  4. [gelöst] Problem beim Update
    6.5k
36 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • D DGR
    hier nochmal der Dateiinhalt von /etc/apt/sources.list.d/influxdata.list (s.o.)
    pi@raspi2:~ $ cat /etc/apt/sources.list.d/influxdata.list
    deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main
    pi@raspi2:~ $
    weitere Dateien influxdata.list gibt es nicht (s.o.), ausser natürlich in der Datensicherung.
    pi@raspi2:~ $ ls -lA /etc/apt/sources.list.d/
    insgesamt 20
    -rw-r--r-- 1 root root  82  2. Nov 12:13 grafana.list
    -rw-r--r-- 1 root root 107 18. Jul 20:25 influxdata.list
    -rw-r--r-- 1 root root 113  4. Dez 2024  influxdb.list
    -rw-r--r-- 1 root root 100  1. Nov 23:11 nodesource.list
    -rw-r--r-- 1 root root 191 19. Nov 2024  raspi.list
    pi@raspi2:~ $ ls -lA /usr/share/keyrings/
    insgesamt 240
    -rw-r--r-- 1 root root  8700 10. Apr 2025  debian-archive-bookworm-automatic.gpg
    -rw-r--r-- 1 root root  8709 10. Apr 2025  debian-archive-bookworm-security-automatic.gpg
    -rw-r--r-- 1 root root   280 10. Apr 2025  debian-archive-bookworm-stable.gpg
    -rw-r--r-- 1 root root  8700 10. Apr 2025  debian-archive-bullseye-automatic.gpg
    -rw-r--r-- 1 root root  8709 10. Apr 2025  debian-archive-bullseye-security-automatic.gpg
    -rw-r--r-- 1 root root  2453 10. Apr 2025  debian-archive-bullseye-stable.gpg
    -rw-r--r-- 1 root root 55918 10. Apr 2025  debian-archive-keyring.gpg
    -rw-r--r-- 1 root root 72636 10. Apr 2025  debian-archive-removed-keys.gpg
    -rw-r--r-- 1 root root  8698 10. Apr 2025  debian-archive-trixie-automatic.gpg
    -rw-r--r-- 1 root root  8707 10. Apr 2025  debian-archive-trixie-security-automatic.gpg
    -rw-r--r-- 1 root root   962 10. Apr 2025  debian-archive-trixie-stable.gpg
    -rw-r--r-- 1 root root  2370 18. Jul 20:25 influxdata-archive_compat.gpg
    -rw-r--r-- 1 root root  4516 18. Jul 20:25 influxdata-archive.gpg
    -rw-r--r-- 1 root root  2847  4. Dez 2024  influxdb-archive-keyring.gpg
    -rw-r--r-- 1 root root  1185  1. Nov 22:50 nodesource.gpg
    -rw-r--r-- 1 root root  1183 13. Jan 2022  raspberrypi-archive-keyring.gpg
    -rw-r--r-- 1 root root     0 13. Jan 2022  raspberrypi-archive-removed-keys.gpg
    -rw-r--r-- 1 root root  1183 13. Jan 2022  raspberrypi-archive-stable.gpg
    pi@raspi2:~ $
    Was bedeutet "insgesamt xx"? gibt es noch vertseckte Dateien ?
    @DGR sagte in Problem beim Update:
    influxdb.list
    sudo rm /etc/apt/sources.list.d/influxdb.list
    sudo apt update
    sudo apt full-upgrade
    Anschließend
    sudo rm /usr/share/keyrings/influxdb-archive-keyring.gpg
    Edit: Falls es zu Rückfragen kommen sollte, dass neue Dateien einen anderen Inhalt haben und welche übernommen werden soll, nimm die Version vom Paketersteller. Hintergrund:
    Influxdb bringt nun ein eigenes Paket mit den Schlüsseln mit und hält die dann künftig darüber aktuell.
    • MartinPM Online
      MartinPM Online
      MartinP
      Du hast bei einem der vorigen Updates wahrscheinlich eine falsche Entscheidung getroffen ...
      Der Ablageort für die Signatur und wahrscheinlich auch der Inhalt der Signaturdatei hat sich für das influx2 Repository geändert ...
      Beim ersten Mal wird man gefragt, ob man seinen generischen Kram behalten will, oder die neue Version herunterladen und verwenden ...
