  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Wolf WP CHA-10 - iSME7i (Wolf Link) oder iSME8i besser ?
    2.8k
    4.8k
    4.1k
35 Beiträge 3 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • O obstbauer
    @ullij wenn es läuft, läuft es wirklich gut, aber leider sehe ich jetzt, dass der Deinst das eine Mal nach jknapp 50 Minuten abgebrochen hat und jetzt nach 1 Stunde 20 Minuten:
    Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.OnPushResponseAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM>
    Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.ResponseDispatcher.DispatchAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/I>
    Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.ReadPipeAsync(PipeReader source, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7C>
    Oct 07 21:19:52 raspberrypi bash[21690]: System.Net.Sockets.SocketException (125): Operation canceled
    Oct 07 21:19:52 raspberrypi bash[21690]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError, CancellationToken)
    Oct 07 21:19:52 raspberrypi bash[21690]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16)
    Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7ssl.Ism7SslStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
    Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.FillPipeAsync(PipeWriter target, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7C>
    Oct 07 21:19:52 raspberrypi systemd[1]: ism7mqtt.service: Deactivated successfully.
    Oct 07 21:19:52 raspberrypi systemd[1]: ism7mqtt.service: Consumed 1min 1.122s CPU time.
    woran könnte das nun liegen ? Alle anderen mqtt Dienste laufen eigentlich einfwandfrei....
    U Offline
    U Offline
    UlliJ
    @obstbauer sagte in Wolf WP CHA-10 - iSME7i (Wolf Link) oder iSME8i besser ?:
    da werde ich Dir nicht viel helfen können...leider. Verstehe die Meldung aber so, daß irgendetwas in einen timeout läuft und anschließend der Dienst beendet wird. Ist das die komplette Fehlermeldung?
    Ist das ISM7 per Kabel oder Wlan angebunden? Wenn per Wlan ist das der erste Kandidat
    Auf der Konsole mal schauen was im log steht
    sudo journalctl -u ism7mqtt.service
    das log von hinten und seit dem letzten booten ...
    sudo journalctl -u ism7mqtt.service -b -e
    Proxmox auf iNuc, lxc für IoB, InfluxDB2, Grafana, u.a. *** Homematic & Homematic IP, Shellies, Zigbee etc
    O 2 Antworten Letzte Antwort
    • U UlliJ
      O Offline
      O Offline
      obstbauer
      schrieb am zuletzt editiert von obstbauer
      @ullij ja es ist seltsam, manchmal läuft es mehrere Stunden und dann wieder nur eine Stunde
      pi@raspberrypi:~ $ sudo journalctl -u ism7mqtt.service -b -e
      Oct 07 16:59:50 raspberrypi bash[20298]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16)
      Oct 07 16:59:50 raspberrypi bash[20298]:    at ism7ssl.Ism7SslStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
      Oct 07 16:59:50 raspberrypi bash[20298]:    at ism7mqtt.Ism7Client.FillPipeAsync(PipeWriter target, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 07 16:59:50 raspberrypi systemd[1]: ism7mqtt.service: Deactivated successfully.
      Oct 07 16:59:50 raspberrypi systemd[1]: ism7mqtt.service: Consumed 31.440s CPU time.
      Oct 07 20:05:32 raspberrypi systemd[1]: Started ism7mqtt.service - ism7mqtt.
      Oct 07 21:19:52 raspberrypi bash[21690]: System.IO.InvalidDataException: timeout
      Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.OnPushResponseAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism>
      Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.ResponseDispatcher.DispatchAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/R>
      Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.ReadPipeAsync(PipeReader source, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 07 21:19:52 raspberrypi bash[21690]:    at ism7mqtt.Ism7Client.FillPipeAsync(PipeWriter target, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 07 21:55:39 raspberrypi systemd[1]: Started ism7mqtt.service - ism7mqtt.
      Oct 08 11:50:14 raspberrypi bash[22379]: System.IO.InvalidDataException: timeout
      Oct 08 11:50:14 raspberrypi bash[22379]:    at ism7mqtt.Ism7Client.OnPushResponseAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism>
      Oct 08 11:50:14 raspberrypi bash[22379]:    at ism7mqtt.ResponseDispatcher.DispatchAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/R>
      Oct 08 11:50:14 raspberrypi bash[22379]:    at ism7mqtt.Ism7Client.ReadPipeAsync(PipeReader source, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 08 11:50:14 raspberrypi bash[22379]: System.Net.Sockets.SocketException (125): Operation canceled
      Oct 08 11:50:14 raspberrypi bash[22379]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError, CancellationToken)
      Oct 08 11:50:14 raspberrypi bash[22379]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16)
      Oct 08 11:50:14 raspberrypi bash[22379]:    at ism7ssl.Ism7SslStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
      Oct 08 11:50:14 raspberrypi bash[22379]:    at ism7mqtt.Ism7Client.FillPipeAsync(PipeWriter target, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 08 11:50:14 raspberrypi systemd[1]: ism7mqtt.service: Deactivated successfully.
