  3. Einsteigerfragen
  4. [gelöst] - Backitup - EACCES: permission denied
    5.3k
4 Beiträge 2 Kommentatoren 388 Aufrufe 2 Beobachtet
  • CyberraphC Online
    CyberraphC Online
    Cyberraph
    schrieb am zuletzt editiert von Cyberraph
    Hallo zusammen!
    Nach Updates zuletzt im iobroker, will mein Backitup nicht mehr, der sonst problemlos immer durchgelaufen ist.
    Backitup gibt folgendes aus:
    21:40:13.860
    INFO
    gui
    Backup gestartet ...
    21:40:23.940
    DEBUG
    mount
    cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup /opt/iobroker/backups"
    21:40:23.990
    DEBUG
    mount
    mount successfully completed
    21:40:23.999
    DEBUG
    mount
    done
    21:40:27.580
    DEBUG
    iobroker
    host.iobroker 16346 objects saved
    21:40:28.215
    DEBUG
    iobroker
    host.iobroker Validating backup ...
    21:40:28.257
    DEBUG
    iobroker
    host.iobroker "config.json" is valid
    21:40:28.264
    DEBUG
    iobroker
    host.iobroker "objects.jsonl" exists
    host.iobroker "states.jsonl" exists
    21:40:28.559
    DEBUG
    iobroker
    host.iobroker JSONL lines are valid
    21:40:28.599
    DEBUG
    iobroker
    host.iobroker The backup is valid!
    21:40:28.911
    ERROR
    iobroker
    host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_12-21_40_25_backupiobroker.tar.gz'
    21:40:28.939
    DEBUG
    iobroker
    Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_12-21_40_25_backupiobroker.tar.gz'
    21:40:29.981
    DEBUG
    iobroker
    done
    21:40:30.139
    DEBUG
    influxDB
    InfluxDB-Backup started ...
    21:40:30.142
    DEBUG
    influxDB
    Start InfluxDB Backup ...
    21:40:30.208
    WARN
    influxDB
    InfluxDB Backup tmp directory cannot created
    21:40:30.239
    DEBUG
    influxDB
    InfluxDB Backup tmp directory created
    21:40:30.348
    DEBUG
    influxDB
    done
    21:40:31.078
    DEBUG
    historyDB
    compress from historyDB started ...
    21:40:31.156
    ERROR
    historyDB
    Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_12-21_40_32_backupiobroker.tar.gz'
    iob diag gibt folgendes aus:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Static hostname: iobroker
          Icon name: computer
             Kernel: Linux 6.12.34+rpt-rpi-2712
       Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
    21:56:49 up 24 days,  6:06,  2 users,  load average: 0.36, 0.28, 0.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                  Local time: Fri 2025-09-12 21:56:49 CEST
              Universal time: Fri 2025-09-12 19:56:49 UTC
                    RTC time: Fri 2025-09-12 19:56:49
                   Time zone: Europe/Vienna (CEST, +0200)
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        3.3G        1.1G        5.2M        4.3G        5.2G
    Swap:           209M         29M        180M
    Total:          8.7G        3.3G        1.3G
    Active iob-Instances:   26
            8063 M total memory
            3129 M used memory
            3091 M active memory
            3324 M inactive memory
            1047 M free memory
             209 M buffer memory
            3898 M swap cache
             199 M total swap
              27 M used swap
             172 M free swap
    top - 21:56:49 up 24 days,  6:06,  2 users,  load average: 0.36, 0.28, 0.25
    Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.2 total,   1047.0 free,   3129.4 used,   4107.7 buff/cache
    MiB Swap:    200.0 total,    172.0 free,     28.0 used.   4933.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                                         Type      Size  Used Avail Use% Mounted on
    udev                                               devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                                              tmpfs     1.6G  5.3M  1.6G   1% /run
    /dev/mmcblk0p2                                     ext4       59G   17G   39G  31% /
    tmpfs                                              tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs                                              tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1                                     vfat      510M   66M  445M  13% /boot/firmware
    tmpfs                                              tmpfs     807M     0  807M   0% /run/user/1000
    //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup cifs       58G   19G   39G  33% /opt/iobroker/backups
    [Tue Aug 19 15:50:15 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:3A:99 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=c4e97527-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 19 15:50:18 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Tue Aug 19 15:50:21 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
    Show mounted filesystems:
    TARGET                  SOURCE                                             FSTYPE OPTIONS
