  4. Umzug von rpb 3 auf rpb 4
    6.5k
21 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • W wolf
    Das kommt als Ausgabe:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 9 (stretch)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 4.19.66-v7+
          Architecture: arm
    OS is similar to: debian
    model name      : ARMv7 Processor rev 4 (v7l)
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     19:00:12 up 21 days, 10:36,  2 users,  load average: 1.23, 0.71, 0.65
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'stretch'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
          Local time: Thu 2025-11-27 19:00:12 CET
      Universal time: Thu 2025-11-27 18:00:12 UTC
            RTC time: n/a
           Time zone: Europe/Vienna (CET, +0100)
     Network time on: yes
    NTP synchronized: yes
     RTC in local TZ: no
    Unknown operation show
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:           948M        649M        104M        5.6M        194M        263M
    Swap:          511M        505M        6.7M
    Total:         1.5G        1.2G        111M
    Active iob-Instances:   20
              926 M total memory
              633 M used memory
              328 M active memory
              426 M inactive memory
              102 M free memory
               49 M buffer memory
              139 M swap cache
              499 M total swap
              493 M used swap
                6 M free swap
    top - 19:00:13 up 21 days, 10:36,  2 users,  load average: 1.23, 0.71, 0.65
    Tasks: 169 total,   1 running, 110 sleeping,   0 stopped,   3 zombie
    %Cpu(s):  4.5 us,  3.5 sy,  0.0 ni, 91.7 id,  0.1 wa,  0.0 hi,  0.2 si,  0.0 st
    KiB Mem :   948304 total,   104548 free,   648976 used,   194780 buff/cache
    KiB Swap:   511996 total,     6716 free,   505280 used.   263872 avail Mem
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       30G  9.4G   19G  34% /
    devtmpfs       devtmpfs  459M     0  459M   0% /dev
    tmpfs          tmpfs     464M     0  464M   0% /dev/shm
    tmpfs          tmpfs     464M   13M  451M   3% /run
    tmpfs          tmpfs     464M     0  464M   0% /sys/fs/cgroup
    /dev/sda1      vfat       41M   23M   19M  55% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    /dev/sdb1      ext4       58G   27G   29G  49% /media/pi/Intenso
    [Thu Nov  6 08:23:56 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e4761da5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Nov  6 08:23:59 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Nov  6 08:23:59 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Nov  6 08:24:00 2025] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Thu Nov  6 08:24:14 2025] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
    [Fri Nov 21 02:00:31 2025] [<802383dc>] (filemap_fault) from [<8036f87c>] (ext4_filemap_fault+0x38/0x4c)
    [Fri Nov 21 02:00:31 2025] [<8036f87c>] (ext4_filemap_fault) from [<80270fe8>] (__do_fault+0x5c/0x194)
    Show mounted filesystems:
    findmnt: unrecognized option '--real'
    Usage:
     findmnt [options]
     findmnt [options] <device> | <mountpoint>
     findmnt [options] <device> <mountpoint>
     findmnt [options] [--source <device>] [--target <path> | --mountpoint <dir>]
    Find a (mounted) filesystem.
