  4. History: Migration von File zu MySQL mit Daten-Mitnahme möglich?
    5.9k
38 Beiträge 5 Kommentatoren 5.8k Aufrufe
    Dax
    ja soweit ich mich erinnern kann schon. soll ich mal neu installieren?
    • apollon77A Offline
      Mach mal :-)
        Dax
        So, hab den adapter jetzt neu installiert. Selber fehler cannot find module pg-negative.
        Hier der Install-Log:
        $ ./iobroker add sql
        npm install iobroker.sql --production --prefix "/opt/iobroker" (System call)
        npm
         WARN deprecated node-uuid@1.4.8: Use uuid module instead
        npm
         WARN deprecated sprintf@0.1.5: The sprintf package is deprecated in favor of sprintf-js.
        node-pre-gyp
         ERR!
         Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.13 and node@4.8.7 (node-v46 ABI) (falling back to source compile with node-gyp)
        ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
             int status = uv_queue_work(uv_default_loop(),
        ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
        In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
        ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
             int status = uv_queue_work(uv_default_loop(),                              \
        ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(Bind);
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(Get);
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(Run);
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(All);
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(Each);
        ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
             STATEMENT_BEGIN(Reset);
        host.raspberrypi install adapter sql
        got /opt/iobroker/node_modules/iobroker.sql/admin
        upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
        upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
        upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
        upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
        upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
        upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
        host.raspberrypi object system.adapter.sql created
        host.raspberrypi object _design/custom created
        host.raspberrypi create instance sql
        host.raspberrypi object sql.0.info.connection created
        host.raspberrypi object sql.0.info created
        host.raspberrypi object system.adapter.sql.0.outputCount created
        host.raspberrypi object system.adapter.sql.0.inputCount created
        host.raspberrypi object system.adapter.sql.0.uptime created
        host.raspberrypi object system.adapter.sql.0.memRss created
        host.raspberrypi object system.adapter.sql.0.memHeapTotal created
        host.raspberrypi object system.adapter.sql.0.memHeapUsed created
        host.raspberrypi object system.adapter.sql.0.connected created
        host.raspberrypi object system.adapter.sql.0.alive created
        host.raspberrypi object system.adapter.sql.0 created
        process exited with code 0
          node -v
          npm -v
            Dax
            node v4.8.7
            npm v2.15.11
              Bei mir auch. interessant.
              Erstmal. Wenn ich deinen befehl von oben kopiere sind bei den "zwei Minuszeichen" eines irgendwie komisch. Tipp es am besten mal ab. Dann tut es auch bei mir. Irgendwie sind da wohl komische Zeichen rein gekommen!! vllt sind auch die leerzeichen komisch
                Dax
                Aja super, jetzt hat er gestartet. zwar auch mit der fehlermeldung aber danach lief sql an. Und jetzt läuft der Converter grad durch :)
                  Na dann warten wir mal was der nächste Crash sagt (falls einer kommt)
                    Dax
                    Hmm zu früh gefreut. Erst kamen jede Menge fehler
                    { [Error: connect ETIMEDOUT]
                      errorno: 'ETIMEDOUT',
                      code: 'ETIMEDOUT',
                      syscall: 'connect',
                      fatal: true }
                    und jetzt
                    { [Error: Connection lost: The server closed the connection.] fatal: true, code: 'PROTOCOL_CONNECTION_LOST' }
                    Reconnection to DB.
                    Reconnection to DB.
                    root@raspberrypi:/opt/iobroker#
                      Bitte schick mal komplett. Nicht nur auszüge
                      • frankjokeF Offline
                        frankjokeF Offline
                        frankjoke
                        Hallo, bin sch 3x umgezogen!
                        Zuerst von XS1 (FS20 protokoll auf SD-Karte) auf den History-Adapter -> auf MySQL -> PostgreSQL wo ich nun seit 1 Jahr bin, nur vom Raspi auf opi2e und dann noch auf einen CSL-NUK umgezogen.
                        Postgres braucht weniger ressourcen und ist meiner Meinung scheller. AUf dem Raspi war das ein Problem da dort der Speicher sehr langsam ist (egal ob SD oder USB), und außerdem .
                        Es gibt ein nettes admin-tool für PostgreSQL, pgAdmin (https://www.pgadmin.org/download/) mit dem ich auf die verschiedenen DB's an den Test-Rechnern oder am Echtzeitsystem zugreifen kann.
                        Momentan hab ich ca 2,2 Millionen Datenpunkte im ts_numbers (und noch mal 200k in ts_bool und ts_string), Daten die teilweise bis 5 Jahre zurückreichen.
