  4. [Gelöst] IOB startet nicht mehr nach Proxmox CT restart.
    6.4k
js-controllerstartet nichtproxmox
22 Beiträge 4 Kommentatoren 708 Aufrufe 4 Beobachtet
    @wendy2702 7
    Diese Meldungen sind merkwürdig:
    (Reading database ... 49106 files and directories currently installed.)
    Preparing to unpack .../linux-libc-dev_6.12.69-1_all.deb ...
    Unpacking linux-libc-dev (6.12.69-1) over (6.12.63-1) ...
    Setting up linux-libc-dev (6.12.69-1) ...
    Haste da mal ein Update unterbrochen? Sieht mir nach korrupter dpkg-Datenbank aus.
    sudo apt update
    sudo apt full-upgrade
    sagt?
    wendy2702W Online
    wendy2702W Online
    @Thomas-Braun sagte in IOB startet nicht mehr nach Proxmox CT restart.:
    Nicht das ich wüsste oder mich aktuell erinnern könnte.
    Habe jetzt vor deiner Antwort nochmal versucht den aktuellen JS-Controller per:
    sudo -H -u iobroker npm install iobroker.js-controller
    zu installieren. Und das scheint geklappt zu haben:
    mirko@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
    npm warn skipping integrity check for git dependency ssh://git@github.com/H5N1v2/ioBroker.open-meteo-weather.git
    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm warn deprecated whatwg-encoding@3.1.1: Use @exodus/bytes instead for a more spec-conformant and faster implementation
    npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
    npm warn deprecated
    npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 12 packages, and changed 1678 packages in 8m
    304 packages are looking for funding
      run `npm fund` for details
    iobroker läuft wieder.
    Hier noch die Ausgabe:
    mirko@iobroker:/opt/iobroker$ sudo apt update
    Get:1 http://security.debian.org/debian-security trixie-security InRelease [43.4 kB]
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Fetched 43.4 kB in 1s (39.3 kB/s)
    All packages are up to date.
    mirko@iobroker:/opt/iobroker$ sudo apt full-upgrade
    Summary:
      Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
    • wendy2702W Online
      wendy2702W Online
      Und hier nochmal das komplette IOB Diag:
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.17.4-2-pve
          Architecture: x86-64
      OS is similar to:
      model name	: Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:56:03 up 18 min,  1 user,  load average: 8.98, 7.82, 4.81
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2026-02-17 18:56:03 CET
                 Universal time: Tue 2026-02-17 17:56:03 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mirko
      HOME=/home/mirko
      GROUPS=mirko sudo iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/mirko
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: 	false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session: 		tty
      *** MEMORY ***
      Mem:             17G        5.1G        9.6G        5.5M        2.5G         12G
      Swap:             0B          0B          0B
      Total:           17G        5.1G        9.6G
      Active iob-Instances: 	67
              16384 M total memory
               4846 M used memory
               4814 M active memory
               1953 M inactive memory
               9121 M free memory
                  0 M buffer memory
               2421 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 18:56:04 up 18 min,  1 user,  load average: 8.98, 7.82, 4.81
      Tasks:  97 total,   3 running,  94 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 45.5 us, 34.1 sy,  0.0 ni, 15.9 id,  0.0 wa,  0.0 hi,  4.5 si,  0.0 st
      MiB Mem :  16384.0 total,   9119.9 free,   4847.8 used,   2421.2 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11536.2 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       30G   19G  9.3G  67% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.3G  120K  6.3G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs      16G  5.2M   16G   1% /tmp
      tmpfs                            tmpfs     3.2G  8.0K  3.2G   1% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
      /var:
      1.3G	/var/
      847M	/var/log
      842M	/var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
      257M	/var/lib
      Archived and active journals take up 130.2M in the file system.