    /                       /dev/mmcblk0p2                                     ext4   rw,noatime
    |-/boot/firmware        /dev/mmcblk0p1                                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/opt/iobroker/backups //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=iobroker,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,reparse=nfs,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    5.0G    /var/
    4.0G    /var/log/journal/f74ba98ec8ff4148b6d00ad2f3b131b8
    4.0G    /var/log
    581M    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    13G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.1G    /opt/iobroker/iobroker-data/
    3.4G    /opt/iobroker/iobroker-data/history
    625M    /opt/iobroker/iobroker-data/files
    120M    /opt/iobroker/iobroker-data/files/vis-2
    109M    /opt/iobroker/iobroker-data/backup-objects
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
     Installed: 20.19.5-1nodesource1
     Candidate: 20.19.5-1nodesource1
     Version table:
    *** 20.19.5-1nodesource1 600
           500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
        20.19.4-1nodesource1 600
        20.19.3-1nodesource1 600
        20.19.2-1nodesource1 600
        20.19.1-1nodesource1 600
        20.19.0-1nodesource1 600
        20.18.3-1nodesource1 600
        20.18.2-1nodesource1 600
        20.18.1-1nodesource1 600
        20.18.0-1nodesource1 600
        20.17.0-1nodesource1 600
        20.16.0-1nodesource1 600
        20.15.1-1nodesource1 600
        20.15.0-1nodesource1 600
        20.14.0-1nodesource1 600
        20.13.1-1nodesource1 600
        20.13.0-1nodesource1 600
        20.12.2-1nodesource1 600
        20.12.1-1nodesource1 600
        20.12.0-1nodesource1 600
        20.11.1-1nodesource1 600
        20.11.0-1nodesource1 600
        20.10.0-1nodesource1 600
        20.9.0-1nodesource1 600
        20.8.1-1nodesource1 600
        20.8.0-1nodesource1 600
        20.7.0-1nodesource1 600
        20.6.1-1nodesource1 600
        20.6.0-1nodesource1 600
        20.5.1-1nodesource1 600
        20.5.0-1nodesource1 600
        20.4.0-1nodesource1 600
        20.3.1-1nodesource1 600
        20.3.0-1nodesource1 600
        20.2.0-1nodesource1 600
        20.1.0-1nodesource1 600
        20.0.0-1nodesource1 600
        18.20.4+dfsg-1~deb12u1 500
           500 http://deb.debian.org/debian bookworm/main arm64 Packages
           500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 85204)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
     system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discord.0                : discord               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
     system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
     system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
     system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled
     system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
     system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
     system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
     system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
     system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
     system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
     system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
     system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
     system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
     system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker                                 -  enabled, port: 16021
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
     system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
     system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
     system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
     system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
     system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
     system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
     system.adapter.vis-homekittiles.0       : vis-homekittiles      : iobroker                                 -  enabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
     system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
     system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
     system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
     system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
     system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
     system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
     system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.67:6638
     system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "discord"      : 2.5.2    , installed 2.5.2
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:        16340
    States:         13744