    Options:
     -s, --fstab            search in static table of filesystems
     -m, --mtab             search in table of mounted filesystems
     -k, --kernel           search in kernel table of mounted
                              filesystems (default)
     -p, --poll[=<list>]    monitor changes in table of mounted filesystems
     -w, --timeout <num>    upper limit in milliseconds that --poll will block
     -A, --all              disable all built-in filters, print all filesystems
     -a, --ascii            use ASCII chars for tree formatting
     -b, --bytes            print sizes in bytes rather than in human readable format
     -C, --nocanonicalize   don't canonicalize when comparing paths
     -c, --canonicalize     canonicalize printed paths
     -D, --df               imitate the output of df(1)
     -d, --direction <word> direction of search, 'forward' or 'backward'
     -e, --evaluate         convert tags (LABEL,UUID,PARTUUID,PARTLABEL)
                              to device names
     -F, --tab-file <path>  alternative file for -s, -m or -k options
     -f, --first-only       print the first found filesystem only
     -i, --invert           invert the sense of matching
     -J, --json             use JSON output format
     -l, --list             use list format output
     -N, --task <tid>       use alternative namespace (/proc/<tid>/mountinfo file)
     -n, --noheadings       don't print column headings
     -O, --options <list>   limit the set of filesystems by mount options
     -o, --output <list>    the output columns to be shown
     -P, --pairs            use key="value" output format
     -R, --submounts        print all submounts for the matching filesystems
     -r, --raw              use raw output format
     -S, --source <string>  the device to mount (by name, maj:min,
                              LABEL=, UUID=, PARTUUID=, PARTLABEL=)
     -T, --target <path>    the path to the filesystem to use
     -M, --mountpoint <dir> the mountpoint directory
     -t, --types <list>     limit the set of filesystems by FS types
     -U, --uniq             ignore filesystems with duplicate target
     -u, --notruncate       don't truncate text in columns
     -v, --nofsroot         don't print [/dir] for bind or btrfs mounts
     -x, --verify           verify mount table content (default is fstab)
         --verbose          print more details
     -h, --help     display this help and exit
     -V, --version  output version information and exit
    Available columns:
          SOURCE  source device
          TARGET  mountpoint
          FSTYPE  filesystem type
         OPTIONS  all mount options
     VFS-OPTIONS  VFS specific mount options
      FS-OPTIONS  FS specific mount options
           LABEL  filesystem label
            UUID  filesystem UUID
       PARTLABEL  partition label
        PARTUUID  partition UUID
         MAJ:MIN  major:minor device number
          ACTION  action detected by --poll
      OLD-TARGET  old mountpoint saved by --poll
     OLD-OPTIONS  old mount options saved by --poll
            SIZE  filesystem size
           AVAIL  filesystem size available
            USED  filesystem size used
            USE%  filesystem use percentage
          FSROOT  filesystem root
             TID  task ID
              ID  mount ID
      OPT-FIELDS  optional mount fields
     PROPAGATION  VFS propagation flags
            FREQ  dump(8) period in days [fstab only]
          PASSNO  pass number on parallel fsck(8) [fstab only]
    For more details see findmnt(8).
    /var:
    2.3G    /var/
    1.4G    /var/cache/apt/archives
    1.4G    /var/cache/apt
    1.4G    /var/cache
    353M    /var/lib
    Archived and active journals take up 11.5M in the file system.
    /opt/iobroker/backups:
    20M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    235M    /opt/iobroker/iobroker-data/
    133M    /opt/iobroker/iobroker-data/files
    75M     /opt/iobroker/iobroker-data/backup-objects
    31M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    12M     /opt/iobroker/iobroker-data/objects.json.bak
    8.2M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.979c3ea7.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
    4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.df84d04d.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9DAEF-if00
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v12.22.12
    /usr/bin/node           v12.22.12
    /usr/bin/npm            6.14.16
    /usr/bin/npx            6.14.16
    corepack:       N/A
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.12-1nodesource1
      Candidate: 12.22.12-1nodesource1
      Version table:
     *** 12.22.12-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
         8.11.1~dfsg-2~bpo9+1 500
            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
         4.8.2~dfsg-1 500
            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    Hosts:
    raspberrypi         raspberrypi (version: 3.1.6, hostname: raspberrypi   , alive, uptime: 1852572)
    Core adapters versions
    js-controller:  3.1.6
    admin:          4.2.1
    javascript:     4.8.4
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                : alexa2                -  enabled
    + system.adapter.backitup.0              : backitup              -  enabled
    + system.adapter.broadlink2.0            : broadlink2            -  enabled
      system.adapter.daswetter.0             : daswetter             -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.flot.0                  : flot                  -  enabled
      system.adapter.icons-ultimate-png.0    : icons-ultimate-png    -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + system.adapter.iot.0                   : iot                   -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
    + system.adapter.mqtt.0                  : mqtt                  -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.parser.0                : parser                - disabled
    + system.adapter.ping.0                  : ping                  -  enabled
    + system.adapter.scenes.0                : scenes                -  enabled
    + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                   : sql                   -  enabled, port: 0
    + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0          : text2command          -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-history.0           : vis-history           -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis-metro.0             : vis-metro             -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
      system.adapter.vis-weather.0           : vis-weather           -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                 : yahka                 -  enabled
    + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9DAEF-if00
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
    Active repo: Stable (default)
    Installed ioBroker-Adapters
    hash unchanged, use cached sources
    Cannot get any information of "_repoInfo". Ignored.
