  4. Geräte-Tab lädt nicht
    6.8k
12 Beiträge 2 Kommentatoren 213 Aufrufe 2 Beobachtet
  • E Offline
    erazor86
    • Adaptername: Devices
    • Adapterversion: 1.2.14
    • js-controller Version: 7.2.2
    • Admin Version: 7.8.23
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 8 GB
    • Festplattenart: SSD
    • Betriebssystem: linux
    • Nodejs-Version: v22.23.1
    • NPM-Version: 10.9.8
    • Installationsart: manuell?
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: ?
    Linux User bitte hier den Output von iob diag einfügen:
    Script v.2026-06-06
    *** BASE SYSTEM ***
     Static hostname: smarthome
           Icon name: computer
              Kernel: Linux 6.12.93+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 1025 days ago (on 2023-10-10).
    Systemuptime and Load:
     00:18:24 up 8 days,  9:42,  2 users,  load average: 0.24, 0.60, 0.79
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-08-01 00:18:25 CEST
               Universal time: Fri 2026-07-31 22:18:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dirk
    HOME=/home/dirk
    GROUPS=dirk adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            8.2G        3.0G        1.1G        1.2M        4.2G        5.2G
    Swap:           209M          0B        209M
    Total:          8.4G        3.0G        1.3G
    Active iob-Instances:   22
             7819 M total memory
             2815 M used memory
             4114 M active memory
             2281 M inactive memory
             1071 M free memory
              204 M buffer memory
             3829 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 00:18:25 up 8 days,  9:42,  2 users,  load average: 0.24, 0.60, 0.79
    Tasks: 196 total,   4 running, 192 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7819.8 total,   1071.2 free,   2815.8 used,   4033.7 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5004.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda2      ext4      117G   17G   95G  16% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   67M  444M  13% /boot/firmware
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Thu Jul 23 14:35:53 2026] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Thu Jul 23 14:35:54 2026] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.2G    /var/
    1.7G    /var/log/journal/b455be8338b6460298ef84109d332adc
    1.7G    /var/log
    1.1G    /var/lib
    Archived and active journals take up 1.6G in the file system.
    /opt/iobroker/backups:
    5.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.6G    /opt/iobroker/iobroker-data/history
    276M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    55M     /opt/iobroker/iobroker-data/files/material
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.23.1
    /usr/bin/node           v22.23.1
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.1-1nodesource1
      Candidate: 22.23.2-1nodesource1
      Version table:
         22.23.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
     *** 22.23.1-1nodesource1 1001
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    smarthome           smarthome (version: 7.2.2, hostname: smarthome     , alive, uptime: 97328)
    Core adapters versions
    js-controller:  7.2.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     1
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
      system.adapter.devices.0                : devices               : smarthome                                -  enabled
    + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
      system.adapter.flot.0                   : flot                  : smarthome                                - disabled
    + system.adapter.ham.0                    : ham                   : smarthome                                -  enabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
    + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : smarthome                                -  enabled
    + system.adapter.jarvis.1                 : jarvis                : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
      system.adapter.material.0               : material              : smarthome                                - disabled
    + system.adapter.modbus.0                 : modbus                : smarthome                                -  enabled
    + system.adapter.modbus.1                 : modbus                : smarthome                                -  enabled
    + system.adapter.net-tools.0              : net-tools             : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
    + system.adapter.sma-em.0                 : sma-em                : smarthome                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.statistics.0             : statistics            : smarthome                                -  enabled
      system.adapter.telegram.0               : telegram              : smarthome                                - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : smarthome                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                - disabled