      Gibt schon einen weiteren Thread zum Thema ...
      https://forum.iobroker.net/topic/82949/sudo-apt-full-upgrade-mit-medung/3?_=1763632575382
        influxdb.list
        sudo apt update
        Anschließend
        DGR
        @Thomas-Braun
        Beides ist ohne Problem durchgelaufen. Könnte ich jetzt einen neuen Versuch starten mit
        sudo apt update -y && sudo apt upgrade -y && sudo apt-get dist-upgrade
        • MartinPM MartinP
          DGR
          @MartinP
          das kann ich leider nicht ausschließen. Werde mir den Link mal ansehen.
          • D DGR
            @Thomas-Braun
            Der Befehl ist Quatsch.
            sudo apt update
            • D DGR
              pi@raspi2:~ $
              insgesamt 20
              insgesamt 240
              pi@raspi2:~ $
              Das ist die Anzahl an Blöcken, die die Dateien aus diesem Verzeichnis auf dem Datenträger einnehmen, nicht die Anzahl an Dateien.
              Versteckte Dateien gibt es aber auch mindestens zwei in dem Verzeichnis. Könnte man per
              ls -la
              sehen.
                DGR
                pi@raspi2:~ $ sudo apt update
                OK:1 http://archive.raspberrypi.com/debian bookworm InRelease
                OK:2 http://deb.debian.org/debian bookworm InRelease
                OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                OK:4 http://deb.debian.org/debian bookworm-updates InRelease
                OK:5 https://apt.grafana.com stable InRelease
                OK:6 https://deb.nodesource.com/node_22.x nodistro InRelease
                OK:7 https://repos.influxdata.com/debian stable InRelease
                Alle Pakete sind aktuell.
                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                  libcamera0.3 libcamera0.4 libdlt2 libdrm-nouveau2 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi
                  linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt rpicam-apps-lite
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                pi@raspi2:~ $
                Hat sich das Update für influx damit erledigt ?
                • MartinPM Online
                  MartinPM Online
                  MartinP
                  Das empfohlene "sudo apt autoremove" könntest Du noch machen, verschafft ein wenig Platz auf der Platte ...
                  • D DGR
                    pi@raspi2:~ $
                    sudo apt autoremove
                    PAGER= apt policy influx*
                      sudo apt autoremove
                      DGR
                      @Thomas-Braun sagte in Problem beim Update:
                      sudo apt autoremove
                      pi@raspi2:~ $ sudo apt autoremove
                      N: Paket influxdb2-client-2.3.0-linux-arm64.tar.gz kann nicht gefunden werden.
                      N: Mittels des Musters »influxdb2-client-2.3.0-linux-arm64.tar.gz« konnte kein Paket gefunden werden.
                      pi@raspi2:~ $
                      • MartinPM MartinP
                        DGR
                        @MartinP
                        pi@raspi2:~ $ sudo apt autoremove libcamera0.3
                        Die folgenden Pakete werden ENTFERNT:
                        0 aktualisiert, 0 neu installiert, 15 zu entfernen und 0 nicht aktualisiert.
                        Nach dieser Operation werden 256 MB Plattenplatz freigegeben.
                        Möchten Sie fortfahren? [J/n] j
                        (Lese Datenbank ... 148522 Dateien und Verzeichnisse sind derzeit installiert.)
                        Entfernen von libcamera0.3:arm64 (0.3.2+rpt20241119-1) ...
                        Entfernen von libcamera0.4:arm64 (0.4.0+rpt20250213-1) ...
                        Entfernen von libdlt2:arm64 (2.18.8-6) ...
                        Entfernen von libdrm-nouveau2:arm64 (2.4.123-1~bpo12+1+rpt1) ...
                        Entfernen von linux-headers-6.12.20+rpt-common-rpi (1:6.12.20-1+rpt1~bpo12+1) ...
                        Entfernen von linux-headers-6.12.25+rpt-common-rpi (1:6.12.25-1+rpt1) ...
                        Entfernen von linux-headers-6.6.51+rpt-common-rpi (1:6.6.51-1+rpt3) ...
                        Entfernen von linux-headers-6.6.62+rpt-common-rpi (1:6.6.62-1+rpt1) ...
                        Entfernen von linux-headers-6.6.74+rpt-common-rpi (1:6.6.74-1+rpt1) ...
