  4. **gelöst** Problem mit Tuya Steckdose
    6.1k
4 Beiträge 2 Kommentatoren 396 Aufrufe 1 Beobachtet
  • spicerS Offline
    spicerS Offline
    spicer
    schrieb am zuletzt editiert von spicer
    Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
    • Adaptername: tuya
    • Adapterversion: 3.16.0
    • js-controller Version: 7.0.7
    • Admin Version: 7.7.19
    • Hardwaresystem: N150 mit Proxmox (lxc)
    • Arbeitsspeicher: 16GB
    • Festplattenart: SSD
    • Betriebssystem: Debian
    • Nodejs-Version: 20.19.5
    • NPM-Version: 10.8.2
    • Installationsart: Blockly
    • Image, Docker genutzt: Nein
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    • Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-16-pve
        Architecture: x86-64
    OS is similar to:
    model name	: Intel(R) N150
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:39:32 up 17 days, 20:06,  2 users,  load average: 0.76, 0.63, 0.63
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-11-16 19:39:32 CET
               Universal time: Sun 2025-11-16 18:39:32 UTC
                     RTC time: n/a
                    Time zone: Europe/Zurich (CET, +0100)
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.6G        1.7G        5.3G        217K        1.6G        6.9G
    Swap:           2.1G         16K        2.1G
    Total:           10G        1.7G        7.4G
    Active iob-Instances: 	13
             8192 M total memory
             1611 M used memory
             1651 M active memory
             1350 M inactive memory
             5019 M free memory
                0 M buffer memory
             1561 M swap cache
             2048 M total swap
                0 M used swap
             2047 M free swap
    top - 19:39:33 up 17 days, 20:06,  2 users,  load average: 0.76, 0.63, 0.63
    Tasks:  49 total,   1 running,  48 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   5018.0 free,   1612.8 used,   1561.4 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6579.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       63G  5.8G   54G  10% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.4G	/var/
    995M	/var/log
    994M	/var/log/journal/aafe2ae9f133463dbcf272f37ebae82d
    254M	/var/cache
    Archived and active journals take up 143.0M in the file system.
    /opt/iobroker/backups:
    147M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    474M	/opt/iobroker/iobroker-data/
    326M	/opt/iobroker/iobroker-data/files
    110M	/opt/iobroker/iobroker-data/backup-objects
    67M	/opt/iobroker/iobroker-data/files/echarts.admin
    61M	/opt/iobroker/iobroker-data/files/echarts
    33M	/opt/iobroker/iobroker-data/objects.jsonl
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.5
    /usr/bin/node 		v20.19.5
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 1541204)
    Core adapters versions
    js-controller: 	7.0.7
    admin: 		7.7.19
    javascript: 	8.9.2
    nodejs modules from github: 	1
    +-- iobroker.sofarcloud@3.2.7 (git+ssh://git@github.com/ltspicer/ioBroker.sofarcloud.git#2808eb7f1b469ef68f459d943e6eccfec3abf731)
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.email.0                  : email                 : iobroker                                 - disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.heizoel24-mex.0          : heizoel24-mex         : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.sofarcloud.0             : sofarcloud            : iobroker                                 -  enabled
      system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weathersense.0           : weathersense          : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "heizoel24-mex": 1.5.0    , installed 1.5.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "shelly"       : 10.4.0   , installed 10.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sofarcloud"   : 3.2.7    , installed 3.2.7
    Adapter    "solarmanpv"   : 0.7.1    , installed 0.7.1
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "weathersense" : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects: 	12111
    States: 	11367
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:444             0.0.0.0:*               LISTEN      0          10965      166/nginx: master p
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10700      1/init
    tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      0          10964      166/nginx: master p
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          10962      166/nginx: master p
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13150      434/io.mqtt.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8139       130/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8130       130/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8077       302/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10845      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10702      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          10963      166/nginx: master p
