  4. 16 bit signed Float einlesen über den Node-red Modbus
    6.0k
67 Beiträge 5 Kommentatoren 17.6k Aufrufe
  • J Offline
    JXA
    Hallo "Graf" vielen Dank für deine Hilfe!
    Das auslesen der Register über node red funktioniert also "sauber",
    das Problem liegt also in der "Funktion" um die Werte Dezimal anzeigen zu können.
    Könntest Du die Funktion im Sample Code anpassen um die Sache besser zu verstehen?
    Nochmals vielen Dank an "Starter" dafür!!
    [{"id":"6f92b84.0ef3ac8","type":"modbus-read","z":"7d4de8d.1542118","name":"X320_Read","topic":"","showStatusActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"272","quantity":"2","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"741a094c.1340b8","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":330,"y":260,"wires":[[],["3de8b140.13ce2e","cca0874c.f3d76"]]},{"id":"3de8b140.13ce2e","type":"function","z":"7d4de8d.1542118","name":" 32bit","func":"msg.payload=msg.payload.buffer.readFloatLE(0,1,2,3);\nreturn msg;\n","outputs":1,"noerr":0,"x":510,"y":400,"wires":[["f6427835.8241b"]]},{"id":"f6427835.8241b","type":"debug","z":"7d4de8d.1542118","name":"","active":true,"console":"false","complete":"false","x":690,"y":540,"wires":[]},{"id":"cca0874c.f3d76","type":"modbus-response","z":"7d4de8d.1542118","name":"","registerShowMax":20,"x":600,"y":260,"wires":[]},{"id":"741a094c.1340b8","type":"modbus-client","z":"","name":"X320","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"192.168.0.48","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"}]
    • G Offline
      Garf
      @JXA:
      Nochmals vielen Dank an "Starter" dafür!! `
      Ich kopiere mir keine Flows mit IP-Adressen die es in meinem Netzwerk nicht gibt in meine laufenden Flows. Dies führt nur zu Problemen. Bitte poste doch einfach mal ein paar Screenshots vom Inhalt des Function Node und die Bufferwerte.
      Soviel ich aus dem Flow herauslesen kann, liest Du zwei Modbusregister in vier Buffer ein.
      Was steht denn in den Buffern 2 und 3?
      Ich kann es zwar nicht testen, aber wenn in den Buffern 0 und 1 die Werte 32771, 16806 stehen, dann müsttest Du nur die Reihenfolge des Einlesens ändern:
      msg.payload.buffer.readFloatLE(1,0)
      Dann sollte der gewünschte Wert richtig angezeigt werden. Ich kann dies leider nicht im wirklichen Wirkbetrieb testen, es sollte aber eigentlich so funktionieren.
      Garf
      • J Offline
        JXA
        Hallo "Graf"
        vielen Dank für deine Antwort!
        Zur bisherigen Funktion:
        ""name":" 32bit","func":"msg.payload=msg.payload.buffer.readFloatLE(0,1,2,3);\nreturn msg"
        Der Gedanke die 16 bit je Register a 2x8Bit einzulesen…
        Also Register 272=(0,1) 273=( 2,3)
        Dank deiner Rechnung ist nun klar das dies nicht erforderlich ist!
        Ich habe die Funktion nun geändert:
        Was zum exakt gleichen Ergebnis führt!
        Die Werte der Register werden im Screenshot im Modbus Response angezeigt.
        Ist die Funktion korrekt von mir übernommen? Habe ich einen Fehler gemacht?
        JXA
        • G Offline
          Garf
          Hi JXA,
          da muss ich meine Aussage von vorhin wohl doch etwas revidieren. Deine Einstellungen im Function-Node waren absolut richtig. Ich hatte einfach vergessen, dass die Javafunktion ja mit den Buffer 8-bit Werten rechnet. Das heißt das Modbusregister 1 und 2 (je 16bit) werden in je zwei Hexzahlen zerlegt und dann als Dezimalzahl umgerechnet.
          Ich habe eben mal verucht die 8-bit Werte von der Reihenfolge 0,1,2,3 in 3,2,0,1 zu ändern. Dies funktioniert aber leider nicht.
          Somit haben wir jetzt zwar eine schöne Javafunktion die uns die Rechenarbeit abnimmt, aber keine Möglichkeit zur Verfügung stellt die Modbusregister von hinten nach vorne einzulesen und umzurechnen. Da müssen wir uns wohl noch etwas einfallen lassen. Ich habe vor einigen Wochen selbst ein Funktion-Node programmiert, welches die Einträge in den Modbusregistern einliest und wieder als Dezimalzahl ausgibt. Ich lese dafür allerdings die Datawerte in msg.payload als Arraywerte ein und kann da auch frei bestimmen in welcher Reihenfolge die Werte eingelesen und zurückgerechnet werden. Damit war es mir dann auch möglich deine geposteten Werte in beiden Varianten einmal zu rechnen.