      /opt/iobroker/backups:
      2.1G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.5G	/opt/iobroker/iobroker-data/
      975M	/opt/iobroker/iobroker-data/files
      287M	/opt/iobroker/iobroker-data/backup-objects
      187M	/opt/iobroker/iobroker-data/files/vis
      179M	/opt/iobroker/iobroker-data/files/vis/widgets
      45M	/opt/iobroker/iobroker-data/objects.jsonl
      32M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
      27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M	/opt/iobroker/iobroker-data/objects.json.migrated
      26M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v22.22.0
      /usr/bin/node 		v22.22.0
      /usr/bin/npm 		10.9.4
      /usr/bin/npx 		10.9.4
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.0-1nodesource1
        Candidate: 22.22.0-1nodesource1
        Version table:
       *** 22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 611)
      pi-iobroker         pi-iobroker (version: 7.0.7, hostname: pi-iobroker   , alive, uptime: 592)
      Core adapters versions
      js-controller: 	7.0.7
      admin: 		7.7.31
      javascript: 	9.0.11
      nodejs modules from github: 	2
      +-- iobroker.open-meteo-weather@2.4.0 (git+ssh://git@github.com/H5N1v2/ioBroker.open-meteo-weather.git#d59cf2747dcbf37ea8fda1c1680d60c62d56e733)
      +-- iobroker.smartstate@0.0.4 (git+ssh://git@github.com/ChriD/ioBroker.smartstate.git#aa448478fd656fff055532b33decd1138d9222e3)
      Adapter State
        system.adapter.admin.1                  : admin                 : pi-iobroker                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.autodarts.0              : autodarts             : iobroker                                 - disabled, port: 3180
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled
        system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobroker                                 - disabled
      + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      + system.adapter.enocean.0                : enocean               : pi-iobroker                              -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
        system.adapter.history.0                : history               : iobroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.2             : javascript            : iobroker                                 -  enabled
        system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
        system.adapter.matter.0                 : matter                : iobroker                                 - disabled
        system.adapter.mercedesme.0             : mercedesme            : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.6                 : modbus                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
        system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
        system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
        system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.open-meteo-weather.0     : open-meteo-weather    : iobroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
      + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
      + system.adapter.reolink.2                : reolink               : iobroker                                 -  enabled
      + system.adapter.reolink.3                : reolink               : iobroker                                 -  enabled
      + system.adapter.reolink.4                : reolink               : iobroker                                 -  enabled
      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
        system.adapter.sayit.1                  : sayit                 : iobroker                                 - disabled
      + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
      + system.adapter.semp.0                   : semp                  : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.18
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8091, bind: 192.168.178.18, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : pi-iobroker                              -  enabled
        system.adapter.smartstate.0             : smartstate            : iobroker                                 - disabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.178.18, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 192.168.178.18
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
      + system.adapter.web.3                    : web                   : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.yahka.3                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yahka.4                  : yahka                 : iobroker                                 - disabled
      + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'Test'             │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
      Active repo(s): Beta (latest)
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: Beta (latest)
      Adapter    "admin"        : 7.7.31   , installed 7.7.31
      Adapter    "alarm"        : 3.7.6    , installed 3.7.6
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "autodarts"    : 1.0.4    , installed 1.0.4
      Adapter    "backitup"     : 3.3.13   , installed 3.3.13
      Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
      Adapter    "cloudless-homeconnect": 1.6.3, installed 1.6.3
      Adapter    "daswetter"    : 4.5.1    , installed 4.5.1
      Adapter    "devices"      : 1.2.14   , installed 1.2.14
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "feiertage"    : 1.3.0    , installed 1.2.1  [Updatable]