    update done
    Adapter    "admin"         : 7.7.19   , installed 4.2.1 [Updateable]
    Adapter    "alexa2"        : 3.27.4   , installed 3.19.10 [Updateable]
    Adapter    "backitup"      : 3.3.10   , installed 1.7.0 [Updateable]
    Adapter    "broadlink2"    : 2.3.0    , installed 2.0.3 [Updateable]
    Adapter    "cloud"         : 5.0.1    , installed 4.0.4 [Updateable]
    Adapter    "daswetter"     : 3.2.8    , installed 3.0.4 [Updateable]
    Adapter    "discovery"     : 5.0.0    , installed 3.0.5 [Updateable]
    Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
    Adapter    "history"       : 3.0.1    , installed 1.9.12 [Updateable]
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "iot"           : 5.0.7    , installed 1.8.13 [Updateable]
    Adapter    "javascript"    : 9.0.11   , installed 4.8.4 [Updateable]
    Controller "js-controller" : 7.0.7    , installed 3.1.6 [Updateable]
    Adapter    "mqtt"          : 6.1.4    , installed 2.4.0 [Updateable]
    Adapter    "parser"        : 2.2.4    , installed 1.0.7 [Updateable]
    Adapter    "ping"          : 1.6.2    , installed 1.4.12 [Updateable]
    Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
    Adapter    "scenes"        : 3.2.3    , installed 2.3.6 [Updateable]
    Adapter    "simple-api"    : 2.8.0    , installed 2.5.3 [Updateable]
    Adapter    "socketio"      : 6.7.1    , installed 3.1.4 [Updateable]
    Adapter    "sonoff"        : 3.2.1    , installed 2.5.1 [Updateable]
    Adapter    "sql"           : 3.0.1    , installed 1.15.5 [Updateable]
    Adapter    "telegram"      : 4.1.0    , installed 1.7.0 [Updateable]
    Adapter    "terminal"      : 1.0.0    , installed 0.1.2 [Updateable]
    Adapter    "text2command"  : 3.0.3    , installed 2.0.7 [Updateable]
    Adapter    "vis"           : 1.5.6    , installed 1.3.10 [Updateable]
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.5.1    , installed 1.1.7 [Updateable]
    Adapter    "vis-jqui-mfd"  : 1.1.1    , installed 1.0.12 [Updateable]
    Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
    Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
    Adapter    "vis-weather"   : 2.5.13   , installed 2.5.2 [Updateable]
    Adapter    "weatherunderground": 3.7.0   , installed 3.3.0 [Updateable]
    Adapter    "web"           : 7.0.8    , installed 3.3.0 [Updateable]
    Adapter    "yahka"         : 1.1.5    , installed 0.13.1 [Updateable]
    Adapter    "yr"            : 5.3.0    , installed 2.0.3 [Updateable]
    Adapter    "zigbee"        : 3.1.5    , installed 1.0.4 [Updateable]
    Objects and States
    Objects:        8070
    States:         7138
    E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13543      496/sshd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       16213      1175/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25550747   5339/io.sonoff.0
    tcp        0      0 127.0.0.1:44801         0.0.0.0:*               LISTEN      1001       886075     1340/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16524      455/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15925      455/iobroker.js-con
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          12081      487/vncserver-x11-c
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16183      1134/io.web.0
    tcp6       0      0 :::37141                :::*                    LISTEN      1001       20151      1340/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13545      496/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17142      1818/io.simple-api.
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17509      1016/io.terminal.0
    tcp6       0      0 :::3306                 :::*                    LISTEN      111        14539      591/mysqld
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          12080      487/vncserver-x11-c
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20152      1340/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9079       340/avahi-daemon: r
    udp        0      0 0.0.0.0:47999           0.0.0.0:*                           108        9081       340/avahi-daemon: r
    udp        0      0 0.0.0.0:50050           0.0.0.0:*                           1001       17574      1103/io.broadlink2.
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12539      377/dhcpcd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17572      1103/io.broadlink2.