          Garf
          • J Offline
            JXA
            Hallo Graf,
            super, dann haben wir jetzt das Grundproblem geklärt und einen soliden Status!
            Der aktuelle Sketch sollte ja nur zum testen dienen.
            Ich möchte natürlich über Modbus mehrere Register auslesen und dann anzeigen.
            Somit ist das speichern der Modbuswerte in einem Array unausweichlich.
            Kannst du mir eine Sample code senden mit deinen selbst programmierten Funktions -Node?
            Modbus->Array->Funktion->Ausgabe
            Danke!
            JXA
            • G Offline
              Garf
              @JXA:
              Kannst du mir eine Sample code senden mit deinen selbst programmierten Funktions -Node? `
              Wenn wir keine andere Lösung finden, dann schicke ich dir das selbst programmierte Funktion-Node zu. Im Moment befindet es sich aber noch in einer Rohfassunge und enthält viele Dinge die man in der praktischen Umrechnung nicht mehr braucht. Um Programmierfehler frühzeitig erkennen zu können, musste ich diese allerdings einbauen. Ich habe an dem Node nicht mehr weitergearbeitet, weil es für die Umrechnung ja bereits diese tolle Javascriptfunktion gibt. Wir müssen mal schauen, ob es da nicht auch schon eine Lösung für dein Problem gibt. Ich lese mich da gleich noch einmal ein.
              Garf
              • G Offline
                Garf
                Ich glaube da schon etwas gefunden zu haben.
                https://github.com/biancode/node-red-co … endianness
                Mit der swap Funktion werden tatsächlich die Bufferwerte getauscht.
                Lt. Response stehen als Werte im Buffer 3f 99 99 9a und nach dem swap 99 3f 9a 99. Mir ist nur noch nicht klar was buffer.swap16() macht und ob es die richtige Funktion für dein Problem ist. Da muss man wohl noch mal weiter nachlesen.
                Ich bin mal optimistisch, damit könnten wir es irgendwie hinbekommen. Wenn Du magst, kannst Du ja schon mal ein Versuch starten.
                • J Offline
                  JXA
                  Hallo Graf,
                  danke für die Info.
                  Ich habe den "Buffer Swap" getestet.
                  Er führt aktuell nicht zum gewünschten Ergebnis…
                  Habe ich etwas vergessen??
                  • G Offline
                    Garf
                    Bei mir scheint es zu funktionieren. Du solltest nur das Debug-Node eingeschaltet lassen, welches uns die Meldungen zu dem Function swap-Node zeigt.
                    Bitte den Inhalt des swap-Nodes posten.
                    Ich habe folgende Eintragungen vorgenommen:
                    msg.payload.buffer.swap16();
                    msg.payload = msg.payload.buffer.readFloatBE(0,1,2,3);
                    return msg;
                    • J Offline
                      JXA
                      Habe die Änderung vorgenommen…
                      • G Offline
                        Garf
                        Erstaunlich, dass es funktioniert, Normalerweise hättest Du das BE durch LE ersetzen müssen. Bisher jedenfalls hast Du immer Littel Endian ausgelesen.
                        Hier mal die Grundlagen dazu: https://de.wikipedia.org/wiki/Byte-Reihenfolge
                        Lt. Bedienungsanleitung von deinem X-320 lässt sich die Byte-Reihenfolge einstellen:
                        ` > Big Endian
                        32-bit data is treated as two individual 16-bit words using IEEE 754 floating point format. Floating
                        point format is used for sensor, pulse counter, analog, and frequency data as well as for setting
                        output pulse duration.
                        If the checkbox is set, the X-320™ will use big-endian architecture, and the most significant 16-bit
                        word (big end) is sent first. If the box is cleared, then the X-320™ will use little-endian architecture,
                        and the least significant word (little end) is sent first. The default setting for this box is
                        unchecked,
                        use little-endian.
                        For example, in little-endian format, a 32-bit floating point number represented by '1234 ABCD' is
                        sent as 'ABCD 1234'. `
                        Um Big Endian auslesen zu können verwendest Du die Funktion msg.payload.buffer.readFloatBE(0,1,2,3) und für Littel Endian die Funktion msg.payload.buffer.readFloatLE(0,1,2,3).
                        Nicht, dass wir uns hier ständig im Kreis drehen. Vielleicht im X-320 Big Endian einstellen und dann mal schauen was in den Modbusregistern 1 und 2 steht. Es könnte dir das Auslesen evtl. vereinfachen.
                        • J Offline
                          JXA
                          Hallo Graf,
                          danke für den Hinweis!
                          Hatte ich mit keinem Gedanken mehr daran gedacht…
                          Und jetzt funktioniert es!!!!
                          Danke für DEINE (Eure) Hilfe!
                          • J Offline
                            JXA
                            Hier noch die Funktion…...
