  4. Tradfri startet nicht
    5.9k
4 Beiträge 2 Kommentatoren 443 Aufrufe
  • N Offline
    N Offline
    nickel73
    hab die Instanz 1.1.1 hinzugefügt und alle Daten wie IP/Host und Security Code eingefügt darauf kommt diese fehler Meldung im Log und die Instanz Startet nicht.
    host.iobroker-pi	2018-02-14 20:30:04.298	info	Restart adapter system.adapter.tradfri.0 because enabled
    host.iobroker-pi	2018-02-14 20:30:04.298	error	instance system.adapter.tradfri.0 terminated with code 1 ()
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at startListening (dgram.js:121:10)
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at Socket.emit (events.js:185:7)
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at emitNone (events.js:86:13)
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at Socket.udp_onListening (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/dtls.js:111:37)
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at new ClientHandshakeHandler (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:125:14)
    host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at ClientHandshakeHandler.renegotiate (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:176:14)
    host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at ClientHandshakeHandler.sendFlight (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:342:14)
    host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at ClientHandshakeHandler.sendFlight_finish (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:326:26)
    host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at RecordLayer.sendFlight (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/RecordLayer.js:69:24)
    host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at Socket.send (dgram.js:339:11)
    host.iobroker-pi	2018-02-14 20:30:04.295	error	Caught by controller[0]: RangeError: Port should be > 0 and < 65536
    Da ich ein blutiger Anfänger bin brauche ich Hilfe, komme da einfach nicht weiter.
    Mein System läuft auf einem Raspberry Pi 3.
    geändert: Code in Code-Tags; Homoran (Mod)
      Code bitte in Code-Tags setzen!
      Habe das für dich einmal gemacht ;-)
      • Was hast du denn in der Konfiguration eingegeben?
      • welche Versionen hast du bei:
        • admin
        • js-controller
        • nodejs
        • npm
      • N Offline
        N Offline
        nickel73
        danke das du meinen Beitrag geändert hast. :oops:
        In die Konfiguration habe ich die IP und den Host des Ikea Gateway eingetragen, im Feld Security-Code den Code auf der Rückseite des Gateway.
        admin 2.0.9
        js-controller 1.2.3
        nodejs v6.12.3
        npm 3.10.10
        Gruß Nickel
        • N Offline
          N Offline
          nickel73
          hab "bash ./reinstall.sh" ausgeführt dadurch habe ich jetzt Admin 3.2.0 auf dem Raspi. Alles andere läuft immer noch super nur der Tradfri Adapter nicht.
          Bekomme immer noch den selben Fehler.
          In Node Red Funktioniert Tradfri tadellos.
          Kennt jemand eine Lösung.
          Gruß Nickel