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "harmony"      : 2.0.5    , installed 1.5.0  [Updatable]
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.19.5   , installed 1.19.4 [Updatable]
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "javascript"   : 9.0.18   , installed 9.0.11 [Updatable]
      Controller "js-controller": 7.1.0    , installed 7.0.7  [Updatable]
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "matter"       : 0.5.6    , installed 0.5.6
      Adapter    "mercedesme"   : 0.6.1    , installed 0.4.1  [Updatable]
      Adapter    "modbus"       : 8.0.3    , installed 6.4.0  [Updatable]
      Adapter    "mytime"       : 2.3.2    , installed 2.3.2
      Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
      Adapter    "nut"          : 1.7.0    , installed 1.7.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.3.0    , installed 1.3.0
      Adapter    "sayit"        : 5.1.0    , installed 5.0.0  [Updatable]
      Adapter    "semp"         : 1.5.4    , installed 1.5.4
      Adapter    "shelly"       : 10.6.0   , installed 10.5.2 [Updatable]
      Adapter    "shuttercontrol": 2.0.11  , installed 2.0.11
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "trashschedule": 5.2.1    , installed 5.2.1
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
      Adapter    "vis-2-widgets-collection": 2.3.3, installed 2.3.2 [Updatable]
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-icontwo": 1.26.1, installed 1.26.1
      Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
      Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
      Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
      Adapter    "vis-icontwo"  : 2.9.0    , installed 2.9.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
      Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 8.0.0    , installed 7.0.9  [Updatable]
      Adapter    "ws"           : 4.0.0    , installed 3.0.19 [Updatable]
      Adapter    "yahka"        : 1.1.6    , installed 1.1.6
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects: 	42690
      States: 	37502
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org/debian-security trixie-security InRelease
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:36913         0.0.0.0:*               LISTEN      1000       300210268  4787/io.yahka.3
      tcp        0      0 192.168.178.18:8084     0.0.0.0:*               LISTEN      1000       300213722  5286/io.socketio.0
      tcp        0      0 192.168.178.18:8091     0.0.0.0:*               LISTEN      1000       300212394  5120/io.simple-api.
      tcp        0      0 0.0.0.0:42937           0.0.0.0:*               LISTEN      1000       300203499  4787/io.yahka.3
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       300190756  2895/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       300190761  2895/iobroker.js-co
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          300143016  311/master
      tcp        0      0 127.0.0.1:33405         0.0.0.0:*               LISTEN      1000       300203197  4637/io.yahka.1
      tcp        0      0 127.0.0.1:35333         0.0.0.0:*               LISTEN      1000       300209444  4742/io.yahka.2
      tcp        0      0 192.168.178.18:1882     0.0.0.0:*               LISTEN      1000       300206458  4854/io.shelly.0
      tcp        0      0 127.0.0.1:45237         0.0.0.0:*               LISTEN      1000       300204875  4554/io.yahka.0
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       300204624  4965/io.mqtt.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       300202865  4878/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       300202924  4899/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          300142916  183/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          300141697  1/init
      tcp        0      0 192.168.178.18:8701     0.0.0.0:*               LISTEN      1000       300200998  4111/io.hm-rpc.1
      tcp        0      0 192.168.178.18:42001    0.0.0.0:*               LISTEN      1000       300198570  4039/io.hm-rpc.0
      tcp        0      0 192.168.178.18:42010    0.0.0.0:*               LISTEN      1000       300201170  4155/io.hm-rpc.2
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          300143017  311/master
      tcp6       0      0 :::9765                 :::*                    LISTEN      1000       300219740  5489/io.semp.0
      tcp6       0      0 :::46081                :::*                    LISTEN      1000       300202346  4742/io.yahka.2
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       300196676  3996/io.harmony.0
      tcp6       0      0 :::36429                :::*                    LISTEN      1000       300201426  4554/io.yahka.0
      tcp6       0      0 :::35057                :::*                    LISTEN      1000       300202079  4637/io.yahka.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          300142918  183/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          300141699  1/init
      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       300214543  5333/io.ws.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       300215790  5226/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       300207026  4976/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       300217332  5449/io.web.3
      tcp6       0      0 :::8086                 :::*                    LISTEN      1000       300217303  5434/io.web.2
      tcp6       0      0 :::8085                 :::*                    LISTEN      1000       300217852  5346/io.web.1