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8078       302/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21798      380/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9296096    121136/io.admin.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22080      490/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22081      490/io.tuya.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10701      1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13040      394/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          10703      1/init
    udp6       0      0 :::1900                 :::*                                1001       13042      394/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       13041      394/io.deconz.0
    2025-11-16 19:40:12.648  - info: mqtt.1 (434) Client [mosqpub|13849-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:12.740  - info: mqtt.1 (434) Client [mosqpub|13851-Dachrollo] connected with secret 1763318412740_8062
    2025-11-16 19:40:12.743  - info: mqtt.1 (434) Client [mosqpub|13851-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:12.838  - info: mqtt.1 (434) Client [mosqpub|13853-Dachrollo] connected with secret 1763318412837_5747
    2025-11-16 19:40:12.841  - info: mqtt.1 (434) Client [mosqpub|13853-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:12.932  - info: mqtt.1 (434) Client [mosqpub|13855-Dachrollo] connected with secret 1763318412931_8439
    2025-11-16 19:40:12.935  - info: mqtt.1 (434) Client [mosqpub|13855-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.027  - info: mqtt.1 (434) Client [mosqpub|13857-Dachrollo] connected with secret 1763318413026_8000
    2025-11-16 19:40:13.030  - info: mqtt.1 (434) Client [mosqpub|13857-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.125  - info: mqtt.1 (434) Client [mosqpub|13859-Dachrollo] connected with secret 1763318413124_7659
    2025-11-16 19:40:13.128  - info: mqtt.1 (434) Client [mosqpub|13859-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.234  - info: mqtt.1 (434) Client [mosqpub|13861-Dachrollo] connected with secret 1763318413233_1258
    2025-11-16 19:40:13.237  - info: mqtt.1 (434) Client [mosqpub|13861-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.330  - info: mqtt.1 (434) Client [mosqpub|13863-Dachrollo] connected with secret 1763318413329_2769
    2025-11-16 19:40:13.333  - info: mqtt.1 (434) Client [mosqpub|13863-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.427  - info: mqtt.1 (434) Client [mosqpub|13865-Dachrollo] connected with secret 1763318413427_5438
    2025-11-16 19:40:13.431  - info: mqtt.1 (434) Client [mosqpub|13865-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.526  - info: mqtt.1 (434) Client [mosqpub|13867-Dachrollo] connected with secret 1763318413526_4292
    2025-11-16 19:40:13.530  - info: mqtt.1 (434) Client [mosqpub|13867-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:13.624  - info: mqtt.1 (434) Client [mosqpub|13869-Dachrollo] connected with secret 1763318413623_9943
    2025-11-16 19:40:13.628  - info: mqtt.1 (434) Client [mosqpub|13869-Dachrollo] connection closed: disconnected
    2025-11-16 19:40:26.036  - info: host.iobroker instance system.adapter.sofarcloud.0 in version "3.2.7" (non-npm: ltspicer/ioBroker.sofarcloud) started with pid 780339
    2025-11-16 19:40:30.418  - info: sofarcloud.0 (780339) starting. Version 3.2.7 (non-npm: ltspicer/ioBroker.sofarcloud) in /opt/iobroker/node_modules/iobroker.sofarcloud, node: v20.19.5, js-controller: 7.0.7
    2025-11-16 19:40:30.590  - info: sofarcloud.0 (780339) Start cloud query after 156 seconds...
    2025-11-16 19:40:52.043  - info: host.iobroker instance system.adapter.weathersense.0 in version "3.0.3" started with pid 780951
    iob diag has finished.
    Hi, habe ein merkwürdiges Verhalten einer Tuya Smartsteckdose festgestellt.
    Wenn ich den Schalterzustand direkt in "Objekte" ändere, ist alles ok.
    Wenn mein Blockly diesen ändert, fällt der Zustand nach 15s wieder auf den vorherigen Wert zurück.
    Habe das Blockly sogar veranlasst, den Zustand eine Stunde lang alle 2min zu setzen.
    Eine andere Tuya Steckdose anderen Modells (ohne Energiezähler) funktioniert aber tadellos.
    Was läuft da schief?
    Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
    (Murphys Gesetz)
    • spicerS spicer
      • Adaptername: tuya
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:           2.1G         16K        2.1G
               8192 M total memory
               1611 M used memory
               5019 M free memory
                  0 M buffer memory
               1561 M swap cache
               2048 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      1.4G	/var/
      995M	/var/log
      254M	/var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.7.19
      javascript: 	8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	12111
      States: 	11367
      Pending Updates: 1
      @spicer said: Was läuft da schief?
      Block "steuere" anstelle von "aktualisiere" verwenden!
      EDIT: Einfacher:
      spicerS 1 Antwort Letzte Antwort
        EDIT: Einfacher:
        spicerS Offline
        spicerS Offline
        spicer
        Gute Idee. Werd ich um 23 Uhr sehn ;)
        (Murphys Gesetz)
        • spicerS Offline
          spicerS Offline
          spicer
          Scheint zu klappen. Vielen Dank
          (Murphys Gesetz)
