  4. InfluxDB
    5.8k
InfluxDB
conflictinfluxinfuxdb
14 Beiträge 5 Kommentatoren 5.3k Aufrufe 4 Beobachtet
  • R Rushmed
    habe heute meinen Influx Adapter auf 3.1.7 aktualisiert und bekomme seitdem häüfig diese Meldung:
    HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
    Was kann ich tun um das zu bereingen?
    @rushmed
    Gibt es da auch noch die vollständigen Zeilen davor und danach? Das sieht für mich nach etwas aus dem Zusammenhang gerissen aus. Welches Log ist das überhaupt?
    R 1 Antwort Letzte Antwort
      @rushmed
      Rushmed
      @thomas-braun Hier mal ein etwas größerer log Auszug:
      2022-07-20 22:49:43.928 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.5c0272fffe88b629.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature","min":250,"max":454},"native":{},"_id":"zigbee.0.5c0272fffe88b629.colortemp","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1656703796573}
      2022-07-20 22:49:43.929 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.5c0272fffe88b629.colortemp_move, sourceObj={"type":"state","common":{"name":"Colortemp change","type":"number","read":false,"write":true,"role":"state","min":-50,"max":50},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1656702673982,"_id":"zigbee.0.5c0272fffe88b629.colortemp_move","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.929 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.5c0272fffe88b629.transition_time, sourceObj={"type":"state","common":{"name":"Transition time","type":"number","unit":"sec","read":false,"write":true,"role":"state"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1656702673982,"_id":"zigbee.0.5c0272fffe88b629.transition_time","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.930 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.5c0272fffe88b629.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1656702673982,"_id":"zigbee.0.5c0272fffe88b629.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.934 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.0017880108ff0d07.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"max":100},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652201960898,"_id":"zigbee.0.0017880108ff0d07.brightness","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.935 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.0017880108ff0d07.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652201960897,"_id":"zigbee.0.0017880108ff0d07.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.936 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ec1bbdfffeb19154.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"max":100},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652202840199,"_id":"zigbee.0.ec1bbdfffeb19154.brightness","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.937 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ec1bbdfffeb19154.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652202840199,"_id":"zigbee.0.ec1bbdfffeb19154.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.938 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ec1bbdfffe94bbcb.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"max":100},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652205181033,"_id":"zigbee.0.ec1bbdfffe94bbcb.brightness","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.939 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ec1bbdfffe94bbcb.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652205181033,"_id":"zigbee.0.ec1bbdfffe94bbcb.colortemp","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.939 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=zigbee.0.ec1bbdfffe94bbcb.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1652205181033,"_id":"zigbee.0.ec1bbdfffe94bbcb.state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.940 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.WiFi-Plug11.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug11.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug11 POWER"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1620320875797,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2022-07-20 22:49:43.940 - error: admin.0 (926) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-1#8CAAB54BD7A3#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"smartName":false,"custom":{"influxdb.0":{"enabled":true,"storageType":"Boolean","aliasId":"","changesOnly":true,"debounce":1000,"changesRelogInterval":"3600","changesMinDelta":0}}},"native":{},"_id":"shelly.0.SHSW-1#8CAAB54BD7A3#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1658343582586}
