  4. Fehlermeldung im DWD Adapter
    6.1k
60 Beiträge 8 Kommentatoren 6.7k Aufrufe 7 Beobachtet
  • L Linguistix
    uff wie setzt man das als liste rein oder war das richtig so?
    Eine Warnung zeigt er mir gerade noch an.
    2026-05-08 17:16:55.856  - info: host.iobroker iobroker Adapter "system.adapter.vis.0" restarted.
    2026-05-08 17:16:56.150  - info: host.iobroker iobroker host.iobroker object system.adapter.vis-bars created/updatedUpdating objects from io-package.json for adapter "vis-bars" with version "0.1.4"
    2026-05-08 17:16:56.192  - info: host.iobroker iobroker INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-bars/www" was not found! Nothing was uploaded or deleted.
    2026-05-08 17:16:56.205  - info: host.iobroker "system.adapter.vis.0" disabled
    2026-05-08 17:16:56.206  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
    2026-05-08 17:16:56.211  - info: host.iobroker "system.adapter.vis.0" enabled
    2026-05-08 17:16:56.211  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
    2026-05-08 17:16:56.214  - info: host.iobroker iobroker Adapter "system.adapter.vis.0" restarted.
    2026-05-08 17:16:56.231  - info: host.iobroker iobroker host.iobroker create instance vis-bars
    2026-05-08 17:16:56.237  - info: host.iobroker iobroker host.iobroker object system.adapter.vis-bars.0 created
    2026-05-08 17:16:57.270  - info: host.iobroker iobroker exit 0
    2026-05-08 17:16:57.540  - info: vis.0 (10661) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
    2026-05-08 17:16:57.636  - info: vis.0 (10661) config.js changed. Upload.
    2026-05-08 17:16:57.735  - info: vis.0 (10661) Changes in index.html detected => update cache.manifest
    2026-05-08 17:16:57.743  - info: vis.0 (10661) Upload vis anew, while changes detected...
    2026-05-08 17:16:58.652  - info: admin.0 (9912) ==> Connected system.user.admin from ::ffff:192.168.0.42
    2026-05-08 17:16:59.090  - info: host.iobroker "system.adapter.vis.0" disabled
    2026-05-08 17:16:59.090  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
    2026-05-08 17:16:59.115  - info: host.iobroker "system.adapter.vis.0" enabled
    2026-05-08 17:16:59.115  - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=true)
    2026-05-08 17:17:01.648  - info: vis.0 (10661) Uploaded. 0
    2026-05-08 17:17:01.830  - info: admin.0 (9912) <== Disconnect system.user.admin from ::ffff:192.168.0.42
    2026-05-08 17:17:02.390  - info: vis.0 (10661) Terminated (NO_ERROR): Without reason
    2026-05-08 17:17:02.406  - warn: host.iobroker instance system.adapter.vis.0 already running with pid 10661
    2026-05-08 17:17:02.952  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
    @Linguistix sagte:
    Da fehlt aber einiges
    L 1 Antwort Letzte Antwort
    • L Linguistix
      @Linguistix sagte:
      Kopier das ganze einfach inkl. der Kopiermarken hier rein.
      Setz den rene in die Gruppe adm rein:
      sudo usermod -aG adm rene
        @Linguistix sagte:
        Linguistix
        @Homoran sagte:
        @Linguistix sagte:
        ok was fehlt alles noch?
        Gruß René
        • IoBroker auf Windows 10 (Testsystem)
        • IoBroker auf Intel Nuc i3 (Produktivsystem)
        • Homematic IP
        • Rolladenaktor Broll
        • Tür Sensoren
        • Samsung TAB A als Anzeige
        • L Linguistix
          @Homoran sagte:
          @Linguistix sagte:
          @Linguistix sagte:
          @Thomas-Braun sagte:
          • L Linguistix
            @Homoran sagte:
            @Linguistix sagte:
            @Linguistix sagte:
            Der vollständige Output von
            iob diag
            Nachdem der user rene zur Gruppe adm hinzugefügt und der Hobel einmal sauber neugestartet wurde.
