  4. admin nach restore nicht erreichbar
    6.4k
19 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
Dieses Thema wurde aufgespalten von ioBroker nach Restore nicht erreichbar Homoran
  • E ece87
    Danke so hat es geklappt hab es in eine *txt Datei gespeichert.
    iob diag.txt
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     16:43:28 up 1 min,  1 user,  load average: 0.66, 0.26, 0.09
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-01-15 16:43:28 CET
               Universal time: Thu 2026-01-15 15:43:28 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspberryio
    HOME=/home/raspberryio
    GROUPS=raspberryio adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/raspberryio
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        321M        3.4G        9.7M        285M        3.7G
    Swap:           2.1G          0B        2.1G
    Total:          6.1G        321M        5.6G
    Active iob-Instances:   2
             3796 M total memory
              306 M used memory
              279 M active memory
              107 M inactive memory
             3289 M free memory
               40 M buffer memory
              231 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 16:43:29 up 1 min,  1 user,  load average: 0.66, 0.26, 0.09
    Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.0 us,  0.0 sy,  0.0 ni, 94.0 id,  2.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.7 total,   3287.6 free,    307.6 used,    272.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   3489.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  751M   2% /run
    /dev/mmcblk0p2 ext4       58G  5.5G   51G  10% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.9G     0  1.9G   0% /tmp
    /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
    [Thu Jan 15 16:42:05 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:04:54:66 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a8836640-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Thu Jan 15 16:42:09 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Thu Jan 15 16:42:09 2026] EXT4-fs (mmcblk0p2): mounted filesystem a76206bf-fc14-4209-834e-7fc7275f6735 ro with ordered data mode. Quota mode: none.
    [Thu Jan 15 16:42:12 2026] EXT4-fs (mmcblk0p2): re-mounted a76206bf-fc14-4209-834e-7fc7275f6735 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    187M    /var/cache
    182M    /var/cache/apt
    122M    /var/lib
    97M     /var/cache/apt/archives
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    268M    /opt/iobroker/iobroker-data/
    257M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.2
    /usr/bin/node           v20.19.2
    /usr/bin/npm            9.2.0
    /usr/bin/npx            9.2.0
    /usr/bin/corepack       0.24.0
    nodejs:
      Installed: 20.19.2+dfsg-1+rpi1
      Candidate: 20.19.2+dfsg-1+rpi1
      Version table:
     *** 20.19.2+dfsg-1+rpi1 500
            500 http://raspbian.raspberrypi.com/raspbian trixie/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v20.19.2) is vulnerable to the following CVEs:
    CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
    This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
    Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
    CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
    CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
    CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
    server.on('secureConnection', socket => {
    socket.on('error', err => {
    console.log(err)
    CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
    CVE-2026-21637(medium): A flaw in Node.js TLS error handling allows remote attackers to crash or exhaust resources of a TLS server when `pskCallback` or `ALPNCallback` are in use. Synchronous exceptions thrown during these callbacks bypass standard TLS error handling paths (tlsClientError and error), causing either immediate process termination or silent file descriptor leaks that eventually lead to denial of service. Because these callbacks process attacker-controlled input during the TLS handshake, a remote client can repeatedly trigger the issue. This vulnerability affects TLS servers using PSK or ALPN callbacks across Node.js versions where these callbacks throw without being safely wrapped.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 82)
    Core adapters versions
    js-controller:  7.0.7
    admin:          6.3.5
    javascript:     6.1.4
    nodejs modules from github:     1
    +-- iobroker.tuya@3.14.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#43f4c1b9bd2f1693f2a1160bc5423b0611c0a143)
    Adapter State
      system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
      system.adapter.cloud.0                  : cloud                 : Raspberry                                - disabled
      system.adapter.discovery.0              : discovery             : Raspberry                                - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Raspberry                                - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : Raspberry                                - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Raspberry                                - disabled
      system.adapter.iqontrol.0               : iqontrol              : Raspberry                                - disabled
      system.adapter.javascript.0             : javascript            : Raspberry                                - disabled
      system.adapter.shelly.0                 : shelly                : Raspberry                                - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : Raspberry                                - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonnen.0                 : sonnen                : Raspberry                                - disabled
      system.adapter.tuya.0                   : tuya                  : Raspberry                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspberry                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : Raspberry                                - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : Raspberry                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : Raspberry                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Raspberry                                - disabled
      system.adapter.vis.0                    : vis                   : Raspberry                                - disabled
      system.adapter.web.0                    : web                   : Raspberry                                - disabled, port: 8082, bind: 192.168.178.55, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.22   , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 3.3.13   , installed 2.5.10 [Updatable]
    Adapter    "cloud"        : 5.1.2    , installed 4.3.0  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "iqontrol"     : 3.0.0    , installed 2.0.0  [Updatable]
    Adapter    "javascript"   : 9.0.18   , installed 6.1.4  [Updatable]
    Controller "js-controller": 7.1.0    , installed 7.0.7  [Updatable]
    Adapter    "shelly"       : 10.5.2   , installed 6.4.1  [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 2.8.0  [Updatable]
    Adapter    "socketio"     : 7.0.8    , installed 4.2.0  [Updatable]
    Adapter    "sonnen"       : 1.18.1   , installed 1.15.6 [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.14.0 [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.3.0  [Updatable]
    Adapter    "vis-icontwo"  : 1.18.0   , installed 0.90.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.1  [Updatable]
    Adapter    "web"          : 7.0.9    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 3.0.19   , installed 1.3.0  [Updatable]
    Objects and States
    Objects:        1037
    States:         747
    Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:2 http://raspbian.raspberrypi.com/raspbian trixie InRelease
    Reading package lists...