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       300196677  3996/io.harmony.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          300141812  102/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          300141698  1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       300219742  5489/io.semp.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300203501  4787/io.yahka.3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300203500  4787/io.yahka.3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300202351  4742/io.yahka.2
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300202350  4742/io.yahka.2
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300202084  4637/io.yahka.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300202083  4637/io.yahka.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300201431  4554/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       300201430  4554/io.yahka.0
      udp6       0      0 :::111                  :::*                                0          300141700  1/init
      2026-02-17 18:56:00.029  - info: javascript.0 (4075) script.js.common.Ansagen.DWD_UWZ_NINA: info: Add UWZ/DWD/ZAMG warning to database. id: 0_userdata.0.wetterwarnung_test.data.dwd.105334000.warning1.object headline: Amtliche WARNUNG vor LEICHTEM SCHNEEFALL
      2026-02-17 18:56:00.030  - info: javascript.0 (4075) script.js.common.Ansagen.DWD_UWZ_NINA: info: DWD Warnung gefunden oder entfernt.RID: 7604.003643617576
      2026-02-17 18:56:00.231  - info: javascript.0 (4075) script.js.common.Ansagen.DWD_UWZ_NINA: info: Add UWZ/DWD/ZAMG warning to database. id: 0_userdata.0.wetterwarnung_test.data.dwd.105334000.warning2.object headline: Amtliche WARNUNG vor FROST
      2026-02-17 18:56:00.232  - info: javascript.0 (4075) script.js.common.Ansagen.DWD_UWZ_NINA: info: DWD Warnung gefunden oder entfernt.RID: 7604.003643617576
      2026-02-17 18:56:03.149  - info: linux-control.0 (5265) successful received data from VIS-Kueche-PI (192.168.178.217:22)
      2026-02-17 18:56:03.362  - info: linux-control.0 (5265) successful received data from VIS-OG (192.168.178.215:22)
      2026-02-17 18:56:03.623  - info: shuttercontrol.0 (4833) Living down #18 Set ID: Rollladen Bad EG.LEVEL value: 0%
      2026-02-17 18:56:22.213  - info: sayit.0 (5101) saying: Wetterwarnung vor Glatteis, für die Region StädteRegion Aachen, Stufe grün, ab heute nachmittag ,  Es gibt 2 weitere neue Warnungen.
      2026-02-17 18:56:31.240  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
      2026-02-17 18:56:31.430  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Regen_Woche" has to be type "number" but received type "string"
      2026-02-17 18:56:31.478  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
      2026-02-17 18:56:31.569  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Regen_Event" has to be type "number" but received type "string"
      2026-02-17 18:56:33.661  - info: shuttercontrol.0 (4833) Living down #18 Set ID: Rollladen HWR.LEVEL value: 0%
      2026-02-17 18:56:34.234  - info: javascript.0 (4075) script.js.common.Tablet_Steuerung.Display_ON_Flur_OG: VIS OG ON
      2026-02-17 18:56:34.413  - info: linux-control.0 (5265) state linux-control.0.VIS-OG.VIS_OG_ScreenOn changed: true (ack = false)
      2026-02-17 18:56:41.710  - info: sayit.0 (5101) saying: Wetterwarnung vor Schnee, für die Region StädteRegion Aachen, Stufe grün, ab heute nachmittag ,  Eine weitere neue Warnung.
      2026-02-17 18:56:43.440  - info: javascript.0 (4075) script.js.common.Tablet_Steuerung.Display_EG_DIM_ON_OFF: VIS EG Bright
      2026-02-17 18:56:43.533  - info: linux-control.0 (5265) state linux-control.0.VIS-EG-PI.VIS_EG_ScreenBright changed: true (ack = false)
      2026-02-17 18:56:49.585  - info: sayit.0 (5101) saying: Wetterwarnung vor Frost, für die Region StädteRegion Aachen, Stufe grün, ab heute nachmittag ,  Insgesamt 3 aktive Warnungen.
      2026-02-17 18:56:53.789  - info: javascript.0 (4075) script.js.common.Tablet_Steuerung.Display_ON_Küche: VIS OG ON
      2026-02-17 18:56:53.797  - info: linux-control.0 (5265) state linux-control.0.VIS-Kueche-PI.VIS_Kueche_ScreenOn changed: true (ack = false)
      2026-02-17 18:57:01.555  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Regen_Woche" has to be type "number" but received type "string"
      2026-02-17 18:57:01.607  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
      2026-02-17 18:57:01.681  - info: simple-api.0 (5120) State value to set for "0_userdata.0.Wetterstation.Regen_Event" has to be type "number" but received type "string"
      2026-02-17 18:57:03.729  - info: shuttercontrol.0 (4833) Living down #17 Set ID: Rollladen Kueche.LEVEL value: 0%
      • wendy2702W wendy2702
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        mirko
        HOME=/home/mirko
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session: 		tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                 4846 M used memory
                 9121 M free memory
                    0 M buffer memory
                 2421 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        1.3G	/var/
        847M	/var/log
        257M	/var/lib
        USB-Devices by-id:
        /usr/bin/npm 		10.9.4
        /usr/bin/npx 		10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.7.31
        javascript: 	9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	42690
        States: 	37502
        @wendy2702 sagte in IOB startet nicht mehr nach Proxmox CT restart.:
        CPU threads: 4
        Den strapaziertst du aber ganz schön.
