  4. Zigbee Garagentoröffner PJ-ZGD01 fehlerhaft
    6.1k
35 Beiträge 3 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • throstenkT throstenk
    @asgothian ich hab alles durchgeführt hier das log
    2025-09-05 10:08:49.838	info	Adapter ready - starting subsystems. Adapter is running in info mode.
    zigbee.0
    2025-09-05 10:08:49.842	warn	External converter not loaded - neither pj-zgd01-custom.js nor /opt/iobroker/iobroker-data/zigbee_0/pj-zgd01-custom.js exist.
    zigbee.0
    2025-09-05 10:08:49.844	info	init localConfig
    zigbee.0
    2025-09-05 10:08:49.938	info	delete old Backup files. keep only last 10
    zigbee.0
    2025-09-05 10:08:49.942	info	--- creating device debug ---
    zigbee.0
    2025-09-05 10:08:49.943	info	Autostart Zigbee subsystem
    zigbee.0
    2025-09-05 10:08:49.944	info	Starting Adapter npm ...
    zigbee.0
    2025-09-05 10:08:49.980	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    zigbee.0
    2025-09-05 10:08:49.983	info	configured transmit power : high+
    zigbee.0
    2025-09-05 10:08:49.984	info	Starting Zigbee-Herdsman
    zigbee.0
    2025-09-05 10:08:50.612	info	Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20230507 (2-1.2.7.1)
    zigbee.0
    2025-09-05 10:08:50.615	info	Unable to disable LED, unsupported function.
    zigbee.0
    2025-09-05 10:08:51.060	info	0xa4c1387b9ff002f5 (addr 64535): ZG-227ZL - Tuya Temperature & humidity LCD sensor (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.088	info	0xa4c138e52ab62222 (addr 42053): ZG-227Z - HOBEIAN Temperature and humidity sensor (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.110	info	0xa4c138aff2ffb35b (addr 4828): WSD500A - Tuya Temperature & humidity sensor (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.121	info	0xa4c1383f7cd84f1f (addr 61844): PJ-ZGD01 - Tuya Garage door opener (Router)
    zigbee.0
    2025-09-05 10:08:51.155	info	0x00124b002918fa55 (addr 46494): SNZB-01 - SONOFF Wireless button (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.166	info	0xa4c1385a489543a6 (addr 54188): PJ-ZGD01 - Tuya Garage door opener (Router)
    zigbee.0
    2025-09-05 10:08:51.219	info	0x5cc7c1fffe62a716 (addr 20148): E2213 - IKEA SOMRIG shortcut button (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.234	info	0xa4c138b1244a2326 (addr 46407): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    zigbee.0
    2025-09-05 10:08:51.241	info	0xa4c1387338f78959 (addr 49783): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    zigbee.0
    2025-09-05 10:08:51.245	info	0xf082c0fffe6ca5a8 (addr 8499): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.254	info	0xa4c1383f1cbae5ee (addr 37143): L1(ZW) - Tuya Light dimmer 0-10V (Router)
    zigbee.0
    2025-09-05 10:08:51.262	info	0xa4c1382a7889262d (addr 32217): L1(ZW) - Tuya Light dimmer 0-10V (Router)
    zigbee.0
    2025-09-05 10:08:51.266	info	0xa4c138c2cceb5a5f (addr 51405): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.271	info	0x3410f4fffede8b53 (addr 21993): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.274	info	0x60b647fffecdcec4 (addr 15162): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.277	info	0xa4c1382f936bc19b (addr 15549): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.281	info	0xa4c138cb00b82a17 (addr 25534): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.288	info	0xa4c138f4a38a40f2 (addr 54321): ZG-204ZL - Tuya Luminance motion sensor (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.291	info	0xe406bffffe3911c7 (addr 47674): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
    zigbee.0
    2025-09-05 10:08:51.292	info	Currently 19 devices are joined:
    zigbee.0
    2025-09-05 10:08:51.296	info	Zigbee started
    zigbee.0
    2025-09-05 10:08:51.365	info	DeviceConfigure 0xa4c138e52ab62222 ZG-227Z needed - Device added to Configuration Queue
    zigbee.0
    2025-09-05 10:08:51.378	info	DeviceConfigure 0x00124b002918fa55 SNZB-01 needed - Device added to Configuration Queue
    zigbee.0
    2025-09-05 10:08:52.134	info	debug devices set to []
    zigbee.0
    2025-09-05 10:08:52.987	info	downloading https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png to /tmp/L1(ZW).png
    zigbee.0
    2025-09-05 10:08:53.617	warn	ERROR : icon path not found /tmp/L1(ZW).png
    zigbee.0
    2025-09-05 10:08:56.367	info	DeviceConfigureQueue configuring 0xa4c138e52ab62222 TS0601
    zigbee.0
    2025-09-05 10:08:56.370	info	Configuring 0xa4c138e52ab62222 ZG-227Z
    zigbee.0
    2025-09-05 10:09:01.367	info	DeviceConfigureQueue configuring 0x00124b002918fa55 WB01
    zigbee.0
    2025-09-05 10:09:01.368	info	Configuring 0x00124b002918fa55 SNZB-01
    zigbee.0
    2025-09-05 10:09:06.368	info	Handled all devices Queued for configuration.