    Pending Updates: 27
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8534       1122/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          150        1/init
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9483       1133/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9488       1133/iobroker.js-co
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      104        9390       1110/redis-server 1
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8536       1122/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1569       1/init
    tcp6       0      0 ::1:6379                :::*                    LISTEN      104        9391       1110/redis-server 1
    udp        0      0 0.0.0.0:59166           0.0.0.0:*                           101        6574       614/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5031       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6572       614/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          151        1/init
    udp6       0      0 :::57932                :::*                                101        6575       614/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                101        6573       614/avahi-daemon: r
    2026-01-15 16:42:16.505  - info: host.Raspberry added notifications configuration of host
    2026-01-15 16:42:17.382  - info: host.Raspberry 20 instances found
    2026-01-15 16:42:17.430  - info: host.Raspberry starting 2 instances
    2026-01-15 16:42:18.342  - info: host.Raspberry instance system.adapter.admin.0 in version "6.3.5" started with pid 1175
    2026-01-15 16:42:22.526  - info: host.Raspberry instance system.adapter.backitup.0 in version "2.5.10" started with pid 1187
    2026-01-15 16:42:23.515  - info: admin.0 (1175) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.2, js-controller: 7.0.7
    2026-01-15 16:42:23.594  - info: admin.0 (1175) requesting all states
    2026-01-15 16:42:23.596  - info: admin.0 (1175) requesting all objects
    2026-01-15 16:42:25.512  - info: admin.0 (1175) received all objects
    2026-01-15 16:42:25.816  - error: admin.0 (1175) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2026-01-15 16:42:25.823  - info: admin.0 (1175) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-01-15 16:42:26.735  - info: admin.0 (1175) Request actual repository...
    2026-01-15 16:42:26.781  - info: admin.0 (1175) Repository received successfully.
    2026-01-15 16:42:27.111  - warn: admin.0 (1175) redis get admin.0.info.newsFeed, error - Connection is closed.
    2026-01-15 16:42:27.145  - warn: admin.0 (1175) get state error: Connection is closed.
    2026-01-15 16:42:27.147  - warn: admin.0 (1175) get state error: Connection is closed.
    2026-01-15 16:42:27.149  - warn: admin.0 (1175) get state error: Connection is closed.
    2026-01-15 16:42:27.151  - warn: admin.0 (1175) get state error: Connection is closed.
    2026-01-15 16:42:27.153  - warn: admin.0 (1175) get state error: Connection is closed.
    2026-01-15 16:42:27.159  - error: admin.0 (1175) Cannot update news: Error: DB closed
    2026-01-15 16:42:27.172  - info: admin.0 (1175) terminating http server on port 8081
    2026-01-15 16:42:27.262  - info: host.Raspberry instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2026-01-15 16:42:27.264  - info: host.Raspberry Do not restart adapter system.adapter.admin.0 because desired by instance
    2026-01-15 16:42:27.947  - info: backitup.0 (1187) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 7.0.7
    2026-01-15 16:42:28.066  - info: backitup.0 (1187) [iobroker] backup was activated at 02:40 every 1 day(s)
    @ece87 sagte in admin nach restore nicht erreichbar:
    bitte als text in code-tags posten!
    fremde Dateien macht nicht jeder auf.
    • E Offline
      ece87
      64Bit habe ich auch schon versucht,
      ich vermute auch das es daran liegen könnte das ich nie Updates aufgespielt habe..
      das System ist ca 3-4 Jahre gelaufen.
