<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tradfri startet nicht]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">hab die Instanz 1.1.1 hinzugefügt und alle Daten wie IP/Host und Security Code eingefügt darauf kommt diese fehler Meldung im Log und die Instanz Startet nicht.</p>
<pre><code>host.iobroker-pi	2018-02-14 20:30:04.298	info	Restart adapter system.adapter.tradfri.0 because enabled
host.iobroker-pi	2018-02-14 20:30:04.298	error	instance system.adapter.tradfri.0 terminated with code 1 ()
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at startListening (dgram.js:121:10)
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at Socket.emit (events.js:185:7)
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at emitNone (events.js:86:13)
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at Socket.udp_onListening (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/dtls.js:111:37)
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at new ClientHandshakeHandler (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:125:14)
host.iobroker-pi	2018-02-14 20:30:04.297	error	Caught by controller[0]: at ClientHandshakeHandler.renegotiate (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:176:14)
host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at ClientHandshakeHandler.sendFlight (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:342:14)
host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at ClientHandshakeHandler.sendFlight_finish (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/HandshakeHandler.js:326:26)
host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at RecordLayer.sendFlight (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/build/DTLS/RecordLayer.js:69:24)
host.iobroker-pi	2018-02-14 20:30:04.296	error	Caught by controller[0]: at Socket.send (dgram.js:339:11)
host.iobroker-pi	2018-02-14 20:30:04.295	error	Caught by controller[0]: RangeError: Port should be &gt; 0 and &lt; 65536
</code></pre>
<p dir="auto">Da ich ein blutiger Anfänger bin brauche ich Hilfe, komme da einfach nicht weiter.</p>
<p dir="auto">Mein System läuft auf einem Raspberry Pi 3.</p>
<p dir="auto"><strong><strong>geändert: Code in Code-Tags; Homoran (Mod)</strong></strong></p>
]]></description><link>https://forum.iobroker.net/topic/10879/tradfri-startet-nicht</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 05:08:02 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/10879.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Feb 2018 19:31:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tradfri startet nicht on Sat, 17 Feb 2018 09:57:56 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">hab "bash ./reinstall.sh" ausgeführt dadurch habe ich jetzt Admin 3.2.0 auf dem Raspi. Alles andere läuft immer noch super nur der Tradfri Adapter nicht.</p>
<p dir="auto">Bekomme immer noch den selben Fehler.</p>
<p dir="auto">In Node Red Funktioniert Tradfri tadellos.</p>
<p dir="auto">Kennt jemand eine Lösung.</p>
<p dir="auto">Gruß Nickel</p>
]]></description><link>https://forum.iobroker.net/post/132503</link><guid isPermaLink="true">https://forum.iobroker.net/post/132503</guid><dc:creator><![CDATA[nickel73]]></dc:creator><pubDate>Sat, 17 Feb 2018 09:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to Tradfri startet nicht on Wed, 14 Feb 2018 20:27:40 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">danke das du meinen Beitrag geändert hast. :oops:</p>
<p dir="auto">In die Konfiguration habe ich die IP und den Host des Ikea Gateway eingetragen, im Feld Security-Code den Code auf der Rückseite des Gateway.</p>
<p dir="auto">admin 2.0.9</p>
<p dir="auto">js-controller 1.2.3</p>
<p dir="auto">nodejs v6.12.3</p>
<p dir="auto">npm 3.10.10</p>
]]></description><link>https://forum.iobroker.net/post/131954</link><guid isPermaLink="true">https://forum.iobroker.net/post/131954</guid><dc:creator><![CDATA[nickel73]]></dc:creator><pubDate>Wed, 14 Feb 2018 20:27:40 GMT</pubDate></item><item><title><![CDATA[Reply to Tradfri startet nicht on Wed, 14 Feb 2018 19:40:00 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">Code bitte in Code-Tags setzen!</p>
<p dir="auto">Habe das für dich einmal gemacht ;-)</p>
<ul>
<li>
<p dir="auto">Was hast du denn in der Konfiguration eingegeben?</p>
</li>
<li>
<p dir="auto">welche Versionen hast du bei:</p>
</li>
<li>
<ul>
<li>admin</li>
</ul>
</li>
<li>
<ul>
<li>js-controller</li>
</ul>
</li>
<li>
<ul>
<li>nodejs</li>
</ul>
</li>
<li>
<ul>
<li>npm</li>
</ul>
</li>
</ul>
<p dir="auto">Gruß</p>
<p dir="auto">Rainer</p>
]]></description><link>https://forum.iobroker.net/post/131930</link><guid isPermaLink="true">https://forum.iobroker.net/post/131930</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Wed, 14 Feb 2018 19:40:00 GMT</pubDate></item></channel></rss>