      Oct 08 11:50:14 raspberrypi systemd[1]: ism7mqtt.service: Consumed 9min 2.241s CPU time.
      Oct 08 15:09:10 raspberrypi systemd[1]: /etc/systemd/system/ism7mqtt.service:6: Missing '=', ignoring line.
      Oct 08 15:09:15 raspberrypi systemd[1]: Started ism7mqtt.service - ism7mqtt.
      Oct 08 15:39:39 raspberrypi bash[28120]: System.IO.InvalidDataException: timeout
      Oct 08 15:39:39 raspberrypi bash[28120]:    at ism7mqtt.Ism7Client.OnPushResponseAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism>
      Oct 08 15:39:39 raspberrypi bash[28120]:    at ism7mqtt.ResponseDispatcher.DispatchAsync(IResponse response, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/R>
      Oct 08 15:39:39 raspberrypi bash[28120]:    at ism7mqtt.Ism7Client.ReadPipeAsync(PipeReader source, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 08 15:39:39 raspberrypi bash[28120]: System.Net.Sockets.SocketException (125): Operation canceled
      Oct 08 15:39:39 raspberrypi bash[28120]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError, CancellationToken)
      Oct 08 15:39:39 raspberrypi bash[28120]:    at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16)
      Oct 08 15:39:39 raspberrypi bash[28120]:    at ism7ssl.Ism7SslStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
      Oct 08 15:39:39 raspberrypi bash[28120]:    at ism7mqtt.Ism7Client.FillPipeAsync(PipeWriter target, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client>
      Oct 08 15:39:39 raspberrypi systemd[1]: ism7mqtt.service: Deactivated successfully.
      Oct 08 15:39:39 raspberrypi systemd[1]: ism7mqtt.service: Consumed 27.262s CPU time.
      es erscheint immer:
      U 1 Antwort Letzte Antwort
      • U UlliJ
        O Offline
        O Offline
        obstbauer
        @ullij ist per Kabel verbunden
        • O obstbauer
          es erscheint immer:
          U Offline
          U Offline
          UlliJ
          ... da bin ich raus.
          Ich habe eine x64 Installation und der Dienst läuft in einem LXC mit (derzeit noch) Debian 12, auf der nichts anderes installiert ist.
          Du könntest die issues auf Github https://github.com/zivillian/ism7mqtt durchsehen.
          Quick and dirty: den Dienst mit einem automatischen Neustart versehen
          Dazu in der Datei "ism7mqtt.service" die beiden Zeilen mit "Restart =..." einfügen
          [Unit]
          Description=ism7mqtt
          [Service]
          Type=simple
          ExecStart=/bin/bash /opt/ism7mqtt/ism7mqtt_start.sh
          Restart=always
          RestartSec=5s
          [Install]
          WantedBy=multi-user.target
          Alias=ism7mqtt.service
          Danach den Dienst neu laden oder den Rechner neu booten... wie gesagt keine saubere Lösung.
          Den restart habe ich auch aktiv, weil der Dienst offline geht und bleibt wenn die Gegenseite (mqtt broker) mal weg ist.
          O 1 Antwort Letzte Antwort
          • U UlliJ
            [Unit]
            [Service]
            Type=simple
            Restart=always
            RestartSec=5s
            [Install]
            O Offline
            O Offline
            obstbauer
            @ullij danke für den Tipp, ich habe ein issue eröffnet
            • O obstbauer
              O Offline
              O Offline
              obstbauer
              @obstbauer Hallo,
              ich habe Hilfe erhalten. Das Problem scheint gewesen zu sein, dass ich alle Werte in der parameter.json abgerufen habe. Das scheint das ism7 zu überfordern. Ich habe dann alle Werte, die ich nicht benötige, entfernt aus der parameter.json (das waren einige) und jetzt läuft es stabil
              • O Offline
                O Offline
                obstbauer
                so nachdem das Empfangen von Werten jetzt richtig gut funktioniert würde ich auch gerne Werte ändern, hat jemand damit Erfahrung wie geht das mit dem Setzen ?