    zigbee.0
    2025-09-05 10:09:11.583	info	Timeout trying to configure 0x00124b002918fa55 SNZB-01 (starting CoM).
    zigbee.0
    2025-09-05 10:09:20.594	warn	DeviceConfigure:0xa4c138e52ab62222 TS0601 Failed to configure. --> ZCL command 0xa4c138e52ab62222/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @throstenk copy paste Fehler - der Dateiname den du genommen hast und der name den du eingetragen hast stimmt nicht überein:
    A.
    throstenkT 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      throstenkT Offline
      throstenkT Offline
      throstenk
      @asgothian jetzt ist ein error im log
      igbee.0
      2025-09-05 10:49:31.314	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.7
      zigbee.0
      2025-09-05 10:49:31.372	info	Adapter ready - starting subsystems. Adapter is running in info mode.
      zigbee.0
      2025-09-05 10:49:31.378	warn	trying to add "tuya = require(../zigbee-herdsman-converters/dist/lib/tuya)" to sandbox
      zigbee.0
      2025-09-05 10:49:31.396	error	converter does not export any converter array, please add 'module.exports' statement to /opt/iobroker/iobroker-data/zigbee_0/pj-zgd01_custom.js
      zigbee.0
      2025-09-05 10:49:31.398	info	Ignoring converter from module: /opt/iobroker/iobroker-data/zigbee_0/pj-zgd01_custom.js - see warn messages for reason
      zigbee.0
      2025-09-05 10:49:31.399	info	init localConfig
      zigbee.0
      2025-09-05 10:49:31.499	info	delete old Backup files. keep only last 10
      zigbee.0
      2025-09-05 10:49:31.503	info	--- creating device debug ---
      zigbee.0
      2025-09-05 10:49:31.504	info	Autostart Zigbee subsystem
      zigbee.0
      2025-09-05 10:49:31.506	info	Starting Adapter npm ...
      zigbee.0
      2025-09-05 10:49:31.549	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
      zigbee.0
      2025-09-05 10:49:31.552	info	configured transmit power : high+
      zigbee.0
      2025-09-05 10:49:31.553	info	Starting Zigbee-Herdsman
      zigbee.0
      2025-09-05 10:49:32.186	info	Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20230507 (2-1.2.7.1)
      zigbee.0
      2025-09-05 10:49:32.188	info	Unable to disable LED, unsupported function.