      Backitup war die Version 2.5.10 ca mittlerweile gibt es 3.13
      wäre es möglich mit einer alten Version von Backitup und Iobroker, da noch evtl was zu machen?
      Danke schonmal
      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
      • E ece87
        Danke schonmal
        Dann verwende es auch...
        Natürlich... Die Kiste ist ganz klassisch so lange nicht 'getatscht' worden, bis sie eben nicht mehr 'runnt'...
        • H HJRoe
          ich hatte ein ähnliches Problem. Ich musste IOB von Hand neu starten, da das alte Binding übernommen wurde!!
          Vielleicht hilft dieser Befehl im Terminal:
          iob list instances --allow-root
          Ja, man sollte nicht als root...
          Danach hat der Neustart funktioniert
          HJR
          @HJRoe sagte in admin nach restore nicht erreichbar:
          ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH!
          • E ece87
            Danke schonmal
            das wird bei den Ketnkomponenten wahrscheinlich nicht anders aussehen
            • E ece87
              Danke schonmal
              @ece87
              iob stop
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Dann:
              iob nodejs-update
              iob stop
              iob update
              iob upgrade self
              iob update
              iob upgrade all -y
              iob start
              Dann sind dann hoffentlich keine Updates mehr ausstehend.
              ioBroker ans Laufen bringen, davon dann ein Backup ziehen, Betriebssystem in der 64Bit-Lite-Version installieren, dort den ioBroker installieren, Backup einspielen, fertig.
              Künftig die Kiste nicht mehr so versumpfen lassen.
              E 1 Antwort Letzte Antwort
                @ece87
                iob stop
                sudo apt update
                sudo reboot
                Dann:
                iob nodejs-update
                iob stop
                iob update
                iob upgrade self
                iob update
                iob upgrade all -y
                iob start
                ece87
                schrieb am zuletzt editiert von ece87
                @Thomas-Braun sagte in admin nach restore nicht erreichbar:
                @ece87
                iob stop
                sudo apt update
                sudo reboot
                Dann:
                iob nodejs-update
                iob stop
                iob update
                iob upgrade self
                iob update
                iob upgrade all -y
                iob start
                Vielen Dank so hat es funktioniert
                echt klasse was ihr für ein wissen habt.
                Gruß Erich
                • E ece87
                  @ece87
                  iob stop
                  sudo apt update
                  sudo reboot
                  Dann:
                  iob nodejs-update
                  iob stop
                  iob update
                  iob upgrade self
                  iob update
                  iob upgrade all -y
                  iob start
                  Gruß Erich
                  @ece87
                  Wie sieht das System denn nun nach der Aktion aus?
                  Gib nochmal den Output von
                  iob diag
                  bekannt.
                  • E Offline
                    ece87
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    Operating System: Debian GNU/Linux 13 (trixie)
                           Icon name: computer
                              Kernel: Linux 6.12.62+rpt-rpi-v8
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     08:44:59 up  8:56,  1 user,  load average: 0.21, 0.22, 0.13
                    CPU threads: 4
                    Current issues:
                                   Local time: Fri 2026-01-16 08:44:59 CET
                               Universal time: Fri 2026-01-16 07:44:59 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    raspberryio
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            4.0G        1.9G        1.5G         10M        645M        2.1G
                    Swap:           2.1G          0B        2.1G
                    Total:          6.1G        1.9G        3.6G
                    Active iob-Instances:   15
                             3796 M total memory
                             1841 M used memory
                             1869 M active memory
                              327 M inactive memory
                             1432 M free memory
                               93 M buffer memory
                              521 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    top - 08:44:59 up  8:56,  1 user,  load average: 0.21, 0.22, 0.13
                    Tasks: 196 total,   2 running, 194 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  8.3 us,  0.0 sy,  0.0 ni, 91.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3796.7 total,   1430.2 free,   1843.3 used,    615.7 buff/cache
                    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1953.4 avail Mem
                    *** FILESYSTEM ***
                    /dev/mmcblk0p2 ext4       59G  6.6G   50G  12% /
                    tmpfs          tmpfs     1.9G  412K  1.9G   1% /tmp
                    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                    [Thu Jan 15 23:48:05 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:04:54:66 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=04962a62-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                    [Thu Jan 15 23:48:10 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                    [Thu Jan 15 23:48:10 2026] EXT4-fs (mmcblk0p2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                    [Thu Jan 15 23:48:12 2026] EXT4-fs (mmcblk0p2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                    /var:
                    2.5G    /var/