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 https://apt.grafana.com stable InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        6469       796/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       123356888  2152601/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5781       806/sshd: /usr/sbin
    tcp        0      0 192.168.178.63:42010    0.0.0.0:*               LISTEN      1001       123356578  2152349/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123356413  2152238/iobroker.js
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123356418  2152238/iobroker.js
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        6470       796/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5783       806/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6628       932/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       128061511  2682213/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      1002       55983093   2915703/node
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       123358709  2152636/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        17383340   2207681/grafana
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        594        680/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       123359752  2152933/io.nanoleaf
    udp        0      0 0.0.0.0:38818           0.0.0.0:*                           104        596        680/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       123356797  2152516/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       123356798  2152516/io.tuya.0
    udp6       0      0 :::5353                 :::*                                104        595        680/avahi-daemon: r
    udp6       0      0 :::37333                :::*                                104        597        680/avahi-daemon: r
    2025-09-12 20:35:05.668  - info: tuya.0 (2152516) 304060208cce4e172808 Init with IP=192.168.178.53, Key=d3)<N]x)(RNs5ST+, Version=3.3
    2025-09-12 20:41:59.228  - info: web.0 (2152636) <== Disconnect system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:42:00.576  - info: web.0 (2152636) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:42:02.820  - info: web.0 (2152636) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:42:02.855  - info: web.0 (2152636) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:42:04.245  - info: admin.0 (2682213) <== Disconnect system.user.admin from ::ffff:192.168.178.49 admin
    2025-09-12 20:42:04.348  - info: admin.0 (2682213) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:42:04.360  - info: admin.0 (2682213) <== Disconnect system.user.admin from ::ffff:192.168.178.49 admin
    2025-09-12 20:42:05.116  - info: admin.0 (2682213) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 20:49:08.496  - info: tuya.0 (2152516) 304060208cce4e1594e2: Connect locally to device
    2025-09-12 20:49:08.496  - info: tuya.0 (2152516) 304060208cce4e1594e2 Init with IP=192.168.178.57, Key=/D/7+YZrz<.Q<:Fh, Version=3.3
    2025-09-12 21:19:30.670  - info: tuya.0 (2152516) 304060208cce4e172808: Connect locally to device
    2025-09-12 21:19:30.671  - info: tuya.0 (2152516) 304060208cce4e172808 Init with IP=192.168.178.53, Key=d3)<N]x)(RNs5ST+, Version=3.3
    2025-09-12 21:39:37.306  - info: admin.0 (2682213) ==> Connected system.user.admin from ::ffff:192.168.178.49
    2025-09-12 21:40:29.870  - error: backitup.0 (2683938) [iobroker/iobroker] host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_12-21_40_25_backupiobroker.tar.gz'
    2025-09-12 21:40:29.870  - error: backitup.0 (2683938) [iobroker/iobroker] host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_12-21_40_25_backupiobroker.tar.gz'
    2025-09-12 21:40:31.168  - warn: backitup.0 (2683938) [iobroker/influxDB] InfluxDB Backup tmp directory cannot created
    2025-09-12 21:40:31.270  - error: backitup.0 (2683938) [iobroker/influxDB] Error: Command failed: influx backup --bucket iobroker -t O368abb_Buecyhi_9ieojUWVItur1vPXt43YPLUrGRn68ZsFJ6UqY_iNqLVEJ9B9ydea56v8yNyTcRstO_DFsA== "/opt/iobroker/backups/influxDB_2025_09_12-21_40_31_backupiobroker"
    2025-09-12 21:40:31.271  - error: backitup.0 (2683938) [iobroker/influxDB] Error: mkdir /opt/iobroker/backups/influxDB_2025_09_12-21_40_31_backupiobroker: permission denied
    2025-09-12 21:40:31.271  - error: backitup.0 (2683938) [iobroker] Error: Command failed: influx backup --bucket iobroker -t O368abb_Buecyhi_9ieojUWVItur1vPXt43YPLUrGRn68ZsFJ6UqY_iNqLVEJ9B9ydea56v8yNyTcRstO_DFsA== "/opt/iobroker/backups/influxDB_2025_09_12-21_40_31_backupiobroker"
    2025-09-12 21:40:32.086  - error: backitup.0 (2683938) [iobroker/historyDB] Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_12-21_40_32_backupiobroker.tar.gz'
    2025-09-12 21:40:32.086  - error: backitup.0 (2683938) [iobroker] Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_12-21_40_32_backupiobroker.tar.gz'
    2025-09-12 21:45:17.192  - info: admin.0 (2682213) <== Disconnect system.user.admin from ::ffff:192.168.178.49 backitup
    iob diag has finished.