    udp6       0      0 :::5353                 :::*                                108        9080       340/avahi-daemon: r
    udp6       0      0 :::60470                :::*                                108        9082       340/avahi-daemon: r
    2025-11-27 18:47:48.860  - info: sonoff.0 (5339) Client [Schlafzimmer_Temp] connected with secret 1764265668858_1409
    2025-11-27 18:50:00.028  - info: javascript.0 (23604) script.js.common.Aussentemp_mit_iobroker: Temperaturen abrufen und senden: Innen=23.39, Außen=2.69
    2025-11-27 18:50:02.357  - info: javascript.0 (23604) script.js.common.Aussentemp_mit_iobroker: Temperaturen erfolgreich gesendet: Innen=23.39, Außen=2.69
    2025-11-27 18:52:57.109  - info: sonoff.0 (5339) Client [Schlafzimmer_Temp] connection closed: timeout
    2025-11-27 18:57:28.532  - info: sonoff.0 (5339) Client [Schlafzimmer_Temp] connected with secret 1764266248531_5854
    2025-11-27 19:00:00.024  - info: javascript.0 (23604) script.js.common.Aussentemp_mit_iobroker: Temperaturen abrufen und senden: Innen=22.88, Außen=2.69
    2025-11-27 19:00:02.451  - info: javascript.0 (23604) script.js.common.Aussentemp_mit_iobroker: Temperaturen erfolgreich gesendet: Innen=22.88, Außen=2.69
    2025-11-27 19:01:19.918  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-11-27 19:01:26.591  - info: sonoff.0 (5339) Client [Schlafzimmer_Touch] connection closed: closed
    2025-11-27 19:01:26.593  - info: sonoff.0 (5339) Client [Schlafzimmer_Touch] connected with secret 1764266486590_2232
    2025-11-27 19:01:19.937  - error: zigbee.0 (5203) unhandled promise rejection: AREQ - AF - dataConfirm after 3000ms
    2025-11-27 19:01:19.996  - error: zigbee.0 (5203) Error: AREQ - AF - dataConfirm after 3000ms
        at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
        at listOnTimeout (internal/timers.js:554:17)
        at processTimers (internal/timers.js:497:7)
    2025-11-27 19:01:20.025  - info: zigbee.0 (5203) cleaned everything up...
    2025-11-27 19:01:20.045  - info: zigbee.0 (5203) Zigbee: disabling joining new devices.
    2025-11-27 19:01:26.880  - warn: zigbee.0 (5203) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-11-27 19:01:33.765  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGKILL
    2025-11-27 19:01:33.795  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code NaN ()
    2025-11-27 19:01:33.804  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2025-11-27 19:01:33.821  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-11-27 19:01:33.822  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
    2025-11-27 19:02:03.887  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18101
    2025-11-27 19:02:03.939  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 18107
    iob diag has finished.
    @wolf sagte in Umzug von rpb 3 auf rpb 4:
    stretch
    oh ha!
    Da wirst du wahrscheinlich mittlerweile wirklich festsitzen.
    dafür wird wahrscheinlich nichts mehr gebaut
    werden.
    was wird dir denn im admin noch zum update angeboten wo kein rotes Kreuz dran ist?
    W 1 Antwort Letzte Antwort
    • W Offline
      W Offline
      wolf
      Sorry, war nicht vollständig. Jetzt die gesamte Ausgabe (hoffentlich):
      Script v.2025-08-09
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
              RTC time: n/a
       RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:
      *** MEMORY ***
                926 M total memory
                633 M used memory
                328 M active memory
                102 M free memory
                 49 M buffer memory
                139 M swap cache
                499 M total swap
                493 M used swap
                  6 M free swap
      *** FILESYSTEM ***
      Usage:
       findmnt [options]
      Options:
                                to device names
      Available columns:
            TARGET  mountpoint
               TID  task ID
                ID  mount ID
      /var:
      2.3G    /var/
      1.4G    /var/cache/apt
      1.4G    /var/cache
      353M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      corepack:       N/A
      nodejs:
        Version table:
           4.8.2~dfsg-1 500
      ioBroker Status
      Objects type: file
      States  type: file
      Hosts:
      admin:          4.2.1
      javascript:     4.8.4
      Adapter State
      + instance is alive
      update done
      Objects and States
      Objects:        8070
      States:         7138
      Pending Updates: 0
        stretch
        oh ha!
        werden.
        W Offline
        W Offline
        wolf
        @Homoran
        Eigenlich wird nichts mehr zum Update angeboten :(
        • W wolf
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                  RTC time: n/a
           RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:
          *** MEMORY ***
                    926 M total memory
                    633 M used memory
                    328 M active memory
                    102 M free memory
                     49 M buffer memory
                    139 M swap cache
                    499 M total swap
                    493 M used swap
                      6 M free swap
          *** FILESYSTEM ***
          Usage:
           findmnt [options]
          Options:
                                    to device names
          Available columns:
                TARGET  mountpoint
                   TID  task ID
                    ID  mount ID
          /var:
          2.3G    /var/
          1.4G    /var/cache/apt
          1.4G    /var/cache
          353M    /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          corepack:       N/A
          nodejs:
            Version table:
               4.8.2~dfsg-1 500
          ioBroker Status
          Objects type: file
          States  type: file
          Hosts:
          admin:          4.2.1
          javascript:     4.8.4
          Adapter State
          + instance is alive
          update done
          Objects and States
          Objects:        8070
          States:         7138
          Pending Updates: 0
          Macht's nicht besser
          ich weiß nicht, ob Backups von v3 überhaupt noch eingelesen werden können mit >5 schon mal gar nicht.