      system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : smarthome                                -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.backitup'           │ 'backitup'           │ '3.3.17' │ 'none'         │
    │ 2       │ 'system.adapter.bring'              │ 'bring'              │ '1.8.4'  │ 'none'         │
    │ 3       │ 'system.adapter.devices'            │ 'devices'            │ '1.2.14' │ 'none'         │
    │ 4       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'  │ 'none'         │
    │ 5       │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0' │ 'none'         │
    │ 6       │ 'system.adapter.ham'                │ 'ham'                │ '5.3.1'  │ 'none'         │
    │ 7       │ 'system.adapter.history'            │ 'history'            │ '4.0.0'  │ 'none'         │
    │ 8       │ 'system.adapter.ical'               │ 'ical'               │ '1.20.1' │ 'none'         │
    │ 9       │ 'system.adapter.icons-icons8'       │ 'icons-icons8'       │ '0.0.1'  │ 'none'         │
    │ 10      │ 'system.adapter.icons-mfd-svg'      │ 'icons-mfd-svg'      │ '1.2.0'  │ 'none'         │
    │ 11      │ 'system.adapter.influxdb'           │ 'influxdb'           │ '4.0.2'  │ 'none'         │
    │ 12      │ 'system.adapter.jarvis'             │ 'jarvis'             │ '3.1.8'  │ 'none'         │
    │ 13      │ 'system.adapter.javascript'         │ 'javascript'         │ '9.0.18' │ 'none'         │
    │ 14      │ 'system.adapter.material'           │ 'material'           │ '1.3.1'  │ 'none'         │
    │ 15      │ 'system.adapter.modbus'             │ 'modbus'             │ '8.0.3'  │ 'none'         │
    │ 16      │ 'system.adapter.net-tools'          │ 'net-tools'          │ '1.2.3'  │ 'none'         │
    │ 17      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1' │ 'none'         │
    │ 18      │ 'system.adapter.shuttercontrol'     │ 'shuttercontrol'     │ '2.0.12' │ 'none'         │
    │ 19      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'  │ 'none'         │
    │ 20      │ 'system.adapter.sma-em'             │ 'sma-em'             │ '1.3.1'  │ 'none'         │
    │ 21      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'  │ 'none'         │
    │ 22      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.4.14' │ 'none'         │
    │ 23      │ 'system.adapter.statistics'         │ 'statistics'         │ '5.0.0'  │ 'none'         │
    │ 24      │ 'system.adapter.telegram'           │ 'telegram'           │ '4.1.0'  │ 'none'         │
    │ 25      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
    │ 26      │ 'system.adapter.vis-google-fonts'   │ 'vis-google-fonts'   │ '1.0.4'  │ 'none'         │
    │ 27      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'  │ 'none'         │
    │ 28      │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.94' │ 'none'         │
    │ 29      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
    │ 30      │ 'system.adapter.whatsapp-cmb'       │ 'whatsapp-cmb'       │ '0.3.0'  │ 'none'         │
    │ 31      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "sma-em"       : 1.3.1    , installed 1.3.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "statistics"   : 5.0.0    , installed 5.0.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        6535
    States:         5285
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
    W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Get:5 https://apt.grafana.com stable InRelease [7661 B]
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Err:5 https://apt.grafana.com stable InRelease
    Err:7 https://repos.influxdata.com/debian stable InRelease
    Fetched 6922 B in 1s (4725 B/s)
    Reading package lists...
    Pending systemupdates: 2
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q              Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                         0.0.0.0:50290              0.0.0.0:*    users:(("avahi-daemon",pid=551,fd=14))
    udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=551,fd=12))
    udp   UNCONN 0      0                         0.0.0.0:9522               0.0.0.0:*    users:(("io.sma-em.0",pid=791494,fd=30))
    udp   UNCONN 0      0                         0.0.0.0:5683               0.0.0.0:*    users:(("io.shelly.0",pid=791465,fd=35))
    udp   UNCONN 0      0      [fe80::811e:585:55be:ecc3]:dhcpv6-client            *:*    users:(("NetworkManager",pid=596,fd=24))
    udp   UNCONN 0      0                               *:58361                    *:*    users:(("avahi-daemon",pid=551,fd=15))
    udp   UNCONN 0      0                               *:mdns                     *:*    users:(("avahi-daemon",pid=551,fd=13))
    tcp   LISTEN 0      128                       0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=681,fd=3))
    tcp   LISTEN 0      511                       0.0.0.0:8400               0.0.0.0:*    users:(("io.jarvis.0",pid=791638,fd=30))
    tcp   LISTEN 0      511                       0.0.0.0:8401               0.0.0.0:*    users:(("io.jarvis.1",pid=791650,fd=30))
    tcp   LISTEN 0      511                     127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=791185,fd=29))