      zigbee.0
      2025-09-05 10:49:32.634	info	0xa4c1387b9ff002f5 (addr 64535): ZG-227ZL - Tuya Temperature & humidity LCD sensor (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.669	info	0xa4c138e52ab62222 (addr 42053): ZG-227Z - HOBEIAN Temperature and humidity sensor (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.692	info	0xa4c138aff2ffb35b (addr 4828): WSD500A - Tuya Temperature & humidity sensor (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.704	info	0xa4c1383f7cd84f1f (addr 61844): PJ-ZGD01 - Tuya Garage door opener (Router)
      zigbee.0
      2025-09-05 10:49:32.738	info	0x00124b002918fa55 (addr 46494): SNZB-01 - SONOFF Wireless button (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.759	info	0xa4c1385a489543a6 (addr 54188): PJ-ZGD01 - Tuya Garage door opener (Router)
      zigbee.0
      2025-09-05 10:49:32.810	info	0x5cc7c1fffe62a716 (addr 20148): E2213 - IKEA SOMRIG shortcut button (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.826	info	0xa4c138b1244a2326 (addr 46407): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      zigbee.0
      2025-09-05 10:49:32.832	info	0xa4c1387338f78959 (addr 49783): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      zigbee.0
      2025-09-05 10:49:32.837	info	0xf082c0fffe6ca5a8 (addr 8499): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.847	info	0xa4c1383f1cbae5ee (addr 37143): L1(ZW) - Tuya Light dimmer 0-10V (Router)
      zigbee.0
      2025-09-05 10:49:32.857	info	0xa4c1382a7889262d (addr 32217): L1(ZW) - Tuya Light dimmer 0-10V (Router)
      zigbee.0
      2025-09-05 10:49:32.862	info	0xa4c138c2cceb5a5f (addr 51405): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.867	info	0x3410f4fffede8b53 (addr 21993): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.871	info	0x60b647fffecdcec4 (addr 15162): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.874	info	0xa4c1382f936bc19b (addr 15549): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.876	info	0xa4c138cb00b82a17 (addr 25534): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.883	info	0xa4c138f4a38a40f2 (addr 54321): ZG-204ZL - Tuya Luminance motion sensor (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.885	info	0xe406bffffe3911c7 (addr 47674): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
      zigbee.0
      2025-09-05 10:49:32.886	info	Currently 19 devices are joined:
      zigbee.0
      2025-09-05 10:49:32.889	info	Zigbee started
      zigbee.0
      2025-09-05 10:49:32.952	info	DeviceConfigure 0xa4c138e52ab62222 ZG-227Z needed - Device added to Configuration Queue
      zigbee.0
      2025-09-05 10:49:32.965	info	DeviceConfigure 0x00124b002918fa55 SNZB-01 needed - Device added to Configuration Queue
      zigbee.0
      2025-09-05 10:49:33.757	info	debug devices set to []
      zigbee.0
      2025-09-05 10:49:34.690	info	downloading https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png to /tmp/L1(ZW).png
      zigbee.0
      2025-09-05 10:49:35.286	warn	ERROR : icon path not found /tmp/L1(ZW).png
      zigbee.0
      2025-09-05 10:49:37.954	info	DeviceConfigureQueue configuring 0xa4c138e52ab62222 TS0601
      zigbee.0
      2025-09-05 10:49:37.955	info	Configuring 0xa4c138e52ab62222 ZG-227Z
      zigbee.0
      2025-09-05 10:49:42.953	info	DeviceConfigureQueue configuring 0x00124b002918fa55 WB01
      zigbee.0
      2025-09-05 10:49:42.955	info	Configuring 0x00124b002918fa55 SNZB-01
      zigbee.0
      2025-09-05 10:49:47.953	info	Handled all devices Queued for configuration.
      zigbee.0
      2025-09-05 10:49:53.118	info	Timeout trying to configure 0x00124b002918fa55 SNZB-01 (starting CoM).
      zigbee.0
      2025-09-05 10:50:02.330	warn	DeviceConfigure:0xa4c138e52ab62222 TS0601 Failed to configure. --> ZCL command 0xa4c138e52ab62222/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
        igbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @throstenk ok.. ein Typo beim Kopieren:
        aus
        module.export definition;
        muss
        module.exports =  definition;
        werden (in der Datei)
        A.
          aus
          muss
          A.
          throstenkT Offline
          throstenkT Offline
          throstenk
          @asgothian hier das neue Log..
          zigbee.0
          2025-09-05 11:12:24.439	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.7
          zigbee.0
          2025-09-05 11:12:24.524	info	Adapter ready - starting subsystems. Adapter is running in info mode.
          zigbee.0
          2025-09-05 11:12:24.531	warn	trying to add "tuya = require(../zigbee-herdsman-converters/dist/lib/tuya)" to sandbox
          zigbee.0
          2025-09-05 11:12:24.555	warn	Trying to run sandbox for /opt/iobroker/iobroker-data/zigbee_0/pj-zgd01_custom.js
          zigbee.0
          2025-09-05 11:12:24.563	info	Model TS0601_garage_door_opener defined in external converter /opt/iobroker/iobroker-data/zigbee_0/pj-zgd01_custom.js
          zigbee.0
          2025-09-05 11:12:24.565	info	added external converter using addExternalDefinition (1 ms)
          zigbee.0
          2025-09-05 11:12:24.566	info	init localConfig
          zigbee.0
          2025-09-05 11:12:24.659	info	delete old Backup files. keep only last 10
          zigbee.0
          2025-09-05 11:12:24.664	info	--- creating device debug ---
          zigbee.0
          2025-09-05 11:12:24.665	info	Autostart Zigbee subsystem
          zigbee.0
          2025-09-05 11:12:24.667	info	Starting Adapter npm ...