                            • P Offline
                              pitu61
                              das ist ja Wahnsinn,
                              was ihr hier zu dem Thema abliefert, ich bin begeistert, nun versuche ich mich
                              damit auch zu befassen, bin jedoch wirklich auf diesem Gebiet ein Noob ;)
                              Ich komme schon gar nicht so weit wie ihr…
                              wenn ich die 32bit function von euch übernehme also:
                              msg.payload.buffer.readFloatLE(0,1.2,3)
                              erhalte ich folgende fehlermeldung:
                              TypeError: Cannot read property 'readFloatLE' of undefined
                              ist das eine zusätzliche Lib die ich übersehen habe, oder warum nimmt er meinem
                              Code nicht an?
                              Verwende einen Raspi mit Node Red drauf.
                              Vielen Dank
                              Pitu61
                                atelmblcd
                                @pitu61:
                                msg.payload.buffer.readFloatLE(0,1.2,3) `
                                du hast ein Punkt zwischen 1.2 stehen es muss (0,1,2,3) sein und nicht vergessen die Funktion unten anzuknÜpfen damit du an die Buffer kommst.
                                Ober wird kein Buffer ausgegeben.
                                MfG
                                Jean
                                • G Offline
                                  Garf
                                  @atelmblcd:
                                  Ober wird kein Buffer ausgegeben. `
                                  Donnerwetter, gute erkannt. Ist mir gar nicht so direkt aufgeallen.
                                  Ich habe mich vielmehr gefragt was will er überhaupt wo und in welchem Format auslesen. Integer- oder Flioatwert, Big Endian oder Littel Endian usw.
                                  Aber vielleicht ist es ja schon genau dieser kleine Tippfehler gewesen.
                                  Aber schön, dass du hier wieder etwas gepostet hast, ich hatte deine Wortmeldungen in den letzten Tagen schon vermisst.
                                    atelmblcd
                                    Ich bin am Hausbauen, und die Handwerker haben diese Woche wieder angefangen zu arbeiten, da kann ich nicht immer online sein.
                                    Ich habe noch eine Methode gefunden.
                                    return [{ payload: msg.payload.buffer.readFloatBE(0,4)},
                                    { payload: msg.payload.buffer.readFloatBE(0,4) }];
                                    Habe mal den Modbussimulator hergenommen
                                    https://sourceforge.net/projects/modrssim/
                                    Die Wert habe ich aus dem Screenshot Buffer 0002 41a2
                                    und in die Kolonne +0 41a2 und in der Kolonne +1 0002 in den Simulator eingegeben,
                                    dann kommt genau der Wert 20,25….. heraus
                                    Die Klammer ()wird anders ausgewertet bei den Floats wenn ich richtg liege.
                                    (0,4) 0 ist wo ich anfange zu lesen und 4 die Anzahl
                                    lese ich z.b 3Stück 32 bit Floats ein und ich will das das 3te 32 bit Float haben so schreibe ich (8,4)
                                    wenn ich nur ein Float habe kann ich die Klammer sogar leer lassen.
                                    gebe ich in der Kolonne +0 0002 und in der Kolonne +1 41a2 in den Simulator kommt -2.6157436202396862e-18
                                    Was komisch ist das es egal ist ob ich LE oder BE angebe die Werte sind immer gleich.
                                    Ist es ein Fehler im Simulator?
                                    Man müsste testen ob das obengenannte Beispiel an dem x320 funktioniert.
                                    Es ist alles so schlecht dokumentiert so dass es nur mit try und error geht, ich hasse das.
                                    MfG
                                    Jean
                                    • J Offline
                                      JXA
                                      Guten Abend!
                                      Ich habe noch 2 Fragen
                                      zum Modbus Read
                                      Kann man mit einer FC3 Abfrage auch Register abfragen die nicht zusammenhängen?
                                      z.B 272-278,528-530…... oder muss man jeden Block einzeln abfragen...
                                      Zur Datenanzeige.
                                      Wie kann ich die Anzahl der angezeigten Stellen einstellen?
                                        atelmblcd
                                        Ja kann man, die Werte sollten jedoch nicht zu weit auseinanderliegen weil man sonst sehr grosse Arrays hat.
                                        bis 50 dürfte kein Problem sein.
                                        Es gibt Modbus Hardware wo ein Limit gesetzt ist, ab einen gewissen Anzahl werden falsche Werte ausgegeben, so steht es jedenfalls in der Anleitung von Klaus ( Authos der Modbus Software) und das sagt er auch in seinem Youtube Video.
                                        https://www.youtube.com/watch?v=YIqb02D3Ps4
                                        Man muss nur die richtige Array oder Buffer Nummer angeben.
                                        MfG
                                        Jean
                                          atelmblcd
                                          Um die stellen in der Gauge zu limitieren einfach
                                          folgendes in der Gauge eingeben
                                          {{value | number:1}}
                                          eingeben 1 steht für 1 Nachkommastelle 2 für 2 Nachkommastellen usw.