        Swap: 0B 0B 0B
        Swap würde ich einrichten.
          CPU threads: 4
          Swap: 0B 0B 0B
          wendy2702W Online
          wendy2702W Online
          Ups... schon länger nicht mehr drauf geschaut. Muss ich mal gucken was die beansprucht.
          Wieviel SWAP würdest du machen?
            eigentlich wollte ich nur mal eben den Proxmox Rechner an eine neue USV hängen und habe erstmal testen wollen ob alles danach sauber startet. Also dachte ich mir stoppe/starte mal jeden CT/VM und schaue ob alles wieder sauber läuft.
            Schon beim ersten "Iobroker" geht nichts mehr.
            JS Controller File kann nicht mehr gefunden werden. Unterschied zum letzten neustart der zwecks CT Backup jeden ersten im Monat erfolgt sind die Updates einiger Adapter und Installation des Open-Meteo-Wetter Adapters von GIT. Ich bin mir aber fast sicher das ich zwischendurch auch mal neu gestartet habe aber egal.
            Fakt: in iob diag kommt das:
            ioBroker Status
            node:internal/modules/cjs/loader:1386
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                at Function._load (node:internal/modules/cjs/loader:1192:37)
                at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                at node:internal/main/run_main_module:36:49 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v22.22.0
            Hosts:
              throw err;
              requireStack: []
            Node.js v22.22.0
              throw err;
              requireStack: []
            Node.js v22.22.0
            js-controller:
              throw err;
              requireStack: []
            Node.js v22.22.0
            admin:
              throw err;
              requireStack: []
            Node.js v22.22.0
            javascript:
            +-- iobroker.open-meteo-weather@ (git+ssh://git@github.com/H5N1v2/ioBroker.open-meteo-weather.git#d59cf2747dcbf37ea8fda1c1680d60c62d56e733)
            +-- iobroker.smartstate@ (git+ssh://git@github.com/ChriD/ioBroker.smartstate.git#aa448478fd656fff055532b33decd1138d9222e3)
            Adapter State
              throw err;
              requireStack: []
            Node.js v22.22.0
              throw err;
              requireStack: []
            Node.js v22.22.0
            Objects and States
            Objects: 	0
            States: 	0
            Ein iob FIX löst das Problem an der Stelle auch nicht und dann dachte ich mir nutze die Gelegenheit und installiere direkt den JS-Controller in Version 7.1.0 was aber leider auch fehlschlägt:
            Hier mal die letzten Zeilen des vollständigen NPM Installations logs:
            4490 info run @serialport/bindings-cpp@13.0.0 install { code: 0, signal: null }
            4491 info run iobroker.vis@1.5.6 install { code: 6, signal: null }
            4492 verbose stack Error: command failed
            4492 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
            4492 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
            4492 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
            4492 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:79:13)
            4492 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
            4492 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
            4492 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
            4492 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:79:13
            4492 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
            4493 verbose pkgid iobroker.vis@1.5.6
            4494 error code 6
            4495 error path /opt/iobroker/node_modules/iobroker.vis
            4496 error command failed
            4497 error command sh -c node main.js --install
            4498 silly unfinished npm timer reify 1771347277111
            4499 silly unfinished npm timer reify:build 1771347352994
            4500 silly unfinished npm timer build 1771347352999
            4501 silly unfinished npm timer build:deps 1771347353000
            4502 silly unfinished npm timer build:run:install 1771347353512
            4503 silly unfinished npm timer build:run:install:node_modules/iobroker.vis 1771347378100
            4504 verbose cwd /opt/iobroker
            4505 verbose os Linux 6.17.4-2-pve
            4506 verbose node v22.22.0
            4507 verbose npm  v10.9.4
            4508 verbose exit 6
            4509 verbose code 6
            Sieht für mich nach einem Problem mit VIS1.5.6 aud was bisher allerdings immer Fehlerfrei lief. Dann ein Versuch mit JS-Controller 7.0.7, die Version die vorher eigentlich Problemlos lief:
            Aber leider endet das genauso nicht erfolgreich:
            2760 info run @serialport/bindings-cpp@13.0.0 install { code: 0, signal: null }