      2022-07-20 22:49:44.049 - error: influxdb.0 (68151) HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
      2022-07-20 22:49:44.093 - error: influxdb.0 (68151) HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
      2022-07-20 22:49:44.101 - error: influxdb.0 (68151) HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
      2022-07-20 22:50:00.068 - info: host.Smartazamba instance system.adapter.weatherunderground.0 started with pid 68441
      2022-07-20 22:50:02.455 - info: weatherunderground.0 (68441) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.16.0, js-controller: 4.0.23
      2022-07-20 22:50:05.793 - error: influxdb.0 (68151) HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
      2022-07-20 22:50:12.653 - info: weatherunderground.0 (68441) Terminated (NO_ERROR): Without reason
      2022-07-20 22:50:13.183 - info: host.Smartazamba instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2022-07-20 22:50:13.801 - info: smartmeter.1 (1229) Received 97 values, 1 updated
      2022-07-20 22:50:19.777 - error: influxdb.0 (68151) HttpError: runtime error @4:12-4:157: filter: type conflict: bool != string
      2022-07-20 22:50:36.929 - info: smartmeter.0 (1205) Received 4 values, 2 updated
      2022-07-20 22:50:54.406 - info: linux-control.0 (1982) getting data from UDM_Pro (192.168.178.1:22)
      2022-07-20 22:50:54.473 - info: linux-control.0 (1982) successful received data from UDM_Pro (192.168.178.1:22)
      2022-07-20 22:51:24.678 - info: admin.0 (926) <== Disconnect system.user.admin from ::ffff:192.168.178.38 admin
      2022-07-20 22:51:25.246 - info: smartmeter.1 (1229) Received 97 values, 1 updated
      2022-07-20 22:51:26.299 - info: admin.0 (926) ==> Connected system.user.admin from ::ffff:192.168.178.38
      2022-07-20 22:51:29.822 - info: admin.0 (926) ==> Connected system.user.admin from ::ffff:192.168.178.38
      • R Rushmed
        @rushmed sagte in InfluxDB:
        Da kommen falsche Datentypen an.
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          @thomas-braun Ich finde in den Objektdaten leider keinen Fehler.
          Bspw. hier:
            "common": {
              "name": "WC Spiegel switch State",
              "type": "boolean",
              "role": "switch",
              "read": true,
              "write": true,
              "smartName": {
                "de": "WC Spiegel",
                "smartType": "LIGHT"
              "alias": {
                "id": "shelly.0.SHSW-1#8CAAB54BD7A3#1.Relay0.Switch"
              "custom": {
                "influxdb.0": {
                  "enabled": true,
                  "changesOnly": true,
                  "debounce": "",
                  "maxLength": 10,
                  "retention": "15811200",
                  "changesRelogInterval": "3600",
                  "changesMinDelta": "",
                  "storageType": "",
                  "aliasId": ""
            "native": {},
            "acl": {
              "object": 1636,
              "owner": "system.user.admin",
              "state": 1636
            "_id": "alias.0.WC_Spiegel_switch_State",
            "type": "state",
            "user": "system.user.admin",
            "ts": 1653158800169
          Jetzt bekomm ich die Meldung auch noch als Popup:
          • R Rushmed
            Bspw. hier:
              "common": {
                "type": "boolean",
                "role": "switch",
                "read": true,
                "write": true,
                "smartName": {
                  "de": "WC Spiegel",
                "alias": {
                "custom": {
                  "influxdb.0": {
                    "enabled": true,
                    "debounce": "",
                    "maxLength": 10,
                    "storageType": "",
                    "aliasId": ""
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636
              "type": "state",
              "ts": 1653158800169
            Sirfauntleroy
            @rushmed
            hast Du das Problem mittlerweile lösen können?
            Ich bekomme die gleiche Meldung und zwar zu dem Zeitpunkt, an dem ich die IO-Broker-App (Android) öffne und die Verbindung hergestellt wird.
            • S Sirfauntleroy
              @rushmed
              Rushmed
              @sirfauntleroy Ich habe das Problem nichtmehr. Wie das gelöst wurde weiß ich nicht mehr.
              • Ben1983B Offline
                Ben1983B Offline
                Ben1983
                schrieb am zuletzt editiert von Ben1983
                Ich habe die Fehlermeldung auch manchmal.
                Auf dem gleichen DP kommt die Meldung von 100 mal beschreiben zwischen 1-5 mal).
