  4. Fehler VIS-2 Widget Inventwo
    5.8k
77 Beiträge 11 Kommentatoren 9.1k Aufrufe 11 Beobachtet
  • jkvarelJ jkvarel
    @longbow bitte mit v0.3.6 versuchen und die Ausgaben schicken. Dort sollte beistehen, woher der Fehler kommt
    Filo
    schrieb am zuletzt editiert von Filo
    @jkvarel
    Habe mit der 0.3.6 folgende Fehlermeldungen erhalten (mit Universal Widget, Schieberegler und Schalter auf der Seite), ich hoffe das kommt nichtzu spät:
    [error] [2025-10-11T15:21:57.865Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [error] Socket Error: UNKNOWN @ @http://192.168.2.8:8082/vis-2/assets/index-CMnY6NW2.js:57091:201
    [log] [2025-10-11T15:21:57.866Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:57.866Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:57.866Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:57.866Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:57.949Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:57.949Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:57.949Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:57.949Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:57.950Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.066Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.067Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.067Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.067Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.067Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.101Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.101Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.101Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.101Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.101Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.212Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.212Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.212Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.212Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.213Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.317Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.317Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.317Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.317Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.317Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.427Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.427Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.428Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.428Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.428Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.481Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.481Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.481Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.481Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.482Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.527Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.527Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.527Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.527Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.528Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.606Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.606Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.606Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.606Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.607Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.677Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.677Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.678Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.678Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.678Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.721Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.721Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.721Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.722Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.722Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.782Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.782Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.783Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.783Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.783Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.899Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.899Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.899Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.899Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.899Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.964Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
    [log] [2025-10-11T15:21:58.965Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.965Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.965Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.965Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
    [error] [2025-10-11T15:21:58.972Z] ws connection error: CLOSED_NO_STATUS @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    [log] [2025-10-11T15:21:58.972Z] Start reconnect 1 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [log] [2025-10-11T15:21:58.972Z] Reconnect is already running 1 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
    [error] [2025-10-11T15:21:58.972Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
    Vielleicht diese noch, die steht ganz am Anfang:
    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: ReferenceError: Cannot access uninitialized variable. @ @http://192.168.2.8:8082/vis-2/assets/visView-9RsJe6Ux.js:3314:22
    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: {} @ @http://192.168.2.8:8082/vis-2/assets/visView-9RsJe6Ux.js:3314:107
    Gruß Filo
    • jkvarelJ jkvarel
      Filo
      @jkvarel
      so, ich hab nochmals alles durchprobiert: Adapter neu installiert, mit allen möglichen socket Enstellungen rumprobiert, IObroker neu aufgespielt (Docker übrigens), aber nichts hat geholfen. Das Problem besteht nur im Apple Umfeld (Iphone und Ipad)., komisch, das sonst niemand diese Probleme hat ausser uns.
      Probleme bei Apple Umgebung:
      Universal Widget: wird manchmal angezeigt
      Schieberegler: Wird nie angezeigt
      Schalter: Wird nie angezeigt
      andere Widgets benutze ich nicht.
      Fehler tritt nur im Apple Universum auf, (Browser oder Vis App), bei Windows Geräten habe ich ich keine Probleme, alles funktioniert einwandfrei, Android Geräte habe ich keine. Versionen bis 0.2.2 laufen auch einwandfrei.
      Gibt es jemand, bei dem die Widgets unter Apple laufen, dann müsste es ja an meinem System liegen. Meine Vis2 ist auf inventwo Widgets aufgebaut und es wäre gar nicht einfach , das Ganze mit anderen Mitteln umzusetzen und wenn, dann doch sehr umständlich..
      Filo
      skvarelS E 2 Antworten Letzte Antwort
      • F Filo
        @jkvarel
        Filo
        skvarelS Offline
        skvarelS Offline
        skvarel
        @filo .. ich sage meinem Sohn Bescheid. Er war in letzter Zeit nicht sehr oft im Forum.
        #TeamInventwo
        Unsere Adapter:
        • F Filo
          @jkvarel
          Filo
          eLichte
          @filo
          Hi, wollte mich mal hier einklinken.
          Ich habe das gleiche Problem nur auf Apple Ipad und Iphone im Safari Browser und auch in der IO-Broker Visu App
          Vis 2 Inventwo Widgets 0.3.9
          Vis 2 2.13.6
          Ich benutze nur das Universal Widget. Meist geht es beim ersten Aufruf und dann nicht mehr.
          F 1 Antwort Letzte Antwort
          • E eLichte
            @filo
            Vis 2 2.13.6
            Filo
            in diesem Beitrag gibt es auch ein Problem von Vis2 im Zusammenhang mit Apple devices. (https://forum.iobroker.net/topic/82774/admin-kann-unter-apple-26-1-nicht-geöffnet-werden/28) Es wird vorgeschlagen, die Seite nicht per IP sondern über Namensauflösung im DNS aufzurufen. Allerdings hat das wohl nichts mit dem Problem hier zu tun. Ich habe die gleichen Probleme (wie andere auch), selbst wenn ich die Seite über DNS Namen aufrufe.. Gibt es noch irgend eine Idee dazu?