          zigbee.0
          2025-09-05 11:12:24.703	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
          zigbee.0
          2025-09-05 11:12:24.705	info	configured transmit power : high+
          zigbee.0
          2025-09-05 11:12:24.706	info	Starting Zigbee-Herdsman
          zigbee.0
          2025-09-05 11:12:25.464	info	Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20230507 (2-1.2.7.1)
          zigbee.0
          2025-09-05 11:12:25.466	info	Unable to disable LED, unsupported function.
          zigbee.0
          2025-09-05 11:12:25.963	info	0xa4c1387b9ff002f5 (addr 64535): ZG-227ZL - Tuya Temperature & humidity LCD sensor (EndDevice)
          zigbee.0
          2025-09-05 11:12:25.979	info	0xa4c138e52ab62222 (addr 42053): ZG-227Z - HOBEIAN Temperature and humidity sensor (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.012	info	0xa4c138aff2ffb35b (addr 4828): WSD500A - Tuya Temperature & humidity sensor (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.024	info	0xa4c1383f7cd84f1f (addr 61844): TS0601_garage_door_opener - Tuya Garage door opener (Router)
          zigbee.0
          2025-09-05 11:12:26.058	info	0x00124b002918fa55 (addr 46494): SNZB-01 - SONOFF Wireless button (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.070	info	0xa4c1385a489543a6 (addr 54188): TS0601_garage_door_opener - Tuya Garage door opener (Router)
          zigbee.0
          2025-09-05 11:12:26.122	info	0x5cc7c1fffe62a716 (addr 20148): E2213 - IKEA SOMRIG shortcut button (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.142	info	0xa4c138b1244a2326 (addr 46407): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
          zigbee.0
          2025-09-05 11:12:26.162	info	0xa4c1387338f78959 (addr 49783): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
          zigbee.0
          2025-09-05 11:12:26.166	info	0xf082c0fffe6ca5a8 (addr 8499): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.175	info	0xa4c1383f1cbae5ee (addr 37143): L1(ZW) - Tuya Light dimmer 0-10V (Router)
          zigbee.0
          2025-09-05 11:12:26.182	info	0xa4c1382a7889262d (addr 32217): L1(ZW) - Tuya Light dimmer 0-10V (Router)
          zigbee.0
          2025-09-05 11:12:26.186	info	0xa4c138c2cceb5a5f (addr 51405): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.190	info	0x3410f4fffede8b53 (addr 21993): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.193	info	0x60b647fffecdcec4 (addr 15162): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.196	info	0xa4c1382f936bc19b (addr 15549): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.199	info	0xa4c138cb00b82a17 (addr 25534): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.205	info	0xa4c138f4a38a40f2 (addr 54321): ZG-204ZL - Tuya Luminance motion sensor (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.208	info	0xe406bffffe3911c7 (addr 47674): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
          zigbee.0
          2025-09-05 11:12:26.208	info	Currently 19 devices are joined:
          zigbee.0
          2025-09-05 11:12:26.211	info	Zigbee started
          zigbee.0
          2025-09-05 11:12:26.283	info	DeviceConfigure 0xa4c138e52ab62222 ZG-227Z needed - Device added to Configuration Queue
          zigbee.0
          2025-09-05 11:12:26.295	info	DeviceConfigure 0x00124b002918fa55 SNZB-01 needed - Device added to Configuration Queue
          zigbee.0
          2025-09-05 11:12:27.000	info	debug devices set to []
          zigbee.0
          2025-09-05 11:12:27.964	info	downloading https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png to /tmp/L1(ZW).png
          zigbee.0
          2025-09-05 11:12:28.523	warn	ERROR : icon path not found /tmp/L1(ZW).png
          zigbee.0
          2025-09-05 11:12:31.285	info	DeviceConfigureQueue configuring 0xa4c138e52ab62222 TS0601
          zigbee.0
          2025-09-05 11:12:31.287	info	Configuring 0xa4c138e52ab62222 ZG-227Z
          zigbee.0
          2025-09-05 11:12:36.286	info	DeviceConfigureQueue configuring 0x00124b002918fa55 WB01
          zigbee.0
          2025-09-05 11:12:36.287	info	Configuring 0x00124b002918fa55 SNZB-01
          zigbee.0
          2025-09-05 11:12:41.286	info	Handled all devices Queued for configuration.