                    277M    /var/cache
                    271M    /var/cache/apt
                    181M    /var/lib
                    145M    /var/lib/apt
                    48M     /opt/iobroker/backups/
                    258M    /opt/iobroker/iobroker-data/
                    193M    /opt/iobroker/iobroker-data/files
                    48M     /opt/iobroker/iobroker-data/objects.jsonl
                    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                    4.0M    /opt/iobroker/iobroker-data/backup-objects/2026-01-16_07-48_objects.jsonl.gz
                    4.0M    /opt/iobroker/iobroker-data/backup-objects/2026-01-16_05-48_objects.jsonl.gz
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/nodejs         v22.22.0
                    /usr/bin/node           v22.22.0
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    /usr/bin/corepack       0.34.0
                    nodejs:
                      Installed: 22.22.0-1nodesource1
                      Candidate: 22.22.0-1nodesource1
                      Version table:
                     *** 22.22.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                         22.21.0-1nodesource1 1001
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         20.19.2+dfsg-1 500
                            500 http://deb.debian.org/debian trixie/main arm64 Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Raspberry           Raspberry (version: 7.1.0, hostname: Raspberry     , alive, uptime: 32213)
                    js-controller:  7.1.0
                    admin:          7.7.22
                    javascript:     9.0.11
                    nodejs modules from github:     0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.ble.0                    : ble                   : Raspberry                                -  enabled
                    + system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
                    + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
                    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                    + system.adapter.ping.0                   : ping                  : Raspberry                                -  enabled
                    + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shelly.1                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.sonnen.0                 : sonnen                : Raspberry                                -  enabled
                    + system.adapter.tuya.0                   : tuya                  : Raspberry                                -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : Raspberry                                -  enabled
                      system.adapter.vis.0                    : vis                   : Raspberry                                -  enabled
                    + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: ::, run as: admin
                      system.adapter.web.1                    : web                   : Raspberry                                - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    Active repo(s): stable
                    Used repository: stable
                    Adapter    "admin"        : 7.7.22   , installed 7.7.22
                    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
                    Adapter    "ble"          : 0.14.0   , installed 0.14.0
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                    Controller "js-controller": 7.0.7    , installed 7.1.0
                    Adapter    "ping"         : 1.7.9    , installed 1.7.9
                    Adapter    "shelly"       : 10.4.1   , installed 10.5.2
                    Adapter    "sonnen"       : 1.18.1   , installed 1.18.1
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Objects and States
                    Objects:        1236
                    States:         896
                    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                    Hit:1 http://deb.debian.org/debian trixie InRelease
                    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10483      1416/io.shelly.1
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4452       1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5992       1134/sshd: /usr/sbi
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7719       1119/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7726       1119/iobroker.js-co
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8714       1592/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8464       1291/io.admin.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          157        1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          5994       1134/sshd: /usr/sbi
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5610       625/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       10456      1372/io.shelly.0
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1680       1/init
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8125       1479/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8126       1479/io.tuya.0
                    udp        0      0 0.0.0.0:37443           0.0.0.0:*                           101        5612       625/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                101        5611       625/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          1681       1/init
                    udp6       0      0 fe80::e65f:1ff:fe04:546 :::*                                0          7705       668/NetworkManager
                    udp6       0      0 :::54139                :::*                                101        5613       625/avahi-daemon: r
                    2026-01-16 08:45:56.116  - warn: sonnen.0 (1439) [LATEST] Error receiving latest data: Request failed with status code 401