    Es steht was von "open..." file, aber das existiert ja nicht, da backitup es nicht erstellen kann.
    Ich verstehe es leider nicht ganz mit meinen Anfängerskills.
    Ergänzung mein Setup bzgl. Backup-Speicherung:
    -> iobroker läuft auf einem RPI5
    -> Backup speichere ich im Netzwerk auf einen externen USB Stick "sozusagen NAS" an meinem Fritzbox Modem
    Könnte ggf. sein (warum auch immer), dass iobroker nicht mehr auf den USB Stick zugreifen kann, weil "Access" / Passwort falsch.
    Aber das verstehe ich nicht, da es keine Änderungen gab.
    Sorry für meine wohl dumme Frage.
    Aber ich danke für jede Hilfe.
    Beste Grüße!
    io-Broker Neuling 2024 :-)
    Bislang jedoch einiges an Beiträgen und Grundlagen eingeflößt, um etwas besser empor zu irren.
    • CyberraphC Cyberraph
      Hallo zusammen!
      21:40:13.860
      INFO
      gui
      21:40:23.940
      DEBUG
      mount
      21:40:23.990
      DEBUG
      mount
      21:40:23.999
      DEBUG
      mount
      done
      21:40:27.580
      DEBUG
      iobroker
      21:40:28.215
      DEBUG
      iobroker
      21:40:28.257
      DEBUG
      iobroker
      21:40:28.264
      DEBUG
      iobroker
      21:40:28.559
      DEBUG
      iobroker
      21:40:28.599
      DEBUG
      iobroker
      21:40:28.911
      ERROR
      iobroker
      21:40:28.939
      DEBUG
      iobroker
      21:40:29.981
      DEBUG
      iobroker
      done
      21:40:30.139
      DEBUG
      influxDB
      21:40:30.142
      DEBUG
      influxDB
      21:40:30.208
      WARN
      influxDB
      21:40:30.239
      DEBUG
      influxDB
      21:40:30.348
      DEBUG
      influxDB
      done
      21:40:31.078
      DEBUG
      historyDB
      21:40:31.156
      ERROR
      historyDB
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
            Icon name: computer
         Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                   NTP service: active
               RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M         29M        180M
              8063 M total memory
              3129 M used memory
              1047 M free memory
               209 M buffer memory
              3898 M swap cache
               199 M total swap
                27 M used swap
               172 M free swap
      *** FILESYSTEM ***
      /var:
      5.0G    /var/
      4.0G    /var/log
      581M    /var/lib
      USB-Devices by-id:
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16340
      States:         13744
      Pending Updates: 0
      @cyberraph
      Da stimmt aber auch noch anderes nicht.