            Filo
            • jkvarelJ jkvarel
              Filo
              @jkvarel Hallo,
              Vesion 0.4.0 arbeitet jetzt sowohl unter Windows als auch unter IOS (26.2 und 26.2) einwandfrei. Vielen Dank für den Aufwand, den Du hattest.
              Fruß
              Filo
              Pedder007P 1 Antwort Letzte Antwort
              • Pedder007P Offline
                Pedder007P Offline
                Pedder007
                schrieb am zuletzt editiert von Pedder007
                Hallo zusammen, ich stolpere gerade über diesen Thread und hänge mich direkt mal dran.
                Ich habe den Fehler auch und eben leider auch mal und mal nicht. Das Ganze unabhängig davon ob ich per WLAN direkt oder VPN (via RUTX Router mit SIM-Karte ins Wohnmobil) zugreife.
                Meine VIS2 läuft auf einem relativ neu aufgesetzten Raspi4 im Wohnmobil (mein erster Anlauf in Sachen VIS2 bevor es an die deutlich größere heimische Umgebung geht). Der Zugriff erfolgt bei Anwesenheit im WoMo normal via iOS und Safari, wo das Problem dann leider sehr sehr häufig auftritt.
                Auf dem Mac (von Zuhause) habe ich zusätzlich noch den Chrome und ich glaube, da tritt das Problem tatsächlich nicht auf - so aus dem Gedächtnis....
                Auch tritt das Problem nicht auf, wenn ich per VPN/XRDP von außen zugreife und dann lokal (auf dem Raspi) über den Chromium Browser arbeite.
                (Da ist die Zugriffsperformance per AldiTalk-SIM-Karte) einfach besser)
                Ich hab's gerade nochmal per iOS/Safari/VPN nachvollziehen können:
                Erster Aufruf "unbekanntes Widget", zweiter Aufruf (1 Min später), alles einwandfrei.
                Dann vom Mac/Chrome/VPN gerade direkt nochmal hinterher, und auch alles gut.
                Cache's hatte ich auf den iOS Devices auch alle schonmal gelöscht, ohne Erfolg.
                Vis2 läuft auf Vers. 2.13.4
                Vis2 inventwo Widgets auf Vers. 0.3.9
                Vis2 inventwo Iconset auf Vers. 1.20.0
                Betroffen ist bei mir immer das Widget "Universal (Schalter, Taster, Nav&mehr)"
                Ich hatte schon angefangen an mir zu zweifeln ;-) und sogar schon die SD-Karte im Wohnmobil getauscht, weil ich vor Ur-Zeiten mal einen ähnlichen Effekt bei der VIS1 mit einer sterbenden Karte hatte.
                Pedder
                All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                Under construction: Smart-WoMo auf Raspi4
                • F Filo
                  @jkvarel Hallo,
                  Fruß
                  Filo
                  Pedder007P Offline
                  Pedder007P Offline
                  Pedder007
                  @Filo kann ich für den Moment bestätigen :-)
                  Nach Update auf 0.4.0 scheint der Fehler weg zu sein.
                  Danke @skvarel + Sohn!
                  Pedder
                  • N Offline
                    N Offline
                    noidea
                    Hallo Zusammen,
                    da ich aktuell mit der Version 0.3.9 das selbe Problem habe, würde ich auch gerne die Version 0.4.0 installieren. Da ich aber noch recht Unsicher in der Handhabung beim Installieren von GitHub bin, bräucht ich bitte mal Eure Hilfe.
                    Ich muss den Experten Modus einschalten und dann das hier auswählen?:
                    Im GitHub gibt es aber aktuell schon die Version 0.5.1. Kann ich auch definiert nur die Version 0.4.0 auswählen, oder wird darüber automatisch die letzte aktuelle Version installiert?
                    Vielen Dank und schöne Grüße
                    skvarelS 1 Antwort Letzte Antwort
                    • N noidea
                      Hallo Zusammen,
                      skvarelS Offline
                      skvarelS Offline
                      skvarel
                      schrieb am zuletzt editiert von skvarel
                      @noidea .. bitte NICHT über GITHUB installieren!
                      Mittlerweile sind wir auch schon bei der v0.5.1 und die ist ganz normal über den Admin (latest) installierbar.
                      Alternativ über NPM, aber NIEMALS über GITHUB!
                      EDIT:
                      #TeamInventwo
                      Unsere Adapter:
                      N skvarelS 2 Antworten Letzte Antwort
                      • skvarelS skvarel
                        EDIT:
                        N Offline
                        N Offline
                        noidea
                        @skvarel Vielen Dnak für das schnelle Feedback.