            • L Offline
              Linguistix
              geht das einfach per copy paste oder muss ich noch etwas beachten?
              Gruß René
              • Homematic IP
              • Tür Sensoren
                @Linguistix sagte:
                iob diag
                Linguistix
                @Linguistix sagte:
                iob diag
                wie füge ich den user zum adm hinzu?
                Gruß René
                • Homematic IP
                • Tür Sensoren
                • L Linguistix
                  @Linguistix
                  Einfach per C&P hier reinklatschen. Die Steuerzeichen für die Forensoftware sind da schon richtig enthalten.
                    @Linguistix sagte:
                    Thomas-Braun sagte:
                    • L Linguistix
                      @Linguistix sagte:
                      iob diag
                      @Linguistix sagte:
                        Thomas-Braun sagte:
                        Linguistix
                        ok hab ich gemacht kann man das prüfen das dass dann auch so ist?
                        Gruß René
                        • Homematic IP
                        • Tür Sensoren
                        • L Linguistix
                          @Linguistix sagte:
                          @Linguistix sagte:
                          iob diag
                          • L Offline
                            Linguistix
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                            Operating System: Debian GNU/Linux 13 (trixie)
                             Static hostname: iobroker
                                   Icon name: computer-desktop
                                     Chassis: desktop 🖥️
                                      Kernel: Linux 6.12.85+deb13-amd64
                                Architecture: x86-64
                             Hardware Vendor: Intel Corporation
                              Hardware Model: D33217CK
                            Firmware Version: GKPPT10H.86A.0066.2018.1120.1113
                               Firmware Date: Tue 2018-11-20
                                Firmware Age: 7y 5month 2w 3d
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
                            Docker          : false
                            Virtualization  : none
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             17:32:27 up 59 min,  2 users,  load average: 0.04, 0.20, 0.27
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            Operating System is the current Debian stable version codenamed 'trixie'!
                            *** TIME AND TIMEZONES ***
                                           Local time: Fri 2026-05-08 17:32:27 CEST
                                       Universal time: Fri 2026-05-08 15:32:27 UTC
                                             RTC time: Fri 2026-05-08 15:32:27
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            rene
                            HOME=/home/rene
                            GROUPS=rene adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
                            iobroker
                            HOME=/home/iobroker
                            SUDO_HOME=/home/rene
                            GROUPS=iobroker tty dialout audio video plugdev
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server:         false
                            Unit display-manager.service could not be found.
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:            8.3G        1.3G        4.3G        3.4M        3.0G        6.9G
                            Swap:           6.6G          0B        6.6G
                            Total:           14G        1.3G         10G
                            Active iob-Instances:   9
                                     7879 M total memory
                                     1262 M used memory
                                      872 M active memory
                                     2526 M inactive memory
                                     4089 M free memory
                                      142 M buffer memory
                                     2688 M swap cache
                                     6302 M total swap
                                        0 M used swap
                                     6302 M free swap
                            top - 17:32:27 up 59 min,  2 users,  load average: 0.04, 0.20, 0.27
                            Tasks: 155 total,   1 running, 154 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.2 us,  0.0 sy,  0.0 ni, 97.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   7879.6 total,   4087.5 free,   1264.2 used,   2831.3 buff/cache
                            MiB Swap:   6303.0 total,   6303.0 free,      0.0 used.   6615.4 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            udev           devtmpfs  3.8G     0  3.8G   0% /dev
                            tmpfs          tmpfs     788M  692K  788M   1% /run
                            /dev/sda2      ext4      110G  3.4G  101G   4% /
                            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                            efivarfs       efivarfs  128K   76K   48K  62% /sys/firmware/efi/efivars
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
                            tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
                            /dev/sda1      vfat      975M  8.8M  966M   1% /boot/efi
                            tmpfs          tmpfs     788M  4.0K  788M   1% /run/user/1000
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty6.servi        ce
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
                            [Fri May  8 16:32:39 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                            [Fri May  8 16:32:39 2026] EXT4-fs (sda2): mounted filesystem 09472f1d-f53c-4d09        -b9b8-1c6d0b2b3fab ro with ordered data mode. Quota mode: none.
                            [Fri May  8 16:32:40 2026] EXT4-fs (sda2): re-mounted 09472f1d-f53c-4d09-b9b8-1c        6d0b2b3fab r/w.
                            Show mounted filesystems:
                            TARGET      SOURCE    FSTYPE OPTIONS
                            /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
                            `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,ioch        arset=ascii,shortname=mixed,utf8,errors=remount-ro
                            /var:
                            514M    /var/
                            287M    /var/cache
                            280M    /var/cache/apt
                            189M    /var/cache/apt/archives
                            187M    /var/lib
                            Archived and active journals take up 24M in the file system.
                            /opt/iobroker/backups:
                            4.0K    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            229M    /opt/iobroker/iobroker-data/
                            208M    /opt/iobroker/iobroker-data/files
                            57M     /opt/iobroker/iobroker-data/files/vis-2
                            47M     /opt/iobroker/iobroker-data/files/admin.admin
                            46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                            21M     /opt/iobroker/iobroker-data/objects.jsonl
                            9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                            8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.j        s
                            8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.        js
                            4.1M    /opt/iobroker/iobroker-data/files/vis-2/assets/index-Vp8lqiIh.js
                            USB-Devices by-id:
                            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                            please always prefer the links 'by-id':
                            No Devices found 'by-id'
                            No nvbackup.json found.
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v22.22.2
                            /usr/bin/node           v22.22.2
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            ✓ Node.js installation is correct
                            nodejs:
                              Installed: 22.22.2-1nodesource1
                              Candidate: 22.22.2-1nodesource1
                              Version table:
                             *** 22.22.2-1nodesource1 1001
                                 22.22.1-1nodesource1 1001
                                 22.22.0-1nodesource1 1001
                                 22.21.0-1nodesource1 1001
                                 22.20.0-1nodesource1 1001
                                 22.19.0-1nodesource1 1001
                                 22.18.0-1nodesource1 1001
                                 22.17.1-1nodesource1 1001
                                 22.17.0-1nodesource1 1001
                                 22.16.0-1nodesource1 1001
                                 22.15.1-1nodesource1 1001
                                 22.15.0-1nodesource1 1001
                                 22.14.0-1nodesource1 1001
                                 22.13.1-1nodesource1 1001
                                 22.13.0-1nodesource1 1001
                                 22.12.0-1nodesource1 1001
                                 22.11.0-1nodesource1 1001
                                 22.10.0-1nodesource1 1001
                                 22.9.0-1nodesource1 1001
                                 22.8.0-1nodesource1 1001
                                 22.7.0-1nodesource1 1001
                                 22.6.0-1nodesource1 1001
                                 22.5.1-1nodesource1 1001
                                 22.5.0-1nodesource1 1001
                                 22.4.1-1nodesource1 1001
                                 22.4.0-1nodesource1 1001
                                 22.3.0-1nodesource1 1001
                                 22.2.0-1nodesource1 1001
                                 22.1.0-1nodesource1 1001
                                 22.0.0-1nodesource1 1001
                                 20.19.2+dfsg-1+deb13u2 500
                                    500 http://security.debian.org/debian-security trixie-security/main amd6        4 Packages
                                 20.19.2+dfsg-1 500
                                    500 http://deb.debian.org/debian trixie/main amd64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2117)
                            Core adapters versions
                            admin:          7.8.23
                            javascript:     "javascript" not found
                            nodejs modules from github:     0
                            Adapter State
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
                            + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                            + system.adapter.history.0                : history               : iobroker                                 -  enabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                              system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
                            + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                              system.adapter.vis-jsontemplate.0       : vis-jsontemplate      : iobroker                                 -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Upgrade policy: none
                            Installed ioBroker-Adapters
                            Used repository: stable
                            Adapter    "admin"        : 7.8.23   , installed 7.8.23
                            Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                            Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
                            Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                            Adapter    "history"      : 4.0.0    , installed 4.0.0
                            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                            Adapter    "iot"          : 5.0.12   , installed 5.0.12
                            Controller "js-controller": 7.0.7    , installed 7.0.7
                            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                            Adapter    "socketio"     : 7.0.8    , installed 7.1.3
                            Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
                            Adapter    "vis-jsontemplate": 4.4.3 , installed 4.4.3
                            Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "web"          : 8.0.0    , installed 8.0.0
                            Adapter    "ws"           : 4.0.0    , installed 4.0.0
                            Objects and States
                            Objects:        2136
                            States:         1153
                            Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                            Hit:2 http://deb.debian.org/debian trixie InRelease
                            Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                            Reading package lists...
                            Pending systemupdates: 1
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30917      1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8301       673/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42257      8869/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42262      8869/iobroker.js-co
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          29385      1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          8303       673/sshd: /usr/sbin
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       43909      9929/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47114      9912/io.admin.0
                            udp        0      0 192.168.0.86:68         0.0.0.0:*                           0          6714       811/dhcpcd: [BOOTP
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29383      1/init
                            udp6       0      0 :::111                  :::*                                0          29387      1/init
                            udp6       0      0 2003:c3:3f3a:9100:5:546 :::*                                0          27393      5559/dhcpcd: [DHCP6
                            udp6       0      0 fdd4:279f:7803:0:52:546 :::*                                0          27392      5558/dhcpcd: [DHCP6
                            udp6       0      0 fdd4:279f:7803:0:6f:546 :::*                                0          7364       767/dhcpcd: [DHCP6
                            udp6       0      0 2003:c3:3f3a:9100:6:546 :::*                                0          7357       751/dhcpcd: [DHCP6
                            udp6       0      0 fe80::5043:78fb:8ac:546 :::*                                0          8320       724/dhcpcd: [DHCP6
                            2026-05-08 17:26:30.991  - info: host.iobroker iobroker upload [12] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_blue.png splash/splash_new_blue.png image/png
                            2026-05-08 17:26:31.000  - info: host.iobroker iobroker upload [11] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_brown.png splash/splash_new_brown.png image/png
                            2026-05-08 17:26:31.009  - info: host.iobroker iobroker upload [10] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_green1.png splash/splash_new_green1.png image/png
                            2026-05-08 17:26:31.021  - info: host.iobroker iobroker upload [9] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_green2.png splash/splash_new_green2.png image/png
                            2026-05-08 17:26:31.032  - info: host.iobroker iobroker upload [8] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_lightblue.png splash/splash_new_lightblue.png image/png
                            2026-05-08 17:26:31.041  - info: host.iobroker iobroker upload [7] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_orange.png splash/splash_new_orange.png image/png
                            2026-05-08 17:26:31.051  - info: host.iobroker iobroker upload [6] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_pink.png splash/splash_new_pink.png image/png
                            2026-05-08 17:26:31.060  - info: host.iobroker iobroker upload [5] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_rose.png splash/splash_new_rose.png image/png
                            2026-05-08 17:26:31.069  - info: host.iobroker iobroker upload [4] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_violet.png splash/splash_new_violet.png image/png
                            2026-05-08 17:26:31.078  - info: host.iobroker iobroker upload [3] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_orange.png splash/splash_orange.png image/png
                            2026-05-08 17:26:31.087  - info: host.iobroker iobroker upload [2] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_pink.png splash/splash_pink.png image/png
                            2026-05-08 17:26:31.096  - info: host.iobroker iobroker upload [1] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_rose.png splash/splash_rose.png image/png
                            2026-05-08 17:26:31.105  - info: host.iobroker iobroker upload [0] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_violet.png splash/splash_violet.png image/png
                            2026-05-08 17:26:31.154  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png created/updated
                            2026-05-08 17:26:31.158  - info: host.iobroker iobroker Updating objects from io-package.json for adapter "icons-addictive-flavour-png" with version "0.1.0"
                            2026-05-08 17:26:31.220  - info: host.iobroker iobroker host.iobroker create instance icons-addictive-flavour-png
                            2026-05-08 17:26:31.230  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png.upload created
                            2026-05-08 17:26:31.236  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png.0 created
                            2026-05-08 17:26:32.269  - info: host.iobroker iobroker exit 0
                            2026-05-08 17:26:33.678  - info: admin.0 (9912) ==> Connected system.user.admin from ::ffff:192.168.0.42