      iob stop
      iob fix
      iob start
      Dann zeig mal die Einstellungen im Adapter zum cifs-mount. Sollte so aussehen:
      CyberraphC 1 Antwort Letzte Antwort
        @cyberraph
        iob stop
        iob fix
        iob start
        CyberraphC Online
        CyberraphC Online
        Cyberraph
        Einstellungen waren zuvor bei mir so:
        Nach Änderung auf deine Einstellungen leider noch Fehler beim Backup Erstellen:
        17:54:04.037
        INFO
        gui
        17:54:14.107
        DEBUG
        mount
        cifs-mount command: "sudo mount -t cifs -o username=fritz1470,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup /opt/iobroker/backups"
        17:54:14.164
        DEBUG
        mount
        17:54:14.211
        DEBUG
        mount
        done
        17:54:17.685
        DEBUG
        iobroker
        17:54:18.249
        DEBUG
        iobroker
        host.iobroker 13744 states saved
        17:54:18.286
        DEBUG
        iobroker
        17:54:18.325
        DEBUG
        iobroker
        17:54:18.741
        DEBUG
        iobroker
        17:54:19.015
        ERROR
        iobroker
        host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_13-17_54_15_backupiobroker.tar.gz'
        17:54:19.020
        DEBUG
        iobroker
        Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_13-17_54_15_backupiobroker.tar.gz'
        17:54:20.149
        DEBUG
        iobroker
        done
        17:54:20.207
        DEBUG
        influxDB
        17:54:20.215
        DEBUG
        influxDB
        17:54:20.263
        WARN
        influxDB
        17:54:20.371
        DEBUG
        influxDB
        17:54:20.408
        DEBUG
        influxDB
        done
        17:54:21.125
        DEBUG
        historyDB
        17:54:21.208
        ERROR
        historyDB
        Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_13-17_54_22_backupiobroker.tar.gz'
        Hab mal iob stop / iob fix / iob start gemacht wie folgt:
        Windows PowerShell
        Copyright (C) Microsoft Corporation. Alle Rechte vorbehalten.
        Installieren Sie die neueste PowerShell für neue Funktionen und Verbesserungen! https://aka.ms/PSWindows
        PS C:\Users\rapha> ssh pi@iobroker
        pi@iobroker's password:
        Linux iobroker 6.12.34+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64
        permitted by applicable law.
        Last login: Fri Sep 12 23:36:01 2025 from 192.168.178.49
        pi@iobroker:~ $ sudo systemctl status iobroker
        ● iobroker.service - ioBroker Server
            Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
            Active: active (running) since Thu 2025-09-11 22:16:46 CEST; 1 day 19h ago
              Docs: http://iobroker.net
          Main PID: 2152238 (iobroker.js-con)
             Tasks: 287 (limit: 9579)
               CPU: 7h 13min 56.595s
            CGroup: /system.slice/iobroker.service
                    ├─2152238 iobroker.js-controller
                    ├─2152305 io.javascript.0
                    ├─2152322 io.history.0
                    ├─2152349 io.hm-rpc.0
                    ├─2152387 io.hm-rega.0
                    ├─2152406 io.alexa2.0
                    ├─2152424 io.discord.0
                    ├─2152471 io.lgtv.0
                    ├─2152486 io.denon.0
                    ├─2152516 io.tuya.0
                    ├─2152531 io.ping.0
                    ├─2152548 io.fullybrowser.0
                    ├─2152566 io.fronius.0
                    ├─2152584 io.mqtt.0
                    ├─2152601 io.shelly.0
                    ├─2152616 io.discovery.0
                    ├─2152636 io.web.0
                    ├─2152671 io.echarts.0
                    ├─2152689 io.moma.0
                    ├─2152870 io.vis-inventwo.0
                    ├─2152891 io.iot.0
        pi@iobroker:~ $ iob stop
        × iobroker.service - ioBroker Server
            Active: failed (Result: exit-code) since Sat 2025-09-13 17:57:14 CEST; 2s ago
          Duration: 1d 19h 40min 21.160s
           Process: 2152238 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js>
          Main PID: 2152238 (code=exited, status=1/FAILURE)
               CPU: 7h 14min 4.845s
        Sep 13 17:57:09 iobroker bash[2152238]: ================================== > LOG REDIRECT system.adapter.javascript.0 =>
        Sep 13 17:57:09 iobroker bash[2152238]: ================================== > LOG REDIRECT system.adapter.admin.0 => fal>
        Sep 13 17:57:09 iobroker bash[2152238]: ================================== > LOG REDIRECT system.adapter.iot.0 => false>
        Sep 13 17:57:14 iobroker systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
        Sep 13 17:57:14 iobroker systemd[1]: iobroker.service: Failed with result 'exit-code'.
        Sep 13 17:57:14 iobroker systemd[1]: Stopped iobroker.service - ioBroker Server.
        Sep 13 17:57:14 iobroker systemd[1]: iobroker.service: Consumed 7h 14min 4.845s CPU time.
        pi@iobroker:~ $ iob fix
        library: loaded
        Library version=2025-08-09
           Welcome to the ioBroker installation fixer!
           Script version: 2025-08-09
           You might need to enter your password a couple of times.
           Installing prerequisites (1/5)
        OK:1 https://repos.influxdata.com/debian stable InRelease
        OK:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Holen:3 http://security.debian.org/debian-security bookworm-security InRelease [48,0 kB]
        OK:4 http://deb.debian.org/debian bookworm InRelease
        Holen:5 https://apt.grafana.com stable InRelease [7.661 B]
        OK:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Holen:7 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB]
        Holen:8 http://security.debian.org/debian-security bookworm-security/main armhf Packages [259 kB]
        OK:9 https://repo.mosquitto.org/debian bookworm InRelease
        Es wurden 370 kB in 1 s geholt (603 kB/s).
        Trigger für man-db (2.11.2-2) werden verarbeitet ...eb12u1_arm64.deb ...iert.)
        Installed distro-info
           Checking ioBroker user and directory permissions (2/5)
        This system does not support setting default permissions.
        Do not use npm to manually install adapters unless you know what you are doing!
           Check and cleanup npm temporary directories (3/5)
        Done.
           Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
           Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
           Your installation was fixed successfully
           Run iobroker start to start ioBroker again!
        pi@iobroker:~ $ iob start
            Active: active (running) since Sat 2025-09-13 17:58:40 CEST; 3s ago
          Main PID: 3224319 (iobroker.js-con)
             Tasks: 23 (limit: 9579)
               CPU: 4.739s
                    ├─3224319 iobroker.js-controller
                    ├─3224337 io.admin.0
                    └─3224352 su root
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-map.0" for host "iobroker"
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-timeandweather.0" for host "io>
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-fancyswitch.0" for host "iobro>
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-keyboard.0" for host "iobroker"
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-inventwo.0" for host "iobroker"
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.sayit.0" for host "iobroker"
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.iot.0" for host "iobroker"
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.nanoleaf-lightpanels.0" for host ">
        Sep 13 17:58:42 iobroker bash[3224319]: host.iobroker check instance "system.adapter.vis-colorpicker.0" for host "iobro>
        Sep 13 17:58:44 iobroker su[3224352]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=io>
        pi@iobroker:~ $
        Hmh komisch leider noch immer der Fehler bei "Iobroker-Backup Starten" über Backitup.
        18:01:29.499
        INFO
        gui
        18:01:39.651
        DEBUG
        mount
        18:01:39.676
        DEBUG
        mount
        18:01:39.682
        DEBUG
        mount
        done
        18:01:43.537
        DEBUG
        iobroker
        18:01:44.092
        DEBUG
        iobroker
        host.iobroker 13763 states saved
        18:01:44.100
        DEBUG
        iobroker
        18:01:44.466
        DEBUG
        iobroker
        18:01:44.484
        DEBUG
        iobroker
        18:01:44.922
        ERROR
        iobroker
        host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_13-18_01_41_backupiobroker.tar.gz'
        18:01:45.176
        DEBUG
        iobroker
        Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_13-18_01_41_backupiobroker.tar.gz'
        18:01:46.166
        DEBUG
        iobroker
        done
        18:01:46.344
        DEBUG
        influxDB
        18:01:46.410
        WARN
        influxDB
        18:01:46.432
        DEBUG
        influxDB
        [DEBUG] [influxDB] -
        18:01:46.559
        DEBUG
        influxDB
        done
        18:01:47.326
        ERROR
        historyDB
        Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_13-18_01_48_backupiobroker.tar.gz'
        Jetzt habe ich es nochmal gegengecheckt, ob auch wirklich Benutzer und Passwort stimmen für das "NAS" = USB-Stick an der Fritzbox.