                    2026-01-16 08:45:56.586  - info: shelly.1 (1416) [authEnabled] 192.168.178.62 (shellyplus1pm / shellyplus1pm-cc7b5c83befc / shellyplus1pm#cc7b5c83befc#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:45:56.709  - warn: shelly.1 (1416) [Mqtt.statusNotifications] 192.168.178.62 (shellyplus1pm / shellyplus1pm-cc7b5c83befc / shellyplus1pm#cc7b5c83befc#1): "General Status Notifications" are disabled (see adapter documentation for details)
                    2026-01-16 08:46:02.205  - info: shelly.1 (1416) [authEnabled] 192.168.178.63 (shellyplusplugs / shellyplusplugs-b0b21c1227b4 / shellyplusplugs#b0b21c1227b4#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:02.327  - warn: shelly.1 (1416) [Mqtt.statusNotifications] 192.168.178.63 (shellyplusplugs / shellyplusplugs-b0b21c1227b4 / shellyplusplugs#b0b21c1227b4#1): "General Status Notifications" are disabled (see adapter documentation for details)
                    2026-01-16 08:46:02.422  - info: shelly.0 (1372) [authEnabled] 192.168.178.26 (shelly1pm / shelly1pm-349454784642 / SHSW-PM#349454784642#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:02.508  - info: shelly.0 (1372) [authEnabled] 192.168.178.40 (shelly1 / shelly1-3494546ABBD9 / SHSW-1#3494546ABBD9#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:03.273  - warn: sonnen.0 (1439) [ADDITIONAL] Error on requesting additional endpoints: Could not request powermeter endpoint: Request failed with status code 404
                    2026-01-16 08:46:03.298  - warn: sonnen.0 (1439) [SETTINGS] Error receiving configuration: Request failed with status code 404
                    2026-01-16 08:46:03.324  - warn: sonnen.0 (1439) [LATEST] Error receiving latest data: Request failed with status code 401
                    2026-01-16 08:46:04.617  - info: shelly.0 (1372) [authEnabled] 192.168.178.34 (shellyplug-s / shellyplug-s-80646F82318A / SHPLG-S#80646F82318A#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:06.925  - info: shelly.1 (1416) [authEnabled] 192.168.178.39 (shellyplusplugs / shellyplusplugs-b0b21c130b34 / shellyplusplugs#b0b21c130b34#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:10.525  - warn: sonnen.0 (1439) [ADDITIONAL] Error on requesting additional endpoints: Could not request powermeter endpoint: Request failed with status code 404
                    2026-01-16 08:46:10.545  - warn: sonnen.0 (1439) [SETTINGS] Error receiving configuration: Request failed with status code 404
                    2026-01-16 08:46:10.562  - warn: sonnen.0 (1439) [LATEST] Error receiving latest data: Request failed with status code 401
                    2026-01-16 08:46:11.876  - info: shelly.1 (1416) [authEnabled] 192.168.178.62 (shellyplus1pm / shellyplus1pm-cc7b5c83befc / shellyplus1pm#cc7b5c83befc#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:11.959  - warn: shelly.1 (1416) [Mqtt.statusNotifications] 192.168.178.62 (shellyplus1pm / shellyplus1pm-cc7b5c83befc / shellyplus1pm#cc7b5c83befc#1): "General Status Notifications" are disabled (see adapter documentation for details)
                    2026-01-16 08:46:17.697  - info: shelly.0 (1372) [authEnabled] 192.168.178.26 (shelly1pm / shelly1pm-349454784642 / SHSW-PM#349454784642#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:17.783  - warn: sonnen.0 (1439) [ADDITIONAL] Error on requesting additional endpoints: Could not request powermeter endpoint: Request failed with status code 404
                    2026-01-16 08:46:17.792  - info: shelly.0 (1372) [authEnabled] 192.168.178.40 (shelly1 / shelly1-3494546ABBD9 / SHSW-1#3494546ABBD9#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:17.823  - warn: sonnen.0 (1439) [SETTINGS] Error receiving configuration: Request failed with status code 404
                    2026-01-16 08:46:17.846  - warn: sonnen.0 (1439) [LATEST] Error receiving latest data: Request failed with status code 401
                    2026-01-16 08:46:18.507  - info: shelly.1 (1416) [authEnabled] 192.168.178.63 (shellyplusplugs / shellyplusplugs-b0b21c1227b4 / shellyplusplugs#b0b21c1227b4#1): This device is not protected via restricted login (see adapter documentation for details)
                    2026-01-16 08:46:18.582  - warn: shelly.1 (1416) [Mqtt.statusNotifications] 192.168.178.63 (shellyplusplugs / shellyplusplugs-b0b21c1227b4 / shellyplusplugs#b0b21c1227b4#1): "General Status Notifications" are disabled (see adapter documentation for details)
                    2026-01-16 08:46:19.733  - info: shelly.0 (1372) [authEnabled] 192.168.178.34 (shellyplug-s / shellyplug-s-80646F82318A / SHPLG-S#80646F82318A#1): This device is not protected via restricted login (see adapter documentation for details)
                    • E ece87
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      raspberryio
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           2.1G          0B        2.1G
                               3796 M total memory
                               1841 M used memory
                               1432 M free memory
                                 93 M buffer memory
                                521 M swap cache
                               2047 M total swap
                                  0 M used swap
                               2047 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.5G    /var/
                      277M    /var/cache
                      271M    /var/cache/apt
                      181M    /var/lib
                      145M    /var/lib/apt
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.22
                      javascript:     9.0.11
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        1236
                      States:         896
                      Pending Updates: 0
                      @ece87
                      Ja, sieht gut aus.
                      Dann halte die Kiste jetzt regelmäßiger auf Stand.
                      • E Offline
                        ece87
                        alles klar Danke
