  4. L&S Beleuchtungssystem Zigbee unbekannt
    6.5k
27 Beiträge 4 Kommentatoren 2.0k Aufrufe 3 Beobachtet
    Tobias 0
    Hallo Asgothian,
    zuerst mal entschuldigung, dass es solange gedauert hat. War von der Arbeit her unterwegs.
    Ich habe deine Anleitung befolgt und folgende Meldungen:
    zigbee.0
    	2025-07-18 12:47:45.198	warn	ELEVATED:I02 (ad2b) value generated '100' from device 286847fffe6d37f1 for 'Brightness'
    zigbee.0
    	2025-07-18 12:47:45.198	warn	ELEVATED:I01 (ad2b) message received '{"brightness":254}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:45.196	warn	ELEVATED:I02 (ad2b) value generated '94' from device 286847fffe6d37f1 for 'Link quality'
    zigbee.0
    	2025-07-18 12:47:45.196	warn	ELEVATED:I01 (ad2b) message received '{"linkquality":94}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:45.195	warn	ELEVATED:I01 (ad2b) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"currentLevel":254},"linkquality":94,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":2,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
    zigbee.0
    	2025-07-18 12:47:35.290	warn	ELEVATED:I02 (8671) value generated 'true' from device 286847fffe6d37f1 for 'Switch state'
    zigbee.0
    	2025-07-18 12:47:35.290	warn	ELEVATED:I01 (8671) message received '{"state":"ON"}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.287	warn	ELEVATED:I02 (8672) value generated '0' from device 286847fffe6d37f1 for 'Brightness'
    zigbee.0
    	2025-07-18 12:47:35.287	warn	ELEVATED:I01 (8672) message received '{"brightness":1}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.287	warn	ELEVATED:I02 (8671) value generated 'true' from device 286847fffe6d37f1 for 'Switch state'
    zigbee.0
    	2025-07-18 12:47:35.286	warn	ELEVATED:I01 (8671) message received '{"state":"ON"}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.284	warn	ELEVATED:I02 (8672) value generated '91' from device 286847fffe6d37f1 for 'Link quality'
    zigbee.0
    	2025-07-18 12:47:35.284	warn	ELEVATED:I01 (8672) message received '{"linkquality":91}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.284	warn	ELEVATED:I02 (8671) value generated '91' from device 286847fffe6d37f1 for 'Link quality'
    zigbee.0
    	2025-07-18 12:47:35.284	warn	ELEVATED:I01 (8671) message received '{"linkquality":91}' from device 286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.282	warn	ELEVATED:SUCCESS (85d9) convert result {"state":{"state":"ON"}} for device 0x286847fffe6d37f1
    zigbee.0
    	2025-07-18 12:47:35.282	warn	ELEVATED:I01 (8672) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"currentLevel":1},"linkquality":91,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":1,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
    zigbee.0
    	2025-07-18 12:47:35.281	warn	ELEVATED:I01 (8671) Zigbee Event of Type attributeReport from device 0x286847fffe6d37f1, incoming event: {"type":"attributeReport","data":{"onOff":1},"linkquality":91,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":11}
    zigbee.0
    	2025-07-18 12:47:35.172	warn	ELEVATED:O04 (85d9) convert state, "ON", {} for device 0x286847fffe6d37f1 with Endpoint state
    zigbee.0
    	2025-07-18 12:47:35.172	warn	ELEVATED:O03 (85d9) Publishing to 0x286847fffe6d37f1 of model Mec Driver module with state
    zigbee.0
    	2025-07-18 12:47:35.172	warn	ELEVATED:O02 (85d9) Change state 'state' at device 0x286847fffe6d37f1 type 'Mec Driver module'
    zigbee.0
    	2025-07-18 12:47:35.130	warn	ELEVATED:O01 (85d9) User state change of state zigbee.0.286847fffe6d37f1.state with value true (ack: false) from system.adapter.admin.0
    So wie ich die Meldungen interpretiere kommt die 0 vom Gerät selbst oder?
