Oder kann man das in einem Satz erläutern?
                    Vielen Dank nochmal!
                    • paul53P Offline
                      @Gerni:
                      Oder kann man das in einem Satz erläutern? `
                      Vielleicht verstehst Du es mit umgekerhrter Logik (Skriptvariable bereitsLicht) besser.
                      Die erste Abfrage im oberen Teil dient nur zur Vermeidung überflüssigen Sendens (duty cycle).
                      • G Offline
                        Gerni
                        Ah ok das ist also nur ein Prüfung. Dann habe ich das verstanden denke ich. Danke
                        • G Offline
                          Gerni
                          Hi zusammen,
                          nachdem das Skript bisher ohne Probleme funktioniert ergeben sich im Daily Doing doch noch ein paar Anforderungen.
                          Wenn Helligkeit unter 90 liegt usw geht ja Licht an bei Öffnen der Tür und bleibt dann für 3 Minuten in der Küche und im Garten für 7 (+4) an.
                          Wenn ich jetzt jedoch den Müll raus bringe, dauert 30Sek zB. und gehe dann wieder rein. Dann sind die Lampen ja durch vorheriges Raus gehen bereits an. Entsprechend bleiben die an und der Timeout greift nicht.
                          Gibt es dazu noch etwas um zB zu sagen wenn die Tür innerhalb 1 Min. 2 Mal geöffnet wurde dann schalte Lichter nach Timer aus?
                          Stefan