        Das stimmt bzw. Passwort nochmal neu angelegt damit ich sicher bin und neu / korrekt hinterlegt.
        Weiterhin fehler beim Backup Erstellen:
        18:18:01.404
        INFO
        gui
        18:18:11.455
        DEBUG
        mount
        cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup /opt/iobroker/backups"
        18:18:11.510
        DEBUG
        mount
        18:18:11.554
        DEBUG
        mount
        done
        18:18:15.071
        DEBUG
        iobroker
        18:18:15.787
        DEBUG
        iobroker
        18:18:16.094
        DEBUG
        iobroker
        18:18:16.569
        DEBUG
        iobroker
        Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2025_09_13-18_18_13_backupiobroker.tar.gz'
        18:18:16.628
        ERROR
        iobroker
        [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/states.jsonl'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'open',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/states.jsonl'
        18:18:16.635
        ERROR
        iobroker
        [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'
        [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/energiefluss-erweitert.0/backup'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/energiefluss-erweitert.0/backup'
        18:18:17.514
        DEBUG
        iobroker
        done
        18:18:17.737
        DEBUG
        influxDB
        18:18:17.769
        WARN
        influxDB
        18:18:17.779
        DEBUG
        influxDB
        18:18:17.866
        DEBUG
        influxDB
        InfluxDB-Backup for is finish
        18:18:17.876
        DEBUG
        influxDB
        done
        18:18:18.601
        DEBUG
        historyDB
        18:18:18.662
        ERROR
        historyDB
        Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2025_09_13-18_18_20_backupiobroker.tar.gz'
        Hab auch nochmal auf dem Host geschaut bzgl. Rechte...
        In dem Verzeichnis, wo der Fehler sagt da gebe es Probleme mit den Zugriffsrecheten
        hat überall der Benutzer und die Gruppe "iobroker" alle Rechte.
        Sehr komisch, da es ja vor ein paar Wochen / vor ein paar Updates im iobroker und über apt normal lief.
        Das letzte Backup war vom 03.09.2025, das regulär durchlief.
        Beste Grüße!
        • CyberraphC Online
          CyberraphC Online
          Cyberraph
          Ich hab die Krux gefunden.
          Meine Fritzbox hat auf einmal keine Schreibberechtigung mehr auf dem NAS / dem UBS-Stick gehabt.
          Ich vermute es hat vielleicht mal eine Sicherung gehauen, oder Strom war weg, was dem nicht zuträglich war.
          Zuerst sah ich die Benutzer in der Fritzbox, die Vollberechtigung dem NAS zugeordnet hatte.
          Da war somit eigentlich kein Fehler.
          Dann sah ich auf einmal den Schriftzug auf der Fritzbox Oberfläche bei dem Menü des USB Sticks,
          er hätte keine Schreibberechtigung auf dem USB Stick
          (nur Leseberechtigung, daher zuerst die Verwirrung, weil ich über den PC "normal alles gesehen hatte").
          Somit sicher entfernt über "Ausgeben Knopf" in der Oberfläche.
          Ausgesteckt, eingesteckt.
          Und nun geht auch das Backup per BackitUP wieder reibungslos.
          SUPER 😬
          PS:
          Eine Meldung ging nach dem manuellen ioBroker Backitup Durchlauf noch im Protokoll auf.
          Aber dies sollte nicht gravierend sein.
          Beobachten werde ich die Meldung sicher noch, aber...
          Ich sehe über ioBroker/History/Grafana/CCU ect. alles schön auf dem USB Stick als Backup angelegt.
          Inkl. in der Aufstellung im BackitUp bei "Backup Liste anzeigen".
          backitup.0
          2025-09-20 18:16:03.048 error
          Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/KINGSTON/ioBroker_Backup /opt/iobroker/backupsmount
          error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          Beste Grüße!