                In der Influx DB stehe die richtigen strings drin
                Oder das hier:
                influxdb.0
                2025-09-12 13:32:42.690	warn	Error on writePoint("{"value":20512,"time":"2025-09-12T11:32:42.624Z","from":"system.adapter.lorawan.1","q":0,"ack":true}): HttpError: failure writing points to database: partial write: field type conflict: input field "value" on measurement "lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex" is type float, already exists as type string dropped=1 / "failure writing points to database: partial write: field type conflict: input field \"value\" on measurement \"lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex\" is type float, already exists as type string dropped=1""
                influxdb.0
                2025-09-12 13:32:42.689	warn	Point could not be written to database: iobroker
                Der Datenpunkt:
                (Ist in einem String)
                • Ben1983B Ben1983
                  Oder das hier:
                  influxdb.0
                  influxdb.0
                  Der Datenpunkt:
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @ben1983 sagte in InfluxDB:
                  Das ist aber prinzipbedingt, Hex-Werte kann die InfluxDB nur als Strings speichern (wenn der Adapter diese nicht vorher als Dezimal umrechnet). Wenn dann ein Hex-Wert wie "020512" daher kommt, denkt die Datenbank, es sei ein float.
                  Wenn du das unfallfrei umsetzen willst, solltest du Hexwerte mit "0x" als Prefix speichern, also "0x020512".
                  • Marc BergM Marc Berg
                    Ben1983B Offline
                    Ben1983B Offline
                    Ben1983
                    @marc-berg ok.
                    Und was soll mir das hier sagen?
                    Das kommt einfach zwischendrin.
                    Auf den state wird nicht geschrieben, er steht nicht auf irgend einem zyklus... usw.
                    2025-09-12 14:06:56.848 - debug: influxdb.0 (85451) Point written to iobroker
                    2025-09-12 14:06:56.984 - debug: influxdb.0 (85451) Incoming message getHistory from system.adapter.admin.0
                    2025-09-12 14:06:56.984 - debug: influxdb.0 (85451) lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex17576788169840.9024760788821555 getHistory message: {"id":"lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex","options":{"instance":"influxdb.0","start":1757592000000,"end":1757678816918,"step":3600000,"from":false,"ack":false,"q":false,"addId":false,"aggregate":"minmax","user":"system.user.admin"}}
                    2025-09-12 14:06:56.986 - debug: influxdb.0 (85451) Query to execute:
                    from(bucket: "iobroker")
                    |> range(start: 2025-09-11T12:00:00.000Z, stop: 2025-09-12T12:06:56.918Z)
                    |> filter(fn: (r) => r["_field"] == "value")
                    |> filter(fn: (r) => r["_measurement"] == "lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex" and contains(value: r._value, set: [true, false]))
                    |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
                    |> group()
                    2025-09-12 14:06:56.996 - debug: influxdb.0 (85451) Query to execute: from(bucket: "iobroker")
                    |> range(start: 2024-09-11T12:00:00.000Z, stop: 2025-09-11T11:59:59.999Z)
                    |> filter(fn: (r) => r["_measurement"] == "lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex")
                    |> last()
                    2025-09-12 14:06:57.006 - debug: influxdb.0 (85451) Query to execute: from(bucket: "iobroker") |> range(start: 2025-09-11T12:00:00.000Z, stop: 2025-09-12T12:06:56.918Z) |> filter(fn: (r) => r["_measurement"] == "lorawan.1.bbea74d6-1fc5-4238-af20-d2aecdbb4f8e.devices.70b3d52dd301b3cc.downlink.lastSend.hex") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns:["_time"], desc: false)
                    2025-09-12 14:06:57.026 - debug: influxdb.0 (85451) Query to execute: from(bucket: "iobroker")
                    |> range(start: 2025-09-12T12:06:56.919Z)
                    |> first()
                    2025-09-12 14:06:57.039 - error: influxdb.0 (85451) HttpError: runtime error @5:12-5:197: filter: type conflict: bool != string
                    2025-09-12 14:06:58.018 - debug: influxdb.0 (85451) Write Point: alias.0.Allgemein.Leistung.WirkleistungGesamt values:{"value":-910.1451416015625,"time":"2025-09-12T12:06:58.009Z","from":"system.adapter.janitza-gridvis.0","q":0,"ack":true} options: null
                    2025-09-12 14:06:58.018 - debug: influxdb.0 (85451) Write Point: alias.0.Talstrasse1A.Zaehlerstaende.1A values:{"value":35147732,"time":"2025-09-12T12:06:58.009Z","from":"system.adapter.janitza-gridvis.0","q":0,"ack":true} options: null
                    2025-09-12 14:06:58.022 - debug: influxdb.0 (85451) Write Point: alias.0.Eigennutz.Zaehlerstaende.DirektverbrauchUndSpeicherentladung values:{"value":31713690,"time":"2025-09-12T12:06:58.010Z","from":"system.adapter.janitza-gridvis.0","q":0,"ack":true} options: null
                    2025-09-12 14:06:58.023 - debug: influxdb.0 (85451) Write Point: alias.0.PV+Speicher.Leistung.WirkleistungPv+Speicher values:{"value":-1842.1007080078125,"time":"2025-09-12T12:06:58.010Z","from":"system.adapter.janitza-gridvis.0","q":0,"ack":true} options: null
                    Der error ist ja auch irgendwie blöd, denn es steht ja nicht mal an welchem dp der error sit.