          Das wird ein heftiges gebastel
            W Offline
            W Offline
            wolf
            @Homoran sagte in Umzug von rpb 3 auf rpb 4:
            Das
            Das habe ich befürchtet…
            • W wolf
              @Homoran
              Logisch, die Update-Karawane läuft ja auch schon seit Jahren an deiner Oase in der du da hockst vorbei.
              Never-tatsch-a-running-system funktioniert halt nicht.
              Zuerst würde ich den Desktop ausschalten. Der Arbeitsspeicher geht dir ja jetzt schon aus, da haste keine Kapazitäten für bunte GUI.
              Versuch zunächst mal:
              sudo systemctl set-default multi-user.target
              sudo reboot
              • W wolf
                Das
                @wolf Man kann es versuchen, neu machen kann man immer noch.
                BACKUP ZIEHEN!
                dann schrittweise versuchen erst den Controller, dann admin, dann weitere Adapter hochzuziehen.
                Eigentlich muss zuerst der Unterbau hochgezogen werden: OS und node.
                Stretch ist nun scho so lange tot, da wird aber nix mehr gehen
                  BACKUP ZIEHEN!
                  Für das OS gibt es nix mehr. Aber nodejs könnte man mal versuchen auf nodejs@16 (und dann ggfls. weiter hoch) zu bringen.
                  Das gibt es noch von nodesource:
                  nodejs:
                    Installed: 25.2.0-1nodesource1
                    Candidate: 16.20.2-1nodesource1
                    Version table:
                   *** 25.2.0-1nodesource1 100
                       20.19.2+dfsg-1 500
                          500 http://deb.debian.org/debian trixie/main arm64 Packages
                       16.20.2-1nodesource1 1001
                          500 https://deb.nodesource.com/node_16.x nodistro/main arm64 Packages
                       16.20.1-1nodesource1 1001
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    W Offline
                    W Offline
                    wolf
                    @Thomas-Braun sagte in Umzug von rpb 3 auf rpb 4:
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    Ich hab das OS seit mindestens 5 Jahren nicht mehr geupdatet. Da fürchte ich, dass, wenn ich apt get drüber laufen lasse, schon etwas zerschossen wird.
                    Bringt es etwas, wenn ich auf nodejs 16 update? Lassen sich dann die Adapter aktualisieren?
                    Sorry, dumme Fragen, aber ich bin nur User mit rudimentären Linux-Kenntnissen.
                    Auf jeden Fall möchte ich mich jetzt bedanken, dass es hier so schnell Tipps gibt. Unabhängig davon, ob es für mein Problem eine Lösung gibt, oder nicht.
                    • W wolf
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      eher 10
                      ist zumindest eine Chance
                      EDIT: Sorry, hab stretch mit Jessie verwechselt
                        eher 10
                        W Offline
                        W Offline
                        wolf
                        eher 10
                        Ich kann mich dunkel erinnern, dass es irgendwo eine Anleitung für das Updaten von npm und nodejs gab. Weißt du vielleicht einen Link dazu?
                        • W Offline
                          W Offline
                          wolf
                          Auf
                          type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs
                          bekomme ich übrigens
                          /usr/bin/nodejs
                          v12.22.12
                          /usr/bin/node
                          v12.22.12
                          /usr/bin/npm
                          6.14.16
                          /usr/bin/npx
                          6.14.16
                          nodejs:
                          Installiert: 12.22.12-1nodesource1
                          Installationskandidat: 12.22.12-1nodesource1
                          Versionstabelle:
                          4.8.2~dfsg-1 500
                          • W wolf
                            Auf
                            /usr/bin/nodejs
                            v12.22.12
                            /usr/bin/node
                            v12.22.12
                            /usr/bin/npm
                            6.14.16
                            /usr/bin/npx
                            6.14.16
                            nodejs:
                            Versionstabelle:
                            4.8.2~dfsg-1 500
                            @wolf
                            Ich würde mal versuchen, ob das nodesource-Repo für nodejs@16 noch für stretch funktioniert. Ich kann dir gleich mal raussuchen, wie das geht, bin gerade aber unterwegs.