    Beste Grüße Tobias
      Tobias 0
      @Asgothian Vielleicht könntest du mir nochmals helfen. Ich habe jetzt unter meinem zweiten Unterschrank die gleiche Lampe. Einbinden hat funktioniert. Leider ist es wieder wie bei der ersten Lampe, dass die Änderung von On/Off bei manuellen Bestätigen am Taster nicht am IObroker ankommt.
      Hast du noch eine Idee?
      • T Tobias 0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @tobias-0 die nutzt den gleichen externen konverter ? Wenn ja, dann:
        auf der Kachel das 'reconfigure' icon nutzen und damit das Gerät neu konfigurieren.
        A.
        • AsgothianA Asgothian
          A.
          Tobias 0
          @asgothian Nach dem Reconfig gehen jetzt beide nicht mehr. Ich habe beim Neustart jetzt auch einen Fehler vom ZIgbee Adapter gesehen.
          Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/mec.js - the code does not run: TypeError: identify is not a function
          Kann es sein, dass sich bei einem Update des Zigbee Adapters an den externen Convertern etwas geändert hat?
            Tobias 0
            Muss meine Aussage von oben nochmals anpassen. Die erste Lampe funktioniert wieder. Bei der zweiten wird der Zustände nicht abgefragt. Kann es ein Thema des fehlers in dem externen converter sein?
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Denkbar. Poste den Code bitte mal hier, incl. weitere Meldungen die beim Einbinden des Konverters kommen. Im code den ich oben gepostet hatte kommt 'identiy' nicht vor.
              A.
                A.
                Tobias 0
                @Asgothian
                Mein Code:
                const {identify, light} = require('zigbee-herdsman-converters/lib/modernExtend');
                const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
                const definition = {
                    zigbeeModel: ["Mec Driver module"],
                    model: "Mec Driver module",
                    vendor: "L&S Germany",
                    description: 'Unterschrank',
                    extend: [
                        identify(),
                        light({
                            color: false,
                            colorTemp: {range: [150, 500]},
                    fromZigbee: [fz.on_off, fz.brightness, fz.level_config],
                    configure: async (device, coordinatorEndpoint, logger) => {
                        const endpoint = device.getEndpoint(11);
                        await endpoint.bind('genOnOff', coordinatorEndpoint);
                        await endpoint.bind('genLevelCtrl', coordinatorEndpoint);
                        await endpoint.bind('lightingColorCtrl', coordinatorEndpoint);
                Wenn ich in der Insance den mec.js converter entferne kommt kein Fehler. Nach wieder einbinden kommt folgender Fehler:
                zigbee.0
                	2025-11-21 08:50:46.428	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/mec.js - the code does not run: TypeError: identify is not a function
                Es hat denke irendetwas mit dem teil "extend:" im converter zu tun. Wenn ich z.B. die Funktion "identify()" entferne, kommt ein Fehler für die Funktion light.
                Ich hab mir auch schon etwas mit den Beispielen auseinandergesetzt aber so richtig steige ich da nicht durch.
                Der obere Fehler kommt auch erst seit dem letzten Update das ich gemacht habe.
                  AsgothianA Offline
                  Asgothian
                  Da wurde dann an den ZHC mal wieder was geaendert. Nimm mal bitte das identify(), bei extend raus. Dann verlierst du wahrscheinlich den DP 'identify', aber das sollte erstmal nicht schmerzen. vielleicht kann ich am WE schauen was da getan wurde.
                  A.
                    A.