                        Entfernen von linux-kbuild-6.12.20+rpt (1:6.12.20-1+rpt1~bpo12+1) ...
                        Entfernen von linux-kbuild-6.12.25+rpt (1:6.12.25-1+rpt1) ...
                        Entfernen von linux-kbuild-6.6.51+rpt (1:6.6.51-1+rpt3) ...
                        Entfernen von linux-kbuild-6.6.62+rpt (1:6.6.62-1+rpt1) ...
                        Entfernen von linux-kbuild-6.6.74+rpt (1:6.6.74-1+rpt1) ...
                        Entfernen von rpicam-apps-lite (1.9.0-1~bpo12+1) ...
                        Trigger für libc-bin (2.36-9+rpt2+deb12u13) werden verarbeitet ...
                        pi@raspi2:~
                        • D DGR
                          sudo apt autoremove
                          pi@raspi2:~ $
                          Warum liegt da diese Datei herum? Sowas wird nicht von Hand in das System geprügelt, dafür gibt es den Paketmanager...
                          rm influxdb2-client-2.3.0-linux-arm64.tar.gz
                          Dann nochmal
                            DGR
                            pi@raspi2:~ $ rm influxdb2-client-2.3.0-linux-arm64.tar.gz
                            pi@raspi2:~ $ PAGER= apt policy influx*
                            influxdb2-cli:
                              Installiert:           2.7.5-2
                              Installationskandidat: 2.7.5-2
                              Versionstabelle:
                             *** 2.7.5-2 500
                                    500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                 2.7.5-1 500
                                 2.7.3-1 500
                                 2.7.1-2 500
                                 2.6.1 500
                                 2.6.0 500
                                 2.5.0 500
                                 2.4.0 500
                                 2.3.0 500
                            influxdb-client:
                              Installiert:           (keine)
                              Installationskandidat: 1.6.7~rc0-1+b13
                              Versionstabelle:
                                 1.6.7~rc0-1+b13 500
                                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
                            influxdb3-enterprise:
                              Installationskandidat: 3.6.0-2
                              Versionstabelle:
                                 3.6.0-2 500
                                 3.6.0-1 500
                                 3.5.0-1 500
                                 3.4.2-1 500
                                 3.4.1-1 500
                                 3.4.0-1 500
                                 3.3.0-1 500
                                 3.2.1-1 500
                                 3.2.0-1 500
                                 3.1.0-1 500
                                 3.0.3-1 500
                                 3.0.2-1 500
                                 3.0.1-1 500
                            influxdb-dev:
                              Installationskandidat: (keine)
                              Versionstabelle:
                            influxdb3-core:
                              Versionstabelle:
                                 3.6.0-2 500
                                 3.6.0-1 500
                                 3.5.0-1 500
                                 3.4.2-1 500
                                 3.4.1-1 500
                                 3.4.0-1 500
                                 3.3.0-1 500
                                 3.2.1-1 500
                                 3.2.0-1 500
                                 3.1.0-1 500
                                 3.0.3-1 500
                                 3.0.2-1 500
                                 3.0.1-1 500
                            influxdata-archive-keyring:
                              Installiert:           2025.07.18
                              Installationskandidat: 2025.07.18
                              Versionstabelle:
                             *** 2025.07.18 500
                                    500 https://repos.influxdata.com/debian stable/main armhf Packages
                            influxdb2-client:
                              Installationskandidat: 2.7.1-1
                              Versionstabelle:
                                 2.7.1-1 500
                            influxdb:
                              Installationskandidat: 1.12.2-3
                              Versionstabelle:
                                 1.12.2-3 500
                                 1.12.2-1 500
                                 1.11.8-2 500
                                 1.11.8-1 500
                                 1.11.7-1 500
                                 1.8.10-1 500
                                 1.6.7~rc0-1+b13 500
                            influxctl:
                              Installationskandidat: 2.11.0-2
                              Versionstabelle:
                                 2.11.0-2 500
                                 2.11.0 500
                                 2.10.5 500
                                 2.10.4 500
                                 2.10.3 500
                                 2.10.2 500
                                 2.10.1 500
                                 2.10.0 500
                                 2.9.9 500
                                 2.9.8 500
                                 2.9.7 500
                                 2.9.6 500
                                 2.9.5 500
                                 2.9.4 500
                                 2.9.3 500
                                 2.9.2 500
                                 2.9.1 500
                                 2.9.0 500
                                 2.8.0 500
                                 2.7.1 500
                                 2.7.0 500
                                 2.6.0 500
                                 2.5.0 500
                                 2.4.4 500
                                 2.4.3 500
                                 2.4.2 500
                                 2.4.1 500
                                 2.4.0 500
                                 2.3.1 500
                                 2.3.0 500
                                 2.2.0 500
                                 2.1.0 500
                                 2.0.4 500
                                 2.0.3 500
                                 2.0.2 500
                                 2.0.1 500
                                 2.0.0 500
                            influxdb2:
                              Installiert:           2.7.12-2