                Aus der Beschreibung werde ich nicht schlau
                konkret geht es bei mir darum zwischen Auto und Standby zu wechseln:
                Wolf/192.168.178.63/DHK_BM-2_0x85/set/
                    "Programmwahl": {
                        "340029": {
                            "text": "Standby"
                wie setze ich das mit dem iobroker? Viele Hinweise sind für home assistant
                • O obstbauer
                      "Programmwahl": {
                          "340029": {
                              "text": "Standby"
                  U Offline
                  U Offline
                  UlliJ
                  @obstbauer
                  das sieht bei mir so aus und funktioniert auch
                  voller Text für das Topic:
                  Wolf/192.168.178.80/BM-2_0x35/set/Urlaubsmodus/value
                  oder die Sollwertverschiebung für den Heizkreis
                  Wolf/192.168.178.80/MK_BM-2_0x85/set/Sollwertkorrektur/360029/value
                  Wolf/192.168.178.80/MK_BM-2_0x85/set/Sollwertkorrektur/360042/value
                  ob Du hier wirklich beide schicken musst? probieren
                  Welche Werte Du beschreiben kannst musst Du ebenso probieren. Ausser den 2 Beispielen schreibe ich noch 1xWarmwasser, WW Solltemperatur, Umschaltung Heizprogramm und WW Programm
                  • U UlliJ
                    @obstbauer
                    O Offline
                    O Offline
                    obstbauer
                    @ullij super! Danke für die schnelle Antwort, werde es testen!
                    • O Offline
                      O Offline
                      obstbauer
                      so ich bin jetzt erst zum ausprobieren gekommen,
                      wie änderst du jetzt einen Wert? Zum Beispiel wenn ich die Sollspreizung von 4 auf 6 ändern möchte oder bei dir die WW Solltemperatur ? Wo gibst du in deinem Blockly den Wert an ? Oder hast du dafür die Objekt ID oben extra erstellt in der der Wert steht? Sorry ich habe das bisher noch nicht gemacht, danke!
                      • O obstbauer
                        U Offline
                        U Offline
                        UlliJ
                        @obstbauer
                        eine von vielen möglichen Lösungen z.B. für die Sollwertverschiebung des Heizkreises
                        3 Datenpunkte unter userdata z.B.
                        • 0_userdata.0.1000_Heizung.WP.HKSoll+
                        • 0_userdata.0.1000_Heizung.WP.HKSoll-
                        • 0_userdata.0.1000_Heizung.WP.Sollwertkorrektur
                        Dazu 2 kleine Blöcke mit Trigger auf HK+ und HK-
                        das 3. Blockly mit Trigger auf der Sollwertkorrektur zum senden an Mqtt, sowie Rücksetzung der Soll+ und Soll- DP's
                        ob wirklich beide Nachrichten gesendet werden müssen habe ich (noch) nicht probiert
                        1. Wolf/192.168.178.80/MK_BM-2_0x85/set/Sollwertkorrektur/360029/value
                        2. Wolf/192.168.178.80/MK_BM-2_0x85/set/Sollwertkorrektur/360042/value
                          Die Mqtt Werte können bei Dir andere sein weil Konfig anders, Du keinen Mischer für den HK hast etc...
                        Steuerung über die Vis dann so
                        ein Button hängt an HKSoll- und der zweite an HKSoll+. Die schreiben beide je ein "+0.5" in den zugehörigen DP.
                        analog für andere Funktionen
                        • O Offline
                          O Offline
                          obstbauer
                          so ich habe es endlich hinbekommen...
                          Die Sollwert-Spreizung kann man bei der CHA-10 mit folgendem Befehl setzen:
                          Wolf/192.168.178.63/CHA_0x8/set/Soll-Spreizung/270075/value
                          Die Sollwertkorrektur geht mit diesen beiden
                          Wolf/192.168.178.63/DHK_BM-2_0x35/set/Sollwertkorrektur/340031/value
                          Wolf/192.168.178.63/DHK_BM-2_0x35/set/Sollwertkorrektur/340026/value
                          Ich nutze aktuell nur 340031 für die Umstellung und sehe dass damit auch 340026 geändert wird. Das ist eine nette Funktion, weil ich damit eigene Absenkungen definieren kann in Abhängigkeit der AT ohne das ECO-ABS und Zeitprogramme in der Wolf.