                    Tobias 0
                    @Asgothian
                    Wenn ich identify() herauslösche kommt folgender fehler:
                    zigbee.0
                    	2025-11-21 10:35:16.757	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/mec.js - the code does not run: TypeError: light is not a function
                    Ohne die light() oder komplett extend: kommt dann folgendes:
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[2]: at async Promise.all (index 2)
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:105:5)
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[2]: at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77)
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'options')
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    host.IOBroker22
                    	2025-11-21 10:37:54.224	error	Caught by controller[1]: [2025-11-21T09:37:52.473Z] zh:adapter:zstack:manager: Extended PAN ID is reversed (expected=7456afdddddddddd, actual=ddddddddddaf5674)
                    zigbee.0
                    	2025-11-21 10:37:53.192	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:53.190	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:52.684	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:52.683	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:52.669	error	Cannot read properties of undefined (reading 'options')
                    zigbee.0
                    	2025-11-21 10:37:52.669	error	TypeError: Cannot read properties of undefined (reading 'options') at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77) at processTicksAndRejections (node:internal/process/task_queues:105:5) at async Promise.all (index 2)
                    zigbee.0
                    	2025-11-21 10:37:52.669	error	unhandled promise rejection: Cannot read properties of undefined (reading 'options')
                    zigbee.0
                    	2025-11-21 10:37:52.669	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    zigbee.0
                    	2025-11-21 10:37:52.668	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:52.666	error	DeviceConfigure:Failed to DeviceConfigure.onZigbeeStarted (finalDefinition.toZigbee is not iterable)
                    zigbee.0
                    	2025-11-21 10:37:52.639	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    zigbee.0
                    	2025-11-21 10:37:52.638	error	Resolve entity error: finalDefinition.toZigbee is not iterable
                    Ich denke es ist irgendwas in diesem extend: fehlerhaft bei mir was ich nicht nachvollziehen kann
                      AsgothianA Offline
                      Asgothian
                      muss ich mir heute abend anschauen - da fehlt wirklich was.
                      A.
                        AsgothianA Offline
                        Asgothian
                        Versuch mal bitte so:
                        const m = require('zigbee-herdsman-converters/lib/modernExtend');
                            extend: [
                                m.identify(),
                                m.light({
                                    color: false,
                              extend: [
                                  m.identify(),
                                  m.light({
                                      color: false,
                          Tobias 0
                          @Asgothian Hi, erst mal ein großes Dankeschön für deine Unterstützung.
                          Fehler beim Starten kommt jetzt ein anderer:
                          zigbee.0
                          	2025-11-29 15:12:48.479	error	converter does not export any converter array, please add 'module.exports' statement to /opt/iobroker/iobroker-data/zigbee_0/mec.js
                          Die erste Lampe, die ich mit deinem damaligen Code angelernt habe, funktioniert. Hier wird auch eine Änderung am Taster direkt an der Lampe schneller erkannt als früher.
                          Bei der zweiten Lampe, Baugleich zur ersten, komme ich auf keinen grünen Zweig. Hier ist es immer so, dass der Tastendruck nicht erkannt wird. Ich habe sich jetzt auch reconfigered und nochmals neu angelernt. Hat keine Auswirkung.
                          Was mir zusätulich aufgefallen ist: Nach dem Einfügen deines Vorschlagen von dem Teil:
                          wird die erste Lampe immer alle paar sekunden abgefragt. Die zweit Lampe nicht. Siehe Bild.
                          Ich weiß nicht wie ich besser unterstützen kann und freue benötige hier hilfe. Jetzt schonmal Danke
                            AsgothianA Offline
                            Asgothian
                            Stimmt. da fehlt am ende das
                            module.exports = definition;
                            statement im Converter
                              Tobias 0
                              @Asgothian Danke Fehler kommt keiner mehr.
                              sagte in L&S Beleuchtungssystem Zigbee unbekannt:
                              Dies bleibt. Kann es sein, dass das device.getEndpoint(11) nur auf einen Endpoint zeigt und nicht beide abfragen kann?
                              • T Tobias 0
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @Tobias-0 sagte in L&S Beleuchtungssystem Zigbee unbekannt:
                                Da musst du mich nochmal auf Stand bringen - soweit ich das quer gelesen habe beide L&S Lampen nur einen EP (11). genau der wird abgefragt.
                                Bitte die Lampe wenn der Konverter funktioniert nochmal über die Rückseite der Kachel konfigurieren.
                                A.
                                  Tobias 0
                                  ich hab letzte woche beide nochmals über die Kachel konfiguriert. Brachte keinen Unterschied.
                                  Als ich dieses Wochenende nochmals schaute gingen auf einmal beide Lampen wie sie sollten.
                                  Warum es nach einer Zeit ging kann ich nicht nachvollziehen.
                                  Bei Konfiguration über die Kachel bleibt es jetzt auch so.
                                  Somit funktioniert der Konverter.
                                  Nochmals herzlichen Danke