                              Installationskandidat: 2.7.12-2
                              Versionstabelle:
                             *** 2.7.12-2 500
                                 2.7.12-1 500
                                 2.7.11-1 500
                                 2.7.10-1 500
                                 2.7.9-1 500
                                 2.7.8-1 500
                                 2.7.7-1 500
                                 2.7.6-1 500
                                 2.7.5-1 500
                                 2.7.4-1 500
                                 2.7.3-1 500
                                 2.7.1-1 500
                                 2.7.0-1 500
                                 2.6.1-1 500
                                 2.6.0-1 500
                                 2.5.1-1 500
                                 2.4.0-1 500
                                 2.3.0-1 500
                                 2.2.0 500
                            pi@raspi2:~ $
                            t
                            • D DGR
                              influxdb2-cli:
                                Versionstabelle:
                               *** 2.7.5-2 500
                                   2.7.5-1 500
                                   2.7.3-1 500
                                   2.7.1-2 500
                                   2.6.1 500
                                   2.6.0 500
                                   2.5.0 500
                                   2.4.0 500
                                   2.3.0 500
                              influxdb-client:
                                Versionstabelle:
                                   1.6.7~rc0-1+b13 500
                                Versionstabelle:
                                   3.6.0-2 500
                                   3.6.0-1 500
                                   3.5.0-1 500
                                   3.4.2-1 500
                                   3.4.1-1 500
                                   3.4.0-1 500
                                   3.3.0-1 500
                                   3.2.1-1 500
                                   3.2.0-1 500
                                   3.1.0-1 500
                                   3.0.3-1 500
                                   3.0.2-1 500
                                   3.0.1-1 500
                              influxdb-dev:
                                Versionstabelle:
                              influxdb3-core:
                                Versionstabelle:
                                   3.6.0-2 500
                                   3.6.0-1 500
                                   3.5.0-1 500
                                   3.4.2-1 500
                                   3.4.1-1 500
                                   3.4.0-1 500
                                   3.3.0-1 500
                                   3.2.1-1 500
                                   3.2.0-1 500
                                   3.1.0-1 500
                                   3.0.3-1 500
                                   3.0.2-1 500
                                   3.0.1-1 500
                                Versionstabelle:
                               *** 2025.07.18 500
                              influxdb2-client:
                                Versionstabelle:
                                   2.7.1-1 500
                              influxdb:
                                Versionstabelle:
                                   1.12.2-3 500
                                   1.12.2-1 500
                                   1.11.8-2 500
                                   1.11.8-1 500
                                   1.11.7-1 500
                                   1.8.10-1 500
                                   1.6.7~rc0-1+b13 500
                              influxctl:
                                Versionstabelle:
                                   2.11.0-2 500
                                   2.11.0 500
                                   2.10.5 500
                                   2.10.4 500
                                   2.10.3 500
                                   2.10.2 500
                                   2.10.1 500
                                   2.10.0 500
                                   2.9.9 500
                                   2.9.8 500
                                   2.9.7 500
                                   2.9.6 500
                                   2.9.5 500
                                   2.9.4 500
                                   2.9.3 500
                                   2.9.2 500
                                   2.9.1 500
                                   2.9.0 500
                                   2.8.0 500
                                   2.7.1 500
                                   2.7.0 500
                                   2.6.0 500
                                   2.5.0 500
                                   2.4.4 500
                                   2.4.3 500
                                   2.4.2 500
                                   2.4.1 500
                                   2.4.0 500
                                   2.3.1 500
                                   2.3.0 500
                                   2.2.0 500
                                   2.1.0 500
                                   2.0.4 500
                                   2.0.3 500
                                   2.0.2 500
                                   2.0.1 500
                                   2.0.0 500
                              influxdb2:
                                Versionstabelle:
                               *** 2.7.12-2 500
                                   2.7.12-1 500
                                   2.7.11-1 500
                                   2.7.10-1 500
                                   2.7.9-1 500
                                   2.7.8-1 500
                                   2.7.7-1 500
                                   2.7.6-1 500
                                   2.7.5-1 500
                                   2.7.4-1 500
                                   2.7.3-1 500
                                   2.7.1-1 500
                                   2.7.0-1 500
                                   2.6.1-1 500
                                   2.6.0-1 500
                                   2.5.1-1 500
                                   2.4.0-1 500
                                   2.3.0-1 500
                                   2.2.0 500
                              pi@raspi2:~ $
                              t
                              @DGR
                              Jetzt passt es wohl.