            2761 info run iobroker.vis@1.5.6 install { code: 6, signal: null }
            2762 verbose stack Error: command failed
            2762 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
            2762 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
            2762 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
            2762 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:79:13)
            2762 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
            2762 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
            2762 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
            2762 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:79:13
            2762 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
            2763 verbose pkgid iobroker.vis@1.5.6
            2764 error code 6
            2765 error path /opt/iobroker/node_modules/iobroker.vis
            2766 error command failed
            2767 error command sh -c node main.js --install
            2768 silly unfinished npm timer reify 1771347567031
            2769 silly unfinished npm timer reify:build 1771347664543
            2770 silly unfinished npm timer build 1771347664550
            2771 silly unfinished npm timer build:deps 1771347664551
            2772 silly unfinished npm timer build:run:install 1771347665381
            2773 silly unfinished npm timer build:run:install:node_modules/iobroker.vis 1771347684206
            2774 verbose cwd /opt/iobroker
            2775 verbose os Linux 6.17.4-2-pve
            2776 verbose node v22.22.0
            2777 verbose npm  v10.9.4
            2778 verbose exit 6
            2779 verbose code 6
            2780 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-02-17T16_59_26_613Z-debug-0.log
            iob diag:
            Script v.2026-01-31
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             18:16:54 up 35 min,  1 user,  load average: 0.59, 0.65, 1.07
            CPU threads: 4
                           Local time: Tue 2026-02-17 18:16:54 CET
                       Universal time: Tue 2026-02-17 17:16:54 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            mirko
            HOME=/home/mirko
            js-controller is not running
            Display-Manager:
            Desktop:
            Session: 		tty
            *** MEMORY ***
            Mem:             17G         45M         15G        3.0M        1.4G         17G
            Swap:             0B          0B          0B
            Total:           17G         45M         15G
            Active iob-Instances: 	0
                       43 M used memory
                      167 M active memory
                     1043 M inactive memory
                    15004 M free memory
                        0 M buffer memory
                     1338 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 18:16:55 up 35 min,  1 user,  load average: 0.70, 0.68, 1.08
            Tasks:  31 total,   1 running,  30 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  2.5 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  16384.0 total,  15003.4 free,     44.7 used,   1338.8 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.  16339.3 avail Mem
            *** FILESYSTEM ***
            /dev/mapper/pve-vm--101--disk--0 ext4       30G   18G   11G  62% /
            tmpfs                            tmpfs     6.3G  116K  6.3G   1% /run
            tmpfs                            tmpfs      16G  2.8M   16G   1% /tmp
            /var:
            1.3G	/var/
            847M	/var/log
            257M	/var/lib
            1.4G	/opt/iobroker/iobroker-data/
            965M	/opt/iobroker/iobroker-data/files
            171M	/opt/iobroker/iobroker-data/files/vis
            163M	/opt/iobroker/iobroker-data/files/vis/widgets
            41M	/opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/npm 		10.9.4
            /usr/bin/npx 		10.9.4
            nodejs:
              Version table:
                 20.20.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.19.6-1nodesource1 1001
                 20.19.5-1nodesource1 1001
                 20.19.4-1nodesource1 1001
                 20.19.3-1nodesource1 1001
                 20.19.2+dfsg-1 500
                 20.19.2-1nodesource1 1001
                 20.19.1-1nodesource1 1001
                 20.19.0-1nodesource1 1001
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
            ioBroker Status
              throw err;
              requireStack: []
            Node.js v22.22.0
            Hosts:
              throw err;
              requireStack: []
            Node.js v22.22.0
              throw err;
              requireStack: []
            Node.js v22.22.0
            js-controller:
              throw err;
              requireStack: []
            Node.js v22.22.0
            admin:
              throw err;
              requireStack: []
            Node.js v22.22.0
            javascript:
            Adapter State
              throw err;
              requireStack: []
            Node.js v22.22.0
              throw err;
              requireStack: []
            Node.js v22.22.0
            Objects and States
            Objects: 	0
            States: 	0
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_20.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-19T15:27:46Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: Failed to fetch https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-19T15:27:46Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            Hit:2 http://deb.debian.org/debian trixie-updates InRelease
            Hit:3 http://security.debian.org/debian-security trixie-security InRelease
            Err:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Err:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Pending systemupdates: 1
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          299894813  311/master
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          299890686  183/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          299889371  1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          299894814  311/master
            tcp6       0      0 :::22                   :::*                    LISTEN      0          299890688  183/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          299889373  1/init
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          299889594  102/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          299889372  1/init
            udp6       0      0 :::111                  :::*                                0          299889374  1/init
            2026-02-17 18:02:37.187  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:02:37.189  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:02:42.190  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:02:42.191  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:02:47.195  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:02:47.195  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:02:52.197  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:02:52.198  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:02:57.204  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:02:57.205  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:03:02.205  - error: vis.0 (5875) States database error: connect ECONNREFUSED 0.0.0.0:9000
            2026-02-17 18:03:02.208  - error: vis.0 (5875) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
            2026-02-17 18:03:02.210  - info: vis.0 (5875) config.js changed. Upload.
            2026-02-17 18:03:02.211  - error: vis.0 (5875) Cannot write file js/config.js: DB closed
            2026-02-17 18:03:02.211  - error: vis.0 (5875) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-02-17 18:03:02.212  - error: vis.0 (5875) unhandled promise rejection: DB closed
            2026-02-17 18:03:02.213  - error: vis.0 (5875) Error: DB closed
                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2353:37)
                at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2394:29)
                at process.processImmediate (node:internal/timers:487:21)
            2026-02-17 18:03:02.213  - error: vis.0 (5875) DB closed
            2026-02-17 18:03:02.715  - info: vis.0 (5875) terminating
            2026-02-17 18:03:02.715  - warn: vis.0 (5875) Terminated (UNCAUGHT_EXCEPTION): Without reason
            Wo liegt jetzt der Hund begraben?
            EDIT: Was muss ich machen um den Text hier besser lesbar zu bekommen:
            Ist das ein Skin Thema?
            @wendy2702 sagte in [Gelöst] IOB startet nicht mehr nach Proxmox CT restart.:
            war aber vorhin nicht.
            oder lief da iob nicht?
            zeig mal top
            • wendy2702W Online
              wendy2702W Online
              Jetzt sieht es schon ruhiger aus:
              top - 19:22:44 up 10 min,  1 user,  load average: 3.61, 6.33, 5.60
              keine Ahnung was da eben noch lief.
                Kommt drauf an...
                Mein RPI4 hat 512MB z. B.
                  siehst du in der darunter angezeigten Tabelle!
                  Das ist immer noch Grenzwertig
                    wendy2702W Online
                    wendy2702W Online
                    @Homoran sagte in IOB startet nicht mehr nach Proxmox CT restart.:
                    Hm,
                    wenn ich mir die Auslastung in Proxmox anschaue dümpelt der CT so bei 20% rum.
