  4. [ gelöst ]vis-inventwo 4.1 Fehler
    5.8k
5 Beiträge 2 Kommentatoren 224 Aufrufe 2 Beobachtet
  • I Offline
    I Offline
    ioBrokerMike
    schrieb am zuletzt editiert von ioBrokerMike
    Moin
    @skvarel
    Nach dem heutigen Update auf 4.1 kommen diese Fehler.
    Nutzen tue ich VIS-2
    Zeit
    silly
    Nachricht
    web.0
    2026-05-29 13:00:22.859	error	10 - at VisCanWidget.renderWidget (http://192.168.178.11:8082/vis-2/assets/visWidgetsCatalog-D4OT0wlf.js:20690:59)
    web.0
    2026-05-29 13:00:22.859	error	9 - at Object.template (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1401:47)
    web.0
    2026-05-29 13:00:22.859	error	8 - at Function.renderAs (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1465:39)
    web.0
    2026-05-29 13:00:22.858	error	7 - at Function.renderTo (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1449:63)
    web.0
    2026-05-29 13:00:22.858	error	6 - at r (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1370:22)
    web.0
    2026-05-29 13:00:22.857	error	5 - at Function.frag (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1405:22)
    web.0
    2026-05-29 13:00:22.857	error	4 - at Function.hookup (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1418:19)
    web.0
    2026-05-29 13:00:22.857	error	3 - at a.each (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:343:211)
    web.0
    2026-05-29 13:00:22.856	error	2 - at HTMLSpanElement.<anonymous> (http://192.168.178.11:8082/vis-2/lib/js/can.custom.js:1419:98)
    web.0
    2026-05-29 13:00:22.856	error	1 - at Object.eval (i-vis-universal.js:22:87)
    web.0
    2026-05-29 13:00:22.856	error	0 - TypeError: Cannot read properties of undefined (reading 'universalButton2')TypeError: Cannot read properties of undefined (reading 'universalButton2')
    web.0
    2026-05-29 13:00:22.855	error	can't render i-vis-universal w000280 on "HomeUnten":
    web.0
    2026-05-29 13:00:22.853	error	10 - at VisCanWidget.renderWidget (http://192.168.178.11:8082/vis-2/assets/visWidgetsCatalog-D4OT0wlf.js:20690:59)
    Mfg
    IOBrokerMike
    Achtung ! Sehkraft 25% | 60% , kein scherz
    Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
    skvarelS 2 Antworten Letzte Antwort
    • I ioBrokerMike
      Moin
      @skvarel
      Zeit
      silly
      Nachricht
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      skvarelS Offline
      skvarelS Offline
      skvarel
      @ioBrokerMike ... das sind auch die VIS1 Widgets. Bitte NICHT in VIS2 nutzen. Am besten, den Adapter komplett deinstallieren, wenn du eh VIS2 nutzt.
      #TeamInventwo
      Unsere Adapter:
      • I ioBrokerMike
        Moin
        @skvarel
        Zeit
        silly
        Nachricht
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        skvarelS Offline
        skvarelS Offline
        skvarel
        @ioBrokerMike
        Bei VIS2 bitte nur diese Widgets nutzen:
        #TeamInventwo
        Unsere Adapter:
        • I Offline
          I Offline
          ioBrokerMike
          Vielen Dank !
          Für die Info, hatte Sie teilweise bis heute genutzt.
          Dann habe ich wieder was zu tun ;-)
          Mfg
          IOBrokerMike
          skvarelS 1 Antwort Letzte Antwort
          • I ioBrokerMike
            Vielen Dank !
            skvarelS Offline
            skvarelS Offline
            skvarel
            @ioBrokerMike .. das hatten wir aber auch kommuniziert, dass die Widgets nicht VIS2-Kompatibel sind.
            Der Widget-Adapter für VIS1 wird auch nicht weiterentwickelt. @jkvarel hat jetzt nur den Adapter einmal auf einen aktuellen Stand gebracht und die Widgets im VIS-Editor ausgeblendet, damit sie nicht mehr 'versehentlich' genutzt werden.
            #TeamInventwo
            Unsere Adapter:
