  4. IOT Update 5.0.12 [solved]
    6.8k
6 Beiträge 2 Kommentatoren 305 Aufrufe 2 Beobachtet
    Dragon
    schrieb am zuletzt editiert von Dragon
    Nach dem Update auf die neueste Stable schmeißt er nur noch Fehler und wird nicht mehr grün.
    Hat jemand eine Idee?
    host.ioBroker
    2026-03-27 18:10:42.539	info	Restart adapter system.adapter.iot.0 because enabled
    host.ioBroker
    2026-03-27 18:10:42.538	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:681:33)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:935:32)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:704:44)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7649:20)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7916:25)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2124:27)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:156:9)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
    host.ioBroker
    2026-03-27 18:10:42.538	error	Caught by controller[0]: TypeError: request.headers.split is not a function
    iot.0
    2026-03-27 18:10:42.386	error	request.headers.split is not a function
    iot.0
    2026-03-27 18:10:42.386	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9) at Channel.publish (node:diagnostics_channel:156:9) at new Request (node:internal/deps/undici/undici:2124:27) at Client.[dispatch] (node:internal/deps/undici/undici:7916:25) at Intercept (node:internal/deps/undici/undici:7649:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16) at Client.dispatch (node:internal/deps/undici/undici:704:44) at Pool.[dispatch] (node:internal/deps/undici/undici:935:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:681:33)
    iot.0
    2026-03-27 18:10:42.384	error	uncaught exception: request.headers.split is not a function
    host.ioBroker
    2026-03-27 18:10:40.277	info	instance system.adapter.iot.0 in version "5.0.12" started with pid 2851
    • D Dragon
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      iot.0
      iot.0
      iot.0
      host.ioBroker
      @Dragon
      Schau dir die Ausgabe von
      iob diag
      an. Ist jedenfalls kein generelles Problem mit der Version, hier läuft es nämlich.
      -1
        @Dragon
        iob diag
        Dragon
        @Thomas-Braun
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
         Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm 🖴
            AF_VSOCK CID: 1
          Virtualization: kvm
                  Kernel: Linux 6.12.74+deb13+1-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
           Firmware Date: Tue 2014-04-01
            Firmware Age: 11y 11month 3w 5d
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:16:04 up 14 min,  1 user,  load average: 1.17, 1.77, 1.38
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2026-03-27 18:16:04 CET
                   Universal time: Fri 2026-03-27 17:16:04 UTC
                         RTC time: Fri 2026-03-27 17:16:04
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        brokeradmin
        HOME=/home/brokeradmin
        GROUPS=brokeradmin adm dialout sudo audio video plugdev users iobroker
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/brokeradmin
        GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:             10G        5.4G        4.1G        5.8M        1.3G        5.1G
        Swap:           2.1G          0B        2.1G
        Total:           12G        5.4G        6.2G
        Active iob-Instances:   70
                 9951 M total memory
                 5109 M used memory
                 4795 M active memory
                  863 M inactive memory
                 3910 M free memory
                  133 M buffer memory
                 1076 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 18:16:05 up 14 min,  1 user,  load average: 1.17, 1.77, 1.38
        Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   9951.8 total,   3910.0 free,   5110.0 used,   1210.0 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4841.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  4.9G     0  4.9G   0% /dev
        tmpfs          tmpfs     996M  548K  995M   1% /run
        /dev/sda1      ext4       54G   32G   20G  62% /
        tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
        tmpfs          tmpfs     4.9G  5.0M  4.9G   1% /tmp
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
        tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/1002
        [Fri Mar 27 18:02:25 2026] EXT4-fs (sda1): mounted filesystem a6df39e5-8210-4c92-b9c8-b4b557b9e693 ro with ordered data mode. Quota mode: none.
        [Fri Mar 27 18:02:26 2026] EXT4-fs (sda1): re-mounted a6df39e5-8210-4c92-b9c8-b4b557b9e693 r/w.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.4G    /var/
        1003M   /var/log
        979M    /var/log/journal/58d2cc2a97184623922200d7fac194bf
        206M    /var/cache
        Archived and active journals take up 978.2M in the file system.
        /opt/iobroker/backups:
        11G     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.5G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/files
        759M    /opt/iobroker/iobroker-data/history
        310M    /opt/iobroker/iobroker-data/backup-objects
        267M    /opt/iobroker/iobroker-data/files/vis
        40M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/states.jsonl
        32M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        *** ZigBee Settings ***
        ⚠ HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'.