                              @wolf
                              W Offline
                              W Offline
                              wolf
                              @wolf
                              Eilt ja nicht. :)
                              • W wolf
                                @wolf
                                Eilt ja nicht. :)
                                @wolf
                                Also:
                                iob stop
                                iob fix
                                iob update
                                iob upgrade all -y
                                iob nodejs-update 16
                                cd /opt/iobroker
                                iob stop
                                npm install iobroker.js-controller@4.0.24
                                iob update
                                iob upgrade all -y
                                iob nodejs-update 18
                                cd /opt/iobroker
                                iob stop
                                npm install iobroker.js-controller@5.0.19
                                iob update
                                iob upgrade all -y
                                iob nodejs-update 20
                                cd /opt/iobroker
                                iob stop
                                npm install iobroker.js-controller@6.0.11
                                iob update
                                iob upgrade all -y
                                iob nodejs-update
                                cd /opt/iobroker
                                iob stop
                                iob update
                                iob upgrade self
                                iob upgrade all -y
                                iob start
                                Und dann mal schauen, was dir ein
                                iob diag
                                um die Ohren wirft.
                                Wenn das alles auf Stand sein sollte, von dem Stand dann wieder ein Backup davon ziehen und in ein frisches System auf aktueller Hardware umziehen.
                                W HomoranH 2 Antworten Letzte Antwort
                                  @wolf
                                  Also:
                                  iob stop
                                  iob fix
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  iob nodejs-update
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade self
                                  iob upgrade all -y
                                  iob start
                                  iob diag
                                  um die Ohren wirft.
                                  W Offline
                                  W Offline
                                  wolf
                                  @wolf
                                  Also:
                                  iob stop
                                  iob fix
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade all -y
                                  iob nodejs-update
                                  cd /opt/iobroker
                                  iob stop
                                  iob update
                                  iob upgrade self
                                  iob upgrade all -y
                                  iob start
                                  iob diag
                                  um die Ohren wirft.
                                  Kein apt-get vorher und auch nodejs belassen, wie es ist?
                                    @wolf
                                    Also:
                                    iob stop
                                    iob fix
                                    iob update
                                    iob upgrade all -y
                                    cd /opt/iobroker
                                    iob stop
                                    iob update
                                    iob upgrade all -y
                                    cd /opt/iobroker
                                    iob stop
                                    iob update
                                    iob upgrade all -y
                                    cd /opt/iobroker
                                    iob stop
                                    iob update
                                    iob upgrade all -y
                                    iob nodejs-update
                                    cd /opt/iobroker
                                    iob stop
                                    iob update
                                    iob upgrade self
                                    iob upgrade all -y
                                    iob start
                                    iob diag
                                    um die Ohren wirft.
                                    @Thomas-Braun bist du sicher dass nodejs-update mit controller v3 läuft?
                                    • W wolf
                                      @wolf
                                      Also:
                                      iob stop
                                      iob fix
                                      iob update
                                      iob upgrade all -y
                                      cd /opt/iobroker
                                      iob stop
                                      iob update
                                      iob upgrade all -y
                                      cd /opt/iobroker
                                      iob stop
                                      iob update
                                      iob upgrade all -y
                                      cd /opt/iobroker
                                      iob stop
                                      iob update
                                      iob upgrade all -y
                                      iob nodejs-update
                                      cd /opt/iobroker
                                      iob stop
                                      iob update
                                      iob upgrade self
                                      iob upgrade all -y
                                      iob start
                                      iob diag
                                      um die Ohren wirft.
                                      apt-get schaut ins Leere, die Quelle ist ja vor Jahren schon ausgetrocknet (Never, never follow the 'Never change a running system'-Schwachsinn).
                                      nodejs-update hat ja nichts mit dem js-controller zu tun, das ist ein reines bash-Skript und kommt via 'iob fix' auf das System. Ich weiß nur nicht, ob der Fixer auf so einem alten System sauber durchläuft.
                                      Und ich weiß auch nicht, bei welcher nodejs-Version auf 'stretch' Schluss ist. Kann sein, das es auch gar nicht funktioniert. Dann müsste man da manuell ran.