                            2026-05-08 17:30:31.035  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 12342
                            2026-05-08 17:30:32.541  - info: dwd.0 (12342) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
                            2026-05-08 17:30:32.925  - info: dwd.0 (12342) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2026-05-08 17:30:33.465  - info: host.iobroker instance system.adapter.dwd.0 having pid 12342 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2026-05-08 17:32:37.036  - info: admin.0 (9912) <== Disconnect system.user.admin from ::ffff:192.168.0.42
                            iob diag has finished.
                            Gruß René
                            • Homematic IP
                            • Tür Sensoren
                            • L Offline
                              Linguistix
                              das sollte der komplette sein
                              Gruß René
                              • Homematic IP
                              • Tür Sensoren
                              • L Linguistix
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                         Chassis: desktop 🖥️
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                              NTP service: active
                                          RTC in local TZ: no
                                rene
                                HOME=/home/rene
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           6.6G          0B        6.6G
                                Total:           14G        1.3G         10G
                                         7879 M total memory
                                         1262 M used memory
                                          872 M active memory
                                         4089 M free memory
                                          142 M buffer memory
                                         2688 M swap cache
                                         6302 M total swap
                                            0 M used swap
                                         6302 M free swap
                                *** FILESYSTEM ***
                                /var:
                                514M    /var/
                                287M    /var/cache
                                280M    /var/cache/apt
                                187M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.9.7
                                /usr/bin/npx            10.9.7
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.8.23
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        2136
                                States:         1153
                                @Linguistix sagte:
                                rene
                                HOME=/home/rene
                                Da ist er
                                L Thomas BraunT 2 Antworten Letzte Antwort
                                  @Linguistix sagte:
                                  rene
                                  HOME=/home/rene
                                  Da ist er
                                  Linguistix
                                  @Homoran sagte:
                                  @Linguistix sagte:
                                  rene
                                  HOME=/home/rene
                                  Da ist er
                                  gerade auch gesehen :)
                                  Gruß René
                                  • Homematic IP
                                  • Tür Sensoren
                                    @Linguistix sagte:
                                    rene
                                    HOME=/home/rene
                                    Da ist er
                                    @Homoran sagte:
                                    Da ist er
                                    Und der Meckerfritze ist auch zufrieden, der Hinweis im Skript ist weg.
                                    • L Offline
                                      Linguistix
                                      das freut mich, ach meckern darfst ruhig muss mich erst rein fuxen wieder in das ganze gerade was debian angeht, aber der Tip nur Debian zu nutzen war Gold wert und macht auch mega sin. Danke für die echt gute Hilfe
                                      Gruß René
                                      • Homematic IP
                                      • Tür Sensoren
                                      • L Linguistix
                                        @Linguistix
                                        System auf Stand bringen:
                                        ioBroker ebenfalls.
                                        Ansonsten schaut das Setup sehr gut aus.
                                        • L Offline
                                          Linguistix
                                          ok das klingt ja schon mal nicht schlecht.
                                          Gruß René
                                          • Homematic IP
                                          • Tür Sensoren