                    • Ben1983B Ben1983
                      @marc-berg ok.
                      |> group()
                      |> last()
                      |> first()
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      @ben1983
                      Das sind zwei ganz verschiedene Sachverhalte.
                      In deinem ersten Beispiel schreibst du Werte von deinem Adapter aus in die InfluxDB. Da die InfluxDB nur drei Datentypen kennt und beim ersten Schreiben eines Feldes der Datentyp festgelegt wird, bekommst du eine Fehlermeldung, sobald du einen numerischen Wert in ein mit "String" initialisiertes Feld schreiben willst. Diesen Fehler kannst du z.B. umgehen, indem du "0x" als Prefix verwendest. Damit ist für die DB klar, es ist ein String. Der User weiß, es ist ein Hex-Wert, was bei "1111" unmöglich wäre zu erkennen.
                      In zweiten Beispiel geht es um Abfragen auf die DB. Ich vermute, die Meldungen kommen, wenn du das History-Fenster im Admin öffnest. Diese Fehler können umgangen werden, indem man den Datentyp auf "automatic" stellt.
                      siehe https://github.com/ioBroker/ioBroker.influxdb/issues/435
                        @ben1983
                        Ben1983B Offline
                        Ben1983B Offline
                        Ben1983
                        @marc-berg OK,
                        wo kann ich Automatic einstzellen?
                        finde ich leider nicht.
                        1. Steht der Hextring in einem Adapter DP.
                          Da stehe immer hex werte drin.
                          aber der Adapter gibt es aus verschiedenen gründen nicht mit führenden 0x aus
                        • Ben1983B Ben1983
                          @marc-berg OK,
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          @marc-berg OK,
                          Zahnrad --> Custom Settings --> Store as
                          Der Adapter ist doch von dir, oder? Das lässt sich nicht ändern?
                            @marc-berg OK,
                            Ben1983B Offline
                            Ben1983B Offline
                            Ben1983
                            @marc-berg
                            influxdb.0
                            2025-09-12 15:25:45.498	warn	Error on writePoint("{"value":0,"time":"2025-09-12T13:25:45.455Z","from":"system.adapter.admin.0","q":0,"ack":false}): HttpError: failure writing points to database: partial write: field type conflict: input field "value" on measurement "0_userdata.0._Test.Teststring" is type float, already exists as type string dropped=1 / "failure writing points to database: partial write: field type conflict: input field \"value\" on measurement \"0_userdata.0._Test.Teststring\" is type float, already exists as type string dropped=1""
                            influxdb.0
                            2025-09-12 15:25:45.497	warn	Point could not be written to database: iobroker
                            Also meines Erachtens sollte hier bei einem Typ String (egal was drin steht, auch immer string erkannt werden, oder?
                            Übrigens.... stellt man auf Automatisch, dann wird ein string rein geschrieben, dann ändert es sich wieder auf text
