  4. [gelöst] Backitup - NAS ?
    6.4k
101 Beiträge 6 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • HumidorH Humidor
    so, hab das heute mit dem Docker geändert
    15:26:40.652INFOguiBackup gestartet ...
    15:26:41.969DEBUGmountdone
    15:26:54.564DEBUGiobrokerhost.iobroker-iobroker-1-1 54071 objects saved
    15:26:57.643DEBUGiobrokerhost.iobroker-iobroker-1-1 48939 states saved
    15:26:57.649DEBUGiobrokerhost.iobroker-iobroker-1-1 Validating backup ...
    15:26:57.652DEBUGiobrokerhost.iobroker-iobroker-1-1 "config.json" is valid
    host.iobroker-iobroker-1-1 "objects.jsonl" exists
    15:26:57.691DEBUGiobrokerhost.iobroker-iobroker-1-1 "states.jsonl" exists
    15:26:58.485DEBUGiobrokerhost.iobroker-iobroker-1-1 JSONL lines are valid
    15:26:58.597DEBUGiobrokerhost.iobroker-iobroker-1-1 The backup is valid!
    15:27:04.876DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_09-15_26_41_backupiobroker.tar.gz
    15:27:04.884DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
    15:27:06.033DEBUGiobrokerdone
    15:27:07.979DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    15:27:08.101DEBUGjavascriptsfound Script: Bewässerung
    15:27:08.251DEBUGjavascriptsfound Script: EBikeLader
    15:27:08.402DEBUGjavascriptsfound Script: Garage
    15:27:08.551DEBUGjavascriptsfound Script: Grid-PV
    15:27:08.702DEBUGjavascriptsfound Script: HBS
    15:27:08.856DEBUGjavascriptsfound Script: Humidor
    15:27:09.003DEBUGjavascriptsfound Script: Pool
    15:27:09.151DEBUGjavascriptsfound Script: Pool_Steuerung
    15:27:09.303DEBUGjavascriptsfound Script: Priority_Management
    15:27:09.454DEBUGjavascriptsfound Script: Rasen
    15:27:09.609DEBUGjavascriptsfound Script: SE_Power
    15:27:09.756DEBUGjavascriptsfound Script: Sonne
    15:27:09.906DEBUGjavascriptsfound Script: Sonnenstand
    15:27:10.057DEBUGjavascriptsfound Script: Wolken-PV_Home
    15:27:10.207DEBUGjavascriptsfound Script: SmartPlug
    15:27:10.357DEBUGjavascriptsfound Script: Smart_BadHzg
    15:27:10.508DEBUGjavascriptsfound Script: go-E_V3_Charger
    15:27:10.658DEBUGjavascriptsfound Script: go-E_V3_Control
    15:27:10.807DEBUGjavascriptsfound Script: go-E_V3_Debug
    15:27:10.958DEBUGjavascriptsfound Script: go-E_V3_Error
    15:27:11.107DEBUGjavascriptsfound Script: go-E_V3_GridOffset
    15:27:11.256DEBUGjavascriptsfound Script: go-E_V3_Init
    15:27:11.407DEBUGjavascriptsfound Script: go-E_V3_LED
    15:27:11.559DEBUGjavascriptsfound Script: go-E_V3_Limits
    15:27:11.709DEBUGjavascriptsfound Script: go-E_V3_Phasen
    15:27:11.862DEBUGjavascriptsfound Script: go-E_V3_Verriegelung
    15:27:12.010DEBUGjavascriptsfound Script: go-E_V3_Überschuss
    15:27:12.172DEBUGjavascriptsfound Script: go-E_V3_Überwachung
    15:27:12.312DEBUGjavascriptsfound Script: go-E_V4_Control
    15:27:12.463DEBUGjavascriptsfound Script: go-E_V4_Debug
    15:27:12.615DEBUGjavascriptsfound Script: go-E_V4_Error