    tcp   LISTEN 0      511                     127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=791185,fd=23))
    tcp   LISTEN 0      128                          [::]:ssh                   [::]:*    users:(("sshd",pid=681,fd=4))
    tcp   LISTEN 0      4096                            *:3000                     *:*    users:(("grafana",pid=816,fd=9))
    tcp   LISTEN 0      511                             *:8084                     *:*    users:(("io.web.1",pid=791662,fd=30))
    tcp   LISTEN 0      4096                            *:8086                     *:*    users:(("influxd",pid=748,fd=496))
    tcp   LISTEN 0      511                             *:tproxy                   *:*    users:(("io.admin.0",pid=791204,fd=35))
    tcp   LISTEN 0      511                             *:8082                     *:*    users:(("io.web.0",pid=791575,fd=30))
    2026-08-01 00:09:26.973  - info: ham.0 (791512) stateChange ham.0.Spa-Thermostat.Thermostat.Current-Temperature {"val":35.5,"ack":true,"ts":1785535766942,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1785532466810}
    2026-08-01 00:09:26.975  - info: ham.0 (791512) stateChange ham.0.Spa-Thermostat.Thermostat.Target-Temperature {"val":30,"ack":true,"ts":1785535766943,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1785494760009}
    2026-08-01 00:09:26.978  - info: ham.0 (791512) stateChange ham.0.Spa-Thermostat.Thermostat.Target-Heating-Cooling-State {"val":1,"ack":true,"ts":1785535766943,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1781130125340}
    2026-08-01 00:09:26.980  - info: javascript.0 (791269) script.js.common.Pool.Verbrauchsberechnung_Pool_2: DEBUG: Event Poolheizung: neuer Wert: 0
    2026-08-01 00:09:26.981  - info: javascript.0 (791269) script.js.common.Pool.Verbrauchsberechnung_Pool_2: DEBUG: handleSwitch für heater - isOn: false (State: 0)
    2026-08-01 00:09:26.980  - info: ham.0 (791512) stateChange ham.0.Spa-Thermostat.Thermostat.Current-Heating-Cooling-State {"val":0,"ack":true,"ts":1785535766943,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1785494353891}
    2026-08-01 00:09:26.983  - info: ham.0 (791512) stateChange ham.0.Spa-Flow.00000083.Leak-Detected {"val":0,"ack":true,"ts":1785535766944,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1732522268384}
    2026-08-01 00:09:26.986  - info: ham.0 (791512) stateChange ham.0.Spa-Flow.00000083.Status-Fault {"val":0,"ack":true,"ts":1785535766944,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1781130125421}
    2026-08-01 00:09:27.040  - info: ham.0 (791512) stateChange ham.0.Hold-Spa.Switch.On {"val":false,"ack":true,"ts":1785535767035,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1785007442436}
    2026-08-01 00:09:27.043  - info: ham.0 (791512) stateChange ham.0.Spa-Settings.Lock-Mechanism.Lock-Current-State {"val":0,"ack":true,"ts":1785535767035,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1719417340842}
    2026-08-01 00:09:27.047  - info: ham.0 (791512) stateChange ham.0.Spa-Settings.Lock-Mechanism.Lock-Target-State {"val":0,"ack":true,"ts":1785535767036,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1719417340842}
    2026-08-01 00:09:27.049  - info: ham.0 (791512) stateChange ham.0.Spa-Panel.Lock-Mechanism.Lock-Current-State {"val":0,"ack":true,"ts":1785535767036,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747679708175}
    2026-08-01 00:09:27.052  - info: ham.0 (791512) stateChange ham.0.Spa-Panel.Lock-Mechanism.Lock-Target-State {"val":0,"ack":true,"ts":1785535767036,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747679708090}
    2026-08-01 00:09:27.055  - info: ham.0 (791512) stateChange ham.0.Spa-Heat-Mode-Ready.Switch.On {"val":false,"ack":true,"ts":1785535767036,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1780945439491}
    2026-08-01 00:10:00.015  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:11:00.009  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:12:00.011  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:12:20.817  - info: admin.0 (791204) <== Disconnect system.user.admin from ::ffff:192.168.178.232 devices
    2026-08-01 00:13:00.012  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:14:00.004  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:15:00.015  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:16:00.008  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:17:00.021  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:18:00.003  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    2026-08-01 00:19:00.022  - debug: javascript.0 (791269) script.js.common.Pool.Temperatursteuerung_2_9: [Pool-Heizung] Außerhalb Zeitfenster
    ich habe vor ca. 2 Wochen nochmal updates nach dem mir bekannten verfahren durchgeführt:
    sudo apt update
    iob stop
    sudo apt upgrade
    sudo reboot
    iob update
    iob upgrade all
    iob stop
    iob upgrade self
    iob restart
    Als ich dann gestern neue Geräte mit Alias versehen wollte, stellte ich fest, dass der geräte-Tab leider nicht mehr lädt. ansonsten funktioniert alles reibungslos, auch bereits vergeben alias funktionieren. Hat jemand eine Idee was die Ursache sein könnte?
