  5. Blockly: has to be type "string" but received type "number"
    6.3k
9 Beiträge 4 Kommentatoren 500 Aufrufe 2 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Hallo
    Ich hab hier ein Blockly, dass mir diesen Fehler schreibt.
    javascript.0 2025-12-17 21:39:39.836	info	State value to set for "0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit" has to be type "string" but received type "number"
    javascript.0 2025-12-17 21:39:39.827	warn	at processImmediate (node:internal/timers:483:21)
    javascript.0 2025-12-17 21:39:39.827	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
    javascript.0 2025-12-17 21:39:39.827	warn	at JavaScript.emit (node:domain:489:12)
    javascript.0 2025-12-17 21:39:39.826	warn	at JavaScript.emit (node:events:524:28)
    javascript.0 2025-12-17 21:39:39.826	warn	at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0 2025-12-17 21:39:39.826	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0 2025-12-17 21:39:39.826	warn	at Object.<anonymous> (script.js.3D-Drucker.Restzeit_Klipper:6:5)
    javascript.0 2025-12-17 21:39:39.826	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    javascript.0 2025-12-17 21:39:39.825	warn	You are assigning a number to the state "0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    Dann hab ich den DP von string zu number geändert.
    Dann ist dann das gekommen
    admin.0 2025-12-17 22:00:41.146	warn	Object 0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit is invalid: Default value has to be type "number" but received type "string" This will throw an error up from js-controller version 7.0.0!
    on({ id: 'klipper-moonraker.0.display_status.progress' /* Progress in Percent */, change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      if (getState('klipper-moonraker.0.print_stats.print_duration').val > 0) {
        setState('0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit' /* Restzeit */, ((obj.state ? obj.state.val : '') < 1 ? Math.round(((1 - (obj.state ? obj.state.val : '')) * getState('klipper-moonraker.0.print_stats.print_duration').val) / (obj.state ? obj.state.val : '')) : 0), true);
        setState('0_userdata.0.3DDrucker.Snapmaker_U1.Endzeit' /* Endzeit */, formatDate(getDateObject(((new Date().getTime()) + ((obj.state ? obj.state.val : '') < 1 ? Math.round((((1 - (obj.state ? obj.state.val : '')) * getState('klipper-moonraker.0.print_stats.print_duration').val) / (obj.state ? obj.state.val : '')) * 1000) : 0))), 'TT.MM.JJJJ SS:mm'), true);
    Der originale DP ist number.
    Wie bring ich das weg?
    ° Fixer ---> iob fix
    • geschildG Offline
      geschildG Offline
      geschild
      Indem du auf dem Pfeil am Ende Zeile in der "Zahl(number)" steht klickst und du dann String auswählst.
      • NegaleinN Negalein
        Hallo
        @Negalein sagte: "0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit"
        ist ein anderer DP als der gezeigte. Ändere dessen Typ von "string" in "number".
        • geschildG geschild
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          @geschild sagte in Blockly: has to be type "string" but received type "number":
          hab ihn doch schon von String zu Number (siehe oben)
          dann kommt
          zurück auf String kommt
          @paul53 sagte in Blockly: has to be type "string" but received type "number":
          den hab ich geändert.
          Da ist dann Object 0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit is invalid: Default value has to be type "number" but received type "string" This will throw an error up from js-controller version 7.0.0! gekommen.
            dann kommt
            @Negalein sagte: Default value has to be type "number"
            Ändere common.def in eine Zahl (0).
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              wo find ich das?
                wo find ich das?
                @Negalein sagte: wo find ich das?
                Unter "OBJEKTDATEN".
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  so richtig?
                    "common": {
                      "name": "Restzeit",
                      "desc": "Manuell erzeugt",
                      "role": "state",
                      "type": "number",
                      "read": true,
                      "write": true,
                      "def": "0"
                    "type": "state",
                    "native": {},
                    "_id": "0_userdata.0.3DDrucker.Snapmaker_U1.Restzeit",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                    "user": "system.user.admin",
                    "ts": 1766005241144
                    so richtig?
                      "common": {
                        "name": "Restzeit",
                        "role": "state",
                        "type": "number",
                        "read": true,
                        "write": true,
                        "def": "0"
                      "type": "state",
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "ts": 1766005241144
                    @Negalein sagte in Blockly: has to be type "string" but received type "number":
                    "def": "0"
                    das ist ein String!
                    Number wäre "def": 0