    15:27:12.767DEBUGjavascriptsfound Script: go-E_V4_GridOffset
    15:27:12.915DEBUGjavascriptsfound Script: go-E_V4_Init
    15:27:13.064DEBUGjavascriptsfound Script: go-E_V4_LED
    15:27:13.217DEBUGjavascriptsfound Script: go-E_V4_Limits
    15:27:13.364DEBUGjavascriptsfound Script: go-E_V4_Phasen
    15:27:13.517DEBUGjavascriptsfound Script: go-E_V4_Verriegelung
    15:27:13.667DEBUGjavascriptsfound Script: go-E_V4_Überwachung
    15:27:13.816DEBUGjavascriptsfound Script: go-E_V4_kWh
    15:27:13.967DEBUGjavascriptsfound Script: MqttBatterie
    15:27:14.118DEBUGjavascriptsfound Script: Victron_INIT
    15:27:14.269DEBUGjavascriptsfound Script: Victron_Mode
    15:27:14.422DEBUGjavascriptsfound Script: Victron_BAT
    15:27:14.570DEBUGjavascriptsfound Script: Victron_EM24
    15:27:14.721DEBUGjavascriptsfound Script: Victron_Mqtt
    15:27:14.871DEBUGjavascriptsfound Script: Victron_Limits
    15:27:15.020DEBUGjavascriptsfound Script: influx
    15:27:15.172DEBUGjavascriptsfound Script: Victron_DiffV
    15:27:15.321DEBUGjavascriptsfound Script: Victron_TOP-Balancing
    15:27:15.471DEBUGjavascriptsfound Script: Hallentore
    15:27:15.623DEBUGjavascriptsfound Script: Grid-PVHalle
    15:27:15.772DEBUGjavascriptsfound Script: go-E_V4_Charger_Neu
    15:27:15.923DEBUGjavascriptsfound Script: Wolken-PV_Halle
    15:27:16.073DEBUGjavascriptsfound Script: Victron_Infos
    15:27:16.224DEBUGjavascriptsfound Script: BSC
    15:27:16.412DEBUGjavascriptsfound Script: Victron_OldGrid
    15:27:16.578DEBUGjavascriptsfound Script: Werkstatt_Hzg
    15:27:16.713DEBUGjavascriptsfound Script: Gobel_VDIFF
    15:27:16.870DEBUGjavascriptsfound Script: go-E_V4_Halle
    15:27:17.155DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    15:27:17.165DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2026_03_09-15_27_07_backupiobroker.tar.gz
    15:27:17.195DEBUGjavascriptsdone
    15:27:18.092DEBUGcifsCopy iobroker_2026_03_09-15_26_41_backupiobroker.tar.gz...
    15:27:18.115DEBUGcifsdone
    15:27:18.712DEBUGcleandone
    15:27:18.878DEBUGhistoryHTMLnew history html values created
    15:27:18.909DEBUGhistoryHTMLdone
    15:27:19.065DEBUGhistoryJSONdone
    15:27:19.215DEBUGumountdone
    15:27:25.362DEBUGtelegramdone
    15:27:26.581DEBUGnotificationAdmin notification will be sent
    15:27:26.617DEBUGnotificationdone
    15:27:26.771INFOguiDas Backup wurde erfolgreich erstellt!
    er hats für mich nicht korrekt abgelegt, sollte unter Backups/iobroker liegen, aber hat im Docker/iob/backups abgelegt??
    ist das hier falsch?
    O Offline
    O Offline
    oFbEQnpoLKKl6mbY5e13
    @Humidor
    Du hast das so korrekt konfiguriert. Die Backups werden zunächst immer unter /opt/iobroker/backups erstellt, bevor sie zu dem Pfad verschoben werden, den du in Backitup konfiguriert hast.
    Die Frage wäre nun, ob du auf der Konsole deines iobroker-Containers im Symlink /opt/backitup im Ordner /volume3/backup/iobroker landest?