                    Komplette PVE bei 40%
                    Top vom CT:
                    top - 19:32:49 up 21 min,  1 user,  load average: 1.98, 3.01, 4.20
                    Tasks:  88 total,   1 running,  87 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 24.9 us,  7.5 sy,  0.0 ni, 65.0 id,  0.0 wa,  0.0 hi,  2.6 si,  0.0 st
                    MiB Mem :  16384.0 total,  11087.7 free,   4649.9 used,    651.5 buff/cache
                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11734.1 avail Mem
                        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                        174 iobroker  20   0   11.5g 593728  54032 S  47.8   3.5  10:52.54 iobroker.js-con
                        677 iobroker  20   0   11.1g 123776  49616 S   8.6   0.7   1:00.77 io.hue.0
                       1234 iobroker  20   0   11.3g 165284  57764 S   6.0   1.0   1:38.47 io.web.0
                        395 iobroker  20   0   21.5g 324324  57348 S   5.3   1.9   4:45.51 io.javascript.0
                        488 iobroker  20   0   11.1g 122972  49456 S   3.3   0.7   0:56.36 io.influxdb.0
                        984 iobroker  20   0   11.0g 117688  54812 S   3.3   0.7   0:17.47 io.shelly.0
                        436 iobroker  20   0   11.3g 276212  55508 S   3.0   1.6   4:25.73 io.javascript.2
                        410 iobroker  20   0   11.3g 303512  49824 S   2.7   1.8   4:27.82 io.javascript.1
                       1402 iobroker  20   0   11.2g  94168  49464 S   1.3   0.6   0:11.78 io.energiefluss
                       1574 iobroker  20   0   11.0g 108512  50612 S   1.3   0.6   0:11.56 io.reolink.2
                        327 iobroker  20   0   21.5g 313772  57060 S   1.0   1.9   0:48.11 io.admin.0
                        799 iobroker  20   0   11.0g  92920  49776 S   1.0   0.6   0:13.62 io.modbus.3
                       1016 iobroker  20   0   11.0g 100512  49428 S   1.0   0.6   0:08.37 io.sonoff.0
                       1507 iobroker  20   0   11.0g 103436  50812 S   1.0   0.6   0:11.64 io.reolink.0
                        850 iobroker  20   0   11.1g 107008  50280 S   0.7   0.6   0:07.01 io.yahka.1
                       1476 iobroker  20   0   11.2g 121176  57724 S   0.7   0.7   0:09.61 io.web.3
                       1604 iobroker  20   0   11.0g 106624  50696 S   0.7   0.6   0:11.67 io.reolink.3
                        588 iobroker  20   0   11.0g  91088  49620 S   0.3   0.5   0:04.65 io.harmony.0
                        756 iobroker  20   0   11.0g  96104  49816 S   0.3   0.6   0:04.93 io.modbus.0
                        775 iobroker  20   0   11.0g  90516  49772 S   0.3   0.5   0:04.53 io.modbus.2
                        835 iobroker  20   0   11.1g 100476  50192 S   0.3   0.6   0:06.75 io.yahka.0
                        883 iobroker  20   0   11.1g  99692  50256 S   0.3   0.6   0:06.70 io.yahka.2
                        906 iobroker  20   0   11.1g 102456  50256 S   0.3   0.6   0:06.42 io.yahka.3
                        925 iobroker  20   0   11.0g  92476  49736 S   0.3   0.6   0:10.39 io.modbus.5
                        950 iobroker  20   0   11.0g  94268  49824 S   0.3   0.6   0:06.42 io.modbus.1
                        969 iobroker  20   0   11.0g 100860  54644 S   0.3   0.6   0:03.14 io.shuttercontr
                    HomoranH 1 2 Antworten Letzte Antwort
                      Hm,
                      Top vom CT:
                      ist das wieder so eine BlechSpezialität?
                      gilt das auch im container für den gesamten Rechner?
                      größer 4 blockiert die CPU
                      • wendy2702W Online
                        wendy2702W Online
                        Das ist ein Proxmox System mit LXC für iobroker.
                        Gibt es hier im Forum doch häufiger.
                          aber nicht bei mir. Kenne daher die Feinheiten nicht. mit Proxmox hatte ich immer nur VMs.
                          Wenn die load average zwischen 2 und >4 liegt ist das definitiv kein dümpeln
                          • wendy2702W Online
                            wendy2702W Online
                            Da muss ich mich nochmal detailiert mit auseinander setzen was TOP im CT wirklich anzeigt und was im Vergleich die Prozessor Auslastung dann bedeutet.
                              Hm,
                              Top vom CT:
                              1 Offline
                              1 Offline
                              150d
                              schrieb am zuletzt editiert von 150d
                              (delete)
