  4. IOBroker nicht mehr erreichbar und pivCCU sehr träge
    6.4k
7 Beiträge 3 Kommentatoren 363 Aufrufe 2 Beobachtet
  • W Offline
    W Offline
    wibear
    Hallo Forum,
    plötzlich sind IOBroker und HABPanel auf einem Raspi 4 B 4GB mit einer SSD nicht mehr erreichbar:
    Alles ist aktuell.
    iob diag sagt alles wäre OK.
    Mehrere Restarts haben nichts gebracht.
    Was wäre zu überprüfen?
    Danke.
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:53:12 up 14 min,  3 users,  load average: 1.11, 1.23, 1.09
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-12-29 14:53:13 CET
               Universal time: Mon 2025-12-29 13:53:13 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspi
    HOME=/home/raspi
    GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.7G        129M        126K        1.2G        1.3G
    Swap:           536M        262M        274M
    Total:          4.5G        2.9G        404M
    Active iob-Instances:   28
             3795 M total memory
             2548 M used memory
             1778 M active memory
             1714 M inactive memory
              123 M free memory
               35 M buffer memory
             1156 M swap cache
              511 M total swap
              250 M used swap
              261 M free swap
    top - 14:53:13 up 14 min,  3 users,  load average: 1.11, 1.23, 1.09
    Tasks: 245 total,   1 running, 244 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.5 us, 25.0 sy,  0.0 ni, 62.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,    123.2 free,   2549.1 used,   1192.1 buff/cache
    MiB Swap:    512.0 total,    261.5 free,    250.5 used.   1246.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  379M   1% /run
    /dev/sda2      ext4       55G   26G   27G  50% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 29 14:38:56 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=b39521b8-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Dec 29 14:39:02 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Mon Dec 29 14:39:03 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    7.7G    /var/
    4.1G    /var/log/journal/23c0d95e6b18424ba8497a2a3730c531
    4.1G    /var/log
    1.9G    /var/cache/apt
    Archived and active journals take up 4.0G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/ESPAsyncWebServer-esphome': Permission denied
    1.2G    /opt/iobroker/iobroker-data/
    863M    /opt/iobroker/iobroker-data/esphome.0
    861M    /opt/iobroker/iobroker-data/esphome.0/.esphome
    849M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    205M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibdeps/esp-display/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps/display4/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps/display7/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps/espwemos/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/wemos/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/test/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/esp32/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/esp8266/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibdeps/displaytft/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps/wemosesp/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibdeps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibdeps/display-tft/ESPAsyncWebServer-esphome': Permission denied
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.pioenvs/esp32/firmware.elf
    21M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.pioenvs/display7/firmware.elf
    19M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.pioenvs/tftdisplay/firmware.elf
    18M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.pioenvs/esp-display/firmware.elf
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi               raspi (version: 7.0.7, hostname: raspi         , alive, uptime: 949)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     2
    +-- iobroker.esphome@0.6.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#ebd79f96c6c48650ad3b818e9b6ef9c6b4106e76)
    +-- iobroker.vw-connect@0.7.15 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#f756508d8a444a476296f880c2ae1ac3e3010beb)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspi                                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
      system.adapter.birthdays.0              : birthdays             : raspi                                    -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspi                                    -  enabled
    + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : raspi                                    -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi                                    -  enabled
    + system.adapter.esphome.0                : esphome               : raspi                                    -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                    -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspi                                    -  enabled
      system.adapter.habpanel.0               : habpanel              : raspi                                    -  enabled
    + system.adapter.history.0                : history               : raspi                                    -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspi                                    -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspi                                    -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspi                                    -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspi                                    -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : raspi                                    -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi                                    -  enabled, port: 1883, bind: 192.168.178.10
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi                                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspi                                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 192.168.178.10, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1886, bind: 192.168.178.10
    + system.adapter.tr-064.0                 : tr-064                : raspi                                    -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : raspi                                    -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspi                                    -  enabled
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 192.168.178.10, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: patch
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "ems-esp"      : 6.0.1    , installed 6.0.1
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Objects and States
    Objects:        8461
    States:         7102
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          1850       815/dnsmasq
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        5771       842/influxd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12410      2525/io.shelly.0
    tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       9875       2238/io.hm-rpc.0
    tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       8133       2494/io.mqtt.0
    tcp        0      0 192.168.178.10:1886     0.0.0.0:*               LISTEN      1001       12440      2593/io.sonoff.0
    tcp        0      0 192.168.178.10:1884     0.0.0.0:*               LISTEN      1001       8134       2494/io.mqtt.0
    tcp        0      0 192.168.178.10:8082     0.0.0.0:*               LISTEN      1001       14491      2786/io.web.0
    tcp        0      0 192.168.178.10:8087     0.0.0.0:*               LISTEN      1001       14449      2775/io.simple-api.