    Hier noch ein Auszug aus der Browser-Konsole:
    • E erazor86
      Script v.2026-06-06
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      dirk
      HOME=/home/dirk
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               7819 M total memory
               2815 M used memory
               1071 M free memory
                204 M buffer memory
               3829 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      3.2G    /var/
      1.7G    /var/log
      1.1G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.8.23
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6535
      States:         5285
      sudo apt update
      iob stop
      sudo apt upgrade
      sudo reboot
      iob update
      iob upgrade all
      iob stop
      iob upgrade self
      iob restart
      @erazor86 sagte:
      Mach das. Und die Repos für Influx und Grafana auch aktualisieren.
      • E Offline
        erazor86
        okay danke für den Hinweis. Beim release-Wechsel geht ja eigentlich nur komplette Neuinstallation über den imager korrekt? Indem Fall werde ich dann wohl auch mal einen Systemwechsel in Erwägung ziehen und auf einen mini pc gehen wo ich dann auch proxmox aufspiele.
        die alias sind mir erstmal nicht so wichtig bis das neue System läuft... spricht ja nichts dagegen das ganze noch ein paar Wochen so zu betreiben oder? Das neue System kann ich dann parallel in Betrieb nehmen und nachher alle Backups einspielen, oder spricht da etwas gegen?
        habt ihr Empfehlungen wegen der Hardware? Ich plane auf dem Rechner dann iobroker, influx, grafana und paperless ngx.
        Dachte an einen Lenovo ThinkCentre M710q mit i5 7500t, 16gb ram und 250 ssd?
        • E erazor86
          @erazor86 sagte:
          In deinem Fall dürfte ein Inline-Upgrade möglich sein.
          Dann halt/bring die Quellen dafür auch auf Stand...
          E 1 Antwort Letzte Antwort
            @erazor86 sagte:
            erazor86
            @Thomas-Braun mit den Quellen meinst du Influx db und grafana? da habe ich mich tatsächlich noch nicht mit den updates beschäftigt 😵
            kannst du hier anleitungen empfehlen? ist ja kein direktes iobroker-thema...
            • E erazor86
              @erazor86
              https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
              • E erazor86
                @erazor86
                Zum eigentlichen Thema: Der devices-Adapter wird gerade schwer umgebaut. Versuch mal, wie sich die aktuelle Beta-Version bei dir verhält.
                  @erazor86
                  erazor86
                  schrieb am zuletzt editiert von erazor86
                  Thomas-Braun sagte:
                  @erazor86
                  danke, das sieht gut aus. die Codes kann ich auch so einfach einsetzen um die repos zu aktualisieren? oder sind die nur für neuinstallationen?
                  von der reihenfolge her auch zuerst die repos aktualisieren und dann erst das betriebssystem?
                  Thomas-Braun sagte:
                  @erazor86
                  okay damit meinst du auf meinem aktuellen betriebssystem bookworm oder erst nach release update?
                  • E erazor86
                    Thomas-Braun sagte:
                    @erazor86
                    Thomas-Braun sagte:
                    @erazor86
                    @erazor86 sagte:
                    Ja, das aktualisiert die Repos, bzw. die Schlüssel.
                    Das ist immer das Vorgehen. Zuerst ruft man die Quellen ab und dann spielt man die anstehenden Updates in das System ein.
                    Wie du meinst.
                    • E Offline
                      erazor86
                      okay das wäre dann diese Version 1.1.5? Das irritiert mich gerade, da ich schon auf 1.2.14 bin? oder ist das bei Beta eine neue Nummerierung?Screenshot 2026-08-01 094143.jpg
                      okay habs, hab nicht nach neuen Updates gesucht. jetzt ist es grün hinterlegt und zeigt 3.0.2 als verfügbar an. das wäre dann die beta, korrekt?
                      • E erazor86
                        @erazor86
                        devices
                        latest:	3.0.2 for 31 days
                        stable:	1.2.14 for 5 months
                          @erazor86
                          devices
                          erazor86
                          @Thomas-Braun sagte:
                          @e:)azor86
                          devices
                          sorry bin jetzt erst dazu gekommen und hab die Beta installiert, der Rest ist noch auf älterem Stand und es hat funktioniert 👍 . dann werde ich mich jetzt mal um die nächsten Themen kümmern :)