          zigbee.0
          2025-09-05 11:12:46.469	info	Timeout trying to configure 0x00124b002918fa55 SNZB-01 (starting CoM).
          zigbee.0
          2025-09-05 11:12:55.929	warn	DeviceConfigure:0xa4c138e52ab62222 TS0601 Failed to configure. --> ZCL command 0xa4c138e52ab62222/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @throstenk damit wird der neu Konverter geladen. Jetzt bitte nochmal mit Device debug aktiv nen device_query
              throstenkT Offline
              throstenkT Offline
              throstenk
              @asgothian hier die letzten 5min
              zigbee.0
              2025-09-05 11:19:05.448	info	debug devices set to ["a4c1385a489543a6"]
              zigbee.0
              2025-09-05 11:19:21.616	warn	ELEVATED:I01 (5c0e) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":26880,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":91,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":236,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:19:21.623	warn	ELEVATED:I01 (5c0e) message received '{"linkquality":91}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:19:21.623	warn	ELEVATED:I02 (5c0e) value generated '91' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:19:22.540	warn	ELEVATED:O01 (5fac) User state change of state zigbee.0.a4c1385a489543a6.device_query with value true (ack: false) from system.adapter.admin.0
              zigbee.0
              2025-09-05 11:19:22.543	warn	ELEVATED:O02 (5fac) Change state 'device_query' at device 0xa4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:19:22.544	warn	ELEVATED:O03 (5fac) Publishing to 0xa4c1385a489543a6 of model TS0601_garage_door_opener with device_query
              zigbee.0
              2025-09-05 11:19:22.547	warn	ELEVATED:Occ (5fac) changed state: {"stateDesc":{"id":"device_query","prop":"device_query","name":"Trigger device query","role":"button","write":true,"read":false,"type":"boolean","isOption":true},"value":true,"index":0,"timeout":0,"source":"system.adapter.admin.0"}
              zigbee.0
              2025-09-05 11:19:22.547	warn	ELEVATED:Oqs (5fac) Device query for '0xa4c1385a489543a6/1' triggered
              zigbee.0
              2025-09-05 11:19:22.548	warn	ELEVATED:Oqe (5fac) ELEVATED O07: Device query for '0xa4c1385a489543a6/1' complete
              zigbee.0
              2025-09-05 11:19:51.637	warn	ELEVATED:I01 (d155) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":27392,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":91,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":237,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:19:51.645	warn	ELEVATED:I01 (d155) message received '{"linkquality":91}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:19:51.645	warn	ELEVATED:I02 (d155) value generated '91' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:20:21.663	warn	ELEVATED:I01 (469e) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":27904,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":87,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":238,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:20:21.668	warn	ELEVATED:I01 (469e) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:20:21.669	warn	ELEVATED:I02 (469e) value generated '87' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:20:51.688	warn	ELEVATED:I01 (bbe8) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":28416,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":91,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":239,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:20:51.698	warn	ELEVATED:I01 (bbe8) message received '{"linkquality":91}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:20:51.698	warn	ELEVATED:I02 (bbe8) value generated '91' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:21:03.501	warn	ELEVATED:I01 (ea0d) Zigbee Event of Type attributeReport from device 0xa4c1385a489543a6, incoming event: {"type":"attributeReport","data":{"65506":54,"65508":0,"appVersion":70},"linkquality":91,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":240,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:21:03.509	warn	ELEVATED:NOCONV (ea0d) No converter available for 'TS0601_garage_door_opener' 'a4c1385a489543a6' with cluster 'genBasic' and type 'attributeReport'
              zigbee.0
              2025-09-05 11:21:03.510	warn	ELEVATED:I01 (ea0d) message received '{"linkquality":91}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:21:03.511	warn	ELEVATED:I02 (ea0d) value generated '91' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:21:21.710	warn	ELEVATED:I01 (312e) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":28928,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":87,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":241,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:21:21.716	warn	ELEVATED:I01 (312e) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:21:21.716	warn	ELEVATED:I02 (312e) value generated '87' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:21:51.733	warn	ELEVATED:I01 (a674) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":29440,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":87,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":242,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:21:51.740	warn	ELEVATED:I01 (a674) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:21:51.741	warn	ELEVATED:I02 (a674) value generated '87' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:22:21.758	warn	ELEVATED:I01 (1bbd) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":29952,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":87,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":243,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:22:21.763	warn	ELEVATED:I01 (1bbd) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:22:21.764	warn	ELEVATED:I02 (1bbd) value generated '87' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:22:51.782	warn	ELEVATED:I01 (9106) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":30464,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":91,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":244,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:22:51.790	warn	ELEVATED:I01 (9106) message received '{"linkquality":91}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:22:51.791	warn	ELEVATED:I02 (9106) value generated '91' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:23:21.798	warn	ELEVATED:I01 (0646) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":30976,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":83,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":245,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:23:21.806	warn	ELEVATED:I01 (0646) message received '{"linkquality":83}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:23:21.807	warn	ELEVATED:I02 (0646) value generated '83' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:23:51.830	warn	ELEVATED:I01 (7b96) Zigbee Event of Type commandDataReport from device 0xa4c1385a489543a6, incoming event: {"type":"commandDataReport","data":{"seq":31488,"dpValues":[{"dp":3,"datatype":1,"data":{"type":"Buffer","data":[0]}}]},"linkquality":87,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":246,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:23:51.837	warn	ELEVATED:I01 (7b96) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:23:51.838	warn	ELEVATED:I02 (7b96) value generated '87' from device a4c1385a489543a6 for 'Link quality'
              zigbee.0
              2025-09-05 11:24:03.228	warn	ELEVATED:I01 (a81b) Zigbee Event of Type attributeReport from device 0xa4c1385a489543a6, incoming event: {"type":"attributeReport","data":{"65506":54,"65508":0,"appVersion":70},"linkquality":87,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":247,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
              zigbee.0
              2025-09-05 11:24:03.242	warn	ELEVATED:NOCONV (a81b) No converter available for 'TS0601_garage_door_opener' 'a4c1385a489543a6' with cluster 'genBasic' and type 'attributeReport'
              zigbee.0
              2025-09-05 11:24:03.243	warn	ELEVATED:I01 (a81b) message received '{"linkquality":87}' from device a4c1385a489543a6 type 'TS0601_garage_door_opener'
              zigbee.0
              2025-09-05 11:24:03.243	warn	ELEVATED:I02 (a81b) value generated '87' from device a4c1385a489543a6 for 'Link quality'
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @throstenk An der Stelle bin ich raus. Das Gerät meldet die Daten
                es melded für den Sensor (DP 3) den Wert false (0), der Konverter erzeugt daraus aber keinen Payload für den Adapter. (bzw. nur den Payload für die link quality)
                Ohne ein physikalisches Gerät kann ich da nicht weiter schauen.
                A.
                  A.
                  throstenkT Offline
                  throstenkT Offline
                  throstenk
                  @asgothian ok das ist schlecht - aber trotzdem Danke für deine Zeit und mühen....
                  denke ich sollte mir einen anderen Toröffner organisieren - hättest du eine Empfehlung für mich wichtig wäre der Status vom Tor offen oder zu?
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @throstenk sagte in Zigbee Garagentoröffner PJ-ZGD01 fehlerhaft:
                    wenn die Funktion ansonsten gut ist, würde ich das Thema 'tor offen / tor zu' mit 2 einfachen Tür/Fenstersensoren überwachen. 2, damit du sowohl 'ganz offen' als auch 'ganz zu' hast.
                    Ich hab den Anwendungsfall nicht, deswegen kann ich da kein Gerät empfehlen. Mit der Verbindung sollte es aber gehen - die Autoren arbeiten ja als Router. Und auch die Alarm / Zeitschalt-Funktion sollte durchaus weiter klappen - die macht das Gerät ja selber. Solltest du ggf. testen.
                    A.
                      A.
                      throstenkT Offline
                      throstenkT Offline
                      throstenk
                      @asgothian Seit ich heute das Update auf v3.1.4 gemacht haben funktioniert wieder alles wurde scheinbar mit gefixt.
                      Vielen Dank für deinen Support und die Zeit - Danke!! Lg. Thorsten