        Please check your setting:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.22.1
        /usr/bin/node           v22.22.1
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        ✓ Node.js installation is correct
        nodejs:
          Installed: 22.22.1-1nodesource1
          Candidate: 22.22.0-1nodesource1
          Version table:
         *** 22.22.1-1nodesource1 100
             22.22.0-1nodesource1 1001
             22.21.0-1nodesource1 1001
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             20.19.2+dfsg-1+deb13u1 500
                500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
             20.19.2+dfsg-1 500
                500 http://deb.debian.org/debian trixie/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 822)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.22
        javascript:     9.0.18
        nodejs modules from github:     8
        +-- iobroker.apsystemsez1@0.0.7 (git+ssh://git@github.com/hefegraphie/ioBroker.apsystemsez1.git#0e771c9d92c4bb4e662b09022820f2aa48358c50)
        +-- iobroker.bambulab@0.4.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#3a38d1d67d09c3cf5f88544e5996f40d5d7e3557)
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        +-- iobroker.nebenkosten-monitor@1.2.2 (git+ssh://git@github.com/fischi87/ioBroker.nebenkosten-monitor.git#6bcdd0aaa88e00bc9c29a312073050c5e5353b0a)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        +-- iobroker.unifi-network@1.3.1 (git+ssh://git@github.com/Scrounger/ioBroker.unifi-network.git#334428eaab151812f80637c435a12083ffb43e51)
        +-- iobroker.utility-monitor@1.5.0 (git+ssh://git@github.com/fischi87/ioBroker.utility-monitor.git#64de59c8aaa26c92f3fcacac80c123bcc2bc9b16)
        +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
        Adapter State
        + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.apsystemsez1.0           : apsystemsez1          : ioBroker                                 -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
        + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
          system.adapter.chromecast.0             : chromecast            : ioBroker                                 - disabled
        + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
        + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
          system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
        + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
        + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
          system.adapter.iceroad.0                : iceroad               : ioBroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
          system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: ioBroker                                 -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : ioBroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
          system.adapter.icons-smarthome.0        : icons-smarthome       : ioBroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
        + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
          system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
        + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
        + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
        + system.adapter.meross.1                 : meross                : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
        + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
        + system.adapter.nebenkosten-monitor.0    : nebenkosten-monitor   : ioBroker                                 -  enabled
        + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
        + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
        + system.adapter.notificationforandroidtv.0: notificationforandroidtv: ioBroker                                 -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
          system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
          system.adapter.openmediavault.0         : openmediavault        : ioBroker                                 - disabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        + system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
        + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
          system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
          system.adapter.sayit.0                  : sayit                 : ioBroker                                 - disabled
          system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
          system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1885, bind: 192.168.178.3
        + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
        + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
          system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 - disabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.3               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.4               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.5               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
        + system.adapter.text2command.2           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 8443
          system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
        + system.adapter.utility-monitor.0        : utility-monitor       : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
          system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.windows-control.0        : windows-control       : ioBroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
        + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "adguard"      : 1.1.1    , installed 1.1.1
        Adapter    "admin"        : 7.7.22   , installed 7.7.22
        Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
        Adapter    "countdown"    : 3.1.0    , installed 3.1.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.15.5  , installed 2.15.5
        Adapter    "devices"      : 1.2.14   , installed 1.2.14
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "ical"         : 1.19.7   , installed 1.19.7
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
        Adapter    "imap"         : 0.3.0    , installed 0.3.0
        Adapter    "iot"          : 5.0.12   , installed 5.0.12
        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "logparser"    : 2.4.0    , installed 2.4.0
        Adapter    "matter"       : 0.5.6    , installed 1.0.0
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mytime"       : 2.3.2    , installed 2.3.2
        Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
        Adapter    "nina"         : 0.0.25   , installed 0.0.26
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openmediavault": 1.4.2   , installed 1.4.2
        Adapter    "openweathermap": 1.4.0   , installed 1.4.0
        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
        Adapter    "samsung"      : 0.7.0    , installed 0.7.0
        Adapter    "sayit"        : 5.1.0    , installed 5.1.0
        Adapter    "schoolfree"   : 1.1.13   , installed 1.1.13
        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
        Adapter    "shuttercontrol": 2.0.11  , installed 2.0.11
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
        Adapter    "socketio"     : 7.0.8    , installed 7.0.8
        Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "text2command" : 4.0.0    , installed 4.0.0
        Adapter    "trashschedule": 3.3.0    , installed 4.0.0
        Adapter    "tuya"         : 3.16.0   , installed 3.17.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "unifi-network": 1.3.1    , installed 1.3.1
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
        Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
        Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
        Adapter    "vis-2-widgets-jaeger-design": 1.4.18, installed 1.4.18
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
        Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
        Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
        Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
        Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-material" : 0.2.0    , installed 0.2.0
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
        Adapter    "weather-warnings": 0.10.0, installed 0.10.0
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "wled"         : 0.7.3    , installed 0.7.3
        Adapter    "ws"           : 4.0.0    , installed 4.0.0
        Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
        Objects and States
        Objects:        30418
        States:         25134
        Hit:1 http://security.debian.org/debian-security trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
        Reading package lists...