                                DGR
                                schrieb am zuletzt editiert von DGR
                                Vielen Dank.
                                Würde gerne auf "gelöst" setzen, aber wo ?
                                • D DGR
                                  Vielen Dank.
                                  Den Threadtitel entsprechend ergänzen.
                                  • MartinPM Online
                                    MartinPM Online
                                    MartinP
                                    Hmm angeregt durch diesen Thread habe ich geschaut, was es bei meinem System für Influx Keys gibt .... ich vermute, die sind beide notwendig?
                                    martin@iobroker-test-sicher:/usr/share/keyrings$ ls -l inf*
                                    -rw-r--r-- 1 root root 4516 Jul 18 20:25 influxdata-archive.gpg
                                    -rw-r--r-- 1 root root 2370 Jul 18 20:25 influxdata-archive_compat.gpg
                                    "influxdata-archive-keyring.gpg" habe ich nicht ...
                                    Offtopic: Ein von einem bösen Akteur untergejubelter keyring wäre ja eine Sicherheitslücke, oder?
                                    • MartinPM MartinP
                                      @MartinP
                                      dpkg -L influxdata-archive-keyring
                                      zeigt dir die Dateien, die aus dem entsprechenden Paket stammen.
                                      Ja, deswegen sind die Pakete selber auch signiert. Wenn man die Schlüssel von Hand reinlädt kann man die auch prüfen.
                                      Wird aber in den meisten Anleitungen zugegebenermaßen nicht gemacht, auch nicht in den 'Phantastischen Repos'.
                                      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                      Edit:
                                      Näheres findet sich in der ReadMe:
                                      /usr/share/doc/influxdata-archive-keyring/README
                                      • MartinPM Online
                                        MartinPM Online
                                        MartinP
                                        Wenn ich den Output richtig interpretiere, gibt es nur die beiden gpg-Dateien, und die sind Authentisch..
                                        martin@iobroker-test-sicher:/usr/share/keyrings$ dpkg -L influxdata-archive-keyring
                                        /usr
                                        /usr/share
                                        /usr/share/doc
                                        /usr/share/doc/influxdata-archive-keyring/changelog.gz
                                        /usr/share/doc/influxdata-archive-keyring/copyright
                                        /usr/share/influxdata-archive-keyring
                                        /usr/share/influxdata-archive-keyring/influxdata.list-http
                                        /usr/share/influxdata-archive-keyring/influxdata.list-http_compat
                                        /usr/share/influxdata-archive-keyring/influxdata.list-https
                                        /usr/share/influxdata-archive-keyring/influxdata.list-https_compat
                                        /usr/share/keyrings
                                        /usr/share/keyrings/influxdata-archive_compat.gpg
                                          searcher57
                                          Ich muss mich mit meiner Dummheit auch hier melden. Ich habe aus Unerfahrenheit in der Konsole den Befehl "sudo rm Influx**" eingegeben, um Platz auf dem Raspi zu machen. Seit dem bekomme ich die Meldung:
                                          pi@Raspi58GB:~ $ sudo apt update
                                          E: Widersprüchliche Werte gesetzt für Option Signed-By betreffend die Quelle https://repos.influxdata.com/debian/ stable: /usr/share/keyrings/influxdata-archive.gpg != /usr/share/keyrings/influxdata-archive_compat.gpg
                                          E: Die Liste der Quellen konnte nicht gelesen werden.
                                          Asche über mein Haupt!