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10468      1633/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10463      1633/iobroker.js-co
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       10917      2428/io.hm-rpc.2
    tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       10868      2306/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          572        639/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7202       842/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7864       1928/io.admin.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      107        8724       1632/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          574        639/sshd: /usr/sbin
    udp        0      0 0.0.0.0:52282           0.0.0.0:*                           104        1693       508/avahi-daemon: r
    udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1001       14496      2616/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1691       508/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11072      2572/io.shelly.1
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          1849       815/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          1846       815/dnsmasq
    udp6       0      0 fe80::6578:418f:682:546 :::*                                0          1823       586/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        1692       508/avahi-daemon: r
    udp6       0      0 :::38977                :::*                                104        1694       508/avahi-daemon: r
    2025-12-29 14:52:04.756  - info: javascript.0 (1987) script.js.Heizung.Luefter-Steuerung: -1.1
    2025-12-29 14:52:04.757  - info: javascript.0 (1987) script.js.Heizung.Luefter-Steuerung: 34
    2025-12-29 14:52:21.162  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:52:51.026  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:53:02.276  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:53:08.350  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:53:12.871  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:53:18.057  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:53:31.030  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:53:42.711  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:53:44.847  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:54:02.060  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:54:17.287  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:54:39.348  - info: javascript.0 (1987) script.js.Heizung.Luefter-Steuerung: 39.5
    2025-12-29 14:54:39.349  - info: javascript.0 (1987) script.js.Heizung.Luefter-Steuerung: -1.1
    2025-12-29 14:54:39.350  - info: javascript.0 (1987) script.js.Heizung.Luefter-Steuerung: 34
    2025-12-29 14:55:02.063  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:55:02.068  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:55:04.007  - info: admin.0 (1928) ==> Connected system.user.admin from ::ffff:192.168.178.184
    2025-12-29 14:55:11.628  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:55:11.634  - info: admin.0 (1928) <== Disconnect system.user.admin from ::ffff:192.168.178.184 admin
    2025-12-29 14:55:36.033  - info: host.raspi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 4030
    2025-12-29 14:55:39.768  - info: weatherunderground.0 (4030) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
    2025-12-29 14:56:13.720  - info: weatherunderground.0 (4030) Terminated (NO_ERROR): Without reason
    2025-12-29 14:56:14.269  - info: host.raspi instance system.adapter.weatherunderground.0 having pid 4030 terminated with code 0 (NO_ERROR)
    • W wibear
      Hallo Forum,
      Alles ist aktuell.
      Danke.
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      raspi
      HOME=/home/raspi
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               3795 M total memory
               2548 M used memory
                123 M free memory
                 35 M buffer memory
               1156 M swap cache
                511 M total swap
                250 M used swap
                261 M free swap
      *** FILESYSTEM ***
      /var:
      7.7G    /var/
      4.1G    /var/log
      1.9G    /var/cache/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8461
      States:         7102
      Pending Updates: 0
      @wibear sagte in IOBroker nicht mehr erreichbar und pivCCU sehr träge:
      habpanel.0 läuft ja nicht.
      Starte die Instanz.
      W 1 Antwort Letzte Antwort
      • HomoranH Homoran verschob dieses Thema von Forum am
        Starte die Instanz.
        W Offline
        W Offline
        wibear
        @Thomas-Braun sagte in IOBroker nicht mehr erreichbar und pivCCU sehr träge:
        Starte die Instanz.
        Wie kann ich sie bitte starten, wenn ich an die Instanzen gar nicht rankomme?
        • W wibear
          Starte die Instanz.
          @wibear
          Über das beste Admin-Tool?
          Die Kommandozeile...
          iob start habpanel.0
          • W Offline
            W Offline
            wibear
            Danke Thomas!
            • W wibear
              Hallo Forum,
              Alles ist aktuell.
              Danke.
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              raspi
              HOME=/home/raspi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       2548 M used memory
                        123 M free memory
                         35 M buffer memory
                       1156 M swap cache
                        511 M total swap
                        250 M used swap
                        261 M free swap
              *** FILESYSTEM ***
              /var:
              7.7G    /var/
              4.1G    /var/log
              1.9G    /var/cache/apt
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.19
              javascript:     9.0.11
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8461
              States:         7102
              Pending Updates: 0
              • system.adapter.shelly.1 : shelly : raspi - enabled, port: 1882, bind: 0.0.0.0
              2x port 1882!??
              ist das bei shelly ok?
              kenne mich bei shelly nicht aus
                2x port 1882!??
                W Offline
                W Offline
                wibear
                @Homoran sagte in IOBroker nicht mehr erreichbar und pivCCU sehr träge:
                2x port 1882!??
                Das hat bisher einwandfrei funktioniert. Es sind verschiedene Shelly Generationen, deswegen 2 Instanzen.
                Hab gerade den Fehler gefunden: mein Dell-Laptop hat gesponnen. Ist bisher noch nie passiert. Danke Euch für Euer Support!