                        Wichtig, hab mir ein kleines script geschrieben (hatte das auch auf MySQL) welches ein Backup von ioBroker und ein Backup (dump) der SQL erzeugt und speichere das wöchentlich auf das NAS.
                        Bei MySQL war das
                        sudo mysqldump -uroot -ppi --all-databases ...
                        Jetzt bei PostgreSQL
                        sudo -u postgres pg_dump iobroker | gzip > /mnt/nas/.../postgres.backup.$(date '+%Y%m%d').sql.gz
                        iobroker wird mit
                        BFILE=`sudo iobroker backup | cut -d " " -f 3`
                        cp -v $BFILE /mnt/nas/.../
                        ins gleiche Verzeichnis gespeichert.
                        Das SQL Backup ist bei mir mit gzip momentan 18MB, iobroker ~1MB.
                        Diese Methode hat mir schon mal das Leben (die Daten) gerettet da mir am Raspi eine SD und später auch ein USB-Stick abgeschmiert ist. Das war der Grund warum ich dann auf opi2e und später auf den NUK (alles unter Linux) umgestiegen bin da diese MMC's als Speicher haben.
                        Frank,
                        NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                        Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                          Dax
                            code: 'ETIMEDOUT',
                            syscall: 'connect',
                            fatal: true }
                            code: 'ETIMEDOUT',
                            syscall: 'connect',
                            fatal: true }
                            code: 'ETIMEDOUT',
                            syscall: 'connect',
                            fatal: true }
                            code: 'ETIMEDOUT',
                            syscall: 'connect',
                            fatal: true }
                          Datatype hm-rega.0.3650: Currently: number, StorageType: Number
                          INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(1, 1518537565661, 0, 1, 1, 0);
                          new value received for hm-rega.0.3650, new-value=0.3, ts=1518537581242, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0, new-value=0.3, ts=1518537581242
                          new value received for hm-rega.0.3650, new-value=0.4, ts=1518537585291, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.3, new-value=0.4, ts=1518537585291
                          new value received for hm-rega.0.2477, new-value=0.2, ts=1518537587246, relog=false
                          Min-Delta reached hm-rega.0.2477, last-value=0, new-value=0.2, ts=1518537587246
                          new value received for hm-rega.0.3650, new-value=0.5, ts=1518537587261, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.4, new-value=0.5, ts=1518537587261
                          new value received for hm-rega.0.16972, new-value=27.3, ts=1518537587261, relog=false
                          Min-Delta reached hm-rega.0.16972, last-value=27.2, new-value=27.3, ts=1518537587261
                          new value received for hm-rega.0.3650, new-value=0.7, ts=1518537591260, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.5, new-value=0.7, ts=1518537591260
                          new value received for hm-rega.0.3650, new-value=0.6, ts=1518537593263, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.7, new-value=0.6, ts=1518537593263
                          new value received for hm-rega.0.3650, new-value=0.5, ts=1518537595256, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.6, new-value=0.5, ts=1518537595256
                          new value received for hm-rega.0.3650, new-value=0.6, ts=1518537599251, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.5, new-value=0.6, ts=1518537599251
                          new value received for hm-rega.0.3650, new-value=0.7, ts=1518537601267, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.6, new-value=0.7, ts=1518537601267
                          new value received for hm-rega.0.3650, new-value=0.6, ts=1518537607279, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.7, new-value=0.6, ts=1518537607279
                          new value received for hm-rpc.0.MEQ0690418.1.FILLING_LEVEL, new-value=100, ts=1518537607722, relog=false
                          value not changed hm-rpc.0.MEQ0690418.1.FILLING_LEVEL, last-value=100, new-value=100, ts=1518537607722
                          new value received for hm-rega.0.3650, new-value=0.5, ts=1518537609267, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.6, new-value=0.5, ts=1518537609267
                          new value received for hm-rega.0.3650, new-value=0.6, ts=1518537611280, relog=false
                          Min-Delta reached hm-rega.0.3650, last-value=0.5, new-value=0.6, ts=1518537611280
                          Datatype hm-rega.0.2477: Currently: number, StorageType: Number
                          INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(2, 1518537587246, 0.2, 1, 1, 0);
                          Datatype hm-rega.0.16972: Currently: number, StorageType: Number
                          INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(4, 1518537587261, 27.3, 1, 1, 0);
                          INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(1, 1518537611280, 0.6, 1, 1, 0);
                          Reconnection to DB.
                          Reconnection to DB.
                            Also mein Tipp ist das die Mysql die Verbindung geschlossen hat. Schau mal ob das MySQL Log irgendwas hergibt. Ansonsten nutze mal die Parameter um die Geschwindigkeit etwas zu verlangsamen von dem Skript