                        Ich wusste das es Sinn macht, hier estmal nach zu fragen. Sorry für die blöde Frage, aber wie geht es denn über den Admin?
                        Ich sehe das nur bis zum stable:
                        • skvarelS skvarel
                          EDIT:
                          skvarelS Offline
                          skvarelS Offline
                          skvarel
                          sagte in Fehler VIS-2 Widget Inventwo:
                          Was passiert denn, wenn du diesen Weg nutzt? Wird dir unser Adapter angezeigt? Dann musst du deinen ioBroker nicht auf Beta umstellen
                          #TeamInventwo
                          Unsere Adapter:
                          N 1 Antwort Letzte Antwort
                          • skvarelS skvarel
                            N Offline
                            N Offline
                            noidea
                            @skvarel Ja das sieht bei mir auch so aus. Ich habe das jetzt darüber mal installiert:
                            Jetzt scheint auch bei mir, wie bei den anderen auch, das IOS Problem behoben zu sein. Vielen Dank für Deine/Eure Arbeit und Mühe und für deine Hilfe :-)
                            • N noidea
                              skvarelS Offline
                              skvarelS Offline
                              skvarel
                              @noidea sagte in Fehler VIS-2 Widget Inventwo:
                              Genauso sieht es aus wenn man im Stable unterwegs ist, aber einen Adapter aus dem Latest installiert hat 😊
                              Alles richtig gemacht 👍
                              #TeamInventwo
                              Unsere Adapter:
                              • N Offline
                                N Offline
                                noidea
                                Noch mal Danke für deine Hilfe 🥳
                                • skvarelS Offline
                                  skvarelS Offline
                                  skvarel
                                  Sehr gerne 😊
                                  #TeamInventwo
                                  Unsere Adapter:
                                    topsurfer
                                    schrieb am zuletzt editiert von topsurfer
                                    #66
                                    Mist, jetzt habe ich diesen Fehler auch.
                                    Aber auf jedem Browser, Chrome, Firefox und auch auf dem Handy im FullyBrowser:
                                    Aber nicht auf jeder Seite im Dashboard, die hier geht z.B.:
                                    Das ist installiert:
                                    (mit Vis-2 inventwo Widget 0.8.0 (via npm) das gleiche, hatte ich zuvor installiert und jetzt wieder de-installiert)
                                    Update:
                                    Was mir gerade auffällt, dass das installierte "Vis 2 inventwo Widgets" gar nicht im vis-2 Editor links bei den installierten Widgets angeboten wird. Nur das (nicht mehr) installierte "vis-inventwo".
                                    Oder missdeute ich da was ?
                                    • T topsurfer
                                      Update:
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #67
                                      @topsurfer
                                      Schau mal bitte in die Browser Konsole mit F12
                                      Da müsste der ein oder andere Fehler auftauchen.
                                      Wenn du schon mehrfach versucht hast, neu zu installieren oder Upload all zu machen, liegt es wahrscheinlich am Widget selber.
                                      Ich kenne das von meinen vis2 Widgets.
                                      Das darin verwendete, so genannte Federation ist etwas empfindlich. Fehler, die dir in der Entwicklungsumgebung nicht auffallen, nimmt das Übel und führt zu diesem Effekt.
                                      Leider liefert react und Federation nicht immer die deutlichen Fehlermeldungen.
                                      Wenn es das ist, kann das nur der Autor reparieren.
                                      Meine Adapter und Widgets
                                      Links im Profil
                                        topsurfer
                                        #68
                                        Habe jetzt (nochmal) die0.8.0 per npm installiert, diese sehe ich jetzt auch in der Widget-Auswahlliste; die Fehler sind weg, puhhh!
                                        (was ich aber auch in der Widget-Auswahlliste sehe ist das Widget von der vis1 (inventwo Design Widgets), das aber laut der Ansicht über die installierten Adapter aber gar nicht mehr installiert ist. Das ist aber ein andere Thema, muss immer nur dran denken davon kein Widget zu nuetzen. Falls da jemand nee Idee hat ... gehört aber hier nicht rein)
                                        • T topsurfer
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #69
                                          @skvarel
                                          man kann vis1 widgets in vis2 ausblenden, wenn sie nicht kompatibel sind.
                                          so habe ich das bei rssfeed gemacht, so das sie mit dem separaten vis2 adapter nicht in die quere kommen
                                          https://github.com/oweitman/ioBroker.rssfeed/blob/64aebdf2bdbfa5ff5483759808e28a8816b2e0ec/io-package.json#L197
                                          vscode zeigt einem zwar einen schemafehler an, da der folgende issue noch nicht umgesetzt wurde. funktioniert aber trotzdem
                                          https://github.com/issues/created?issue=ioBroker|ioBroker.js-controller|3104
                                          Links im Profil