    HumidorH 1 Antwort Letzte Antwort
    • O oFbEQnpoLKKl6mbY5e13
      @Humidor
      HumidorH Offline
      HumidorH Offline
      Humidor
      @oFbEQnpoLKKl6mbY5e13 wie kann ich das testen?
      BG
      O 1 Antwort Letzte Antwort
      • HumidorH Humidor
        O Offline
        O Offline
        @Humidor
        cd /opt/backitup
        ls
        • HumidorH Offline
          HumidorH Offline
          Humidor
          schrieb am zuletzt editiert von Humidor
          hab das gerade gefunden
          und hier:
          BG
          O 2 Antworten Letzte Antwort
          • HumidorH Humidor
            und hier:
            O Offline
            O Offline
            @Humidor
            cifs? da hast du aber noch irgendwo ein Konfig-Problem in Backitup.
            • HumidorH Humidor
              und hier:
              O Offline
              O Offline
              @Humidor
              Sieht doch gut aus, was deine Container-Konfig betrifft!
              • HumidorH Offline
                HumidorH Offline
                Humidor
                jup, der container kann auf das backup verzeichnis zugreifen
                aber es wird dort nicht abgelegt
                BG
                • HumidorH Humidor
                  O Offline
                  O Offline
                  @Humidor
                  Ja, weil er immer noch versucht, per CIFS zu mounten. Siehe deinen ersten Screenshot.
                  • HumidorH Offline
                    HumidorH Offline
                    Humidor
                    Verbindungstyp im Backitup Adapter ist "Lokal kopieren", das CIFS ist dann ein Adapter Problem?
                    BG
                    • HumidorH Humidor
                      O Offline
                      O Offline
                      @Humidor
                      Vielleicht schmeißt du deine Backitup-Instanz einfach mal weg und erstellts sie neu.
                      • HumidorH Offline
                        HumidorH Offline
                        Humidor
                        Adapter neu installiert, keine Änderung, will per CIFS mounten.
                        BG
                        • HumidorH Humidor
                          O Offline
                          O Offline
                          @Humidor
                          Wenn du in der Konsole deines iobroker-Containers unter /opt/backitup den Befehl "touch test.txt" eingibst, wird dann eine Datei erstellt?
                            @Humidor
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            @oFbEQnpoLKKl6mbY5e13 nein, wird nicht angelegt, doch Rechteprobleme?
                            BG
                            • HumidorH Humidor
                              O Offline
                              O Offline
                              @Humidor
                              Kommt denn eine Fehlermeldung, wenn du den Befehl absetzt?
                                @Humidor
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                @oFbEQnpoLKKl6mbY5e13 Nein
                                wenn ich das im Grafana probiere, kommt eine permission denied
                                dh er ekennt hier keine Zugriffsrechtprobleme, dennoch wird es nicht angelegt
                                BG
                                • HumidorH Humidor
                                  O Offline
                                  O Offline
                                  @Humidor
                                  Es kommt keinerlei Rückmeldung auf den Befehl?
                                    @Humidor
                                    HumidorH Offline
                                    HumidorH Offline
                                    Humidor
                                    @oFbEQnpoLKKl6mbY5e13 nein, oder mach ichs im falschen Verzeichnis?
                                    ja, habs überlesen
                                    BG
                                    • HumidorH Humidor
                                      ja, habs überlesen
                                      O Offline
                                      O Offline
                                      @Humidor
                                      Zunächst mit cd /opt/backitup in den richtigen Ordner wechseln.
                                        @Humidor
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        @oFbEQnpoLKKl6mbY5e13 ja, richtig, sorry
                                        Ja - er legt das file an.
                                        BG
                                        O Marc BergM 2 Antworten Letzte Antwort
                                        • HumidorH Humidor
                                          O Offline
                                          O Offline
                                          @Humidor
                                          Das ist gut, denn das bedeutet, dass der Container Schreibrechte auf das gemountete Volume hat.