        Pending systemupdates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6641       1052/exim4
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       7231       785/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       7236       785/iobroker.js-con
        tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       9373       1441/io.mqtt.0
        tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       9374       1441/io.mqtt.0
        tcp        0      0 192.168.178.3:1885      0.0.0.0:*               LISTEN      1000       10659      1938/io.shelly.0
        tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       9747       1621/io.sonoff.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          838        1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6512       829/sshd: /usr/sbin
        tcp6       0      0 :::8086                 :::*                    LISTEN      1000       11961      2318/io.ws.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       11022      2302/io.simple-api.
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       10976      2271/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       10850      2243/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       6746       1071/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6642       1052/exim4
        tcp6       0      0 :::51989                :::*                    LISTEN      1000       9783       1643/io.nuki-extend
        tcp6       0      0 :::111                  :::*                    LISTEN      0          840        1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6514       829/sshd: /usr/sbin
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       11863      2151/io.upnp.0
        udp        0      0 0.0.0.0:44869           0.0.0.0:*                           1000       28545      3382/io.matter.0
        udp        0      0 0.0.0.0:53621           0.0.0.0:*                           1000       11671      2151/io.upnp.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       27518      3382/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       27869      3382/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       11840      2255/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       10668      1904/io.ham.0
        udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1000       27868      3382/io.matter.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       10531      1784/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       10532      1784/io.tuya.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       7703       1246/io.broadlink2.
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839        1/init
        udp        0      0 0.0.0.0:50178           0.0.0.0:*                           1000       8328       1246/io.broadlink2.
        udp        0      0 0.0.0.0:34057           0.0.0.0:*                           1000       7714       1246/io.broadlink2.
        udp6       0      0 :::5353                 :::*                                1000       27519      3382/io.matter.0
        udp6       0      0 :::5353                 :::*                                1000       27872      3382/io.matter.0
        udp6       0      0 :::5541                 :::*                                1000       27867      3382/io.matter.0
        udp6       0      0 :::40712                :::*                                1000       28544      3382/io.matter.0
        udp6       0      0 :::111                  :::*                                0          841        1/init
        2026-03-27 18:15:39.650  - error: matter.0 (2594) request.headers.split is not a function
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]: TypeError: request.headers.split is not a function
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Channel.publish (node:diagnostics_channel:156:9)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at new Request (node:internal/deps/undici/undici:2124:27)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Client.[dispatch] (node:internal/deps/undici/undici:7916:25)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Intercept (node:internal/deps/undici/undici:7649:20)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:688:16)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Client.dispatch (node:internal/deps/undici/undici:704:44)
        2026-03-27 18:15:40.075  - error: host.ioBroker Caught by controller[0]:     at Pool.[dispatch] (node:internal/deps/undici/undici:935:32)
        2026-03-27 18:15:40.076  - error: host.ioBroker Caught by controller[0]:     at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:681:33)
        2026-03-27 18:15:40.076  - error: host.ioBroker instance system.adapter.matter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2026-03-27 18:15:40.076  - info: host.ioBroker Restart adapter system.adapter.matter.0 because enabled
        2026-03-27 18:16:10.886  - info: host.ioBroker instance system.adapter.matter.0 in version "1.0.0" started with pid 3382
        2026-03-27 18:16:22.500  - error: matter.0 (3382) Cannot initialize device deb4f42d-cb42-45af-b453-10e8900567dc "Heizung Automatik Gäste WC" because 0_userdata.0.Automatikmodi.InfrarotHeizungAutomatik does not exist! Check configuration.
        • D Dragon
          @Thomas-Braun
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
              AF_VSOCK CID: 1
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          brokeradmin
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   9951 M total memory
                   5109 M used memory
                   3910 M free memory
                    133 M buffer memory
                   1076 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          1.4G    /var/
          1003M   /var/log
          206M    /var/cache
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        30418
          States:         25134
          @Dragon
          Schalt mal sentry für den Adapter aus.
            @Dragon
            Dragon
            @Thomas-Braun Vielen vielen Dank für die schnelle Hilfe! Ihr seid echt die Besten!
            • D Dragon
              @apollon77 Da ist wohl irgendwas am sentry 'putt. :-D
